[Live-demo] Translations and Proj4 documentation
Nicolas Roelandt roelandtn.pro at gmail.com
Sat Jun 3 06:12:12 PDT 2017
Thank you Vicky and Julien to get involved with this :)
Transifex is really simple to use for translator. You just have to
translate the strings.
There is sometime some code chunks to let in place but in osgeo-live, I
don't remember seen that much.
In all cases, welcome aboard !
Cheers,
Nicolas
2017-06-03 5:47 GMT+02:00 Vicky Vergara <vicky at georepublic.de>:
> Hello Julien
> > I found   "https://github.com/cvvergara/OSGeoLive-doc" which appears to
> be Vicky's fork.
> Yes indeed that is my fork.
> > With a "test/sphinx" branch inside that seems to be the transiflex
> implementation ?
> Yes, test/sphinx is the branch I am using. although it stopped being a
> test of sphinx long time ago, (like after the next day, I started working
> on it)
> > It's like you've been 6 days on it on github. But what a work done !
> Yes 6 days, but not all the time, I confess, you see I have to work with 3
> GSoC students in the morning, and do my own pgRouting stuff but ..
> because I am doing the same thing (handing the documentation in pgRouting)
> then its kind of:
> - do some experimenting here, it works do the same there
> - do some experimenting there, it works do the same here
> > I do not really know transiflex indeed...
> You can practice with pgRouting
> Register to transifex.
> https://docs.transifex.com/getting-started/translators
> find pgRouting:
> Navigate to: https://www.transifex.com/pgrouting/pgrouting
> Ask to be a french translator, I aprove you
> then you can start translating french.
> choose a file, with v2.5 (I keep the V2_0 because transifex has memory for
> already translated string that comes out very handy) tell me when you are
> done, and we discuss about details like Sphinx syntax that has to be kept.
> Translations using transifex to OSGeoLive are not ready yet, I don't think
> I will finish before the release. I am so slow.
> So about OSGeoLive main repo translation (in master)
> In [1] you can see the files that already have being translated to french
> In [2] you can see the files that are in total
> [1] https://github.com/OSGeo/OSGeoLive-doc/tree/master/fr/quickstart
> [2] https://github.com/OSGeo/OSGeoLive-doc/tree/master/en/quickstart
> > But nevermind ! Are you stuck somewhere or something can be done ?
> Actually I am stuck, what I want to do is to extract already translated
> strings, and upload them to transifex.
> That way, all these years of translation is not re-done from scratch
> And of course if I can do that, then maybe there is a very "petit"
> possibility that for version 11 transifex could be used.
> Of course tests must be done, and you see I am a testing freak, that is
> why I started CI tests
> https://travis-ci.org/cvvergara/OSGeoLive-doc
> Just occurred to me that maybe a bunch of copy/paste and let a real
> translator check if the copy/paste was good.
> That would be a good test to do....
> I'll prepare it ASAP and keep you posted, on the mean time
> when you register to transifex, also ask to be a french translator on
> https://www.transifex.com/bakanikos-lab/test_osgeolive
> don't translate there, because that is only for testing, the real location
> is not going to be that one
> (for Spanish I just translated a single string, just for testing)
> On Thu, Jun 1, 2017 at 3:47 PM, Julien Moquet <moquet.julien at gmail.com>
> wrote:
>> HI,
>> be Vicky's fork.
>> implementation ?
>> Regards,
>> Julien.
>> 2017-06-01 22:09 GMT+02:00 Cameron Shorter <cameron.shorter at gmail.com>:
>>> Hi Julien,
>>> Thanks for offering to help with translations. I'm looping in Niko and
>>> Vicky who are currently wrestling with trying to get transifex to work. If
>>> you are familiar with it, you might be able to help them.
>>> Warm regards, Cameron
>>> On 2/6/17 3:22 am, Julien Moquet wrote:
>>> Hi,
>>> >> It would be ok to say "Proj4 has been translated into other
>>> languages, including proj4js, ..."
>>> > Agreed that metacrs is probably a bit too ..
>>> I am fully agree too.
>>> And as OsGeoLive aims to be multilanguages, I can help on the proj4
>>> French Translation pages.
>>> Regards,
>>> 2017-05-31 22:15 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
>>>> On jeudi 1 juin 2017 05:57:38 CEST Cameron Shorter wrote:
>>>> > Hi Evan,
>>>> > Yes, MetaCRS was a project gathering all the Proj4 projects together.
>>>> > However, it appears that proj4 is the only project in that grouping
>>>> > which is active?
>>>> > Hence my thoughts are that "MetaCRS" should be dropped from OSGeo-Live
>>>> > as a concept and "Proj4" be used instead. It would be ok to say "Proj4
>>>> > has been translated into other languages, including proj4js, ..."
>>>> > Your thoughts are welcome.
>>>> Regarding what is listed currently in metacrs :
>>>> - proj4js: no opinion
>>>> - cs-map: no-opinion
>>>> - geotiff/libgeotiff: heavily used underneath by GDAL in particular,
>>>> mostly in maintaince mode, but can be treated as a technical dependency
>>>> that doesn't require to be visible from users.
>>>> - proj4j: no opinion
>>>> - spatialreference.org: not maintained in years. http://epsg.io/ would
>>>> be a possible replacement
>>>> Agreed that metacrs is probably a bit too ... meta for folks exploring
>>>> OSGeo-Live content, so it could make sense exposing proj.4 as a standalone
>>>> project.
>>>> Spatialys - Geospatial professional services
>>>> http://www.spatialys.com
>>> Cameron Shorter
>>> M +61 419 142 254 <+61%20419%20142%20254>
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20170603/3f532927/attachment.html>
More information about the Live-demo mailing list
