[Live-demo] Translations and Proj4 documentation
Vicky Vergara vicky at georepublic.de
Mon Jun 5 07:11:25 PDT 2017
I added the languages so long a go I fogot how to do stuff
by the time I wanted to add Julien he was already there but I used  the
method click and find ;)
I honestly don't know
Vicky
On Mon, Jun 5, 2017 at 2:44 AM, Baka Niko <baka.niko at gmail.com> wrote:
> Hi Vicky  and Julien,
> Regarding mytest lab, I added Julien as a translator and Spanish as a new
> language.
> Vicky as a maintainer, where you able to add languages or people in the
> project ?
> I might not be very reactive if you need something.
> Best regards,
> Nicolas
> 2017-06-05 7:10 GMT+02:00 Vicky Vergara <vicky at georepublic.de>:
>> Hello Julien
>> In the pgRouting I see you as a translator
>> Can you confirm that?
>> On Sun, Jun 4, 2017 at 3:55 PM, Julien Moquet <moquet.julien at gmail.com>
>> wrote:
>>> Hi Vicky,
>>> >> Navigate to: https://www.transifex.com/pgrouting/pgrouting
>>> >> Ask to be a french translator, I aprove you
>>> Done !
>>> Let's begin !
>>> >> I'll prepare it ASAP and keep you posted, on the mean time
>>> >> when you register to transifex, also ask to be a french translator on
>>> >> https://www.transifex.com/bakanikos-lab/test_osgeolive
>>> Done !
>>> I am waiting for you.
>>> Regards,
>>> Julien.
>>> 2017-06-03 5:47 GMT+02:00 Vicky Vergara <vicky at georepublic.de>:
>>>> Hello Julien
>>>> > I found   "https://github.com/cvvergara/OSGeoLive-doc" which appears
>>>> to be Vicky's fork.
>>>> Yes indeed that is my fork.
>>>> > With a "test/sphinx" branch inside that seems to be the transiflex
>>>> implementation ?
>>>> Yes, test/sphinx is the branch I am using. although it stopped being a
>>>> test of sphinx long time ago, (like after the next day, I started working
>>>> on it)
>>>> > It's like you've been 6 days on it on github. But what a work done !
>>>> Yes 6 days, but not all the time, I confess, you see I have to work
>>>> with 3 GSoC students in the morning, and do my own pgRouting stuff but ..
>>>> because I am doing the same thing (handing the documentation in
>>>> pgRouting) then its kind of:
>>>> - do some experimenting here, it works do the same there
>>>> - do some experimenting there, it works do the same here
>>>> > I do not really know transiflex indeed...
>>>> You can practice with pgRouting
>>>> Register to transifex.
>>>> https://docs.transifex.com/getting-started/translators
>>>> find pgRouting:
>>>> then you can start translating french.
>>>> choose a file, with v2.5 (I keep the V2_0 because transifex has memory
>>>> for already translated string that comes out very handy) tell me when you
>>>> are done, and we discuss about details like Sphinx syntax that has to be
>>>> kept.
>>>> Translations using transifex to OSGeoLive are not ready yet, I don't
>>>> think I will finish before the release. I am so slow.
>>>> So about OSGeoLive main repo translation (in master)
>>>> In [1] you can see the files that already have being translated to
>>>> french
>>>> In [2] you can see the files that are in total
>>>> [1] https://github.com/OSGeo/OSGeoLive-doc/tree/master/fr/quickstart
>>>> [2] https://github.com/OSGeo/OSGeoLive-doc/tree/master/en/quickstart
>>>> > But nevermind ! Are you stuck somewhere or something can be done ?
>>>> Actually I am stuck, what I want to do is to extract already translated
>>>> strings, and upload them to transifex.
>>>> That way, all these years of translation is not re-done from scratch
>>>> And of course if I can do that, then maybe there is a very "petit"
>>>> possibility that for version 11 transifex could be used.
>>>> Of course tests must be done, and you see I am a testing freak, that is
>>>> why I started CI tests
>>>> https://travis-ci.org/cvvergara/OSGeoLive-doc
>>>> Just occurred to me that maybe a bunch of copy/paste and let a real
>>>> translator check if the copy/paste was good.
>>>> That would be a good test to do....
>>>> don't translate there, because that is only for testing, the real
>>>> location is not going to be that one
>>>> (for Spanish I just translated a single string, just for testing)
>>>> On Thu, Jun 1, 2017 at 3:47 PM, Julien Moquet <moquet.julien at gmail.com>
>>>> wrote:
>>>>> HI,
>>>>> to be Vicky's fork.
>>>>> implementation ?
>>>>> Regards,
>>>>> Julien.
>>>>> 2017-06-01 22:09 GMT+02:00 Cameron Shorter <cameron.shorter at gmail.com>
>>>>>> Hi Julien,
>>>>>> Thanks for offering to help with translations. I'm looping in Niko
>>>>>> and Vicky who are currently wrestling with trying to get transifex to work.
>>>>>> If you are familiar with it, you might be able to help them.
>>>>>> Warm regards, Cameron
>>>>>> On 2/6/17 3:22 am, Julien Moquet wrote:
>>>>>> Hi,
>>>>>> >> It would be ok to say "Proj4 has been translated into other
>>>>>> languages, including proj4js, ..."
>>>>>> > Agreed that metacrs is probably a bit too ..
>>>>>> I am fully agree too.
>>>>>> And as OsGeoLive aims to be multilanguages, I can help on the proj4
>>>>>> French Translation pages.
>>>>>> Regards,
>>>>>> 2017-05-31 22:15 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
>>>>>>> On jeudi 1 juin 2017 05:57:38 CEST Cameron Shorter wrote:
>>>>>>> > Hi Evan,
>>>>>>> > Yes, MetaCRS was a project gathering all the Proj4 projects
>>>>>>> together.
>>>>>>> > However, it appears that proj4 is the only project in that grouping
>>>>>>> > which is active?
>>>>>>> > Hence my thoughts are that "MetaCRS" should be dropped from
>>>>>>> OSGeo-Live
>>>>>>> > as a concept and "Proj4" be used instead. It would be ok to say
>>>>>>> "Proj4
>>>>>>> > has been translated into other languages, including proj4js, ..."
>>>>>>> > Your thoughts are welcome.
>>>>>>> Regarding what is listed currently in metacrs :
>>>>>>> - proj4js: no opinion
>>>>>>> - cs-map: no-opinion
>>>>>>> - geotiff/libgeotiff: heavily used underneath by GDAL in particular,
>>>>>>> mostly in maintaince mode, but can be treated as a technical dependency
>>>>>>> that doesn't require to be visible from users.
>>>>>>> - proj4j: no opinion
>>>>>>> - spatialreference.org: not maintained in years. http://epsg.io/
>>>>>>> would be a possible replacement
>>>>>>> Agreed that metacrs is probably a bit too ... meta for folks
>>>>>>> exploring OSGeo-Live content, so it could make sense exposing proj.4 as a
>>>>>>> standalone project.
>>>>>>> Spatialys - Geospatial professional services
>>>>>>> http://www.spatialys.com
>>>>>> Cameron Shorter
>>>>>> M +61 419 142 254 <+61%20419%20142%20254>
>>>> Georepublic UG (haftungsbeschränkt)
>>>> Salzmannstraße 44,
>>>> 81739 München, Germany
>>>> Vicky Vergara
>>>> Operations Research
>>>> eMail: vicky at georepublic.de
>>>> Web: https://georepublic.info
>>>> Tel: +49 (089) 4161 7698-1
>>>> Fax: +49 (089) 4161 7698-9
>>>> Commercial register: Amtsgericht München, HRB 181428
>>>> CEO: Daniel Kastl
>> Salzmannstraße 44,
>> Vicky Vergara
>> Operations Research
>> CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20170605/c7c2847f/attachment-0001.html>
More information about the Live-demo mailing list
