[Mapbender-commits] r1531 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jul 25 03:53:31 EDT 2007
Author: christoph
Date: 2007-07-25 03:53:31 -0400 (Wed, 25 Jul 2007)
New Revision: 1531
Removed:
   trunk/mapbender/http/classes/class_database.php
   trunk/mapbender/http/classes/class_database_table.php
   trunk/mapbender/http/classes/class_database_table_column.php
   trunk/mapbender/http/classes/class_database_table_constraint.php
   trunk/mapbender/http/classes/class_database_table_key.php
deprecated classes
Deleted: trunk/mapbender/http/classes/class_database.php
--- trunk/mapbender/http/classes/class_database.php	2007-07-24 13:43:40 UTC (rev 1530)
+++ trunk/mapbender/http/classes/class_database.php	2007-07-25 07:53:31 UTC (rev 1531)
@@ -1,939 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_database.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-	manages a database structure
-	contact christoph.baudson at ccgis.de for help
-require_once(dirname(__FILE__)."/class_database_table.php");
-class database{
-	* Class variables:
-	var $table = array();
-	var $table_cnt = -1;
-	var $server;
-	var $db;
-	var $owner;
-	var $pw;
-	var $con;
-	// constructs a database object
-	// if it represents a database of the mapbender user, it should be initialized with arguments,
-	// otherwise (if it represents a remote db) arguments are "", "", "", ""
-	// the constructor already connects to the database!
-	function database($aServer, $aDbName, $anOwner, $aPassword) {
- 		$this->table_cnt = 0;
- 		$this->server = $aServer;
- 		$this->db = $aDbName;
- 		$this->owner = $anOwner;
- 		$this->pw = $aPassword;
- 		// connect only if all parameters are set
- 		if (!($this->server == "" || $this->db == "" || $this->owner == "")) {
-			$this->connect();
-	function connect () {
-		if ($this->server == "" || $this->db == "" || $this->owner == "" ) {
-			echo "Could not connect to database. Some arguments are missing.<br>";
-			echo "server = '" . $this->server . "'; db = '" . $this->db . "'; owner = '" . $this->owner . "';<br>";
-			die();
-		else {
-	 		$this->con = db_connect($this->server,$this->owner,$this->pw);
-	 		if ($this->con) {
-	 			$this->selectDb();
-#		echo $this->server . "<br>";
-#		echo $this->db . "<br>";
-#		echo $this->owner . "<br>";
-#		echo $this->pw . "<br>";
-	function selectDb () {
-		if (!db_select_db($this->db)) {
-			echo "Error while selecting database '" . $this->db . "'<br>";
-			die();
-	// adds a table object to the database object
-	// the table name must be unique
-	function addTable($aTableName){
-		if ($this->getNumberOfTables() == 0 || !in_array($aTableName, $this->getTableNames())) {
-			$this->table[$this->table_cnt] = new database_table($aTableName);
-			$this->table_cnt++;
-			return (strval($this->table_cnt)-1);
-		else {
-			echo "Table '" . $aTableName . "' already in database!<br>";
-	// adds a column object to the table object (table index is known)
-	// the column name must be unique within its table object
-	function addColumnToTableAtIndex($aColumnName, $aTableIndex) {
-		$columnIndex = $this->table[$aTableIndex]->addColumn($aColumnName);
-		return $columnIndex;
-	// adds a column object to the table object (table index is unknown)
-	function addKeyToTableAtIndex($aKeyName, $aColumnName, $isPrimary, $aTableIndex) {
-		$keyIndex = $this->table[$aTableIndex]->addKey($aKeyName, $aColumnName, $isPrimary);
-		return $keyIndex;
-	// adds a constraint object to the table object (table index is unknown)
-	function addConstraintToTableAtIndex ($conSymbol, $tableIndex, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate) {
-		$this->table[$tableIndex]->addConstraint($conSymbol, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate);
-	// returns an array of all table names in this database
-	function getTableNames() {
-		$tables = array();
-		for ($i=0; $i<$this->table_cnt; $i++) {
-			$tables[$i] = $this->table[$i]->getName();
-		if ($this->table_cnt>0) {
-			return $tables;
-		else {
-			return false;
-	// return a table object (index is known)
-	function getTableAtIndex($anIndex) {
-		return $this->table[$anIndex];
-	// return a table object (index is unknown)
-	function getTableWithName($aName) {
-		return $this->table[$this->getTableIndex($aName)];
-	// return the index of a table object
-	function getTableIndex($aTableName) {
-			if ($aTableName == $this->table[$i]->getName()) {
-				return $i;
-		return false;
-	// returns the number of tables in this database object
-	function getNumberOfTables () {
-		return $this->table_cnt;
-	// sets the engine type (f.e. 'InnoDb')
-	function setTableType($anIndex, $aType) {
-		$this->table[$anIndex]->setType($aType);
-	// sets the column data type for a column objext in a table object (both indexes unknown)
-	function setColumnTypeInColumnAtIndexInTableAtIndex($aColumnType, $aColumnIndex, $aTableIndex) {
-		$this->table[$aTableIndex]->setColumnTypeAtIndex($aColumnType, $aColumnIndex);
-	// sets the column attributes (f.e. "NOT NULL")
-	function setColumnAttributesInColumnAtIndexInTableAtIndex($someColumnAttributes, $aColumnIndex, $aTableIndex) {
-		$this->table[$aTableIndex]->setColumnAttributesAtIndex($someColumnAttributes, $aColumnIndex);
-	// sets the column default (f.e. "DEFAULT ''")
-	function setColumnDefaultInColumnAtIndexInTableAtIndex($someColumnDefault, $aColumnIndex, $aTableIndex) {
-		$this->table[$aTableIndex]->setColumnDefaultAtIndex($someColumnDefault, $aColumnIndex);
-	// displays the whole database structure
-	function displayDatabase() {
-		print_r($this->table);
-	// imports the structure of an actual database specified by server, db, owner, pw
-	function mysqlDbToDatabase() {
-		if (!$this->con) {
-			$this->connect();
-		// collects all table names
-		$sql = "SHOW TABLES FROM " . $this->db;
-		$res = db_query($sql);
-		$cnt = 0;
-		while($table = db_fetch_row($res)){
-			$inst_tables[$cnt] = $table[0];
-			$cnt++;
-		$message = array();
-		$createTable = array();
-		// generates SHOW CREATE TABLE sqls for each table name
-		for ($i=0; $i<count($inst_tables); $i++) {
-			$sql = "SHOW CREATE TABLE " . $inst_tables[$i];
-			$cnt = 0;
-				$message[$cnt] = $table[1];
-				$cnt++;
-			$createTable[$i] = $message[0] . ";";
-		$createTableString = implode("\n", $createTable);
-		$createTableArray = array();
-		$createTableArray = explode("\n", $createTableString);
-		// treat the sqls just like a dump
-		$cleanDump = $this->mysqlCleanDumpArray($createTableArray);
-		$this->mysqlDumpToDatabaseFromArray($cleanDump);
-	// compares this database object with another (remote) one
-	// returns sql statements that adds or changes tables/columns/constraints/keys
-	//  so that this database has all fields of the remote database as well
-	function compareDbWithRemoteDb($remoteDb, &$messageArray) {
-		$sql = "";
-		$message = "";
-		$sqlCreateTable = "";
-		$messageCreateTable = "";
-		$sqlColumn = "";
-		$messageColumn = "";
-		$sqlKey = "";
-		$messageKey = "";
-		$sqlConstraint = "";
-		$messageConstraint = "";
-		$splitString = "::::";
-		for ($i=0; $i < $remoteDb->getNumberOfTables(); $i++) {
-			$t = $remoteDb->getTableAtIndex($i);
-			$table = $t->getName();
-			// check tables
-			// check if all tables from the remote DB are in the local DB
-			// if a table is missing, generate a SQL containg a CREATE TABLE statement
-			if (!in_array($table, $this->getTableNames())) {
-				$messageCreateTable .= "Table '" . $table . "' is missing.";
-				$messageCreateTable .= $splitString;
-				$sqlCreateTable .= $t->getMysql();
-			//table exists, now checking columns
-			else {
-				// check columns
-				// check if all columns of a table from the remote DB are in the local DB
-				// if a column is missing, generate a SQL containg a ALTER TABLE statement
-				//php4
-				$table_i = $t;
-				$table_i_nr_cols = $table_i->getNumberOfColumns();
-				$tableWithName_table = $this->getTableWithName($table);
-				for ($j=0; $j < $table_i_nr_cols; $j++) {
-					$c = $table_i->getColumnAtIndex($j);
-					$column = $c->getName();
-					if (!in_array($column, $tableWithName_table->getColumnNames())) {
-#PHP5					if (!in_array($column, $this->getTableWithName($table)->getColumnNames())) {
-						$messageColumn .= "Column '".$column."' is missing.";
-						$messageColumn .= $splitString;
-						$sqlColumn .= "ALTER TABLE " . $table . " ADD COLUMN";
-						$sqlColumn .= $c->getMysql();
-					//column exists, now checking type and attributes
-					else {
-						// check if type (varchar etc) AND attributes are equal
-						$colWithName_column = $tableWithName_table->getColumnWithName($column);
-						if (trim(strtoupper($colWithName_column->getType())) != trim(strtoupper($c->getType()))
-						  || trim(strtoupper($colWithName_column->getAttributes())) != trim(strtoupper($c->getAttributes()))) {
-#php5						if (trim(strtoupper($this->getTableWithName($table)->getColumnWithName($column)->getType())) != trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getType()))
-#php5						|| trim(strtoupper($this->getTableWithName($table)->getColumnWithName($column)->getAttributes())) != trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getAttributes()))) {
-							$messageColumn .= "Column '".$column."' has incorrect type or attributes.";
-							$sqlColumn .= "ALTER TABLE " . $table . " CHANGE COLUMN " . $column;
-						 * checking DEFAULTs doesn't work properly
-						 if (trim(strtoupper($this->getTableWithName($table)->getColumnWithName($column)->getDefaultValue())) != trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getDefaultValue()))) {
-							$messageColumn .= "Column '".$remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getName()."' has incorrect default value.";
-							#echo trim(strtoupper($this->getTableWithName($table)->getColumnWithName($column)->getDefaultValue())) . "<br>";
-							#echo trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getDefaultValue())) . "<br><br>";
-							$sqlColumn .= "ALTER TABLE " . $table . " ALTER COLUMN " . $column;
-							$newDef = trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getDefaultValue()));
-							if ($newDef) {
-								$sqlColumn .= " SET DEFAULT " . trim(strtoupper($remoteDb->getTableAtIndex($i)->getColumnAtIndex($j)->getDefaultValue())) . "\n\n";
-							else {
-								$sqlColumn .= " DROP DEFAULT\n\n";
-				// check keys
-				for ($j=0; $j < $table_i->getNumberOfKeys(); $j++) {
-					$k = $table_i->getKeyAtIndex($j);
-					$key = $k->getKey();
-					if (!in_array($key, $tableWithName_table->getAllKeys())) {
-#php5				if (!in_array($key, $this->getTableWithName($table)->getAllKeys())) {
-						$messageKey .= "Key '".$k->getName()."' is missing.";
-						$messageKey .= $splitString;
-						$sqlKey .= "ALTER TABLE " . $table . " ADD";
-						$sqlKey .=	$k->getMysql();
-				// check constraints
-				//  FIXME
-				//  InnoDB: Let InnoDB's FOREIGN KEY parser to remove the latin1 character 0xA0
-				//  from the end of an unquoted identifier. The EMS MySQL Manager in ALTER TABLE
-				//  adds that character after a table name, which caused error 121 when we tried
-				//  to add a new constraint.
-				//  May work with Mysql >= 4.1
-				//  http://bugs.mysql.com/bug.php?id=6340
-				for ($j=0; $j < $table_i->getNumberOfConstraints(); $j++) {
-					$k = $table_i->getConstraintAtIndex($j);
-					$key = $k->getConstraint();
-					$someArray = $tableWithName_table->getAllConstraints();
-					if (!in_array($key, $someArray)) {
-						$messageConstraint .= "Constraint is missing.";
-						$messageConstraint .= $splitString;
-						$sqlConstraint .= "ALTER TABLE " . $table . " ADD";
-						$sqlConstraint .=	$k->getMysql();
-		//order in which the sql statements will be processed
-		// create table
-		// add / change column
-		// add / change key
-		// add / change constraints
-		$sql = $sqlCreateTable . $sqlColumn . $sqlKey . $sqlConstraint;
-		$message = $messageCreateTable . $messageColumn . $messageKey . $messageConstraint;
-		// remove last "\n\n"
-		$sql = substr($sql, 0, strlen($sql)-2);
-		// remove last $splitString
-		$message = substr($message, 0, strlen($message)-strlen($splitString));
-		// break sql string into single sql statements
-		$sqlArray = explode("\n\n", $sql);
-		// break message string into single message statements
-		$messageArray = explode($splitString, $message);
-		return $sqlArray;
-	// executes a single sql statement
-	// connection details have to be specified in this database object
-	// returns a string with error message
-	function executeMysql($sql) {
-		$error = "";
-			$this->connect();
-		if (db_errno()) {
-			$error .= $sql . "<br>" . db_error() . "<br><br>";
-		return $error;
-	// executes sql statements
-	// returns a string with all error messages
-	function executeMysqlArray($sqlArray) {
-		$error = "";
-		for ($i=0; $i<count($sqlArray); $i++) {
-			if ($sqlArray[$i] != "") {
-				$error .= $this->executeMysql($sqlArray[$i]);
-		return $error;
-	// executes sql transaction
-	function executeMysqlTransaction($sqlArray) {
-		$error = "";
-		$error .= $this->executeMysql("START TRANSACTION");
-			//echo $error;
-		$error .= $this->executeMysql("COMMIT");
-		return $error;
-	// ONLY NEEDED IN function mysqlDumpToDatabaseFromArrayNew($dumpArray)
-	// this function extracts attributes of a constraint from an excerpt of an sql statement
-	// this is needed in two segments of the algorithm and is therefore put in a function
-	function addConstraintFromString($row, $tableIndex) {
-		//retrieve constraint data
-		$row = str_replace("(", "", $row);
-		$row = str_replace(")", "", $row);
-		$row = str_replace(", ", " ", $row);
-		while (ereg("([:space:]){2}")) {
-			ereg_replace("([:space:]){2}", "([:space:])", $row);
-		$row = str_replace("on delete", "ondelete", strtolower($row));
-		$row = str_replace("on update", "onupdate", strtolower($row));
-		$row = str_replace("foreign key", "foreignkey", strtolower($row));
-		$values = explode(" ", $row);
-		$cnt = 0;
-		$conSymbol = "";
-		$conOnDelete = "";
-		$conOnUpdate = "";
-		$conColumn = "";
-		$conTableName = "";
-		$conTableColumnName = "";
-		if ($cnt < count($values) && strtolower($values[$cnt]) == "constraint") {
-			$cnt++;
-		if ($cnt < count($values) && strtolower($values[$cnt]) != "foreignkey") {
-			$conSymbol = $values[$cnt];
-			$cnt++;
-		if ($cnt < count($values) && strtolower($values[$cnt]) == "foreignkey") {
-			$cnt++;
-			while ($cnt < count($values) && strtolower($values[$cnt]) != "references") {
-				if (!$conColumn) {
-					$conColumn = $values[$cnt];
-				else {
-					$conColumn .= "," . $values[$cnt];
-				$cnt++;
-		if ($cnt < count($values) && strtolower($values[$cnt]) == "references") {
-			$cnt++;
-			$conTableName = $values[$cnt];
-			$cnt++;
-		while ($cnt < count($values) && strtolower($values[$cnt]) != "ondelete" && strtolower($values[$cnt]) != "onupdate" ) {
-			if (!$conTableColumnName) {
-				$conTableColumnName = $values[$cnt];
-			else {
-				$conTableColumnName .= "," . $values[$cnt];
-			$cnt++;
-		if ($cnt < count($values) && strtolower($values[$cnt]) == "ondelete") {
-			$cnt++;
-			$conOnDelete = $values[$cnt];
-			$cnt++;
-		if ($cnt < count($values) && strtolower($values[$cnt]) == "onupdate") {
-			$cnt++;
-			$conOnUpdate = $values[$cnt];
-			$cnt++;
-		$this->addConstraintToTableAtIndex($conSymbol, $tableIndex, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate);
-	// creates a database object from a mysql dump
-	// the dump is parsed and the objects are generated accordingly
-	// needs some testing!
-	// restrictions:
-	// only 'foreign key' constraints are implemented, no other constraints.
-	function mysqlDumpToDatabaseFromArray($commandArray) {
-		// now the parsing begins
-		$tableIndex = -1;
-		$keyIndex = -1;
-		$tablename = "";
-		$verbose = "";
-		for ($i=0; $i<count($commandArray); $i++) {
-			$line = $commandArray[$i];
-			// check for "CREATE TABLE"
-			if (strtolower(substr($line, 0, 12)) == "create table") {
-				// remove "create table" from the string
-				$line = trim(substr($line, 12));
-				// look for "(", because it marks the end of the table name
-				$pos = strpos($line, "(");
-				$tablename = trim(substr($line, 0, $pos));
-				$tableIndex = $this->addTable($tablename);
-				//remove tablename and "(" from string
-				$line = trim(substr($line, $pos+1));
-				//get the last ")" in the string and get the type
-				$type = trim(substr(strrchr($line, ")"), 1));
-				$type = trim(substr(strstr($line, '='), 1));
-				$this->setTableType($tableIndex, $type);
-				//remove the type bit from the line
-				$line = substr($line, 0, strlen($line)-strlen(strrchr($line, ")")));
-				//replace , that are not seperating column definitions (or key definitions)
-				// these may be , that seperate two columns forming a key
-				$regexp = "(\([A-Za-z0-9[:space:]_\-\,;]+)\,([A-Za-z0-9[:space:]_\-\,;]+\))";
-				$regexp_replace = "\\1;;;\\2";
-				$replace = false;
-				while (ereg($regexp, $line)) {
-					#if (!$replace) echo "<br><br>" . $line . "<br><br>";
-					$line = ereg_replace($regexp, $regexp_replace, $line);
-					$replace = true;
-				$rows = explode(",", $line);
-				$rows = str_replace(";;;", ",", $rows);
-				for ($j=0; $j<count($rows); $j++) {
-					// trim each row.
-					$row = trim($rows[$j]);
-					//find primary keys
-					if (strtolower(substr($row,0,11)) == "primary key" ) {
-						//retrieve key data
-						$row = trim(substr($row, 12));
-						$row = trim(str_replace("(", "", $row));
-						$row = trim(str_replace(")", "", $row));
-						$keyIndex = $this->addKeyToTableAtIndex("", $row, true, $tableIndex);
-					// key
-					elseif (strtolower(substr($row,0,3)) == "key" ) {
-						$row = trim(substr($row, 4));
-						$keys = explode(" ", $row);
-						//add key to object
-						$keyIndex = $this->addKeyToTableAtIndex($keys[0], $keys[1], false, $tableIndex);
-					elseif (strtolower(substr($row,0,10)) == "constraint" ) {
-						$this->addConstraintFromString(substr($row, 11), $tableIndex);
-					else {
-						//retrieve column information
-						$column = explode(" ", $row);
-						$col_name = $column[0];
-						$col_type = $column[1];
-						$col_attributes = substr($row,strlen($column[0])+strlen($column[1])+2);
-						$col_attr_array = explode(" ", $col_attributes);
-						$col_attributes = "";
-						for ($r=0; $r<strlen($col_attr_array); $r++) {
-							if (strtoupper($col_attr_array[$r]) == "DEFAULT") {
-								$defaultValue = $col_attr_array[$r+1];
-								$r++;
-							else {
-								$col_attributes .= $col_attr_array[$r] . " ";
-						//add columns to object
-						$columnIndex = $this->addColumnToTableAtIndex($col_name, $tableIndex);
-						$this->setColumnTypeInColumnAtIndexInTableAtIndex($col_type, $columnIndex, $tableIndex);
-						$this->setColumnAttributesInColumnAtIndexInTableAtIndex($col_attributes, $columnIndex, $tableIndex);
-						$this->setColumnDefaultInColumnAtIndexInTableAtIndex($defaultValue, $columnIndex, $tableIndex);
-			// CHECK FOR ALTER TABLE (for constraints, like in PHPMyAdmin dumps)
-			elseif (strtolower(substr($line, 0, 11)) == "alter table") {
-				// remove "alter table" from the string
-				// identify the tableIndex of the constraint
-				$pos = strpos($line, " ");
-				$tableIndex = $this->getTableIndex($tablename);
-				// delete table name from line
-				// identify the command, f.e. ADD
-				$cmd = trim(substr($line, 0, $pos));
-				$line = trim(str_replace(",", "", $line));
-				$constraintStrings = explode($cmd, $line);
-				for ($k=0; $k<count($constraintStrings); $k++) {
-					$con = trim($constraintStrings[$k]);
-					$this->addConstraintFromString($con, $tableIndex);
-	function mysqlCleanDumpArray ($dumpArray) {
-		// remove commentary and name wrappers
-		$cnt=0;
-		$newDumpArray = array();
-		for ($i=0; $i<count($dumpArray); $i++) {
-			// remove ` (name wrappers, like in dumpArrays from PHPMyAdmin)
-			$dumpArray[$i] = trim(str_replace("`", "", $dumpArray[$i]));
-			// discard empty lines and comments (lines beginning with "#" (like in MySQL Front), or "-" (like in PHPMyAdmin))
-			if (substr($dumpArray[$i], 0, 1) == "#" || substr($dumpArray[$i], 0, 1) == "-" || $dumpArray[$i]=="") {
-				$dumpArray[$i] = "";
-			else {
-				$newDumpArray[$cnt] = $dumpArray[$i];
-				$cnt++;
-		// put everything in one string
-		$dump = implode(":::: ", $newDumpArray);
-		//remove tabs and new lines
-		$dump = str_replace("\n", "", $dump);
-		$dump = str_replace("\t", "", $dump);
-		// replace multiple spaces by single spaces
-		while(ereg("  ", $dump)){
-			$dump = ereg_replace("  ", " ", $dump);
-		// split string to array of single sql commands
-		$commandArray = explode(";::::", $dump);
-		// trim each command
-			$commandArray[$i] = str_replace("::::", "", trim($commandArray[$i]));
-			//remove last ";"
-			if (substr($commandArray[$i], -1) == ";") {
-				$commandArray[$i] = substr($commandArray[$i], 0, strlen($commandArray[$i])-1);
-		return $commandArray;
-	// loads a mysql dump hands it over to the parser
-	function mysqlDumpToDatabaseFromUrl($url) {
-		$dumpArray=array();
-		if ($dumpArray = file($url)) {
-			$cleanDump = $this->mysqlCleanDumpArray($dumpArray);
-		else {
-			echo "MySQL dump not found!";
-			die();
-	function mysqlDumpFromArray($dumpArray) {
-		return $cleanDump;
-	function mysqlDumpFromUrl($url) {
-		return false;
-	// removes a table object at a given index
-	function removeTableAtIndex ($aTableIndex) {
-		if ($aTableIndex && $aTableIndex < $this->table_cnt && $aTableIndex >= 0) {
-			$this->table[$aTableIndex]->destroyTable();
-			//fill gap in table array with last entry
-			if ($this->table_cnt > 1 && $aTableIndex != $this->table_cnt-1) {
-				$this->table[$aTableIndex] = $this->table[$this->table_cnt-1];
-				$this->table[$this->table_cnt-1] = null;
-			$this->table_cnt--;
-		else {
-			echo "Table '" . $aTableIndex . "' not in database!<br>";
-	// removes a table object (table index unknown)
-	function removeTableWithName($aTableName){
-		$index = $this->getTableIndex($aTableName);
-		$this->removeTableAtIndex($index);
-	// removes a column object in a table object (table index unknown)
-	function removeColumnWithNameInTableWithName($aColumnName, $aTableName){
-		$this->removeColumnWithNameInTableAtIndex($aColumnName, $index);
-	// removes a key object in a table object (table index unknown)
-	function removeKeyWithNameInTableWithName($aKeyName, $aTableName){
-		$this->removeKeyWithNameInTableAtIndex($aKeyName, $index);
-	// removes a constraint object in a table object (table index unknown)
-	function removeConstraintWithNameInTableWithName($aConstraintName, $aTableName){
-		$this->removeConstraintWithNameInTableAtIndex($aConstraintName, $index);
-	// removes a column object in a table object at a given table index
-	function removeKeyWithNameInTableAtIndex($aKeyName, $aTableIndex){
-		if ($aTableIndex < $this->table_cnt && $aTableIndex >= 0 && $aKeyName != "") {
-			$this->table[$aTableIndex]->removeKeyWithName($aKeyName);
-		else {
-			echo "Table index out of range!<br>";
-	// removes a constraint object in a table object at a given table index
-	function removeConstraintWithNameInTableAtIndex($aConstraintName, $aTableIndex){
-		if ($aTableIndex < $this->table_cnt && $aTableIndex >= 0 && $aConstraintName != "") {
-			$this->table[$aTableIndex]->removeConstraintWithName($aConstraintName);
-		else {
-	function removeColumnWithNameInTableAtIndex($aColumnName, $aTableIndex){
-		if ($aTableIndex < $this->table_cnt && $aTableIndex >= 0 && $aColumnName != "") {
-			$this->table[$aTableIndex]->removeColumnWithName($aColumnName);
-		else {
-// EXAMPLES
-// this is how the database object may be accessed
-//creates a database from an actual database
-//$myDb = new database($server, $db, $owner, $pw);
-//$myDb->mysqlDbToDatabase();
-//creates a database from a mysql dump
-//$myDb = new database("", "", "", "");
-//$myDb->mysqlDumpToDatabaseFromUrl("http://localhost/mapbender/mapbender_PHPMyAdmin.sql");
-//removes the table "wms" from the database
-//$myDb->removeTableWithName("mb_user_mb_group");
-//(intended to be a private method)
-//removes the column "gui_id" from table "gui"
-//$myDb->removeColumnWithNameInTableWithName("gui_id", "gui");
-//removes the key "mb_Group_index" from table "mb_user_mb_group"
-//$myDb->removeKeyWithNameInTableWithName("mb_group_index", "mb_user_mb_group");
-//removes the constraint "mb_user_mb_group_ibfk_1" from table "mb_user_mb_group"
-//$myDb->removeConstraintWithNameInTableWithName("mb_user_mb_group_ibfk_1", "mb_user_mb_group");
-//validates ownDb against remoteDb and returns an SQL string
-//$sql = $myDb->compareDbWithRemoteDb($theirDb);
-// executes all statements and displays occuring mysql errors
-//echo $myDb->executeMysqlArray($sqlArray);
-//displays the complete database structure
-//$myDb->displayDatabase();
- *  MySQL - Definition CREATE TABLE
-       CREATE [TEMPORARY] TABLE [IF NOT EXISTS] tbl_name
-       [(create_definition,...)]
-       [table_options] [select_statement]
-       [(] LIKE old_tbl_name [)];
-       create_definition:
-       column_definition
-       | [CONSTRAINT [symbol]] PRIMARY KEY [index_type] (index_col_name,...)
-       | KEY [index_name] [index_type] (index_col_name,...)
-       | INDEX [index_name] [index_type] (index_col_name,...)
-       | [CONSTRAINT [symbol]] UNIQUE [INDEX]
-       [index_name] [index_type] (index_col_name,...)
-       | [FULLTEXT|SPATIAL] [INDEX] [index_name] (index_col_name,...)
-       | [CONSTRAINT [symbol]] FOREIGN KEY
-       [index_name] (index_col_name,...) [reference_definition]
-       | CHECK (expr)
-       column_definition:
-       col_name type [NOT NULL | NULL] [DEFAULT default_value]
-       [AUTO_INCREMENT] [UNIQUE [KEY] | [PRIMARY] KEY]
-       [COMMENT 'string'] [reference_definition]
-       type:
-       TINYINT[(length)] [UNSIGNED] [ZEROFILL]
-       | SMALLINT[(length)] [UNSIGNED] [ZEROFILL]
-       | MEDIUMINT[(length)] [UNSIGNED] [ZEROFILL]
-       | INT[(length)] [UNSIGNED] [ZEROFILL]
-       | INTEGER[(length)] [UNSIGNED] [ZEROFILL]
-       | BIGINT[(length)] [UNSIGNED] [ZEROFILL]
-       | REAL[(length,decimals)] [UNSIGNED] [ZEROFILL]
-       | DOUBLE[(length,decimals)] [UNSIGNED] [ZEROFILL]
-       | FLOAT[(length,decimals)] [UNSIGNED] [ZEROFILL]
-       | DECIMAL(length,decimals) [UNSIGNED] [ZEROFILL]
-       | NUMERIC(length,decimals) [UNSIGNED] [ZEROFILL]
-       | DATE
-       | TIME
-       | TIMESTAMP
-       | DATETIME
-       | CHAR(length) [BINARY | ASCII | UNICODE]
-       | VARCHAR(length) [BINARY]
-       | TINYBLOB
-       | BLOB
-       | MEDIUMBLOB
-       | LONGBLOB
-       | TINYTEXT [BINARY]
-       | TEXT [BINARY]
-       | MEDIUMTEXT [BINARY]
-       | LONGTEXT [BINARY]
-       | ENUM(value1,value2,value3,...)
-       | SET(value1,value2,value3,...)
-       | spatial_type
-       index_col_name:
-       col_name [(length)] [ASC | DESC]
-       reference_definition:
-       REFERENCES tbl_name [(index_col_name,...)]
-       [MATCH FULL | MATCH PARTIAL | MATCH SIMPLE]
-       [ON DELETE reference_option]
-       [ON UPDATE reference_option]
-       reference_option:
-       RESTRICT | CASCADE | SET NULL | NO ACTION
-       table_options: table_option [table_option] ...
-       table_option:
-       {ENGINE|TYPE} = engine_name
-       | AUTO_INCREMENT = value
-       | AVG_ROW_LENGTH = value
-       | [DEFAULT] CHARACTER SET charset_name [COLLATE collation_name]
-       | CHECKSUM = {0 | 1}
-       | COMMENT = 'string'
-       | MAX_ROWS = value
-       | MIN_ROWS = value
-       | PACK_KEYS = {0 | 1 | DEFAULT}
-       | PASSWORD = 'string'
-       | DELAY_KEY_WRITE = {0 | 1}
-       | ROW_FORMAT = {DEFAULT|DYNAMIC|FIXED|COMPRESSED|REDUNDANT|COMPACT}
-       | RAID_TYPE = { 1 | STRIPED | RAID0 }
-       RAID_CHUNKS = value
-       RAID_CHUNKSIZE = value
-       | UNION = (tbl_name[,tbl_name]...)
-       | INSERT_METHOD = { NO | FIRST | LAST }
-       | DATA DIRECTORY = 'absolute path to directory'
-       | INDEX DIRECTORY = 'absolute path to directory'
-       select_statement:
-       [IGNORE | REPLACE] [AS] SELECT ...   (Some legal select statement)
Deleted: trunk/mapbender/http/classes/class_database_table.php
--- trunk/mapbender/http/classes/class_database_table.php	2007-07-24 13:43:40 UTC (rev 1530)
+++ trunk/mapbender/http/classes/class_database_table.php	2007-07-25 07:53:31 UTC (rev 1531)
@@ -1,416 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_database_table.php
-require_once(dirname(__FILE__)."/class_database_table_column.php");
-require_once(dirname(__FILE__)."/class_database_table_key.php");
-require_once(dirname(__FILE__)."/class_database_table_constraint.php");
-class database_table{
-	var $name;
-	var $column = array();
-	var $key = array();
-	var $constraint = array();
-	var $key_cnt = -1;
-	var $column_cnt = -1;
-	var $constraint_cnt = -1;
-	var $type;
-	function database_table($aName) {
- 		$this->constraint_cnt = 0;
- 		$this->column_cnt = 0;
- 		$this->key_cnt = 0;
- 		$this->name = $aName;
-	function addKey ($aKeyName, $aColumnName, $isPrimary) {
-		if (!strpos($aColumnName, ",")) {
-			// referenced column must be part of the table
-			if (in_array($aColumnName, $this->getColumnNames())) {
-				if ($this->getNumberOfKeys() == 0 || !$this->keyExists($aKeyName, $aColumnName)) {
-					$this->key[$this->key_cnt] = new database_table_key($aKeyName, $aColumnName, $isPrimary);
-					$index = $this->key_cnt;
-					$this->key_cnt ++;
-					return $index;
-				else {
-					echo "Key '" . $aKeyName . "' already in table!<br>";
-			else {
-				echo "Error when adding a new key: Column '" . $aColumnName . "' must be from table '" . $this->getName() . "'!<br>";
-		else {
-			$keyArray = explode(",", $aColumnName);
-			$inArray = true;
-			for ($i=0; $i < count($keyArray); $i++) {
-				if (!in_array($keyArray[$i], $this->getColumnNames())) {
-					$inArray = false;
-			if ($inArray) {
-					return $index;
-				else {
-	function addConstraint($conSymbol, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate) {
-		if (!strpos($conColumn, ",")&& !strpos($conTableColumnName, ",")) {
-			if (in_array($conColumn, $this->getColumnNames())) {
-				$newConstr = new database_table_constraint($conSymbol, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate);
-				$conSymbol = "";
-				#print_r($newConstr);
-				#print_r($this->getAllConstraints());
-				if (!in_array($newConstr, $this->getAllConstraints())) {
-					$this->constraint[$this->constraint_cnt] = $newConstr;
-					$index = $this->constraint_cnt;
-					$this->constraint_cnt ++;
-					return $index;
-			else {
-				echo "Error when adding a new constraint: Column '" . $conColumn . "' must be from table '" . $this->getName() . "'!<br>";
-		else {
-			$inArray = true;
-			$keyArray = explode(",", $conColumn);
-					$inArray = false;
-			$keyArray = explode(",", $conTableColumnName);
-					$inArray = false;
-			if ($inArray) {
-				return $index;
-		return false;
-	function addColumn ($aColumnName) {
-		if ($this->getNumberOfColumns() == 0 || !in_array($aColumnName, $this->getColumnNames())) {
-			$this->column[$this->column_cnt] = new database_table_column($aColumnName);
-			$index = $this->column_cnt;
-			$this->column_cnt ++;
-			return $index;
-		else {
-			echo "Column '" . $aColumnName . "' already in table!<br>";
-	function getName(){
-		return $this->name;
-	function getKeyAtIndex($anIndex){
-		return $this->key[$anIndex];
-	function getAllKeys(){
-		$keyArray = array();
-		for ($i=0; $i<$this->getNumberOfKeys(); $i++) {
-			$key_i = $this->getKeyAtIndex($i);
-			$keyArray[$i] = $key_i->getKey();
-		return $keyArray;
-	function getAllConstraints(){
-		$conArray = array();
-		for ($i=0; $i<$this->getNumberOfConstraints(); $i++) {
-			$con_i = $this->getConstraintAtIndex($i);
-			$conArray[$i] = $con_i->getConstraint();
-		return $conArray;
-	function getConstraintAtIndex($anIndex){
-		return $this->constraint[$anIndex];
-	function getColumnAtIndex($anIndex){
-		return $this->column[$anIndex];
-	function getColumnWithName($aName){
-		return $this->getColumnAtIndex($this->getColumnIndex($aName));
-	function getType() {
-		return $this->type;
-	function getMysql() {
-		$sql = "";
-		$sql .= "CREATE TABLE " . $this->getName() . " (\n";
-		// add the columns
-		for ($i=0; $i<$this->getNumberOfColumns(); $i++) {
-			$sql .= "\t" . $this->column[$i]->getName() . " ";
-			$sql .= $this->column[$i]->getType() . " ";
-			$sql .= $this->column[$i]->getAttributes();
-			$sql .= ",";
-			$sql .= "\n";
-		// add keys
-			if ($this->key[$i]->isPrimary()) {
-				$sql .= "\tPRIMARY KEY ";
-			else {
-				$sql .= "\tKEY ";
-			$sql .= $this->key[$i]->getKeyName() . " ";
-			$sql .= "(" . $this->key[$i]->getColumnName() . "),\n";
-		// add constraints
-			$constr = array();
-			$constr = $this->constraint[$i]->getConstraint();
-			$sql .= "\tCONSTRAINT";
-			// constraint name
-			if ($constr[0]) {
-				$sql .= " " . $constr[0];
-			if ($constr[1]) {
-				$sql .= " FOREIGN KEY (" . $constr[1] . ")";
-				if ($constr[2] && $constr[3]) {
-					$sql .= " REFERENCES " . $constr[2] . " (" . $constr[3] . ")";
-					if ($constr[4]) {
-						$sql .= " ON DELETE " . $constr[4];
-					if ($constr[5]) {
-						$sql .= " ON UPDATE " . $constr[5];
-			$sql .= ",\n";
-		// remove last ","
-		$sql = substr($sql, 0, strlen($sql)-2) . "\n";
-		// add the table type
-		$sql .= ") TYPE = " . $this->getType() . "\n\n";
-		return $sql;
-	function getColumnNames() {
-		$columns = array();
-		for ($i=0; $i<$this->column_cnt; $i++) {
-			$columns[$i] = $this->column[$i]->getName();
-		if ($this->column_cnt>0) {
-			return $columns;
-		else {
-			return false;
-	function getColumnIndex($aColumnName) {
-			if ($aColumnName == $this->column[$i]->getName()) {
-				return $i;
-		return false;
-	function getKeyIndex($aKeyName) {
-		for ($i=0; $i<$this->key_cnt; $i++) {
-			if ($aKeyName == $this->key[$i]->getKeyName()) {
-				return $i;
-		return false;
-	function getConstraintIndex($aConstraintName) {
-		for ($i=0; $i<$this->constraint_cnt; $i++) {
-			if ($aConstraintName == $this->constraint[$i]->getName()) {
-				return $i;
-		return false;
-	function getNumberOfColumns () {
-		return $this->column_cnt;
-	function getNumberOfConstraints () {
-		return $this->constraint_cnt;
-	function getNumberOfKeys () {
-		return $this->key_cnt;
-	function destroyTable() {
-		settype(&$this, 'null');
-	//FIXME
-	function keyExists ($aKeyName, $aColumnName) {
-		return false;
-	//FIXME
-	function constraintExists ($aConstraintName, $aColumnName) {
-		return false;
-	function setType($aType) {
-		$this->type = $aType;
-	function setColumnTypeAtIndex($aColumnType, $aColumnIndex) {
-		if ($aColumnIndex < $this->column_cnt) {
-			$this->column[$aColumnIndex]->setType($aColumnType);
-		else {
-			echo "column index out of range!";
-	function setColumnAttributesAtIndex($someColumnAttributes, $aColumnIndex) {
-			$this->column[$aColumnIndex]->setAttributes($someColumnAttributes);
-		else {
-	function setColumnDefaultAtIndex($someColumnDefault, $aColumnIndex) {
-			$this->column[$aColumnIndex]->setDefaultValue($someColumnDefault);
-		else {
-	function removeColumnWithName($aColumnName){
-		$index = $this->getColumnIndex($aColumnName);
-		$this->removeColumnAtIndex($index);
-	function removeKeyWithName($aKeyName){
-		$index = $this->getKeyIndex($aKeyName);
-		$this->removeKeyAtIndex($index);
-	function removeKeyAtIndex ($aKeyIndex) {
-		if ($aKeyIndex < $this->key_cnt && $aKeyIndex >= 0) {
-			$this->key[$aKeyIndex]->destroyKey();
-			//if key is not only key and not last key
-			if ($this->key_cnt > 1 && $aKeyIndex != $this->key_cnt-1) {
-				//fill gap in key array with last entry
-				$this->key[$aKeyIndex] = $this->key[$this->key_cnt-1];
-				$this->key[$this->key_cnt-1] = null;
-			$this->key_cnt--;
-		else {
-			echo "Key '" . $aKeyIndex . "' not in database!<br>";
-	function removeConstraintWithName($aConstraintName){
-		$index = $this->getConstraintIndex($aConstraintName);
-		$this->removeConstraintAtIndex($index);
-	function removeConstraintAtIndex ($aConstraintIndex) {
-		if ($aConstraintIndex < $this->constraint_cnt && $aConstraintIndex >= 0) {
-			$this->constraint[$aConstraintIndex]->destroyConstraint();
-			//if constraint is not only constraint and not last constraint
-			if ($this->constraint_cnt > 1 && $aConstraintIndex != $this->constraint_cnt-1) {
-				//fill gap in constraint array with last entry
-				$this->constraint[$aConstraintIndex] = $this->constraint[$this->constraint_cnt-1];
-				$this->constraint[$this->constraint_cnt-1] = null;
-			$this->constraint_cnt--;
-		else {
-			echo "Constraint '" . $aConstraintIndex . "' not in database!<br>";
-	function removeColumnAtIndex ($aColumnIndex) {
-		if ($aColumnIndex < $this->column_cnt && $aColumnIndex >= 0) {
-			$this->column[$aColumnIndex]->destroyColumn();
-			//if column is not only column and not last column
-			if ($this->column_cnt > 1 && $aColumnIndex != $this->column_cnt-1) {
-				//fill gap in column array with last entry
-				$this->column[$aColumnIndex] = $this->column[$this->column_cnt-1];
-				$this->column[$this->column_cnt-1] = null;
-			$this->column_cnt--;
-		else {
-			echo "Column '" . $aColumnIndex . "' not in database!<br>";
\ No newline at end of file
Deleted: trunk/mapbender/http/classes/class_database_table_column.php
--- trunk/mapbender/http/classes/class_database_table_column.php	2007-07-24 13:43:40 UTC (rev 1530)
+++ trunk/mapbender/http/classes/class_database_table_column.php	2007-07-25 07:53:31 UTC (rev 1531)
@@ -1,72 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_database_table_column.php
-class database_table_column{
-	var $name;
-	var $type;
-	var $defaultValue;
-	var $attributes;
-	function database_table_column($aName) {
-	function getName() {
-	function getDefaultValue() {
-		return $this->defaultValue;
-	function getAttributes() {
-		return $this->attributes;
-		$sql = "";
-		$sql .= " " . $this->getName() . " " . $this->getType() . " " . $this->getAttributes();
-		$sql .= "\n\n";
-		return $sql;
-	function setType ($aType) {
-	function setAttributes ($someAttributes) {
-		$this->attributes = $someAttributes;
-	function setDefaultValue ($someAttributes) {
-		$this->defaultValue = $someAttributes;
-	function destroyColumn () {
Deleted: trunk/mapbender/http/classes/class_database_table_constraint.php
--- trunk/mapbender/http/classes/class_database_table_constraint.php	2007-07-24 13:43:40 UTC (rev 1530)
+++ trunk/mapbender/http/classes/class_database_table_constraint.php	2007-07-25 07:53:31 UTC (rev 1531)
@@ -1,103 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_database_table_constraint.php
-// TODO
-// this version implements foreign key constraints only!
-class database_table_constraint{
-	var $conSymbol;
-	var $conColumn;
-	var $conTableName;
-	var $conTableColumnName;
-	var $conOnDelete;
-	var $conOnUpdate;
-	function database_table_constraint($conSymbol, $conColumn, $conTableName, $conTableColumnName, $conOnDelete, $conOnUpdate) {
-		#$this->conSymbol = $conSymbol;
-		$this->conSymbol = "";
-		$this->conColumn = trim($conColumn);
-		$this->conTableName = trim($conTableName);
-		$this->conTableColumnName = trim($conTableColumnName);
-		$this->conOnDelete = trim($conOnDelete);
-		$this->conOnUpdate = trim($conOnUpdate);
-	function getConstraint() {
-		return array(conSymbol => $this->conSymbol, conColumn => $this->conColumn, conTableName => $this->conTableName, conTableColumnName => $this->conTableColumnName, conOnDelete => $this->conOnDelete, conOnUpdate => $this->conOnUpdate);
-		return $this->conSymbol;
-	function getColumn() {
-		return $this->conColumn;
-	function getTableName() {
-		return $this->conTableName;
-	function getTableColumnName() {
-		return $this->conTableColumnName;
-	function getOnDelete() {
-		return $this->conOnDelete;
-	function getOnUpdate() {
-		return $this->conOnUpdate;
-		$sql = "";
-		$sql .= " CONSTRAINT";
-		if ($this->getName()) {
-			$sql .= " " . $this->getName();
-		$sql .= " FOREIGN KEY";
-		$sql .= " (" . $this->getColumn() . ")";
-		$sql .= " REFERENCES";
-		$sql .= " " . $this->getTableName() . " (" . $this->getTableColumnName() . ")";
-		if ($this->getOnDelete()) {
-			$sql .= " ON DELETE " . $this->getOnDelete();
-		if ($this->getOnUpdate()) {
-			$sql .= " ON UPDATE " . $this->getOnUpdate();
-		$sql .= "\n\n";
-		return $sql;
-	function destroyConstraint () {
Deleted: trunk/mapbender/http/classes/class_database_table_key.php
--- trunk/mapbender/http/classes/class_database_table_key.php	2007-07-24 13:43:40 UTC (rev 1530)
+++ trunk/mapbender/http/classes/class_database_table_key.php	2007-07-25 07:53:31 UTC (rev 1531)
@@ -1,69 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_database_table_key.php
-class database_table_key{
-	var $keyName;
-	var $columnName;
-	var $isPrimary = false;
-	function database_table_key($aKeyName, $aColumnName, $isPrimary) {
-		$this->keyName = $aKeyName;
-		$this->columnName = $aColumnName;
-		$this->isPrimary = $isPrimary;
-	function getKey() {
-		return $this->keyName . "," . $this->columnName . "," .  $this->isPrimary;
-	function isPrimary() {
-		return $this->isPrimary;
-	function getColumnName() {
-		return $this->columnName;
-	function getKeyName() {
-		return $this->keyName;
-		$sql = "";
-		if ($this->isPrimary()) {
-			$sql .= " PRIMARY";
-		$sql .= " KEY";
-		if ($this->getKeyName()) {
-			$sql .= " " . $this->getKeyName();
-		$sql .= " (" . $this->getColumnName() . ")";
-		$sql .= "\n\n";
-		return $sql;
-	function destroyKey () {
More information about the Mapbender_commits mailing list
