[Live-demo] Switch to tomcat 7 possible?
Eike Hinderk Jürrens e.h.juerrens at 52north.org
Thu Jun 18 03:17:56 PDT 2015
Hi!
On 18.06.2015 11:58, Angelos Tzotsos wrote:
> There is also ncWMS that depends on tomcat. We need to ask this
> project too.
> Thanks for bringing up this issue.
Okay, you are right. I just asked the projects that clearly stated a
specific tomcat version. I assumed that the projects that state as
dependency "tomcat" are okay with updating to the latest tomcat version.
The full list of tomcat dependent projects:
- 52nWPS: just checked with Benjamin
- 52nSOS: okay
- deegree: ???
- ncwms: ???
- rasdaman: dependency is just updated (12:00 CEST) to tomcat7
By the way, I already prepared a PR which updates everything regarding
tomcat6 -> tomcat7 in the OSGeoLive repository:
    https://github.com/OSGeo/OSGeoLive/pull/5
We should add an issue to OSGeoLive-doc if this PR is accepted and
merged to update all documentation that refers to tomcat6 in any command.
Kind regards,
Eike
> On 06/18/2015 11:47 AM, Eike Hinderk Jürrens wrote:
>> Hi Vlad,
>> thank for your insights.
>> @Peter Baumann, Dimitar Misev: Could you please update [1] to be more
>> generic or up-to-date.
>> Who is responsible for the install_tomcat6.sh?
>> We might change it's name to install_tomcat.sh and define that installs
>> the latest available tomcat from ubuntu packages for the currently used
>> ubuntu release. What do you think?
>> Kind regards,
>> Eike
>> On 18.06.2015 10:21, Vlad Merticariu wrote:
>>> Hi Eike,
>>> Yes, rasdaman works with tomcat7, we use it frequently in deployments.
>>> Best regards,
>>> Vlad
>>> On Jun 18, 2015 10:14 AM, "Eike Hinderk Jürrens"
>>> <e.h.juerrens at 52north.org <mailto:e.h.juerrens at 52north.org>> wrote:
>>>      Hi,
>>>      is it possible to switch to tomcat 7 for 9.0?
>>>      It is available via packages [0] and there is only one package
>>> that
>>>      depends on tomcat6: rasdaman (following [1]).
>>>      @Peter: is it possible to switch to tomcat7 for rasdaman?
>>>      Kind regards,
>>>      Eike
>>>      Links
>>>      [0] http://packages.ubuntu.com/trusty/tomcat7
>>>      [1]
>>> https://docs.google.com/spreadsheets/d/1Q5BaEgQtgw4O1bXyeWMlM8XtAOhUgcjZ7Y2O0FZc2H0/edit?pli=1#gid=323391984
52°North Initiative for Geospatial Open Source Software GmbH
Martin-Luther-King-Weg 24
48155 Münster, Germany
E-Mail: e.h.juerrens at 52north.org
Fon: +49-(0)-251–396371-33
Fax: +49-(0)-251–396371-11
http://52north.org/
Twitter: @FiveTwoN
General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
Local Court Muenster HRB 10849
More information about the Live-demo mailing list
