[Live-demo] make translation easier - define software version in conf.py
Cameron Shorter cameron.shorter at gmail.com
Fri Dec 5 01:02:59 PST 2014
Hi Astrid,
You bring up a valid concern.
There is a reason that we currently prefer version numbers to be hard
coded into the Project Overview text instead of by using a variable.
We wish to verify that if an application has been updated, then someone
has assessed whether the Project Overview has been looked at and
updated. We do this by checking svn timestamps on the
<project>_overview.rst. If the version number changes, then the
<project>_overview.rst should change too. If the version number is
stored in a conf.py file instead, then we will need to think of another
way to check that each ProjectOverview has been reviewed and updated.
I'm open to suggestions.
We could relatively easily write a script which loops through all
translations and updates the version number to the English master version.
On 4/12/2014 5:50 pm, Astrid Emde wrote:
> Hello,
> I do not know, whether you discussed this before.
> Before each OSGeo-Live version comes out the translators have to edit
> many files and sometimes only have to change the version of the software.
> Things are much easier and less work, if the version is only defined at
> one place as a variable and the version is used in all the overview
> translations.
> Some projects use this way already and I would like to encourage more
> projects to make it this way.
> Have a look at:
> http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/doc/conf.py
> 1.)  f.e. define  |version-geoserver| replace:: 2.5
> 2.) and refer in the xx_overview.rst like this
> http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/doc/de/overview/geoserver_overview.rst
> **Software Version:** |version-geoserver|
> Like this only changes in the text of the overview document have to be
> translated for every new version.
> Astrid
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter,
Software and Data Solutions Manager
LISAsoft
Suite 112, Jones Bay Wharf,
26 - 32 Pirrama Rd, Pyrmont NSW 2009
P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
More information about the Live-demo mailing list
