[Mapbender-commits] r1789 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Nov 9 07:16:58 EST 2007
Author: christoph
Date: 2007-11-09 07:16:54 -0500 (Fri, 09 Nov 2007)
New Revision: 1789
Added:
   trunk/mapbender/http/php/mod_featuretypeMetadata.php
new wfs metadata module
Added: trunk/mapbender/http/php/mod_featuretypeMetadata.php
--- trunk/mapbender/http/php/mod_featuretypeMetadata.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_featuretypeMetadata.php	2007-11-09 12:16:54 UTC (rev 1789)
@@ -0,0 +1,138 @@
+<?php
+# $Id: mod_featuretypeMetadata.php 235 2007-09-20 verenadiewald $
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once("../../conf/mapbender.conf");
+require_once("../../conf/geoportal.conf");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+function display_text($string) {
+    $string = eregi_replace("[[:alpha:]]+://[^<>[:space:]]+[[:alnum:]/]", "<a href=\"\\0\" target=_blank>\\0</a>", $string);
+    $string = eregi_replace("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@([0-9a-z](-?[0-9a-z])*\.)+[a-z]{2}([zmuvtg]|fo|me)?$", "<a href=\"mailto:\\0\" target=_blank>\\0</a>", $string);
+    $string = eregi_replace("\n", "<br>", $string);
+    return $string;
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="de">
+	<head>
+		<title>WFS Metadata</title>
+		<meta name="description" content="Metadata" xml:lang="en" />
+		<meta name="keywords" content="Metadaten" xml:lang="en" />
+		<meta http-equiv="cache-control" content="no-cache">
+		<meta http-equiv="pragma" content="no-cache">
+		<meta http-equiv="expires" content="0">
+		<meta http-equiv="content-language" content="de" />
+		<meta http-equiv="content-style-type" content="text/css" />
+<?php
+	echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+	</head>
+	<body id="top">
+	<div>
+<?php
+	$wfs_conf_id = $_GET['wfs_conf_id'];
+	//for testing only
+	#$wfs_conf_id = 1;
+	$sql_id = "SELECT fkey_wfs_id, fkey_featuretype_id FROM wfs_conf WHERE wfs_conf_id = $1";
+	$v_id = array($wfs_conf_id);
+	$t_id = array('i');
+	$res_id = db_prep_query($sql_id,$v_id,$t_id);
+	$row_id = db_fetch_array($res_id);
+	$wfs_id = $row_id['fkey_wfs_id'];
+	$featuretype_id = $row_id['fkey_featuretype_id'];
+	// retrieve the geometry type
+	$sql_geom = "SELECT a.element_type AS geom_type ";
+	$sql_geom .= "FROM wfs_element AS a, wfs_conf AS b, wfs_conf_element AS c ";
+	$sql_geom .= "WHERE a.fkey_featuretype_id = b.fkey_featuretype_id AND b.wfs_conf_id = $1 ";
+	$sql_geom .= "AND b.wfs_conf_id = c.fkey_wfs_conf_id AND c.f_geom = 1 AND c.f_id = a.element_id";
+	$v_geom = array($wfs_conf_id);
+	$t_geom = array('i');
+	$res_geom = db_prep_query($sql_geom, $v_geom, $t_geom);
+	$row_geom = db_fetch_array($res_geom);
+	$geomType = $row_geom['geom_type'];
+	$sql = "SELECT ";
+	$sql .= "ft.featuretype_id, ft.featuretype_title, ft.featuretype_srs, ft.featuretype_abstract, ";
+	$sql .= "wfs.wfs_title, wfs.wfs_abstract, wfs.wfs_id, wfs.fees, wfs.accessconstraints, wfs.individualname, ";
+	$sql .= "wfs.positionname, wfs.providername, wfs.deliverypoint, wfs.city, wfs.wfs_timestamp, wfs.wfs_owner, ";
+	$sql .= "wfs.country, wfs.postalcode, wfs.voice, wfs.facsimile, ";
+	$sql .= "wfs.electronicmailaddress, wfs.wfs_getcapabilities ";
+	$sql .= "FROM wfs, wfs_featuretype ft WHERE wfs.wfs_id = $1 AND ft.featuretype_id = $2 AND wfs.wfs_id = ft.fkey_wfs_id LIMIT 1";
+	$v = array($wfs_id,$featuretype_id);
+	$t = array('i','i');
+	$res = db_prep_query($sql,$v,$t);
+	echo db_error();
+	$wfs = array();
+	$row = db_fetch_array($res);
+	$sql_dep = "SELECT mb_group_name FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1  AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND b.mb_user_department = a.mb_group_description LIMIT 1";
+	$v_dep = array($row['wfs_owner']);
+	$t_dep = array('i');
+	$res_dep = db_prep_query($sql_dep, $v_dep, $t_dep);
+	$row_dep = db_fetch_array($res_dep);
+	$featuretype['ID'] = $featuretype_id;
+	$featuretype['Titel'] = $row['featuretype_title'];
+	$featuretype['Zusammenfassung'] = $row['featuretype_abstract'];
+	$featuretype['Koordinatensysteme'] = $row['featuretype_srs'];
+	$featuretype['Geometrietyp'] = $geomType;
+	$featuretype['Capabilities-Dokument'] = $row['wfs_getcapabilities'];
+	#$featuretype['Capabilities-Dokument'] = "<a href='".$row['wfs_getcapabilities']."' target=_blank>Capabilities-Dokument</a>";
+	if ($row['wfs_timestamp']) {
+		$layer['Datum der Registrierung'] = date("d.m.Y",$row['wfs_timestamp']);
+	else {
+		$layer['Datum der Registrierung'] = "Keine Angabe";
+	$featuretype['Registrierende Stelle'] = $row_dep['mb_group_name'];
+	$featuretype['WFS ID'] = $row['wfs_id'];
+	$featuretype['WFS Titel'] = $row['wfs_title'];
+	$featuretype['WFS Zusammenfassung'] = $row['wfs_abstract'];
+	$featuretype['Geb&uuml;hren'] = $row['fees'];
+	$featuretype['Zugriffsbeschr&auml;nkung'] = $row['accessconstraints'];
+	$featuretype['Ansprechpartner'] = $row['individualname'];
+	$featuretype['Organisation'] = $row['providername'];
+	$featuretype['Adresse'] = $row['deliverypoint'];
+	$featuretype['Stadt'] = $row['city'];
+	$featuretype['PLZ'] = $row['postalcode'];
+	$featuretype['Telefon'] = $row['voice'];
+	$featuretype['Fax'] = $row['facsimile'];
+	$featuretype['E-Mail'] = $row['electronicmailaddress'];
+	$featuretype['Land'] = $row['country'];
+	echo "<table class='contenttable-0-wide'>\n";
+	$t_a = "\t<tr>\n\t\t<th>\n\t\t\t";
+	$t_b = "\n\t\t</th>\n\t\t<td>\n\t\t\t";
+	$t_c = "\n\t\t</td>\n\t</tr>\n";
+	$keys = array_keys($featuretype);
+	for ($j=0; $j<count($featuretype); $j++) {
+		echo $t_a . utf8_encode($keys[$j]) . $t_b . display_text($featuretype[$keys[$j]]) . $t_c;
+	echo "</td></tr></table>\n";
+	</div>
+	</body>
+</html>
More information about the Mapbender_commits mailing list
