svn commit: r223 - trunk/mapbender/http/php/mod_group_filteredGui.php
uli at osgeo.org uli at osgeo.org
Wed May 10 11:40:07 EDT 2006
Author: uli
Date: 2006-05-10 15:40:07+0000
New Revision: 223
db_prep_query included
verification of user permissions
Modified: trunk/mapbender/http/php/mod_group_filteredGui.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_group_filteredGui.php?view=diff&rev=223&p1=trunk/mapbender/http/php/mod_group_filteredGui.php&p2=trunk/mapbender/http/php/mod_group_filteredGui.php&r1=222&r2=223
--- trunk/mapbender/http/php/mod_group_filteredGui.php	(original)
+++ trunk/mapbender/http/php/mod_group_filteredGui.php	2006-05-10 15:40:07+0000
@@ -17,13 +17,13 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-session_start();
 import_request_variables("PG");
-require_once("../php/mb_validateSession.php");
 require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
+$con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
-$gui_id = $_SESSION["mb_user_gui"];
+require_once("../php/mb_validatePermission.php");
+$self = $PHP_SELF . "?".SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 <html>
@@ -63,9 +63,7 @@
 </head>
 <body>
 <?php
-require_once("../../conf/mapbender.conf");
-db_select_db(DB,$con);
 require_once("../php/mb_getGUIs.php");
 $fieldHeight = 20;
@@ -87,12 +85,16 @@
 	if(count($selected_gui)>0){
 		for($i=0; $i<count($selected_gui); $i++){
 			$exists = false;
-			$sql_insert = "SELECT * from gui_mb_group where fkey_mb_group_id = '".$selected_group."' and fkey_gui_id = '".$selected_gui[$i]."'";
-			$res_insert = db_query($sql_insert);
+			$sql_insert = "SELECT * from gui_mb_group where fkey_mb_group_id = $1 and fkey_gui_id = $2";
+			$v = array($selected_group,$selected_gui[$i]);
+			$t = array('i','s');
+			$res_insert = db_prep_query($sql_insert,$v,$t);
 			while(db_fetch_row($res_insert)){$exists = true;}
 			if($exists == false){
-				$sql_insert = "INSERT INTO gui_mb_group(fkey_mb_group_id, fkey_gui_id) VALUES('$selected_group', '".$selected_gui[$i]."');";
+				$sql_insert = "INSERT INTO gui_mb_group(fkey_mb_group_id, fkey_gui_id) VALUES($1, $2);";
@@ -100,31 +102,31 @@
 if($remove){
 	if(count($remove_gui)>0){
 		for($i=0; $i<count($remove_gui); $i++){
-			$sql_remove = "DELETE FROM gui_mb_group WHERE fkey_gui_id = '".$remove_gui[$i]."' and fkey_mb_group_id = '$selected_group'";
-			db_query($sql_remove);
+			$sql_remove = "DELETE FROM gui_mb_group WHERE fkey_gui_id = $1 and fkey_mb_group_id = $2";
+			$v = array($remove_gui[$i],$selected_group);
+			$t = array('s','i');
+			db_prep_query($sql_remove,$v,$t);
 /*get allocated gui  ********************************************************************************************/
-#$sql_gui = "SELECT * FROM gui ORDER BY gui_name";
-#$sql_gui = "SELECT gui.gui_id, gui.gui_name, gui_mb_user.fkey_mb_user_id ";
-#$sql_gui .= "FROM gui INNER JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id ";
-#$sql_gui .= "WHERE gui_mb_user.fkey_mb_user_id='".$logged_user_id."'";
 $arrayGuis=mb_getGUIs($logged_user_id);
+$v = array();
+$t = array();
 $sql_gui = "SELECT * FROM gui WHERE gui_id IN (";
 for($i=0; $i<count($arrayGuis); $i++){
 	if($i>0){ $sql_gui .= ",";}
-	$sql_gui .= "'".$arrayGuis[$i]."'";
+	$sql_gui .= "$".($i + 1);
+	array_push($v, $arrayGuis[$i]);
+	array_push($t, 's');
 $sql_gui.= ") ORDER BY gui_name";
+$res_gui = db_prep_query($sql_gui,$v,$t);
-$res_gui = db_query($sql_gui);
 while($row = db_fetch_array($res_gui)){
 	$gui_id_array[$cnt_gui] = $row["gui_id"];
 	$gui_name[$cnt_gui] = $row["gui_name"];
@@ -143,22 +145,26 @@
 /*get allocated gui from selected_group******************************************************************************/
+$v = array();
+$t = array();
 $sql_group_mb_gui = "SELECT gui.gui_id, gui.gui_name, gui_mb_group.fkey_mb_group_id FROM gui_mb_group ";
 $sql_group_mb_gui .= "INNER JOIN gui ON gui_mb_group.fkey_gui_id = gui.gui_id ";
-$sql_group_mb_gui .= "WHERE gui_mb_group.fkey_mb_group_id=";
-if(!$selected_group){$sql_group_mb_gui .= $group_id[0];}
-if($selected_group){$sql_group_mb_gui .= $selected_group;}
+$sql_group_mb_gui .= "WHERE gui_mb_group.fkey_mb_group_id = $1 ";
+if(!$selected_group){array_push($v,$group_id[0]);}
+if($selected_group){array_push($v,$selected_group);}
+array_push($t,'i');
 $sql_group_mb_gui .= " AND gui.gui_id IN (";
+$c = 2;
 	if($i>0){ $sql_group_mb_gui .= ",";}
-	$sql_group_mb_gui .= "'".$arrayGuis[$i]."'";
+	$sql_group_mb_gui .= "$".$c;
+	array_push($v,$arrayGuis[$i]);
+	array_push($t,'s');
+	$c++;
 $sql_group_mb_gui .= ") ORDER BY gui.gui_name";
-$res_group_mb_gui = db_query($sql_group_mb_gui);
+$res_group_mb_gui = db_prep_query($sql_group_mb_gui,$v,$t);
 while($row = db_fetch_array($res_group_mb_gui)){
 	$gui_id_group[$cnt_gui_group] = $row["gui_id"];
 	$gui_name_group[$cnt_gui_group] =  $row["gui_name"];
@@ -170,7 +176,7 @@
 /*INSERT HTML*/
-echo "<form name='form1' action='" . $PHP_SELF . "?".SID."&e_id_css=".$_REQUEST["e_id_css"]."' method='post'>";
+echo "<form name='form1' action='" . $self ."' method='post'>";
 /*insert all group in selectbox*************************************************************************************/
 echo "<div class='text1'>GROUP: </div>";
More information about the Mapbender_commits mailing list
