[Mapbender-commits] r1845 - branches/mapbender_sld/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Nov 23 09:07:56 EST 2007
Author: christoph
Date: 2007-11-23 09:07:56 -0500 (Fri, 23 Nov 2007)
New Revision: 1845
   branches/mapbender_sld/http/classes/class_wms.php
merge
Modified: branches/mapbender_sld/http/classes/class_wms.php
--- branches/mapbender_sld/http/classes/class_wms.php	2007-11-23 13:55:47 UTC (rev 1844)
+++ branches/mapbender_sld/http/classes/class_wms.php	2007-11-23 14:07:56 UTC (rev 1845)
@@ -19,6 +19,8 @@
 include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_mb_exception.php");
+require_once(dirname(__FILE__)."/class_administration.php");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
@@ -56,16 +58,16 @@
 	var $data_type = array();
 	var $data_format = array();
 	var $objLayer = array();
-	var $wms_supportsld;
-	var $wms_userlayer;
-	var $wms_userstyle;
-	var $wms_remotewfs;
+	var $wms_supportsld;
+	var $wms_userlayer;
+	var $wms_userstyle;
+	var $wms_remotewfs;
 	var $gui_wms_mapformat;
 	var $gui_wms_featureinfoformat;
 	var $gui_wms_exceptionformat;
-	var $gui_wms_epsg;
+	var $gui_wms_epsg;
 	var $gui_wms_sldurl;
 	var $default_epsg = 0;
@@ -89,15 +91,23 @@
 		$values = null;
 		$tags = null;
-		$this->wms_getcapabilities_doc = $this->char_encode($data);
+		$admin = new administration();
+		$this->wms_getcapabilities_doc = $admin->char_encode($data);
 		$this->wms_upload_url = $url;
-		$this->wms_id = "";
-		$parser = xml_parser_create(CHARSET);
+		$this->wms_id = "";
+		$parser = xml_parser_create("");
 		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
 		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
 		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
-		xml_parse_into_struct($parser,$data,$values,$tags);
+		xml_parse_into_struct($parser,$this->wms_getcapabilities_doc,$values,$tags);
+		$code = xml_get_error_code($parser);
+		if ($code) {
+			$line = xml_get_current_line_number($parser);
+			$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
 		xml_parser_free($parser);
 		$section = null;
@@ -111,207 +121,207 @@
 		$cnt_styles = -1;
 		foreach ($values as $element) {
-			if(strtoupper($element[tag]) == "WMT_MS_CAPABILITIES" && $element[type] == "open"){
+			if(mb_strtoupper($element[tag]) == "WMT_MS_CAPABILITIES" && $element[type] == "open"){
 				$this->wms_version = $element[attributes][version];
-			if(strtoupper($element[tag]) == "TITLE" && $element[level] == '3'){
+			if(mb_strtoupper($element[tag]) == "TITLE" && $element[level] == '3'){
 				$this->wms_title = $this->stripEndlineAndCarriageReturn($element[value]);
-			if(strtoupper($element[tag]) == "ABSTRACT" && $element[level] == '3'){
+			if(mb_strtoupper($element[tag]) == "ABSTRACT" && $element[level] == '3'){
 				$this->wms_abstract = $this->stripEndlineAndCarriageReturn($element[value]);
-			if(strtolower($element[tag]) == "fees"){
+			if(mb_strtolower($element[tag]) == "fees"){
 				$this->fees = $element[value];
-			if(strtolower($element[tag]) == "accessconstraints"){
+			if(mb_strtolower($element[tag]) == "accessconstraints"){
 				$this->accessconstraints = $element[value];
-			if(strtolower($element[tag]) == "contactperson"){
+			if(mb_strtolower($element[tag]) == "contactperson"){
 				$this->contactperson = $element[value];
-			if(strtolower($element[tag]) == "contactposition"){
+			if(mb_strtolower($element[tag]) == "contactposition"){
 				$this->contactposition = $element[value];
-			if(strtolower($element[tag]) == "contactorganization"){
+			if(mb_strtolower($element[tag]) == "contactorganization"){
 				$this->contactorganization = $element[value];
-			if(strtolower($element[tag]) == "address"){
+			if(mb_strtolower($element[tag]) == "address"){
 				$this->address = $element[value];
-			if(strtolower($element[tag]) == "city"){
+			if(mb_strtolower($element[tag]) == "city"){
 				$this->city = $element[value];
-			if(strtolower($element[tag]) == "stateorprovince"){
+			if(mb_strtolower($element[tag]) == "stateorprovince"){
 				$this->stateorprovince = $element[value];
-			if(strtolower($element[tag]) == "postcode"){
+			if(mb_strtolower($element[tag]) == "postcode"){
 				$this->postcode = $element[value];
-			if(strtolower($element[tag]) == "country"){
+			if(mb_strtolower($element[tag]) == "country"){
 				$this->country = $element[value];
-			if(strtolower($element[tag]) == "contactvoicetelephone"){
+			if(mb_strtolower($element[tag]) == "contactvoicetelephone"){
 				$this->contactvoicetelephone = $element[value];
-			if(strtolower($element[tag]) == "contactfacsimiletelephone"){
+			if(mb_strtolower($element[tag]) == "contactfacsimiletelephone"){
 				$this->contactfacsimiletelephone = $element[value];
-			if(strtolower($element[tag]) == "contactelectronicmailaddress"){
+			if(mb_strtolower($element[tag]) == "contactelectronicmailaddress"){
 				$this->contactelectronicmailaddress = $element[value];
-	  		if(strtolower($element[tag]) == "keyword" && $section != 'layer'){
+	  		if(mb_strtolower($element[tag]) == "keyword" && $section != 'layer'){
 				$this->wms_keyword[count($this->wms_keyword)] = $element[value];
 			/*map section*/
 			if($this->wms_version == "1.0.0"){
-		 		if(strtoupper($element[tag]) == "MAP" && $element[type] == "open"){
+		 		if(mb_strtoupper($element[tag]) == "MAP" && $element[type] == "open"){
 					$section = "map";
-				if($section == "map" && strtoupper($element[tag]) == "GET"){
+				if($section == "map" && mb_strtoupper($element[tag]) == "GET"){
 					$this->wms_getmap = $element[attributes][onlineResource];
-				if($section == "map" && strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
+				if($section == "map" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
 					$format = "map";
-				if(strtoupper($element[tag]) != "FORMAT" && $section == "map" && $format == "map"){
+				if(mb_strtoupper($element[tag]) != "FORMAT" && $section == "map" && $format == "map"){
 					$this->data_type[$cnt_format] = "map";
 					$this->data_format[$cnt_format] = trim($element[tag]);
 					$cnt_format++;
-				if(strtoupper($element[tag]) == "FORMAT" && $element[type] == "close"){
+				if(mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "close"){
 					$format = "";
-				if(strtoupper($element[tag]) == "MAP" && $element[type] == "close"){
+				if(mb_strtoupper($element[tag]) == "MAP" && $element[type] == "close"){
 					$section = "";
 			else{
-				if(strtoupper($element[tag]) == "GETMAP" && $element[type] == "open"){
+				if(mb_strtoupper($element[tag]) == "GETMAP" && $element[type] == "open"){
 					$section = "map";
-				if($section == "map" && strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+				if($section == "map" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
 					$request = "get";
-				if($section == "map" && $request == "get" && strtoupper($element[tag]) == "ONLINERESOURCE"){
+				if($section == "map" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
 					$this->wms_getmap = $element[attributes]["xlink:href"];
-				if($section == "map" && strtoupper($element[tag]) == "FORMAT"){
+				if($section == "map" && mb_strtoupper($element[tag]) == "FORMAT"){
 					$this->data_format[$cnt_format] = trim($element[value]);
 					$cnt_format++;
-				if($section == "map" && strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+				if($section == "map" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
 					$request = "";
-				if(strtoupper($element[tag]) == "GETMAP" && $element[type] == "close"){
+				if(mb_strtoupper($element[tag]) == "GETMAP" && $element[type] == "close"){
 					$section = "";
 			/*capabilities section*/
-				if(strtoupper($element[tag]) == "CAPABILITIES" && $element[type] == "open"){
+				if(mb_strtoupper($element[tag]) == "CAPABILITIES" && $element[type] == "open"){
 					$section = "capabilities";
-				if($section == "capabilities" && strtoupper($element[tag]) == "GET"){
+				if($section == "capabilities" && mb_strtoupper($element[tag]) == "GET"){
 					$this->wms_getcapabilities = $element[attributes][onlineResource];
-				if(strtoupper($element[tag]) == "CAPABILITIES" && $element[type] == "close"){
+				if(mb_strtoupper($element[tag]) == "CAPABILITIES" && $element[type] == "close"){
 					$section = "";
 			else{
-				if(strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "open"){
+				if(mb_strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "open"){
-				if($section == "capabilities" && strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+				if($section == "capabilities" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
 					$request = "get";
-				if($section == "capabilities" && $request == "get" && strtoupper($element[tag]) == "ONLINERESOURCE"){
+				if($section == "capabilities" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
 					$this->wms_getcapabilities = $element[attributes]["xlink:href"];
-				if($section == "capabilities" && strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+				if($section == "capabilities" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
 					$request = "";
-				if(strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "close"){
+				if(mb_strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "close"){
 					$section = "";
 			/*featureInfo section*/
-				if(strtoupper($element[tag]) == "FEATUREINFO" && $element[type] == "open"){
+				if(mb_strtoupper($element[tag]) == "FEATUREINFO" && $element[type] == "open"){
 					$section = "featureinfo";
-				if($section == "featureinfo" && strtoupper($element[tag]) == "GET"){
+				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "GET"){
 					$this->wms_getfeatureinfo = $element[attributes][onlineResource];
-				if($section == "featureinfo" && strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
+				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
 					$format = "featureinfo";
-				if(strtoupper($element[tag]) != "FORMAT" && $section == "featureinfo" && $format == "featureinfo"){
+				if(mb_strtoupper($element[tag]) != "FORMAT" && $section == "featureinfo" && $format == "featureinfo"){
 					$this->data_type[$cnt_format] = "featureinfo";
 					$cnt_format++;
 					$format = "";
-				if(strtoupper($element[tag]) == "FEATUREINFO" && $element[type] == "close"){
+				if(mb_strtoupper($element[tag]) == "FEATUREINFO" && $element[type] == "close"){
 					$section = "";
 			else{
-				if(strtoupper($element[tag]) == "GETFEATUREINFO" && $element[type] == "open"){
+				if(mb_strtoupper($element[tag]) == "GETFEATUREINFO" && $element[type] == "open"){
-				if($section == "featureinfo" && strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
 					$request = "get";
-				if($section == "featureinfo" && $request == "get" && strtoupper($element[tag]) == "ONLINERESOURCE"){
+				if($section == "featureinfo" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
 					$this->wms_getfeatureinfo = $element[attributes]["xlink:href"];
-				if($section == "featureinfo" && strtoupper($element[tag]) == "FORMAT"){
+				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "FORMAT"){
 					$cnt_format++;
-				if($section == "featureinfo" && strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+				if($section == "featureinfo" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
 					$request = "";
-				if(strtoupper($element[tag]) == "GETFEATUREINFO" && $element[type] == "close"){
+				if(mb_strtoupper($element[tag]) == "GETFEATUREINFO" && $element[type] == "close"){
 					$section = "";
 			/*exception section*/
-				if(strtoupper($element[tag]) == "EXCEPTION" && $element[type] == "open"){
+				if(mb_strtoupper($element[tag]) == "EXCEPTION" && $element[type] == "open"){
 					$section = "exception";
-				if($section == "exception" && strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
+				if($section == "exception" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "open"){
 					$format = "exception";
-				if(strtoupper($element[tag]) != "FORMAT" && $section == "exception" && $format == "exception"){
+				if(mb_strtoupper($element[tag]) != "FORMAT" && $section == "exception" && $format == "exception"){
 					$this->data_type[$cnt_format] = "exception";
 					$cnt_format++;
-				if($section == "exception" && strtoupper($element[tag]) == "FORMAT" && $element[type] == "close"){
+				if($section == "exception" && mb_strtoupper($element[tag]) == "FORMAT" && $element[type] == "close"){
 					$format = "";
-				if(strtoupper($element[tag]) == "EXCEPTION" && $element[type] == "close"){
+				if(mb_strtoupper($element[tag]) == "EXCEPTION" && $element[type] == "close"){
 					$section = "";
 			else{
-				if($section == "exception" && strtoupper($element[tag]) == "FORMAT"){
+				if($section == "exception" && mb_strtoupper($element[tag]) == "FORMAT"){
 					$cnt_format++;
 					$section = "";
@@ -320,33 +330,32 @@
 	      else{
-	        if(strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "open"){
+	        if(mb_strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "open"){
 				$section = "legend";
-	        if($section == "legend" && strtoupper($element[tag]) == "GET" && $element[type] == "open"){
+	        if($section == "legend" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "open"){
 				$request = "get";
-			if($section == "legend" && $request == "get" && strtoupper($element[tag]) == "ONLINERESOURCE"){
+			if($section == "legend" && $request == "get" && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
 				$this->wms_getlegendurl = $element[attributes]["xlink:href"];
-	        if($section == "legend" && strtoupper($element[tag]) == "GET" && $element[type] == "close"){
+	        if($section == "legend" && mb_strtoupper($element[tag]) == "GET" && $element[type] == "close"){
 				$request = "";
-			if(strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "close"){
+			if(mb_strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "close"){
 				$section = "";
-			/* sld section */
-			if(strtoupper($element[tag]) == "USERDEFINEDSYMBOLIZATION" && $element[type] == "complete"){
-				$this->wms_supportsld = $element[attributes]["SupportSLD"];
-				$this->wms_userlayer = $element[attributes]["UserLayer"];
-				$this->wms_userstyle = $element[attributes]["UserStyle"];
-				$this->wms_remotewfs = $element[attributes]["RemoteWFS"];
+			/* sld section */
+			if(mb_strtoupper($element[tag]) == "USERDEFINEDSYMBOLIZATION" && $element[type] == "complete"){
+				$this->wms_supportsld = $element[attributes]["SupportSLD"];
+				$this->wms_userlayer = $element[attributes]["UserLayer"];
+				$this->wms_userstyle = $element[attributes]["UserStyle"];
+				$this->wms_remotewfs = $element[attributes]["RemoteWFS"];
 			/*layer section*/
-			if(strtoupper($element[tag]) == "LAYER"){
+			if(mb_strtoupper($element[tag]) == "LAYER"){
 				$section = "layer";
 				if ($element[type] == "open") {
 					$cnt_epsg = -1;
@@ -361,7 +370,7 @@
 			/* attribution */
-			if(strtoupper($element[tag]) == "ATTRIBUTION"){
+			if(mb_strtoupper($element[tag]) == "ATTRIBUTION"){
 					$section = "attribution";
@@ -370,7 +379,7 @@
 			/* styles */
-			if(strtoupper($element[tag]) == "STYLE"){
+			if(mb_strtoupper($element[tag]) == "STYLE"){
 				$section = "style";
 				if($cnt_layer != $layer_style){
 					$layer_style = $cnt_layer;
@@ -384,64 +393,65 @@
 			if($section == "style"){
-				if(strtoupper($element[tag]) == "NAME"){
+				if(mb_strtoupper($element[tag]) == "NAME"){
 					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["name"] = $element[value];
-				if(strtoupper($element[tag]) == "TITLE"){
+				if(mb_strtoupper($element[tag]) == "TITLE"){
 					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["title"] = $element[value];
-	      		if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "open"){
+	      		if(mb_strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "open"){
 					$legendurl = true;
-				if($legendurl && strtoupper($element[tag]) == "FORMAT"){
+				if($legendurl && mb_strtoupper($element[tag]) == "FORMAT"){
 					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["legendurlformat"] = $element[value];
-				if($legendurl && strtoupper($element[tag]) == "ONLINERESOURCE"){
+				if($legendurl && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
 					$this->objLayer[$cnt_layer]->layer_style[$cnt_styles]["legendurl"] = $element[attributes]["xlink:href"];
-			    if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "close"){
+			    if(mb_strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "close"){
 					$legendurl = false;
 			/* end of styles */
 			if($section == "layer"){
 					$this->objLayer[$cnt_layer]->layer_name = $element[value];
 					$this->objLayer[$cnt_layer]->layer_title = $this->stripEndlineAndCarriageReturn($element[value]);
-				if(strtoupper($element[tag]) == "ABSTRACT"){
+				if(mb_strtoupper($element[tag]) == "ABSTRACT"){
 					$this->objLayer[$cnt_layer]->layer_abstract = $this->stripEndlineAndCarriageReturn($element[value]);
-				if(strtoupper($element[tag]) == "KEYWORD"){
-					$this->objLayer[$cnt_layer]->layer_keyword[count($this->objLayer[$cnt_layer]->layer_keyword)] = $element[value];
+				if(mb_strtoupper($element[tag]) == "KEYWORD"){
+					array_push($this->objLayer[$cnt_layer]->layer_keyword, trim($element[value]));
-	      		if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "open"){
+	      		if(mb_strtoupper($element[tag]) == "DATAURL" && $element[type] == "open"){
 					$dataurl = true;
-				if($dataurl && strtoupper($element[tag]) == "ONLINERESOURCE"){
+				if($dataurl && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
 					$this->objLayer[$cnt_layer]->layer_dataurl_href = $element[attributes]["xlink:href"];
-			    if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "close"){
+			    if(mb_strtoupper($element[tag]) == "DATAURL" && $element[type] == "close"){
 					$dataurl = false;
-				if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
+				if(mb_strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
 					$metadataurl = true;
-				if($metadataurl && strtoupper($element[tag]) == "ONLINERESOURCE"){
+				if($metadataurl && mb_strtoupper($element[tag]) == "ONLINERESOURCE"){
 					$this->objLayer[$cnt_layer]->layer_metadataurl = $element[attributes]["xlink:href"];
-			    if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "close"){
+			    if(mb_strtoupper($element[tag]) == "METADATAURL" && $element[type] == "close"){
 					$metadataurl = false;
-				if(strtoupper($element[tag]) == "SRS"){
+				if(mb_strtoupper($element[tag]) == "SRS"){
 	  				$this->objLayer[$cnt_layer]->wms_srs1 = $element[value];
-					$this->wms_srs = explode (" ", $this->objLayer[0]->wms_srs1);
+					// unique srs only, see http://www.mapbender.org/index.php/Arrays_with_unique_entries
+					$this->wms_srs = array_keys(array_flip(explode(" ", $this->objLayer[0]->wms_srs1)));
-				if(strtoupper($element[tag]) == "LATLONBOUNDINGBOX"){
+				if(mb_strtoupper($element[tag]) == "LATLONBOUNDINGBOX"){
 					$cnt_epsg++;
 					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["epsg"] = "EPSG:4326";
 					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["minx"] = $element[attributes][minx];
@@ -449,7 +459,7 @@
 					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["maxx"] = $element[attributes][maxx];
 					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["maxy"] = $element[attributes][maxy];
-				if(strtoupper($element[tag]) == "BOUNDINGBOX" && $element[attributes][SRS] != "EPSG:4326"){
+				if(mb_strtoupper($element[tag]) == "BOUNDINGBOX" && $element[attributes][SRS] != "EPSG:4326"){
 					$cnt_epsg++;
 					$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["epsg"] = $element[attributes][SRS];
@@ -457,11 +467,11 @@
 					// a default epsg for mapbender
-					if($cnt_layer == 0 && $this->default_epsg == 0 && strlen(trim($element[attributes][SRS]))>= 10){
+					if($cnt_layer == 0 && $this->default_epsg == 0 && mb_strlen(trim($element[attributes][SRS]))>= 10){
 						$this->default_epsg = $cnt_epsg;
-				if(strtoupper($element[tag]) == "SCALEHINT"){
+				if(mb_strtoupper($element[tag]) == "SCALEHINT"){
 					if($element[attributes][max]>1000) $max = 0; else $max = $element[attributes][max];
 					if($element[attributes][min]>1000) $min = 0; else $min = $element[attributes][min];
 					$this->objLayer[$cnt_layer]->layer_minscale = round(($min * 2004.3976484406788493955738891127));
@@ -475,11 +485,13 @@
 		if(!$this->wms_title || $this->wms_title == "" || !$this->wms_getmap || $this->wms_getmap == ""){
 			$this->wms_status = false;
 			$this->optimizeWMS();
 			return false;
 		else{
 			$this->wms_status = true;
 			return true;
@@ -532,7 +544,9 @@
 			if(!is_int($this->objLayer[$i]->layer_parent)){
 				$this->objLayer[$i]->layer_abstract = $this->wms_abstract;
-				$this->objLayer[$i]->layer_keyword = $this->wms_keyword;
+				for ($r = 0; $r < count($this->wms_keyword); $r++) {
+					array_push($this->objLayer[$i]->layer_keyword, trim($this->wms_keyword[$r]));
 			if($this->objLayer[$i]->layer_name == ""){
 				$this->objLayer[$i]->layer_name = $this->objLayer[$i]->layer_title;
@@ -550,32 +564,32 @@
 			$this->objLayer[$i]->gui_layer_maxscale = $this->objLayer[$i]->layer_maxscale;
 		for($i=0;$i<count($this->data_format);$i++){
-			if(strtolower($this->data_type[$i]) == 'map' && strtoupper($this->data_format[$i]) == strtoupper($map_default)){
-				$this->gui_wms_mapformat = strtolower($map_default);
+			if(mb_strtolower($this->data_type[$i]) == 'map' && mb_strtoupper($this->data_format[$i]) == mb_strtoupper($map_default)){
+				$this->gui_wms_mapformat = mb_strtolower($map_default);
 				$map_default_ok = true;
-			if(strtolower($this->data_type[$i]) == 'featureinfo' && strtoupper($this->data_format[$i]) == strtoupper($featureinfo_default)){
-				$this->gui_wms_featureinfoformat = strtolower($featureinfo_default);
+			if(mb_strtolower($this->data_type[$i]) == 'featureinfo' && mb_strtoupper($this->data_format[$i]) == mb_strtoupper($featureinfo_default)){
+				$this->gui_wms_featureinfoformat = mb_strtolower($featureinfo_default);
 				$featureinfo_default_ok = true;
-			if(strtolower($this->data_type[$i]) == 'exception' && strtolower($this->data_format[$i]) == strtolower($exception_default)){
-				$this->gui_wms_exceptionformat = strtolower($exception_default);
+			if(mb_strtolower($this->data_type[$i]) == 'exception' && mb_strtolower($this->data_format[$i]) == mb_strtolower($exception_default)){
+				$this->gui_wms_exceptionformat = mb_strtolower($exception_default);
 				$exception_default_ok = true;
 		if($map_default_ok == false){
-				if(strtolower($this->data_type[$i]) == "map" ){$this->gui_wms_mapformat = $this->data_format[$i]; break;}
+				if(mb_strtolower($this->data_type[$i]) == "map" ){$this->gui_wms_mapformat = $this->data_format[$i]; break;}
 		if($featureinfo_default_ok == false){
-				if(strtolower($this->data_type[$i]) == "featureinfo" ){$this->gui_wms_featureinfoformat = $this->data_format[$i]; break;}
+				if(mb_strtolower($this->data_type[$i]) == "featureinfo" ){$this->gui_wms_featureinfoformat = $this->data_format[$i]; break;}
 		if($exception_default_ok == false){
-				if(strtolower($this->data_type[$i]) == "exception" ){$this->gui_wms_exceptionformat = $this->data_format[$i]; break;}
+				if(mb_strtolower($this->data_type[$i]) == "exception" ){$this->gui_wms_exceptionformat = $this->data_format[$i]; break;}
@@ -596,23 +610,23 @@
 		for($i=0; $i<count($this->objLayer); $i++){
 				$this->objLayer[$i]->layer_pos=$i;
-		/* fill sld variables when empty */
-		if($this->wms_supportsld == ""){
-				$this->wms_supportsld = 0;
-		if($this->wms_userlayer == ""){
-				$this->wms_userlayer = 0;
-		if($this->wms_userstyle == ""){
-				$this->wms_userstyle = 0;
-		if($this->wms_remotewfs == ""){
-				$this->wms_remotewfs = 0;
+		/* fill sld variables when empty */
+		if($this->wms_supportsld == ""){
+				$this->wms_supportsld = 0;
+		if($this->wms_userlayer == ""){
+				$this->wms_userlayer = 0;
+		if($this->wms_userstyle == ""){
+				$this->wms_userstyle = 0;
+		if($this->wms_remotewfs == ""){
+				$this->wms_remotewfs = 0;
 	function displayWMS(){
 		echo "<br>id: " . $this->wms_id . " <br>";
 		echo "version: " . $this->wms_version . " <br>";
@@ -626,7 +640,7 @@
 		echo "gui_wms_exceptionformat: " . $this->gui_wms_exceptionformat . " <br>";
 		echo "gui_wms_epsg: " . $this->gui_wms_epsg . " <br>";
 		echo "wms_srs: " . $this->objLayer[0]->wms_srs1 . " <br>";
-		echo "gui_wms_visible: " . $this->gui_wms_visible . " <br>";
+		echo "gui_wms_visible: " . $this->gui_wms_visible . " <br>";
 		echo "support_sld: " . $this->wms_supportsld . " <br>";
 		for($i=0; $i<count($this->data_type);$i++){
@@ -663,7 +677,7 @@
 	   * private function
 	  function stripEndlineAndCarriageReturn($string) {
-	  	return str_replace(chr(13), "", str_replace(chr(10), " ", $string));
+	  	return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
 	  function createJsObjFromWMS($parent=0){
 	  	if(!$this->wms_title || $this->wms_title == ""){
@@ -689,7 +703,7 @@
 					"'" . $this->gui_wms_featureinfoformat . "'," .
 					"'" . $this->gui_wms_exceptionformat . "'," .
 					"'" . $this->gui_wms_epsg ."'," .
-					"'" . $this->gui_wms_visible ."'," .
+					"'" . $this->gui_wms_visible ."'," .
 					"'" . $this->gui_wms_sldurl ."" .
 			echo $add_wms_string;
@@ -716,7 +730,8 @@
 				$this->objLayer[$i]->layer_maxscale ."','".
 				$this->objLayer[$i]->layer_metadataurl ."','".
 				$this->objLayer[$i]->gui_layer_wms_id ."','".
-				$this->objLayer[$i]->gui_layer_status ."','".
+				$this->objLayer[$i]->gui_layer_status ."','".
+				$this->objLayer[$i]->gui_layer_style ."','".
 				$this->objLayer[$i]->gui_layer_selectable ."','".
 				$this->objLayer[$i]->gui_layer_visible ."','".
 				$this->objLayer[$i]->gui_layer_queryable ."','".
@@ -769,8 +784,8 @@
 			print("add_wms('".
 			$this->wms_id ."','".
 			$this->wms_version ."','".
-			str_replace("'", "", $this->wms_title) ."','".
-			str_replace("'", "", $this->wms_abstract) ."','".
+			preg_replace("/'/", "", $this->wms_title) ."','".
+			preg_replace("/'/", "", $this->wms_abstract) ."','".
 			$this->wms_getmap ."','" .
 			$this->wms_getfeatureinfo ."','".
 			$this->wms_getlegendurl ."','".
@@ -779,7 +794,7 @@
 			$this->gui_wms_featureinfoformat ."','".
 			$this->gui_wms_exceptionformat . "','".
 			$this->gui_wms_epsg ."','".
-			$this->gui_wms_visible ."','".
+			$this->gui_wms_visible ."','".
 			$this->gui_wms_sldurl ."');\n");
@@ -806,7 +821,8 @@
@@ -854,7 +870,7 @@
 	function writeObjInDB($gui_id){
 		global $con;
 		$this->checkObj();
 		db_begin();
@@ -863,7 +879,7 @@
 		$sql.= "wms_getfeatureinfo, wms_getlegendurl, wms_getcapabilities_doc, wms_upload_url, fees, ";
 		$sql .= "accessconstraints, contactperson, contactposition, contactorganization, address, city, ";
 		$sql .= "stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, ";
-		$sql .= "wms_owner,wms_timestamp, ";
+		$sql .= "wms_owner,wms_timestamp, ";
 		$sql .= "wms_supportsld, wms_userlayer, wms_userstyle, wms_remotewfs) ";
 		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24,$25,$26,$27,$28)";
 		$v = array($this->wms_version,$this->wms_title,$this->wms_abstract,$this->wms_getcapabilities,
@@ -871,7 +887,7 @@
 			$this->wms_upload_url,$this->fees,$this->accessconstraints,$this->contactperson,$this->contactposition,
 			$this->contactorganization,$this->address,$this->city,$this->stateorprovince,$this->postcode,$this->country,
 			$this->contactvoicetelephone,$this->contactfacsimiletelephone,$this->contactelectronicmailaddress,
-			$_SESSION['mb_user_id'],strtotime("now"),
+			$_SESSION['mb_user_id'],strtotime("now"),
 			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs );
 		$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i','s','s','s','s');
 		$res = db_prep_query($sql,$v,$t);
@@ -945,16 +961,18 @@
 		if(!$res){
 			db_rollback();
+		else {
+			# save the id of each layer: set param2 true
+			$this->objLayer[$i]->db_id = db_insert_id($con, 'layer','layer_id');
+			$this->insertLayerEPSG($i);
+			# TABLE layer_style for each layer
+			$this->insertLayerStyle($i);
+			# insert Keywords
+			$this->insertLayerKeyword($i);
-		# save the id of each layer: set param2 true
-		$this->objLayer[$i]->db_id = db_insert_id($con, 'layer','layer_id');
-		$this->insertLayerEPSG($i);
-		# TABLE layer_style for each layer
-		$this->insertLayerStyle($i);
-		# insert Keywords
-		$this->insertLayerKeyword($i);
 	function updateLayer($i,$myWMS){
 		$sql = "SELECT layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_name = $2";
@@ -1012,15 +1030,17 @@
 		if(!$res){
 			db_rollback();
-		$this->objLayer[$i]->db_id = $l_id;
-		if($this->overwrite == true){
+		else {
+			$this->objLayer[$i]->db_id = $l_id;
+			if($this->overwrite == true){
 	function insertGuiLayer($i,$myWMS,$gui_id){
@@ -1028,14 +1048,21 @@
 		$sql = "INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, ";
 		$sql .= "gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, ";
-		$sql .= "gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale, gui_layer_priority) ";
-		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11)";
+		$sql .= "gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale, gui_layer_priority, gui_layer_style) ";
+		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12)";
+		if(count($this->objLayer[$i]->layer_style)>0){
+			$layer_style_name = $this->objLayer[$i]->layer_style[0]["name"];
+		else{
+			$layer_style_name = NULL;
 		$v = array($gui_id,$this->objLayer[$i]->db_id,$myWMS,1,1,1,$this->objLayer[$i]->layer_queryable,
-			$this->objLayer[$i]->layer_queryable,$this->objLayer[$i]->layer_minscale,$this->objLayer[$i]->layer_maxscale,$i);
-		$t = array('s','i','i','i','i','i','i','i','i','i','i');
+			$this->objLayer[$i]->layer_queryable,$this->objLayer[$i]->layer_minscale,$this->objLayer[$i]->layer_maxscale,$i,$layer_style_name);
+		$t = array('s','i','i','i','i','i','i','i','i','i','i','s');
+		#$e = new mb_exception("name des insert styles und fkey_layer_id: ".$layer_style_name." --- ".$this->objLayer[$i]->db_id);
 		if(!$res){
-			db_rollback();
+			////db_rollback();
 	function appendGuiLayer($i,$myWMS,$gui_id){
@@ -1043,11 +1070,17 @@
+		else{
 		$v = array($gui_id,$this->objLayer[$i]->db_id,$myWMS,0,0,0,$this->objLayer[$i]->layer_queryable,
 		if(!$res){
 			db_rollback();
@@ -1056,7 +1089,7 @@
 	function insertSRS($myWMS){
 		for($i=0; $i<count($this->wms_srs);$i++){
 			$sql ="INSERT INTO wms_srs (fkey_wms_id, wms_srs) values($1,$2)";
-			$v = array($myWMS,strtoupper($this->wms_srs[$i]));
+			$v = array($myWMS,mb_strtoupper($this->wms_srs[$i]));
 			$t = array('i','s');
 			if(!$res){
@@ -1121,17 +1154,19 @@
 		$t = array('i');
+//		var_dump($this);
 		$k = $this->objLayer[$i]->layer_keyword;
+//		var_dump($k);
 		for($j=0; $j<count($k); $j++){
 			$keyword_id = "";
 			while ($keyword_id == "") {
-				$sql = "SELECT keyword_id FROM keyword WHERE keyword = $1";
+				$sql = "SELECT keyword_id FROM keyword WHERE UPPER(keyword) = UPPER($1)";
 				$v = array($k[$j]);
 				$t = array('s');
 				$row = db_fetch_array($res);
+			//print_r($row);
 				if ($row) {
 					$keyword_id = $row["keyword_id"];
@@ -1153,6 +1188,7 @@
 			$t = array('i', 'i');
 			$res_layerKeywordExists = db_prep_query($sql_layerKeywordExists, $v, $t);
 			$row = db_fetch_array($res_layerKeywordExists);
+			//print_r($row);
 			if (!$row) {
 				$sql1 = "INSERT INTO layer_keyword (fkey_keyword_id,fkey_layer_id)";
 				$sql1 .= "VALUES ($1,$2)";
@@ -1177,16 +1213,16 @@
 		$sql .= "wms_getcapabilities_doc = $6 ,";
 		$sql .= "wms_upload_url = $7,  ";
 		$sql .= "wms_owner = $8, ";
-		$sql .= "wms_timestamp = $9, ";
-		$sql .= "wms_supportsld = $10, ";
-		$sql .= "wms_userlayer = $11, ";
-		$sql .= "wms_userstyle = $12, ";
+		$sql .= "wms_timestamp = $9, ";
+		$sql .= "wms_supportsld = $10, ";
+		$sql .= "wms_userlayer = $11, ";
+		$sql .= "wms_userstyle = $12, ";
 		$sql .= "wms_remotewfs = $13 ";
 		$sql .= " WHERE wms_id = $14";
 		$v = array($this->wms_version,$this->wms_getcapabilities,
 			$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,
-			$this->wms_getcapabilities_doc,$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),
+			$this->wms_getcapabilities_doc,$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),
 			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs,$myWMS);
 		$t = array('s','s','s','s','s','s','s','i','i','s','s','s','s','i');
@@ -1330,7 +1366,10 @@
 				$v = array($l_id,$gui_id);
 				$res1 = db_prep_query($sql1,$v,$t);
-				if(!$res1){db_rollback();}
+				if(!$res1){
+				db_rollback();
 			if($this->objLayer[$i]->layer_queryable == 1){
 				$sql1 = "UPDATE gui_layer set gui_layer_queryable = 1 ";
@@ -1338,7 +1377,10 @@
+				if(!$res1){
+				db_rollback();
 			if($row["gui_layer_minscale"] < $this->objLayer[$i]->layer_minscale){
 				$sql1 = "UPDATE gui_layer set gui_layer_minscale = $1 ";
@@ -1346,7 +1388,8 @@
 				$v = array($this->objLayer[$i]->layer_minscale,$l_id,$gui_id);
 				$t = array('i','i','s');
+				if(!$res1){db_rollback();
 			if($row["gui_layer_maxscale"] > $this->objLayer[$i]->layer_maxscale){
 				$sql1 = "UPDATE gui_layer set gui_layer_maxscale = $1 ";
@@ -1354,7 +1397,8 @@
 				$v = array($this->objLayer[$i]->layer_maxscale,$l_id,$gui_id);
@@ -1371,15 +1415,15 @@
 			$sql = "UPDATE gui_wms SET ";
 			for($i=0; $i<count($this->data_type); $i++){
 				# gui_wms_mapformat
-				if(strtolower($this->data_type[$i]) == "map" && strtolower($this->data_format[$i]) == strtolower($row["gui_wms_mapformat"])){
+				if(mb_strtolower($this->data_type[$i]) == "map" && mb_strtolower($this->data_format[$i]) == mb_strtolower($row["gui_wms_mapformat"])){
 					$myMapFormat = true;
 				# gui_wms_featureinfoformat
-				if(strtolower($this->data_type[$i]) == "featureinfo" && strtolower($this->data_format[$i]) == strtolower($row["gui_wms_featureinfoformat"])){
+				if(mb_strtolower($this->data_type[$i]) == "featureinfo" && mb_strtolower($this->data_format[$i]) == mb_strtolower($row["gui_wms_featureinfoformat"])){
 					$myFeatureInfoFormat = true;
 				# gui_wms_exceptionformat
-				if(strtolower($this->data_type[$i]) == "exception" && strtolower($this->data_format[$i]) == strtolower($row["gui_wms_exceptionformat"])){
+				if(mb_strtolower($this->data_type[$i]) == "exception" && mb_strtolower($this->data_format[$i]) == mb_strtolower($row["gui_wms_exceptionformat"])){
 					$myExceptionFormat = true;
@@ -1400,7 +1444,7 @@
 			# gui_wms_epsg
 			for($j=0; $j<count($this->objLayer[0]->layer_epsg);$j++){
-				if($this->objLayer[0]->layer_epsg[$j][epsg] == strtoupper($row["gui_wms_epsg"])){
+				if($this->objLayer[0]->layer_epsg[$j][epsg] == mb_strtoupper($row["gui_wms_epsg"])){
 					$myGUI_EPSG = true;
@@ -1467,7 +1511,7 @@
 			$this->gui_wms_featureinfoformat=$row["gui_wms_featureinfoformat"];
 			$this->gui_wms_exceptionformat=$row["gui_wms_exceptionformat"];
 			$this->gui_wms_epsg=$row["gui_wms_epsg"];
-			$this->gui_wms_visible = $row["gui_wms_visible"];
+			$this->gui_wms_visible = $row["gui_wms_visible"];
 			$this->gui_wms_sldurl = $row["gui_wms_sldurl"];
 			$sql = "Select * from wms where wms_id = $1 ";
@@ -1480,24 +1524,28 @@
 				$this->wms_version = $row2["wms_version"];
 				$this->wms_title = $this->stripEndlineAndCarriageReturn($row2["wms_title"]);
 				$this->wms_abstract = $this->stripEndlineAndCarriageReturn($row2["wms_abstract"]);
-				if($row2["wms_owsproxy"] != ""){
-					$t = OWSPROXY."/".session_id()."/".$row2["wms_owsproxy"]."?";
-					$this->wms_getmap = $t;
-					$this->wms_getcapabilities =  $t;
-					$this->wms_getfeatureinfo = $t;
+				$wmsowsproxy = $row2["wms_owsproxy"];
+				#$wmsowsproxy = "test";
+				if($wmsowsproxy != ""){
+					$owsproxyurl = OWSPROXY."/".session_id()."/".$wmsowsproxy."?";
+					$this->wms_getmap = $owsproxyurl;
+					$this->wms_getcapabilities =  $owsproxyurl;
+					$this->wms_getfeatureinfo = $owsproxyurl;
+					$this->wms_getlegendurl = $owsproxyurl;
 				else{
 					$this->wms_getmap =  $row2["wms_getmap"];
 					$this->wms_getcapabilities =  $row2["wms_getcapabilities"];
 					$this->wms_getfeatureinfo = $row2["wms_getfeatureinfo"];
+					$this->wms_getlegendurl = $row2["wms_getlegendurl"];
 				$this->wms_getcapabilities_doc = $row2["wms_getcapabilities_doc"];
-				$this->wms_getlegendurl = $row2["wms_getlegendurl"];
-				$this->wms_filter = $row2["wms_filter"];
-				$this->wms_supportsld = $row2["wms_supportsld"];
-				$this->wms_userlayer = $row2["wms_userlayer"];
-				$this->wms_userstyle = $row2["wms_userstyle"];
+				$this->wms_filter = $row2["wms_filter"];
+				$this->wms_supportsld = $row2["wms_supportsld"];
+				$this->wms_userlayer = $row2["wms_userlayer"];
+				$this->wms_userstyle = $row2["wms_userstyle"];
 				$this->wms_remotewfs = $row2["wms_remotewfs"];
 				$count_wms++;
@@ -1553,6 +1601,7 @@
 			$this->objLayer[$layer_cnt]->gui_layer_querylayer = $row["gui_layer_querylayer"];
 			$this->objLayer[$layer_cnt]->gui_layer_minscale = $row["gui_layer_minscale"];
 			$this->objLayer[$layer_cnt]->gui_layer_maxscale = $row["gui_layer_maxscale"];
+			$this->objLayer[$layer_cnt]->gui_layer_style = $row["gui_layer_style"];
 			$this->objLayer[$layer_cnt]->gui_layer_wfs_featuretype = $row["gui_layer_wfs_featuretype"];
 			$sql = "Select * from layer_epsg where fkey_layer_id = $1 ORDER BY fkey_layer_id";
@@ -1579,11 +1628,22 @@
 			while($row2 = db_fetch_array($res_style)){
 				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["name"]=$row2["name"];
 				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["title"]=$row2["title"];
-				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]=$row2["legendurl"];
+					if($row2["legendurl"]!=''){
+						$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]=$owsproxyurl.
+						"REQUEST=getlegendgraphic&VERSION=".$this->wms_version."&LAYER=".$this->objLayer[$layer_cnt]->layer_name."&FORMAT=".$row2["legendurlformat"].
+						"&STYLE=".$row2["name"];
+				else{
+						$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]=$row2["legendurl"];
+						#$e = new mb_exception("legendurl = ".$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]);
 				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurlformat"]=$row2["legendurlformat"];
 				$count_layer_style++;
 			$count++;
@@ -1687,17 +1747,19 @@
 	var $gui_layer_selectable = 1;
 	var $gui_layer_visible = 0;
 	var $gui_layer_queryable = 0;
-	var $gui_layer_querylayer = 0;
+	var $gui_layer_querylayer = 0;
+	var $gui_layer_style = NULL;
-	function layer($id,$parent){
-		$this->layer_id = $id;
-		$this->layer_parent = $parent;
 	function char_encode($s){
 		if(CHARSET == 'UTF-8'){
 			$s = utf8_encode($s);
 		return $s;
+	function layer($id,$parent){
+		$this->layer_id = $id;
+		$this->layer_parent = $parent;
+		//var_dump($this);
\ No newline at end of file
More information about the Mapbender_commits mailing list
