[Mapbender-commits] r1124 - trunk/mapbender/conf
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Feb 13 11:38:47 EST 2007
Author: christoph
Date: 2007-02-13 11:38:47 -0500 (Tue, 13 Feb 2007)
New Revision: 1124
   trunk/mapbender/conf/digitize_default.conf
even more configuration frenzy
Modified: trunk/mapbender/conf/digitize_default.conf
--- trunk/mapbender/conf/digitize_default.conf	2007-02-13 16:32:20 UTC (rev 1123)
+++ trunk/mapbender/conf/digitize_default.conf	2007-02-13 16:38:47 UTC (rev 1124)
@@ -11,6 +11,18 @@
 var selectedLanguage = language.de;
+var messageDescriptionPolygon = [];
+messageDescriptionPolygon[language.de] = "Polygon";
+messageDescriptionPolygon[language.en] = "polygon";
+var messageDescriptionLine = [];
+messageDescriptionLine[language.de] = "Linie";
+messageDescriptionLine[language.en] = "line";
+var messageDescriptionPoint = [];
+messageDescriptionPoint[language.de] = "Punkt";
+messageDescriptionPoint[language.en] = "point";
 var messageErrorNotAnInteger = [];
 messageErrorNotAnInteger[language.de] = "Kein Integer-Wert.";
 messageErrorNotAnInteger[language.en] = "Not an integer value.";
@@ -149,17 +161,26 @@
 addButtonDig("Line", 1, "line_off.png", buttonLabelLineOff[selectedLanguage], buttonLabelLineOn[selectedLanguage], 25, 0);
 addButtonDig("Polygon", 1, "polygon_off.png", buttonLabelPolygonOff[selectedLanguage], buttonLabelPolygonOn[selectedLanguage], 50, 0);
 addButtonDig("dragBasePoint", 1, "move_node_off.png", buttonLabelMoveBasepointOff[selectedLanguage], buttonLabelMoveBasepointOn[selectedLanguage], 75, 0);
-addButtonDig("setBasePoint", 1, "new_node_off.png", buttonLabelMoveBasepointOff[selectedLanguage], buttonLabelMoveBasepointOn[selectedLanguage], 100, 0);
+addButtonDig("setBasePoint", 1, "new_node_off.png", buttonLabelInsertBasepointOff[selectedLanguage], buttonLabelInsertBasepointOn[selectedLanguage], 100, 0);
 addButtonDig("delBasePoint", 1, "delete_node_off.png", buttonLabelDeleteBasepointOff[selectedLanguage], buttonLabelDeleteBasepointOn[selectedLanguage], 125, 0);
 addButtonDig("clear", 1, "del_off.png", buttonLabelClearListOff[selectedLanguage], buttonLabelClearListOn[selectedLanguage], 150, 0);
 //addButtonDig("combine", 1, "combine_off.png", "combine to multigeometry", "combine to multigeometry", 175, 0);
 var buttonDig_wfs_src = "geomInfo.png";
-var buttonDig_wfs_title = "save / update / delete";
+var buttonDig_wfs_title = [];
+buttonDig_wfs_title[language.de] = "speichern / aktualisieren / löschen";
+buttonDig_wfs_title[language.en] = "save / update / delete";
 var buttonDig_remove_src = "geomRemove.png";
-var buttonDig_remove_title = "remove from workspace";
+var buttonDig_remove_title = [];
+buttonDig_remove_title[language.de] = "aus der Liste entfernen";
+buttonDig_remove_title[language.en] = "remove from workspace";
 var buttonDig_removeDb_src = "geomRemoveDb.png";
-var buttonDig_removeDb_title = "remove from database";
+var buttonDig_removeDb_title = [];
+buttonDig_removeDb_title[language.de] = "aus der Datenbank löschen";
+buttonDig_removeDb_title[language.en] = "remove from database";
 var closePolygon_title = "click the first basepoint to close the polygon";
@@ -173,7 +194,7 @@
 var snappingHighlightZIndex = 120;
 var digitizeTransactionalZIndex = 80;
-var digitizeNonTransactionalZIndex = 10;
+var digitizeNonTransactionalZIndex = 20;
 // see also "generalHighlightZIndex" in wfs_default.conf
@@ -192,9 +213,9 @@
 var measureTagStyle = "position:absolute;top:530px;left:250px;width:5000px;height:30px;z-index:100"; //style is ignored when tag already exists
 var measureNumberOfDigits = 3;
-var nonTransactionalEditable = true;
-var nonTransactionalColor = "#bedada";
-var nonTransactionalLineWidth = 1;
+var nonTransactionalEditable = false;
+var nonTransactionalColor = "#ff66cc";
+var nonTransactionalLineWidth = 2;
 var wfsWindowWidth = 400;
 var wfsWindowHeight = 300;
More information about the Mapbender_commits mailing list
