[Mapbender-commits] r1357 - trunk/mapbender/http/print
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 25 03:44:37 EDT 2007
Author: astrid_emde
Date: 2007-05-25 03:44:37 -0400 (Fri, 25 May 2007)
New Revision: 1357
   trunk/mapbender/http/print/mod_printPDF_pdf.php
frame around the legend was definded twice, deleted one definition
Modified: trunk/mapbender/http/print/mod_printPDF_pdf.php
--- trunk/mapbender/http/print/mod_printPDF_pdf.php	2007-05-24 15:42:07 UTC (rev 1356)
+++ trunk/mapbender/http/print/mod_printPDF_pdf.php	2007-05-25 07:44:37 UTC (rev 1357)
@@ -572,44 +572,6 @@
     $my_legend = explode("___",$my_legend);
-	//frames (x1, y1, x2, y2)
-	if($size == "A4" && $format == "portrait"){
-		#line
-		$pdf->setLineStyle($linewidth, '', '', array());
-		//left
-		$pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border + $header_height);
-		//right
-		$pdf->line($mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height);
-		//top
-		$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
-		//bottom
-		$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
-		if ($legendImage!=''){
-			//image on top of page
-			$pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border + $header_height - $legendImage_height - 4 , $legendImage_width, $legendImage_height);
-	} else {
-	  //left
-	  $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border);
-	  //right
-	  $pdf->line($mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
-	  //top
-	   $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
-	   //bottom
-	   $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border , $mapOffset_left - $border, $mapOffset_bottom - $border);
-			$pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border - $legendImage_height -4 , $legendImage_width, $legendImage_height);
-			//line under legend (only landscape)
-			//$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border  - $legendImage_height - 4 , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 6);
 	//columns
 	  $pdf->ezColumnsStart(array ('num'=>2, 'gap'=>10));
@@ -631,7 +593,7 @@
 	//generate the legend---------------------------------------------
-	// gesamth�he Legende / height of the legend
+	// Gesamthoehe Legende / height of the legend
 	$sum_legend_height = 0;
@@ -643,7 +605,7 @@
 			$wms_y_position = $pdf->ezText("<b>".$my_wms_title[$i]."</b>", 12, array('spacing'=>1.2));
 			$wms_zeilenhoehe   =  $pdf->getFontHeight(12);
-			// add this to the height of the legend /addiere dies zur Gesamth�he Legende
+			// add this to the height of the legend /addiere dies zur Gesamthoehe Legende
 			$sum_legend_height += $wms_zeilenhoehe;
 			//Layer
@@ -663,10 +625,10 @@
 					}elseif($temp_url[$q] != '0' ){
 						$funktionsaufruf = new SaveLegend($temp_url[$q],$legendFilename);
 						$imgsize = getimagesize($legendFilename);
-						// add this to the height of the legend /addiere dies zur Gesamth�he der Legende
+						// add this to the height of the legend /addiere dies zur Gesamthoehe der Legende
 						$sum_legend_height += $imgsize[1];
-						//calculate text + picture / Berechnung Gr��e Schrift + Bild
+						//calculate text + picture / Berechnung Groesse Schrift + Bild
 						if($l == 0){
 						       $y_position = $wms_y_position;
 						       $wms_y_position = '';
@@ -682,7 +644,7 @@
 						$l = $l+1;
 		     			// if text + picture are smaler then the lower margin + textsize, then set a space
-						//wenn Schrift + Bild kleiner der unteren Margin + Zeilenh�he, dann Abstand setzen
+						//wenn Schrift + Bild kleiner der unteren Margin + Zeilenhoehe, dann Abstand setzen
 						 if($size == "A4" && $format == "portrait" && $next_position <= 35 +$layer_zeilenhoehe){ //90 $layer_zeilenhoehe
 							$space = $layer_zeilenhoehe + $imgsize[1];
 						  $pdf->ezSetDy(-$space);
@@ -692,7 +654,7 @@
-						//write the header layername / �berschrift schreiben
+						//write the header layername / Ueberschrift schreiben
 						$legend = $temp_layers[$q]."\n";  //$layer[$j]."\n";
 						$pdf->ezText($legend, 11, array('spacing'=>1.2));
@@ -715,7 +677,12 @@
 					//top
 					//bottom
+					$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
+					if ($legendImage!=''){
+						//image on top of page
+						$pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border + $header_height - $legendImage_height - 4 , $legendImage_width, $legendImage_height);
 				} else {
 				  //left
@@ -726,6 +693,13 @@
 				   //bottom
+						$pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border - $legendImage_height -4 , $legendImage_width, $legendImage_height);
+						//line under legend (only landscape)
+						//$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border  - $legendImage_height - 4 , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 6);
 			}// for layers
 		} //if wms_id not 0
More information about the Mapbender_commits mailing list
