[Live-demo] Switch to tomcat 7 possible?
Angelos Tzotsos gcpp.kalxas at gmail.com
Thu Jun 18 03:23:32 PDT 2015
On 06/18/2015 01:17 PM, Eike Hinderk Jürrens wrote:
> Hi!
> On 18.06.2015 11:58, Angelos Tzotsos wrote:
>> There is also ncWMS that depends on tomcat. We need to ask this
>> project too.
>> Thanks for bringing up this issue.
> Okay, you are right. I just asked the projects that clearly stated a
> specific tomcat version. I assumed that the projects that state as
> dependency "tomcat" are okay with updating to the latest tomcat version.
Yes, projects should specify requirements with more details.
> The full list of tomcat dependent projects:
> - 52nWPS: just checked with Benjamin
> - 52nSOS: okay
> - deegree: ???
> - ncwms: ???
> - rasdaman: dependency is just updated (12:00 CEST) to tomcat7
Regarding deegree, it uses an internal tomcat, so it is not affected by
default tomcat.
> By the way, I already prepared a PR which updates everything regarding
> tomcat6 -> tomcat7 in the OSGeoLive repository:
>      https://github.com/OSGeo/OSGeoLive/pull/5
Thanks for the PR, I will review.
> We should add an issue to OSGeoLive-doc if this PR is accepted and
> merged to update all documentation that refers to tomcat6 in any command.
> Kind regards,
> Eike
Best,
Angelos
>> On 06/18/2015 11:47 AM, Eike Hinderk Jürrens wrote:
>>> Hi Vlad,
>>> thank for your insights.
>>> @Peter Baumann, Dimitar Misev: Could you please update [1] to be more
>>> generic or up-to-date.
>>> Who is responsible for the install_tomcat6.sh?
>>> We might change it's name to install_tomcat.sh and define that installs
>>> the latest available tomcat from ubuntu packages for the currently used
>>> ubuntu release. What do you think?
>>> Kind regards,
>>> Eike
>>> On 18.06.2015 10:21, Vlad Merticariu wrote:
>>>> Hi Eike,
>>>> Yes, rasdaman works with tomcat7, we use it frequently in deployments.
>>>> Best regards,
>>>> Vlad
>>>> On Jun 18, 2015 10:14 AM, "Eike Hinderk Jürrens"
>>>> <e.h.juerrens at 52north.org <mailto:e.h.juerrens at 52north.org>> wrote:
>>>>       Hi,
>>>>       is it possible to switch to tomcat 7 for 9.0?
>>>>       It is available via packages [0] and there is only one package
>>>> that
>>>>       depends on tomcat6: rasdaman (following [1]).
>>>>       @Peter: is it possible to switch to tomcat7 for rasdaman?
>>>>       Kind regards,
>>>>       Eike
>>>>       Links
>>>>       [0] http://packages.ubuntu.com/trusty/tomcat7
>>>>       [1]
>>>> https://docs.google.com/spreadsheets/d/1Q5BaEgQtgw4O1bXyeWMlM8XtAOhUgcjZ7Y2O0FZc2H0/edit?pli=1#gid=323391984
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo mailing list
