[Mapbender-commits] r1844 - branches/mapbender_sld
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Nov 23 08:55:47 EST 2007
Author: christoph
Date: 2007-11-23 08:55:47 -0500 (Fri, 23 Nov 2007)
New Revision: 1844
   branches/mapbender_sld/Changes.txt
   branches/mapbender_sld/Install.txt
txt
Modified: branches/mapbender_sld/Changes.txt
--- branches/mapbender_sld/Changes.txt	2007-11-23 13:55:09 UTC (rev 1843)
+++ branches/mapbender_sld/Changes.txt	2007-11-23 13:55:47 UTC (rev 1844)
@@ -4,8 +4,49 @@
- Changelog 2.4.1
+Changelog 2.4.2
+  english
+    bug fixes: see http://trac.osgeo.org/mapbender/report/9
+    new features
+    * set WMS opacity in treeGDE2
+    * Bulgarian translation of the introduction to Mapbender
+    * improved module Add WMS from filtered list: loading a configured WMS from a GUI is now possible
+    * updated Meetingpoint / Treffpunkt: new image, some bugfixes
+    * improved exception handling / log levels (see mapbender.conf#Mapbender_error_logging)
+    * poi (not included in a GUI yet)
+    * JavaScript compression; Mapbender will load faster
+    * dynamic overview - integration in the rc1 an testing gui2
+    * treeGDE2 replaces treeGDE
+    * different configurations of treeGDE2
+    * first draft of an API documentation for JavaScript classes
+    * print temporary objects (lines and polygons) which where drawn with the measure element
+  deutsch
+    behobene Fehler: siehe http://trac.osgeo.org/mapbender/report/9
+    neue Features
+    * Einstellen der Deckkraft (Opacity) einzelner WMSe in der TreeGDE2
+    * Bulgarische Übersetzung der Mapbender-Einführung
+    * Verbesserung des Moduls Add WMS from filtered list: es ist nun möglich, konfigurierte WMSe aus GUIs zu laden
+    * Update des Moduls Meetingpoint / Treffpunkt: neue Bilddatei, diverse Fehler behoben
+    * Verbessertes Logging, auch von JavaScript Fehlern (siehe mapbender.conf#Mapbender_error_logging)
+    * poi (noch in keiner GUI enthalten)
+    * JavaScript Kompression; Mapbender lädt schneller
+    * Dynamisches Overview
+    * TreeGDE2 ersetzt die alte Baumstruktur
+    * verschiedene Konfigurationen der TreeGDE2 in den Standard-GUIs
+    * vorläufige API Dokumentation für JavaScript Klassen
+    * Druck von temporären Objekten (Linien und Polygone), die mit dem "measure" Element erstellt wurden
+Changelog 2.4.1
 english
Modified: branches/mapbender_sld/Install.txt
--- branches/mapbender_sld/Install.txt	2007-11-23 13:55:09 UTC (rev 1843)
+++ branches/mapbender_sld/Install.txt	2007-11-23 13:55:47 UTC (rev 1844)
@@ -25,11 +25,11 @@
 -- database with utf8 encoding
-create database mapbender CHARACTER SET utf8 COLLATE utf8_general_ci ;
+CREATE DATABASE mapbender CHARACTER SET utf8 COLLATE utf8_general_ci ;
 -- database with ISO-8859-1 encoding
-create database mapbender CHARACTER SET latin1 COLLATE latin1_german1_ci ;
+CREATE DATABASE mapbender CHARACTER SET latin1 COLLATE latin1_german1_ci ;
 -- select the database mapbender
@@ -56,13 +56,19 @@
 -- Create a Database with Latin1 or UTF8 encoding
+CREATE DATABASE mapbender ENCODING = 'UTF8';
+or
+CREATE DATABASE mapbender ENCODING = 'LATIN1';
 If you want to run Mapbender with PostgreSQL load the following files:
 1. pgsql_schema.sql (creates tables, keys, constraints)
 2. pgsql_data.sql	(loads data)
 3. pgsql_serial_set_sequences_7x.sql or pgsql_serial_set_sequences.sql
 (depending on wich postgresql version you use, sets the values for the sequences)
-- Z�hlerstand der Sequenz f�r Serial-Felder (Autowerte)
+- Zaehlerstand der Sequenz fuer Serial-Felder (Autowerte)
 -- How to load the sqls in PostgreSQL:
More information about the Mapbender_commits mailing list
