[Mapbender-commits] r2791 - branches/2.6/resources/db/pgsql/UTF-8
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 14 09:53:39 EDT 2008
Author: christoph
Date: 2008-08-14 09:53:38 -0400 (Thu, 14 Aug 2008)
New Revision: 2791
   branches/2.6/resources/db/pgsql/UTF-8/pgsql_data.sql
removed whitespace
Modified: branches/2.6/resources/db/pgsql/UTF-8/pgsql_data.sql
--- branches/2.6/resources/db/pgsql/UTF-8/pgsql_data.sql	2008-08-14 13:46:24 UTC (rev 2790)
+++ branches/2.6/resources/db/pgsql/UTF-8/pgsql_data.sql	2008-08-14 13:53:38 UTC (rev 2791)
@@ -23248,4 +23248,4 @@
 INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
-UPDATE pg_catalog.pg_class SET reltriggers = (SELECT pg_catalog.count(*) FROM pg_catalog.pg_trigger where pg_class.oid = tgrelid) ;
\ No newline at end of file
+UPDATE pg_catalog.pg_class SET reltriggers = (SELECT pg_catalog.count(*) FROM pg_catalog.pg_trigger where pg_class.oid = tgrelid);
More information about the Mapbender_commits mailing list
