[Live-demo] Wiki update for Git
Angelos Tzotsos gcpp.kalxas at gmail.com
Tue May 26 01:59:42 PDT 2015
Thanks Luca,
Your pull request is now merged :)
Best,
Angelos
On 05/26/2015 11:13 AM, Luca Delucchi wrote:
> On 23 May 2015 at 17:44, Angelos Tzotsos <gcpp.kalxas at gmail.com> wrote:
>> Hi all,
> Hi Angelos
>> This is a first attempt to update our wiki regarding Git:
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc#Git_migration
>> Please review.
> I forked and cloned it, I also create a new branch to work on the pdf
> output [0].
> When I tried to compile html or latexpdf I got error for missing files....
> make latexpdf
> for LANG in en ; do \
>          cat index_pdf.template | sed "s/LANG_PDF/$LANG/#"  > index.rst ; \
> done
> echo `pwd`
> /home/lucadelu/github/OSGeoLive-doc
> ../bin/extract_licenses.sh > licenses.csv
> /bin/sh: 1: ../bin/extract_licenses.sh: not found
> Makefile:134: recipe for target 'licenses.csv' failed
> make: *** [licenses.csv] Error 127
> make html
> cp index.template index.rst
> sphinx-build -b html -d _build/doctrees   . _build/html
> Making output directory...
> Running Sphinx v1.2.3
> Exception occurred:
>    File "conf.py", line 25, in <module>
>      fileIN = open("../VERSION.txt", "r")
> IOError: [Errno 2] No such file or directory: '../VERSION.txt'
> The full traceback has been saved in /tmp/sphinx-err-sqFIS6.log, if
> you want to report the issue to the developers.
> Please also report this if it was a user error, so that a better error
> message can be provided next time.
> A bug report can be filed in the tracker at
> <https://bitbucket.org/birkenfeld/sphinx/issues/>. Thanks!
> Makefile:69: recipe for target 'sphinxbuild' failed
> make: *** [sphinxbuild] Error 1
> So I open a pull request [1] to add the needed files in to repository.
> With this pull request it is possible to compile both html and
> latexpdf but in the HTML there are still some errors
> bin/extract_licenses.sh: 32: cd: can't cd to
> /home/lucadelu/github/OSGeoLive-doc/bin/../doc/en/overview
> awk: fatal: cannot open file `*.rst' for reading (No such file or directory)
> /home/lucadelu/github/OSGeoLive-doc/bin/../doc/en/quickstart
>> Angelos
> [0] https://github.com/lucadelu/OSGeoLive-doc/tree/pdf_output
> [1] https://github.com/OSGeo/OSGeoLive-doc/pull/5
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo mailing list
