[Mapbender-commits] r2790 - trunk/mapbender/resources/db/pgsql/UTF-8
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 14 09:46:37 EDT 2008
Author: christoph
Date: 2008-08-14 09:46:24 -0400 (Thu, 14 Aug 2008)
New Revision: 2790
   trunk/mapbender/resources/db/pgsql/UTF-8/pgsql_data.sql
removed whitespace
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/pgsql_data.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/pgsql_data.sql	2008-08-14 12:54:33 UTC (rev 2789)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/pgsql_data.sql	2008-08-14 13:46:24 UTC (rev 2790)
@@ -23248,4 +23248,4 @@
 INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
-UPDATE pg_catalog.pg_class SET reltriggers = (SELECT pg_catalog.count(*) FROM pg_catalog.pg_trigger where pg_class.oid = tgrelid) ;
\ No newline at end of file
+UPDATE pg_catalog.pg_class SET reltriggers = (SELECT pg_catalog.count(*) FROM pg_catalog.pg_trigger where pg_class.oid = tgrelid);
More information about the Mapbender_commits mailing list
