[Mapbender-commits] r2833 - branches/spsneo_dev/mapbender/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 15 13:40:29 EDT 2008
Author: spsneo
Date: 2008-08-15 13:40:26 -0400 (Fri, 15 Aug 2008)
New Revision: 2833
   branches/spsneo_dev/mapbender/update/update.php
Chnaged the update db folder
Modified: branches/spsneo_dev/mapbender/update/update.php
--- branches/spsneo_dev/mapbender/update/update.php	2008-08-15 17:01:44 UTC (rev 2832)
+++ branches/spsneo_dev/mapbender/update/update.php	2008-08-15 17:40:26 UTC (rev 2833)
@@ -35,7 +35,7 @@
 fwrite(STDOUT, "Enter the path to the installed copy of the Mapbender directory.\nExample: /var/www/mapbender/\n");
 $rootdir_path = trim(fgets(STDIN));
 $dir_not_to_scan = array();
-array_push($dir_not_to_scan,".", "..", "conf", "license", "log", "resources", "update");
+array_push($dir_not_to_scan,".", "..", "conf", "license", "log", "update");
 //remove slash if it is there at the end of the path
 if(substr($rootdir_path, -1) == '/') {
@@ -137,8 +137,3 @@
 echo "All updates successfully committed.\n";
More information about the Mapbender_commits mailing list
