[Mapbender-commits] r1125 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Feb 13 21:37:03 EST 2007
Author: marcjansen
Date: 2007-02-13 21:37:01 -0500 (Tue, 13 Feb 2007)
New Revision: 1125
   trunk/mapbender/http/classes/class_weldLegend2PNG.php
Added documentation,
added imagedestroy for temporary images
Modified: trunk/mapbender/http/classes/class_weldLegend2PNG.php
--- trunk/mapbender/http/classes/class_weldLegend2PNG.php	2007-02-13 16:38:47 UTC (rev 1124)
+++ trunk/mapbender/http/classes/class_weldLegend2PNG.php	2007-02-14 02:37:01 UTC (rev 1125)
@@ -1,7 +1,7 @@
 <?php
 # $Id$
 # http://www.mapbender.org/index.php/class_weldLegend2PNG.php
-# Copyright (C) 2002 CCGIS
+# Copyright (C) 2002 CCGIS
 # This program is free software; you can redistribute it and/or modify
 # it under the terms of the GNU General Public License as published by
@@ -17,49 +17,83 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-* class_weldMaps2PNG
-* @version 1.0.0
-* get/post '___' separated maprequests
 require_once(dirname(__FILE__)."/class_stripRequest.php");
 require_once(dirname(__FILE__)."/class_mb_exception.php");
+ * Class used to weld different images (coming from various maprequests) together.
+ * These maprequests are supposed to be passed to the constructor as '___'-seperated urls.
+ * @version 1.0.0
+ * @uses stripRequest
 class weldMaps2PNG{
-	function weldMaps2PNG($urls,$filename){
+     * Constructor, assumes you pass over two parameters: the first is a string with
+     * different maprequests, each seperated by three underscores (___).
+     * Iteratively calls a method to generate temporary images which are welded together at once.
+     * The generated image is saved to the filesystem under the name
+     * passed over as second parameter to the constructor.
+     * @param <string> the maprequests seperated by three underscores
+	function weldMaps2PNG($urls, $filename){
 		if(!$urls || $urls == ""){
 			$e = new mb_exception("weldMaps2PNG: no maprequests delivered");
+		// getting the array of urls
 		$url = explode("___", $urls);
+		// make url parameters accessible
 		$obj1 = new stripRequest($url[0]);
 		$width = $obj1->get("width");
 		$height = $obj1->get("height");
+		// create output image
 		$image = imagecreatetruecolor($width, $height);
-		$white = ImageColorAllocate($image,255,255,255);
-		ImageFilledRectangle($image,0,0,$width,$height,$white);
+		// assign a white background color
+		$white = ImageColorAllocate($image,255,255,255);
+		ImageFilledRectangle($image,0,0,$width,$height,$white);
+		// iterate over each request
 		for($i=0; $i<count($url); $i++){
 			$obj = new stripRequest($url[$i]);
-			#$url[$i] = $obj->setPNG();
+//            $url[$i] = $obj->setPNG();
 			$url[$i] = $obj->encodeGET();
+			// get temporary image for this URL
 			$img = $this->loadpng($url[$i]);
 			if($img != false){
+				// copy temporary image over already assigned images
 				imagecopy($image, $img, 0, 0, 0, 0, $width, $height);
+				imagedestroy($img);
 			else{
 				$e = new mb_exception("weldMaps2PNG: unable to copy image: " . $url[$i]);
+		// output the image to the filesystem
+		 * @todo different outputs?
 		imagepng($image,$filename);
-		imagedestroy($image);
+		imagedestroy($image);
+	 * Helper function to generate temporary images for each URL
+	 * @param <string> a single URL which represents a maprequest
 	function loadpng ($imgurl) {
 		$obj = new stripRequest($imgurl);
 		$f = $obj->get("format");
+		 * react on format
+		 * @todo create switch?
+		 * @todo handle as reg-exp?
+		 * @todo instanciate $im as false or null?
 		if(strtolower($f) == 'image/png' || strtolower($f) == 'png'){
 			$im = @ImageCreateFromPNG($imgurl);
@@ -72,9 +106,10 @@
 		if(!$im){
 			$im = false;
 			$e = new mb_exception("weldMaps2PNG: unable to load image: ".$imgurl);
+		// return the temporary image
 		return $im;
+} // eof class weldMaps2PNG
\ No newline at end of file
More information about the Mapbender_commits mailing list
