[Mapbender-commits] r2816 - branches/2.6/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 15 06:04:07 EDT 2008
Author: christoph
Date: 2008-08-15 06:04:07 -0400 (Fri, 15 Aug 2008)
New Revision: 2816
   branches/2.6/resources/db/schema_2.5.dia
changed primary in gui_treegde
added unique index on fkey_gui_id, id, lft, rgt
Modified: branches/2.6/resources/db/schema_2.5.dia
--- branches/2.6/resources/db/schema_2.5.dia	2008-08-15 09:45:11 UTC (rev 2815)
+++ branches/2.6/resources/db/schema_2.5.dia	2008-08-15 10:04:07 UTC (rev 2816)
@@ -10216,7 +10216,7 @@
             <dia:string>##</dia:string>
           </dia:attribute>
           <dia:attribute name="visibility">
-            <dia:enum val="2"/>
+            <dia:enum val="0"/>
           </dia:attribute>
           <dia:attribute name="abstract">
             <dia:boolean val="false"/>
@@ -10285,7 +10285,7 @@
           </dia:attribute>
           </dia:attribute>
@@ -10308,7 +10308,7 @@
           </dia:attribute>
           </dia:attribute>
@@ -10387,7 +10387,107 @@
           </dia:attribute>
         </dia:composite>
       </dia:attribute>
-      <dia:attribute name="operations"/>
+      <dia:attribute name="operations">
+        <dia:composite type="umloperation">
+          <dia:attribute name="name">
+            <dia:string>#gui_treegde_idx#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="stereotype">
+            <dia:string>#btree#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="type">
+            <dia:string>#unique index#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="visibility">
+          </dia:attribute>
+          <dia:attribute name="comment">
+            <dia:string>##</dia:string>
+          </dia:attribute>
+          <dia:attribute name="abstract">
+            <dia:boolean val="false"/>
+          </dia:attribute>
+          <dia:attribute name="inheritance_type">
+            <dia:enum val="2"/>
+          </dia:attribute>
+          <dia:attribute name="query">
+          </dia:attribute>
+          <dia:attribute name="class_scope">
+          </dia:attribute>
+          <dia:attribute name="parameters">
+            <dia:composite type="umlparameter">
+                <dia:string>#fkey_gui_id#</dia:string>
+              </dia:attribute>
+              </dia:attribute>
+              <dia:attribute name="value">
+              </dia:attribute>
+              </dia:attribute>
+              <dia:attribute name="kind">
+              </dia:attribute>
+            </dia:composite>
+                <dia:string>#id#</dia:string>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+                <dia:string>#lft#</dia:string>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+                <dia:string>#rgt#</dia:string>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
       <dia:attribute name="template">
       </dia:attribute>
More information about the Mapbender_commits mailing list
