[Mapbender-commits] r2737 - branches/spsneo_dev/build
svn_mapbender at osgeo.org
Mon Aug 4 11:25:28 EDT 2008
Author: spsneo
Date: 2008-08-04 11:25:28 -0400 (Mon, 04 Aug 2008)
New Revision: 2737
branches/spsneo_dev/build/checksum-utils.inc
minor modifications
Modified: branches/spsneo_dev/build/checksum-utils.inc
--- branches/spsneo_dev/build/checksum-utils.inc 2008-08-04 10:12:50 UTC (rev 2736)
+++ branches/spsneo_dev/build/checksum-utils.inc 2008-08-04 15:25:28 UTC (rev 2737)
@@ -2,6 +2,7 @@
function build_checksum($dir_path) {
+ #This array holds the file-name and sha1 checksum for the files in the current directory
$file_arr = array();
//remove slash if it is there at the end of the path
@@ -9,6 +10,7 @@
$dir_path = substr($dir_path, 0 , -1);
if(!is_dir($dir_path)) {
echo $dir_path." is not a valid directory\n";
return FALSE;
More information about the Mapbender_commits
