[Mapbender-commits] r1138 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Feb 23 06:56:04 EST 2007
Author: christoph
Date: 2007-02-23 06:56:03 -0500 (Fri, 23 Feb 2007)
New Revision: 1138
   trunk/mapbender/http/javascripts/point.js
* separation of public, privileged and private member data
* moved code to geometry.js
Modified: trunk/mapbender/http/javascripts/point.js
--- trunk/mapbender/http/javascripts/point.js	2007-02-23 10:44:49 UTC (rev 1137)
+++ trunk/mapbender/http/javascripts/point.js	2007-02-23 11:56:03 UTC (rev 1138)
@@ -5,37 +5,39 @@
 //http://www.mapbender.org/index.php/point.js
 function Point(x, y){
-	this.dist = function(p){
-		return Math.sqrt(Math.pow(this.y-p.y,2) + Math.pow(this.x-p.x,2)) ;
-	this.equals = function(p){
-		if (this.x == p.x && this.y == p.y) {return true;}
-		return false;
-	this.minus = function(p){
-		return new Point(this.x-p.x, this.y-p.y);
-	this.plus = function(p){
-		return new Point(this.x+p.x, this.y+p.y);
-	this.dividedBy = function(c){
-		if (c != 0) {return new Point(this.x/c, this.y/c);}
-		alert("Exception: Division by zero");
-		return false;
-	this.times = function(c){
-		return new Point(this.x*c, this.y*c);
-	this.round = function(numOfDigits){
-		return new Point(roundToDigits(this.x, numOfDigits), roundToDigits(this.y, numOfDigits));
-	this.toString = function(){
-		return "(" + this.x + ", " + this.y + ")";
 	this.x = x;
 	this.y = y;
+Point.prototype.dist = function(p){
+	return Math.sqrt(Math.pow(this.y-p.y,2) + Math.pow(this.x-p.x,2)) ;
+Point.prototype.equals = function(p){
+	if (this.x == p.x && this.y == p.y) {return true;}
+	return false;
+Point.prototype.minus = function(p){
+	return new Point(this.x-p.x, this.y-p.y);
+Point.prototype.plus = function(p){
+	return new Point(this.x+p.x, this.y+p.y);
+Point.prototype.dividedBy = function(c){
+	if (c != 0) {return new Point(this.x/c, this.y/c);}
+	alert("Exception: Division by zero");
+	return false;
+Point.prototype.times = function(c){
+	return new Point(this.x*c, this.y*c);
+Point.prototype.round = function(numOfDigits){
+	return new Point(roundToDigits(this.x, numOfDigits), roundToDigits(this.y, numOfDigits));
+Point.prototype.toString = function(){
+	return "(" + this.x + ", " + this.y + ")";
 // possible improvement: point has flag: map OR real. additional functions: toReal, toMap
@@ -81,13 +83,3 @@
 function roundToDigits(aFloat, numberOfDigits) {
 	return Math.round(aFloat*Math.pow(10, parseInt(numberOfDigits)))/Math.pow(10, parseInt(numberOfDigits));
-function cloneObject(a){
-	var z = [];
-	for (attr in a) {
-		var b = a[attr];
-		if (typeof(b) == "object") {z[attr] = cloneObject(b);}
-		else z[attr] = b;
-	return z;
\ No newline at end of file
More information about the Mapbender_commits mailing list
