[Mapbender-commits] r2832 - branches/spsneo_dev/mapbender/update
svn_mapbender at osgeo.org
Fri Aug 15 13:01:44 EDT 2008
Author: spsneo
Date: 2008-08-15 13:01:44 -0400 (Fri, 15 Aug 2008)
New Revision: 2832
branches/spsneo_dev/mapbender/update/updaters.inc
Chnaged the update db folder
Modified: branches/spsneo_dev/mapbender/update/updaters.inc
--- branches/spsneo_dev/mapbender/update/updaters.inc 2008-08-15 15:41:19 UTC (rev 2831)
+++ branches/spsneo_dev/mapbender/update/updaters.inc 2008-08-15 17:01:44 UTC (rev 2832)
@@ -6,7 +6,7 @@
#locates the correct directory containing the sql files to be executed.
#parse the sql files and execute the queries
-#SQL files are to be placed in /update/db/SYS_DBTYPE/CHARSET directory.
+#SQL files are to be placed in /resources/db/SYS_DBTYPE/CHARSET/update/ directory.
#where SYS_DBTYPE is the constant defining the database type and CHARSET defines the encoding
# these constants are defined in /conf/mapbender.conf file
#SQL files should have .sql extension
@@ -19,7 +19,7 @@
#select the database
db_select_db(DB,$con);
#locate the correct directory according to SYS_DBTYPE and CHARSET
- $db_dir = dir('./db/'.SYS_DBTYPE.'/'.CHARSET);
+ $db_dir = dir(realpath(dirname(__FILE__).'/../resources/db/'.SYS_DBTYPE.'/'.CHARSET.'/update/'));
#Get the path of directory containing the sql files for later use in this function
$db_dir_path = $db_dir->path;
#this loops iterates for every file in the directory located
More information about the Mapbender_commits
