[Mapbender-commits] r2777 - branches/2.5/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Aug 13 17:58:13 EDT 2008
Author: astrid_emde
Date: 2008-08-13 17:58:13 -0400 (Wed, 13 Aug 2008)
New Revision: 2777
   branches/2.5/http/php/nestedSets.php
bugs fixed. have a look at:
http://trac.osgeo.org/mapbender/ticket/179#comment:8
still two errors remain
Modified: branches/2.5/http/php/nestedSets.php
--- branches/2.5/http/php/nestedSets.php	2008-08-13 17:07:19 UTC (rev 2776)
+++ branches/2.5/http/php/nestedSets.php	2008-08-13 21:58:13 UTC (rev 2777)
@@ -54,16 +54,16 @@
 	if(value == 'insert'){
 		if(document.forms[0].title.value == ''){alert("Bitte geben Sie einen Titel an."); permission = false; return;}
-		if(document.forms[0].left.value == ''){alert("W�hlen Sie eine Position."); permission = false; return;}
+		if(document.forms[0].left.value == ''){alert("Wählen Sie eine Position."); permission = false; return;}
-      	if(document.forms[0].title.value == ''){alert("Please insert a title."); permission = false; return;}
+      	if(document.forms[0].title.value == ''){alert("<?php echo _mb("Please insert a title.") ?>"); permission = false; return;}
 		if(document.forms[0].left.value == ''){alert("Please choose a position."); permission = false; return;}
-      if(document.forms[0].wmsList.selectedIndex > 0 && document.forms[0].layer.selectedIndex == 0){alert("W�hlen Sie einen Layer."); permission = false; return;}
+      if(document.forms[0].wmsList.selectedIndex > 0 && document.forms[0].layer.selectedIndex == 0){alert("Wählen Sie einen Layer."); permission = false; return;}
 		if(permission == true){document.forms[0].action.value = "insert"; document.forms[0].submit();}
 	if(value == 'delete'){
-		//permission = confirm("Soll das Objekt mit Inhalten gel�scht werden?");
+		//permission = confirm("Soll das Objekt mit Inhalten gelöscht werden?");
 		permission = confirm("Do you want to delete the object and the content of the object?");
 		document.forms[0].action.value = "delete";
@@ -73,7 +73,7 @@
 	if(value == 'update'){
-		if(document.forms[0].left.value == ''){alert("Bitte w�hlen Sie eine Position."); permission = false; return;}
+		if(document.forms[0].left.value == ''){alert("Bitte wählen Sie eine Position."); permission = false; return;}
 		if(document.forms[0].title.value == ''){alert("Please fill in a labeling."); permission = false; return;}
@@ -83,10 +83,10 @@
 	if(value == 'add'){
-		if(document.forms[0].guiList.selectedIndex == 0){alert("Bitte w�hlen Sie eine GUI."); permission = false; return;}
-		if(document.forms[0].wmsList.selectedIndex == 0){alert("Bitte w�hlen Sie einen WMS."); permission = false; return;}
-		if(document.forms[0].layer.selectedIndex == 0){alert("Bitte w�hlen Sie eine Ebene."); permission = false; return;}
+		if(document.forms[0].guiList.selectedIndex == 0){alert("Bitte wählen Sie eine GUI."); permission = false; return;}
+		if(document.forms[0].wmsList.selectedIndex == 0){alert("Bitte wählen Sie einen WMS."); permission = false; return;}
+		if(document.forms[0].layer.selectedIndex == 0){alert("Bitte wählen Sie eine Ebene."); permission = false; return;}
 		if(document.forms[0].left.value == ''){alert("Please fill in a position."); permission = false; return;}
@@ -112,7 +112,7 @@
 if(isset($action) && $action == "insert"){
 	$temp = explode("###", $layer);
-	$sql = "SELECT rgt FROM gui_treegde WHERE lft = $1 AND fkey_gui_id = $1";
+	$sql = "SELECT rgt FROM gui_treegde WHERE lft = $1 AND fkey_gui_id = $2";
 	$v = array($left, $guiList);
 	$t = array("i", "s");
 	$res = db_prep_query($sql, $v, $t);
@@ -124,15 +124,16 @@
+#echo $sql . " 1: ".$left." 2:".$guiList."<br>";
 	$sql = "UPDATE gui_treegde SET lft=lft+2 WHERE lft >= $1 AND fkey_gui_id = $2";
 	$sql = "INSERT INTO gui_treegde(fkey_gui_id, fkey_layer_id, lft,rgt, ";
 	$sql .= "my_layer_title, layer, wms_id) VALUES($1, $2, $3, $4, $5, $6, $7)";
-		#echo $sql . "<br>";
+#echo $sql . "<br>";
 	$v = array($guiList, $temp[0], $left, ($left+1), $name, $temp[1], $wmsList);
 	$t = array("s", "s", "i", "i", "s", "s", "s");
@@ -146,7 +147,7 @@
 		db_query($sql);
 		#hier ist noch was falsch
 		$sql = "INSERT INTO gui_treegde(fkey_gui_id,my_layer_title,lft,rgt,layer) VALUES('".$guiList."','new',".$left.",".($left+1).",'new')";
-		echo $sql . "<br />";
+		#echo $sql . "<br />";
 		db_query($sql);
@@ -168,10 +169,11 @@
 		$v = array($right, $left, $right, $guiList);
 		$t = array("i", "i", "i", "s");
+#echo $sql . " r:".$right." l:".$left." 2:".$guiList."<br>";
 		$sql = "UPDATE gui_treegde SET rgt=rgt-(($1 - $2 + 1)) WHERE rgt > $3 AND fkey_gui_id = $4";
@@ -193,12 +195,12 @@
 	$sql_val = "SELECT * FROM gui_treegde WHERE lft = $1 AND fkey_gui_id = $2";
-	$res = db_prep_query($sql_val, $v, $t);
+	$res_val = db_prep_query($sql_val, $v, $t);
 	$sql = "UPDATE gui_treegde SET ";
 	$sql .= "fkey_layer_id = $1, layer = $2, wms_id =  $3 ";
 	$sql .= "WHERE lft = $4 AND fkey_gui_id = $5";
 	$v = array();
 	$t = array("s", "s", "s", "i", "s");
@@ -222,7 +224,6 @@
 	else {
 		array_push($v, $wmsList);
 	array_push($v, $left);
 	array_push($v, $guiList);
More information about the Mapbender_commits mailing list
