[Mapbender-commits] r1137 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Feb 23 05:44:49 EST 2007
Author: astrid_emde
Date: 2007-02-23 05:44:49 -0500 (Fri, 23 Feb 2007)
New Revision: 1137
   trunk/mapbender/resources/db/update/update_postgresql_db.sql
added new column f_form_element_html in table wfs_conf_element
Modified: trunk/mapbender/resources/db/update/update_postgresql_db.sql
--- trunk/mapbender/resources/db/update/update_postgresql_db.sql	2007-02-23 10:44:31 UTC (rev 1136)
+++ trunk/mapbender/resources/db/update/update_postgresql_db.sql	2007-02-23 10:44:49 UTC (rev 1137)
@@ -112,13 +112,13 @@
 -- new columns in table wfs_conf_element
 -- Selectbox (Text) for predefined values
- ALTER TABLE wfs_conf_element ADD f_box TEXT NULL ;
+ALTER TABLE wfs_conf_element ADD f_form_element_html TEXT NULL ;
 -- editable
- ALTER TABLE wfs_conf_element ADD COLUMN f_edit int4;
+ALTER TABLE wfs_conf_element ADD COLUMN f_edit int4;
 -- Pflichtfeld / mandatory
- ALTER TABLE wfs_conf_element ADD COLUMN f_mandatory int4;
+ALTER TABLE wfs_conf_element ADD COLUMN f_mandatory int4;
 -- add missing primary keys
More information about the Mapbender_commits mailing list
