[Live-demo] OSGeo Live 8.5 translation deadline
Ko Nagase nagase at georepublic.co.jp
Sat Jan 31 05:47:43 PST 2015
Hi list,
Is OSGeo Live 8.5 translation deadline just February 2nd (next 48 hours) ?
https://docs.google.com/a/georepublic.de/spreadsheet/ccc?key=0Al9zh8DjmU_RdE1SYUN3YWJ2N1NpSUczbW9IRWZNclE&usp=drive_web#gid=0
By the way, I wrote that I will try to "gettext" tool (*.pot .etc) in
previous mail,
but, I didn't have much time to do that in these months...
So, about ver 8.5 Japanese translation, I am thinking to do it by current way.
Regards,
2014-12-10 18:16 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
> Hi Cameron,
> Thanks for answer.
> 2014-12-10 4:54 GMT+09:00 Cameron Shorter <cameron.shorter at gmail.com>:
>> The OSGeo-Live translation process is currently linked from:
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc#Translate
>> While it seems to mostly work, I acknowledge that there is likely a better
>> way to do things, and if someone would like to step up and implement a
>> better process, then that would be great.
> Okay.
> I will try to think about it more, later.
> Thanks,
>> On 9/12/2014 6:36 pm, Ko Nagase wrote:
>>> Hi list,
>>> I am not sure whether my question is related with separating version
>>> number definition,
>>> but is there some plan about "gettext" tool (*.pot .etc) based
>>> translation workflow
>>> like the following MapServer documentation development guide links ?
>>> http://mapserver.org/el/development/documentation.html#the-old-way-for-translations
>>> http://mapserver.org/el/development/documentation.html#the-standard-internationalization-system-i18n-for-translations
>>> Regards,
>>> 2014-12-09 16:22 GMT+09:00 Astrid Emde <astrid.emde at wheregroup.com>:
>>>> Hello Cameron,
>>>> thanks for your answer.
>>>> Maybe we could check conf.py for changes too and define a rule for
>>>> commit messages like - "version mapbender3 changed, final 8.5"
>>>> If something in the text of the overview files changes it still means
>>>> that the translators must have a look and translate.
>>>> I like your idea to loop through all translations and updates the
>>>> version number to the English master version.
>>>> Astrid
>>>> Am 05.12.2014 10:02, schrieb Cameron Shorter:
>>>>> Hi Astrid,
>>>>> You bring up a valid concern.
>>>>> There is a reason that we currently prefer version numbers to be hard
>>>>> coded into the Project Overview text instead of by using a variable.
>>>>> We wish to verify that if an application has been updated, then
>>>>> someone has assessed whether the Project Overview has been looked at
>>>>> and updated. We do this by checking svn timestamps on the
>>>>> <project>_overview.rst. If the version number changes, then the
>>>>> <project>_overview.rst should change too. If the version number is
>>>>> stored in a conf.py file instead, then we will need to think of
>>>>> another way to check that each ProjectOverview has been reviewed and
>>>>> updated.
>>>>> I'm open to suggestions.
>>>>> We could relatively easily write a script which loops through all
>>>>> translations and updates the version number to the English master
>>>>> version.
>>>>> On 4/12/2014 5:50 pm, Astrid Emde wrote:
>>>>>> Hello,
>>>>>> I do not know, whether you discussed this before.
>>>>>> Before each OSGeo-Live version comes out the translators have to edit
>>>>>> many files and sometimes only have to change the version of the
>>>>>> software.
>>>>>> Things are much easier and less work, if the version is only defined at
>>>>>> one place as a variable and the version is used in all the overview
>>>>>> translations.
>>>>>> Some projects use this way already and I would like to encourage more
>>>>>> projects to make it this way.
>>>>>> Have a look at:
>>>>>> http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/doc/conf.py
>>>>>> 1.)  f.e. define  |version-geoserver| replace:: 2.5
>>>>>> 2.) and refer in the xx_overview.rst like this
>>>>>> http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/doc/de/overview/geoserver_overview.rst
>>>>>> **Software Version:** |version-geoserver|
>>>>>> Like this only changes in the text of the overview document have to be
>>>>>> translated for every new version.
>>>>>> Astrid
>>>>>> _______________________________________________
>>>>>> Live-demo mailing list
>>>>>> Live-demo at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>>>> http://live.osgeo.org
>>>> Mit freundlichen Grüßen
>>>> Astrid Emde
>>>> GIS-Consultant
>>>> Where2B Konferenz 2014
>>>> 11. Dezember 2014 in Bonn
>>>> www.where2b-conference.com
>>>>   Astrid Emde
>>>>   WhereGroup GmbH & Co.KG
>>>>   Eifelstraße 7
>>>>   53119 Bonn
>>>>   Germany
>>>>   Fon: +49(0)228 90 90 38 - 19
>>>>   Fax: +49(0)228 90 90 38 - 11
>>>>   www.wheregroup.com
>>>>   Folgen Sie der WhereGroup auf twitter:
>>>> http://twitter.com/WhereGroup_com
>>>> Amtsgericht Bonn, HRA 6788
>>>> Komplementärin:
>>>> WhereGroup Verwaltungs GmbH
>>>> vertreten durch:
>>>> Olaf Knopp, Peter Stamm
>>>>   pgp-public key:
>>>>   http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>>>>    Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>>>>    Signed and/or encrypted mail is highly appreciated
>> Cameron Shorter,
>> Software and Data Solutions Manager
>> LISAsoft
>> Suite 112, Jones Bay Wharf,
>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>> P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
> Ko Nagase (長瀬 興)
> Georepublic Japan
> mail: nagase at georepublic.co.jp
> web: http://georepublic.co.jp
Ko Nagase (長瀬 興)
Georepublic Japan
More information about the Live-demo mailing list
