[Mapbender-commits] r2738 - in branches/2.5/http: frames php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Aug 5 03:59:34 EDT 2008
Author: christoph
Date: 2008-08-05 03:59:34 -0400 (Tue, 05 Aug 2008)
New Revision: 2738
   branches/2.5/http/frames/login.php
   branches/2.5/http/php/mod_logout.php
http://trac.osgeo.org/mapbender/ticket/121
Modified: branches/2.5/http/frames/login.php
--- branches/2.5/http/frames/login.php	2008-08-04 15:25:28 UTC (rev 2737)
+++ branches/2.5/http/frames/login.php	2008-08-05 07:59:34 UTC (rev 2738)
@@ -166,7 +166,12 @@
 			#only one gui is provided
 			if(count($arrayGUIs) == 1){
-				$myURL = "Location: http://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/index.php?".strip_tags (SID)."&gui_id=".$arrayGUIs[0];
+				if (isset($_SERVER["HTTPS"]) && $_SERVER["HTTPS"] == "on") {
+					$myURL = "Location: https://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/index.php?".strip_tags (SID)."&gui_id=".$arrayGUIs[0];
+				else {
+					$myURL = "Location: http://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/index.php?".strip_tags (SID)."&gui_id=".$arrayGUIs[0];
 				# params for the initial call
 				if(isset($_REQUEST["mb_myBBOX"])){
 					$myURL .= "&mb_myBBOX=".$_REQUEST["mb_myBBOX"];
@@ -186,7 +191,12 @@
 		$v = array($name);
 		$t = array('s');
 		db_prep_query($sql_set_cnt,$v,$t);
-		header ("Location: http://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/login.php?name=".$name);
+			header ("Location: https://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/login.php?name=".$name);
+		else {
+			header ("Location: http://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/login.php?name=".$name);
 		exit();
Modified: branches/2.5/http/php/mod_logout.php
--- branches/2.5/http/php/mod_logout.php	2008-08-04 15:25:28 UTC (rev 2737)
+++ branches/2.5/http/php/mod_logout.php	2008-08-05 07:59:34 UTC (rev 2738)
@@ -22,22 +22,36 @@
 ob_start();
 require_once(dirname(__FILE__)."/../include/dyn_php.php");
 ignore_user_abort();
 if (isset($_COOKIE[session_name()])) {
     setcookie(session_name(), '', time()-42000, '/');
 session_destroy();
 $dir = preg_replace("/\\\/","/", dirname($_SERVER['PHP_SELF']));
 if (isset($logout_location) && $logout_location != ''){
 	header("Location: ".$logout_location);
 else {
-   if (is_file(dirname($_SERVER['PHP_SELF'])."/login.php")) {
-      header("Location: http://".$_SERVER['HTTP_HOST'].$dir."/login.php");
-   else {
-      header("Location: http://".$_SERVER['HTTP_HOST'].preg_replace("/\/php/","/frames",$dir)."/login.php");
+	if (is_file(dirname($_SERVER['PHP_SELF'])."/login.php")) {
+			header("Location: https://".$_SERVER['HTTP_HOST'].$dir."/login.php");
+		else {
+			header("Location: http://".$_SERVER['HTTP_HOST'].$dir."/login.php");
+	else {
+			header("Location: https://".$_SERVER['HTTP_HOST'].preg_replace("/\/php/","/frames",$dir)."/login.php");
+		else {
+			header("Location: http://".$_SERVER['HTTP_HOST'].preg_replace("/\/php/","/frames",$dir)."/login.php");
\ No newline at end of file
More information about the Mapbender_commits mailing list
