[Mapbender-commits] r1353 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 24 11:34:07 EDT 2007
Author: christoph
Date: 2007-05-24 11:34:07 -0400 (Thu, 24 May 2007)
New Revision: 1353
Removed:
   trunk/mapbender/http/php/mod_wfs_gazetteer_ajax.php
   trunk/mapbender/http/php/mod_wfs_gazetteer_conf_server.php
   trunk/mapbender/http/php/mod_wfs_gazetteer_search.php
   trunk/mapbender/http/php/mod_wfs_gazetteer.php
   trunk/mapbender/http/php/mod_wfs_gazetteer_server.php
new wfs gazetteer w/ ajax
Modified: trunk/mapbender/http/php/mod_wfs_gazetteer.php
--- trunk/mapbender/http/php/mod_wfs_gazetteer.php	2007-05-24 14:59:52 UTC (rev 1352)
+++ trunk/mapbender/http/php/mod_wfs_gazetteer.php	2007-05-24 15:34:07 UTC (rev 1353)
@@ -197,6 +197,7 @@
 	  echo "<style type='text/css'>";
 	  echo $g_style[$i];
+	  echo $g_res_style[$i];
 	  echo "</style>";
 	  /* wfs_conf_element */
Deleted: trunk/mapbender/http/php/mod_wfs_gazetteer_ajax.php
--- trunk/mapbender/http/php/mod_wfs_gazetteer_ajax.php	2007-05-24 14:59:52 UTC (rev 1352)
+++ trunk/mapbender/http/php/mod_wfs_gazetteer_ajax.php	2007-05-24 15:34:07 UTC (rev 1353)
@@ -1,392 +0,0 @@
-<?php
-# $Id$
-# maintained by http://www.mapbender.org/index.php/User:Verena Diewald
-# http://www.mapbender.org/index.php/WFS_gazetteer
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-session_start();
-$gui_id = $_SESSION["mb_user_gui"];
-$wfsConfIdString = $_REQUEST["wfs_conf"];
-$selectedConfId = $_REQUEST["selected_conf"];
-$target = $_REQUEST["target"];
-$resultFrame = $_REQUEST["resultFrame"];
-$e_id_css = $_REQUEST["e_id_css"];
-require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db($DB,$con);
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="Content-Type" content="text/html; charset='<?php echo CHARSET;?>'">
-<title>mod_wfs_gazetteer</title>
-<?php
-include '../include/dyn_css.php';
-function createWfsConfSelectBox($idArray, $labelArray, $selectedId) {
-	$wfsConfSelectBox .= "<select name='wfs_conf_sel' size='1' onChange='conf_selection()'>\n";
-	if (!isset($selectedId)) {$selectedId = 0;}
-	for($i = 0; $i < count($idArray); $i++){
-		$selected = "";
-		if ($idArray[$i] == $selectedId) {$selected = "selected";}
-		$wfsConfSelectBox .= "<option value='".$idArray[$i]."' " . $selected . ">" . $labelArray[$idArray[$i]] . "</option>\n";
-	$wfsConfSelectBox .= "</select>";
-	return $wfsConfSelectBox;
-if ($wfsConfIdString != "") {
-	$wfsConfIdArray = split(",", $wfsConfIdString);
-	$wfsConfCount = count($wfsConfIdArray);
-else {
-	if ($selectedConfId) {
-		$wfsConfIdArray = array($selectedConfId);
-		$wfsConfCount = 1;
-	else {
-		$wfsConfIdArray = array();
-		$wfsConfCount = 0;
-if ($wfsConfCount > 0) {
-	// WFS CONF
-	$sql = "SELECT * FROM wfs_conf ";
-	$sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
-	$sql .= "WHERE wfs_conf.wfs_conf_id IN (";
-	$v = array();
-	$t = array();
-	for ($i = 0; $i < $wfsConfCount; $i++) {
-		if ($i > 0) {$sql .= ", ";}
-		$sql .= "$" . ($i+1);
-		array_push($v, $wfsConfIdArray[$i]);
-		array_push($t, 'i');
-	$sql .= ")";
-	$res = db_prep_query($sql, $v, $t);
-	while ($row = db_fetch_array($res)) {
-		$id = $row["wfs_conf_id"];
-		$g_label[$id] = $row["g_label"];
-		$g_label_id[$id]  = $row["g_label_id"];
-		$g_style[$id]  = $row["g_style"];
-		$g_button[$id] = $row["g_button"];
-		$g_button_id[$id] = $row["g_button_id"];
-		$g_buffer[$id]  = $row["g_buffer"];
-		$g_res_style[$id]  = $row["g_res_style"];
-		$g_use_wzgraphics[$id] = $row["g_use_wzgraphics"];
-		$wfs_id[$id]  = $row["fkey_wfs_id"];
-		$featuretype_id[$id]  = $row["fkey_featuretype_id"];
-		$wfs_getfeature[$id] = $row["wfs_getfeature"];
-	// if more than one wfs is available, add a select box
- 	if ($wfsConfCount > 1) {
-		$wfsConfForm = "<form name='sel_wfs_conf_form' method='POST' action='mod_wfs_gazetteer.php'>\n";
-		$wfsConfForm .= createWfsConfSelectBox($wfsConfIdArray, $g_label, $selectedConfId);
-		$wfsConfForm .= "<input type='hidden' name='wfs_conf' value='".$wfsConfIdString."'>\n";
-		$wfsConfForm .= "<input type='hidden' name='selected_conf' value='".$selectedConfId."'>\n";
-		$wfsConfForm .= "<input type='hidden' name='target' value='".$target."'>\n";
-		$wfsConfForm .= "<input type='hidden' name='resultFrame' value='".$resultFrame."'>\n";
-	 	$wfsConfForm .= "</form>";
-	 	echo $wfsConfForm;
-	 	if (!isset($selectedConfId)) {
-	 		$selectedConfId = $wfsConfIdArray[0];
- 	// if only one wfs is available, use it
- 	else {
-	$sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
-	$v = array($wfs_id[$selectedConfId], $featuretype_id[$selectedConfId]);
-	$t = array('i', 'i');
-	if ($row = db_fetch_array($res)) {
-		$featuretype_name  = $row["featuretype_name"];
-		$featuretype_srs  = $row["featuretype_srs"];
-	else{
-		die("Please add the wfs_conf to the src-Parameter");
-	// Style
-	echo "<style type='text/css'>" . $g_style[$selectedConfId] . "</style>";
-	// WFS CONF ELEMENTS
-	$sql = "SELECT * FROM wfs_conf_element ";
-	$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-	$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-	$sql .= "AND wfs_conf_element.f_search = 1 ORDER BY wfs_conf_element.f_pos";
-	$v = array($selectedConfId);
-	$t = array('i');
-	echo "<script type='text/javascript'>";
-	echo "var el = new Array();";
-	$cnt = 0;
-	while($row = db_fetch_array($res)){
-		echo "el[".$cnt."] = [];";
-		echo "el[".$cnt."]['f_search'] = ".$row["f_search"].";";
-		echo "el[".$cnt."]['f_style_id'] = '".$row["f_style_id"]."';";
-		echo "el[".$cnt."]['f_toupper'] = '".$row["f_toupper"]."';";
-		echo "el[".$cnt."]['f_label'] = '".$row["f_label"]."';";
-		echo "el[".$cnt."]['f_label_id'] = '".$row["f_label_id"]."';";
-		echo "el[".$cnt."]['element_name'] = '".$row["element_name"]."';";
-		echo "el[".$cnt."]['element_type'] = '".$row["element_type"]."';";
-		$cnt++;
-	if($cnt == 0){
-	echo "var g_label = '".$g_label[$selectedConfId]."';";
-	echo "var g_label_id = '".$g_label_id[$selectedConfId]."';";
-	echo "var g_button = '".$g_button[$selectedConfId]."';";
-	echo "var g_button_id = '".$g_button_id[$selectedConfId]."';";
-	echo "var g_buffer = ".$g_buffer[$selectedConfId].";";
-	echo "var g_res_style = '".urlencode($g_res_style[$selectedConfId])."';";
-	echo "var g_use_wzgraphics = ".$g_use_wzgraphics[$selectedConfId].";";
-	echo "var featuretype_name= '".$featuretype_name."';";
-	echo "var featuretype_srs = '".$featuretype_srs."';";
-	echo "var wfs_getfeature = '".$wfs_getfeature[$selectedConfId]."';";
-	echo "var wfs_conf_id = '".$selectedConfId."';";
-	echo "var targets = '".$target."';";
-	echo "var targetArray = targets.split(',');";
-	echo "var resultFrame = '".$resultFrame."';";
-	echo "var selectedConfId = ".$selectedConfId.";";
-	echo "</script>";
-else {
-	die("problem.");
-<script type="text/javascript">
-//var res = true;
-var wfs_conf_color = "255,0,0";
- *  Sets the wfs conf ID that was selected in the select box as default and reloads.
-function conf_selection(){
-	document.sel_wfs_conf_form.selected_conf.value = document.sel_wfs_conf_form.wfs_conf_sel.value;
-	document.sel_wfs_conf_form.submit();
- *  displays the form where the search criteria may be entered
-function init_mod_wfs_gazetteer(){
-	var s = "";
-	s += "<form onsubmit='return validate()'>";
-	s += "<div class='"+g_label_id+"'>"+g_label+"</div>";
-	for(var i=0; i<el.length; i++){
-		s += "<span class='"+el[i]["f_label_id"]+"'>"+el[i]["f_label"]+"</span>";
-		s += "<input type='text' class='"+el[i]["f_style_id"]+"' id='"+el[i]["element_name"]+"'><br>";
-	s += "<input type='submit' class='"+g_button_id+"' value='"+g_button+"' >";
-	s += "</form>";
-	document.getElementById("gaz").innerHTML = s;
-	return true;
-function validate(){
-	var filterParameterCount = getNumberOfFilterParameters();
-	if(filterParameterCount == 0){
-		return false;
-	else{
-		var andConditions = "";
-		for (var i = 0; i < el.length; i++) {
-			if (el[i]['f_search'] == 1 && document.getElementById(el[i]['element_name']).value != '') {
-				var a = new Array();
-				a = document.getElementById(el[i]['element_name']).value.split(",");
-				var orConditions = "";
-				for (var j=0; j < a.length; j++) {
-					orConditions += "<ogc:PropertyIsLike wildCard='*' singleChar='.' escape='!'>";
-					orConditions += "<ogc:PropertyName>" + el[i]['element_name'] + "</ogc:PropertyName>";
-					orConditions += "<ogc:Literal>*";
-					if(el[i]['f_toupper'] == 1){
-						orConditions += a[j].toUpperCase();
-					else{
-						orConditions += a[j];
-					orConditions += "*</ogc:Literal>";
-					orConditions += "</ogc:PropertyIsLike>";
-				if(a.length > 1){
-					andConditions += "<Or>" + orConditions + "</Or>";
-				else {
-					andConditions += orConditions;
-		var u = wfs_getfeature + parent.mb_getConjunctionCharacter(wfs_getfeature);
-		u += "REQUEST=getFeature&Typename="+featuretype_name+"&Version=1.0.0&service=WFS";
-		u += "&filter=";
-		if (filterParameterCount > 1) {
-			andConditions = "<And>" + andConditions + "</And>";
-		var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>"+andConditions+"</ogc:Filter>";
-		document.getElementById("res").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Searching...</td></tr></table>";
-		var parameters = {"wfs_conf_id":wfs_conf_id, "frame":this.name, "url":u, "filter":filter, "backlink":""};
-		parent.mb_ajax_get("../php/mod_wfs_gazetteer_search.php", parameters, function (jsCode, status) {
-			eval(jsCode);
-			for (var i=0; i < parent.wms.length; i++) {
-				for (var j=0; j < parent.wms[i].objLayer.length; j++) {
-					var currentLayer = parent.wms[i].objLayer[j];
-					var wms_id = parent.wms[i].wms_id;
-					if (currentLayer.gui_layer_wfs_featuretype == selectedConfId) {
-						var layer_name = currentLayer.layer_name;
-						parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'querylayer',1);
-						parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'visible',1);
-			var body = "";
-			if (typeof(geom) == 'object') {
-				resultGeom = geom; // set the global variable
-				for (var i=0; i < geom.count(); i++) {
-					body += "<div id='geom"+i+"'style='cursor:pointer;' ";
-					if ((i % 2) === 0) {
-						body += "class='even'";
-					else {
-						body += "class='uneven'";
-					body += " onmouseover=\"setResult('over', this.id)\" ";
-					body += " onmouseout=\"setResult('out', this.id)\" ";
-					body += " onclick=\"setResult('click', this.id)\">";
-					for (var j=0; j < geom.get(i).e.count(); j++) {
-						body += geom.get(i).e.getValue(j) + " ";
-					body += "</div>";
-			else {
-				body = "Kein Ergebnis.";
-			document.getElementById('res').innerHTML = body;
-	return false;
-function getNumberOfFilterParameters(){
-	var cnt = 0;
-	for (var i = 0; i < el.length; i++){
-		if( el[i]['f_search'] == 1){
-			if (document.getElementById(el[i]['element_name']).value != '') {
-				cnt++;
-	return cnt;
-* event -> {over || out || click}
-* geom -> commaseparated coordinates x1,y1,x2,y2 ...
-function setResult(event, id){
-	var index = parseInt(id.slice(4));
-	if (event == "over") {
-		if(g_use_wzgraphics == 1){
-			global_resultHighlight.add(resultGeom.get(index), cw_fillcolor);
-	else if (event == "out"){
-			global_resultHighlight.del(resultGeom.get(index), cw_fillcolor);
-	else if (event == "click"){
-		var bbox = resultGeom.get(index).getBBox();
-		var buffer = new parent.Point(1,1);
-		bbox[0] = bbox[0].minus(buffer);
-		bbox[1] = bbox[1].plus(buffer);
-		parent.mb_calculateExtent(targetArray[0], bbox[0].x, bbox[0].y, bbox[1].x, bbox[1].y);
-		parent.zoom(targetArray[0], 'true', 1.0);
-	return true;
-/* Opacity for hilighting */
-    parent.cw_opacity = 1.5;
-/* Color for polygon boundary */
-    var cw_bndcolor = "#cc33cc";
-/* Color for polygon fill */
-    var cw_fillcolor = "#cc33cc";
-var point_px = 10;
-var resultGeom = null;
-var global_resultHighlight;
-parent.mb_registerInitFunctions("window.frames['"+this.name+"'].initWfsGazetteerHighlight()");
-function initWfsGazetteerHighlight() {
-	global_resultHighlight = new parent.Highlight(targetArray, "wfs_gazetteer_highlight", {"position":"absolute", "top":"0px", "left":"0px", "z-index":100}, 2);
-</script>
-</head>
-<body leftmargin='0' topmargin='10'  bgcolor='#ffffff' onload='init_mod_wfs_gazetteer()'>
-<div id='gaz'></div>
-<div name='res' id='res' frameborder='0' style='width:180px;height:200px'></div>
-</body>
-</html>
\ No newline at end of file
Deleted: trunk/mapbender/http/php/mod_wfs_gazetteer_conf_server.php
--- trunk/mapbender/http/php/mod_wfs_gazetteer_conf_server.php	2007-05-24 14:59:52 UTC (rev 1352)
+++ trunk/mapbender/http/php/mod_wfs_gazetteer_conf_server.php	2007-05-24 15:34:07 UTC (rev 1353)
@@ -1,111 +0,0 @@
-<?php
-# $Id: mod_wfsrequest.php 1008 2007-01-16 11:26:56Z christoph $
-# http://www.mapbender.org/index.php/Administration
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/../extensions/JSON.php");
-$wfsConfIdString = $_GET["wfsConfIdString"];
-else {
-	echo "please specify wfs conf id.";
-	die();
-$sql = "SELECT * FROM wfs_conf ";
-$sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
-$sql .= "WHERE wfs_conf.wfs_conf_id IN (";
-$v = array();
-$t = array();
-for ($i = 0; $i < count($wfsConfIdArray); $i++) {
-$sql .= ")";
-$res = db_prep_query($sql, $v, $t);
-$obj = array();
-while ($row = db_fetch_array($res)) {
-	$sql_conf_element = "SELECT * FROM wfs_conf_element ";
-	$sql_conf_element .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-	$sql_conf_element .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-	$sql_conf_element .= "AND wfs_conf_element.f_search = 1 ORDER BY wfs_conf_element.f_pos";
-	$v_conf_element = array($id);
-	$t_conf_element = array('i');
-	$res_conf_element = db_prep_query($sql_conf_element, $v_conf_element, $t_conf_element);
-	$elementArray = array();
-	while ($row_conf_element = db_fetch_array($res_conf_element)) {
-		$currentElement = array("f_search" => $row_conf_element["f_search"],
-								"f_style_id" => $row_conf_element["f_style_id"],
-								"f_toupper" => $row_conf_element["f_toupper"],
-								"f_label" => $row_conf_element["f_label"],
-								"f_label_id" => $row_conf_element["f_label_id"],
-								"element_name" => $row_conf_element["element_name"],
-								"element_type" => $row_conf_element["element_type"]
-		array_push($elementArray, $currentElement);
-	$sql_feature_type = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
-	$v_feature_type = array($row["fkey_wfs_id"], $row["fkey_featuretype_id"]);
-	$t_feature_type = array("i", "i");
-	$res_feature_type = db_prep_query($sql_feature_type, $v_feature_type, $t_feature_type);
-	if($row_feature_type = db_fetch_array($res_feature_type)){
-		$featuretype_name  = $row_feature_type["featuretype_name"];
-		$featuretype_srs  = $row_feature_type["featuretype_srs"];
-	$currentRow = array("g_label" => $row["g_label"],
-                        "g_label_id" => $row["g_label_id"],
-						"g_style" => $row["g_style"],
-						"g_button" => $row["g_button"],
-						"g_button_id" => $row["g_button_id"],
-						"g_buffer" => $row["g_buffer"],
-						"g_res_style" => $row["g_res_style"],
-						"g_use_wzgraphics" => $row["g_use_wzgraphics"],
-						"wfs_id" => $row["fkey_wfs_id"],
-						"featuretype_id" => $row["fkey_featuretype_id"],
-						"featuretype_name" => $featuretype_name,
-						"featuretype_id" => $featuretype_srs,
-						"wfs_getfeature" => $row["wfs_getfeature"],
-						"element" => $elementArray
-	$obj[$id] = $currentRow;
-$json = new Services_JSON();
-$output = $json->encode($obj);
-echo $output;
Deleted: trunk/mapbender/http/php/mod_wfs_gazetteer_search.php
--- trunk/mapbender/http/php/mod_wfs_gazetteer_search.php	2007-05-24 14:59:52 UTC (rev 1352)
+++ trunk/mapbender/http/php/mod_wfs_gazetteer_search.php	2007-05-24 15:34:07 UTC (rev 1353)
@@ -1,82 +0,0 @@
-<?php
-include(dirname(__FILE__)."/../classes/class_gml2.php");
-$backlink = $_REQUEST["backlink"];
-$wfs_conf_id = $_REQUEST["wfs_conf_id"];
-$frame = $_REQUEST["frame"];
-$filter = $_REQUEST["filter"];
-$url = $_REQUEST["url"];
-/* wfs_conf */
-$sql = "SELECT * FROM wfs_conf JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
-$sql .= "WHERE wfs_conf.wfs_conf_id = $1";
-$v = array($wfs_conf_id);
-$t = array('i');
-$res = db_prep_query($sql,$v,$t);
-if ($row = db_fetch_array($res)) {
-	$g_res_style  = $row["g_res_style"];
-else {
-	die("wfs_conf data not available");
-/* wfs_conf_element */
-$sql = "SELECT * FROM wfs_conf_element ";
-$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-$sql .= "AND wfs_conf_element.f_show = 1 ORDER BY wfs_conf_element.f_respos;";
-$t = array('i');
-$col = array();
-	array_push($col, $row["element_name"]);
-if (count($col) == 0) {
-	die("wfs_conf_element data not available");
-$req = urldecode($url).urlencode(stripslashes($filter));
-$mygml = new gml2();
-$mygml->parsegml($req);
-// generates JavaScript code that will add a geometry array containing
-// all the result geometries and their attributes (wfs_conf_elements)
-$js = "";
-if ($mygml->getMemberCount() > 0) {
-	$js .= $mygml->exportGeometriesToJS(true);
-	for ($i = 0; $i < $mygml->getMemberCount(); $i++) {
-		for ($j = 0; $j < count($col); $j++){
-			$js .= "geom.get(".$i.").e.setElement('".$j."', '".$mygml->getValueBySeparatedKey($i, $col[$j]) . "');\n";
-echo $js;
Modified: trunk/mapbender/http/php/mod_wfs_gazetteer_server.php
--- trunk/mapbender/http/php/mod_wfs_gazetteer_server.php	2007-05-24 14:59:52 UTC (rev 1352)
+++ trunk/mapbender/http/php/mod_wfs_gazetteer_server.php	2007-05-24 15:34:07 UTC (rev 1353)
@@ -19,64 +19,157 @@
+require_once(dirname(__FILE__)."/../extensions/JSON.php");
-/* wfs_conf */
-$t = array('i');
+$command = $_REQUEST["command"];
+if ($command == "getWfsConf") {
+	$wfsConfIdString = $_GET["wfsConfIdString"];
+	if ($wfsConfIdString != "") {
+		$wfsConfIdArray = split(",", $wfsConfIdString);
+	else {
+		echo "please specify wfs conf id.";
+		die();
+	$sql = "SELECT * FROM wfs_conf ";
+	$sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+	$sql .= "WHERE wfs_conf.wfs_conf_id IN (";
+	$v = array();
+	$t = array();
+	for ($i = 0; $i < count($wfsConfIdArray); $i++) {
+		if ($i > 0) {$sql .= ", ";}
+		$sql .= "$" . ($i+1);
+		array_push($v, $wfsConfIdArray[$i]);
+		array_push($t, 'i');
+	$sql .= ")";
+	$res = db_prep_query($sql, $v, $t);
+	$obj = array();
+	while ($row = db_fetch_array($res)) {
+		$id = $row["wfs_conf_id"];
+		$sql_conf_element = "SELECT * FROM wfs_conf_element ";
+		$sql_conf_element .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+		$sql_conf_element .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+		$sql_conf_element .= "AND wfs_conf_element.f_search = 1 ORDER BY wfs_conf_element.f_pos";
+		$v_conf_element = array($id);
+		$t_conf_element = array('i');
+		$res_conf_element = db_prep_query($sql_conf_element, $v_conf_element, $t_conf_element);
+		$elementArray = array();
+		while ($row_conf_element = db_fetch_array($res_conf_element)) {
+			$currentElement = array("f_search" => $row_conf_element["f_search"],
+									"f_style_id" => $row_conf_element["f_style_id"],
+									"f_toupper" => $row_conf_element["f_toupper"],
+									"f_label" => $row_conf_element["f_label"],
+									"f_label_id" => $row_conf_element["f_label_id"],
+									"element_name" => $row_conf_element["element_name"],
+									"element_type" => $row_conf_element["element_type"]
+			array_push($elementArray, $currentElement);
+		$sql_feature_type = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
+		$v_feature_type = array($row["fkey_wfs_id"], $row["fkey_featuretype_id"]);
+		$t_feature_type = array("i", "i");
+		$res_feature_type = db_prep_query($sql_feature_type, $v_feature_type, $t_feature_type);
+		if($row_feature_type = db_fetch_array($res_feature_type)){
+			$featuretype_name  = $row_feature_type["featuretype_name"];
+			$featuretype_srs  = $row_feature_type["featuretype_srs"];
+		$currentRow = array("g_label" => $row["g_label"],
+	                        "g_label_id" => $row["g_label_id"],
+							"g_style" => $row["g_style"],
+							"g_button" => $row["g_button"],
+							"g_button_id" => $row["g_button_id"],
+							"g_buffer" => $row["g_buffer"],
+							"g_res_style" => $row["g_res_style"],
+							"g_use_wzgraphics" => $row["g_use_wzgraphics"],
+							"wfs_id" => $row["fkey_wfs_id"],
+							"featuretype_id" => $row["fkey_featuretype_id"],
+							"featuretype_name" => $featuretype_name,
+							"featuretype_id" => $featuretype_srs,
+							"wfs_getfeature" => $row["wfs_getfeature"],
+							"element" => $elementArray
+		$obj[$id] = $currentRow;
+	$json = new Services_JSON();
+	$output = $json->encode($obj);
+	echo $output;
-else {
+else if ($command == "getSearchResults") {
+	$wfs_conf_id = $_REQUEST["wfs_conf_id"];
+	$backlink = $_REQUEST["backlink"];
+	$frame = $_REQUEST["frame"];
+	$filter = $_REQUEST["filter"];
+	$url = $_REQUEST["url"];
-$t = array('i');
-$col = array();
-$js = "";
+	/* wfs_conf */
+	$sql = "SELECT * FROM wfs_conf JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+	$sql .= "WHERE wfs_conf.wfs_conf_id = $1";
+	$v = array($wfs_conf_id);
+	$t = array('i');
+	$res = db_prep_query($sql,$v,$t);
+	if ($row = db_fetch_array($res)) {
+		$g_res_style  = $row["g_res_style"];
+	else {
+		die("wfs_conf " . $wfs_conf_id . "data not available");
+	/* wfs_conf_element */
+	$sql = "SELECT * FROM wfs_conf_element ";
+	$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+	$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+	$sql .= "AND wfs_conf_element.f_show = 1 ORDER BY wfs_conf_element.f_respos;";
+	$t = array('i');
+	$col = array();
+		array_push($col, $row["element_name"]);
+	if (count($col) == 0) {
+		die("wfs_conf_element data not available");
+	$req = urldecode($url).urlencode(stripslashes($filter));
+	$mygml = new gml2();
+	$mygml->parsegml($req);
+	// generates JavaScript code that will add a geometry array containing
+	// all the result geometries and their attributes (wfs_conf_elements)
+	$js = "";
+	if ($mygml->getMemberCount() > 0) {
+		$js .= $mygml->exportGeometriesToJS(true);
+		for ($i = 0; $i < $mygml->getMemberCount(); $i++) {
+			for ($j = 0; $j < count($col); $j++){
+				$js .= "geom.get(".$i.").e.setElement('".$j."', '".$mygml->getValueBySeparatedKey($i, $col[$j]) . "');\n";
+	echo $js;
-echo $js;
+else {
+	echo "please enter a valid command.";
More information about the Mapbender_commits mailing list
