[Mapbender-commits] r1643 - trunk/mapbender/http/tools
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 9 05:01:15 EDT 2007
Author: astrid_emde
Date: 2007-08-09 05:01:15 -0400 (Thu, 09 Aug 2007)
New Revision: 1643
   trunk/mapbender/http/tools/mapbender_setup.php
checks for php extensions mbstring an gettext
Modified: trunk/mapbender/http/tools/mapbender_setup.php
--- trunk/mapbender/http/tools/mapbender_setup.php	2007-08-09 08:52:57 UTC (rev 1642)
+++ trunk/mapbender/http/tools/mapbender_setup.php	2007-08-09 09:01:15 UTC (rev 1643)
@@ -104,10 +104,19 @@
 #PGSQL
 	if(!extension_loaded('pgsql')) $check.="<tr><td>PostgreSQL check</td><td></td><td><font color=#FF0000>PostgreSQL not installed (You have to include pgsql-extension if you want to use Postgres as MB-Database!)</font></td></tr>";
 	else $check.="<tr><td>PostgreSQL check</td><td>X</td><td><font color=#00D000>PostgreSQL installed</font></td></tr>";
-#GD
-	if(extension_loaded('gd')) $check.="<tr ><td>GD2 check</td><td>X</td><td><font color=#00D000>GD installed</font></td></tr>";
-	else $check.="<tr ><td>GD2 check</td><td></td><td><font color=#FF0000>GD not installed (no printing possible)</font></td></tr>";
-	echo $check;
+#GD2
+	if(extension_loaded('gd')) $check.="<tr ><td>GD check</td><td>X</td><td><font color=#00D000>GD installed</font></td></tr>";
+	else $check.="<tr ><td>GD check</td><td></td><td><font color=#FF0000>GD not installed (no printing possible)</font></td></tr>";
+#mbstring
+	if(extension_loaded('mbstring')) $check.="<tr ><td>mbstring check</td><td>X</td><td><font color=#00D000>mbstring installed</font></td></tr>";
+	else $check.="<tr ><td>mbstring check</td><td></td><td><font color=#FF0000>PHP extension mbstring is not installed</font></td></tr>";
+#gettext
+	if(extension_loaded('gettext')) $check.="<tr ><td>gettext check</td><td>X</td><td><font color=#00D000>gettext installed</font></td></tr>";
+	else $check.="<tr ><td>gettext check</td><td></td><td><font color=#FF0000>PHP extension gettext is not installed</font></td></tr>";
+	echo $check;
 # Database check
More information about the Mapbender_commits mailing list
