[Mapbender-commits] r1356 - trunk/mapbender/http/extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 24 11:42:08 EDT 2007
Author: christoph
Date: 2007-05-24 11:42:07 -0400 (Thu, 24 May 2007)
New Revision: 1356
Removed:
   trunk/mapbender/http/extensions/jquery_uncompressed.js
Deleted: trunk/mapbender/http/extensions/jquery_uncompressed.js
--- trunk/mapbender/http/extensions/jquery_uncompressed.js	2007-05-24 15:41:17 UTC (rev 1355)
+++ trunk/mapbender/http/extensions/jquery_uncompressed.js	2007-05-24 15:42:07 UTC (rev 1356)
@@ -1,2243 +0,0 @@
-/* prevent execution of jQuery if included more than once */
-if(typeof window.jQuery == "undefined") {
- * jQuery 1.1.2 - New Wave Javascript
- * Copyright (c) 2007 John Resig (jquery.com)
- * Dual licensed under the MIT (MIT-LICENSE.txt)
- * and GPL (GPL-LICENSE.txt) licenses.
- * $Date: 2007-02-28 12:03:00 -0500 (Wed, 28 Feb 2007) $
- * $Rev: 1465 $
-// Global undefined variable
-window.undefined = window.undefined;
-var jQuery = function(a,c) {
-	// If the context is global, return a new object
-	if ( window == this )
-		return new jQuery(a,c);
-	// Make sure that a selection was provided
-	a = a || document;
-	// HANDLE: $(function)
-	// Shortcut for document ready
-	if ( jQuery.isFunction(a) )
-		return new jQuery(document)[ jQuery.fn.ready ? "ready" : "load" ]( a );
-	// Handle HTML strings
-	if ( typeof a  == "string" ) {
-		// HANDLE: $(html) -> $(array)
-		var m = /^[^<]*(<(.|\s)+>)[^>]*$/.exec(a);
-		if ( m )
-			a = jQuery.clean( [ m[1] ] );
-		// HANDLE: $(expr)
-		else
-			return new jQuery( c ).find( a );
-	return this.setArray(
-		// HANDLE: $(array)
-		a.constructor == Array && a ||
-		// HANDLE: $(arraylike)
-		// Watch for when an array-like object is passed as the selector
-		(a.jquery || a.length && a != window && !a.nodeType && a[0] != undefined && a[0].nodeType) && jQuery.makeArray( a ) ||
-		// HANDLE: $(*)
-		[ a ] );
-// Map over the $ in case of overwrite
-if ( typeof $ != "undefined" )
-	jQuery._$ = $;
-// Map the jQuery namespace to the '$' one
-var $ = jQuery;
-jQuery.fn = jQuery.prototype = {
-	jquery: "1.1.2",
-	size: function() {
-		return this.length;
-	length: 0,
-	get: function( num ) {
-		return num == undefined ?
-			// Return a 'clean' array
-			jQuery.makeArray( this ) :
-			// Return just the object
-			this[num];
-	pushStack: function( a ) {
-		var ret = jQuery(a);
-		ret.prevObject = this;
-		return ret;
-	setArray: function( a ) {
-		this.length = 0;
-		[].push.apply( this, a );
-		return this;
-	each: function( fn, args ) {
-		return jQuery.each( this, fn, args );
-	index: function( obj ) {
-		var pos = -1;
-		this.each(function(i){
-			if ( this == obj ) pos = i;
-		return pos;
-	attr: function( key, value, type ) {
-		var obj = key;
-		// Look for the case where we're accessing a style value
-		if ( key.constructor == String )
-			if ( value == undefined )
-				return this.length && jQuery[ type || "attr" ]( this[0], key ) || undefined;
-			else {
-				obj = {};
-				obj[ key ] = value;
-		// Check to see if we're setting style values
-		return this.each(function(index){
-			// Set all the styles
-			for ( var prop in obj )
-				jQuery.attr(
-					type ? this.style : this,
-					prop, jQuery.prop(this, obj[prop], type, index, prop)
-	css: function( key, value ) {
-		return this.attr( key, value, "curCSS" );
-	text: function(e) {
-		if ( typeof e == "string" )
-			return this.empty().append( document.createTextNode( e ) );
-		var t = "";
-		jQuery.each( e || this, function(){
-			jQuery.each( this.childNodes, function(){
-				if ( this.nodeType != 8 )
-					t += this.nodeType != 1 ?
-						this.nodeValue : jQuery.fn.text([ this ]);
-		return t;
-	wrap: function() {
-		// The elements to wrap the target around
-		var a = jQuery.clean(arguments);
-		// Wrap each of the matched elements individually
-		return this.each(function(){
-			// Clone the structure that we're using to wrap
-			var b = a[0].cloneNode(true);
-			// Insert it before the element to be wrapped
-			this.parentNode.insertBefore( b, this );
-			// Find the deepest point in the wrap structure
-			while ( b.firstChild )
-				b = b.firstChild;
-			// Move the matched element to within the wrap structure
-			b.appendChild( this );
-	append: function() {
-		return this.domManip(arguments, true, 1, function(a){
-			this.appendChild( a );
-	prepend: function() {
-		return this.domManip(arguments, true, -1, function(a){
-			this.insertBefore( a, this.firstChild );
-	before: function() {
-		return this.domManip(arguments, false, 1, function(a){
-			this.parentNode.insertBefore( a, this );
-	after: function() {
-		return this.domManip(arguments, false, -1, function(a){
-			this.parentNode.insertBefore( a, this.nextSibling );
-	end: function() {
-		return this.prevObject || jQuery([]);
-	find: function(t) {
-		return this.pushStack( jQuery.map( this, function(a){
-			return jQuery.find(t,a);
-		}), t );
-	clone: function(deep) {
-			var a = a.cloneNode( deep != undefined ? deep : true );
-			a.$events = null; // drop $events expando to avoid firing incorrect events
-			return a;
-	filter: function(t) {
-			jQuery.isFunction( t ) &&
-			jQuery.grep(this, function(el, index){
-				return t.apply(el, [index])
-			jQuery.multiFilter(t,this) );
-	not: function(t) {
-			t.constructor == String &&
-			jQuery.multiFilter(t, this, true) ||
-			jQuery.grep(this, function(a) {
-				return ( t.constructor == Array || t.jquery )
-					? jQuery.inArray( a, t ) < 0
-					: a != t;
-	add: function(t) {
-		return this.pushStack( jQuery.merge(
-			this.get(),
-			t.constructor == String ?
-				jQuery(t).get() :
-				t.length != undefined && (!t.nodeName || t.nodeName == "FORM") ?
-					t : [t] )
-	is: function(expr) {
-		return expr ? jQuery.filter(expr,this).r.length > 0 : false;
-	val: function( val ) {
-		return val == undefined ?
-			( this.length ? this[0].value : null ) :
-			this.attr( "value", val );
-	html: function( val ) {
-			( this.length ? this[0].innerHTML : null ) :
-			this.empty().append( val );
-	domManip: function(args, table, dir, fn){
-		var clone = this.length > 1;
-		var a = jQuery.clean(args);
-		if ( dir < 0 )
-			a.reverse();
-			var obj = this;
-			if ( table && jQuery.nodeName(this, "table") && jQuery.nodeName(a[0], "tr") )
-				obj = this.getElementsByTagName("tbody")[0] || this.appendChild(document.createElement("tbody"));
-			jQuery.each( a, function(){
-				fn.apply( obj, [ clone ? this.cloneNode(true) : this ] );
-jQuery.extend = jQuery.fn.extend = function() {
-	// copy reference to target object
-	var target = arguments[0],
-		a = 1;
-	// extend jQuery itself if only one argument is passed
-	if ( arguments.length == 1 ) {
-		target = this;
-		a = 0;
-	var prop;
-	while (prop = arguments[a++])
-		// Extend the base object
-		for ( var i in prop ) target[i] = prop[i];
-	// Return the modified object
-	return target;
-jQuery.extend({
-	noConflict: function() {
-		if ( jQuery._$ )
-			$ = jQuery._$;
-		return jQuery;
-	// This may seem like some crazy code, but trust me when I say that this
-	// is the only cross-browser way to do this. --John
-	isFunction: function( fn ) {
-		return !!fn && typeof fn != "string" && !fn.nodeName &&
-			typeof fn[0] == "undefined" && /function/i.test( fn + "" );
-	// check if an element is in a XML document
-	isXMLDoc: function(elem) {
-		return elem.tagName && elem.ownerDocument && !elem.ownerDocument.body;
-	nodeName: function( elem, name ) {
-		return elem.nodeName && elem.nodeName.toUpperCase() == name.toUpperCase();
-	// args is for internal usage only
-	each: function( obj, fn, args ) {
-		if ( obj.length == undefined )
-			for ( var i in obj )
-				fn.apply( obj[i], args || [i, obj[i]] );
-		else
-			for ( var i = 0, ol = obj.length; i < ol; i++ )
-				if ( fn.apply( obj[i], args || [i, obj[i]] ) === false ) break;
-		return obj;
-	prop: function(elem, value, type, index, prop){
-			// Handle executable functions
-			if ( jQuery.isFunction( value ) )
-				value = value.call( elem, [index] );
-			// exclude the following css properties to add px
-			var exclude = /z-?index|font-?weight|opacity|zoom|line-?height/i;
-			// Handle passing in a number to a CSS property
-			return value && value.constructor == Number && type == "curCSS" && !exclude.test(prop) ?
-				value + "px" :
-				value;
-	className: {
-		// internal only, use addClass("class")
-		add: function( elem, c ){
-			jQuery.each( c.split(/\s+/), function(i, cur){
-				if ( !jQuery.className.has( elem.className, cur ) )
-					elem.className += ( elem.className ? " " : "" ) + cur;
-		// internal only, use removeClass("class")
-		remove: function( elem, c ){
-			elem.className = c ?
-				jQuery.grep( elem.className.split(/\s+/), function(cur){
-					return !jQuery.className.has( c, cur );
-				}).join(" ") : "";
-		// internal only, use is(".class")
-		has: function( t, c ) {
-			t = t.className || t;
-			// escape regex characters
-			c = c.replace(/([\.\\\+\*\?\[\^\]\$\(\)\{\}\=\!\<\>\|\:])/g, "\\$1");
-			return t && new RegExp("(^|\\s)" + c + "(\\s|$)").test( t );
-	swap: function(e,o,f) {
-		for ( var i in o ) {
-			e.style["old"+i] = e.style[i];
-			e.style[i] = o[i];
-		f.apply( e, [] );
-			e.style[i] = e.style["old"+i];
-	css: function(e,p) {
-		if ( p == "height" || p == "width" ) {
-			var old = {}, oHeight, oWidth, d = ["Top","Bottom","Right","Left"];
-			jQuery.each( d, function(){
-				old["padding" + this] = 0;
-				old["border" + this + "Width"] = 0;
-			jQuery.swap( e, old, function() {
-				if (jQuery.css(e,"display") != "none") {
-					oHeight = e.offsetHeight;
-					oWidth = e.offsetWidth;
-				} else {
-					e = jQuery(e.cloneNode(true))
-						.find(":radio").removeAttr("checked").end()
-						.css({
-							visibility: "hidden", position: "absolute", display: "block", right: "0", left: "0"
-						}).appendTo(e.parentNode)[0];
-					var parPos = jQuery.css(e.parentNode,"position");
-					if ( parPos == "" || parPos == "static" )
-						e.parentNode.style.position = "relative";
-					oHeight = e.clientHeight;
-					oWidth = e.clientWidth;
-						e.parentNode.style.position = "static";
-					e.parentNode.removeChild(e);
-			return p == "height" ? oHeight : oWidth;
-		return jQuery.curCSS( e, p );
-	curCSS: function(elem, prop, force) {
-		var ret;
-		if (prop == "opacity" && jQuery.browser.msie)
-			return jQuery.attr(elem.style, "opacity");
-		if (prop == "float" || prop == "cssFloat")
-		    prop = jQuery.browser.msie ? "styleFloat" : "cssFloat";
-		if (!force && elem.style[prop])
-			ret = elem.style[prop];
-		else if (document.defaultView && document.defaultView.getComputedStyle) {
-			if (prop == "cssFloat" || prop == "styleFloat")
-				prop = "float";
-			prop = prop.replace(/([A-Z])/g,"-$1").toLowerCase();
-			var cur = document.defaultView.getComputedStyle(elem, null);
-			if ( cur )
-				ret = cur.getPropertyValue(prop);
-			else if ( prop == "display" )
-				ret = "none";
-			else
-				jQuery.swap(elem, { display: "block" }, function() {
-				    var c = document.defaultView.getComputedStyle(this, "");
-				    ret = c && c.getPropertyValue(prop) || "";
-		} else if (elem.currentStyle) {
-			var newProp = prop.replace(/\-(\w)/g,function(m,c){return c.toUpperCase();});
-			ret = elem.currentStyle[prop] || elem.currentStyle[newProp];
-		return ret;
-	clean: function(a) {
-		var r = [];
-		jQuery.each( a, function(i,arg){
-			if ( !arg ) return;
-			if ( arg.constructor == Number )
-				arg = arg.toString();
-			 // Convert html string into DOM nodes
-			if ( typeof arg == "string" ) {
-				// Trim whitespace, otherwise indexOf won't work as expected
-				var s = jQuery.trim(arg), div = document.createElement("div"), tb = [];
-				var wrap =
-					 // option or optgroup
-					!s.indexOf("<opt") &&
-					[1, "<select>", "</select>"] ||
-					(!s.indexOf("<thead") || !s.indexOf("<tbody") || !s.indexOf("<tfoot")) &&
-					[1, "<table>", "</table>"] ||
-					!s.indexOf("<tr") &&
-					[2, "<table><tbody>", "</tbody></table>"] ||
-				 	// <thead> matched above
-					(!s.indexOf("<td") || !s.indexOf("<th")) &&
-					[3, "<table><tbody><tr>", "</tr></tbody></table>"] ||
-					[0,"",""];
-				// Go to html and back, then peel off extra wrappers
-				div.innerHTML = wrap[1] + s + wrap[2];
-				// Move to the right depth
-				while ( wrap[0]-- )
-					div = div.firstChild;
-				// Remove IE's autoinserted <tbody> from table fragments
-				if ( jQuery.browser.msie ) {
-					// String was a <table>, *may* have spurious <tbody>
-					if ( !s.indexOf("<table") && s.indexOf("<tbody") < 0 )
-						tb = div.firstChild && div.firstChild.childNodes;
-					// String was a bare <thead> or <tfoot>
-					else if ( wrap[1] == "<table>" && s.indexOf("<tbody") < 0 )
-						tb = div.childNodes;
-					for ( var n = tb.length-1; n >= 0 ; --n )
-						if ( jQuery.nodeName(tb[n], "tbody") && !tb[n].childNodes.length )
-							tb[n].parentNode.removeChild(tb[n]);
-				arg = [];
-				for (var i=0, l=div.childNodes.length; i<l; i++)
-					arg.push(div.childNodes[i]);
-			if ( arg.length === 0 && !jQuery.nodeName(arg, "form") )
-				return;
-			if ( arg[0] == undefined || jQuery.nodeName(arg, "form") )
-				r.push( arg );
-			else
-				r = jQuery.merge( r, arg );
-		return r;
-	attr: function(elem, name, value){
-		var fix = jQuery.isXMLDoc(elem) ? {} : {
-			"for": "htmlFor",
-			"class": "className",
-			"float": jQuery.browser.msie ? "styleFloat" : "cssFloat",
-			cssFloat: jQuery.browser.msie ? "styleFloat" : "cssFloat",
-			innerHTML: "innerHTML",
-			className: "className",
-			value: "value",
-			disabled: "disabled",
-			checked: "checked",
-			readonly: "readOnly",
-			selected: "selected"
-		// IE actually uses filters for opacity ... elem is actually elem.style
-		if ( name == "opacity" && jQuery.browser.msie && value != undefined ) {
-			// IE has trouble with opacity if it does not have layout
-			// Force it by setting the zoom level
-			elem.zoom = 1;
-			// Set the alpha filter to set the opacity
-			return elem.filter = elem.filter.replace(/alpha\([^\)]*\)/gi,"") +
-				( value == 1 ? "" : "alpha(opacity=" + value * 100 + ")" );
-		} else if ( name == "opacity" && jQuery.browser.msie )
-			return elem.filter ?
-				parseFloat( elem.filter.match(/alpha\(opacity=(.*)\)/)[1] ) / 100 : 1;
-		// Mozilla doesn't play well with opacity 1
-		if ( name == "opacity" && jQuery.browser.mozilla && value == 1 )
-			value = 0.9999;
-		// Certain attributes only work when accessed via the old DOM 0 way
-		if ( fix[name] ) {
-			if ( value != undefined ) elem[fix[name]] = value;
-			return elem[fix[name]];
-		} else if ( value == undefined && jQuery.browser.msie && jQuery.nodeName(elem, "form") && (name == "action" || name == "method") )
-			return elem.getAttributeNode(name).nodeValue;
-		// IE elem.getAttribute passes even for style
-		else if ( elem.tagName ) {
-			if ( value != undefined ) elem.setAttribute( name, value );
-			if ( jQuery.browser.msie && /href|src/.test(name) && !jQuery.isXMLDoc(elem) )
-				return elem.getAttribute( name, 2 );
-			return elem.getAttribute( name );
-		// elem is actually elem.style ... set the style
-		} else {
-			name = name.replace(/-([a-z])/ig,function(z,b){return b.toUpperCase();});
-			if ( value != undefined ) elem[name] = value;
-			return elem[name];
-	trim: function(t){
-		return t.replace(/^\s+|\s+$/g, "");
-	makeArray: function( a ) {
-		var r = [];
-		if ( a.constructor != Array )
-			for ( var i = 0, al = a.length; i < al; i++ )
-				r.push( a[i] );
-		else
-			r = a.slice( 0 );
-		return r;
-	inArray: function( b, a ) {
-			if ( a[i] == b )
-				return i;
-		return -1;
-	merge: function(first, second) {
-		var r = [].slice.call( first, 0 );
-		// Now check for duplicates between the two arrays
-		// and only add the unique items
-		for ( var i = 0, sl = second.length; i < sl; i++ )
-			// Check for duplicates
-			if ( jQuery.inArray( second[i], r ) == -1 )
-				// The item is unique, add it
-				first.push( second[i] );
-		return first;
-	grep: function(elems, fn, inv) {
-		// If a string is passed in for the function, make a function
-		// for it (a handy shortcut)
-		if ( typeof fn == "string" )
-			fn = new Function("a","i","return " + fn);
-		var result = [];
-		// Go through the array, only saving the items
-		// that pass the validator function
-		for ( var i = 0, el = elems.length; i < el; i++ )
-			if ( !inv && fn(elems[i],i) || inv && !fn(elems[i],i) )
-				result.push( elems[i] );
-		return result;
-	map: function(elems, fn) {
-			fn = new Function("a","return " + fn);
-		var result = [], r = [];
-		// Go through the array, translating each of the items to their
-		// new value (or values).
-		for ( var i = 0, el = elems.length; i < el; i++ ) {
-			var val = fn(elems[i],i);
-			if ( val !== null && val != undefined ) {
-				if ( val.constructor != Array ) val = [val];
-				result = result.concat( val );
-		var r = result.length ? [ result[0] ] : [];
-		check: for ( var i = 1, rl = result.length; i < rl; i++ ) {
-			for ( var j = 0; j < i; j++ )
-				if ( result[i] == r[j] )
-					continue check;
-			r.push( result[i] );
-		return r;
- * Whether the W3C compliant box model is being used.
- * @property
- * @name $.boxModel
- * @type Boolean
- * @cat JavaScript
-new function() {
-	var b = navigator.userAgent.toLowerCase();
-	// Figure out what browser is being used
-	jQuery.browser = {
-		safari: /webkit/.test(b),
-		opera: /opera/.test(b),
-		msie: /msie/.test(b) && !/opera/.test(b),
-		mozilla: /mozilla/.test(b) && !/(compatible|webkit)/.test(b)
-	// Check to see if the W3C box model is being used
-	jQuery.boxModel = !jQuery.browser.msie || document.compatMode == "CSS1Compat";
-jQuery.each({
-	parent: "a.parentNode",
-	parents: "jQuery.parents(a)",
-	next: "jQuery.nth(a,2,'nextSibling')",
-	prev: "jQuery.nth(a,2,'previousSibling')",
-	siblings: "jQuery.sibling(a.parentNode.firstChild,a)",
-	children: "jQuery.sibling(a.firstChild)"
-}, function(i,n){
-	jQuery.fn[ i ] = function(a) {
-		var ret = jQuery.map(this,n);
-		if ( a && typeof a == "string" )
-			ret = jQuery.multiFilter(a,ret);
-		return this.pushStack( ret );
-jQuery.each({
-	appendTo: "append",
-	prependTo: "prepend",
-	insertBefore: "before",
-	insertAfter: "after"
-}, function(i,n){
-	jQuery.fn[ i ] = function(){
-		var a = arguments;
-			for ( var j = 0, al = a.length; j < al; j++ )
-				jQuery(a[j])[n]( this );
-jQuery.each( {
-	removeAttr: function( key ) {
-		jQuery.attr( this, key, "" );
-		this.removeAttribute( key );
-	addClass: function(c){
-		jQuery.className.add(this,c);
-	removeClass: function(c){
-		jQuery.className.remove(this,c);
-	toggleClass: function( c ){
-		jQuery.className[ jQuery.className.has(this,c) ? "remove" : "add" ](this, c);
-	remove: function(a){
-		if ( !a || jQuery.filter( a, [this] ).r.length )
-			this.parentNode.removeChild( this );
-	empty: function() {
-		while ( this.firstChild )
-			this.removeChild( this.firstChild );
-}, function(i,n){
-	jQuery.fn[ i ] = function() {
-		return this.each( n, arguments );
-jQuery.each( [ "eq", "lt", "gt", "contains" ], function(i,n){
-	jQuery.fn[ n ] = function(num,fn) {
-		return this.filter( ":" + n + "(" + num + ")", fn );
-jQuery.each( [ "height", "width" ], function(i,n){
-	jQuery.fn[ n ] = function(h) {
-		return h == undefined ?
-			( this.length ? jQuery.css( this[0], n ) : null ) :
-			this.css( n, h.constructor == String ? h : h + "px" );
-jQuery.extend({
-	expr: {
-		"": "m[2]=='*'||jQuery.nodeName(a,m[2])",
-		"#": "a.getAttribute('id')==m[2]",
-			// Position Checks
-			lt: "i<m[3]-0",
-			gt: "i>m[3]-0",
-			nth: "m[3]-0==i",
-			eq: "m[3]-0==i",
-			first: "i==0",
-			last: "i==r.length-1",
-			even: "i%2==0",
-			odd: "i%2",
-			// Child Checks
-			"nth-child": "jQuery.nth(a.parentNode.firstChild,m[3],'nextSibling',a)==a",
-			"first-child": "jQuery.nth(a.parentNode.firstChild,1,'nextSibling')==a",
-			"last-child": "jQuery.nth(a.parentNode.lastChild,1,'previousSibling')==a",
-			"only-child": "jQuery.sibling(a.parentNode.firstChild).length==1",
-			// Parent Checks
-			parent: "a.firstChild",
-			empty: "!a.firstChild",
-			// Text Check
-			contains: "jQuery.fn.text.apply([a]).indexOf(m[3])>=0",
-			// Visibility
-			visible: 'a.type!="hidden"&&jQuery.css(a,"display")!="none"&&jQuery.css(a,"visibility")!="hidden"',
-			hidden: 'a.type=="hidden"||jQuery.css(a,"display")=="none"||jQuery.css(a,"visibility")=="hidden"',
-			// Form attributes
-			enabled: "!a.disabled",
-			disabled: "a.disabled",
-			checked: "a.checked",
-			selected: "a.selected||jQuery.attr(a,'selected')",
-			// Form elements
-			text: "a.type=='text'",
-			radio: "a.type=='radio'",
-			checkbox: "a.type=='checkbox'",
-			file: "a.type=='file'",
-			password: "a.type=='password'",
-			submit: "a.type=='submit'",
-			image: "a.type=='image'",
-			reset: "a.type=='reset'",
-			button: 'a.type=="button"||jQuery.nodeName(a,"button")',
-			input: "/input|select|textarea|button/i.test(a.nodeName)"
-		".": "jQuery.className.has(a,m[2])",
-			"=": "z==m[4]",
-			"!=": "z!=m[4]",
-			"^=": "z&&!z.indexOf(m[4])",
-			"$=": "z&&z.substr(z.length - m[4].length,m[4].length)==m[4]",
-			"*=": "z&&z.indexOf(m[4])>=0",
-			"": "z",
-			_resort: function(m){
-				return ["", m[1], m[3], m[2], m[5]];
-			_prefix: "z=a[m[3]];if(!z||/href|src/.test(m[3]))z=jQuery.attr(a,m[3]);"
-		"[": "jQuery.find(m[2],a).length"
-	// The regular expressions that power the parsing engine
-	parse: [
-		// Match: [@value='test'], [@foo]
-		/^\[ *(@)([a-z0-9_-]*) *([!*$^=]*) *('?"?)(.*?)\4 *\]/i,
-		// Match: [div], [div p]
-		/^(\[)\s*(.*?(\[.*?\])?[^[]*?)\s*\]/,
-		// Match: :contains('foo')
-		/^(:)([a-z0-9_-]*)\("?'?(.*?(\(.*?\))?[^(]*?)"?'?\)/i,
-		// Match: :even, :last-chlid
-		/^([:.#]*)([a-z0-9_*-]*)/i
-	token: [
-		/^(\/?\.\.)/, "a.parentNode",
-		/^(>|\/)/, "jQuery.sibling(a.firstChild)",
-		/^(\+)/, "jQuery.nth(a,2,'nextSibling')",
-		/^(~)/, function(a){
-			var s = jQuery.sibling(a.parentNode.firstChild);
-			return s.slice(jQuery.inArray(a,s) + 1);
-	multiFilter: function( expr, elems, not ) {
-		var old, cur = [];
-		while ( expr && expr != old ) {
-			old = expr;
-			var f = jQuery.filter( expr, elems, not );
-			expr = f.t.replace(/^\s*,\s*/, "" );
-			cur = not ? elems = f.r : jQuery.merge( cur, f.r );
-		return cur;
-	find: function( t, context ) {
-		// Quickly handle non-string expressions
-		if ( typeof t != "string" )
-			return [ t ];
-		// Make sure that the context is a DOM Element
-		if ( context && !context.nodeType )
-			context = null;
-		// Set the correct context (if none is provided)
-		context = context || document;
-		// Handle the common XPath // expression
-		if ( !t.indexOf("//") ) {
-			context = context.documentElement;
-			t = t.substr(2,t.length);
-		// And the / root expression
-		} else if ( !t.indexOf("/") ) {
-			t = t.substr(1,t.length);
-			if ( t.indexOf("/") >= 1 )
-				t = t.substr(t.indexOf("/"),t.length);
-		// Initialize the search
-		var ret = [context], done = [], last = null;
-		// Continue while a selector expression exists, and while
-		// we're no longer looping upon ourselves
-		while ( t && last != t ) {
-			var r = [];
-			last = t;
-			t = jQuery.trim(t).replace( /^\/\//i, "" );
-			var foundToken = false;
-			// An attempt at speeding up child selectors that
-			// point to a specific element tag
-			var re = /^[\/>]\s*([a-z0-9*-]+)/i;
-			var m = re.exec(t);
-			if ( m ) {
-				// Perform our own iteration and filter
-				jQuery.each( ret, function(){
-					for ( var c = this.firstChild; c; c = c.nextSibling )
-						if ( c.nodeType == 1 && ( jQuery.nodeName(c, m[1]) || m[1] == "*" ) )
-							r.push( c );
-				ret = r;
-				t = t.replace( re, "" );
-				if ( t.indexOf(" ") == 0 ) continue;
-				foundToken = true;
-			} else {
-				// Look for pre-defined expression tokens
-				for ( var i = 0; i < jQuery.token.length; i += 2 ) {
-					// Attempt to match each, individual, token in
-					// the specified order
-					var re = jQuery.token[i];
-					// If the token match was found
-					if ( m ) {
-						// Map it against the token's handler
-						r = ret = jQuery.map( ret, jQuery.isFunction( jQuery.token[i+1] ) ?
-							jQuery.token[i+1] :
-							function(a){ return eval(jQuery.token[i+1]); });
-						// And remove the token
-						t = jQuery.trim( t.replace( re, "" ) );
-						break;
-			// See if there's still an expression, and that we haven't already
-			// matched a token
-			if ( t && !foundToken ) {
-				// Handle multiple expressions
-				if ( !t.indexOf(",") ) {
-					// Clean the result set
-					if ( ret[0] == context ) ret.shift();
-					// Merge the result sets
-					jQuery.merge( done, ret );
-					// Reset the context
-					r = ret = [context];
-					// Touch up the selector string
-					t = " " + t.substr(1,t.length);
-				} else {
-					// Optomize for the case nodeName#idName
-					var re2 = /^([a-z0-9_-]+)(#)([a-z0-9\\*_-]*)/i;
-					var m = re2.exec(t);
-					// Re-organize the results, so that they're consistent
-					if ( m ) {
-					   m = [ 0, m[2], m[3], m[1] ];
-					} else {
-						// Otherwise, do a traditional filter check for
-						// ID, class, and element selectors
-						re2 = /^([#.]?)([a-z0-9\\*_-]*)/i;
-						m = re2.exec(t);
-					// Try to do a global search by ID, where we can
-					if ( m[1] == "#" && ret[ret.length-1].getElementById ) {
-						// Optimization for HTML document case
-						var oid = ret[ret.length-1].getElementById(m[2]);
-						// Do a quick check for the existence of the actual ID attribute
-						// to avoid selecting by the name attribute in IE
-						if ( jQuery.browser.msie && oid && oid.id != m[2] )
-							oid = jQuery('[@id="'+m[2]+'"]', ret[ret.length-1])[0];
-						// Do a quick check for node name (where applicable) so
-						// that div#foo searches will be really fast
-						ret = r = oid && (!m[3] || jQuery.nodeName(oid, m[3])) ? [oid] : [];
-					} else {
-						// Pre-compile a regular expression to handle class searches
-						if ( m[1] == "." )
-							var rec = new RegExp("(^|\\s)" + m[2] + "(\\s|$)");
-						// We need to find all descendant elements, it is more
-						// efficient to use getAll() when we are already further down
-						// the tree - we try to recognize that here
-							// Grab the tag name being searched for
-							var tag = m[1] != "" || m[0] == "" ? "*" : m[2];
-							// Handle IE7 being really dumb about <object>s
-							if ( jQuery.nodeName(this, "object") && tag == "*" )
-								tag = "param";
-							jQuery.merge( r,
-								m[1] != "" && ret.length != 1 ?
-									jQuery.getAll( this, [], m[1], m[2], rec ) :
-									this.getElementsByTagName( tag )
-						// It's faster to filter by class and be done with it
-						if ( m[1] == "." && ret.length == 1 )
-							r = jQuery.grep( r, function(e) {
-								return rec.test(e.className);
-						// Same with ID filtering
-						if ( m[1] == "#" && ret.length == 1 ) {
-							// Remember, then wipe out, the result set
-							var tmp = r;
-							r = [];
-							// Then try to find the element with the ID
-							jQuery.each( tmp, function(){
-								if ( this.getAttribute("id") == m[2] ) {
-									r = [ this ];
-									return false;
-						ret = r;
-					t = t.replace( re2, "" );
-			// If a selector string still exists
-			if ( t ) {
-				// Attempt to filter it
-				var val = jQuery.filter(t,r);
-				ret = r = val.r;
-				t = jQuery.trim(val.t);
-		// Remove the root context
-		if ( ret && ret[0] == context ) ret.shift();
-		// And combine the results
-		return done;
-	filter: function(t,r,not) {
-		// Look for common filter expressions
-		while ( t && /^[a-z[({<*:.#]/i.test(t) ) {
-			var p = jQuery.parse, m;
-			jQuery.each( p, function(i,re){
-				// Look for, and replace, string-like sequences
-				// and finally build a regexp out of it
-				m = re.exec( t );
-				if ( m ) {
-					// Remove what we just matched
-					t = t.substring( m[0].length );
-					// Re-organize the first match
-					if ( jQuery.expr[ m[1] ]._resort )
-						m = jQuery.expr[ m[1] ]._resort( m );
-					return false;
-			// :not() is a special case that can be optimized by
-			// keeping it out of the expression list
-			if ( m[1] == ":" && m[2] == "not" )
-				r = jQuery.filter(m[3], r, true).r;
-			// Handle classes as a special case (this will help to
-			// improve the speed, as the regexp will only be compiled once)
-			else if ( m[1] == "." ) {
-				var re = new RegExp("(^|\\s)" + m[2] + "(\\s|$)");
-				r = jQuery.grep( r, function(e){
-					return re.test(e.className || "");
-				}, not);
-			// Otherwise, find the expression to execute
-			} else {
-				var f = jQuery.expr[m[1]];
-				if ( typeof f != "string" )
-					f = jQuery.expr[m[1]][m[2]];
-				// Build a custom macro to enclose it
-				eval("f = function(a,i){" +
-					( jQuery.expr[ m[1] ]._prefix || "" ) +
-					"return " + f + "}");
-				// Execute it against the current filter
-				r = jQuery.grep( r, f, not );
-		// Return an array of filtered elements (r)
-		// and the modified expression string (t)
-		return { r: r, t: t };
-	getAll: function( o, r, token, name, re ) {
-		for ( var s = o.firstChild; s; s = s.nextSibling )
-			if ( s.nodeType == 1 ) {
-				var add = true;
-				if ( token == "." )
-					add = s.className && re.test(s.className);
-				else if ( token == "#" )
-					add = s.getAttribute("id") == name;
-				if ( add )
-					r.push( s );
-				if ( token == "#" && r.length ) break;
-				if ( s.firstChild )
-					jQuery.getAll( s, r, token, name, re );
-		return r;
-	parents: function( elem ){
-		var matched = [];
-		var cur = elem.parentNode;
-		while ( cur && cur != document ) {
-			matched.push( cur );
-			cur = cur.parentNode;
-		return matched;
-	nth: function(cur,result,dir,elem){
-		result = result || 1;
-		var num = 0;
-		for ( ; cur; cur = cur[dir] ) {
-			if ( cur.nodeType == 1 ) num++;
-			if ( num == result || result == "even" && num % 2 == 0 && num > 1 && cur == elem ||
-				result == "odd" && num % 2 == 1 && cur == elem ) return cur;
-	sibling: function( n, elem ) {
-		var r = [];
-		for ( ; n; n = n.nextSibling ) {
-			if ( n.nodeType == 1 && (!elem || n != elem) )
-				r.push( n );
-		return r;
- * A number of helper functions used for managing events.
- * Many of the ideas behind this code orignated from
- * Dean Edwards' addEvent library.
-jQuery.event = {
-	// Bind an event to an element
-	// Original by Dean Edwards
-	add: function(element, type, handler, data) {
-		// For whatever reason, IE has trouble passing the window object
-		// around, causing it to be cloned in the process
-		if ( jQuery.browser.msie && element.setInterval != undefined )
-			element = window;
-		// if data is passed, bind to handler
-		if( data )
-			handler.data = data;
-		// Make sure that the function being executed has a unique ID
-		if ( !handler.guid )
-			handler.guid = this.guid++;
-		// Init the element's event structure
-		if (!element.$events)
-			element.$events = {};
-		// Get the current list of functions bound to this event
-		var handlers = element.$events[type];
-		// If it hasn't been initialized yet
-		if (!handlers) {
-			// Init the event handler queue
-			handlers = element.$events[type] = {};
-			// Remember an existing handler, if it's already there
-			if (element["on" + type])
-				handlers[0] = element["on" + type];
-		// Add the function to the element's handler list
-		handlers[handler.guid] = handler;
-		// And bind the global event handler to the element
-		element["on" + type] = this.handle;
-		// Remember the function in a global list (for triggering)
-		if (!this.global[type])
-			this.global[type] = [];
-		this.global[type].push( element );
-	guid: 1,
-	global: {},
-	// Detach an event or set of events from an element
-	remove: function(element, type, handler) {
-		if (element.$events) {
-			var i,j,k;
-			if ( type && type.type ) { // type is actually an event object here
-				handler = type.handler;
-				type    = type.type;
-			if (type && element.$events[type])
-				// remove the given handler for the given type
-				if ( handler )
-					delete element.$events[type][handler.guid];
-				// remove all handlers for the given type
-				else
-					for ( i in element.$events[type] )
-						delete element.$events[type][i];
-			else
-				for ( j in element.$events )
-					this.remove( element, j );
-			// remove event handler if no more handlers exist
-			for ( k in element.$events[type] )
-				if (k) {
-					k = true;
-					break;
-			if (!k) element["on" + type] = null;
-	trigger: function(type, data, element) {
-		// Clone the incoming data, if any
-		data = jQuery.makeArray(data || []);
-		// Handle a global trigger
-		if ( !element )
-			jQuery.each( this.global[type] || [], function(){
-				jQuery.event.trigger( type, data, this );
-		// Handle triggering a single element
-		else {
-			var handler = element["on" + type ], val,
-				fn = jQuery.isFunction( element[ type ] );
-			if ( handler ) {
-				// Pass along a fake event
-				data.unshift( this.fix({ type: type, target: element }) );
-				// Trigger the event
-				if ( (val = handler.apply( element, data )) !== false )
-					this.triggered = true;
-			if ( fn && val !== false )
-				element[ type ]();
-			this.triggered = false;
-	handle: function(event) {
-		// Handle the second event of a trigger and when
-		// an event is called after a page has unloaded
-		if ( typeof jQuery == "undefined" || jQuery.event.triggered ) return;
-		// Empty object is for triggered events with no data
-		event = jQuery.event.fix( event || window.event || {} );
-		// returned undefined or false
-		var returnValue;
-		var c = this.$events[event.type];
-		var args = [].slice.call( arguments, 1 );
-		args.unshift( event );
-		for ( var j in c ) {
-			// Pass in a reference to the handler function itself
-			// So that we can later remove it
-			args[0].handler = c[j];
-			args[0].data = c[j].data;
-			if ( c[j].apply( this, args ) === false ) {
-				event.preventDefault();
-				event.stopPropagation();
-				returnValue = false;
-		// Clean up added properties in IE to prevent memory leak
-		if (jQuery.browser.msie) event.target = event.preventDefault = event.stopPropagation = event.handler = event.data = null;
-		return returnValue;
-	fix: function(event) {
-		// Fix target property, if necessary
-		if ( !event.target && event.srcElement )
-			event.target = event.srcElement;
-		// Calculate pageX/Y if missing and clientX/Y available
-		if ( event.pageX == undefined && event.clientX != undefined ) {
-			var e = document.documentElement, b = document.body;
-			event.pageX = event.clientX + (e.scrollLeft || b.scrollLeft);
-			event.pageY = event.clientY + (e.scrollTop || b.scrollTop);
-		// check if target is a textnode (safari)
-		if (jQuery.browser.safari && event.target.nodeType == 3) {
-			// store a copy of the original event object
-			// and clone because target is read only
-			var originalEvent = event;
-			event = jQuery.extend({}, originalEvent);
-			// get parentnode from textnode
-			event.target = originalEvent.target.parentNode;
-			// add preventDefault and stopPropagation since
-			// they will not work on the clone
-			event.preventDefault = function() {
-				return originalEvent.preventDefault();
-			event.stopPropagation = function() {
-				return originalEvent.stopPropagation();
-		// fix preventDefault and stopPropagation
-		if (!event.preventDefault)
-				this.returnValue = false;
-		if (!event.stopPropagation)
-				this.cancelBubble = true;
-		return event;
-jQuery.fn.extend({
-	bind: function( type, data, fn ) {
-			jQuery.event.add( this, type, fn || data, data );
-	one: function( type, data, fn ) {
-			jQuery.event.add( this, type, function(event) {
-				jQuery(this).unbind(event);
-				return (fn || data).apply( this, arguments);
-			}, data);
-	unbind: function( type, fn ) {
-			jQuery.event.remove( this, type, fn );
-	trigger: function( type, data ) {
-	toggle: function() {
-		// Save reference to arguments for access in closure
-		return this.click(function(e) {
-			// Figure out which function to execute
-			this.lastToggle = this.lastToggle == 0 ? 1 : 0;
-			// Make sure that clicks stop
-			e.preventDefault();
-			// and execute the function
-			return a[this.lastToggle].apply( this, [e] ) || false;
-	hover: function(f,g) {
-		// A private function for handling mouse 'hovering'
-		function handleHover(e) {
-			// Check if mouse(over|out) are still within the same parent element
-			var p = (e.type == "mouseover" ? e.fromElement : e.toElement) || e.relatedTarget;
-			// Traverse up the tree
-			while ( p && p != this ) try { p = p.parentNode } catch(e) { p = this; };
-			// If we actually just moused on to a sub-element, ignore it
-			if ( p == this ) return false;
-			// Execute the right function
-			return (e.type == "mouseover" ? f : g).apply(this, [e]);
-		// Bind the function to the two event listeners
-		return this.mouseover(handleHover).mouseout(handleHover);
-	ready: function(f) {
-		// If the DOM is already ready
-		if ( jQuery.isReady )
-			// Execute the function immediately
-			f.apply( document, [jQuery] );
-		// Otherwise, remember the function for later
-		else {
-			// Add the function to the wait list
-			jQuery.readyList.push( function() { return f.apply(this, [jQuery]) } );
-		return this;
-jQuery.extend({
-	 * All the code that makes DOM Ready work nicely.
-	isReady: false,
-	readyList: [],
-	// Handle when the DOM is ready
-	ready: function() {
-		// Make sure that the DOM is not already loaded
-		if ( !jQuery.isReady ) {
-			// Remember that the DOM is ready
-			jQuery.isReady = true;
-			// If there are functions bound, to execute
-			if ( jQuery.readyList ) {
-				// Execute all of them
-				jQuery.each( jQuery.readyList, function(){
-					this.apply( document );
-				// Reset the list of functions
-				jQuery.readyList = null;
-			// Remove event lisenter to avoid memory leak
-			if ( jQuery.browser.mozilla || jQuery.browser.opera )
-				document.removeEventListener( "DOMContentLoaded", jQuery.ready, false );
-new function(){
-	jQuery.each( ("blur,focus,load,resize,scroll,unload,click,dblclick," +
-		"mousedown,mouseup,mousemove,mouseover,mouseout,change,select," +
-		"submit,keydown,keypress,keyup,error").split(","), function(i,o){
-		// Handle event binding
-		jQuery.fn[o] = function(f){
-			return f ? this.bind(o, f) : this.trigger(o);
-	// If Mozilla is used
-		// Use the handy event callback
-		document.addEventListener( "DOMContentLoaded", jQuery.ready, false );
-	// If IE is used, use the excellent hack by Matthias Miller
-	// http://www.outofhanwell.com/blog/index.php?title=the_window_onload_problem_revisited
-	else if ( jQuery.browser.msie ) {
-		// Only works if you document.write() it
-		document.write("<scr" + "ipt id=__ie_init defer=true " +
-			"src=//:><\/script>");
-		// Use the defer script hack
-		var script = document.getElementById("__ie_init");
-		// script does not exist if jQuery is loaded dynamically
-		if ( script )
-			script.onreadystatechange = function() {
-				if ( this.readyState != "complete" ) return;
-				jQuery.ready();
-		// Clear from memory
-		script = null;
-	// If Safari  is used
-	} else if ( jQuery.browser.safari )
-		// Continually check to see if the document.readyState is valid
-		jQuery.safariTimer = setInterval(function(){
-			// loaded and complete are both valid states
-			if ( document.readyState == "loaded" ||
-				document.readyState == "complete" ) {
-				// If either one are found, remove the timer
-				clearInterval( jQuery.safariTimer );
-				jQuery.safariTimer = null;
-				// and execute any waiting functions
-				jQuery.ready();
-		}, 10);
-	// A fallback to window.onload, that will always work
-	jQuery.event.add( window, "load", jQuery.ready );
-// Clean up after IE to avoid memory leaks
-if (jQuery.browser.msie)
-	jQuery(window).one("unload", function() {
-		var global = jQuery.event.global;
-		for ( var type in global ) {
-			var els = global[type], i = els.length;
-			if ( i && type != 'unload' )
-				do
-					jQuery.event.remove(els[i-1], type);
-				while (--i);
-jQuery.fn.extend({
-	loadIfModified: function( url, params, callback ) {
-		this.load( url, params, callback, 1 );
-	load: function( url, params, callback, ifModified ) {
-		if ( jQuery.isFunction( url ) )
-			return this.bind("load", url);
-		callback = callback || function(){};
-		// Default to a GET request
-		var type = "GET";
-		// If the second parameter was provided
-		if ( params )
-			// If it's a function
-			if ( jQuery.isFunction( params ) ) {
-				// We assume that it's the callback
-				callback = params;
-				params = null;
-			// Otherwise, build a param string
-			} else {
-				params = jQuery.param( params );
-				type = "POST";
-		var self = this;
-		// Request the remote document
-		jQuery.ajax({
-			url: url,
-			type: type,
-			data: params,
-			ifModified: ifModified,
-			complete: function(res, status){
-				if ( status == "success" || !ifModified && status == "notmodified" )
-					// Inject the HTML into all the matched elements
-					self.attr("innerHTML", res.responseText)
-					  // Execute all the scripts inside of the newly-injected HTML
-					  .evalScripts()
-					  // Execute callback
-					  .each( callback, [res.responseText, status, res] );
-				else
-					callback.apply( self, [res.responseText, status, res] );
-		return this;
-	serialize: function() {
-		return jQuery.param( this );
-	evalScripts: function() {
-		return this.find("script").each(function(){
-			if ( this.src )
-				jQuery.getScript( this.src );
-			else
-				jQuery.globalEval( this.text || this.textContent || this.innerHTML || "" );
-		}).end();
-// If IE is used, create a wrapper for the XMLHttpRequest object
-if ( !window.XMLHttpRequest )
-	XMLHttpRequest = function(){
-		return new ActiveXObject("Microsoft.XMLHTTP");
-// Attach a bunch of functions for handling common AJAX events
-jQuery.each( "ajaxStart,ajaxStop,ajaxComplete,ajaxError,ajaxSuccess,ajaxSend".split(","), function(i,o){
-		return this.bind(o, f);
-jQuery.extend({
-	get: function( url, data, callback, type, ifModified ) {
-		// shift arguments if data argument was ommited
-		if ( jQuery.isFunction( data ) ) {
-			callback = data;
-			data = null;
-		return jQuery.ajax({
-			url: url,
-			data: data,
-			success: callback,
-			dataType: type,
-	getIfModified: function( url, data, callback, type ) {
-		return jQuery.get(url, data, callback, type, 1);
-	getScript: function( url, callback ) {
-		return jQuery.get(url, null, callback, "script");
-	getJSON: function( url, data, callback ) {
-		return jQuery.get(url, data, callback, "json");
-	post: function( url, data, callback, type ) {
-			callback = data;
-			data = {};
-			type: "POST",
-			url: url,
-			data: data,
-			dataType: type
-	// timeout (ms)
-	//timeout: 0,
-	ajaxTimeout: function( timeout ) {
-		jQuery.ajaxSettings.timeout = timeout;
-	ajaxSetup: function( settings ) {
-		jQuery.extend( jQuery.ajaxSettings, settings );
-	ajaxSettings: {
-		global: true,
-		type: "GET",
-		timeout: 0,
-		contentType: "application/x-www-form-urlencoded",
-		processData: true,
-		async: true,
-		data: null
-	// Last-Modified header cache for next request
-	lastModified: {},
-	ajax: function( s ) {
-		// TODO introduce global settings, allowing the client to modify them for all requests, not only timeout
-		s = jQuery.extend({}, jQuery.ajaxSettings, s);
-		// if data available
-		if ( s.data ) {
-			// convert data if not already a string
-			if (s.processData && typeof s.data != "string")
-    			s.data = jQuery.param(s.data);
-			// append data to url for get requests
-			if( s.type.toLowerCase() == "get" ) {
-				// "?" + data or "&" + data (in case there are already params)
-				s.url += ((s.url.indexOf("?") > -1) ? "&" : "?") + s.data;
-				// IE likes to send both get and post data, prevent this
-				s.data = null;
-		// Watch for a new set of requests
-		if ( s.global && ! jQuery.active++ )
-			jQuery.event.trigger( "ajaxStart" );
-		var requestDone = false;
-		// Create the request object
-		var xml = new XMLHttpRequest();
-		// Open the socket
-		xml.open(s.type, s.url, s.async);
-		// Set the correct header, if data is being sent
-		if ( s.data )
-			xml.setRequestHeader("Content-Type", s.contentType);
-		// Set the If-Modified-Since header, if ifModified mode.
-		if ( s.ifModified )
-			xml.setRequestHeader("If-Modified-Since",
-				jQuery.lastModified[s.url] || "Thu, 01 Jan 1970 00:00:00 GMT" );
-		// Set header so the called script knows that it's an XMLHttpRequest
-		xml.setRequestHeader("X-Requested-With", "XMLHttpRequest");
-		// Make sure the browser sends the right content length
-		if ( xml.overrideMimeType )
-			xml.setRequestHeader("Connection", "close");
-		// Allow custom headers/mimetypes
-		if( s.beforeSend )
-			s.beforeSend(xml);
-		if ( s.global )
-		    jQuery.event.trigger("ajaxSend", [xml, s]);
-		// Wait for a response to come back
-		var onreadystatechange = function(isTimeout){
-			// The transfer is complete and the data is available, or the request timed out
-			if ( xml && (xml.readyState == 4 || isTimeout == "timeout") ) {
-				requestDone = true;
-				// clear poll interval
-				if (ival) {
-					clearInterval(ival);
-					ival = null;
-				var status;
-				try {
-					status = jQuery.httpSuccess( xml ) && isTimeout != "timeout" ?
-						s.ifModified && jQuery.httpNotModified( xml, s.url ) ? "notmodified" : "success" : "error";
-					// Make sure that the request was successful or notmodified
-					if ( status != "error" ) {
-						// Cache Last-Modified header, if ifModified mode.
-						var modRes;
-						try {
-							modRes = xml.getResponseHeader("Last-Modified");
-						} catch(e) {} // swallow exception thrown by FF if header is not available
-						if ( s.ifModified && modRes )
-							jQuery.lastModified[s.url] = modRes;
-						// process the data (runs the xml through httpData regardless of callback)
-						var data = jQuery.httpData( xml, s.dataType );
-						// If a local callback was specified, fire it and pass it the data
-						if ( s.success )
-							s.success( data, status );
-						// Fire the global callback
-						if( s.global )
-							jQuery.event.trigger( "ajaxSuccess", [xml, s] );
-					} else
-						jQuery.handleError(s, xml, status);
-				} catch(e) {
-					status = "error";
-					jQuery.handleError(s, xml, status, e);
-				// The request was completed
-				if( s.global )
-					jQuery.event.trigger( "ajaxComplete", [xml, s] );
-				// Handle the global AJAX counter
-				if ( s.global && ! --jQuery.active )
-					jQuery.event.trigger( "ajaxStop" );
-				// Process result
-				if ( s.complete )
-					s.complete(xml, status);
-				// Stop memory leaks
-				if(s.async)
-					xml = null;
-		// don't attach the handler to the request, just poll it instead
-		var ival = setInterval(onreadystatechange, 13);
-		// Timeout checker
-		if ( s.timeout > 0 )
-			setTimeout(function(){
-				// Check to see if the request is still happening
-				if ( xml ) {
-					// Cancel the request
-					xml.abort();
-					if( !requestDone )
-						onreadystatechange( "timeout" );
-			}, s.timeout);
-		// Send the data
-		try {
-			xml.send(s.data);
-		} catch(e) {
-			jQuery.handleError(s, xml, null, e);
-		// firefox 1.5 doesn't fire statechange for sync requests
-		if ( !s.async )
-			onreadystatechange();
-		// return XMLHttpRequest to allow aborting the request etc.
-		return xml;
-	handleError: function( s, xml, status, e ) {
-		if ( s.error ) s.error( xml, status, e );
-		if ( s.global )
-			jQuery.event.trigger( "ajaxError", [xml, s, e] );
-	// Counter for holding the number of active queries
-	active: 0,
-	// Determines if an XMLHttpRequest was successful or not
-	httpSuccess: function( r ) {
-		try {
-			return !r.status && location.protocol == "file:" ||
-				( r.status >= 200 && r.status < 300 ) || r.status == 304 ||
-				jQuery.browser.safari && r.status == undefined;
-		} catch(e){}
-		return false;
-	// Determines if an XMLHttpRequest returns NotModified
-	httpNotModified: function( xml, url ) {
-		try {
-			var xmlRes = xml.getResponseHeader("Last-Modified");
-			// Firefox always returns 200. check Last-Modified date
-			return xml.status == 304 || xmlRes == jQuery.lastModified[url] ||
-				jQuery.browser.safari && xml.status == undefined;
-		} catch(e){}
-		return false;
-	/* Get the data out of an XMLHttpRequest.
-	 * Return parsed XML if content-type header is "xml" and type is "xml" or omitted,
-	 * otherwise return plain text.
-	 * (String) data - The type of data that you're expecting back,
-	 * (e.g. "xml", "html", "script")
-	httpData: function( r, type ) {
-		var ct = r.getResponseHeader("content-type");
-		var data = !type && ct && ct.indexOf("xml") >= 0;
-		data = type == "xml" || data ? r.responseXML : r.responseText;
-		// If the type is "script", eval it in global context
-		if ( type == "script" )
-			jQuery.globalEval( data );
-		// Get the JavaScript object, if JSON is used.
-		if ( type == "json" )
-			eval( "data = " + data );
-		// evaluate scripts within html
-		if ( type == "html" )
-			jQuery("<div>").html(data).evalScripts();
-		return data;
-	// Serialize an array of form elements or a set of
-	// key/values into a query string
-	param: function( a ) {
-		var s = [];
-		// If an array was passed in, assume that it is an array
-		// of form elements
-		if ( a.constructor == Array || a.jquery )
-			// Serialize the form elements
-				s.push( encodeURIComponent(this.name) + "=" + encodeURIComponent( this.value ) );
-		// Otherwise, assume that it's an object of key/value pairs
-		else
-			// Serialize the key/values
-			for ( var j in a )
-				// If the value is an array then the key names need to be repeated
-				if ( a[j] && a[j].constructor == Array )
-					jQuery.each( a[j], function(){
-						s.push( encodeURIComponent(j) + "=" + encodeURIComponent( this ) );
-				else
-					s.push( encodeURIComponent(j) + "=" + encodeURIComponent( a[j] ) );
-		// Return the resulting serialization
-		return s.join("&");
-	// evalulates a script in global context
-	// not reliable for safari
-	globalEval: function( data ) {
-		if ( window.execScript )
-			window.execScript( data );
-		else if ( jQuery.browser.safari )
-			// safari doesn't provide a synchronous global eval
-			window.setTimeout( data, 0 );
-		else
-			eval.call( window, data );
-jQuery.fn.extend({
-	show: function(speed,callback){
-		var hidden = this.filter(":hidden");
-		speed ?
-			hidden.animate({
-				height: "show", width: "show", opacity: "show"
-			}, speed, callback) :
-			hidden.each(function(){
-				this.style.display = this.oldblock ? this.oldblock : "";
-				if ( jQuery.css(this,"display") == "none" )
-					this.style.display = "block";
-		return this;
-	hide: function(speed,callback){
-		var visible = this.filter(":visible");
-		speed ?
-			visible.animate({
-				height: "hide", width: "hide", opacity: "hide"
-			visible.each(function(){
-				this.oldblock = this.oldblock || jQuery.css(this,"display");
-				if ( this.oldblock == "none" )
-					this.oldblock = "block";
-				this.style.display = "none";
-		return this;
-	// Save the old toggle function
-	_toggle: jQuery.fn.toggle,
-	toggle: function( fn, fn2 ){
-		var args = arguments;
-		return jQuery.isFunction(fn) && jQuery.isFunction(fn2) ?
-			this._toggle( fn, fn2 ) :
-			this.each(function(){
-				jQuery(this)[ jQuery(this).is(":hidden") ? "show" : "hide" ]
-					.apply( jQuery(this), args );
-	slideDown: function(speed,callback){
-		return this.animate({height: "show"}, speed, callback);
-	slideUp: function(speed,callback){
-		return this.animate({height: "hide"}, speed, callback);
-	slideToggle: function(speed, callback){
-			var state = jQuery(this).is(":hidden") ? "show" : "hide";
-			jQuery(this).animate({height: state}, speed, callback);
-	fadeIn: function(speed, callback){
-		return this.animate({opacity: "show"}, speed, callback);
-	fadeOut: function(speed, callback){
-		return this.animate({opacity: "hide"}, speed, callback);
-	fadeTo: function(speed,to,callback){
-		return this.animate({opacity: to}, speed, callback);
-	animate: function( prop, speed, easing, callback ) {
-		return this.queue(function(){
-			this.curAnim = jQuery.extend({}, prop);
-			var opt = jQuery.speed(speed, easing, callback);
-			for ( var p in prop ) {
-				var e = new jQuery.fx( this, opt, p );
-				if ( prop[p].constructor == Number )
-					e.custom( e.cur(), prop[p] );
-				else
-					e[ prop[p] ]( prop );
-	queue: function(type,fn){
-		if ( !fn ) {
-			fn = type;
-			type = "fx";
-			if ( !this.queue )
-				this.queue = {};
-			if ( !this.queue[type] )
-				this.queue[type] = [];
-			this.queue[type].push( fn );
-			if ( this.queue[type].length == 1 )
-				fn.apply(this);
-jQuery.extend({
-	speed: function(speed, easing, fn) {
-		var opt = speed && speed.constructor == Object ? speed : {
-			complete: fn || !fn && easing ||
-				jQuery.isFunction( speed ) && speed,
-			duration: speed,
-			easing: fn && easing || easing && easing.constructor != Function && easing
-		opt.duration = (opt.duration && opt.duration.constructor == Number ?
-			opt.duration :
-			{ slow: 600, fast: 200 }[opt.duration]) || 400;
-		// Queueing
-		opt.old = opt.complete;
-		opt.complete = function(){
-			jQuery.dequeue(this, "fx");
-			if ( jQuery.isFunction( opt.old ) )
-				opt.old.apply( this );
-		return opt;
-	easing: {},
-	queue: {},
-	dequeue: function(elem,type){
-		type = type || "fx";
-		if ( elem.queue && elem.queue[type] ) {
-			// Remove self
-			elem.queue[type].shift();
-			// Get next function
-			var f = elem.queue[type][0];
-			if ( f ) f.apply( elem );
-	 * I originally wrote fx() as a clone of moo.fx and in the process
-	 * of making it small in size the code became illegible to sane
-	 * people. You've been warned.
-	fx: function( elem, options, prop ){
-		var z = this;
-		// The styles
-		var y = elem.style;
-		// Store display property
-		var oldDisplay = jQuery.css(elem, "display");
-		// Make sure that nothing sneaks out
-		y.overflow = "hidden";
-		// Simple function for setting a style value
-		z.a = function(){
-			if ( options.step )
-				options.step.apply( elem, [ z.now ] );
-			if ( prop == "opacity" )
-				jQuery.attr(y, "opacity", z.now); // Let attr handle opacity
-			else if ( parseInt(z.now) ) // My hate for IE will never die
-				y[prop] = parseInt(z.now) + "px";
-			y.display = "block"; // Set display property to block for animation
-		// Figure out the maximum number to run to
-		z.max = function(){
-			return parseFloat( jQuery.css(elem,prop) );
-		// Get the current size
-		z.cur = function(){
-			var r = parseFloat( jQuery.curCSS(elem, prop) );
-			return r && r > -10000 ? r : z.max();
-		// Start an animation from one number to another
-		z.custom = function(from,to){
-			z.startTime = (new Date()).getTime();
-			z.now = from;
-			z.a();
-			z.timer = setInterval(function(){
-				z.step(from, to);
-			}, 13);
-		// Simple 'show' function
-		z.show = function(){
-			if ( !elem.orig ) elem.orig = {};
-			// Remember where we started, so that we can go back to it later
-			elem.orig[prop] = this.cur();
-			options.show = true;
-			// Begin the animation
-			z.custom(0, elem.orig[prop]);
-			// Stupid IE, look what you made me do
-			if ( prop != "opacity" )
-				y[prop] = "1px";
-		// Simple 'hide' function
-		z.hide = function(){
-			options.hide = true;
-			z.custom(elem.orig[prop], 0);
-		//Simple 'toggle' function
-		z.toggle = function() {
-			if(oldDisplay == "none")  {
-					y[prop] = "1px";
-			} else {
-		// Each step of an animation
-		z.step = function(firstNum, lastNum){
-			var t = (new Date()).getTime();
-			if (t > options.duration + z.startTime) {
-				// Stop the timer
-				clearInterval(z.timer);
-				z.timer = null;
-				z.now = lastNum;
-				z.a();
-				if (elem.curAnim) elem.curAnim[ prop ] = true;
-				var done = true;
-				for ( var i in elem.curAnim )
-					if ( elem.curAnim[i] !== true )
-						done = false;
-				if ( done ) {
-					// Reset the overflow
-					y.overflow = "";
-					// Reset the display
-					y.display = oldDisplay;
-					if (jQuery.css(elem, "display") == "none")
-					// Hide the element if the "hide" operation was done
-					if ( options.hide )
-						y.display = "none";
-					// Reset the properties, if the item has been hidden or shown
-					if ( options.hide || options.show )
-						for ( var p in elem.curAnim )
-							if (p == "opacity")
-								jQuery.attr(y, p, elem.orig[p]);
-							else
-								y[p] = "";
-				// If a callback was provided, execute it
-				if ( done && jQuery.isFunction( options.complete ) )
-					// Execute the complete function
-					options.complete.apply( elem );
-			} else {
-				var n = t - this.startTime;
-				// Figure out where in the animation we are and set the number
-				var p = n / options.duration;
-				// If the easing function exists, then use it
-				z.now = options.easing && jQuery.easing[options.easing] ?
-					jQuery.easing[options.easing](p, n,  firstNum, (lastNum-firstNum), options.duration) :
-					// else use default linear easing
-					((-Math.cos(p*Math.PI)/2) + 0.5) * (lastNum-firstNum) + firstNum;
-				// Perform the next step of the animation
-				z.a();
More information about the Mapbender_commits mailing list
