[Mapbender-commits] r1033 - trunk/mapbender/http/extensions
svn_mapbender at osgeo.org
Wed Jan 24 08:14:06 EST 2007
Author: christoph
Date: 2007-01-24 08:14:06 -0500 (Wed, 24 Jan 2007)
New Revision: 1033
trunk/mapbender/http/extensions/geom2wfst.php
added ajax style wfs saving
Modified: trunk/mapbender/http/extensions/geom2wfst.php
--- trunk/mapbender/http/extensions/geom2wfst.php 2007-01-24 13:13:40 UTC (rev 1032)
+++ trunk/mapbender/http/extensions/geom2wfst.php 2007-01-24 13:14:06 UTC (rev 1033)
@@ -1,5 +1,3 @@
-<html>
-<head>
<?php
# $Id$
# http://www.mapbender.org/index.php/geom2wfst.php
@@ -19,31 +17,47 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Test WFS-T operated by CCGIS</title>
-</head>
-<body>
-<?php
+require_once("../../conf/mapbender.conf");
+require_once("../classes/class_mb_exception.php");
+function sepNameSpace($s){
+ $c = strpos($s,":");
+ if($c>0) return substr($s,$c+1);
+ return $s;
+function sendToHost($host,$port,$method,$path,$data){
+ $buf = '';
+ if (empty($method)) $method = 'POST';
+ $method = strtoupper($method);
+ $fp = fsockopen($host, $port);
+ fputs($fp, "$method $path HTTP/1.1\r\n");
+ fputs($fp, "Host: $host\r\n");
+ fputs($fp,"Content-type: application/x-www-form-urlencoded\r\n");
+ fputs($fp, "Content-length: " . strlen($data) . "\r\n");
+ fputs($fp, "Connection: close\r\n\r\n");
+ if ($method == 'POST') fputs($fp, $data);
+ while (!feof($fp)) $buf .= fgets($fp,4096);
+ fclose($fp);
+ return $buf;
+$result="";
+$error = false;
$arURL = parse_url($_REQUEST["url"]);
$host = $arURL["host"];
$port = $arURL["port"];
-if($port == ''){
- $port = 80;
+if($port == '') $port = 80;
$path = $arURL["path"];
$method = "POST";
+$filter = stripslashes($_REQUEST["filter"]);
-$data = stripslashes($_REQUEST["filter"]);
+$data = sendToHost($host,$port,$method,html_entity_decode($path),$filter);
-$out = sendToHost($host,$port,$method,html_entity_decode($path),$data);
-$data = $out;
$data = eregi_replace("^[^<]*", "", $data);
$data = eregi_replace("[^>]*$", "", $data);
$parser = xml_parser_create(CHARSET);
xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
@@ -51,85 +65,40 @@
xml_parse_into_struct($parser,$data,$values,$tags);
$code = xml_get_error_code ($parser);
if ($code) {
- echo "<br><br>Error " . $code . " (" . xml_error_string($code) . ")<br><br>";
+ $result = "Error " . $code . " (" . xml_error_string($code) . ")";
+ $error = true;
xml_parser_free($parser);
-$section;
-$result="";
-foreach ($values as $element) {
- $element[tag] = sepNameSpace($element[tag]);
- if(strtoupper($element[tag]) == "SERVICEEXCEPTIONREPORT" && $element[type] == "open"){
- $section = "serviceexceptionreport";
+if (!$error) {
+ $section;
+ foreach ($values as $element) {
+ $element[tag] = sepNameSpace($element[tag]);
+ if(strtoupper($element[tag]) == "SERVICEEXCEPTIONREPORT" && $element[type] == "open"){
+ $section = "serviceexceptionreport";
+ if ($section == "serviceexceptionreport" && strtoupper($element[tag]) == "SERVICEEXCEPTION") {
+// $result = $element[value];
+ $result = "An error occured.";
+ $error = true;
+ if(strtoupper($element[tag]) == "STATUS" && $element[type] == "open"){
+ $section = "status";
+ if ($section == "status" && strtoupper($element[tag]) == "SUCCESS") {
+ $result = "Success.";
+ $error = false;
- if ($section == "serviceexceptionreport" && strtoupper($element[tag]) == "SERVICEEXCEPTION") {
- $result = $element[value];
- $error = true;
- if(strtoupper($element[tag]) == "STATUS" && $element[type] == "open"){
- $section = "status";
- if ($section == "status" && strtoupper($element[tag]) == "SUCCESS") {
- $result = "Success.";
- $error = false;
if ($error) {
- #echo "wfsWindow = open('', 'wfs', 'width=400, height=300, resizable, dependent=yes, scrollbars=yes');";
- #echo "wfsWindow.document.open('text/html');";
- #echo "wfsWindow.document.write('<html><head></head><body>');";
- #echo "wfsWindow.document.write('</body></html>');";
- #echo "wfsWindow.document.getElementsByTagName('body')[0].innerHTML = '".addslashes($result)."';";
- #echo "wfsWindow.document.close();";
- echo $result;
$e = new mb_exception('WFS error at: host: '.$host.' port: '.$port.' filter: '.$_REQUEST["filter"].' - error message: '.$result);
- echo $result;
- echo "<script language='javascript'>";
- echo "window.focus();";
- echo "</script>";
else {
$e = new mb_exception('WFS successfull host: '.$host.' port: '.$port.' filter: '.$_REQUEST["filter"]);
- echo "window.opener.alert('".$result."');\n";
- echo "window.opener.focus();";
- echo "window.close();";
- echo "</script>";
-function sepNameSpace($s){
- $c = strpos($s,":");
- if($c>0){
- return substr($s,$c+1);
- else{
- return $s;
-function sendToHost($host,$port,$method,$path,$data)
- $buf = '';
- if (empty($method)) {
- $method = 'POST';
- $method = strtoupper($method);
- $fp = fsockopen($host, $port);
- fputs($fp, "$method $path HTTP/1.1\r\n");
- fputs($fp, "Host: $host\r\n");
- fputs($fp,"Content-type: application/x-www-form-urlencoded\r\n");
- fputs($fp, "Content-length: " . strlen($data) . "\r\n");
- fputs($fp, "Connection: close\r\n\r\n");
- if ($method == 'POST') {
- fputs($fp, $data);
- while (!feof($fp)) {
- $buf .= fgets($fp,4096);
- fclose($fp);
- return $buf;
-</body>
-</html>
\ No newline at end of file
+header('Content-type: text/xml');
+echo $data;
More information about the Mapbender_commits
