[Mapbender-commits] r2817 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 15 06:04:26 EDT 2008
Author: christoph
Date: 2008-08-15 06:04:26 -0400 (Fri, 15 Aug 2008)
New Revision: 2817
   trunk/mapbender/resources/db/schema_2.5.dia
changed primary in gui_treegde
added unique index on fkey_gui_id, id, lft, rgt
Modified: trunk/mapbender/resources/db/schema_2.5.dia
--- trunk/mapbender/resources/db/schema_2.5.dia	2008-08-15 10:04:07 UTC (rev 2816)
+++ trunk/mapbender/resources/db/schema_2.5.dia	2008-08-15 10:04:26 UTC (rev 2817)
@@ -2243,13 +2243,13 @@
     </dia:object>
     <dia:object type="UML - Class" version="0" id="O13">
       <dia:attribute name="obj_pos">
-        <dia:point val="34,-23"/>
+        <dia:point val="34,-22.8"/>
       </dia:attribute>
       <dia:attribute name="obj_bb">
-        <dia:rectangle val="33.95,-23.05;45.05,-16.55"/>
+        <dia:rectangle val="33.95,-22.85;45.05,-16.35"/>
       </dia:attribute>
       <dia:attribute name="elem_corner">
       </dia:attribute>
       <dia:attribute name="elem_width">
         <dia:real val="11"/>
@@ -2558,13 +2558,13 @@
         <dia:point val="54.9496,-17.8"/>
       </dia:attribute>
-        <dia:rectangle val="44.25,-21.05;58.85,-17.285"/>
+        <dia:rectangle val="44.25,-20.85;58.85,-17.285"/>
       </dia:attribute>
       <dia:attribute name="orth_points">
         <dia:point val="49.9748,-17.8"/>
-        <dia:point val="49.9748,-20.3"/>
-        <dia:point val="45,-20.3"/>
+        <dia:point val="49.9748,-20.1"/>
+        <dia:point val="45,-20.1"/>
       </dia:attribute>
       <dia:attribute name="orth_orient">
         <dia:enum val="0"/>
@@ -10216,7 +10216,7 @@
             <dia:string>##</dia:string>
           </dia:attribute>
           <dia:attribute name="visibility">
-            <dia:enum val="2"/>
+            <dia:enum val="0"/>
           </dia:attribute>
           <dia:attribute name="abstract">
             <dia:boolean val="false"/>
@@ -10285,7 +10285,7 @@
           </dia:attribute>
           </dia:attribute>
@@ -10308,7 +10308,7 @@
           </dia:attribute>
           </dia:attribute>
@@ -10387,7 +10387,107 @@
           </dia:attribute>
         </dia:composite>
       </dia:attribute>
-      <dia:attribute name="operations"/>
+      <dia:attribute name="operations">
+        <dia:composite type="umloperation">
+          <dia:attribute name="name">
+            <dia:string>#gui_treegde_idx#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="stereotype">
+            <dia:string>#btree#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="type">
+            <dia:string>#unique index#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="visibility">
+          </dia:attribute>
+          <dia:attribute name="comment">
+            <dia:string>##</dia:string>
+          </dia:attribute>
+          <dia:attribute name="abstract">
+            <dia:boolean val="false"/>
+          </dia:attribute>
+          <dia:attribute name="inheritance_type">
+            <dia:enum val="2"/>
+          </dia:attribute>
+          <dia:attribute name="query">
+          </dia:attribute>
+          <dia:attribute name="class_scope">
+          </dia:attribute>
+          <dia:attribute name="parameters">
+            <dia:composite type="umlparameter">
+                <dia:string>#fkey_gui_id#</dia:string>
+              </dia:attribute>
+              </dia:attribute>
+              <dia:attribute name="value">
+              </dia:attribute>
+              </dia:attribute>
+              <dia:attribute name="kind">
+              </dia:attribute>
+            </dia:composite>
+                <dia:string>#id#</dia:string>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+                <dia:string>#lft#</dia:string>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+                <dia:string>#rgt#</dia:string>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
       <dia:attribute name="template">
       </dia:attribute>
More information about the Mapbender_commits mailing list
