[Mapbender-commits] r1290 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 3 05:53:23 EDT 2007
Author: astrid_emde
Date: 2007-05-03 05:53:23 -0400 (Thu, 03 May 2007)
New Revision: 1290
   trunk/mapbender/http/javascripts/mod_setTimeout.php
new elements vars for this modul
Modified: trunk/mapbender/http/javascripts/mod_setTimeout.php
--- trunk/mapbender/http/javascripts/mod_setTimeout.php	2007-05-02 14:06:07 UTC (rev 1289)
+++ trunk/mapbender/http/javascripts/mod_setTimeout.php	2007-05-03 09:53:23 UTC (rev 1290)
@@ -1,67 +1,95 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_setTimeout.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-# requires a session-variable 'ttl'
-session_start();
-echo "var mod_timeout_ttl = '".(intval($_SESSION["ttl"])/60)."';";
-mod_timeout_cnt = false;
-* alert:    a confirm - window to reload the application when timeout "ttl" is reached
-* logout:  request mod_logout after timeout "ttl"
-mod_timeout_action = "alert";
-mb_registerSubFunctions("mod_setTimeout_set()");            // maprequest
-mb_registerInitFunctions("mod_setTimeout_interval()");
-function mod_setTimeout_interval(){
-	var aktiv = window.setInterval("mod_setTimeout_check()",60000);
-	mod_setTimeout_set();
-	mod_setTimeout_check();
-function mod_setTimeout_set(){
-	mod_timeout_cnt = parseInt(mod_timeout_ttl);
-function mod_setTimeout_check(){
-	var str = "<span style='font-family: Arial, Helvetica, sans-serif;font-size:10px;'>";
-	str += "Automatische Abmeldung: ";
-	if(mod_timeout_cnt >= 0){
-		str += mod_timeout_cnt;
-	else { str += "0";  }
-	str += " min";
-	str += "</span>";
-	writeTag("", "timeout",  str );
-	if(mod_timeout_cnt == 0 && mod_timeout_action == 'alert'){
-		var go = confirm("Bitte beachten Sie, dass Ihre Session abgelaufen sein kann...\n Mit OK laden Sie die Anwendung neu!");
-		if(go == true){
-			document.location.href = "../frames/login.php";
-	if(mod_timeout_cnt == 0 && mod_timeout_action == 'logout'){ document.location.href = "../php/mod_logout.php";}
-	mod_timeout_cnt--;
\ No newline at end of file
+<?php
+# $Id:$
+# http://www.mapbender.org/index.php/mod_setTimeout.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+session_start();
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+$e_id_css = 'timeout';
+$gui_id = $_REQUEST["gui_id"];
+include '../include/dyn_js.php';
+try{
+	if (timeout_text){}
+catch(e){
+	timeout_text = "Your session isn't valid anymore ...\n Press ok to restart the application!";
+	//timeout_text = "Bitte beachten Sie, dass Ihre Session abgelaufen sein kann...\n Mit OK laden Sie die Anwendung neu!";
+try{
+	if (timeout_interval){}
+catch(e){
+	timeout_interval = '15';
+* alert:    a confirm - window to reload the application when timeout is reached
+* logout:  request mod_logout after timeout
+try{
+	if (timeout_action){}
+catch(e){
+	timeout_action = 'alert';
+/*version 2.0.0*/
+mod_timeout_cnt = false;
+mb_registerSubFunctions("mod_setTimeout_set()");            // maprequest
+mb_registerInitFunctions("mod_setTimeout_interval()");
+function mod_setTimeout_interval(){
+   var aktiv = window.setInterval("mod_setTimeout_check()",60000);
+   mod_setTimeout_set();
+   mod_setTimeout_check();
+function mod_setTimeout_set(){
+   mod_timeout_cnt = parseInt(timeout_interval);
+function mod_setTimeout_check(){
+   var str = "<span style='font-family: Arial, Helvetica, sans-serif;font-size:10px;'>";
+   str += "Logout in ";
+   if(mod_timeout_cnt >= 0){
+      str += mod_timeout_cnt;
+   else { str += "0";  }
+   str += " min";
+   str += "</span>";
+   writeTag("", "timeout",  str );
+   if(mod_timeout_cnt == 0 && timeout_action == 'alert'){
+      var go = confirm(timeout_text);
+      if(go == true){
+         document.location.href = "./login.php";
+   if(mod_timeout_cnt == 0 && timeout_action == 'logout'){ document.location.href = "../php/mod_logout.php";}
+   mod_timeout_cnt--;
More information about the Mapbender_commits mailing list
