[Live-demo] make translation easier - define software version	in conf.py
    Ko Nagase
    nagase at georepublic.co.jp
    Mon Dec  8 23:36:23 PST 2014
Hi list,
I am not sure whether my question is related with separating version
number definition,
but is there some plan about "gettext" tool (*.pot .etc) based
translation workflow
like the following MapServer documentation development guide links ?
http://mapserver.org/el/development/documentation.html#the-old-way-for-translations
http://mapserver.org/el/development/documentation.html#the-standard-internationalization-system-i18n-for-translations
Regards,
2014-12-09 16:22 GMT+09:00 Astrid Emde <astrid.emde at wheregroup.com>:
> Hello Cameron,
> thanks for your answer.
> Maybe we could check conf.py for changes too and define a rule for
> commit messages like - "version mapbender3 changed, final 8.5"
> If something in the text of the overview files changes it still means
> that the translators must have a look and translate.
> I like your idea to loop through all translations and updates the
> version number to the English master version.
> Astrid
> Am 05.12.2014 10:02, schrieb Cameron Shorter:
>> Hi Astrid,
>> You bring up a valid concern.
>> There is a reason that we currently prefer version numbers to be hard
>> coded into the Project Overview text instead of by using a variable.
>> We wish to verify that if an application has been updated, then
>> someone has assessed whether the Project Overview has been looked at
>> and updated. We do this by checking svn timestamps on the
>> <project>_overview.rst. If the version number changes, then the
>> <project>_overview.rst should change too. If the version number is
>> stored in a conf.py file instead, then we will need to think of
>> another way to check that each ProjectOverview has been reviewed and
>> updated.
>> I'm open to suggestions.
>> We could relatively easily write a script which loops through all
>> translations and updates the version number to the English master
>> version.
>> On 4/12/2014 5:50 pm, Astrid Emde wrote:
>>> Hello,
>>> I do not know, whether you discussed this before.
>>> Before each OSGeo-Live version comes out the translators have to edit
>>> many files and sometimes only have to change the version of the
>>> software.
>>> Things are much easier and less work, if the version is only defined at
>>> one place as a variable and the version is used in all the overview
>>> translations.
>>> Some projects use this way already and I would like to encourage more
>>> projects to make it this way.
>>> Have a look at:
>>> http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/doc/conf.py
>>> 1.)  f.e. define  |version-geoserver| replace:: 2.5
>>> 2.) and refer in the xx_overview.rst like this
>>> http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/doc/de/overview/geoserver_overview.rst
>>> **Software Version:** |version-geoserver|
>>> Like this only changes in the text of the overview document have to be
>>> translated for every new version.
>>> Astrid
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> http://live.osgeo.org
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Where2B Konferenz 2014
> 11. Dezember 2014 in Bonn
> www.where2b-conference.com
>  Astrid Emde
>  WhereGroup GmbH & Co.KG
>  Eifelstraße 7
>  53119 Bonn
>  Germany
>  Fon: +49(0)228 90 90 38 - 19
>  Fax: +49(0)228 90 90 38 - 11
>  www.wheregroup.com
>  Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
>  pgp-public key:
>  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>   Signed and/or encrypted mail is highly appreciated
Ko Nagase (長瀬 興)
Georepublic Japan
mail: nagase at georepublic.co.jp
web: http://georepublic.co.jp
More information about the Live-demo
