[Mapbender-commits] r1034 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jan 24 08:44:18 EST 2007
Author: christoph
Date: 2007-01-24 08:44:18 -0500 (Wed, 24 Jan 2007)
New Revision: 1034
   trunk/mapbender/http/php/mod_wfs_conf.php
   trunk/mapbender/http/php/mod_wfs_edit.php
removed  f_edit, f_form_element and f_mandatory temporarily
Modified: trunk/mapbender/http/php/mod_wfs_conf.php
--- trunk/mapbender/http/php/mod_wfs_conf.php	2007-01-24 13:14:06 UTC (rev 1033)
+++ trunk/mapbender/http/php/mod_wfs_conf.php	2007-01-24 13:44:18 UTC (rev 1034)
@@ -115,14 +115,15 @@
                 if(!empty($_REQUEST["f_show".$i])){
                 	$sql .= "'1',";
                 }else{$sql .= "'0',";}
-                $sql .= "'".$_REQUEST["f_respos".$i]."',";
-                if(!empty($_REQUEST["f_edit".$i])){
-                	$sql .= "'1',";
-                }else{$sql .= "'0',";}
-                $sql .= "'".$_REQUEST["f_form_element_html".$i]."',";
-                if(!empty($_REQUEST["f_mandatory".$i])){
-                	$sql .= "'1'";
-                }else{$sql .= "'0'";}
+                $sql .= "'".$_REQUEST["f_respos".$i]."'";
+//				$sql .= ",";
+//                if(!empty($_REQUEST["f_edit".$i])){
+//                	$sql .= "'1',";
+//                }else{$sql .= "'0',";}
+//                $sql .= "'".$_REQUEST["f_form_element_html".$i]."',";
+//                if(!empty($_REQUEST["f_mandatory".$i])){
+//                	$sql .= "'1'";
+//                }else{$sql .= "'0'";}
                 $sql .= "); ";
                 $res = db_query($sql);
@@ -244,9 +245,9 @@
                 echo "<td>label_id</td>";
                 echo "<td>show</td>";
                 echo "<td>position</td>";
-                echo "<td>mandatory</td>";
-                echo "<td>edit</td>";
-                echo "<td>html</td>";
+//                echo "<td>mandatory</td>";
+//                echo "<td>edit</td>";
+//                echo "<td>html</td>";
         echo "</tr>";
         for($i=0; $i<count($aWFS->elements->element_id); $i++){
@@ -264,9 +265,9 @@
                 echo "<td><input name='f_label_id".$i."' type='text' size='2'  value='0'></td>";
                 echo "<td><input name='f_show".$i."' type='checkbox'></td>";
                 echo "<td><input name='f_respos".$i."' type='text' size='4' value='0'></td>";
-                echo "<td><input name='f_mandatory".$i."' type='checkbox'></td>";
-                echo "<td><input name='f_edit".$i."' type='checkbox'></td>";
-                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' ></textarea></td>";
+//                echo "<td><input name='f_mandatory".$i."' type='checkbox'></td>";
+//                echo "<td><input name='f_edit".$i."' type='checkbox'></td>";
+//                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' ></textarea></td>";
                 echo "</tr>";
         echo "</table>";
Modified: trunk/mapbender/http/php/mod_wfs_edit.php
--- trunk/mapbender/http/php/mod_wfs_edit.php	2007-01-24 13:14:06 UTC (rev 1033)
+++ trunk/mapbender/http/php/mod_wfs_edit.php	2007-01-24 13:44:18 UTC (rev 1034)
@@ -117,19 +117,21 @@
                 	$sql .= '1';
                 }else{$sql .= '0';}
 				$sql .= "',";
-                $sql .= "f_respos = '".$_REQUEST["f_respos".$i]."', ";
-                $sql .= "f_edit = '";
-                	$sql .= '1';
-                }else{$sql .= '0';}
-				$sql .= "',";
-                $sql .= "f_form_element_html = '".addslashes($_REQUEST["f_form_element_html".$i]);
-				$sql .= "',";
-                $sql .= "f_mandatory = '";
-                	$sql .= '1';
-                $sql .= "' WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id = ".$_REQUEST["f_id".$i].";";
+                $sql .= "f_respos = '".$_REQUEST["f_respos".$i]."' ";
+//				$sql .= ",";
+//                $sql .= "f_edit = '";
+//                	$sql .= '1';
+//                }else{$sql .= '0';}
+//				$sql .= "',";
+//                $sql .= "f_form_element_html = '".addslashes($_REQUEST["f_form_element_html".$i]);
+//				$sql .= "',";
+//                $sql .= "f_mandatory = '";
+//                	$sql .= '1';
+//                $sql .= "' ";
+                $sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id = ".$_REQUEST["f_id".$i].";";
@@ -201,9 +203,9 @@
         echo "</tr>";
         $cnt = 0;
         while($row = db_fetch_array($res)){
@@ -231,14 +233,14 @@
                 if($row["f_show"] == 1){ echo " checked"; }
                 echo "></td>";
                 echo "<td><input name='f_respos".$cnt."' type='text' size='4' value='".$row["f_respos"]."'></td>";
-                echo "<td><input name='f_mandatory".$cnt."' type='checkbox'";
-                if($row["f_mandatory"] == 1){ echo " checked"; }
-                echo "></td>";
-                echo "<td><input name='f_edit".$cnt."' type='checkbox'";
-                if($row["f_edit"] == 1){ echo " checked"; }
-                echo "></td>";
-                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".$row["f_form_element_html"]."</textarea></td>";
-                echo "</tr>";
+//                echo "<td><input name='f_mandatory".$cnt."' type='checkbox'";
+//                if($row["f_mandatory"] == 1){ echo " checked"; }
+//                echo "></td>";
+//                echo "<td><input name='f_edit".$cnt."' type='checkbox'";
+//                if($row["f_edit"] == 1){ echo " checked"; }
+//                echo "></td>";
+//                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".$row["f_form_element_html"]."</textarea></td>";
+//                echo "</tr>";
                 $cnt++;
         echo "</table>";
More information about the Mapbender_commits mailing list
