[Mapbender-commits] r1602 - trunk/mapbender/owsproxy/http
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 6 04:31:21 EDT 2007
Author: christoph
Date: 2007-08-06 04:31:21 -0400 (Mon, 06 Aug 2007)
New Revision: 1602
   trunk/mapbender/owsproxy/http/index.php
replaced old string functions by multibyte string function
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php	2007-08-06 08:30:31 UTC (rev 1601)
+++ trunk/mapbender/owsproxy/http/index.php	2007-08-06 08:31:21 UTC (rev 1602)
@@ -24,17 +24,17 @@
 require_once("../../http/classes/class_mb_exception.php");
 /***** conf *****/
 $imageformats = array("image/png","image/gif","image/jpeg", "image/jpg");
-$mbkeys = array("sid",strtolower(ini_get("session.name")),"wms");
+$mbkeys = array("sid",mb_strtolower(ini_get("session.name")),"wms");
 /***** conf *****/
 $reqParams = array();
 $myKeys = array_keys($_REQUEST);
 // create an associative array with request parameters (get)
 for($i=0; $i<count($myKeys); $i++){
-	$tmp[$i] = removeQM(strtolower($myKeys[$i]));
+	$tmp[$i] = removeQM(mb_strtolower($myKeys[$i]));
 	$$tmp[$i]  = $_REQUEST[$myKeys[$i]];
-	if(!in_array(removeQM(strtolower($myKeys[$i])),$mbkeys)){
-		$reqParams[removeQM(strtolower($myKeys[$i]))] = $_REQUEST[$myKeys[$i]];
+	if(!in_array(removeQM(mb_strtolower($myKeys[$i])),$mbkeys)){
+		$reqParams[removeQM(mb_strtolower($myKeys[$i]))] = $_REQUEST[$myKeys[$i]];
@@ -78,7 +78,7 @@
 /*************  prepare and send the response ************/
-switch (strtolower($request)) {
+switch (mb_strtolower($request)) {
 	case 'getcapabilities':
 		$or = $n->checkURL($row["wms_getcapabilities"]);
 		$or = completeURL($or);
@@ -140,8 +140,8 @@
 	return $url;
 function removeQM($t){
-	if(strpos($t,"?") === 0){
-		$t = substr($t,1);
+	if(mb_strpos($t,"?") === 0){
+		$t = mb_substr($t,1);
 	return $t;
@@ -162,13 +162,13 @@
 	global $sid,$wms;
 	$t = array(htmlentities($wms_getcapabilities),htmlentities($wms_getmap),htmlentities($wms_getfeatureinfo));
 	$new = OWSPROXY ."/". $sid ."/".$wms."?";
-	$r = str_replace($t,$new,$wms_getcapabilities_doc);
+	$r = preg_replace($t,$new,$wms_getcapabilities_doc);
 	header("Content-Type: application/xml");
 	echo $r;
 function checkLayerPermission($l){
 	global $n,$wms_id;
-	$myl = split(",",$l);
+	$myl = mb_split(",",$l);
 	$r = array();
 	foreach($myl as $mysl){
 		if($n->getLayerPermission($wms_id, $mysl, $_SESSION["mb_user_id"]) === true){
More information about the Mapbender_commits mailing list
