[Mapbender-commits] r1354 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 24 11:36:48 EDT 2007
Author: christoph
Date: 2007-05-24 11:36:48 -0400 (Thu, 24 May 2007)
New Revision: 1354
Removed:
   trunk/mapbender/http/php/mod_wfs_gazetteer.php
deprecated
Deleted: trunk/mapbender/http/php/mod_wfs_gazetteer.php
--- trunk/mapbender/http/php/mod_wfs_gazetteer.php	2007-05-24 15:34:07 UTC (rev 1353)
+++ trunk/mapbender/http/php/mod_wfs_gazetteer.php	2007-05-24 15:36:48 UTC (rev 1354)
@@ -1,644 +0,0 @@
-<?php
-# $Id$
-# maintained by http://www.mapbender.org/index.php/User:Verena Diewald
-# http://www.mapbender.org/index.php/WFS_gazetteer
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-session_start();
-require_once("../../conf/mapbender.conf");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>mod_wfs_gazetteer</title>
-<?php
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db($DB,$con);
-$gui_id = $_SESSION["mb_user_gui"];
-include '../include/dyn_css.php';
-/* wfs_conf */
-$sql = "SELECT * FROM wfs_conf ";
-$sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
-$sql .= "WHERE wfs_conf.wfs_conf_id = $1";
-//get wfs_conf as array
-$v1 = array($_REQUEST["wfs_conf"]);
-//split array $v1 (comma-separated) to get all chosen wfs_confs
-$v2 = split(",", $v1[0]);
-//get number of chosen wfs_confs
-if(strlen($v2[0])==NULL){
-  $cnt_confs = NULL;
-else{
-  $cnt_confs = count($v2);
-$t = array('i');
-//do this if there is more than 1 wfs_conf
-if($cnt_confs>1){
-  for($i=0; $i < $cnt_confs; $i++){
-  	 $res = db_prep_query($sql,$v2[$i],$t);
-  	 if($row = db_fetch_array($res)){
-     	$g_label[$v2[$i]] = $row["g_label"];
-     	$g_label_id[$v2[$i]]  = $row["g_label_id"];
-		$g_style[$v2[$i]]  = $row["g_style"];
-		$g_button[$v2[$i]] = $row["g_button"];
-		$g_button_id[$v2[$i]] = $row["g_button_id"];
-		$g_buffer[$v2[$i]]  = $row["g_buffer"];
-		$g_res_style[$v2[$i]]  = $row["g_res_style"];
-		$g_use_wzgraphics[$v2[$i]] = $row["g_use_wzgraphics"];
-		$wfs_id[$v2[$i]]  = $row["fkey_wfs_id"];
-		$featuretype_id[$v2[$i]]  = $row["fkey_featuretype_id"];
-		$wfs_getfeature[$v2[$i]] = $row["wfs_getfeature"];
-  echo "<script type='text/javascript' language='javascript'>
-  function conf_selection(){
-    //alert(document.sel_wfs_conf_form.wfs_conf_sel.value);
-    document.sel_wfs_conf_form.selected_conf.value = document.sel_wfs_conf_form.wfs_conf_sel.value;
-    document.sel_wfs_conf_form.submit();
-  </script>";
-  //display select box for different wfs_confs
-  echo "<form name='sel_wfs_conf_form' method='POST' action='mod_wfs_gazetteer.php'>\n" .
-  	   "<select name='wfs_conf_sel' size='1' onChange='conf_selection()'>\n";
-  	if(empty($_REQUEST["selected_conf"])){
-  	  if($i==0){
-  	    echo "<option value='".$v2[$i]."' selected>".$g_label[$v2[$i]]."</option>\n";
-  	  else{
-  	    echo "<option value='".$v2[$i]."'>".$g_label[$v2[$i]]."</option>\n";
-  	else{
-  	  if($v2[$i]==$_REQUEST["selected_conf"]){
-  	    $selected = "selected";
-  	  else{
-  	    $selected= "";
-  	  echo "<option value='".$v2[$i]."' $selected>".$g_label[$v2[$i]]."</option>\n";
-  echo "</select>".
-  	   "<input type='hidden' name='wfs_conf' value='".$_REQUEST["wfs_conf"]."'>\n".
-  	   "<input type='hidden' name='selected_conf' value='".$_REQUEST["selected_conf"]."'>\n".
-  	   "<input type='hidden' name='target' value='".$_REQUEST["target"]."'>\n".
-  	   "<input type='hidden' name='resultFrame' value='".$_REQUEST["resultFrame"]."'>\n";
- echo  "</form>";
-  $sql = "SELECT * FROM wfs_featuretype ";
-  $sql .= "WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
-  //if first value of select box is active and there was not yet a selection of another value, take index 0 for the
-  //following steps
-  if(!isset($_REQUEST["selected_conf"])){
-  	  $v = array($wfs_id[$v2[0]],$featuretype_id[$v2[0]]);
-	  $t = array('i','i');
-	  $res = db_prep_query($sql,$v,$t);
-	    $featuretype_name  = $row["featuretype_name"];
-	    $featuretype_srs  = $row["featuretype_srs"];
-	  else{
-	   die("Please add the wfs_conf to the src-Parameter");
-	  echo "<style type='text/css'>";
-	  echo $g_style[$v2[0]];
-	  echo "</style>";
-	  /* wfs_conf_element */
-	  $sql = "SELECT * FROM wfs_conf_element ";
-	  $sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-	  $sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-	  $sql .= "AND wfs_conf_element.f_search = 1 ORDER BY wfs_conf_element.f_pos;";
-	  $v1 = array($_REQUEST["wfs_conf"]);
-	  $t = array('i');
-	  //split array $v1 (comma-separated) to get all chosen wfs_confs
-	  $v2 = split(",", $v1[0]);
-	  $res = db_prep_query($sql,$v2[0],$t);
-	  echo '<script type="text/javascript">';
-	  echo "var el = new Array();";
-	  $cnt = 0;
-	  while($row = db_fetch_array($res)){
-		echo "el[".$cnt."] = new Array();";
-		echo "el[".$cnt."]['f_search'] = ".$row["f_search"].";";
-		echo "el[".$cnt."]['f_style_id'] = '".$row["f_style_id"]."';";
-		echo "el[".$cnt."]['f_toupper'] = '".$row["f_toupper"]."';";
-		echo "el[".$cnt."]['f_label'] = '".$row["f_label"]."';";
-		echo "el[".$cnt."]['f_label_id'] = '".$row["f_label_id"]."';";
-		echo "el[".$cnt."]['element_name'] = '".$row["element_name"]."';";
-		echo "el[".$cnt."]['element_type'] = '".$row["element_type"]."';";
-		$cnt++;
-	  if($cnt == 0){
-	  echo "var g_label = '".$g_label[$v2[0]]."';";
-	  echo "var g_label_id = '".$g_label_id[$v2[0]]."';";
-	  echo "var g_button = '".$g_button[$v2[0]]."';";
-	  echo "var g_button_id = '".$g_button_id[$v2[0]]."';";
-	  echo "var g_buffer = ".$g_buffer[$v2[0]].";";
-	  echo "var g_res_style = '".urlencode($g_res_style[$v2[0]])."';";
-	  echo "var g_use_wzgraphics = ".$g_use_wzgraphics[$v2[0]].";";
-	  echo "var featuretype_name= '".$featuretype_name."';";
-	  echo "var featuretype_srs = '".$featuretype_srs."';";
-	  echo "var wfs_getfeature = '".$wfs_getfeature[$v2[0]]."';";
-	  echo "var wfs_conf_id = '".$v2[0]."';";
-	  echo "var targets = '".$_REQUEST["target"]."';";
-	  echo "var resultFrame = '".$_REQUEST["resultFrame"]."';";
-	  echo "</script>";
-  //if value of select box changed through new selection, do the following
-  else{
-  	  //set $i as selected_conf value
-   	  $i = $_REQUEST["selected_conf"];
-   	  $v = array($wfs_id[$i],$featuretype_id[$i]);
-	  else{
-	  echo $g_style[$i];
-	  echo $g_res_style[$i];
-	  echo "</style>";
-	  #$v1 = array($_REQUEST["wfs_conf"]);
-	  $t = array('i');
-	  #$v2 = split(",", $v1[0]);
-	  $res = db_prep_query($sql,$i,$t);
-	  $cnt = 0;
-		$cnt++;
-	  if($cnt == 0){
-	  echo "var g_label = '".$g_label[$i]."';";
-	  echo "var g_label_id = '".$g_label_id[$i]."';";
-	  echo "var g_button = '".$g_button[$i]."';";
-	  echo "var g_button_id = '".$g_button_id[$i]."';";
-	  echo "var g_buffer = ".$g_buffer[$i].";";
-	  echo "var g_res_style = '".urlencode($g_res_style[$i])."';";
-	  echo "var g_use_wzgraphics = ".$g_use_wzgraphics[$i].";";
-	  echo "var wfs_getfeature = '".$wfs_getfeature[$i]."';";
-	  echo "var wfs_conf_id = '".$i."';";
-	  echo "</script>";
-//do this if there is 1 wfs_conf
-elseif($cnt_confs>0 && $cnt_confs==1){
-   $res = db_prep_query($sql,$v1,$t);
-		$g_label  = $row["g_label"];
-		$g_label_id  = $row["g_label_id"];
-		$g_style  = $row["g_style"];
-		$g_button = $row["g_button"];
-		$g_button_id = $row["g_button_id"];
-		$g_buffer  = $row["g_buffer"];
-		$g_res_style  = $row["g_res_style"];
-		$g_use_wzgraphics = $row["g_use_wzgraphics"];
-		$wfs_id  = $row["fkey_wfs_id"];
-		$featuretype_id  = $row["fkey_featuretype_id"];
-		$wfs_getfeature = $row["wfs_getfeature"];
-   //get wfs_id & featuretype_id as array
-   $v = array($wfs_id,$featuretype_id);
-   else{
-   echo $g_style;
-   echo "</style>";
-   $v = array($_REQUEST["wfs_conf"]);
-   $t = array('i');
-   $cnt = 0;
-	 $cnt++;
-   if($cnt == 0){
-   echo "var g_label = '".$g_label."';";
-   echo "var g_label_id = '".$g_label_id."';";
-   echo "var g_button = '".$g_button."';";
-   echo "var g_button_id = '".$g_button_id."';";
-   echo "var g_buffer = ".$g_buffer.";";
-   echo "var g_res_style = '".urlencode($g_res_style)."';";
-   echo "var g_use_wzgraphics = ".$g_use_wzgraphics.";";
-   echo "var wfs_getfeature = '".$wfs_getfeature."';";
-   echo "var wfs_conf_id = '".$_REQUEST["wfs_conf"]."';";
-   echo "</script>";
-//do this if wfs_conf is missing
-else{
-	die("Please add the wfs_conf to the src-Parameter!");
-<script type="text/javascript">
-//var res = true;
-var wfs_conf_color = "255,0,0";
-var cnt = 0;
-function checkTag(){
-	var target = targets.split(",");
-	canvas = new Array();
-	canvasHasDrawing = new Array();
-	for(var i=0; i<target.length; i++){
-		var isTag = (parent.frames[target[i]].document.getElementById('mod_gaz_draw'))?1:0;
-		if(isTag == 0){
-			var draw = parent.frames[target[i]].document.createElement("div");
-			var tmp = parent.frames[target[i]].document.getElementsByTagName("body")[0].appendChild(draw);
-			tmp.setAttribute("id","mod_gaz_draw");
-			tmp.setAttribute("style","position:absolute;top:0px;left:0px;width:0px;height:0px");
-		canvas[target[i]] = new parent.jsGraphics('mod_gaz_draw', parent.window.frames[target[i]]);
-		canvas[target[i]].setStroke(3);
-		canvasHasDrawing[target[i]] = false;
-	return true;
-function check(){
-	var cnt = 0;
-	for(var i=0; i<el.length; i++){
-		if(el[i]['f_search'] == 1){
-			if(document.getElementById(el[i]['element_name']).value != ''){
-				cnt++;
-	return cnt;
-function validate(){
-	var cnt = check();
-	if(cnt == 0){
-		return false;
-	else{
-		document.sendForm.wfs_conf_id.value = wfs_conf_id;
-		document.sendForm.frame.value = this.name;
-		/* url */
-		var u = wfs_getfeature;
-		if(wfs_getfeature.indexOf("?") > -1){u += "&";}
-		if(wfs_getfeature.indexOf("?") == -1){u += "?";}
-		u += "REQUEST=getFeature&Typename="+featuretype_name+"&Version=1.0.0&service=WFS";
-		u += "&filter=";
-		document.sendForm.url.value = u;
-		/* filter */
-		var f = '<ogc:Filter xmlns:ogc="http://ogc.org" xmlns:gml="http://www.opengis.net/gml">';
-		if(cnt > 1){
-			f += "<And>";
-			if(el[i]['f_search'] == 1 && document.getElementById(el[i]['element_name']).value != ''){
-				var a = new Array();
-				a = document.getElementById(el[i]['element_name']).value.split(",");
-				if(a.length > 1){
-					f += "<Or>";
-				for(var j=0; j<a.length; j++){
-					f += "<ogc:PropertyIsLike wildCard='*' singleChar='.' escape='!'>";
-//equal				f += "<ogc:PropertyIsEqualTo>";
-					f += '<ogc:PropertyName>';
-					f += el[i]['element_name'];
-					f += '</ogc:PropertyName>';
-					f += '<ogc:Literal>';
-					if(el[i]['f_toupper'] == 1){
-						f += a[j].toUpperCase();
-					else{
-						f += a[j];
-					f += "*";
-					f += '</ogc:Literal>';
-					f += '</ogc:PropertyIsLike>';
-//equal				f += '</ogc:PropertyIsEqualTo>';
-				if(a.length > 1){
-					f += "</Or>";
-		if(cnt > 1){
-			f += "</And>";
-		f += '</ogc:Filter>';
-		document.sendForm.filter.value = f;
-		document.sendForm.backlink.value = 'parent';
-		document.sendForm.submit();
-//		prompt("",b);
-		return false;
-function init_mod_wfs_gazetteer(){
-	var s = "";
-	s += "<form onsubmit='return validate()'>";
-	s += "<div class='"+g_label_id+"'>"+g_label+"</div>";
-		s += "<span class='"+el[i]["f_label_id"]+"'>"+el[i]["f_label"]+"</span>";
-		s += "<input type='text' class='"+el[i]["f_style_id"]+"' id='"+el[i]["element_name"]+"'><br>";
-	s += "<input type='submit' class='"+g_button_id+"' value='"+g_button+"' >";
-	s += "</form>";
-	document.getElementById("gaz").innerHTML = s;
-	return true;
-* event -> {over || out || click}
-* geom -> commaseparated coordinates x1,y1,x2,y2 ...
-function setResult(geomtype,event,geom){
-//  alert(geomtype + " - " + event + " - " + geom);
-	var geomtype = geomtype.toLowerCase();
-	var x = new Array();
-	var y = new Array();
-	var mygeom = new Array();
-	mygeom = geom.split(":");
-	if(event != 'out'){
-		var minx;
-		var miny;
-		var maxx;
-		var maxy;
-		for(var i=0; i<mygeom.length; i++){
-			x[i] = new Array();
-			y[i] = new Array();
-			var tmp = new Array();
-			tmp = mygeom[i].split(",");
-			var k = 0;
-			for(var j=0; j<(tmp.length-1); j=j+2){
-				x[i][k] = tmp[j];
-				y[i][k] = tmp[j+1];
-				//bounded by:
-				if(i==0 && j==0){
-					minx = tmp[j];
-					miny = tmp[j+1];
-					maxx = tmp[j];
-					maxy = tmp[j+1];
-				else{
-					if(tmp[j]<minx){ minx = tmp[j];}
-					if(tmp[j+1]<miny){ miny = tmp[j+1]; }
-					if(tmp[j]>maxx){ maxx = tmp[j]; }
-					if(tmp[j+1]>maxy){ maxy = tmp[j+1]; }
-				k++;
-	//events
-	if(event == "over"){
-		if(g_use_wzgraphics == 1){
-			for(var i=0; i<target.length;i++){
-				for(var j=0; j<x.length; j++){
-					var ev = setFocus(target[i],geomtype,x[j],y[j]);
-		else{
-			if(geomtype == 'point'){
-				parent.mb_showHighlight(target[0],x[0][0],y[0][0]);
-				parent.mb_showHighlight(target[1],x[0][0],y[0][0]);
-			else{
-				parent.mb_markResult(target[0],mygeom,wfs_conf_color);
-	else if (event == "out"){
-				clearFocus(target[i]);
-		else{
-			hideResult();
-	else if (event == "click"){
-		minx -=g_buffer;
-		miny -= g_buffer;
-		maxx = parseFloat(maxx) +  parseFloat(g_buffer);
-		maxy = parseFloat(maxy) + parseFloat(g_buffer);
-		parent.mb_calculateExtent(target[0],minx,miny,maxx,maxy);
-		parent.zoom(target[0], 'true', 1.0);
-		else{
-			hideResult();
-	return true;
-function hideResult(geom_type){
-	if(geom_type == 'point'){
-		parent.mb_hideHighlight(target[0]);
-		parent.mb_hideHighlight(target[1]);
-	else{
-	parent.mb_disableResult(target[0]);
-function Numsort(a,b)
-{ return a-b; }
-/* Opacity for hilighting */
-    parent.cw_opacity = 1.5;
-/* Color for polygon boundary */
-    var cw_bndcolor = "#cc33cc";
-/* Color for polygon fill */
-    var cw_fillcolor = "#cc33cc";
-    var point_px = 10;
-function setFocus(frame,geomtype,coordsx,coordsy) {
-	var pxx = new Array();
-	var pxy = new Array();
-	var c = checkTag();
-	for(var i=0; i<coordsx.length; i++){
-		var pos = parent.makeRealWorld2mapPos(frame,coordsx[i],coordsy[i]);
-		pxx[i] = pos[0];
-		pxy[i] = pos[1];
-		//check min/max
-		if(i == 0){
-			var minx = pos[0];
-			var miny = pos[1];
-                        var maxx = pos[0];
-                        var maxy = pos[1];
-                else{
-                        if(pos[0]<minx){ minx = pos[0]; }
-                        if(pos[0]>maxx){ maxx = pos[0]; }
-                        if(pos[1]<miny){ miny = pos[1]; }
-                        if(pos[1]>maxy){ maxy = pos[1]; }
-        if((maxx-minx)<8 && (maxy-miny)<8){
-                geomtype = 'point';
-                pxx.length = 0;
-                pxx[0] = minx;
-                pxy.length = 0;
-                pxy[0] = miny;
-        if (geomtype == 'linestring') {
-                canvas[frame].setColor(cw_bndcolor);
-                canvas[frame].drawPolyline(pxx,pxy);
-                canvas[frame].paint();
-        if (geomtype == 'polygon') {
-//                canvas[frame].setColor(cw_fillcolor);
-//                canvas[frame].fillPolygon(pxx,pxy);
-//                canvas[frame].paint();
-                canvas[frame].drawPolygon(pxx,pxy);
-        if (geomtype == 'point') {
-//                canvas.setColor(cw_fillcolor);
-//                canvas.fillEllipse((parseInt(x)-point_px/2),(parseInt(y)-point_px/2),point_px,point_px);
-//                canvas.paint();
-                canvas[frame].drawEllipse((pxx[0]-point_px/2),(pxy[0]-point_px/2),point_px,point_px);
-        canvasHasDrawing[frame] = true;
-        return true;
-function clearFocus(frame) {
-        parent.frames[frame].document.getElementById('mod_gaz_draw').innerHTML = "";
-        canvasHasDrawing[frame] = false;
-        return true;
-</script>
-</head>
-<body leftmargin='0' topmargin='10'  bgcolor='#ffffff' onload='init_mod_wfs_gazetteer()'>
-<div id='gaz'></div>
-<iframe name='res' id='res' src='' frameborder='0' style='width:180px;height:200px'></iframe>
-<form name='sendForm' action='mod_wfsrequest.php' target='res' method='POST'>
-<input type='hidden' name='wfs_conf_id'>
-<input type='hidden' name='frame'>
-<input type='hidden' name='url'>
-<input type='hidden' name='backlink'>
-<input type='hidden' name='filter'>
-</form>
-</body>
-</html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
