[Mapbender-commits] r1291 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 3 06:23:25 EDT 2007
Author: astrid_emde
Date: 2007-05-03 06:23:25 -0400 (Thu, 03 May 2007)
New Revision: 1291
   trunk/mapbender/http/javascripts/mod_setTimeout.php
Modified: trunk/mapbender/http/javascripts/mod_setTimeout.php
--- trunk/mapbender/http/javascripts/mod_setTimeout.php	2007-05-03 09:53:23 UTC (rev 1290)
+++ trunk/mapbender/http/javascripts/mod_setTimeout.php	2007-05-03 10:23:25 UTC (rev 1291)
@@ -1,5 +1,6 @@
 <?php
-# $Id:$
+# $Id$
+# maintained by http://www.mapbender.org/index.php/User:Astrid Emde
 # http://www.mapbender.org/index.php/mod_setTimeout.php
 # Copyright (C) 2002 CCGIS
@@ -16,6 +17,7 @@
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 session_start();
 require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 $e_id_css = 'timeout';
@@ -25,18 +27,18 @@
 try{
-	if (timeout_text){}
+	if (mod_timeout_text){}
 catch(e){
-	timeout_text = "Your session isn't valid anymore ...\n Press ok to restart the application!";
-	//timeout_text = "Bitte beachten Sie, dass Ihre Session abgelaufen sein kann...\n Mit OK laden Sie die Anwendung neu!";
+	mod_timeout_text = "Your session may not be valid anymore!";
+	//mod_timeout_text = "Bitte beachten Sie, dass Ihre Session abgelaufen sein kann!";
 try{
-	if (timeout_interval){}
+	if (mod_timeout_ttl){}
 catch(e){
-	timeout_interval = '15';
+	mod_timeout_ttl = '15';
@@ -44,10 +46,10 @@
 * logout:  request mod_logout after timeout
 try{
-	if (timeout_action){}
+	if (mod_timeout_action){}
 catch(e){
-	timeout_action = 'alert';
+	mod_timeout_action = 'alert';
@@ -65,7 +67,7 @@
 function mod_setTimeout_set(){
-   mod_timeout_cnt = parseInt(timeout_interval);
+   mod_timeout_cnt = parseInt(mod_timeout_ttl);
    mod_setTimeout_check();
@@ -83,13 +85,13 @@
    str += "</span>";
    writeTag("", "timeout",  str );
-   if(mod_timeout_cnt == 0 && timeout_action == 'alert'){
-      var go = confirm(timeout_text);
+   if(mod_timeout_cnt == 0 && mod_timeout_action == 'alert'){
+      var go = confirm(mod_timeout_text);
       if(go == true){
-         document.location.href = "./login.php";
+        //  document.location.href = "./login.php";
-   if(mod_timeout_cnt == 0 && timeout_action == 'logout'){ document.location.href = "../php/mod_logout.php";}
+   if(mod_timeout_cnt == 0 && mod_timeout_action == 'logout'){ document.location.href = "../php/mod_logout.php";}
    mod_timeout_cnt--;
More information about the Mapbender_commits mailing list
