[Mapbender-commits] r2778 - trunk/build
svn_mapbender at osgeo.org
Thu Aug 14 04:22:39 EDT 2008
Author: christoph
Date: 2008-08-14 04:22:39 -0400 (Thu, 14 Aug 2008)
New Revision: 2778
trunk/build/mpbn25_.dia
should be complete now, testing can begin
Modified: trunk/build/mpbn25_.dia
--- trunk/build/mpbn25_.dia 2008-08-13 21:58:13 UTC (rev 2777)
+++ trunk/build/mpbn25_.dia 2008-08-14 08:22:39 UTC (rev 2778)
@@ -65,13 +65,13 @@
<dia:layer name="Background" visible="true">
<dia:object type="UML - Class" version="0" id="O0">
<dia:attribute name="obj_pos">
- <dia:point val="-26.55,-29.7"/>
+ <dia:point val="-27,-29"/>
</dia:attribute>
<dia:attribute name="obj_bb">
- <dia:rectangle val="-26.6,-29.75;-8.85,-24.85"/>
+ <dia:rectangle val="-27.05,-29.05;-9.3,-24.15"/>
</dia:attribute>
<dia:attribute name="elem_corner">
</dia:attribute>
<dia:attribute name="elem_width">
<dia:real val="17.649999999999999"/>
@@ -265,13 +265,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O1">
- <dia:point val="-46.95,-29.2"/>
+ <dia:point val="-47,-29"/>
</dia:attribute>
- <dia:rectangle val="-47,-29.25;-31,-12.35"/>
+ <dia:rectangle val="-47.05,-29.05;-31.05,-12.15"/>
</dia:attribute>
</dia:attribute>
<dia:real val="15.9"/>
@@ -810,13 +810,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O2">
- <dia:point val="-35.65,-38.55"/>
+ <dia:point val="-35,-34"/>
</dia:attribute>
- <dia:rectangle val="-35.7,-38.6;-24.6,-35.3"/>
+ <dia:rectangle val="-35.05,-34.05;-23.95,-30.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="11"/>
@@ -964,15 +964,15 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O3">
- <dia:point val="-39,-29.2498"/>
+ <dia:point val="-39.05,-29.0481"/>
</dia:attribute>
- <dia:rectangle val="-49.5,-37.45;-34.9,-28.4498"/>
+ <dia:rectangle val="-48.85,-32.9;-34.25,-28.2481"/>
</dia:attribute>
<dia:attribute name="orth_points">
- <dia:point val="-39,-36.65"/>
- <dia:point val="-35.65,-36.65"/>
+ <dia:point val="-39.05,-32.1"/>
+ <dia:point val="-35,-32.1"/>
</dia:attribute>
<dia:attribute name="orth_orient">
<dia:enum val="1"/>
@@ -1030,15 +1030,15 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O4">
- <dia:point val="-17.725,-29.7503"/>
+ <dia:point val="-18.175,-29.0503"/>
</dia:attribute>
- <dia:rectangle val="-25.4,-37.45;-10.8,-28.9503"/>
+ <dia:rectangle val="-24.75,-32.9;-10.15,-28.2503"/>
</dia:attribute>
- <dia:point val="-17.725,-36.65"/>
- <dia:point val="-24.65,-36.65"/>
+ <dia:point val="-18.175,-32.1"/>
+ <dia:point val="-24,-32.1"/>
</dia:attribute>
<dia:enum val="1"/>
@@ -1096,13 +1096,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O5">
- <dia:point val="-47.1157,-6.3175"/>
+ <dia:point val="-47,-6"/>
</dia:attribute>
- <dia:rectangle val="-47.1657,-7.2675;-1.3157,-4.0675"/>
+ <dia:rectangle val="-47.05,-6.95;-1.2,-3.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="45.75"/>
@@ -1131,7 +1131,7 @@
<dia:real val="0.80000000000000004"/>
</dia:attribute>
<dia:attribute name="pos">
- <dia:point val="-46.8157,-4.675"/>
+ <dia:point val="-46.7,-4.3575"/>
</dia:attribute>
<dia:attribute name="color">
<dia:color val="#000000"/>
@@ -1144,13 +1144,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O6">
- <dia:point val="-47.1307,-2.7025"/>
+ <dia:point val="-47,-2"/>
</dia:attribute>
- <dia:rectangle val="-47.1807,-3.6525;-15.6807,-0.4525"/>
+ <dia:rectangle val="-47.05,-2.95;-15.55,0.25"/>
</dia:attribute>
</dia:attribute>
<dia:real val="31.400000000000002"/>
@@ -1179,7 +1179,7 @@
</dia:attribute>
- <dia:point val="-46.8307,-1.06"/>
+ <dia:point val="-46.7,-0.3575"/>
</dia:attribute>
@@ -1192,13 +1192,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O7">
- <dia:point val="-47.1,-10.75"/>
+ <dia:point val="-47,-11"/>
</dia:attribute>
- <dia:rectangle val="-47.15,-11.7;-14.25,-7.7"/>
+ <dia:rectangle val="-47.05,-11.95;-14.15,-7.95"/>
</dia:attribute>
</dia:attribute>
<dia:real val="32.800000000000004"/>
@@ -1228,7 +1228,7 @@
</dia:attribute>
- <dia:point val="-46.8,-9.1075"/>
+ <dia:point val="-46.7,-9.3575"/>
</dia:attribute>
@@ -1241,13 +1241,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O8">
- <dia:point val="-26.4574,-15.15"/>
+ <dia:point val="-27,-14"/>
</dia:attribute>
- <dia:rectangle val="-26.5074,-16.1;6.0426,-12.9"/>
+ <dia:rectangle val="-27.05,-14.95;5.5,-11.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="32.450000000000003"/>
@@ -1276,7 +1276,7 @@
</dia:attribute>
- <dia:point val="-26.1574,-13.5075"/>
+ <dia:point val="-26.7,-12.3575"/>
</dia:attribute>
@@ -1289,13 +1289,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O9">
- <dia:point val="-26.5074,-18.875"/>
+ <dia:point val="-27,-18"/>
</dia:attribute>
- <dia:rectangle val="-26.5574,-19.825;20.6926,-16.625"/>
+ <dia:rectangle val="-27.05,-18.95;20.2,-15.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="47.149999999999999"/>
@@ -1324,7 +1324,7 @@
</dia:attribute>
- <dia:point val="-26.2074,-17.2325"/>
+ <dia:point val="-26.7,-16.3575"/>
</dia:attribute>
@@ -1337,13 +1337,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O10">
- <dia:point val="-26.5574,-23.175"/>
+ <dia:point val="-27,-23"/>
</dia:attribute>
- <dia:rectangle val="-26.6074,-24.125;7.3426,-20.125"/>
+ <dia:rectangle val="-27.05,-23.95;6.9,-19.95"/>
</dia:attribute>
</dia:attribute>
<dia:real val="33.850000000000001"/>
@@ -1373,7 +1373,7 @@
</dia:attribute>
- <dia:point val="-26.2574,-21.5325"/>
+ <dia:point val="-26.7,-21.3575"/>
</dia:attribute>
@@ -1386,13 +1386,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O11">
- <dia:point val="30.45,-40.75"/>
+ <dia:point val="31,-39"/>
</dia:attribute>
- <dia:rectangle val="30.4,-40.8;46.4,-35.9"/>
+ <dia:rectangle val="30.95,-39.05;46.95,-34.15"/>
</dia:attribute>
</dia:attribute>
@@ -1586,13 +1586,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O12">
- <dia:point val="31.5,-30.9"/>
+ <dia:point val="31,-30"/>
</dia:attribute>
- <dia:rectangle val="31.45,-30.95;45.35,-12.45"/>
+ <dia:rectangle val="30.95,-30.05;44.85,-11.55"/>
</dia:attribute>
</dia:attribute>
<dia:real val="13.800000000000001"/>
@@ -2243,13 +2243,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O13">
- <dia:point val="32.9,-8.6"/>
+ <dia:point val="49,-30"/>
</dia:attribute>
- <dia:rectangle val="32.85,-8.65;43.95,-2.15"/>
+ <dia:rectangle val="48.95,-30.05;60.05,-23.55"/>
</dia:attribute>
</dia:attribute>
@@ -2555,21 +2555,19 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O14">
- <dia:point val="38.4,-12.4497"/>
+ <dia:point val="44.8504,-20.8"/>
</dia:attribute>
- <dia:rectangle val="38.35,-12.4497;51.2,-8.57969"/>
+ <dia:rectangle val="44.8004,-24.35;67.3,-20.285"/>
</dia:attribute>
- <dia:point val="38.4,-8.6504"/>
+ <dia:point val="54.5,-20.8"/>
+ <dia:point val="54.5,-23.6"/>
</dia:attribute>
<dia:enum val="0"/>
<dia:enum val="1"/>
- <dia:enum val="0"/>
</dia:attribute>
<dia:attribute name="autorouting">
<dia:boolean val="true"/>
@@ -2618,26 +2616,26 @@
</dia:attribute>
<dia:connections>
<dia:connection handle="0" to="O12" connection="50"/>
- <dia:connection handle="1" to="O13" connection="20"/>
+ <dia:connection handle="1" to="O13" connection="6"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O15">
- <dia:point val="38.4,-35.95"/>
+ <dia:point val="38.95,-34.2"/>
</dia:attribute>
- <dia:rectangle val="38.35,-35.95;51.2,-30.8293"/>
+ <dia:rectangle val="37.15,-34.25;50.7,-29.25"/>
</dia:attribute>
- <dia:point val="38.4,-30.9"/>
+ <dia:point val="38.95,-32.1"/>
+ <dia:point val="37.9,-32.1"/>
+ <dia:point val="37.9,-30"/>
</dia:attribute>
+ <dia:enum val="1"/>
<dia:enum val="0"/>
<dia:enum val="1"/>
</dia:attribute>
@@ -2691,13 +2689,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O16">
- <dia:point val="-4.2,-44.75"/>
+ <dia:point val="1,-39"/>
</dia:attribute>
- <dia:rectangle val="-4.25,-44.8;9.65,-40.7"/>
+ <dia:rectangle val="0.95,-39.05;14.85,-34.95"/>
</dia:attribute>
</dia:attribute>
@@ -2868,16 +2866,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O17">
- <dia:point val="-46.95,-28.5"/>
+ <dia:point val="-47,-28.3"/>
</dia:attribute>
- <dia:rectangle val="-50.8807,-42.8;-3.45,-27.985"/>
+ <dia:rectangle val="-50.8807,-37.05;1.75,-27.785"/>
</dia:attribute>
- <dia:point val="-50.8307,-28.5"/>
- <dia:point val="-50.8307,-42.05"/>
- <dia:point val="-4.2,-42.05"/>
+ <dia:point val="-50.8307,-28.3"/>
+ <dia:point val="-50.8307,-36.3"/>
+ <dia:point val="1,-36.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -2936,16 +2934,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O18">
- <dia:point val="30.45,-37.25"/>
+ <dia:point val="31,-34.7"/>
</dia:attribute>
- <dia:rectangle val="8.85,-42.8;30.5,-36.735"/>
+ <dia:rectangle val="14.05,-37.05;31.05,-34.185"/>
</dia:attribute>
- <dia:point val="21.6758,-37.25"/>
- <dia:point val="21.6758,-42.05"/>
- <dia:point val="9.6,-42.05"/>
+ <dia:point val="19,-34.7"/>
+ <dia:point val="19,-36.3"/>
+ <dia:point val="14.8,-36.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -2998,19 +2996,19 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O11" connection="12"/>
+ <dia:connection handle="0" to="O11" connection="14"/>
<dia:connection handle="1" to="O16" connection="11"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Class" version="0" id="O19">
- <dia:point val="72.85,-129.4"/>
+ <dia:point val="73,-129"/>
</dia:attribute>
- <dia:rectangle val="72.8,-129.45;90.2,-102.15"/>
+ <dia:rectangle val="72.95,-129.05;90.35,-101.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="17.300000000000001"/>
@@ -3848,13 +3846,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O20">
- <dia:point val="72.834,-95.8675"/>
+ <dia:point val="73,-95"/>
</dia:attribute>
- <dia:rectangle val="72.784,-96.8175;113.034,-93.6175"/>
+ <dia:rectangle val="72.95,-95.95;113.2,-92.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="40.149999999999999"/>
@@ -3883,7 +3881,7 @@
</dia:attribute>
- <dia:point val="73.134,-94.225"/>
+ <dia:point val="73.3,-93.3575"/>
</dia:attribute>
@@ -3896,13 +3894,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O21">
- <dia:point val="72.819,-91.9525"/>
+ <dia:point val="73,-91"/>
</dia:attribute>
- <dia:rectangle val="72.769,-92.9025;100.069,-89.7025"/>
+ <dia:rectangle val="72.95,-91.95;100.25,-88.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="27.200000000000003"/>
@@ -3931,7 +3929,7 @@
</dia:attribute>
- <dia:point val="73.119,-90.31"/>
+ <dia:point val="73.3,-89.3575"/>
</dia:attribute>
@@ -3944,13 +3942,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O22">
- <dia:point val="72.85,-100.35"/>
+ <dia:point val="73,-100"/>
</dia:attribute>
- <dia:rectangle val="72.8,-101.3;101.5,-97.3"/>
+ <dia:rectangle val="72.95,-100.95;101.65,-96.95"/>
</dia:attribute>
</dia:attribute>
<dia:real val="28.600000000000001"/>
@@ -3980,7 +3978,7 @@
</dia:attribute>
- <dia:point val="73.15,-98.7075"/>
+ <dia:point val="73.3,-98.3575"/>
</dia:attribute>
@@ -3993,13 +3991,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O23">
- <dia:point val="53.35,-78.75"/>
+ <dia:point val="53,-79"/>
</dia:attribute>
- <dia:rectangle val="53.3,-78.8;67.9,-67.5"/>
+ <dia:rectangle val="52.95,-79.05;67.55,-67.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="14.5"/>
@@ -4377,13 +4375,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O24">
- <dia:point val="36.35,-88.75"/>
+ <dia:point val="34,-89"/>
</dia:attribute>
- <dia:rectangle val="36.3,-88.8;50.55,-77.5"/>
+ <dia:rectangle val="33.95,-89.05;48.2,-77.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="14.15"/>
@@ -4761,13 +4759,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O25">
- <dia:point val="117.45,-50.7"/>
+ <dia:point val="105,-48"/>
</dia:attribute>
- <dia:rectangle val="117.4,-50.75;134.8,-28.25"/>
+ <dia:rectangle val="104.95,-48.05;122.35,-25.55"/>
</dia:attribute>
</dia:attribute>
@@ -5467,16 +5465,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O26">
- <dia:point val="30.45,-40.05"/>
+ <dia:point val="31,-38.3"/>
</dia:attribute>
- <dia:rectangle val="22.4572,-83.9;37.0572,-39.535"/>
+ <dia:rectangle val="20.0997,-84.15;34.6997,-37.785"/>
</dia:attribute>
- <dia:point val="28.4433,-40.05"/>
- <dia:point val="28.4433,-83.15"/>
- <dia:point val="36.3072,-83.15"/>
+ <dia:point val="28,-38.3"/>
+ <dia:point val="28,-83.4"/>
+ <dia:point val="33.9497,-83.4"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -5535,15 +5533,15 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O27">
- <dia:point val="53.35,-73.65"/>
+ <dia:point val="53,-74.7"/>
</dia:attribute>
- <dia:rectangle val="42.675,-78.3;56.225,-72.85"/>
+ <dia:rectangle val="40.325,-78.55;53.875,-74.185"/>
</dia:attribute>
- <dia:point val="43.425,-73.65"/>
- <dia:point val="43.425,-77.55"/>
+ <dia:point val="41.075,-74.7"/>
+ <dia:point val="41.075,-77.8"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -5595,22 +5593,22 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O23" connection="16"/>
+ <dia:connection handle="0" to="O23" connection="14"/>
<dia:connection handle="1" to="O24" connection="6"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O28">
- <dia:point val="72.85,-105.9"/>
+ <dia:point val="73,-105.5"/>
</dia:attribute>
- <dia:rectangle val="67.1,-106.985;81.7,-77.1325"/>
+ <dia:rectangle val="66.75,-106.585;81.35,-77.3825"/>
</dia:attribute>
- <dia:point val="70.35,-105.9"/>
- <dia:point val="70.35,-78.05"/>
- <dia:point val="67.85,-78.05"/>
+ <dia:point val="71,-105.5"/>
+ <dia:point val="71,-78.3"/>
+ <dia:point val="67.5,-78.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -5618,7 +5616,7 @@
<dia:enum val="0"/>
</dia:attribute>
- <dia:boolean val="true"/>
+ <dia:boolean val="false"/>
</dia:attribute>
<dia:attribute name="name">
<dia:string>##</dia:string>
@@ -5669,13 +5667,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O29">
- <dia:point val="79.7299,-42.635"/>
+ <dia:point val="79,-41"/>
</dia:attribute>
- <dia:rectangle val="79.6799,-42.685;90.7799,-39.385"/>
+ <dia:rectangle val="78.95,-41.05;90.05,-37.75"/>
</dia:attribute>
</dia:attribute>
@@ -5823,16 +5821,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O30">
- <dia:point val="46.35,-38.85"/>
+ <dia:point val="46.9,-38.3"/>
</dia:attribute>
- <dia:rectangle val="46.3,-40.685;80.4799,-38.335"/>
+ <dia:rectangle val="46.9,-39.385;79.0707,-37.3825"/>
</dia:attribute>
- <dia:point val="63.0399,-38.85"/>
- <dia:point val="63.0399,-39.935"/>
- <dia:point val="79.7299,-39.935"/>
+ <dia:point val="79,-38.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -5885,22 +5883,22 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O11" connection="9"/>
+ <dia:connection handle="0" to="O11" connection="4"/>
<dia:connection handle="1" to="O29" connection="10"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O31">
- <dia:point val="117.45,-45.6"/>
+ <dia:point val="105,-42.9"/>
</dia:attribute>
- <dia:rectangle val="115.091,-46.685;164.322,-10.6675"/>
+ <dia:rectangle val="102.7,-43.985;152.75,-10.5825"/>
</dia:attribute>
- <dia:point val="115.141,-45.6"/>
- <dia:point val="115.141,-11.585"/>
- <dia:point val="163.572,-11.585"/>
+ <dia:point val="102.941,-42.9"/>
+ <dia:point val="102.941,-11.5"/>
+ <dia:point val="152,-11.5"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -5954,18 +5952,18 @@
</dia:attribute>
<dia:connections>
<dia:connection handle="0" to="O25" connection="16"/>
- <dia:connection handle="1" to="O41" connection="8"/>
+ <dia:connection handle="1" to="O41" connection="12"/>
</dia:connections>
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O32">
- <dia:point val="117.545,-21.29"/>
+ <dia:point val="105,-19"/>
</dia:attribute>
- <dia:rectangle val="117.495,-22.24;157.745,-19.04"/>
+ <dia:rectangle val="104.95,-19.95;145.2,-16.75"/>
</dia:attribute>
</dia:attribute>
@@ -5994,7 +5992,7 @@
</dia:attribute>
- <dia:point val="117.845,-19.6475"/>
+ <dia:point val="105.3,-17.3575"/>
</dia:attribute>
@@ -6007,13 +6005,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O33">
- <dia:point val="117.53,-17.525"/>
+ <dia:point val="105,-15"/>
</dia:attribute>
- <dia:rectangle val="117.48,-18.475;144.78,-15.275"/>
+ <dia:rectangle val="104.95,-15.95;132.25,-12.75"/>
</dia:attribute>
</dia:attribute>
@@ -6042,7 +6040,7 @@
</dia:attribute>
- <dia:point val="117.83,-15.8825"/>
+ <dia:point val="105.3,-13.3575"/>
</dia:attribute>
@@ -6055,13 +6053,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O34">
- <dia:point val="117.611,-25.7725"/>
+ <dia:point val="105,-24"/>
</dia:attribute>
- <dia:rectangle val="117.561,-26.7225;146.261,-22.7225"/>
+ <dia:rectangle val="104.95,-24.95;133.65,-20.95"/>
</dia:attribute>
</dia:attribute>
@@ -6091,7 +6089,7 @@
</dia:attribute>
- <dia:point val="117.911,-24.13"/>
+ <dia:point val="105.3,-22.3575"/>
</dia:attribute>
@@ -6104,13 +6102,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O35">
- <dia:point val="-4.205,-40.0725"/>
+ <dia:point val="1,-34"/>
</dia:attribute>
- <dia:rectangle val="-4.255,-40.1225;10.695,-36.0225"/>
+ <dia:rectangle val="0.95,-34.05;15.9,-29.95"/>
</dia:attribute>
</dia:attribute>
<dia:real val="14.85"/>
@@ -6281,22 +6279,24 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O36">
- <dia:point val="-8.9,-27"/>
+ <dia:point val="-9.35,-26.3"/>
</dia:attribute>
- <dia:rectangle val="-8.95,-36.8225;16.02,-26.485"/>
+ <dia:rectangle val="-12.85,-32.85;1.75,-25.785"/>
</dia:attribute>
- <dia:point val="3.22,-27"/>
- <dia:point val="3.22,-36.0725"/>
+ <dia:point val="-4.175,-26.3"/>
+ <dia:point val="-4.175,-32.1"/>
+ <dia:point val="1,-32.1"/>
</dia:attribute>
<dia:enum val="0"/>
<dia:enum val="1"/>
+ <dia:enum val="0"/>
</dia:attribute>
- <dia:boolean val="false"/>
+ <dia:boolean val="true"/>
</dia:attribute>
@@ -6342,21 +6342,21 @@
</dia:attribute>
<dia:connections>
<dia:connection handle="0" to="O0" connection="11"/>
- <dia:connection handle="1" to="O35" connection="6"/>
+ <dia:connection handle="1" to="O35" connection="8"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O37">
- <dia:point val="30.45,-36.45"/>
+ <dia:point val="31,-34.2"/>
</dia:attribute>
- <dia:rectangle val="9.94546,-38.8225;30.5,-35.935"/>
+ <dia:rectangle val="15.1,-35.285;31.05,-30.3825"/>
</dia:attribute>
- <dia:point val="20.5727,-36.45"/>
- <dia:point val="20.5727,-38.0725"/>
- <dia:point val="10.6955,-38.0725"/>
+ <dia:point val="19,-34.2"/>
+ <dia:point val="19,-31.3"/>
+ <dia:point val="15.85,-31.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -6364,7 +6364,7 @@
<dia:enum val="0"/>
</dia:attribute>
</dia:attribute>
@@ -6409,19 +6409,19 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O11" connection="14"/>
- <dia:connection handle="1" to="O35" connection="14"/>
+ <dia:connection handle="0" to="O11" connection="5"/>
+ <dia:connection handle="1" to="O35" connection="11"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Class" version="0" id="O38">
- <dia:point val="36.245,-99.8975"/>
+ <dia:point val="34,-100"/>
</dia:attribute>
- <dia:rectangle val="36.195,-99.9475;55.345,-90.2475"/>
+ <dia:rectangle val="33.95,-100.05;53.1,-90.35"/>
</dia:attribute>
</dia:attribute>
<dia:real val="19.050000000000001"/>
@@ -6819,16 +6819,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O39">
- <dia:point val="30.45,-38.85"/>
+ <dia:point val="31,-37.1"/>
</dia:attribute>
- <dia:rectangle val="22.395,-97.9475;36.995,-38.335"/>
+ <dia:rectangle val="20.15,-98.05;34.75,-36.585"/>
</dia:attribute>
- <dia:point val="26.4933,-38.85"/>
- <dia:point val="26.4933,-97.1975"/>
- <dia:point val="36.245,-97.1975"/>
+ <dia:point val="26,-37.1"/>
+ <dia:point val="26,-97.3"/>
+ <dia:point val="34,-97.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -6887,16 +6887,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O40">
- <dia:point val="72.85,-108.3"/>
+ <dia:point val="73,-107.9"/>
</dia:attribute>
- <dia:rectangle val="54.5953,-109.385;72.9,-94.18"/>
+ <dia:rectangle val="52.3503,-108.985;73.05,-94.2825"/>
</dia:attribute>
- <dia:point val="68.5916,-108.3"/>
- <dia:point val="68.5916,-95.0975"/>
- <dia:point val="55.3453,-95.0975"/>
+ <dia:point val="69,-107.9"/>
+ <dia:point val="69,-95.2"/>
+ <dia:point val="53.1003,-95.2"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -6955,13 +6955,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O41">
- <dia:point val="163.572,-13.485"/>
+ <dia:point val="152,-15"/>
</dia:attribute>
- <dia:rectangle val="163.522,-13.535;178.822,-1.435"/>
+ <dia:rectangle val="151.95,-15.05;167.25,-2.95"/>
</dia:attribute>
</dia:attribute>
<dia:real val="15.199999999999999"/>
@@ -7362,13 +7362,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O42">
- <dia:point val="164.822,-46.285"/>
+ <dia:point val="152,-43"/>
</dia:attribute>
- <dia:rectangle val="164.772,-46.335;180.772,-39.035"/>
+ <dia:rectangle val="151.95,-43.05;167.95,-35.75"/>
</dia:attribute>
</dia:attribute>
@@ -7631,16 +7631,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O43">
- <dia:point val="134.75,-46.4"/>
+ <dia:point val="122.3,-43.7"/>
</dia:attribute>
- <dia:rectangle val="134.7,-47.485;165.572,-41.0675"/>
+ <dia:rectangle val="122.25,-44.785;152.75,-37.7825"/>
</dia:attribute>
- <dia:point val="149.786,-46.4"/>
- <dia:point val="149.786,-41.985"/>
- <dia:point val="164.822,-41.985"/>
+ <dia:point val="137.15,-43.7"/>
+ <dia:point val="137.15,-38.7"/>
+ <dia:point val="152,-38.7"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -7699,16 +7699,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O44">
- <dia:point val="46.35,-38.05"/>
+ <dia:point val="46.9,-35.5"/>
</dia:attribute>
- <dia:rectangle val="46.3,-39.135;80.4754,-36.1175"/>
+ <dia:rectangle val="46.85,-36.585;79.75,-34.3825"/>
</dia:attribute>
- <dia:point val="63.0377,-38.05"/>
- <dia:point val="63.0377,-37.035"/>
- <dia:point val="79.7254,-37.035"/>
+ <dia:point val="62.95,-35.5"/>
+ <dia:point val="62.95,-35.3"/>
+ <dia:point val="79,-35.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -7761,22 +7761,22 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O11" connection="11"/>
+ <dia:connection handle="0" to="O11" connection="13"/>
<dia:connection handle="1" to="O65" connection="3"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O45">
- <dia:point val="117.45,-47.2"/>
+ <dia:point val="105,-44.5"/>
</dia:attribute>
- <dia:rectangle val="89.9799,-48.285;117.5,-39.0175"/>
+ <dia:rectangle val="89.25,-45.585;105.05,-37.3825"/>
</dia:attribute>
- <dia:point val="104.09,-47.2"/>
- <dia:point val="104.09,-39.935"/>
- <dia:point val="90.7299,-39.935"/>
+ <dia:point val="100.89,-44.5"/>
+ <dia:point val="100.89,-38.3"/>
+ <dia:point val="90,-38.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -7784,7 +7784,7 @@
<dia:enum val="0"/>
</dia:attribute>
</dia:attribute>
@@ -7835,13 +7835,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O46">
- <dia:point val="184.658,-61.11"/>
+ <dia:point val="173,-58"/>
</dia:attribute>
- <dia:rectangle val="184.608,-61.16;199.908,-56.26"/>
+ <dia:rectangle val="172.95,-58.05;188.25,-53.15"/>
</dia:attribute>
</dia:attribute>
@@ -8035,19 +8035,17 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O47">
- <dia:point val="180.722,-43.585"/>
+ <dia:point val="159.95,-43"/>
</dia:attribute>
- <dia:rectangle val="170.808,-59.96;185.822,-43.07"/>
+ <dia:rectangle val="159.15,-56.9;173.75,-42.2"/>
</dia:attribute>
- <dia:point val="182.69,-43.585"/>
- <dia:point val="182.69,-59.21"/>
- <dia:point val="184.658,-59.21"/>
+ <dia:point val="159.95,-56.1"/>
+ <dia:point val="173,-56.1"/>
</dia:attribute>
<dia:enum val="1"/>
<dia:enum val="0"/>
</dia:attribute>
@@ -8097,19 +8095,19 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O42" connection="11"/>
+ <dia:connection handle="0" to="O42" connection="1"/>
<dia:connection handle="1" to="O46" connection="8"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Class" version="0" id="O48">
- <dia:point val="44.609,-112.01"/>
+ <dia:point val="34,-112"/>
</dia:attribute>
- <dia:rectangle val="44.559,-112.06;59.159,-107.96"/>
+ <dia:rectangle val="33.95,-112.05;48.55,-107.95"/>
</dia:attribute>
</dia:attribute>
@@ -8280,16 +8278,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O49">
- <dia:point val="72.85,-122.7"/>
+ <dia:point val="73,-122.3"/>
</dia:attribute>
- <dia:rectangle val="58.4094,-123.785;73.0094,-109.092"/>
+ <dia:rectangle val="47.7993,-123.385;73.05,-109.082"/>
</dia:attribute>
- <dia:point val="66.0047,-122.7"/>
- <dia:point val="66.0047,-110.01"/>
- <dia:point val="59.1594,-110.01"/>
+ <dia:point val="63,-122.3"/>
+ <dia:point val="63,-110"/>
+ <dia:point val="48.5493,-110"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -8297,7 +8295,7 @@
<dia:enum val="0"/>
</dia:attribute>
</dia:attribute>
@@ -8348,13 +8346,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O50">
- <dia:point val="44.514,-106.81"/>
+ <dia:point val="34,-107"/>
</dia:attribute>
- <dia:rectangle val="44.464,-106.86;57.314,-103.56"/>
+ <dia:rectangle val="33.95,-107.05;46.8,-103.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="12.75"/>
@@ -8502,16 +8500,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O51">
- <dia:point val="72.85,-117.9"/>
+ <dia:point val="73,-117.5"/>
</dia:attribute>
- <dia:rectangle val="56.5636,-118.985;72.9,-104.293"/>
+ <dia:rectangle val="46.0489,-118.585;73.05,-104.483"/>
</dia:attribute>
- <dia:point val="67.6916,-117.9"/>
- <dia:point val="67.6916,-105.21"/>
- <dia:point val="57.3136,-105.21"/>
+ <dia:point val="67,-117.5"/>
+ <dia:point val="67,-105.4"/>
+ <dia:point val="46.7989,-105.4"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -8570,13 +8568,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O52">
- <dia:point val="44.614,-116.41"/>
+ <dia:point val="34,-116"/>
</dia:attribute>
- <dia:rectangle val="44.564,-116.46;61.264,-113.16"/>
+ <dia:rectangle val="33.95,-116.05;50.65,-112.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="16.600000000000001"/>
@@ -8724,16 +8722,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O53">
- <dia:point val="72.85,-127.5"/>
+ <dia:point val="73,-127.1"/>
</dia:attribute>
- <dia:rectangle val="60.5128,-128.585;75.1128,-113.893"/>
+ <dia:rectangle val="49.8992,-128.185;73.05,-113.483"/>
</dia:attribute>
- <dia:point val="64.4416,-127.5"/>
- <dia:point val="64.4416,-114.81"/>
- <dia:point val="61.2628,-114.81"/>
+ <dia:point val="58,-127.1"/>
+ <dia:point val="58,-114.4"/>
+ <dia:point val="50.6492,-114.4"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -8792,13 +8790,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O54">
- <dia:point val="4.864,-125.897"/>
+ <dia:point val="-47,-117"/>
</dia:attribute>
- <dia:rectangle val="4.814,-125.947;19.414,-121.847"/>
+ <dia:rectangle val="-47.05,-117.05;-32.45,-112.95"/>
</dia:attribute>
</dia:attribute>
@@ -8969,21 +8967,21 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O55">
- <dia:point val="12.114,-121.897"/>
+ <dia:point val="-32.5,-115.1"/>
</dia:attribute>
- <dia:rectangle val="12.064,-121.947;65.714,-115.66"/>
+ <dia:rectangle val="-32.55,-116.185;34.75,-114.382"/>
</dia:attribute>
- <dia:point val="12.114,-119.154"/>
- <dia:point val="52.914,-119.154"/>
- <dia:point val="52.914,-116.41"/>
+ <dia:point val="0.75,-115.1"/>
+ <dia:point val="0.75,-115.3"/>
+ <dia:point val="34,-115.3"/>
</dia:attribute>
<dia:enum val="1"/>
<dia:enum val="0"/>
- <dia:enum val="1"/>
</dia:attribute>
@@ -9031,19 +9029,19 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O54" connection="6"/>
- <dia:connection handle="1" to="O52" connection="1"/>
+ <dia:connection handle="0" to="O54" connection="9"/>
+ <dia:connection handle="1" to="O52" connection="3"/>
</dia:connections>
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O56">
- <dia:point val="184.659,-49.815"/>
+ <dia:point val="173,-46"/>
</dia:attribute>
- <dia:rectangle val="184.609,-50.765;236.059,-47.565"/>
+ <dia:rectangle val="172.95,-46.95;224.4,-43.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="51.350000000000001"/>
@@ -9072,7 +9070,7 @@
</dia:attribute>
- <dia:point val="184.959,-48.1725"/>
+ <dia:point val="173.3,-44.3575"/>
</dia:attribute>
@@ -9085,13 +9083,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O57">
- <dia:point val="184.644,-46.05"/>
+ <dia:point val="173,-42"/>
</dia:attribute>
- <dia:rectangle val="184.594,-47;217.494,-43.8"/>
+ <dia:rectangle val="172.95,-42.95;205.85,-39.75"/>
</dia:attribute>
</dia:attribute>
@@ -9120,7 +9118,7 @@
</dia:attribute>
- <dia:point val="184.944,-44.4075"/>
+ <dia:point val="173.3,-40.3575"/>
</dia:attribute>
@@ -9133,13 +9131,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O58">
- <dia:point val="184.725,-54.2975"/>
+ <dia:point val="173,-51"/>
</dia:attribute>
- <dia:rectangle val="184.675,-55.2475;220.375,-51.2475"/>
+ <dia:rectangle val="172.95,-51.95;208.65,-47.95"/>
</dia:attribute>
</dia:attribute>
<dia:real val="35.600000000000001"/>
@@ -9169,7 +9167,7 @@
</dia:attribute>
- <dia:point val="185.025,-52.655"/>
+ <dia:point val="173.3,-49.3575"/>
</dia:attribute>
@@ -9182,13 +9180,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O59">
- <dia:point val="164.859,-33.14"/>
+ <dia:point val="152,-29"/>
</dia:attribute>
- <dia:rectangle val="164.809,-34.09;221.859,-30.89"/>
+ <dia:rectangle val="151.95,-29.95;209,-26.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="56.950000000000003"/>
@@ -9217,7 +9215,7 @@
</dia:attribute>
- <dia:point val="165.159,-31.4975"/>
+ <dia:point val="152.3,-27.3575"/>
</dia:attribute>
@@ -9230,13 +9228,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O60">
- <dia:point val="164.744,-29.375"/>
+ <dia:point val="152,-25"/>
</dia:attribute>
- <dia:rectangle val="164.694,-30.325;201.794,-27.125"/>
+ <dia:rectangle val="151.95,-25.95;189.05,-22.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="37"/>
@@ -9265,7 +9263,7 @@
</dia:attribute>
- <dia:point val="165.044,-27.7325"/>
+ <dia:point val="152.3,-23.3575"/>
</dia:attribute>
@@ -9278,13 +9276,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O61">
- <dia:point val="164.825,-37.6225"/>
+ <dia:point val="152,-34"/>
</dia:attribute>
- <dia:rectangle val="164.775,-38.5725;204.675,-34.5725"/>
+ <dia:rectangle val="151.95,-34.95;191.85,-30.95"/>
</dia:attribute>
</dia:attribute>
<dia:real val="39.800000000000004"/>
@@ -9314,7 +9312,7 @@
</dia:attribute>
- <dia:point val="165.125,-35.98"/>
+ <dia:point val="152.3,-32.3575"/>
</dia:attribute>
@@ -9327,13 +9325,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O62">
- <dia:point val="53.3454,-61.34"/>
+ <dia:point val="53,-61"/>
</dia:attribute>
- <dia:rectangle val="53.2954,-62.29;96.3454,-59.09"/>
+ <dia:rectangle val="52.95,-61.95;96,-58.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="42.950000000000003"/>
@@ -9362,7 +9360,7 @@
</dia:attribute>
- <dia:point val="53.6454,-59.6975"/>
+ <dia:point val="53.3,-59.3575"/>
</dia:attribute>
@@ -9375,13 +9373,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O63">
- <dia:point val="53.3304,-57.425"/>
+ <dia:point val="53,-57"/>
</dia:attribute>
- <dia:rectangle val="53.2804,-58.375;82.6804,-55.175"/>
+ <dia:rectangle val="52.95,-57.95;82.35,-54.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="29.300000000000001"/>
@@ -9410,7 +9408,7 @@
</dia:attribute>
- <dia:point val="53.6304,-55.7825"/>
+ <dia:point val="53.3,-55.3575"/>
</dia:attribute>
@@ -9423,13 +9421,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O64">
- <dia:point val="53.3614,-65.8225"/>
+ <dia:point val="53,-66"/>
</dia:attribute>
- <dia:rectangle val="53.3114,-66.7725;84.1114,-62.7725"/>
+ <dia:rectangle val="52.95,-66.95;83.75,-62.95"/>
</dia:attribute>
</dia:attribute>
<dia:real val="30.700000000000003"/>
@@ -9459,7 +9457,7 @@
</dia:attribute>
- <dia:point val="53.6614,-64.18"/>
+ <dia:point val="53.3,-64.3575"/>
</dia:attribute>
@@ -9472,13 +9470,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O65">
- <dia:point val="79.7254,-37.735"/>
+ <dia:point val="79,-36"/>
</dia:attribute>
- <dia:rectangle val="79.6754,-37.785;90.7754,-34.485"/>
+ <dia:rectangle val="78.95,-36.05;90.05,-32.75"/>
</dia:attribute>
</dia:attribute>
@@ -9626,22 +9624,24 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O66">
- <dia:point val="163.572,-10.785"/>
+ <dia:point val="152,-9.9"/>
</dia:attribute>
- <dia:rectangle val="84.4754,-35.285;163.622,-9.985"/>
+ <dia:rectangle val="89.25,-36.05;152.05,-9.385"/>
</dia:attribute>
- <dia:point val="85.2254,-10.785"/>
- <dia:point val="85.2254,-34.535"/>
+ <dia:point val="100.94,-9.9"/>
+ <dia:point val="100.94,-35.3"/>
+ <dia:point val="90,-35.3"/>
</dia:attribute>
<dia:enum val="0"/>
<dia:enum val="1"/>
</dia:attribute>
</dia:attribute>
@@ -9686,22 +9686,22 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O41" connection="10"/>
- <dia:connection handle="1" to="O65" connection="6"/>
+ <dia:connection handle="0" to="O41" connection="16"/>
+ <dia:connection handle="1" to="O65" connection="4"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O67">
- <dia:point val="164.822,-40.385"/>
+ <dia:point val="152,-37.1"/>
</dia:attribute>
- <dia:rectangle val="149.722,-41.47;164.872,-11.8675"/>
+ <dia:rectangle val="138.15,-38.185;152.75,-12.1825"/>
</dia:attribute>
- <dia:point val="159.665,-40.385"/>
- <dia:point val="159.665,-12.785"/>
- <dia:point val="163.572,-12.785"/>
+ <dia:point val="147.465,-37.1"/>
+ <dia:point val="147.465,-13.1"/>
+ <dia:point val="152,-13.1"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -9755,18 +9755,18 @@
</dia:attribute>
<dia:connections>
<dia:connection handle="0" to="O42" connection="18"/>
- <dia:connection handle="1" to="O41" connection="3"/>
+ <dia:connection handle="1" to="O41" connection="8"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Class" version="0" id="O68">
- <dia:point val="-3.57325,-53.3225"/>
+ <dia:point val="-47,-61"/>
</dia:attribute>
- <dia:rectangle val="-3.62325,-53.3725;9.57675,-46.0725"/>
+ <dia:rectangle val="-47.05,-61.05;-33.85,-53.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="13.1"/>
@@ -9817,7 +9817,7 @@
</dia:attribute>
<dia:attribute name="fill_color">
- <dia:color val="#add8e6"/>
+ <dia:color val="#ffffff"/>
</dia:attribute>
<dia:attribute name="text_color">
@@ -10029,13 +10029,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O69">
- <dia:point val="33.2051,-52.935"/>
+ <dia:point val="34,-63"/>
</dia:attribute>
- <dia:rectangle val="33.1551,-52.985;43.5551,-44.885"/>
+ <dia:rectangle val="33.95,-63.05;44.35,-54.95"/>
</dia:attribute>
</dia:attribute>
<dia:real val="10.300000000000001"/>
@@ -10321,13 +10321,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O70">
- <dia:point val="123.17,-72.81"/>
+ <dia:point val="126,-82"/>
</dia:attribute>
- <dia:rectangle val="123.12,-72.86;136.32,-69.56"/>
+ <dia:rectangle val="125.95,-82.05;139.15,-78.75"/>
</dia:attribute>
</dia:attribute>
@@ -10524,13 +10524,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O71">
- <dia:point val="89.3079,-69.56"/>
+ <dia:point val="89,-71"/>
</dia:attribute>
- <dia:rectangle val="89.2579,-69.61;102.458,-63.91"/>
+ <dia:rectangle val="88.95,-71.05;102.15,-65.35"/>
</dia:attribute>
</dia:attribute>
@@ -10747,16 +10747,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O72">
- <dia:point val="67.85,-68.85"/>
+ <dia:point val="67.5,-71.5"/>
</dia:attribute>
- <dia:rectangle val="67.8,-69.935;90.0579,-66.7425"/>
+ <dia:rectangle val="67.45,-72.585;89.75,-69.3825"/>
</dia:attribute>
- <dia:point val="78.579,-68.85"/>
- <dia:point val="78.579,-67.66"/>
- <dia:point val="89.3079,-67.66"/>
+ <dia:point val="78,-71.5"/>
+ <dia:point val="78,-70.3"/>
+ <dia:point val="89,-70.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -10764,7 +10764,7 @@
<dia:enum val="0"/>
</dia:attribute>
</dia:attribute>
@@ -10809,19 +10809,19 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O23" connection="29"/>
- <dia:connection handle="1" to="O71" connection="8"/>
+ <dia:connection handle="0" to="O23" connection="23"/>
+ <dia:connection handle="1" to="O71" connection="3"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Class" version="0" id="O73">
- <dia:point val="89.4579,-85.235"/>
+ <dia:point val="89,-86"/>
</dia:attribute>
- <dia:rectangle val="89.4079,-85.285;102.608,-78.785"/>
+ <dia:rectangle val="88.95,-86.05;102.15,-79.55"/>
</dia:attribute>
</dia:attribute>
@@ -11061,16 +11061,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O74">
- <dia:point val="67.85,-76.05"/>
+ <dia:point val="67.5,-76.3"/>
</dia:attribute>
- <dia:rectangle val="67.8,-80.885;90.2079,-75.535"/>
+ <dia:rectangle val="67.45,-81.65;89.75,-75.785"/>
</dia:attribute>
- <dia:point val="78.654,-76.05"/>
- <dia:point val="78.654,-80.135"/>
- <dia:point val="89.4579,-80.135"/>
+ <dia:point val="75,-76.3"/>
+ <dia:point val="75,-80.9"/>
+ <dia:point val="89,-80.9"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -11078,7 +11078,7 @@
<dia:enum val="0"/>
</dia:attribute>
</dia:attribute>
@@ -11129,13 +11129,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O75">
- <dia:point val="89.3766,-77.9475"/>
+ <dia:point val="89,-79"/>
</dia:attribute>
- <dia:rectangle val="89.3266,-77.9975;102.527,-74.6975"/>
+ <dia:rectangle val="88.95,-79.05;102.15,-75.75"/>
</dia:attribute>
</dia:attribute>
@@ -11283,16 +11283,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O76">
- <dia:point val="67.85,-74.45"/>
+ <dia:point val="67.5,-74.7"/>
</dia:attribute>
- <dia:rectangle val="67.8,-76.7975;90.1266,-73.935"/>
+ <dia:rectangle val="67.45,-78.15;89.7005,-74.185"/>
</dia:attribute>
- <dia:point val="80.1832,-74.45"/>
- <dia:point val="80.1832,-76.0475"/>
- <dia:point val="89.3766,-76.0475"/>
+ <dia:point val="78,-74.7"/>
+ <dia:point val="78,-77.4"/>
+ <dia:point val="88.9505,-77.4"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -11346,18 +11346,18 @@
</dia:attribute>
<dia:connections>
<dia:connection handle="0" to="O23" connection="15"/>
- <dia:connection handle="1" to="O75" connection="8"/>
+ <dia:connection handle="1" to="O75" connection="12"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Class" version="0" id="O77">
- <dia:point val="89.3309,-73.6975"/>
+ <dia:point val="89,-75"/>
</dia:attribute>
- <dia:rectangle val="89.2809,-73.7475;98.6309,-70.4475"/>
+ <dia:rectangle val="88.95,-75.05;98.3,-71.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="9.25"/>
@@ -11505,16 +11505,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O78">
- <dia:point val="67.85,-72.05"/>
+ <dia:point val="67.5,-73.1"/>
</dia:attribute>
- <dia:rectangle val="67.8,-73.135;90.0306,-71.18"/>
+ <dia:rectangle val="67.5,-74.185;89.0707,-72.1825"/>
</dia:attribute>
- <dia:point val="78.5653,-72.05"/>
- <dia:point val="78.5653,-72.0975"/>
- <dia:point val="89.2806,-72.0975"/>
+ <dia:point val="89,-73.1"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -11567,22 +11567,22 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O23" connection="21"/>
- <dia:connection handle="1" to="O77" connection="12"/>
+ <dia:connection handle="0" to="O23" connection="19"/>
+ <dia:connection handle="1" to="O77" connection="8"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O79">
- <dia:point val="123.12,-71.21"/>
+ <dia:point val="125.95,-80.4"/>
</dia:attribute>
- <dia:rectangle val="97.8309,-72.5475;123.17,-70.695"/>
+ <dia:rectangle val="97.5,-81.485;126,-72.1825"/>
</dia:attribute>
- <dia:point val="110.85,-71.21"/>
- <dia:point val="110.85,-71.7975"/>
- <dia:point val="98.5809,-71.7975"/>
+ <dia:point val="112.1,-80.4"/>
+ <dia:point val="112.1,-73.1"/>
+ <dia:point val="98.25,-73.1"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -11641,13 +11641,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O80">
- <dia:point val="-25.4952,-93.535"/>
+ <dia:point val="126,-106"/>
</dia:attribute>
- <dia:rectangle val="-25.5452,-93.585;-14.0952,-83.085"/>
+ <dia:rectangle val="125.95,-106.05;137.4,-95.55"/>
</dia:attribute>
</dia:attribute>
<dia:real val="11.35"/>
@@ -12002,13 +12002,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O81">
- <dia:point val="-25.6989,-77.3025"/>
+ <dia:point val="126,-89"/>
</dia:attribute>
- <dia:rectangle val="-25.7489,-78.2525;14.5011,-75.0525"/>
+ <dia:rectangle val="125.95,-89.95;166.2,-86.75"/>
</dia:attribute>
</dia:attribute>
@@ -12037,7 +12037,7 @@
</dia:attribute>
- <dia:point val="-25.3989,-75.66"/>
+ <dia:point val="126.3,-87.3575"/>
</dia:attribute>
@@ -12050,13 +12050,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O82">
- <dia:point val="-25.7139,-73.5375"/>
+ <dia:point val="126,-85"/>
</dia:attribute>
- <dia:rectangle val="-25.7639,-74.4875;1.53613,-71.2875"/>
+ <dia:rectangle val="125.95,-85.95;153.25,-82.75"/>
</dia:attribute>
</dia:attribute>
@@ -12085,7 +12085,7 @@
</dia:attribute>
- <dia:point val="-25.4139,-71.895"/>
+ <dia:point val="126.3,-83.3575"/>
</dia:attribute>
@@ -12098,13 +12098,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O83">
- <dia:point val="-25.6332,-81.785"/>
+ <dia:point val="126,-94"/>
</dia:attribute>
- <dia:rectangle val="-25.6832,-82.735;3.01683,-78.735"/>
+ <dia:rectangle val="125.95,-94.95;154.65,-90.95"/>
</dia:attribute>
</dia:attribute>
@@ -12134,7 +12134,7 @@
</dia:attribute>
- <dia:point val="-25.3332,-80.1425"/>
+ <dia:point val="126.3,-92.3575"/>
</dia:attribute>
@@ -12147,13 +12147,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O84">
- <dia:point val="125.604,-117.647"/>
+ <dia:point val="126,-117"/>
</dia:attribute>
- <dia:rectangle val="125.554,-117.697;141.204,-107.997"/>
+ <dia:rectangle val="125.95,-117.05;141.6,-107.35"/>
</dia:attribute>
</dia:attribute>
<dia:real val="15.550000000000001"/>
@@ -12485,16 +12485,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O85">
- <dia:point val="90.2003,-115.8"/>
+ <dia:point val="90.3503,-115.4"/>
</dia:attribute>
- <dia:rectangle val="90.1503,-116.885;126.354,-114.03"/>
+ <dia:rectangle val="90.3003,-116.485;126.75,-114.182"/>
</dia:attribute>
- <dia:point val="107.902,-115.8"/>
- <dia:point val="107.902,-114.947"/>
- <dia:point val="125.604,-114.947"/>
+ <dia:point val="108.175,-115.4"/>
+ <dia:point val="108.175,-115.1"/>
+ <dia:point val="126,-115.1"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -12548,18 +12548,18 @@
</dia:attribute>
<dia:connections>
<dia:connection handle="0" to="O19" connection="72"/>
- <dia:connection handle="1" to="O84" connection="10"/>
+ <dia:connection handle="1" to="O84" connection="8"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Class" version="0" id="O86">
- <dia:point val="-74.362,-23.585"/>
+ <dia:point val="-47,-124"/>
</dia:attribute>
- <dia:rectangle val="-74.412,-23.635;-61.562,-17.935"/>
+ <dia:rectangle val="-47.05,-124.05;-34.2,-118.35"/>
</dia:attribute>
</dia:attribute>
@@ -12776,16 +12776,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O87">
- <dia:point val="-47.0005,-20.8"/>
+ <dia:point val="-47.0503,-20.6"/>
</dia:attribute>
- <dia:rectangle val="-62.3116,-21.885;-46.9505,-19.8675"/>
+ <dia:rectangle val="-60.85,-122.05;-46.25,-20.085"/>
</dia:attribute>
- <dia:point val="-54.281,-20.8"/>
- <dia:point val="-54.281,-20.785"/>
- <dia:point val="-61.5616,-20.785"/>
+ <dia:point val="-56.2733,-20.6"/>
+ <dia:point val="-56.2733,-121.3"/>
+ <dia:point val="-47,-121.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -12793,7 +12793,7 @@
<dia:enum val="0"/>
</dia:attribute>
</dia:attribute>
@@ -12839,21 +12839,21 @@
</dia:attribute>
<dia:connections>
<dia:connection handle="0" to="O1" connection="46"/>
- <dia:connection handle="1" to="O86" connection="18"/>
+ <dia:connection handle="1" to="O86" connection="10"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O88">
- <dia:point val="-46.95,-27.3"/>
+ <dia:point val="-47,-25.5"/>
</dia:attribute>
- <dia:rectangle val="-52.1742,-50.5725;-2.82325,-26.785"/>
+ <dia:rectangle val="-60.85,-58.25;-46.25,-24.985"/>
</dia:attribute>
- <dia:point val="-52.1242,-27.3"/>
- <dia:point val="-52.1242,-49.8225"/>
- <dia:point val="-3.57325,-49.8225"/>
+ <dia:point val="-52.1242,-25.5"/>
+ <dia:point val="-52.1242,-57.5"/>
+ <dia:point val="-47,-57.5"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -12906,22 +12906,22 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O1" connection="8"/>
+ <dia:connection handle="0" to="O1" connection="12"/>
<dia:connection handle="1" to="O68" connection="12"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O89">
- <dia:point val="30.45,-38.05"/>
+ <dia:point val="31,-35.5"/>
</dia:attribute>
- <dia:rectangle val="8.82705,-50.4725;30.5,-37.535"/>
+ <dia:rectangle val="-34.6011,-58.15;31.05,-34.985"/>
</dia:attribute>
- <dia:point val="23.7758,-38.05"/>
- <dia:point val="23.7758,-49.7225"/>
- <dia:point val="9.57705,-49.7225"/>
+ <dia:point val="21.1025,-35.5"/>
+ <dia:point val="21.1025,-57.4"/>
+ <dia:point val="-33.8511,-57.4"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -12974,19 +12974,19 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O11" connection="10"/>
+ <dia:connection handle="0" to="O11" connection="12"/>
<dia:connection handle="1" to="O68" connection="22"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Class" version="0" id="O90">
- <dia:point val="-25.4159,-113.385"/>
+ <dia:point val="-47,-99"/>
</dia:attribute>
- <dia:rectangle val="-25.4659,-113.435;-16.1159,-108.535"/>
+ <dia:rectangle val="-47.05,-99.05;-37.7,-94.15"/>
</dia:attribute>
</dia:attribute>
@@ -13229,13 +13229,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O91">
- <dia:point val="-25.4195,-102.452"/>
+ <dia:point val="-47,-88"/>
</dia:attribute>
- <dia:rectangle val="-25.4695,-103.402;21.0805,-100.202"/>
+ <dia:rectangle val="-47.05,-88.95;-0.5,-85.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="46.450000000000003"/>
@@ -13264,7 +13264,7 @@
</dia:attribute>
- <dia:point val="-25.1195,-100.81"/>
+ <dia:point val="-46.7,-86.3575"/>
</dia:attribute>
@@ -13277,13 +13277,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O92">
- <dia:point val="-25.4345,-98.6875"/>
+ <dia:point val="-47,-84"/>
</dia:attribute>
- <dia:rectangle val="-25.4845,-99.6375;4.96549,-96.4375"/>
+ <dia:rectangle val="-47.05,-84.95;-16.6,-81.75"/>
</dia:attribute>
</dia:attribute>
<dia:real val="30.350000000000001"/>
@@ -13312,7 +13312,7 @@
</dia:attribute>
- <dia:point val="-25.1345,-97.045"/>
+ <dia:point val="-46.7,-82.3575"/>
</dia:attribute>
@@ -13325,13 +13325,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O93">
- <dia:point val="-25.3538,-106.935"/>
+ <dia:point val="-47,-93"/>
</dia:attribute>
- <dia:rectangle val="-25.4038,-107.885;9.59619,-103.885"/>
+ <dia:rectangle val="-47.05,-93.95;-12.05,-89.95"/>
</dia:attribute>
</dia:attribute>
<dia:real val="34.899999999999999"/>
@@ -13361,7 +13361,7 @@
</dia:attribute>
- <dia:point val="-25.0538,-105.292"/>
+ <dia:point val="-46.7,-91.3575"/>
</dia:attribute>
@@ -13374,13 +13374,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O94">
- <dia:point val="132.863,-1.335"/>
+ <dia:point val="78,-25"/>
</dia:attribute>
- <dia:rectangle val="132.813,-1.385;147.063,15.515"/>
+ <dia:rectangle val="77.95,-25.05;92.2,-8.15"/>
</dia:attribute>
</dia:attribute>
@@ -13919,19 +13919,21 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O95">
- <dia:point val="163.572,-9.985"/>
+ <dia:point val="152,-8.3"/>
</dia:attribute>
- <dia:rectangle val="139.188,-11.07;163.622,-0.585"/>
+ <dia:rectangle val="91.4,-9.45;152.05,-7.7"/>
</dia:attribute>
- <dia:point val="139.938,-9.985"/>
- <dia:point val="139.938,-1.335"/>
+ <dia:point val="122.075,-8.3"/>
+ <dia:point val="122.075,-8.7"/>
+ <dia:point val="92.15,-8.7"/>
</dia:attribute>
<dia:enum val="0"/>
<dia:enum val="1"/>
</dia:attribute>
@@ -13979,19 +13981,19 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O41" connection="12"/>
- <dia:connection handle="1" to="O94" connection="1"/>
+ <dia:connection handle="0" to="O41" connection="20"/>
+ <dia:connection handle="1" to="O94" connection="45"/>
</dia:connections>
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O96">
- <dia:point val="132.871,21.335"/>
+ <dia:point val="78,-1"/>
</dia:attribute>
- <dia:rectangle val="132.821,20.385;191.271,23.585"/>
+ <dia:rectangle val="77.95,-1.95;136.4,1.25"/>
</dia:attribute>
</dia:attribute>
<dia:real val="58.350000000000001"/>
@@ -14020,7 +14022,7 @@
</dia:attribute>
- <dia:point val="133.171,22.9775"/>
+ <dia:point val="78.3,0.6425"/>
</dia:attribute>
@@ -14033,13 +14035,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O97">
- <dia:point val="132.756,25.1"/>
+ <dia:point val="78,3"/>
</dia:attribute>
- <dia:rectangle val="132.706,24.15;173.656,27.35"/>
+ <dia:rectangle val="77.95,2.05;118.9,5.25"/>
</dia:attribute>
</dia:attribute>
<dia:real val="40.850000000000001"/>
@@ -14068,7 +14070,7 @@
</dia:attribute>
- <dia:point val="133.056,26.7425"/>
+ <dia:point val="78.3,4.6425"/>
</dia:attribute>
@@ -14081,13 +14083,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O98">
- <dia:point val="132.836,16.8525"/>
+ <dia:point val="78,-6"/>
</dia:attribute>
- <dia:rectangle val="132.786,15.9025;175.136,19.9025"/>
+ <dia:rectangle val="77.95,-6.95;120.3,-2.95"/>
</dia:attribute>
</dia:attribute>
<dia:real val="42.25"/>
@@ -14117,7 +14119,7 @@
</dia:attribute>
- <dia:point val="133.136,18.495"/>
+ <dia:point val="78.3,-4.3575"/>
</dia:attribute>
@@ -14130,13 +14132,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O99">
- <dia:point val="140.379,-64.07"/>
+ <dia:point val="126,-60"/>
</dia:attribute>
- <dia:rectangle val="140.329,-64.12;154.929,-60.82"/>
+ <dia:rectangle val="125.95,-60.05;140.55,-56.75"/>
</dia:attribute>
</dia:attribute>
@@ -14284,13 +14286,13 @@
</dia:object>
<dia:object type="UML - Class" version="0" id="O100">
- <dia:point val="138.544,-58.2975"/>
+ <dia:point val="126,-55"/>
</dia:attribute>
- <dia:rectangle val="138.494,-58.3475;155.544,-53.4475"/>
+ <dia:rectangle val="125.95,-55.05;143,-50.15"/>
</dia:attribute>
</dia:attribute>
<dia:real val="16.949999999999999"/>
@@ -14484,16 +14486,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O101">
- <dia:point val="164.822,-43.585"/>
+ <dia:point val="152,-40.3"/>
</dia:attribute>
- <dia:rectangle val="154.744,-56.3475;169.344,-43.07"/>
+ <dia:rectangle val="142.2,-53.05;156.8,-39.785"/>
</dia:attribute>
- <dia:point val="160.158,-43.585"/>
- <dia:point val="160.158,-55.5975"/>
- <dia:point val="155.494,-55.5975"/>
+ <dia:point val="147.475,-40.3"/>
+ <dia:point val="147.475,-52.3"/>
+ <dia:point val="142.95,-52.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -14552,15 +14554,15 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O102">
- <dia:point val="126.1,-50.7"/>
+ <dia:point val="113.65,-48"/>
</dia:attribute>
- <dia:rectangle val="124.694,-56.3475;139.294,-49.9"/>
+ <dia:rectangle val="112.15,-53.1;126.75,-47.2"/>
</dia:attribute>
- <dia:point val="126.1,-55.5975"/>
- <dia:point val="138.544,-55.5975"/>
+ <dia:point val="113.65,-52.3"/>
+ <dia:point val="126,-52.3"/>
</dia:attribute>
<dia:enum val="1"/>
@@ -14618,13 +14620,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O103">
- <dia:point val="163.69,4.56"/>
+ <dia:point val="152,4"/>
</dia:attribute>
- <dia:rectangle val="163.64,3.61;210.89,6.81"/>
+ <dia:rectangle val="151.95,3.05;199.2,6.25"/>
</dia:attribute>
</dia:attribute>
@@ -14653,7 +14655,7 @@
</dia:attribute>
- <dia:point val="163.99,6.2025"/>
+ <dia:point val="152.3,5.6425"/>
</dia:attribute>
@@ -14666,13 +14668,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O104">
- <dia:point val="163.575,8.325"/>
+ <dia:point val="152,8"/>
</dia:attribute>
- <dia:rectangle val="163.525,7.375;196.075,10.575"/>
+ <dia:rectangle val="151.95,7.05;184.5,10.25"/>
</dia:attribute>
</dia:attribute>
@@ -14701,7 +14703,7 @@
</dia:attribute>
- <dia:point val="163.875,9.9675"/>
+ <dia:point val="152.3,9.6425"/>
</dia:attribute>
@@ -14714,13 +14716,13 @@
</dia:object>
<dia:object type="UML - SmallPackage" version="0" id="O105">
- <dia:point val="163.656,0.0775"/>
+ <dia:point val="152,-1"/>
</dia:attribute>
- <dia:rectangle val="163.606,-0.8725;197.556,3.1275"/>
+ <dia:rectangle val="151.95,-1.95;185.9,2.05"/>
</dia:attribute>
</dia:attribute>
@@ -14750,7 +14752,7 @@
</dia:attribute>
- <dia:point val="163.956,1.72"/>
+ <dia:point val="152.3,0.6425"/>
</dia:attribute>
@@ -14763,16 +14765,16 @@
</dia:object>
<dia:object type="UML - Association" version="1" id="O106">
- <dia:point val="164.822,-45.585"/>
+ <dia:point val="152,-42.3"/>
</dia:attribute>
- <dia:rectangle val="154.129,-62.92;168.729,-45.07"/>
+ <dia:rectangle val="139.75,-58.05;154.35,-41.785"/>
</dia:attribute>
- <dia:point val="162.035,-45.585"/>
- <dia:point val="162.035,-62.17"/>
- <dia:point val="154.879,-62.17"/>
+ <dia:point val="150,-42.3"/>
+ <dia:point val="150,-57.3"/>
+ <dia:point val="140.5,-57.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -14826,21 +14828,21 @@
</dia:attribute>
<dia:connections>
<dia:connection handle="0" to="O42" connection="3"/>
- <dia:connection handle="1" to="O99" connection="9"/>
+ <dia:connection handle="1" to="O99" connection="11"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O107">
- <dia:point val="136.27,-70.91"/>
+ <dia:point val="139.1,-80.1"/>
</dia:attribute>
- <dia:rectangle val="126.529,-71.995;141.129,-61.2525"/>
+ <dia:rectangle val="139.05,-81.185;175.1,-58.3825"/>
</dia:attribute>
- <dia:point val="138.325,-70.91"/>
- <dia:point val="138.325,-62.17"/>
- <dia:point val="140.379,-62.17"/>
+ <dia:point val="175,-80.1"/>
+ <dia:point val="175,-59.3"/>
+ <dia:point val="140.5,-59.3"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -14848,7 +14850,7 @@
<dia:enum val="0"/>
</dia:attribute>
</dia:attribute>
@@ -14894,26 +14896,24 @@
</dia:attribute>
<dia:connections>
<dia:connection handle="0" to="O70" connection="9"/>
- <dia:connection handle="1" to="O99" connection="8"/>
+ <dia:connection handle="1" to="O99" connection="4"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O108">
- <dia:point val="38.4,-40.8003"/>
</dia:attribute>
- <dia:rectangle val="37.6051,-45.685;51.1551,-40.0003"/>
+ <dia:rectangle val="20.15,-60.3;34.75,-38.2"/>
</dia:attribute>
- <dia:point val="38.4,-42.8676"/>
- <dia:point val="38.3551,-42.8676"/>
- <dia:point val="38.3551,-44.935"/>
+ <dia:point val="31,-59.5"/>
+ <dia:point val="34,-59.5"/>
</dia:attribute>
<dia:enum val="1"/>
<dia:enum val="0"/>
</dia:attribute>
@@ -14961,21 +14961,21 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O11" connection="16"/>
- <dia:connection handle="1" to="O69" connection="6"/>
+ <dia:connection handle="0" to="O11" connection="0"/>
+ <dia:connection handle="1" to="O69" connection="12"/>
</dia:connections>
</dia:object>
<dia:object type="UML - Association" version="1" id="O109">
- <dia:point val="53.35,-69.65"/>
+ <dia:point val="53,-71.5"/>
</dia:attribute>
- <dia:rectangle val="37.6051,-70.735;53.4,-52.185"/>
+ <dia:rectangle val="38.4,-72.585;53.05,-62.25"/>
</dia:attribute>
- <dia:point val="38.3551,-69.65"/>
- <dia:point val="38.3551,-52.935"/>
+ <dia:point val="39.15,-71.5"/>
+ <dia:point val="39.15,-63"/>
</dia:attribute>
<dia:enum val="0"/>
@@ -15027,9 +15027,1184 @@
</dia:composite>
</dia:attribute>
<dia:connections>
- <dia:connection handle="0" to="O23" connection="26"/>
+ <dia:connection handle="0" to="O23" connection="22"/>
<dia:connection handle="1" to="O69" connection="1"/>
</dia:connections>
</dia:object>
+ <dia:object type="UML - Class" version="0" id="O110">
+ <dia:attribute name="obj_pos">
+ <dia:point val="-47,-81"/>
+ </dia:attribute>
+ <dia:attribute name="obj_bb">
+ <dia:rectangle val="-47.05,-81.05;-33.15,-74.55"/>
+ </dia:attribute>
+ <dia:attribute name="elem_corner">
+ </dia:attribute>
+ <dia:attribute name="elem_width">
+ <dia:real val="13.800000000000001"/>
+ </dia:attribute>
+ <dia:attribute name="elem_height">
+ <dia:real val="6.4000000000000004"/>
+ </dia:attribute>
+ <dia:attribute name="name">
+ <dia:string>#sld_user_layer#</dia:string>
+ </dia:attribute>
+ <dia:attribute name="stereotype">
+ <dia:string>##</dia:string>
+ </dia:attribute>
+ <dia:attribute name="comment">
+ </dia:attribute>
+ <dia:attribute name="abstract">
+ </dia:attribute>
+ <dia:attribute name="suppress_attributes">
+ </dia:attribute>
+ <dia:attribute name="suppress_operations">
+ </dia:attribute>
+ <dia:attribute name="visible_attributes">
+ </dia:attribute>
+ <dia:attribute name="visible_operations">
+ </dia:attribute>
+ <dia:attribute name="visible_comments">
+ </dia:attribute>
+ <dia:attribute name="wrap_operations">
+ </dia:attribute>
+ <dia:attribute name="wrap_after_char">
+ <dia:int val="40"/>
+ </dia:attribute>
+ <dia:attribute name="comment_line_length">
+ </dia:attribute>
+ <dia:attribute name="comment_tagging">
+ </dia:attribute>
+ <dia:attribute name="line_color">
+ <dia:color val="#000000"/>
+ </dia:attribute>
+ <dia:attribute name="fill_color">
+ </dia:attribute>
+ <dia:attribute name="text_color">
+ </dia:attribute>
+ <dia:attribute name="normal_font">
+ <dia:font family="monospace" style="0" name="Courier"/>
+ </dia:attribute>
+ <dia:attribute name="abstract_font">
+ <dia:font family="monospace" style="88" name="Courier-BoldOblique"/>
+ </dia:attribute>
+ <dia:attribute name="polymorphic_font">
+ <dia:font family="monospace" style="8" name="Courier-Oblique"/>
+ </dia:attribute>
+ <dia:attribute name="classname_font">
+ <dia:font family="sans" style="80" name="Helvetica-Bold"/>
+ </dia:attribute>
+ <dia:attribute name="abstract_classname_font">
+ <dia:font family="sans" style="88" name="Helvetica-BoldOblique"/>
+ </dia:attribute>
+ <dia:attribute name="comment_font">
+ <dia:font family="sans" style="8" name="Helvetica-Oblique"/>
+ </dia:attribute>
+ <dia:attribute name="normal_font_height">
+ <dia:real val="0.80000000000000004"/>
+ </dia:attribute>
+ <dia:attribute name="polymorphic_font_height">
+ </dia:attribute>
+ <dia:attribute name="abstract_font_height">
+ </dia:attribute>
+ <dia:attribute name="classname_font_height">
+ <dia:real val="1"/>
+ </dia:attribute>
+ <dia:attribute name="abstract_classname_font_height">
+ </dia:attribute>
+ <dia:attribute name="comment_font_height">
+ </dia:attribute>
+ <dia:attribute name="attributes">
+ <dia:composite type="umlattribute">
+ <dia:string>#sld_user_layer_id#</dia:string>
+ </dia:attribute>
+ <dia:attribute name="type">
+ <dia:string>#integer#</dia:string>
+ </dia:attribute>
+ <dia:attribute name="value">
+ </dia:attribute>
+ </dia:attribute>
+ <dia:attribute name="visibility">
+ <dia:enum val="2"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:attribute name="class_scope">
+ </dia:attribute>
+ </dia:composite>
+ <dia:string>#fkey_mb_user_id#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#NOT NULL#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ <dia:string>#fkey_layer_id#</dia:string>
+ </dia:attribute>
+ <dia:string>#varchar(50)#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ <dia:string>#fkey_gui_id#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ <dia:string>#sld_xml#</dia:string>
+ </dia:attribute>
+ <dia:string>#text#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ <dia:string>#use_sld#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ <dia:attribute name="operations"/>
+ <dia:attribute name="template">
+ </dia:attribute>
+ <dia:attribute name="templates"/>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O111">
+ <dia:point val="-47,-68"/>
+ </dia:attribute>
+ <dia:rectangle val="-47.05,-68.95;-6.8,-65.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:real val="40.149999999999999"/>
+ </dia:attribute>
+ <dia:real val="2.2000000000000002"/>
+ </dia:attribute>
+ <dia:attribute name="line_colour">
+ </dia:attribute>
+ <dia:attribute name="fill_colour">
+ </dia:attribute>
+ <dia:string>#postgres:post#</dia:string>
+ </dia:attribute>
+ <dia:attribute name="text">
+ <dia:composite type="text">
+ <dia:attribute name="string">
+ <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs','wfs_id'), (SELECT max(wfs_id) FROM wfs), true);#</dia:string>
+ </dia:attribute>
+ <dia:attribute name="font">
+ </dia:attribute>
+ <dia:attribute name="height">
+ </dia:attribute>
+ <dia:attribute name="pos">
+ <dia:point val="-46.7,-66.3575"/>
+ </dia:attribute>
+ <dia:attribute name="color">
+ </dia:attribute>
+ <dia:attribute name="alignment">
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O112">
+ <dia:point val="-47,-64"/>
+ </dia:attribute>
+ <dia:rectangle val="-47.05,-64.95;-19.75,-61.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:real val="27.200000000000003"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#innodb:pre#</dia:string>
+ </dia:attribute>
+ <dia:string>#ALTER TABLE wfs CHANGE COLUMN wfs_id wfs_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="-46.7,-62.3575"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O113">
+ <dia:point val="-47,-73"/>
+ </dia:attribute>
+ <dia:rectangle val="-47.05,-73.95;-18.35,-69.95"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:real val="28.600000000000001"/>
+ </dia:attribute>
+ <dia:real val="3"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#postgres:pre#</dia:string>
+ </dia:attribute>
+ <dia:string>#CREATE SEQUENCE wfs_id_seq;
+ALTER TABLE wfs ALTER COLUMN wfs_id SET DEFAULT nextval('wfs_id_seq'::regclass);#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="-46.7,-71.3575"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - Association" version="1" id="O114">
+ <dia:point val="-47,-22.3"/>
+ </dia:attribute>
+ <dia:rectangle val="-60.85,-79.05;-46.25,-21.785"/>
+ </dia:attribute>
+ <dia:attribute name="orth_points">
+ <dia:point val="-54.062,-22.3"/>
+ <dia:point val="-54.062,-78.3"/>
+ <dia:point val="-47,-78.3"/>
+ </dia:attribute>
+ <dia:attribute name="orth_orient">
+ </dia:attribute>
+ <dia:attribute name="autorouting">
+ </dia:attribute>
+ </dia:attribute>
+ <dia:attribute name="direction">
+ </dia:attribute>
+ <dia:attribute name="ends">
+ <dia:composite>
+ <dia:attribute name="role">
+ <dia:string>#mb_user_id#</dia:string>
+ </dia:attribute>
+ <dia:attribute name="multiplicity">
+ </dia:attribute>
+ <dia:attribute name="arrow">
+ </dia:attribute>
+ <dia:attribute name="aggregate">
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ <dia:composite>
+ </dia:attribute>
+ <dia:string>#on delete cascade on update cascade#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ <dia:connections>
+ <dia:connection handle="0" to="O1" connection="20"/>
+ <dia:connection handle="1" to="O110" connection="10"/>
+ </dia:connections>
+ </dia:object>
+ <dia:object type="UML - Association" version="1" id="O115">
+ <dia:point val="31,-36.3"/>
+ </dia:attribute>
+ <dia:rectangle val="-33.95,-77.45;31.05,-35.785"/>
+ </dia:attribute>
+ <dia:point val="23,-36.3"/>
+ <dia:point val="23,-76.7"/>
+ <dia:point val="-33.2,-76.7"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:composite>
+ <dia:string>#gui_id#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ <dia:composite>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ <dia:connections>
+ <dia:connection handle="0" to="O11" connection="10"/>
+ <dia:connection handle="1" to="O110" connection="15"/>
+ </dia:object>
+ <dia:object type="UML - Association" version="1" id="O116">
+ <dia:point val="53,-73.1"/>
+ </dia:attribute>
+ <dia:rectangle val="-33.95,-79.05;53.05,-72.585"/>
+ </dia:attribute>
+ <dia:point val="24,-73.1"/>
+ <dia:point val="24,-78.3"/>
+ <dia:point val="-33.2,-78.3"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:composite>
+ <dia:string>#layer_id#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ <dia:composite>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ <dia:connections>
+ <dia:connection handle="0" to="O23" connection="18"/>
+ <dia:connection handle="1" to="O110" connection="11"/>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O117">
+ <dia:point val="-47,-47"/>
+ </dia:attribute>
+ <dia:rectangle val="-47.05,-47.95;-4,-44.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:real val="42.950000000000003"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_kml','kml_id'), (SELECT max(kml_id) FROM gui_kml), true);#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="-46.7,-45.3575"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O118">
+ <dia:point val="-47,-43"/>
+ </dia:attribute>
+ <dia:rectangle val="-47.05,-43.95;-18.35,-40.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#ALTER TABLE gui_gml CHANGE COLUMN kml_id kml_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="-46.7,-41.3575"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O119">
+ <dia:point val="-47,-52"/>
+ </dia:attribute>
+ <dia:rectangle val="-47.05,-52.95;-16.95,-48.95"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:real val="30"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#CREATE SEQUENCE kml_id_seq;
+ALTER TABLE gui_kml ALTER COLUMN kml_id SET DEFAULT nextval('kml_id_seq'::regclass);#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="-46.7,-50.3575"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O120">
+ <dia:point val="34,-48"/>
+ </dia:attribute>
+ <dia:rectangle val="33.95,-48.95;74.9,-45.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:real val="40.850000000000001"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:color val="#90ee90"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_treegde','id'), (SELECT max(id) FROM layer), true);#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="34.3,-46.3575"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O121">
+ <dia:point val="34,-44"/>
+ </dia:attribute>
+ <dia:rectangle val="33.95,-44.95;61.25,-41.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#ALTER TABLE gui_treegde CHANGE COLUMN id id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="34.3,-42.3575"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O122">
+ <dia:point val="34,-53"/>
+ </dia:attribute>
+ <dia:rectangle val="33.95,-53.95;66.85,-49.95"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:real val="32.800000000000004"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#CREATE SEQUENCE gui_treegde_id_seq;
+ALTER TABLE gui_treegde ALTER COLUMN id SET DEFAULT nextval('gui_treegde_id_seq'::regclass);#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="34.3,-51.3575"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O123">
+ <dia:point val="126,-72"/>
+ </dia:attribute>
+ <dia:rectangle val="125.95,-72.95;171.8,-69.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:real val="45.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('keyword','keyword_id'), (SELECT max(keyword_id) FROM keyword), true);#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="126.3,-70.3575"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O124">
+ <dia:point val="126,-68"/>
+ </dia:attribute>
+ <dia:rectangle val="125.95,-68.95;157.45,-65.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:real val="31.400000000000002"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#ALTER TABLE keyword CHANGE COLUMN keyword_id keyword_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="126.3,-66.3575"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O125">
+ <dia:point val="126,-77"/>
+ </dia:attribute>
+ <dia:rectangle val="125.95,-77.95;158.85,-73.95"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#CREATE SEQUENCE keyword_id_seq;
+ALTER TABLE keyword ALTER COLUMN keyword_id SET DEFAULT nextval('keyword_id_seq'::regclass);#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="126.3,-75.3575"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O126">
+ <dia:point val="-47,-106"/>
+ </dia:attribute>
+ <dia:rectangle val="-47.05,-106.95;12.8,-103.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:real val="59.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('md_topic_category','md_topic_category_id'), (SELECT max(md_topic_category_id) FROM md_topic_category), true);#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="-46.7,-104.358"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O127">
+ <dia:point val="-47,-102"/>
+ </dia:attribute>
+ <dia:rectangle val="-47.05,-102.95;-19.75,-99.75"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="-46.7,-100.358"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
+ <dia:object type="UML - SmallPackage" version="0" id="O128">
+ <dia:point val="-47,-111"/>
+ </dia:attribute>
+ <dia:rectangle val="-47.05,-111.95;-3.65,-107.95"/>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:real val="43.300000000000004"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:string>#CREATE SEQUENCE md_topic_category_id_seq;
+ALTER TABLE md_topic_category ALTER COLUMN md_topic_category_id SET DEFAULT nextval('md_topic_category_id_seq'::regclass);#</dia:string>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ <dia:point val="-46.7,-109.358"/>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:attribute>
+ </dia:composite>
+ </dia:attribute>
+ </dia:object>
</dia:layer>
</dia:diagram>
More information about the Mapbender_commits
