[Live-demo] Translations and Proj4 documentation
Even Rouault even.rouault at spatialys.com
Wed Jun 14 00:45:07 PDT 2017
On mercredi 14 juin 2017 00:23:45 CEST Julien Moquet wrote:
> Hi Vicky,
> My fork is up to date regarding the overview and quickstart:
> https://github.com/julien2512/OSGeoLive-doc
> Before making a pull request, I need to test it over the OsGeoLive-10.5 (on
> wednesday or thursday).
> Although, as I read the sources.list include in this version, I don't
> really think the latest proj4 will be used.
> The ubuntugis is used for that, and there is only the stable 4.8.0-3 proj4
> release to be used.
> See :
> http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu/pool/main/p/pro
> j/ and
> https://github.com/OSGeo/OSGeoLive/blob/osgeolive_10_5/sources.list.d/ubuntu
> gis.list
I haven't tested this OSGeoLive version, but it looks like it is based on Ubuntu Xenial :
https://github.com/OSGeo/OSGeoLive/blob/master/sources.list.d/osgeolive.list
And if you look at
https://launchpad.net/%7Eubuntugis/+archive/ubuntu/ubuntugis-unstable/+index?field.series_filter=xenial
the proj package you quote isn't listed. In fact it is tagged as being for the old'ish
Precise:
https://launchpad.net/%7Eubuntugis/+archive/ubuntu/ubuntugis-unstable/+index?field.series_filter=precise
So I think that OSGeoLive just inherits the official proj in Xenial :
https://packages.ubuntu.com/xenial/proj-bin
ie proj 4.9.2
Of course in-situ observation would be better than this deduction game ;-)
> That's why I finally don't have to change the proj4 release on its overview.
> I only bypass the metacrs and stuff.
> Regards,
> Julien.
> 2017-06-11 18:11 GMT+02:00 Vicky Vergara <vicky at georepublic.de>:
> > Hi Julien, et all
> > Maybe you can help me.
> > It so happened that I sent another mail asking about what version to use,
> > while reviewing today, I saw that I didn't send the mail to proj4.
> > (my mail merge skills are not so good)
> > So, here is the hand made mail:
> > Hi all,
> > With the upcoming OSGeo-Live 11.0 reboot, we will be re-inserting each
> > project into the OSGeo-Live baseline once someone from each project has
> > replied to confirm that they have reviewed docs and verified the
> > application works as expected.
> > Can you please:
> >  0. Reply by return email to confirm that you have recieved this email and
> > that you are able to check docs within the next 2 weeks. (sooner would be
> > better if you can)
> >  1. Reply to confirm the Project Overview is still accurate, or has been
> > updated, (and version numbers are correct)
> >  2. Reply to confirm you have run a recent OSGeo-Live version (the
> > previous 10.5 version is ok), and updated the quickstart where needed.
> >  We understand that version 4.9.2 of proj4 will be installed on OSGeo-Live
> > 11.0 (Version 4.9.2 was installed on OSGeo-Live 10.5.)
> > (all in one reply is ok)
> > Full package status can be seen here:
> > https://docs.google.com/spreadsheets/d/1Q5BaEgQtgw4O1bXyeWMl
> > M8XtAOhUgcjZ7Y2O0FZc2H0/edit?hl=en_GB#gid=2014800150
> > Key Milestones
> > 18-Jun-2017    All docs reviewed and verified
> > 21-Jun-2017    OSGeo-Live delivered to UAT (final application versions
> > installed - Beta stage)
> > 24-Jul-2017    OSGeo-Live Final ISO
> > 14-Aug-2017 FOSS4G 2017 Boston
> > ... full schedule http://spreadsheets.google.com
> > /ccc?key=0Al9zh8DjmU_RdE1SYUN3YWJ2N1NpSUczbW9IRWZNclE&hl=en_GB
> > On Thu, Jun 1, 2017 at 3:09 PM, Cameron Shorter <cameron.shorter at gmail.com
> > > wrote:
> >> Hi Julien,
> >> Thanks for offering to help with translations. I'm looping in Niko and
> >> Vicky who are currently wrestling with trying to get transifex to work.
> >> If
> >> you are familiar with it, you might be able to help them.
> >> Warm regards, Cameron
> >> On 2/6/17 3:22 am, Julien Moquet wrote:
> >> Hi,
> >> >> It would be ok to say "Proj4 has been translated into other languages,
> >> including proj4js, ..."
> >> > Agreed that metacrs is probably a bit too ..
> >> I am fully agree too.
> >> And as OsGeoLive aims to be multilanguages, I can help on the proj4
> >> French Translation pages.
> >> Regards,
> >> 2017-05-31 22:15 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> >>> On jeudi 1 juin 2017 05:57:38 CEST Cameron Shorter wrote:
> >>> > Hi Evan,
> >>> > Yes, MetaCRS was a project gathering all the Proj4 projects together.
> >>> > However, it appears that proj4 is the only project in that grouping
> >>> > which is active?
> >>> > Hence my thoughts are that "MetaCRS" should be dropped from OSGeo-Live
> >>> > as a concept and "Proj4" be used instead. It would be ok to say "Proj4
> >>> > has been translated into other languages, including proj4js, ..."
> >>> > Your thoughts are welcome.
> >>> Regarding what is listed currently in metacrs :
> >>> - proj4js: no opinion
> >>> - cs-map: no-opinion
> >>> - geotiff/libgeotiff: heavily used underneath by GDAL in particular,
> >>> mostly in maintaince mode, but can be treated as a technical dependency
> >>> that doesn't require to be visible from users.
> >>> - proj4j: no opinion
> >>> - spatialreference.org: not maintained in years. http://epsg.io/ would
> >>> be a possible replacement
> >>> Agreed that metacrs is probably a bit too ... meta for folks exploring
> >>> OSGeo-Live content, so it could make sense exposing proj.4 as a
> >>> standalone
> >>> project.
> >>> Spatialys - Geospatial professional services
> >>> http://www.spatialys.com
> >> Cameron Shorter
> >> M +61 419 142 254 <+61%20419%20142%20254>
> > Georepublic UG (haftungsbeschränkt)
> > Salzmannstraße 44,
> > 81739 München, Germany
> > Vicky Vergara
> > Operations Research
> > eMail: vicky at georepublic.de
> > Web: https://georepublic.info
> > Tel: +49 (089) 4161 7698-1
> > Fax: +49 (089) 4161 7698-9
> > Commercial register: Amtsgericht München, HRB 181428
> > CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20170614/38f09d7f/attachment-0001.html>
More information about the Live-demo mailing list
