[Mapbender-commits] r1790 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Nov 9 07:20:45 EST 2007
Author: christoph
Date: 2007-11-09 07:20:40 -0500 (Fri, 09 Nov 2007)
New Revision: 1790
Added:
   trunk/mapbender/http/classes/class_metadata.php
new wfs metadata module
Added: trunk/mapbender/http/classes/class_metadata.php
--- trunk/mapbender/http/classes/class_metadata.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_metadata.php	2007-11-09 12:20:40 UTC (rev 1790)
@@ -0,0 +1,1465 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/class_administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+#require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/class_administration.php");
+require_once(dirname(__FILE__)."/class_mb_exception.php");
+include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+ * class to handle keywords for services
+class class_metadata{
+	private $user_id;
+	private $departments = array();
+	private $categories = array();
+	private $searchtext;
+	private $timestamp_beg;
+	private $timestamp_end;
+	private $limit;
+	private $search_bbox = array();
+	private $search_epsg;
+	private $obj_members = array();
+	private $availabilityTime;
+	private $doc;
+	 * Constructor of the class_metadata-class
+	 * @$user_id 		integer 	users ID
+	 * @$departments 	array 		departments
+	 * @$categories 	array 		categories
+	 * @$searchtext 	string 		searchtext (with blanks => more searchwords)
+	 * @$timestamp_beg 	integer		Timebegin of the Search in TIMESTAMP-Format
+	 * @$timestamp_end 	integer		Timeend of the Search in TIMESTAMP-Format
+	 * @$limit			integer		Limit of the whole Result of the Metadata Search
+	 * @$search_bbox	array		BoundingBox
+	 * @$search_epsg	string		EPSG like: "EPSG:4326"
+	 function logit($text){
+	 	if($h = fopen("/data/mapbender/http/tmp/gregor.txt","a")){
+					$content = $text .chr(13).chr(10);
+					if(!fwrite($h,$content)){
+						#exit;
+					fclose($h);
+	function __construct($user_id, $departments, $categories, $searchtext, $timestamp_beg, $timestamp_end, $limit, $search_bbox, $search_epsg){
+		$this->user_id = $user_id;
+		$this->departments = $departments;
+		$this->categories = $categories;
+		$this->searchtext = $searchtext;
+		$this->timestamp_beg = $timestamp_beg;
+		$this->timestamp_end = $timestamp_end;
+		$this->limit = $limit;
+		$this->search_bbox = $search_bbox;
+		$this->search_epsg = $search_epsg;
+		$this->availabilityTime = 60*60*24*90;	// sec*min*hour*days
+//		$e = new mb_notice("Search extended => user_id: ".$this->user_id."");
+//		$e = new mb_notice("Search extended => searchtext: ".$this->searchtext."");
+//		$e = new mb_notice("Search extended => timestamp_beg: ".$this->timestamp_beg."");
+//		$e = new mb_notice("Search extended => timestamp_end: ".$this->timestamp_end."");
+//		$e = new mb_notice("Search extended => limit: ".$this->limit."");
+//		$e = new mb_notice("Search extended => search_epsg: ".$this->search_epsg."");
+//		$e = new mb_notice("Search extended => count departments: ".count($this->departments)."");
+//		$e = new mb_notice("Search extended => count categories: ".count($this->categories)."");
+//		$e = new mb_notice("Search extended => count search_bbox: ".count($this->search_bbox)."");
+//		echo "Search extended => user_id: ".$this->user_id."<br>";
+//		echo "Search extended => searchtext: ".$this->searchtext."<br>";
+//		echo "Search extended => timestamp_beg: ".$this->timestamp_beg."<br>";
+//		echo "Search extended => timestamp_end: ".$this->timestamp_end."<br>";
+//		echo "Search extended => limit: ".$this->limit."<br>";
+//		echo "Search extended => search_epsg: ".$this->search_epsg."<br>";
+//		echo "Search extended => count search_bbox: ".count($this->search_bbox)."<br>";
+//		echo "Search extended => count departments: ".count($this->departments)."<br>";
+//		echo "Search extended => count categories: ".count($this->categories)."<br>";
+//		echo "Search extended => count departments: ".$this->departments[0]."<br>";
+//		echo "Search extended => count categories: ".$this->categories[0]."<br>";
+//		echo "Search extended => count search_bbox: ".$this->search_bbox[0]."<br>";
+		$this->logit("searchtext: ".$this->searchtext);
+		$this->logit("count categories: ".count($this->categories));
+		$this->logit("count departments: ".count($this->departments));
+		$this->logit("count search_bbox: ".count($this->search_bbox));
+		$cat_id="";
+		for ($index = 0; $index < sizeof($this->categories); $index++) {
+			$array_element = $this->categories[$index];
+			$cat_id .= $array_element.", ";
+		$this->isOverLimit;
+		$this->anz_wms=0;
+		$this->anz_wfs=0;
+		$cat = array();
+		$this->cat = $cat;
+		$this->user_authorization();
+		$this->set_categories();
+		$this->doc = new DOMDocument('1.0');
+		$this->generate_xml_output();
+	 * user authorization
+	function user_authorization(){
+		$n = new administration();
+		$this->n = $n;
+		$myguis = $this->n->getGuisByPermission($this->user_id,true);
+		$mywms = $this->n->getWmsByOwnGuis($myguis);
+		$myWFSconfs = $this->n->getWfsConfByPermission($this->user_id);
+		$this->myWFSConfs = $myWFSconfs;
+		for ($index = 0; $index < sizeof($this->myWFSConfs); $index++) {
+			$array_element = $this->myWFSConfs[$index];
+//			 echo $index."wfs_conf_id: ".$array_element."<br>";
+		$mylayer = array();
+		$this->mylayer = $mylayer;
+		if($mywms == false){
+			$mywms = array();
+	/* set categories as array */
+		function set_categories(){
+			$sql = "SELECT * FROM md_topic_category ";
+			$sql .= " ORDER BY md_topic_category_id";
+			$res = db_query($sql);
+			$this->cat[0] = array();
+			$this->cat[0]['md_topic_category_code_de'] = '';
+			$this->cat[0]['member'] = array();
+			$cnt = 1;
+			while($row = db_fetch_array($res)){
+				$this->cat[$cnt] = array();
+				$this->cat[$cnt]['md_topic_category_code_de'] = $row['md_topic_category_code_de'];
+				$this->cat[$cnt]['member'] = array();
+				$cnt++;
+//				echo " => ".$row['md_topic_category_code_de'];
+//				echo " => ".$row['md_topic_category_id']."<br>";
+			$cat_de="";
+			for ($index = 0; $index < sizeof($this->cat); $index++) {
+				$array_element = $this->cat[$index];
+				$cat_de .= "'".$this->cat[$index]['md_topic_category_code_de']."', ";
+//			$this->logit("set cat => count categories in [][]: ".count($this->cat));
+//			$this->logit("set cat => categories: ".$cat_de);
+	 * replace german letters (for example ä => ae)
+	function replaceChars($text){
+	$search = array( "ä",  "ö",  "ü",  "Ä",  "Ö",  "Ü",  "ß");
+	$repwith = array("ae", "oe", "ue", "AE", "OE", "UE", "ss");
+	if(CHARSET=="UTF-8")
+		$text = utf8_decode($text);
+	$ret = str_replace($search, $repwith, $text);
+		$ret = utf8_encode($ret);
+	return $ret;
+	function replaceString($string , $replaceString, $newString){
+		$newstr = str_replace($string, $replaceString, $newString);
+		return $newstr;
+	function generate_xml_output(){
+		$this->writeXmlhead();
+		$this->writeXmlWMSPart();
+		$this->writeXmlWFSPart();
+		$this->writeXmlEnd();
+	function writeXmlhead(){
+		$this->doc->encoding = CHARSET;
+		$result = $this->doc->createElement("result");
+		$this->doc->appendChild($result);
+		//Trefferanzahl
+		$overLimit = $this->doc->createElement('overLimit');
+		$result->appendChild($overLimit);
+		$tr_text = $this->doc->createTextNode($this->isOverLimit);
+		$overLimit->appendChild($tr_text);
+		$rd = $this->doc->createElement("redirect");
+		$result->appendChild($rd);
+		$trd = $this->doc->createTextNode("muss noch...");
+		$rd->appendChild($trd);
+	function writeXmlEnd(){
+		$overLimitText = $this->doc->createTextNode($this->isOverLimit);
+		$overLimits = $this->doc->getElementsByTagName("overLimit");
+		foreach ($overLimits as $overLimit) {
+			$overLimit->appendChild($overLimitText);
+		$ready = $this->doc->createElement('ready');
+		$tready = $this->doc->createTextNode("true");
+		$ready->appendChild($tready);
+		$results = $this->doc->getElementsByTagName("result");
+				foreach ($results as $result) {
+				$result->appendChild($ready);
+		echo $this->doc->saveXML();	// Ausgabe
+		$e = new mb_notice("Wrote the XML-File");
+	 * generats categories with members in the xml-File
+	function writeXmlWMSPart(){
+		$asstr = array();
+		if ($this->searchtext!="false"){
+			$asstr = split(" ",$this->searchtext);
+		$isTextSearch = "false";
+		for ($index = 0; $index < count($asstr); $index++) {
+			$array_element = $asstr[$index];
+			$e = new mb_notice("Search-Text: ".$index.".  ".$array_element."");
+		$v = array();
+		$t = array();
+		$sql = "SELECT DISTINCT * from service_metadata where ";
+		for($i=0; $i<count($asstr); $i++){
+			$isTextSearch = "true";
+			if($i>0){$sql .= " AND ";}
+			$sql .= "searchtext LIKE $".($i+1);
+			$va = "%".trim(strtoupper($this->replaceChars($asstr[$i])))."%";
+			array_push($v,$va);
+			array_push($t,"s");
+		$whereBedArray = array();
+		//layer_searchable condition
+		array_push($whereBedArray, "(layer_searchable = 1)");
+		//date condition
+		if ($this->timestamp_beg!="false" && $this->timestamp_end!="false"){
+			$time ="(wms_timestamp BETWEEN ".$this->timestamp_beg." AND ".$this->timestamp_end.")";
+			array_push($whereBedArray, $time);
+		} else if ($this->timestamp_beg!="false" && $this->timestamp_end=="false"){
+			$time ="(wms_timestamp > ".$this->timestamp_beg.")";
+		} else if ($this->timestamp_beg=="false" && $this->timestamp_end!="false"){
+			$time ="(wms_timestamp < ".$this->timestamp_end.")";
+		//department condition
+		if(count($this->departments)>0){
+			$txt = $this->getDepartmentBed("wms_owner", "mb_user_department", $this->departments, "OR");
+			$dep = " (". $txt . ") ";
+			array_push($whereBedArray, $dep);
+//		//Testausgabe
+//		for ($index = 0; $index < sizeof($this->whereBedArray); $index++) {
+//			$array_element = $this->whereBedArray[$index];
+//			echo $index." el: ".$array_element."<br>";
+		//Creating the Where Clausel, based on a Array
+		if(count($whereBedArray)>0){
+			$txt_whereBed="";
+			for ($index = 0; $index < sizeof($whereBedArray); $index++) {
+			$array_element = $whereBedArray[$index];
+				if($isTextSearch=="true") {
+					$txt_whereBed .=" AND ".$array_element;
+				} else {
+					if($index>0){
+					} else {
+						$txt_whereBed .=" ".$array_element;
+			$sql .= $txt_whereBed;
+		//order by
+		$sql .= " ORDER BY load_count DESC";
+		//Beschränkung
+		$lim = $this->limit;
+		$overLimit = $lim+1;
+		$sql .= " LIMIT ".$overLimit;
+		for ($index = 0; $index < sizeof($asstr); $index++) {
+			$this->logit($index.".Suchwort : ".$array_element);
+		$this->logit("SQL_WMS: ".$sql);
+		$e = new mb_notice("Search extended => SQL-Request of view service_metadata: ".$sql."");
+		$res = db_prep_query($sql, $v, $t);
+		//	spatial search
+//		for ($index = 0; $index < sizeof($this->cat); $index++) {
+//		$array_element = $this->cat[$index];
+//		$this->logit("0. vor Kategorieeinordnung => Kategorie: ".$this->cat[$index]['md_topic_category_code_de'].", Anzahl Member: ".count($this->cat[$index]['member']));
+		if(count($this->search_bbox)>0){
+		$anz = 0;
+			$resultColumns = array();
+			$resultColumns = $this->generateNewReaArray($res);
+			$e = new mb_notice("count service_metadata: ".count($resultColumns)."");
+			for ($index = 0; $index < count($resultColumns); $index++) {
+				$row = $resultColumns[$index];
+				if ($this->n->getLayerPermission($row['wms_id'], $row['layer_name'], $this->user_id)) {
+					array_push($this->mylayer,$row['layer_id']);
+				//accessconstraints -> email subadmin
+//				$sql_ac = "SELECT mb_user_email FROM mb_user WHERE mb_user_id = $1";
+//				$v = array($row["wms_owner"]);
+//				$t = array('i');
+//				$res_ac = db_prep_query($sql_ac, $v, $t);
+//				if($row_ac = db_fetch_array($res_ac)){
+//					$row["accessconstraints"] = $row_ac["mb_user_email"];
+				$ns = $this->make_members($row);
+				$anz++;
+			$e = new mb_notice("count service_metadata(spatial-search): ".$anz."");
+			$this->logit("ANZ_WMS mit bbox: ".$anz);
+		} else {
+		$anz = 0;
+//				if ($row_ac = db_fetch_array($res_ac)){
+				$anz++;
+		$e = new mb_notice("count service_metadata(no spatial-search): ".$anz."");
+		$this->logit("ANZ_WMS ohne bbox: ".$anz);
+//		$this->logit("1.nach Kategorieeinordnung => Kategorie: ".$this->cat[$index]['md_topic_category_code_de'].", Anzahl Member: ".count($this->cat[$index]['member']));
+		if ($this->limit < $anz ){
+			$this->isOverLimit="true";
+		} else {
+			$this->isOverLimit="false";
+		$ns = $this->make_xml();
+	 *  fills an array[][] with members based on categories
+	function make_members($r){
+//		$sql = "SELECT fkey_md_topic_category_id FROM layer_md_topic_category WHERE fkey_layer_id = $1";
+		$sql = "SELECT fkey_md_topic_category_id, md_topic_category_code_de, fkey_layer_id " .
+		"FROM layer_md_topic_category, md_topic_category " .
+		"WHERE layer_md_topic_category.fkey_md_topic_category_id = md_topic_category.md_topic_category_id " .
+		"AND fkey_layer_id = $1";
+		$sql .= " ORDER BY fkey_md_topic_category_id";
+		$v = array($r['layer_id']);
+		$t = array('i');
+		$c = 0;
+		//layer with category
+			if (count($this->categories)>0){
+				if (in_array($row['fkey_md_topic_category_id'], $this->categories) ){
+					$this->cat[$row['fkey_md_topic_category_id']]['member'][count($this->cat[$row['fkey_md_topic_category_id']]['member'])] = $r;
+			} else {
+//			$this->cat[$row['fkey_md_topic_category_id']]['member'][count($this->cat[$row['fkey_md_topic_category_id']]['member'])] = $r;
+//			$catID = $row['fkey_md_topic_category_id'];
+//			array_push($this->cat[$catID]['member'],$r);
+			$c++;
+		// no category for this layer
+		if($c == 0){
+			array_push($this->cat[0]['member'],$r);
+		return true;
+	 * generats the xml-document
+	function make_xml(){
+//		echo "Kategorie: ".$this->cat[$index]['md_topic_category_code_de'].", Anzahl Member: ".count($this->cat[$index]['member'])."<br>";
+	$i=0;
+	if (count($this->categories) == 0){		// Wenn eine Kategorieauswahl werde WMSe/Layer die keiner Kategorie zugeordnet sind nicht angezeigt
+		$i=0;
+	} else {
+		$i=1;
+	for($i; $i<count($this->cat); $i++){
+		if(count($this->cat[$i]['member'])>0){
+			$c = $this->doc->createElement("category");
+			$result->appendChild($c);
+			$c->setAttribute('name',$this->cat[$i]['md_topic_category_code_de']);
+			$c->setAttribute('count',count($this->cat[$i]['member']));
+			$this->logit("IM XML-Aufbau: category: ".$this->cat[$i]['md_topic_category_code_de'].", Anzahl: ".count($this->cat[$i]['member']));
+			for($ii=0; $ii<count($this->cat[$i]['member']); $ii++){
+// 					Schachtelung Start
+					$m = $this->doc->createElement('member');
+					$m->setAttribute('wms_id',$this->cat[$i]['member'][$ii]['wms_id']);			// Attribut muss gesetzt werden um es wieder zu finden
+					$m->setAttribute('layer_pos',$this->cat[$i]['member'][$ii]['layer_pos']);	// Attribut muss gesetzt werden um es wieder zu finden
+//					$m->setAttribute('layer_parent',$this->cat[$i]['member'][$ii]['layer_parent']);
+					if ($ii != 0){
+						$members = $c->getElementsByTagName('member');
+						$sub = "false";
+						$mem = null;
+						foreach ($members as $member) {
+							$tmp_wms_id = $member -> getAttribute('wms_id');
+							$tmp_layer_pos = $member -> getAttribute('layer_pos');
+						     * Wiederfinden des Members über die Attribute
+							if ($this->cat[$i]['member'][$ii]['wms_id'] == $tmp_wms_id){
+								if ($this->cat[$i]['member'][$ii]['layer_parent'] == $tmp_layer_pos){
+									$sub = "true";
+									$member->appendChild($m);	// dem member $member wird ein weiteres member $m hinzugefügt
+									break;
+								} else {
+									$sub = "false";
+						if ($sub == "true"){
+										     // member konnte schon in der foreach-schleife eingefuegt werden
+						} else {
+						$c->appendChild($m); // member kategorie 1	(anderer WMS)
+					} else {
+						$c->appendChild($m);	 // member kategorie 1 (erstes member)
+// 				Schachtelung Ende
+				// LayerName
+				$state = $this->doc->createElement('layername');
+				$m->appendChild($state);
+				$name = "";
+				$layname = $this->cat[$i]['member'][$ii]['layer_name'];
+				if ($layname == "NULL" || $layname == "") {
+					$name = "";
+				} else {
+					$name = $layname;
+				$lay_name_text = $this->doc->createTextNode($name);
+				$state->appendChild($lay_name_text);
+				//Abfragbarkeit
+				$queryable = $this->doc->createElement('queryable');
+				$m->appendChild($queryable);
+				if ($this->cat[$i]['member'][$ii]['layer_queryable']==1){
+					$lay_queryable = "true";
+				} else {
+					$lay_queryable = "false";
+				$abf_text = $this->doc->createTextNode($lay_queryable);
+				$queryable->appendChild($abf_text);
+				// Epsg
+				$epsg = $this->doc->createElement('epsg');
+				$m->appendChild($epsg);
+				$equalEPSG = $this->checkEPSG($this->cat[$i]['member'][$ii]['wms_id']);
+				$epsg_text = $this->doc->createTextNode($equalEPSG);
+				$epsg->appendChild($epsg_text);
+				// Länderkennung
+				$state = $this->doc->createElement('federalstate');
+				$spatialSource = "";
+				$stateorprovince = $this->cat[$i]['member'][$ii]['stateorprovince'];
+				if ($stateorprovince == "NULL" || $stateorprovince == "") {
+					$spatialSource = $this->cat[$i]['member'][$ii]['country'];
+				} else {
+					$spatialSource = $this->cat[$i]['member'][$ii]['stateorprovince'];
+				$countr_code_text = $this->doc->createTextNode($spatialSource);
+				$state->appendChild($countr_code_text);
+				// Satus des letzten Monitorings
+				$last_monitoring = $this->doc->createElement('last_monitoring');
+				$m->appendChild($last_monitoring);
+				$lastMonitoring = $this->getLastMonitoringDate($this->cat[$i]['member'][$ii]['wms_id']);
+				$last_monitoring_text = $this->doc->createTextNode($lastMonitoring);
+				$last_monitoring->appendChild($last_monitoring_text);
+				// Verfügbarkeit - Prozentzahl
+				$availability = $this->doc->createElement('availability');
+				$m->appendChild($availability);
+				$availabilityPercent = $this->getWMSavailability($this->cat[$i]['member'][$ii]['wms_id'], $this->availabilityTime);
+				$availability_text = $this->doc->createTextNode($availabilityPercent);
+				$availability->appendChild($availability_text);
+				// Relevanz / Count
+				$relevance = $this->doc->createElement('relevance');
+				$m->appendChild($relevance);
+				$lay_count=0;
+				if($this->cat[$i]['member'][$ii]['load_count'] != null){
+				$lay_count=$this->cat[$i]['member'][$ii]['load_count'];
+				$relevance_text = $this->doc->createTextNode($lay_count);
+				$relevance->appendChild($relevance_text);
+				//type
+				$type = $this->doc->createElement('type');
+				$m->appendChild($type);
+				if($this->cat[$i]['member'][$ii]['layer_pos'] > 0){
+					$ttype = $this->doc->createTextNode("layer");
+				else{
+					$ttype = $this->doc->createTextNode("wms");
+				$type->appendChild($ttype);
+				//wms_id
+				$wms__id = $this->doc->createElement('wms_id');
+				$m->appendChild($wms__id);
+				$id_text = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['wms_id']);
+				$wms__id->appendChild($id_text);
+				//layer_id
+				$id = $this->doc->createElement('id');
+				$m->appendChild($id);
+				$tid = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['layer_id']);
+				$id->appendChild($tid);
+				//title
+				$title = $this->doc->createElement('title');
+				$m->appendChild($title);
+				$ttitle = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['layer_title']);
+				$title->appendChild($ttitle);
+				//abstract
+				$abst = $this->doc->createElement('abstract');
+				$m->appendChild($abst);
+				$tabst = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['layer_abstract']);
+				$abst->appendChild($tabst);
+				// accesscontraints
+				$ac = $this->doc->createElement('accessconstraints');
+				$m->appendChild($ac);
+				$myac = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['accessconstraints']);
+				$ac->appendChild($myac);
+				//data
+				$date = $this->doc->createElement('date');
+				$m->appendChild($date);
+				$tdate = $this->doc->createTextNode(date("d.m.Y",$this->cat[$i]['member'][$ii]['wms_timestamp']));
+				$date->appendChild($tdate);
+				//department
+				$dm = $this->doc->createElement('department');
+				$m->appendChild($dm);
+				$tdm = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['mb_group_name']);
+				$dm->appendChild($tdm);
+				//permission // Leseberechtigung des Benutzers(true), sonst Email zur Beantragung(email)
+				$per = $this->doc->createElement('permission');
+				$m->appendChild($per);
+				$per_text = $this->getPermissionValue( $this->cat[$i]['member'][$ii]['wms_id'], $this->cat[$i]['member'][$ii]['layer_id']);
+				$pe =  $this->doc->createTextNode($per_text);
+				$per->appendChild($pe);
+				// termsofuse
+				$ter = $this->doc->createElement('termsofuse');
+				$m->appendChild($ter);
+				$myter_text = $this->getTermOfUse($this->cat[$i]['member'][$ii]['wms_id']);
+				$myter =  $this->doc->createTextNode($myter_text);
+				$ter->appendChild($myter);
+//				$this->logit("Ende member: ".$ii);
+//				echo "ende member: ".$ii."<br>";
+	function writeXmlWFSPart(){
+//		$asstr = split(" ",$this->searchtext);
+		$asstr = array();
+		$v = array();
+		$t = array();
+		$sql = "SELECT DISTINCT * from wfs_service_metadata where ";
+		$isTextSearch="false";
+		//textsearch
+			$isTextSearch="true";
+		//date condition
+			$time ="(wfs_timestamp BETWEEN ".$this->timestamp_beg." AND ".$this->timestamp_end.")";
+			$time ="(wfs_timestamp > ".$this->timestamp_beg.")";
+			$time ="(wfs_timestamp < ".$this->timestamp_end.")";
+				$txt = $this->getDepartmentBed("wfs_owner", "mb_user_department", $this->departments, "OR");
+		//featuretype_searchable condition
+			array_push($whereBedArray, "(featuretype_searchable = 1)");
+		// Creating the Where Clausel, based on a Array
+				$txt_whereBed="";
+					} else {
+						if($index>0){
+						} else {
+//				$txt_whereBed .=" AND ".$array_element;
+			//order by
+			$sql .= " ORDER BY featuretype_id ";
+//			echo "WFS-SQL:<br>".$sql."<br>";
+			$this->logit("WFS_SQL: ".$sql);
+				$c->setAttribute('name', "Geometriedienste");
+				$c->setAttribute('count', "0");
+			$i = 0;
+			$m->setAttribute('wfs_id', $row['wfs_id']);
+			$m->setAttribute('layer_pos', "");
+			//Abfragbarkeit
+			if ($row['featuretype_searchable'] == "1"){
+			} else {
+			$search_text = $this->doc->createTextNode($lay_queryable);
+			$queryable->appendChild($search_text);
+			// Epsg
+			$equalEPSG = $row['featuretype_srs'];
+			// Länderkennung
+			$stateorprovince = $row['administrativearea'];
+				$spatialSource = $row['country'];
+			} else {
+				$spatialSource = $row['administrativearea'];
+			//type
+			$ttype = $this->doc->createTextNode("wfs");
+//			// FeaturetypeName
+//			$state = $this->doc->createElement('name');
+//			$m->appendChild($state);
+//			$name = "";
+//			$stateorprovince = $row['featuretype_name'];
+//			if ($stateorprovince == "NULL" || $stateorprovince == "") {
+////				$name = $row[''];
+//			} else {
+//				$name = $row['featuretype_name'];
+//			$countr_code_text = $this->doc->createTextNode($name);
+//			$state->appendChild($countr_code_text);
+			//id
+			$id = $this->doc->createElement('featuretype_id');
+			$tid = $this->doc->createTextNode($row['featuretype_id']);
+			//wfs_conf_id
+			$conf_id = $this->doc->createElement('wfs_conf_id');
+			$m->appendChild($conf_id);
+			$c_id = $this->doc->createTextNode($row['wfs_conf_id']);
+			$conf_id->appendChild($c_id);
+			//title
+			$ttitle = $this->doc->createTextNode($row['wfs_conf_abstract']);
+			//title
+			//abstract
+			$tabst = $this->doc->createTextNode($row['wfs_conf_description']);
+			// Geomtype
+			$geo = $this->doc->createElement('geomtype');
+			$m->appendChild($geo);
+			$geo_text = $this->getGeoType($row['wfs_id'], $row['featuretype_id']);
+			$ge =  $this->doc->createTextNode($geo_text);
+			$geo->appendChild($ge);
+//				$myac = $this->getAccessConstraints($this->cat[$i]['member'][$ii]['wms_id'], $this->cat[$i]['member'][$ii]['accessconstraints'], $this->cat[$i]['member'][$ii]['layer_id']);
+			$myac = $this->doc->createTextNode($row['accessconstraints']);
+			//data
+			$tdate = $this->doc->createTextNode(date("d.m.Y",$row['wfs_timestamp']));
+			//department
+			$tdm = $this->doc->createTextNode($row['mb_group_name']);
+			//permission  		 Leseberechtigung des Benutzers(true), sonst Email zur Beantragung(email)
+			$per_text = $this->getPermissionValueForWFS($row['wfs_id'], $row['wfs_conf_id']);
+//			// termsofuse
+//			$ter = $this->doc->createElement('termsofuse');
+//			$m->appendChild($ter);
+////			$myter = $this->getAccessConstraints($this->cat[$i]['member'][$ii]['wms_id'], $this->cat[$i]['member'][$ii]['accessconstraints'], $this->cat[$i]['member'][$ii]['layer_id']);
+//			$myter_text = "";
+//			$myter =  $this->doc->createTextNode($myter_text);
+//			$ter->appendChild($myter);
+			$i++;
+		$c->setAttribute('count', $i);
+		$this->anz_wfs = $i;
+	function getLastMonitoringDate($wms_id){
+	$sql = "SELECT max(upload_id) as last_time, status FROM mb_monitor WHERE fkey_wms_id=$1 GROUP BY (status)";
+	$v = array($wms_id);
+	$t = array('i');
+	$c = 0;
+	$status = "";
+		$status = $row['status'];
+		$c++;
+		return $status;
+	 * Returns the availability of a WMS/Layer during a period of time
+	 * in percent
+	function getWMSavailability ($wms_id, $time_period){
+		$timestamp = time();
+		$datum = date("d.m.Y - H:i", $timestamp);
+		$last_timestamp = $timestamp - $time_period;
+		$last_date = date("d.m.Y - H:i", $last_timestamp);
+//		Vorrübergehend auskommentiert da keine aktuellen (auf Timestamp basierten) Daten vorliegen
+//		$sql = "SELECT upload_id as time, status FROM mb_monitor WHERE fkey_wms_id=$1 AND upload_id > ".$last_timestamp;
+		$sql = "SELECT upload_id as time, status FROM mb_monitor WHERE fkey_wms_id=$1";
+		$t = array('i');
+		$c = 0;
+		$positivStatus=0;
+			if ($row['status'] == "1" || $row['status'] == "0"){
+				$positivStatus++;
+			$c++;
+		$percent=0;
+		if ($c!=0){
+			$percent = ($positivStatus*100) / $c;
+		} else {
+			$percent = 0;
+		return number_format($percent,0, ",", ".") ;
+	function checkEPSG ($wms_id){
+	$sql = "SELECT wms.wms_id, wms_srs.wms_srs FROM wms, wms_srs where wms.wms_id=fkey_wms_id and wms.wms_id=$1";
+	$t = array('i');
+	$c = 0;
+	$isequal = "false";
+		$wms_epsg = $row['wms_srs.wms_srs'];
+		$c++;
+		if ($wms_epsg==$this->epsg){
+			$isequal="true";
+		return $isequal;
+	function isPermissioned() {
+	function getPermissionValue($wms_id, $lay_id){
+		$return_permission="";
+		// get permission
+		if (in_array($lay_id, $this->mylayer)){
+			$return_permission = "true";
+		} else {
+			$sql = "SELECT wms.wms_id, mb_user.mb_user_email as email FROM wms, mb_user where wms.wms_owner=mb_user.mb_user_id " .
+						"and wms.wms_id=$1";
+			$t = array('i');
+			// get email
+			$mail="";
+			$mail = $row['email'];
+			$return_permission = $mail;
+		return $return_permission;
+	function getPermissionValueForWFS($wfs_id, $wfs_conf_id){
+	// get permission
+	if (in_array($wfs_conf_id, $this->myWFSConfs)){
+	} else {
+		$sql = "SELECT wfs.wfs_id, mb_user.mb_user_email as email FROM wfs, mb_user where wfs.wfs_owner=mb_user.mb_user_id " .
+					"and wfs.wfs_id=$1";
+		$v = array($wfs_id);
+		$t = array('i');
+		// get email
+		$mail="";
+	function getTermOfUse($wms_id){
+		$return_tou_id="";
+		$sql = "SELECT wms.wms_id, wms_termsofuse.fkey_wms_id, wms_termsofuse.fkey_termsofuse_id, termsofuse.termsofuse_id as tid " .
+				"FROM wms, wms_termsofuse, termsofuse " .
+				"where wms.wms_id=wms_termsofuse.fkey_wms_id " .
+				"and wms_termsofuse.fkey_termsofuse_id=termsofuse.termsofuse_id " .
+		$t = array('i');
+		// get termsofuse_id
+		$termsofuse_id="";
+		$termsofuse_id = $row['tid'];
+//		$return_tou_id = "mapbender/php/mod_termsofuse_service.php?id=".$termsofuse_id;
+		$return_tou_id = $termsofuse_id;
+		return $return_tou_id;
+	function generateNewReaArray($result){
+		global $con;
+//		echo "func generateNewReaArray<br>";
+//		$this->search_bbox;
+//		$this->search_epsg;
+		$delColumns = array();
+		$columnsResult = array();
+		$db_epsg="";
+		$db_minx="";
+		$db_miny="";
+		$db_maxx="";
+		$db_maxy="";
+		$isIntersecting = "";
+		$anz = 0;
+		while($row = db_fetch_array($result)){
+			$status="";
+//			echo $anz.". layer_id: ".$row['layer_id'];
+			//EPSG Vergleich
+			$sql_ac = "SELECT * FROM layer_epsg WHERE fkey_layer_id = $1";
+			$v = array($row["layer_id"]);
+			$t = array('i');
+			$res_ac = db_prep_query($sql_ac, $v, $t);
+			$tra_epsg="";
+			$tra_minx="";
+			$tra_miny="";
+			$tra_maxx="";
+			$tra_maxy="";
+			$i=0;
+			while($row_ac = db_fetch_array($res_ac)){
+				if ($row_ac["epsg"]=="EPSG:4326"){ // maybe for transformation needed
+					$db_epsg=$row_ac["epsg"];
+					$db_minx=$row_ac["minx"];
+					$db_miny=$row_ac["miny"];
+					$db_maxx=$row_ac["maxx"];
+					$db_maxy=$row_ac["maxy"];
+				if ($row_ac["epsg"]==$this->search_epsg){
+//				if ($row_ac["epsg"]=="EPSG:31467"){
+					$status="match";
+					break;
+				} else {
+				$i++;
+			if ($status=="match"){
+//					echo "match<br>";
+					$temp = $this->search_bbox;
+					$isIntersecting = $this->intersect($temp[0], $temp[1], $temp[2], $temp[3], $db_minx, $db_miny, $db_maxx, $db_maxy, $this->search_epsg);
+			} else if ($status != "match" && $i>0){
+//					echo "Transformation<br>";
+//					Transformation
+					$sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$temp[0]." ".$temp[1].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as minx";
+					$resMinx = @pg_query($con,$sqlMinx);
+					$s_minx = pg_result($resMinx,0,"minx");
+					$sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$temp[0]." ".$temp[1].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as miny";
+					$resMiny = @pg_query($con,$sqlMiny);
+					$s_miny = pg_result($resMiny,0,"miny");
+					$sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as maxx";
+					$resMaxx = @pg_query($con,$sqlMaxx);
+					$s_maxx = pg_result($resMaxx,0,"maxx");
+					$sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as maxy";
+					$resMaxy = @pg_query($con,$sqlMaxy);
+					$s_maxy = pg_result($resMaxy,0,"maxy");
+					$isIntersecting = $this->intersect($s_minx, $s_miny, $s_maxx, $s_maxy, $db_minx, $db_miny, $db_maxx, $db_maxy, "EPSG:4326");
+			} else {
+//					"no intersection possible()<br>";
+					$isIntersecting="f";
+			if ($isIntersecting=="t"){
+//				Datensatz loeschen
+				array_push($columnsResult, $row);
+			$anz++;
+		return $columnsResult;
+	function intersect($s_minx, $s_miny, $s_maxx, $s_maxy, $db_minx, $db_miny, $db_maxx, $db_maxy, $epsg){
+		global $con;
+		$result="";
+		$sqlint = "SELECT intersects(envelope(geometryFROMtext('LINESTRING(".$s_minx." ".$s_miny.", ".$s_maxx." ".$s_maxy.")',".str_replace("EPSG:","",$epsg).")) " .
+								   ",envelope(geometryFROMtext('LINESTRING(".$db_minx." ".$db_miny.", ".$db_maxx." ".$db_maxy.")',".str_replace("EPSG:","",$epsg).")))";
+		$resInt = @pg_query($con,$sqlint);
+		$result = pg_result($resInt,0,"intersects");
+		return $result;
+	 * Checks whether the keyword exist in the table keywords
+	 * @todo is UPPER() working with mysql
+	 * @param string the keyword
+	 * @return integer the ID of the keyword
+	function exists($keyword){
+		global $con;
+		$sql = "SELECT keyword_id FROM keyword WHERE UPPER(keyword) = UPPER($1)";
+		$v = array($keyword);
+		$t = array('s');
+		$res = db_prep_query($sql,$v,$t);
+		if($row = db_fetch_array($res)){
+			return $row['keyword_id'];
+		else{
+			return false;
+	function getSQLBedfromArray($culumnName, $columnValues, $additionalChar){
+		$a = array();
+		$a = $columnValues;
+		$a_char = $additionalChar;
+		$colName=$culumnName;
+		$resultSql="";
+		for ($index = 0; $index < sizeof($a); $index++) {
+			$array_element = $a[$index];
+			if ($index<1){
+				$resultSql .= $colName."='".$a[$index]."'";
+			}else{
+				$resultSql .= " ".$a_char." " .$colName."='".$a[$index]."'";
+		return $resultSql;
+	function getDepartmentBed ($columnFkey, $culumnName, $columnValues, $additionalChar){
+		$a = array();
+		$resultSql = $columnFkey." in (SELECT mb_user_id FROM mb_user WHERE ";
+		for ($index = 0; $index < count($a); $index++) {
+			if ($index<1){
+			}else{
+		$resultSql .=")";
+	function getGeoType($wfs_id, $featureType_id){
+		$return_geoType="";
+		$sql = "SELECT element_type FROM wfs_element, wfs_featuretype " .
+				"where wfs_featuretype.featuretype_id=wfs_element.fkey_featuretype_id " .
+				"and element_name='the_geom'" .
+				"and wfs_featuretype.fkey_wfs_id = $1" .
+				"and wfs_element.fkey_featuretype_id=$2";
+		$v = array($wfs_id, $featureType_id);
+		$t = array('i', 'i');
+		// get element_type
+		$return_geoType = $row['element_type'];;
+		return $return_geoType;
More information about the Mapbender_commits mailing list
