[Mapbender-commits] r2736 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 4 06:12:50 EDT 2008
Author: verenadiewald
Date: 2008-08-04 06:12:50 -0400 (Mon, 04 Aug 2008)
New Revision: 2736
   trunk/mapbender/http/javascripts/popup.js
current version
Modified: trunk/mapbender/http/javascripts/popup.js
--- trunk/mapbender/http/javascripts/popup.js	2008-08-04 09:59:43 UTC (rev 2735)
+++ trunk/mapbender/http/javascripts/popup.js	2008-08-04 10:12:50 UTC (rev 2736)
@@ -18,22 +18,25 @@
  *  width: popup width
  *  height: popup height
  *  title: popup title
- *  frameName: name of the popups iframe if it loads a frame
- *  opacity: opacity of the frame
- *  moveOpacity: opacity while the user moves or resizes the frame
+ *  frameName: name of the popups iframe if it loads a frame  (recommended to set destroy to false)
+ *  opacity: opacity of the frame default:1
+ *  moveOpacity: opacity while the user moves or resizes the frame default:0.8
  *  html:content html of the frame (not parsed if url not false)
  *  url:content url of the frame
  *  minWidth: minimum width of the popup if the user resizes it
  *  maxWidth: maximum width of the popup if the user resizes it
  *  minHeight: minimum height of the popup if the user resizes it
  *  maxHeight: maximum height of the popup if the user resizes it
- *  minTop: minimum top position if the user moves the popup
- *  minLeft: minimum left position if the user moves the popup
+ *  minTop: minimum top position if the user moves the popup default:"document"
+ *  minLeft: minimum left position if the user moves the popup default:"document"
  *  maxRight: maximum right position if the user moves/resizes the popup
  *  maxBottom: maximum bottom position if the user moves/resized the popup
- * 	style: additional styles for the popup
- *  destroy: remove dom of popup if user closes it (don't use it for iframes with framename)
+ * 	style: additional styles for the popup window
+ *  destroy: remove dom of popup if user closes it (don't use it for iframes with framename) default:true
  *  closeCallback: function that is called if the user closes the window
+ *  resizeable: allow user to change the size default:true
+ *  dragable: allow user to move the window default:true
+ *  balloon: balloon popup from top, left (disables resizeable and dragable)
  * @param {String} html the "body" of the popup, can also be "url:http://foo.de" to display a website
  * @param {Number} width width of the popup
@@ -52,7 +55,7 @@
 	this.id="popup"+String(create_pos);
-//	this.id="popup"+String(++popup_top);
+//	this.id="popup"+String(popup_top);
 	//Set defaults
 	defaults = {
@@ -60,8 +63,9 @@
 		top:25*create_pos,
 		width:300,height:250,
 		title:"Title",
-		frameName:this.id
+		frameName:this.id,
+		id:this.id
 	if(typeof(title)!='object'){
 		this.options = defaults;
@@ -109,6 +113,7 @@
 mb_popup.prototype.hide = function(){
 	$("#"+this.id).hide();
+	$("#balloon_"+this.id).hide();
@@ -116,6 +121,7 @@
 mb_popup.prototype.destroy = function(){
 	$("#"+this.id).remove();
+	$("#balloon_"+this.id).remove();
@@ -238,14 +244,14 @@
 	$.fn.mbPopup = function(options){
 		//default settings
 		defaults = {
-			left:0,top:0,
-			width:300,height:250,
+			left:0,top:0,width:300,height:250,
 			title:"",frameName:"",
 			opacity:1.0,moveOpacity:0.8,html:false,url:false,
 			minWidth:false,maxWidth:false,
 			minHeight:false,maxHeight:false,
 			minTop:"document",minLeft:"document",
 			maxRight:false,maxBottom:false,
+			dragable:true,resizeable:true,balloon:false,
 			style:null,destroy:true,
 			closeCallback:null
@@ -255,10 +261,47 @@
 		//add Styles
 		this.addClass("jqmNotice");
-		this.css({top:settings.top,
-			left:settings.left,
-			width:settings.width,
-			height:settings.height,
+		//automated settings for balloon popup
+		if(settings.balloon){
+			var dim = getScrollPos();
+			bubble_height = 80;
+			bubble_width = 100;
+			settings.resizeable = false;
+			settings.dragable = false;
+			settings.hotSpotY=settings.top;
+			settings.hotSpotX=settings.left;
+			position = 0;
+			console ={};
+			console.log = function(){};
+			if(settings.hotSpotY-settings.height-bubble_height-parseInt(this.css("border-top-width"))<dim.Y){
+				//bubble on top
+				settings.top = settings.hotSpotY+bubble_height-parseInt(this.css("border-top-width"));
+			else{
+				//bubble on bottom
+				settings.top = settings.hotSpotY-settings.height-bubble_height+(top.ie?parseInt(this.css("border-bottom-width")):-parseInt(this.css("border-top-width")));
+				position+=2;
+			if(settings.hotSpotX+settings.width+parseInt(this.css("border-left-width"))+parseInt(this.css("border-right-width"))>(dim.X+dim.wW)){
+				//bubble on right
+				settings.left = settings.hotSpotX-parseInt(this.css("border-left-width"))-parseInt(this.css("border-right-width"))-settings.width;
+				position++;
+			else{
+				//bubble on left
+				settings.left = settings.hotSpotX-parseInt(this.css("border-left-width"));
+			$("body").append("<div id='balloon_"+settings.id+"' class='balloon"+(position>=2?"B":"T")+(position%2?"R":"L")+"' style='z-index:"+(popup_top++)+";left:"+(settings.hotSpotX-(position%2?bubble_width:0))+"px;top:"+(settings.hotSpotY-(position>=2?bubble_height:0))+"px'>");
+		this.css({top:settings.top+"px",
+			left:settings.left+"px",
+			width:settings.width+"px",
+			height:settings.height+"px",
 			opacity:settings.opacity
@@ -271,13 +314,14 @@
 		else
 			html = ('<div class="scrollDiv">'+settings.html+'</div>');
-		this.html('<div class="jqmnTitle jqDrag"><h1>'+settings.title+'</h1></div><div class="jqmnContent">'+html+'</div><img src="../img/close_icon.png" class="jqmClose" alt="close" /><div class="jqResize" />');
+		this.html('<div class="jqmnTitle jqDrag"><h1>'+settings.title+'</h1></div><div class="jqmnContent">'+html+'</div><img src="../img/close_icon.png" class="jqmClose" alt="close" />'+(settings.resizeable?'<div class="jqResize" />':''));
 		var data = {El:this,fY:settings.minTop,fX:settings.minLeft,tX:settings.maxRight,tY:settings.maxBottom,
 			fW:settings.minWidth,tW:settings.maxWidth,fH:settings.minHeight,tH:settings.maxHeight,
 			destroy:settings.destroy,opacity:settings.opacity,moveOpacity:settings.moveOpacity,close:settings.closeCallback}
 		//Make window Dragable
+		if(settings.dragable)
 		$(".jqDrag", this).bind('mousedown',data,function(event){
 			//set to top
 			event.data.El.css("z-index",popup_top++);
@@ -290,10 +334,11 @@
 			var data = $.mbPopupFn.parseDimensions(event);
 			//bind mouse events to popup
-			$().bind("mousemove",data,$.mbPopupFn.drag).bind('mouseup',event.data,$.mbPopupFn.stopdrag);
+				$().bind("mousemove",$.extend(data,{drag:true}),$.mbPopupFn.move).bind('mouseup',event.data,$.mbPopupFn.stop);
 		//Make Window resizable
+		if(settings.resizeable)
 		$(".jqResize", this).bind('mousedown',data,function(event){
 			//set to top
@@ -306,27 +351,36 @@
-			$().bind("mousemove",data,$.mbPopupFn.resize).bind('mouseup',event.data,$.mbPopupFn.stopresize);
+				$().bind("mousemove",$.extend(data,{drag:false}),$.mbPopupFn.move).bind('mouseup',event.data,$.mbPopupFn.stop);
 		//closeButton
 		$(".jqmClose", this).bind('click',data, function(event){
 			if(event.data.close)
 				event.data.close();
-			if(event.data.destroy)
+			if(event.data.destroy){
 				event.data.El.slideUp('slow', function(){$(this).remove();});
-			else
+				$("#balloon_"+event.data.El.attr("id")).remove();
+			else{
 				event.data.El.slideUp('slow');
+				$("#balloon_"+event.data.El.attr("id")).fadeOut();
 		//raise on click
-		this.click(function(){this.style.zIndex=popup_top++});
+		this.click(function(){this.style.zIndex=popup_top++;$("#balloon_"+this.id).css("z-index", popup_top++);});
+		$("#balloon_"+settings.id).click(function(){$("#"+this.id.substr(8)).css("z-index", popup_top++);this.style.zIndex=popup_top++;});
+		//raise top postition
+		popup_top++;
 	//helper functions
 	$.mbPopupFn = {
-		//on drag
-		drag:function(event){
-			//console.log("tesddt");
+		//on mouse action
+		move:function(event){
+			//drag
+			if(event.data.drag){
 			var newPos = {X:event.data.X+event.pageX-event.data.pX,
 				Y:event.data.Y+event.pageY-event.data.pY};
 			if(event.data.fX!==false&&newPos.X<event.data.fX)
@@ -339,9 +393,9 @@
 				newPos.Y=event.data.tY-event.data.H;
 			event.data.El.css({left:newPos.X,top:newPos.Y});
-		//on resize
-		resize:function(event){
+				return;
+			//resize
 			var newDim = {W:Math.max(event.pageX-event.data.pX+event.data.W,0),
 				H:Math.max(event.pageY-event.data.pY+event.data.H,0)};
 			if(event.data.fW!==false&&newDim.W<event.data.fW)
@@ -359,10 +413,10 @@
 			event.data.El.css({width:newDim.W,height:newDim.H});
-		stopdrag:function(event){
+		stop:function(event){
 			event.data.El.css('opacity',event.data.opacity)
 			$("iframe", event.data.El).show();
-			$().unbind('mousemove',$.mbPopupFn.drag).unbind('mouseup',$.mbPopupFn.stopdrag);
+			$().unbind('mousemove',$.mbPopupFn.move).unbind('mouseup',$.mbPopupFn.stop);
 			$("#mouse_catcher").remove();
 		stopresize:function(event){
@@ -374,7 +428,9 @@
 		//parse move and resize dimensions
 		parseDimensions:function(d){
-			return {El:d.data.El,
+			var bd = {X:parseInt($(d.data.El).css("border-left-width"))+parseInt($(d.data.El).css("border-right-width")),
+				Y:parseInt($(d.data.El).css("border-top-width"))+parseInt($(d.data.El).css("border-bottom-width"))};
+			ret = {El:d.data.El,
 				fX:(d.data.fX=="window"?dim.X:(d.data.fX=="document"?0:(d.data.fX<0?dim.dW-d.data.fX:d.data.fX))),
 				fY:(d.data.fX=="window"?dim.Y:(d.data.fY=="document"?0:(d.data.fY<0?dim.dH-d.data.fY:d.data.fY))),
 				tX:(d.data.tX=="window"?dim.X+dim.wW:(d.data.tX=="document"?dim.dW:(d.data.tX<0?dim.dW-d.data.tX:d.data.tX))),
@@ -389,6 +445,9 @@
 				H:parseInt(d.data.El.css("height")),
 				pX:d.pageX,pY:d.pageY
+			if(ret.tX)ret.tX-=bd.X;
+			if(ret.tY)ret.tY-=bd.Y;
+			return ret;
More information about the Mapbender_commits mailing list
