[Mapbender-commits] r2837 - in branches/dev_lenkne: http/classes http/css http/extensions http/php lib resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 15 18:20:09 EDT 2008
Author: lenkne
Date: 2008-08-15 18:20:09 -0400 (Fri, 15 Aug 2008)
New Revision: 2837
Added:
   branches/dev_lenkne/http/extensions/jquery-1.2.6.pack.js
   branches/dev_lenkne/http/extensions/jquery-impromptu.1.5.js
   branches/dev_lenkne/http/extensions/jquery.formvalidation.1.1.5.js
   branches/dev_lenkne/http/extensions/jquery.validate.js
   branches/dev_lenkne/resources/locale/de_DE/LC_MESSAGES/Mapbender.mo
   branches/dev_lenkne/http/classes/class_administration.php
   branches/dev_lenkne/http/classes/class_locale.php
   branches/dev_lenkne/http/classes/class_user.php
   branches/dev_lenkne/http/css/screen.css
   branches/dev_lenkne/http/extensions/geom2wfst.php
   branches/dev_lenkne/http/extensions/jquery.js
   branches/dev_lenkne/http/extensions/markResult.php
   branches/dev_lenkne/http/extensions/wz_jsgraphics.js
   branches/dev_lenkne/http/php/mod_adminEditFilteredUser.php
   branches/dev_lenkne/http/php/mod_adminFrame.php
   branches/dev_lenkne/lib/mb_admin_functions.js
backup
Modified: branches/dev_lenkne/http/classes/class_administration.php
--- branches/dev_lenkne/http/classes/class_administration.php	2008-08-15 20:58:02 UTC (rev 2836)
+++ branches/dev_lenkne/http/classes/class_administration.php	2008-08-15 22:20:09 UTC (rev 2837)
@@ -606,26 +606,6 @@
 		return $output;
-	function getSearchResults($owner, $searchText) {
-		$allUsers = array();
-		$searchLikeText = "%" . $searchText . "%";
-		$sql = "SELECT mb_user_id,mb_user_name,mb_user_email FROM mb_user ";
-		$sql .= " WHERE mb_user_owner = $1 AND UPPER(mb_user_name) LIKE UPPER($2) ORDER BY mb_user_name ";
-		$v = array($owner,$searchLikeText);
-		$t = array('i','s');
-		$res = db_prep_query($sql, $v, $t);
-		while ($row = db_fetch_array($res)) {
-			array_push($allUsers, array("mb_user_id" => $row["mb_user_id"], "mb_user_name" => $row["mb_user_name"], "mb_user_email" => $row["mb_user_email"]));
-		$json = new Mapbender_JSON();
-		$output = $json->encode($allUsers);
-		header("Content-type:text/plain; charset=utf-8");
-//echo $sql;
-//print_r($v);
-		return $output;
 	function getAllUserColumns($userId) {
 		$userArray = array();
 		$sql = "SELECT * FROM mb_user WHERE mb_user_id = $1";
@@ -646,12 +626,16 @@
 		return $output;
-	function getTableColumns($table,$keyField,$keyFieldValue) {
-		$sql = "SELECT * FROM $table WHERE $keyField = $1";
+	 * Returns an array of column names and fieldtype for a table.
+	function getTableColumns($table) {
+		$sql = "SELECT * FROM $table LIMIT 1";
 		$columnArray = array();
-		$v = array($keyFieldValue);
-		$t = array('s');
+		$v = array();
+		$t = array();
 		$res = db_prep_query($sql,$v,$t);
 		$i = 0;
Modified: branches/dev_lenkne/http/classes/class_locale.php
--- branches/dev_lenkne/http/classes/class_locale.php	2008-08-15 20:58:02 UTC (rev 2836)
+++ branches/dev_lenkne/http/classes/class_locale.php	2008-08-15 22:20:09 UTC (rev 2837)
@@ -113,10 +113,10 @@
 					$_SESSION["mb_locale"] = $this->name;
 					$e = new Mb_notice("locale " . $this->name . " ok on " . $this->os);
 					// from http://de3.php.net/manual/de/function.gettext.php
-					$path = bindtextdomain("Messages1", dirname(__FILE__)."/../../resources/locale/");
+					$path = bindtextdomain("Mapbender", dirname(__FILE__)."/../../resources/locale/");
 					$e = new Mb_notice("path " . $path);
-					$enc = bind_textdomain_codeset("Messages1", "UTF-8");
-					$dom = textdomain("Messages1");
+					$enc = bind_textdomain_codeset("Mapbender", "UTF-8");
+					$dom = textdomain("Mapbender");
 					return true;
Modified: branches/dev_lenkne/http/classes/class_user.php
--- branches/dev_lenkne/http/classes/class_user.php	2008-08-15 20:58:02 UTC (rev 2836)
+++ branches/dev_lenkne/http/classes/class_user.php	2008-08-15 22:20:09 UTC (rev 2837)
@@ -1,159 +1,242 @@
-<?php
-# $Id: class_kml_geometry.php 1966 2008-01-15 08:25:15Z christoph $
-# http://www.mapbender.org/index.php/class_wmc.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
- * A Mapbender user as described in the table mb_user.
-class User {
-	 * @var Integer The user ID
-	var $id;
-	 * Constructor
-	 * @param $userId Integer 	the ID of the user that	is represented by
-	 * 							this object.
-	public function __construct ($userId) {
-		$this->id = $userId;
-	 * @return String the ID of this user
-	public function __toString () {
-		return (string) $this->id;
-	 * Returns an array of application IDs that the user is allowed to access.
-	 * @return Array an array of application IDs
-	 * @param $ignorepublic boolean whether or not to ignore
-	 * 								public applications (?)
-	public function getApplicationsByPermission ($ignorepublic) {
-		$mb_user_id = $this->id;
-		$arrayGuis = array();
-		$mb_user_groups = array();
-		$sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
-		$v = array($mb_user_id);
-		$t = array("i");
-		$res_groups = db_prep_query($sql_groups,$v,$t);
-		$cnt_groups = 0;
-		while($row = db_fetch_array($res_groups)){
-			$mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
-			$cnt_groups++;
-		if($cnt_groups > 0){
-			$v = array();
-			$t = array();
-			$sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
-			$sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
-			for($i=0; $i<count($mb_user_groups);$i++){
-				if($i > 0){$sql_g .= ",";}
-				$sql_g .= "$".strval($i+1);
-				array_push($v,$mb_user_groups[$i]);
-				array_push($t,"i");
-			$sql_g .= ") GROUP BY gui.gui_id";
-			$res_g = db_prep_query($sql_g,$v,$t);
-			while($row = db_fetch_array($res_g)){
-				array_push($arrayGuis,$row["gui_id"]);
-		$sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
-		$sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
-		if (!isset($ignore_public) OR $ignore_public== false){
-			$sql_guis .= " AND gui.gui_public = 1 ";
-		$sql_guis .= " GROUP BY gui.gui_id";
-		$t = array("i");
-		$res_guis = db_prep_query($sql_guis,$v,$t);
-		$guis = array();
-		while($row = db_fetch_array($res_guis)){
-			if(!in_array($row['gui_id'],$arrayGuis)){
-		return $arrayGuis;
-	/** identifies the IDs of WFS confs where the user is owner
-	 * @param integer userid the user-ID of the current user
-	 * @return integer[] the IDs of the wfs_conf-table
-	public function getWfsConfByPermission(){
-		$userid = $this->id;
-	 	$guisByPer = array();
-//	 	1.
-		$adm = new administration();
-	 	$guisByPer = $adm->getGuisByPermission($userid, true);
-//	 	2.
-		$ownWFSconfs = array();
-		if(count($guisByPer)>0){
-			$v = array();
-			$t = array();
-			$sql = "SELECT wfs_conf.wfs_conf_id  FROM gui_wfs_conf, wfs_conf " .
-					"where wfs_conf.wfs_conf_id = gui_wfs_conf.fkey_wfs_conf_id " .
-					"and gui_wfs_conf.fkey_gui_id IN(";
-			for($i=0; $i<count($guisByPer); $i++){
-				if($i>0){ $sql .= ",";}
-				$sql .= "$".strval($i+1);
-				array_push($v, $guisByPer[$i]);
-				array_push($t, "s");
-			$sql .= ") GROUP BY wfs_conf.wfs_conf_id ORDER BY wfs_conf.wfs_conf_id";
-			$res = db_prep_query($sql,$v,$t);
-			$i=0;
-			while($row = db_fetch_array($res)){
-				$ownWFSconfs[$i] = $row['wfs_conf_id'];
-				$i++;
-		return $ownWFSconfs;
-	 * Returns all WMCs that this user owns
-	 * @return integer[] an array of WMC ids; ids from table mb_user_wmc
-	public function getWmcByOwner () {
-		$sql = "SELECT wmc_id FROM mb_user_wmc ";
-		$sql .= "WHERE fkey_user_id = $1 GROUP BY wmc_id";
-		$v = array($this->id);
-		$t = array("i");
-		$res_wmc = db_prep_query($sql, $v, $t);
-  		$wmcArray = array();
-		while($row = db_fetch_array($res_wmc)){
-			array_push($wmcArray, $row["wmc_id"]);
-		return $wmcArray;
+<?php
+# $Id: class_kml_geometry.php 1966 2008-01-15 08:25:15Z christoph $
+# http://www.mapbender.org/index.php/class_wmc.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+ * A Mapbender user as described in the table mb_user.
+class User {
+	 * @var Integer The user ID
+	var $id;
+	 * Constructor
+	 * @param $userId Integer 	the ID of the user that	is represented by
+	 * 							this object.
+	public function __construct ($userId) {
+		$this->id = $userId;
+	 * Returns an array of application IDs that the user is allowed to access.
+	 * @return Array an array of application IDs
+	 * @param $ignorepublic boolean whether or not to ignore
+	 * 								public applications (?)
+	public function getApplicationsByPermission ($ignorepublic) {
+		$mb_user_id = $this->id;
+		$arrayGuis = array();
+		$mb_user_groups = array();
+		$sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
+		$v = array($mb_user_id);
+		$t = array("i");
+		$res_groups = db_prep_query($sql_groups,$v,$t);
+		$cnt_groups = 0;
+		while($row = db_fetch_array($res_groups)){
+			$mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
+			$cnt_groups++;
+		if($cnt_groups > 0){
+			$v = array();
+			$t = array();
+			$sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
+			$sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
+			for($i=0; $i<count($mb_user_groups);$i++){
+				if($i > 0){$sql_g .= ",";}
+				$sql_g .= "$".strval($i+1);
+				array_push($v,$mb_user_groups[$i]);
+				array_push($t,"i");
+			$sql_g .= ") GROUP BY gui.gui_id";
+			$res_g = db_prep_query($sql_g,$v,$t);
+			while($row = db_fetch_array($res_g)){
+				array_push($arrayGuis,$row["gui_id"]);
+		$sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
+		$sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
+		if (!isset($ignore_public) OR $ignore_public== false){
+			$sql_guis .= " AND gui.gui_public = 1 ";
+		$sql_guis .= " GROUP BY gui.gui_id";
+		$t = array("i");
+		$res_guis = db_prep_query($sql_guis,$v,$t);
+		$guis = array();
+		while($row = db_fetch_array($res_guis)){
+			if(!in_array($row['gui_id'],$arrayGuis)){
+		return $arrayGuis;
+	/** identifies the IDs of WFS confs where the user is owner
+	 * @param integer userid the user-ID of the current user
+	 * @return integer[] the IDs of the wfs_conf-table
+	public function getWfsConfByPermission(){
+		$userid = $this->id;
+	 	$guisByPer = array();
+//	 	1.
+		$adm = new administration();
+	 	$guisByPer = $adm->getGuisByPermission($userid, true);
+//	 	2.
+		$ownWFSconfs = array();
+		if(count($guisByPer)>0){
+			$v = array();
+			$t = array();
+			$sql = "SELECT wfs_conf.wfs_conf_id  FROM gui_wfs_conf, wfs_conf " .
+					"where wfs_conf.wfs_conf_id = gui_wfs_conf.fkey_wfs_conf_id " .
+					"and gui_wfs_conf.fkey_gui_id IN(";
+			for($i=0; $i<count($guisByPer); $i++){
+				if($i>0){ $sql .= ",";}
+				$sql .= "$".strval($i+1);
+				array_push($v, $guisByPer[$i]);
+				array_push($t, "s");
+			$sql .= ") GROUP BY wfs_conf.wfs_conf_id ORDER BY wfs_conf.wfs_conf_id";
+			$res = db_prep_query($sql,$v,$t);
+			$i=0;
+			while($row = db_fetch_array($res)){
+				$ownWFSconfs[$i] = $row['wfs_conf_id'];
+				$i++;
+		return $ownWFSconfs;
+	 * Updates mb_user table.
+	function updateUser($updateArray) {
+		$sql = "UPDATE mb_user SET ";
+		$i = 0;
+		foreach ($updateArray as $key => $value) {
+			if ($value[1]) {
+				if (($i+1) == 1) {
+					$sql.= $key . "=$" . ($i+1);
+				else {
+					$sql.= "," . $key . "=$" . ($i+1);
+			$t[$i] = $value[0];
+			if ($key == "mb_user_password") { // for password
+				$v[$i] = md5($value[1]);
+			else {
+				$v[$i] = $value[1];
+			$i++;
+		$sql.= " WHERE mb_user_id = $1";
+		return $res;
+	 * Insert new record into mb_user table.
+	function insertUser($insertArray) {
+		$res = "";
+		$sql = "INSERT INTO mb_user (";
+		$i = 0;
+		foreach ($insertArray as $key => $value) { //Adds the field names, $v & $t
+			if ($value[1]) {
+					$sql.= $key;
+				else {
+					$sql.= "," . $key;
+			else {
+			$i++;
+		$sql.=") VALUES (";
+		$i = 0;
+		foreach ($insertArray as $key => $value) {  //Adds field values from form
+			if ($value[1]) {
+					$sql.= "$" . ($i+1);
+				else {
+					$sql.= ",$" . ($i+1);
+			$i++;
+		$sql.=")";
+		return $res;
+	 * Search for user name
+	function getSearchResults($owner, $searchText) {
+		$allUsers = array();
+		$searchLikeText = "%" . $searchText . "%";
+		$sql = "SELECT mb_user_id,mb_user_name,mb_user_email FROM mb_user ";
+		$sql .= " WHERE mb_user_owner = $1 AND UPPER(mb_user_name) LIKE UPPER($2) ORDER BY mb_user_name ";
+		$v = array($owner,$searchLikeText);
+		$t = array('i','s');
+		$res = db_prep_query($sql, $v, $t);
+		while ($row = db_fetch_array($res)) {
+			array_push($allUsers, array("mb_user_id" => $row["mb_user_id"], "mb_user_name" => $row["mb_user_name"], "mb_user_email" => $row["mb_user_email"]));
+		if (empty($allUsers)) {
+			return false;
+		else {
+			$json = new Mapbender_JSON();
+			$output = $json->encode($allUsers);
+			header("Content-type:text/plain; charset=utf-8");
+			return $output;
\ No newline at end of file
Modified: branches/dev_lenkne/http/css/screen.css
--- branches/dev_lenkne/http/css/screen.css	2008-08-15 20:58:02 UTC (rev 2836)
+++ branches/dev_lenkne/http/css/screen.css	2008-08-15 22:20:09 UTC (rev 2837)
@@ -33,8 +33,8 @@
 #options {
 	float: left;
-	width: 20em;
-	margin-left: -20em;
+	width: 24em;
+	margin-left: -24em;
 #footer {
@@ -231,7 +231,7 @@
 #main form fieldset p label {
 	float: left;
-	width: 10em;
+	width: 12em;
 	padding: 3px 0;
@@ -335,4 +335,52 @@
 .optionButton {
 	width:	110;
+ .jqiwarning .jqi{
+      background-color: #b0be96;
+.jqifade{
+      background-color: #ffffff;
+div.jqi{
+      position: absolute;
+      background-color: #666;
+      padding: 10px;
+      width: 300px;
+div.jqi .jqiclose{
+      float: right;
+      margin: -35px -10px 0 0;
+      cursor: pointer;
+div.jqi .jqicontainer{
+      background-color: #eee;
+      padding: 5px;
+      color: #ffffff;
+      font-weight: bold;
+div.jqi .jqimessage{
+      background-color: #69F;
+      padding: 10px;
+div.jqi .jqibuttons{
+      text-align: center;
+      padding: 5px 0 0 0;
+div.jqi button{
+      padding: 3px 10px 3px 10px;
+      margin: 0 10px;
+/* Style for invalid input */
+.invalidInput{
+	border:1px dotted #F00;
+	background-color: #FFECE6;
+/* Style for valid input */
+.validInput{
+	border: 1px dotted #FF0000;
Modified: branches/dev_lenkne/http/extensions/geom2wfst.php
--- branches/dev_lenkne/http/extensions/geom2wfst.php	2008-08-15 20:58:02 UTC (rev 2836)
+++ branches/dev_lenkne/http/extensions/geom2wfst.php	2008-08-15 22:20:09 UTC (rev 2837)
@@ -1,160 +1,160 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/geom2wfst.php
- * $_REQUEST["url"]
- * $_REQUEST["filter"]
-$wfs_conf_id = $_REQUEST["wfs_conf_id"];
-$featuretype_name = $_REQUEST["featuretype_name"];
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_json.php");
-function isValidVarName ($varname) {
-	if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
-		return true;
-	return false;
-function addParameterToFilter($filter, $featuretype_name, $wfs_conf_id) {
-	/* wfs_conf_element */
-	$sql = "SELECT * FROM wfs_conf_element ";
-	$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-	$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-	$sql .= "ORDER BY wfs_conf_element.f_respos";
-	$v = array($wfs_conf_id);
-	$t = array('i');
-		if (!empty($row["f_auth_varname"])) {
-			$auth_varname = $row["f_auth_varname"];
-			$element_name = $row["element_name"];
-	if (!empty($auth_varname)) {
-		$e = new mb_notice("geom2wfst: addParameterToFilter: auth_varname = " . $auth_varname);
-		$e = new mb_notice("geom2wfst: addParameterToFilter: element_name = " . $element_name);
-		if (isValidVarName($auth_varname)) {
-			$user = eval("return " . $auth_varname . ";");
-			$e = new mb_notice("geom2wfst: addParameterToFilter: user should be " . $_SESSION["mb_user_id"]);
-			$e = new mb_notice("geom2wfst: addParameterToFilter: user is " . $user);
-			$patternUpdate = "(<wfs:Update[^>]*>)";
-			$patternInsert = "(<wfs:Insert[^>]*>)";
-			$patternDelete = "(<wfs:Delete[^>]*>)";
-			$e = new mb_notice("geom2wfst: addParameterToFilter: old filter was: " . $filter);
-			// insert: store authenticated user in database
-			if (eregi($patternInsert, $filter)) {
-				$pattern = "(<" . $featuretype_name . ">)";
-				$replacement = "\\1<" . $element_name . ">" . $user . "</" . $element_name . ">";
-				$filter = eregi_replace($pattern, $replacement, $filter);
-			// update or delete: disallow access for other users
-			if (eregi($patternDelete, $filter) || eregi($patternUpdate, $filter)) {
-				$pattern = "(<ogc:Filter>)(<ogc:FeatureId[^>]*>)(</ogc:filter>)";
-				$replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
-			$e = new mb_notice("geom2wfst: addParameterToFilter: new filter is: " . $filter);
-		else {
-			$e = new mb_exception("geom2wfst: addParameterToFilter: invalid auth_varname (".$auth_varname.")");
-	else {
-		$e = new mb_notice("geom2wfst: addParameterToFilter: no auth_varname.");
-	return $filter;
-function checkVal($value){
-	$pattern = array("'",'"',"--");
-	$r = str_replace($pattern, "", $value);
-	$r = addslashes($r);
-	return $r;
-function sepNameSpace($s){
-	$c = mb_strpos($s,":");
-	if($c>0) return mb_substr($s,$c+1);
-	return $s;
-function sendToHost($host,$port,$method,$path,$data){
-	$buf = '';
-    if (empty($method)) $method = 'POST';
-    $method = mb_strtoupper($method);
-    $fp = fsockopen($host, $port);
-    fputs($fp, "$method $path HTTP/1.1\r\n");
-    fputs($fp, "Host: $host\r\n");
-    fputs($fp,"Content-type: application/xml\r\n");
-    fputs($fp, "Content-length: " . strlen($data) . "\r\n");
-    fputs($fp, "Connection: close\r\n\r\n");
-    if ($method == 'POST') fputs($fp, $data);
-    while (!feof($fp)) $buf .= fgets($fp,4096);
-    fclose($fp);
-    return $buf;
-$result="";
-$error = false;
-$arURL = parse_url($_REQUEST["url"]);
-$host = $arURL["host"];
-$port = $arURL["port"];
-if($port == '') $port = 80;
-$path = $arURL["path"];
-$method = "POST";
-$filter = stripslashes(addParameterToFilter($_REQUEST["filter"], $featuretype_name, $wfs_conf_id));
-$data = sendToHost($host,$port,$method,html_entity_decode($path),$filter);
-$data = mb_eregi_replace("^[^<]*", "", $data);
-$data = mb_eregi_replace("[^>]*$", "", $data);
-header('Content-type: text/html');
-$resObj = array();
-if (mb_strpos(mb_strtoupper($data), "SUCCESS") !== false) {
-	$response = "success";
-	if (mb_ereg("^.*ogc:FeatureId fid=\"(.+)\"/>.*$", $data)) {
-		$fid = mb_ereg_replace("^.*ogc:FeatureId fid=\"(.+)\"/>.*$", "\\1", $data);
-		$resObj["fid"] = $fid;
-	$resObj["successConfirmation"] = $data;
-else {
-	$response = "error";
-	$resObj["errorMessage"] = $data;
-$resObj["response"] = $response;
-$notice = new mb_notice("response:".$response);
-header("Content-Type:application/x-json");
-$json = new Mapbender_JSON();
-echo $json->encode($resObj);
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/geom2wfst.php
+ * $_REQUEST["url"]
+ * $_REQUEST["filter"]
+$wfs_conf_id = $_REQUEST["wfs_conf_id"];
+$featuretype_name = $_REQUEST["featuretype_name"];
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+function isValidVarName ($varname) {
+	if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
+		return true;
+	return false;
+function addParameterToFilter($filter, $featuretype_name, $wfs_conf_id) {
+	/* wfs_conf_element */
+	$sql = "SELECT * FROM wfs_conf_element ";
+	$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+	$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+	$sql .= "ORDER BY wfs_conf_element.f_respos";
+	$v = array($wfs_conf_id);
+	$t = array('i');
+		if (!empty($row["f_auth_varname"])) {
+			$auth_varname = $row["f_auth_varname"];
+			$element_name = $row["element_name"];
+	if (!empty($auth_varname)) {
+		$e = new mb_notice("geom2wfst: addParameterToFilter: auth_varname = " . $auth_varname);
+		$e = new mb_notice("geom2wfst: addParameterToFilter: element_name = " . $element_name);
+		if (isValidVarName($auth_varname)) {
+			$user = eval("return " . $auth_varname . ";");
+			$e = new mb_notice("geom2wfst: addParameterToFilter: user should be " . $_SESSION["mb_user_id"]);
+			$e = new mb_notice("geom2wfst: addParameterToFilter: user is " . $user);
+			$patternUpdate = "(<wfs:Update[^>]*>)";
+			$patternInsert = "(<wfs:Insert[^>]*>)";
+			$patternDelete = "(<wfs:Delete[^>]*>)";
+			$e = new mb_notice("geom2wfst: addParameterToFilter: old filter was: " . $filter);
+			// insert: store authenticated user in database
+			if (eregi($patternInsert, $filter)) {
+				$pattern = "(<" . $featuretype_name . ">)";
+				$replacement = "\\1<" . $element_name . ">" . $user . "</" . $element_name . ">";
+				$filter = eregi_replace($pattern, $replacement, $filter);
+			// update or delete: disallow access for other users
+			if (eregi($patternDelete, $filter) || eregi($patternUpdate, $filter)) {
+				$pattern = "(<ogc:Filter>)(<ogc:FeatureId[^>]*>)(</ogc:filter>)";
+				$replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
+			$e = new mb_notice("geom2wfst: addParameterToFilter: new filter is: " . $filter);
+		else {
+			$e = new mb_exception("geom2wfst: addParameterToFilter: invalid auth_varname (".$auth_varname.")");
+	else {
+		$e = new mb_notice("geom2wfst: addParameterToFilter: no auth_varname.");
+	return $filter;
+function checkVal($value){
+	$pattern = array("'",'"',"--");
+	$r = str_replace($pattern, "", $value);
+	$r = addslashes($r);
+	return $r;
+function sepNameSpace($s){
+	$c = mb_strpos($s,":");
+	if($c>0) return mb_substr($s,$c+1);
+	return $s;
+function sendToHost($host,$port,$method,$path,$data){
+	$buf = '';
+    if (empty($method)) $method = 'POST';
+    $method = mb_strtoupper($method);
+    $fp = fsockopen($host, $port);
+    fputs($fp, "$method $path HTTP/1.1\r\n");
+    fputs($fp, "Host: $host\r\n");
+    fputs($fp,"Content-type: application/xml\r\n");
+    fputs($fp, "Content-length: " . strlen($data) . "\r\n");
+    fputs($fp, "Connection: close\r\n\r\n");
+    if ($method == 'POST') fputs($fp, $data);
+    while (!feof($fp)) $buf .= fgets($fp,4096);
+    fclose($fp);
+    return $buf;
+$result="";
+$error = false;
+$arURL = parse_url($_REQUEST["url"]);
+$host = $arURL["host"];
+$port = $arURL["port"];
+if($port == '') $port = 80;
+$path = $arURL["path"];
+$method = "POST";
+$filter = stripslashes(addParameterToFilter($_REQUEST["filter"], $featuretype_name, $wfs_conf_id));
+$data = sendToHost($host,$port,$method,html_entity_decode($path),$filter);
+$data = mb_eregi_replace("^[^<]*", "", $data);
+$data = mb_eregi_replace("[^>]*$", "", $data);
+header('Content-type: text/html');
+$resObj = array();
+if (mb_strpos(mb_strtoupper($data), "SUCCESS") !== false) {
+	$response = "success";
+	if (mb_ereg("^.*ogc:FeatureId fid=\"(.+)\"/>.*$", $data)) {
+		$fid = mb_ereg_replace("^.*ogc:FeatureId fid=\"(.+)\"/>.*$", "\\1", $data);
+		$resObj["fid"] = $fid;
+	$resObj["successConfirmation"] = $data;
+else {
+	$response = "error";
+	$resObj["errorMessage"] = $data;
+$resObj["response"] = $response;
+$notice = new mb_notice("response:".$response);
+header("Content-Type:application/x-json");
+$json = new Mapbender_JSON();
+echo $json->encode($resObj);
Added: branches/dev_lenkne/http/extensions/jquery-1.2.6.pack.js
--- branches/dev_lenkne/http/extensions/jquery-1.2.6.pack.js	                        (rev 0)
+++ branches/dev_lenkne/http/extensions/jquery-1.2.6.pack.js	2008-08-15 22:20:09 UTC (rev 2837)
@@ -0,0 +1,11 @@
+ * jQuery 1.2.6 - New Wave Javascript
+ * Copyright (c) 2008 John Resig (jquery.com)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * $Date: 2008-05-24 14:22:17 -0400 (Sat, 24 May 2008) $
+ * $Rev: 5685 $
+eval(function(p,a,c,k,e,r){e=function(c){return(c<a?'':e(parseInt(c/a)))+((c=c%a)>35?String.fromCharCode(c+29):c.toString(36))};if(!''.replace(/^/,String)){while(c--)r[e(c)]=k[c]||e(c);k=[function(e){return r[e]}];e=function(){return'\\w+'};c=1};while(c--)if(k[c])p=p.replace(new RegExp('\\b'+e(c)+'\\b','g'),k[c]);return p}('(H(){J w=1b.4M,3m$=1b.$;J D=1b.4M=1b.$=H(a,b){I 2B D.17.5j(a,b)};J u=/^[^<]*(<(.|\\s)+>)[^>]*$|^#(\\w+)$/,62=/^.[^:#\\[\\.]*$/,12;D.17=D.44={5j:H(d,b){d=d||S;G(d.16){7[0]=d;7.K=1;I 7}G(1j d=="23"){J c=u.2D(d);G(c&&(c[1]||!b)){G(c[1])d=D.4h([c[1]],b);N{J a=S.61(c[3]);G(a){G(a.2v!=c[3])I D().2q(d);I D(a)}d=[]}}N I D(b).2q(d)}N G(D.1D(d))I D(S)[D.17.27?"27":"43"](d);I 7.6Y(D.2d(d))},5w:"1.2.6",8G:H(){I 7.K},K:0,3p:H(a){I a==12?D.2d(7):7[a]},2I:H(b){J a=D(b);a.5n=7;I a},6Y:H(a){7.K=0;2p.44.1p.1w(7,a);I 7},P:H(a,b){I D.P(7,a,b)},5i:H(b){J a=-1;I D.2L(b&&b.5w?b[0]:b,7)},1K:H(c,a,b){J d=c;G(c.1q==56)G(a===12)I 7[0]&&D[b||"1K"](7[0],c);N{d={};d[c]=a}I 7.P(H(i){R(c 1n d)D.1K(b?7.V:7,c,D.1i(7,d[c],b,i,c))})},1g:H(b,a){G((b==\'2h\'||b==\'1Z\')&&3d(a)<0)a=12;I 7.1K(b,a,"2a")},1r:H(b){G(1j b!="49"&&b!=U)I 7.4E().3v((7[0]&&7[0].2z||S).5F(b));J a="";D.P(b||7,H(){D.P(7.3t,H(){G(7.16!=8)a+=7.16!=1?7.76:D.17.1r([7])})});I a},5z:H(b){G(7[0])D(b,7[0].2z).5y().39(7[0]).2l(H(){J a=7;1B(a.1x)a=a.1x;I a}).3v(7);I 7},8Y:H(a){I 7.P(H(){D(7).6Q().5z(a)})},8R:H(a){I 7.P(H(){D(7).5z(a)})},3v:H(){I 7.3W(19,M,Q,H(a){G(7.16==1)7.3U(a)})},6F:H(){I 7.3W(19,M,M,H(a){G(7.16==1)7.39(a,7.1x)})},6E:H(){I 7.3W(19,Q,Q,H(a){7.1d.39(a,7)})},5q:H(){I 7.3W(19,Q,M,H(a){7.1d.39(a,7.2H)})},3l:H(){I 7.5n||D([])},2q:H(b){J c=D.2l(7,H(a){I D.2q(b,a)});I 7.2I(/[^+>] [^+>]/.11(b)||b.1h("..")>-1?D.4r(c):c)},5y:H(e){J f=7.2l(H(){G(D.14.1f&&!D.4n(7)){J a=7.6o(M),5h=S.3h("1v");5h.3U(a);I D.4h([5h.4H])[0]}N I 7.6o(M)});J d=f.2q("*").5c().P(H(){G(7[E]!=12)7[E]=U});G(e===M)7.2q("*").5c().P(H(i){G(7.16==3)I;J c=D.L(7,"3w");R(J a 1n c)R(J b 1n c[a])D.W.1e(d[i],a,c[a][b],c[a][b].L)});I f},1E:H(b){I 7.2I(D.1D(b)&&D.3C(7,H(a,i){I b.1k(a,i)})||D.3g(b,7))},4Y:H(b){G(b.1q==56)G(62.11(b))I 7.2I(D.3g(b,7,M));N b=D.3g(b,7);J a=b.K&&b[b.K-1]!==12&&!b.16;I 7.1E(H(){I a?D.2L(7,b)<0:7!=b})},1e:H(a){I 7.2I(D.4r(D.2R(7.3p(),1j a==\'23\'?D(a):D.2d(a))))},3F:H(a){I!!a&&D.3g(a,7).K>0},7T:H(a){I 7.3F("."+a)},6e:H(b){G(b==12){G(7.K){J c=7[0];G(D.Y(c,"2A")){J e=c.64,63=[],15=c.15,2V=c.O=="2A-2V";G(e<0)I U;R(J i=2V?e:0,2f=2V?e+1:15.K;i<2f;i++){J d=15[i];G(d.2W){b=D.14.1f&&!d.at.2x.an?d.1r:d.2x;G(2V)I b;63.1p(b)}}I 63}N I(7[0].2x||"").1o(/\\r/g,"")}I 12}G(b.1q==4L)b+=\'\';I 7.P(H(){G(7.16!=1)I;G(b.1q==2p&&/5O|5L/.11(7.O))7.4J=(D.2L(7.2x,b)>=0||D.2L(7.34,b)>=0);N G(D.Y(7,"2A")){J a=D.2d(b);D("9R",7).P(H(){7.2W=(D.2L(7.2x,a)>=0||D.2L(7.1r,a)>=0)});G(!a.K)7.64=-1}N 7.2x=b})},2K:H(a){I a==12?(7[0]?7[0].4H:U):7.4E().3v(a)},7b:H(a){I 7.5q(a).21()},79:H(i){I 7.3s(i,i+1)},3s:H(){I 7.2I(2p.44.3s.1w(7,19))},2l:H(b){I 7.2I(D.2l(7,H(a,i){I b.1k(a,i,a)}))},5c:H(){I 7.1e(7.5n)},L:H(d,b){J a=d.1R(".");a[1]=a[1]?"."+a[1]:"";G(b===12){J c=7.5C("9z"+a[1]+"!",[a[0]]);G(c===12&&7.K)c=D.L(7[0],d);I c===12&&a[1]?7.L(a[0]):c}N I 7.1P("9u"+a[1]+"!",[a[0],b]).P(H(){D.L(7,d,b)})},3b:H(a){I 7.P(H(){D.3b(7,a)})},3W:H(g,f,h,d){J e=7.K>1,3x;I 7.P(H(){G(!3x){3x=D.4h(g,7.2z);G(h)3x.9o()}J b=7;G(f&&D.Y(7,"1T")&&D.Y(3x[0],"4F"))b=7.3H("22")[0]||7.3U(7.2z.3h("22"));J c=D([]);D.P(3x,H(){J a=e?D(7).5y(M)[0]:7;G(D.Y(a,"1m"))c=c.1e(a);N{G(a.16==1)c=c.1e(D("1m",a).21());d.1k(b,a)}});c.P(6T)})}};D.17.5j.44=D.17;H 6T(i,a){G(a.4d)D.3Y({1a:a.4d,31:Q,1O:"1m"});N D.5u(a.1r||a.6O||a.4H||"");G(a.1d)a.1d.37(a)}H 1z(){I+2B 8J}D.1l=D.17.1l=H(){J b=19[0]||{},i=1,K=19.K,4x=Q,15;G(b.1q==8I){4x=b;b=19[1]||{};i=2}G(1j b!="49"&&1j b!="H")b={};G(K==i){b=7;--i}R(;i<K;i++)G((15=19[i])!=U)R(J c 1n 15){J a=b[c],2w=15[c];G(b===2w)6M;G(4x&&2w&&1j 2w=="49"&&!2w.16)b[c]=D.1l(4x,a||(2w.K!=U?[]:{}),2w);N G(2w!==12)b[c]=2w}I b};J E="4M"+1z(),6K=0,5r={},6G=/z-?5i|8B-?8A|1y|6B|8v-?1Z/i,3P=S.3P||{};D.1l({8u:H(a){1b.$=3m$;G(a)1b.4M=w;I D},1D:H(a){I!!a&&1j a!="23"&&!a.Y&&a.1q!=2p&&/^[\\s[]?H/.11(a+"")},4n:H(a){I a.1C&&!a.1c||a.2j&&a.2z&&!a.2z.1c},5u:H(a){a=D.3k(a);G(a){J b=S.3H("6w")[0]||S.1C,1m=S.3h("1m");1m.O="1r/4t";G(D.14.1f)1m.1r=a;N 1m.3U(S.5F(a));b.39(1m,b.1x);b.37(1m)}},Y:H(b,a){I b.Y&&b.Y.2r()==a.2r()},1Y:{},L:H(c,d,b){c=c==1b?5r:c;J a=c[E];G(!a)a=c[E]=++6K;G(d&&!D.1Y[a])D.1Y[a]={};G(b!==12)D.1Y[a][d]=b;I d?D.1Y[a][d]:a},3b:H(c,b){c=c==1b?5r:c;J a=c[E];G(b){G(D.1Y[a]){2U D.1Y[a][b];b="";R(b 1n D.1Y[a])1X;G(!b)D.3b(c)}}N{1U{2U c[E]}1V(e){G(c.5l)c.5l(E)}2U D.1Y[a]}},P:H(d,a,c){J e,i=0,K=d.K;G(c){G(K==12){R(e 1n d)G(a.1w(d[e],c)===Q)1X}N R(;i<K;)G(a.1w(d[i++],c)===Q)1X}N{G(K==12){R(e 1n d)G(a.1k(d[e],e,d[e])===Q)1X}N R(J b=d[0];i<K&&a.1k(b,i,b)!==Q;b=d[++i]){}}I d},1i:H(b,a,c,i,d){G(D.1D(a))a=a.1k(b,i);I a&&a.1q==4L&&c=="2a"&&!6G.11(d)?a+"2X":a},1F:{1e:H(c,b){D.P((b||"").1R(/\\s+/),H(i,a){G(c.16==1&&!D.1F.3T(c.1F,a))c.1F+=(c.1F?" ":"")+a})},21:H(c,b){G(c.16==1)c.1F=b!=12?D.3C(c.1F.1R(/\\s+/),H(a){I!D.1F.3T(b,a)}).6s(" "):""},3T:H(b,a){I D.2L(a,(b.1F||b).6r().1R(/\\s+/))>-1}},6q:H(b,c,a){J e={};R(J d 1n c){e[d]=b.V[d];b.V[d]=c[d]}a.1k(b);R(J d 1n c)b.V[d]=e[d]},1g:H(d,e,c){G(e=="2h"||e=="1Z"){J b,3X={30:"5x",5g:"1G",18:"3I"},35=e=="2h"?["5e","6k"]:["5G","6i"];H 5b(){b=e=="2h"?d.8f:d.8c;J a=0,2C=0;D.P(35,H(){a+=3d(D.2a(d,"57"+7,M))||0;2C+=3d(D.2a(d,"2C"+7+"4b",M))||0});b-=29.83(a+2C)}G(D(d).3F(":4j"))5b();N D.6q(d,3X,5b);I 29.2f(0,b)}I D.2a(d,e,c)},2a:H(f,l,k){J e,V=f.V;H 3E(b){G(!D.14.2k)I Q;J a=3P.54(b,U);I!a||a.52("3E")==""}G(l=="1y"&&D.14.1f){e=D.1K(V,"1y");I e==""?"1":e}G(D.14.2G&&l=="18"){J d=V.50;V.50="0 7Y 7W";V.50=d}G(l.1I(/4i/i))l=y;G(!k&&V&&V[l])e=V[l];N G(3P.54){G(l.1I(/4i/i))l="4i";l=l.1o(/([A-Z])/g,"-$1").3y();J c=3P.54(f,U);G(c&&!3E(f))e=c.52(l);N{J g=[],2E=[],a=f,i=0;R(;a&&3E(a);a=a.1d)2E.6h(a);R(;i<2E.K;i++)G(3E(2E[i])){g[i]=2E[i].V.18;2E[i].V.18="3I"}e=l=="18"&&g[2E.K-1]!=U?"2F":(c&&c.52(l))||"";R(i=0;i<g.K;i++)G(g[i]!=U)2E[i].V.18=g[i]}G(l=="1y"&&e=="")e="1"}N G(f.4g){J h=l.1o(/\\-(\\w)/g,H(a,b){I b.2r()});e=f.4g[l]||f.4g[h];G(!/^\\d+(2X)?$/i.11(e)&&/^\\d/.11(e)){J j=V.1A,66=f.65.1A;f.65.1A=f.4g.1A;V.1A=e||0;e=V.aM+"2X";V.1A=j;f.65.1A=66}}I e},4h:H(l,h){J k=[];h=h||S;G(1j h.3h==\'12\')h=h.2z||h[0]&&h[0].2z||S;D.P(l,H(i,d){G(!d)I;G(d.1q==4L)d+=\'\';G(1j d=="23"){d=d.1o(/(<(\\w+)[^>]*?)\\/>/g,H(b,a,c){I c.1I(/^(aK|4f|7E|aG|4T|7A|aB|3n|az|ay|av)$/i)?b:a+"></"+c+">"});J f=D.3k(d).3y(),1v=h.3h("1v");J e=!f.1h("<au")&&[1,"<2A 7w=\'7w\'>","</2A>"]||!f.1h("<ar")&&[1,"<7v>","</7v>"]||f.1I(/^<(aq|22|am|ak|ai)/)&&[1,"<1T>","</1T>"]||!f.1h("<4F")&&[2,"<1T><22>","</22></1T>"]||(!f.1h("<af")||!f.1h("<ad"))&&[3,"<1T><22><4F>","</4F></22></1T>"]||!f.1h("<7E")&&[2,"<1T><22></22><7q>","</7q></1T>"]||D.14.1f&&[1,"1v<1v>","</1v>"]||[0,"",""];1v.4H=e[1]+d+e[2];1B(e[0]--)1v=1v.5T;G(D.14.1f){J g=!f.1h("<1T")&&f.1h("<22")<0?1v.1x&&1v.1x.3t:e[1]=="<1T>"&&f.1h("<22")<0?1v.3t:[];R(J j=g.K-1;j>=0;--j)G(D.Y(g[j],"22")&&!g[j].3t.K)g[j].1d.37(g[j]);G(/^\\s/.11(d))1v.39(h.5F(d.1I(/^\\s*/)[0]),1v.1x)}d=D.2d(1v.3t)}G(d.K===0&&(!D.Y(d,"3V")&&!D.Y(d,"2A")))I;G(d[0]==12||D.Y(d,"3V")||d.15)k.1p(d);N k=D.2R(k,d)});I k},1K:H(d,f,c){G(!d||d.16==3||d.16==8)I 12;J e=!D.4n(d),40=c!==12,1f=D.14.1f;f=e&&D.3X[f]||f;G(d.2j){J g=/5Q|4d|V/.11(f);G(f=="2W"&&D.14.2k)d.1d.64;G(f 1n d&&e&&!g){G(40){G(f=="O"&&D.Y(d,"4T")&&d.1d)7p"O a3 a1\'t 9V 9U";d[f]=c}G(D.Y(d,"3V")&&d.7i(f))I d.7i(f).76;I d[f]}G(1f&&e&&f=="V")I D.1K(d.V,"9T",c);G(40)d.9Q(f,""+c);J h=1f&&e&&g?d.4G(f,2):d.4G(f);I h===U?12:h}G(1f&&f=="1y"){G(40){d.6B=1;d.1E=(d.1E||"").1o(/7f\\([^)]*\\)/,"")+(3r(c)+\'\'=="9L"?"":"7f(1y="+c*7a+")")}I d.1E&&d.1E.1h("1y=")>=0?(3d(d.1E.1I(/1y=([^)]*)/)[1])/7a)+\'\':""}f=f.1o(/-([a-z])/9H,H(a,b){I b.2r()});G(40)d[f]=c;I d[f]},3k:H(a){I(a||"").1o(/^\\s+|\\s+$/g,"")},2d:H(b){J a=[];G(b!=U){J i=b.K;G(i==U||b.1R||b.4I||b.1k)a[0]=b;N 1B(i)a[--i]=b[i]}I a},2L:H(b,a){R(J i=0,K=a.K;i<K;i++)G(a[i]===b)I i;I-1},2R:H(a,b){J i=0,T,2S=a.K;G(D.14.1f){1B(T=b[i++])G(T.16!=8)a[2S++]=T}N 1B(T=b[i++])a[2S++]=T;I a},4r:H(a){J c=[],2o={};1U{R(J i=0,K=a.K;i<K;i++){J b=D.L(a[i]);G(!2o[b]){2o[b]=M;c.1p(a[i])}}}1V(e){c=a}I c},3C:H(c,a,d){J b=[];R(J i=0,K=c.K;i<K;i++)G(!d!=!a(c[i],i))b.1p(c[i]);I b},2l:H(d,a){J c=[];R(J i=0,K=d.K;i<K;i++){J b=a(d[i],i);G(b!=U)c[c.K]=b}I c.7d.1w([],c)}});J v=9B.9A.3y();D.14={5B:(v.1I(/.+(?:9y|9x|9w|9v)[\\/: ]([\\d.]+)/)||[])[1],2k:/75/.11(v),2G:/2G/.11(v),1f:/1f/.11(v)&&!/2G/.11(v),42:/42/.11(v)&&!/(9s|75)/.11(v)};J y=D.14.1f?"7o":"72";D.1l({71:!D.14.1f||S.70=="6Z",3X:{"R":"9n","9k":"1F","4i":y,72:y,7o:y,9h:"9f",9e:"9d",9b:"99"}});D.P({6W:H(a){I a.1d},97:H(a){I D.4S(a,"1d")},95:H(a){I D.3a(a,2,"2H")},91:H(a){I D.3a(a,2,"4l")},8Z:H(a){I D.4S(a,"2H")},8X:H(a){I D.4S(a,"4l")},8W:H(a){I D.5v(a.1d.1x,a)},8V:H(a){I D.5v(a.1x)},6Q:H(a){I D.Y(a,"8U")?a.8T||a.8S.S:D.2d(a.3t)}},H(c,d){D.17[c]=H(b){J a=D.2l(7,d);G(b&&1j b=="23")a=D.3g(b,a);I 7.2I(D.4r(a))}});D.P({6P:"3v",8Q:"6F",39:"6E",8P:"5q",8O:"7b"},H(c,b){D.17[c]=H(){J a=19;I 7.P(H(){R(J i=0,K=a.K;i<K;i++)D(a[i])[b](7)})}});D.P({8N:H(a){D.1K(7,a,"");G(7.16==1)7.5l(a)},8M:H(a){D.1F.1e(7,a)},8L:H(a){D.1F.21(7,a)},8K:H(a){D.1F[D.1F.3T(7,a)?"21":"1e"](7,a)},21:H(a){G(!a||D.1E(a,[7]).r.K){D("*",7).1e(7).P(H(){D.W.21(7);D.3b(7)});G(7.1d)7.1d.37(7)}},4E:H(){D(">*",7).21();1B(7.1x)7.37(7.1x)}},H(a,b){D.17[a]=H(){I 7.P(b,19)}});D.P(["6N","4b"],H(i,c){J b=c.3y();D.17[b]=H(a){I 7[0]==1b?D.14.2G&&S.1c["5t"+c]||D.14.2k&&1b["5s"+c]||S.70=="6Z"&&S.1C["5t"+c]||S.1c["5t"+c]:7[0]==S?29.2f(29.2f(S.1c["4y"+c],S.1C["4y"+c]),29.2f(S.1c["2i"+c],S.1C["2i"+c])):a==12?(7.K?D.1g(7[0],b):U):7.1g(b,a.1q==56?a:a+"2X")}});H 25(a,b){I a[0]&&3r(D.2a(a[0],b,M),10)||0}J C=D.14.2k&&3r(D.14.5B)<8H?"(?:[\\\\w*3m-]|\\\\\\\\.)":"(?:[\\\\w\\8F-\\8E*3m-]|\\\\\\\\.)",6L=2B 4v("^>\\\\s*("+C+"+)"),6J=2B 4v("^("+C+"+)(#)("+C+"+)"),6I=2B 4v("^([#.]?)("+C+"*)");D.1l({6H:{"":H(a,i,m){I m[2]=="*"||D.Y(a,m[2])},"#":H(a,i,m){I a.4G("2v")==m[2]},":":{8D:H(a,i,m){I i<m[3]-0},8C:H(a,i,m){I i>m[3]-0},3a:H(a,i,m){I m[3]-0==i},79:H(a,i,m){I m[3]-0==i},3o:H(a,i){I i==0},3S:H(a,i,m,r){I i==r.K-1},6D:H(a,i){I i%2==0},6C:H(a,i){I i%2},"3o-4u":H(a){I a.1d.3H("*")[0]==a},"3S-4u":H(a){I D.3a(a.1d.5T,1,"4l")==a},"8z-4u":H(a){I!D.3a(a.1d.5T,2,"4l")},6W:H(a){I a.1x},4E:H(a){I!a.1x},8y:H(a,i,m){I(a.6O||a.8x||D(a).1r()||"").1h(m[3])>=0},4j:H(a){I"1G"!=a.O&&D.1g(a,"18")!="2F"&&D.1g(a,"5g")!="1G"},1G:H(a){I"1G"==a.O||D.1g(a,"18")=="2F"||D.1g(a,"5g")=="1G"},8w:H(a){I!a.3R},3R:H(a){I a.3R},4J:H(a){I a.4J},2W:H(a){I a.2W||D.1K(a,"2W")},1r:H(a){I"1r"==a.O},5O:H(a){I"5O"==a.O},5L:H(a){I"5L"==a.O},5p:H(a){I"5p"==a.O},3Q:H(a){I"3Q"==a.O},5o:H(a){I"5o"==a.O},6A:H(a){I"6A"==a.O},6z:H(a){I"6z"==a.O},2s:H(a){I"2s"==a.O||D.Y(a,"2s")},4T:H(a){I/4T|2A|6y|2s/i.11(a.Y)},3T:H(a,i,m){I D.2q(m[3],a).K},8t:H(a){I/h\\d/i.11(a.Y)},8s:H(a){I D.3C(D.3O,H(b){I a==b.T}).K}}},6x:[/^(\\[) *@?([\\w-]+) *([!*$^~=]*) *(\'?"?)(.*?)\\4 *\\]/,/^(:)([\\w-]+)\\("?\'?(.*?(\\(.*?\\))?[^(]*?)"?\'?\\)/,2B 4v("^([:.#]*)("+C+"+)")],3g:H(a,c,b){J d,1t=[];1B(a&&a!=d){d=a;J f=D.1E(a,c,b);a=f.t.1o(/^\\s*,\\s*/,"");1t=b?c=f.r:D.2R(1t,f.r)}I 1t},2q:H(t,o){G(1j t!="23")I[t];G(o&&o.16!=1&&o.16!=9)I[];o=o||S;J d=[o],2o=[],3S,Y;1B(t&&3S!=t){J r=[];3S=t;t=D.3k(t);J l=Q,3j=6L,m=3j.2D(t);G(m){Y=m[1].2r();R(J i=0;d[i];i++)R(J c=d[i].1x;c;c=c.2H)G(c.16==1&&(Y=="*"||c.Y.2r()==Y))r.1p(c);d=r;t=t.1o(3j,"");G(t.1h(" ")==0)6M;l=M}N{3j=/^([>+~])\\s*(\\w*)/i;G((m=3j.2D(t))!=U){r=[];J k={};Y=m[2].2r();m=m[1];R(J j=0,3i=d.K;j<3i;j++){J n=m=="~"||m=="+"?d[j].2H:d[j].1x;R(;n;n=n.2H)G(n.16==1){J g=D.L(n);G(m=="~"&&k[g])1X;G(!Y||n.Y.2r()==Y){G(m=="~")k[g]=M;r.1p(n)}G(m=="+")1X}}d=r;t=D.3k(t.1o(3j,""));l=M}}G(t&&!l){G(!t.1h(",")){G(o==d[0])d.4s();2o=D.2R(2o,d);r=d=[o];t=" "+t.6v(1,t.K)}N{J h=6J;J m=h.2D(t);G(m){m=[0,m[2],m[3],m[1]]}N{h=6I;m=h.2D(t)}m[2]=m[2].1o(/\\\\/g,"");J f=d[d.K-1];G(m[1]=="#"&&f&&f.61&&!D.4n(f)){J p=f.61(m[2]);G((D.14.1f||D.14.2G)&&p&&1j p.2v=="23"&&p.2v!=m[2])p=D(\'[@2v="\'+m[2]+\'"]\',f)[0];d=r=p&&(!m[3]||D.Y(p,m[3]))?[p]:[]}N{R(J i=0;d[i];i++){J a=m[1]=="#"&&m[3]?m[3]:m[1]!=""||m[0]==""?"*":m[2];G(a=="*"&&d[i].Y.3y()=="49")a="3n";r=D.2R(r,d[i].3H(a))}G(m[1]==".")r=D.5m(r,m[2]);G(m[1]=="#"){J e=[];R(J i=0;r[i];i++)G(r[i].4G("2v")==m[2]){e=[r[i]];1X}r=e}d=r}t=t.1o(h,"")}}G(t){J b=D.1E(t,r);d=r=b.r;t=D.3k(b.t)}}G(t)d=[];G(d&&o==d[0])d.4s();2o=D.2R(2o,d);I 2o},5m:H(r,m,a){m=" "+m+" ";J c=[];R(J i=0;r[i];i++){J b=(" "+r[i].1F+" ").1h(m)>=0;G(!a&&b||a&&!b)c.1p(r[i])}I c},1E:H(t,r,h){J d;1B(t&&t!=d){d=t;J p=D.6x,m;R(J i=0;p[i];i++){m=p[i].2D(t);G(m){t=t.8r(m[0].K);m[2]=m[2].1o(/\\\\/g,"");1X}}G(!m)1X;G(m[1]==":"&&m[2]=="4Y")r=62.11(m[3])?D.1E(m[3],r,M).r:D(r).4Y(m[3]);N G(m[1]==".")r=D.5m(r,m[2],h);N G(m[1]=="["){J g=[],O=m[3];R(J i=0,3i=r.K;i<3i;i++){J a=r[i],z=a[D.3X[m[2]]||m[2]];G(z==U||/5Q|4d|2W/.11(m[2]))z=D.1K(a,m[2])||\'\';G((O==""&&!!z||O=="="&&z==m[5]||O=="!="&&z!=m[5]||O=="^="&&z&&!z.1h(m[5])||O=="$="&&z.6v(z.K-m[5].K)==m[5]||(O=="*="||O=="~=")&&z.1h(m[5])>=0)^h)g.1p(a)}r=g}N G(m[1]==":"&&m[2]=="3a-4u"){J e={},g=[],11=/(-?)(\\d*)n((?:\\+|-)?\\d*)/.2D(m[3]=="6D"&&"2n"||m[3]=="6C"&&"2n+1"||!/\\D/.11(m[3])&&"8q+"+m[3]||m[3]),3o=(11[1]+(11[2]||1))-0,d=11[3]-0;R(J i=0,3i=r.K;i<3i;i++){J j=r[i],1d=j.1d,2v=D.L(1d);G(!e[2v]){J c=1;R(J n=1d.1x;n;n=n.2H)G(n.16==1)n.4q=c++;e[2v]=M}J b=Q;G(3o==0){G(j.4q==d)b=M}N G((j.4q-d)%3o==0&&(j.4q-d)/3o>=0)b=M;G(b^h)g.1p(j)}r=g}N{J f=D.6H[m[1]];G(1j f=="49")f=f[m[2]];G(1j f=="23")f=6u("Q||H(a,i){I "+f+";}");r=D.3C(r,H(a,i){I f(a,i,m,r)},h)}}I{r:r,t:t}},4S:H(b,c){J a=[],1t=b[c];1B(1t&&1t!=S){G(1t.16==1)a.1p(1t);1t=1t[c]}I a},3a:H(a,e,c,b){e=e||1;J d=0;R(;a;a=a[c])G(a.16==1&&++d==e)1X;I a},5v:H(n,a){J r=[];R(;n;n=n.2H){G(n.16==1&&n!=a)r.1p(n)}I r}});D.W={1e:H(f,i,g,e){G(f.16==3||f.16==8)I;G(D.14.1f&&f.4I)f=1b;G(!g.24)g.24=7.24++;G(e!=12){J h=g;g=7.3M(h,H(){I h.1w(7,19)});g.L=e}J j=D.L(f,"3w")||D.L(f,"3w",{}),1H=D.L(f,"1H")||D.L(f,"1H",H(){G(1j D!="12"&&!D.W.5k)I D.W.1H.1w(19.3L.T,19)});1H.T=f;D.P(i.1R(/\\s+/),H(c,b){J a=b.1R(".");b=a[0];g.O=a[1];J d=j[b];G(!d){d=j[b]={};G(!D.W.2t[b]||D.W.2t[b].4p.1k(f)===Q){G(f.3K)f.3K(b,1H,Q);N G(f.6t)f.6t("4o"+b,1H)}}d[g.24]=g;D.W.26[b]=M});f=U},24:1,26:{},21:H(e,h,f){G(e.16==3||e.16==8)I;J i=D.L(e,"3w"),1L,5i;G(i){G(h==12||(1j h=="23"&&h.8p(0)=="."))R(J g 1n i)7.21(e,g+(h||""));N{G(h.O){f=h.2y;h=h.O}D.P(h.1R(/\\s+/),H(b,a){J c=a.1R(".");a=c[0];G(i[a]){G(f)2U i[a][f.24];N R(f 1n i[a])G(!c[1]||i[a][f].O==c[1])2U i[a][f];R(1L 1n i[a])1X;G(!1L){G(!D.W.2t[a]||D.W.2t[a].4A.1k(e)===Q){G(e.6p)e.6p(a,D.L(e,"1H"),Q);N G(e.6n)e.6n("4o"+a,D.L(e,"1H"))}1L=U;2U i[a]}}})}R(1L 1n i)1X;G(!1L){J d=D.L(e,"1H");G(d)d.T=U;D.3b(e,"3w");D.3b(e,"1H")}}},1P:H(h,c,f,g,i){c=D.2d(c);G(h.1h("!")>=0){h=h.3s(0,-1);J a=M}G(!f){G(7.26[h])D("*").1e([1b,S]).1P(h,c)}N{G(f.16==3||f.16==8)I 12;J b,1L,17=D.1D(f[h]||U),W=!c[0]||!c[0].32;G(W){c.6h({O:h,2J:f,32:H(){},3J:H(){},4C:1z()});c[0][E]=M}c[0].O=h;G(a)c[0].6m=M;J d=D.L(f,"1H");G(d)b=d.1w(f,c);G((!17||(D.Y(f,\'a\')&&h=="4V"))&&f["4o"+h]&&f["4o"+h].1w(f,c)===Q)b=Q;G(W)c.4s();G(i&&D.1D(i)){1L=i.1w(f,b==U?c:c.7d(b));G(1L!==12)b=1L}G(17&&g!==Q&&b!==Q&&!(D.Y(f,\'a\')&&h=="4V")){7.5k=M;1U{f[h]()}1V(e){}}7.5k=Q}I b},1H:H(b){J a,1L,38,5f,4m;b=19[0]=D.W.6l(b||1b.W);38=b.O.1R(".");b.O=38[0];38=38[1];5f=!38&&!b.6m;4m=(D.L(7,"3w")||{})[b.O];R(J j 1n 4m){J c=4m[j];G(5f||c.O==38){b.2y=c;b.L=c.L;1L=c.1w(7,19);G(a!==Q)a=1L;G(1L===Q){b.32();b.3J()}}}I a},6l:H(b){G(b[E]==M)I b;J d=b;b={8o:d};J c="8n 8m 8l 8k 2s 8j 47 5d 6j 5E 8i L 8h 8g 4K 2y 5a 59 8e 8b 58 6f 8a 88 4k 87 86 84 6d 2J 4C 6c O 82 81 35".1R(" ");R(J i=c.K;i;i--)b[c[i]]=d[c[i]];b[E]=M;b.32=H(){G(d.32)d.32();d.80=Q};b.3J=H(){G(d.3J)d.3J();d.7Z=M};b.4C=b.4C||1z();G(!b.2J)b.2J=b.6d||S;G(b.2J.16==3)b.2J=b.2J.1d;G(!b.4k&&b.4K)b.4k=b.4K==b.2J?b.6c:b.4K;G(b.58==U&&b.5d!=U){J a=S.1C,1c=S.1c;b.58=b.5d+(a&&a.2e||1c&&1c.2e||0)-(a.6b||0);b.6f=b.6j+(a&&a.2c||1c&&1c.2c||0)-(a.6a||0)}G(!b.35&&((b.47||b.47===0)?b.47:b.5a))b.35=b.47||b.5a;G(!b.59&&b.5E)b.59=b.5E;G(!b.35&&b.2s)b.35=(b.2s&1?1:(b.2s&2?3:(b.2s&4?2:0)));I b},3M:H(a,b){b.24=a.24=a.24||b.24||7.24++;I b},2t:{27:{4p:H(){55();I},4A:H(){I}},3D:{4p:H(){G(D.14.1f)I Q;D(7).2O("53",D.W.2t.3D.2y);I M},4A:H(){G(D.14.1f)I Q;D(7).4e("53",D.W.2t.3D.2y);I M},2y:H(a){G(F(a,7))I M;a.O="3D";I D.W.1H.1w(7,19)}},3N:{4p:H(){G(D.14.1f)I Q;D(7).2O("51",D.W.2t.3N.2y);I M},4A:H(){G(D.14.1f)I Q;D(7).4e("51",D.W.2t.3N.2y);I M},2y:H(a){G(F(a,7))I M;a.O="3N";I D.W.1H.1w(7,19)}}}};D.17.1l({2O:H(c,a,b){I c=="4X"?7.2V(c,a,b):7.P(H(){D.W.1e(7,c,b||a,b&&a)})},2V:H(d,b,c){J e=D.W.3M(c||b,H(a){D(7).4e(a,e);I(c||b).1w(7,19)});I 7.P(H(){D.W.1e(7,d,e,c&&b)})},4e:H(a,b){I 7.P(H(){D.W.21(7,a,b)})},1P:H(c,a,b){I 7.P(H(){D.W.1P(c,a,7,M,b)})},5C:H(c,a,b){I 7[0]&&D.W.1P(c,a,7[0],Q,b)},2m:H(b){J c=19,i=1;1B(i<c.K)D.W.3M(b,c[i++]);I 7.4V(D.W.3M(b,H(a){7.4Z=(7.4Z||0)%i;a.32();I c[7.4Z++].1w(7,19)||Q}))},7X:H(a,b){I 7.2O(\'3D\',a).2O(\'3N\',b)},27:H(a){55();G(D.2Q)a.1k(S,D);N D.3A.1p(H(){I a.1k(7,D)});I 7}});D.1l({2Q:Q,3A:[],27:H(){G(!D.2Q){D.2Q=M;G(D.3A){D.P(D.3A,H(){7.1k(S)});D.3A=U}D(S).5C("27")}}});J x=Q;H 55(){G(x)I;x=M;G(S.3K&&!D.14.2G)S.3K("69",D.27,Q);G(D.14.1f&&1b==1S)(H(){G(D.2Q)I;1U{S.1C.7V("1A")}1V(3e){3B(19.3L,0);I}D.27()})();G(D.14.2G)S.3K("69",H(){G(D.2Q)I;R(J i=0;i<S.4W.K;i++)G(S.4W[i].3R){3B(19.3L,0);I}D.27()},Q);G(D.14.2k){J a;(H(){G(D.2Q)I;G(S.3f!="68"&&S.3f!="1J"){3B(19.3L,0);I}G(a===12)a=D("V, 7A[7U=7S]").K;G(S.4W.K!=a){3B(19.3L,0);I}D.27()})()}D.W.1e(1b,"43",D.27)}D.P(("7R,7Q,43,85,4y,4X,4V,7P,"+"7O,7N,89,53,51,7M,2A,"+"5o,7L,7K,8d,3e").1R(","),H(i,b){D.17[b]=H(a){I a?7.2O(b,a):7.1P(b)}});J F=H(a,c){J b=a.4k;1B(b&&b!=c)1U{b=b.1d}1V(3e){b=c}I b==c};D(1b).2O("4X",H(){D("*").1e(S).4e()});D.17.1l({67:D.17.43,43:H(g,d,c){G(1j g!=\'23\')I 7.67(g);J e=g.1h(" ");G(e>=0){J i=g.3s(e,g.K);g=g.3s(0,e)}c=c||H(){};J f="2P";G(d)G(D.1D(d)){c=d;d=U}N{d=D.3n(d);f="6g"}J h=7;D.3Y({1a:g,O:f,1O:"2K",L:d,1J:H(a,b){G(b=="1W"||b=="7J")h.2K(i?D("<1v/>").3v(a.4U.1o(/<1m(.|\\s)*?\\/1m>/g,"")).2q(i):a.4U);h.P(c,[a.4U,b,a])}});I 7},aL:H(){I D.3n(7.7I())},7I:H(){I 7.2l(H(){I D.Y(7,"3V")?D.2d(7.aH):7}).1E(H(){I 7.34&&!7.3R&&(7.4J||/2A|6y/i.11(7.Y)||/1r|1G|3Q/i.11(7.O))}).2l(H(i,c){J b=D(7).6e();I b==U?U:b.1q==2p?D.2l(b,H(a,i){I{34:c.34,2x:a}}):{34:c.34,2x:b}}).3p()}});D.P("7H,7G,7F,7D,7C,7B".1R(","),H(i,o){D.17[o]=H(f){I 7.2O(o,f)}});J B=1z();D.1l({3p:H(d,b,a,c){G(D.1D(b)){a=b;b=U}I D.3Y({O:"2P",1a:d,L:b,1W:a,1O:c})},aE:H(b,a){I D.3p(b,U,a,"1m")},aD:H(c,b,a){I D.3p(c,b,a,"3z")},aC:H(d,b,a,c){G(D.1D(b)){a=b;b={}}I D.3Y({O:"6g",1a:d,L:b,1W:a,1O:c})},aA:H(a){D.1l(D.60,a)},60:{1a:5Z.5Q,26:M,O:"2P",2T:0,7z:"4R/x-ax-3V-aw",7x:M,31:M,L:U,5Y:U,3Q:U,4Q:{2N:"4R/2N, 1r/2N",2K:"1r/2K",1m:"1r/4t, 4R/4t",3z:"4R/3z, 1r/4t",1r:"1r/as",4w:"*/*"}},4z:{},3Y:H(s){s=D.1l(M,s,D.1l(M,{},D.60,s));J g,2Z=/=\\?(&|$)/g,1u,L,O=s.O.2r();G(s.L&&s.7x&&1j s.L!="23")s.L=D.3n(s.L);G(s.1O=="4P"){G(O=="2P"){G(!s.1a.1I(2Z))s.1a+=(s.1a.1I(/\\?/)?"&":"?")+(s.4P||"7u")+"=?"}N G(!s.L||!s.L.1I(2Z))s.L=(s.L?s.L+"&":"")+(s.4P||"7u")+"=?";s.1O="3z"}G(s.1O=="3z"&&(s.L&&s.L.1I(2Z)||s.1a.1I(2Z))){g="4P"+B++;G(s.L)s.L=(s.L+"").1o(2Z,"="+g+"$1");s.1a=s.1a.1o(2Z,"="+g+"$1");s.1O="1m";1b[g]=H(a){L=a;1W();1J();1b[g]=12;1U{2U 1b[g]}1V(e){}G(i)i.37(h)}}G(s.1O=="1m"&&s.1Y==U)s.1Y=Q;G(s.1Y===Q&&O=="2P"){J j=1z();J k=s.1a.1o(/(\\?|&)3m=.*?(&|$)/,"$ap="+j+"$2");s.1a=k+((k==s.1a)?(s.1a.1I(/\\?/)?"&":"?")+"3m="+j:"")}G(s.L&&O=="2P"){s.1a+=(s.1a.1I(/\\?/)?"&":"?")+s.L;s.L=U}G(s.26&&!D.4O++)D.W.1P("7H");J n=/^(?:\\w+:)?\\/\\/([^\\/?#]+)/;G(s.1O=="1m"&&O=="2P"&&n.11(s.1a)&&n.2D(s.1a)[1]!=5Z.al){J i=S.3H("6w")[0];J h=S.3h("1m");h.4d=s.1a;G(s.7t)h.aj=s.7t;G(!g){J l=Q;h.ah=h.ag=H(){G(!l&&(!7.3f||7.3f=="68"||7.3f=="1J")){l=M;1W();1J();i.37(h)}}}i.3U(h);I 12}J m=Q;J c=1b.7s?2B 7s("ae.ac"):2B 7r();G(s.5Y)c.6R(O,s.1a,s.31,s.5Y,s.3Q);N c.6R(O,s.1a,s.31);1U{G(s.L)c.4B("ab-aa",s.7z);G(s.5S)c.4B("a9-5R-a8",D.4z[s.1a]||"a7, a6 a5 a4 5N:5N:5N a2");c.4B("X-9Z-9Y","7r");c.4B("9W",s.1O&&s.4Q[s.1O]?s.4Q[s.1O]+", */*":s.4Q.4w)}1V(e){}G(s.7m&&s.7m(c,s)===Q){s.26&&D.4O--;c.7l();I Q}G(s.26)D.W.1P("7B",[c,s]);J d=H(a){G(!m&&c&&(c.3f==4||a=="2T")){m=M;G(f){7k(f);f=U}1u=a=="2T"&&"2T"||!D.7j(c)&&"3e"||s.5S&&D.7h(c,s.1a)&&"7J"||"1W";G(1u=="1W"){1U{L=D.6X(c,s.1O,s.9S)}1V(e){1u="5J"}}G(1u=="1W"){J b;1U{b=c.5I("7g-5R")}1V(e){}G(s.5S&&b)D.4z[s.1a]=b;G(!g)1W()}N D.5H(s,c,1u);1J();G(s.31)c=U}};G(s.31){J f=4I(d,13);G(s.2T>0)3B(H(){G(c){c.7l();G(!m)d("2T")}},s.2T)}1U{c.9P(s.L)}1V(e){D.5H(s,c,U,e)}G(!s.31)d();H 1W(){G(s.1W)s.1W(L,1u);G(s.26)D.W.1P("7C",[c,s])}H 1J(){G(s.1J)s.1J(c,1u);G(s.26)D.W.1P("7F",[c,s]);G(s.26&&!--D.4O)D.W.1P("7G")}I c},5H:H(s,a,b,e){G(s.3e)s.3e(a,b,e);G(s.26)D.W.1P("7D",[a,s,e])},4O:0,7j:H(a){1U{I!a.1u&&5Z.9O=="5p:"||(a.1u>=7e&&a.1u<9N)||a.1u==7c||a.1u==9K||D.14.2k&&a.1u==12}1V(e){}I Q},7h:H(a,c){1U{J b=a.5I("7g-5R");I a.1u==7c||b==D.4z[c]||D.14.2k&&a.1u==12}1V(e){}I Q},6X:H(a,c,b){J d=a.5I("9J-O"),2N=c=="2N"||!c&&d&&d.1h("2N")>=0,L=2N?a.9I:a.4U;G(2N&&L.1C.2j=="5J")7p"5J";G(b)L=b(L,c);G(c=="1m")D.5u(L);G(c=="3z")L=6u("("+L+")");I L},3n:H(a){J s=[];G(a.1q==2p||a.5w)D.P(a,H(){s.1p(3u(7.34)+"="+3u(7.2x))});N R(J j 1n a)G(a[j]&&a[j].1q==2p)D.P(a[j],H(){s.1p(3u(j)+"="+3u(7))});N s.1p(3u(j)+"="+3u(D.1D(a[j])?a[j]():a[j]));I s.6s("&").1o(/%20/g,"+")}});D.17.1l({1N:H(c,b){I c?7.2g({1Z:"1N",2h:"1N",1y:"1N"},c,b):7.1E(":1G").P(H(){7.V.18=7.5D||"";G(D.1g(7,"18")=="2F"){J a=D("<"+7.2j+" />").6P("1c");7.V.18=a.1g("18");G(7.V.18=="2F")7.V.18="3I";a.21()}}).3l()},1M:H(b,a){I b?7.2g({1Z:"1M",2h:"1M",1y:"1M"},b,a):7.1E(":4j").P(H(){7.5D=7.5D||D.1g(7,"18");7.V.18="2F"}).3l()},78:D.17.2m,2m:H(a,b){I D.1D(a)&&D.1D(b)?7.78.1w(7,19):a?7.2g({1Z:"2m",2h:"2m",1y:"2m"},a,b):7.P(H(){D(7)[D(7).3F(":1G")?"1N":"1M"]()})},9G:H(b,a){I 7.2g({1Z:"1N"},b,a)},9F:H(b,a){I 7.2g({1Z:"1M"},b,a)},9E:H(b,a){I 7.2g({1Z:"2m"},b,a)},9D:H(b,a){I 7.2g({1y:"1N"},b,a)},9M:H(b,a){I 7.2g({1y:"1M"},b,a)},9C:H(c,a,b){I 7.2g({1y:a},c,b)},2g:H(k,j,i,g){J h=D.77(j,i,g);I 7[h.36===Q?"P":"36"](H(){G(7.16!=1)I Q;J f=D.1l({},h),p,1G=D(7).3F(":1G"),46=7;R(p 1n k){G(k[p]=="1M"&&1G||k[p]=="1N"&&!1G)I f.1J.1k(7);G(p=="1Z"||p=="2h"){f.18=D.1g(7,"18");f.33=7.V.33}}G(f.33!=U)7.V.33="1G";f.45=D.1l({},k);D.P(k,H(c,a){J e=2B D.28(46,f,c);G(/2m|1N|1M/.11(a))e[a=="2m"?1G?"1N":"1M":a](k);N{J b=a.6r().1I(/^([+-]=)?([\\d+-.]+)(.*)$/),2b=e.1t(M)||0;G(b){J d=3d(b[2]),2M=b[3]||"2X";G(2M!="2X"){46.V[c]=(d||1)+2M;2b=((d||1)/e.1t(M))*2b;46.V[c]=2b+2M}G(b[1])d=((b[1]=="-="?-1:1)*d)+2b;e.3G(2b,d,2M)}N e.3G(2b,a,"")}});I M})},36:H(a,b){G(D.1D(a)||(a&&a.1q==2p)){b=a;a="28"}G(!a||(1j a=="23"&&!b))I A(7[0],a);I 7.P(H(){G(b.1q==2p)A(7,a,b);N{A(7,a).1p(b);G(A(7,a).K==1)b.1k(7)}})},9X:H(b,c){J a=D.3O;G(b)7.36([]);7.P(H(){R(J i=a.K-1;i>=0;i--)G(a[i].T==7){G(c)a[i](M);a.7n(i,1)}});G(!c)7.5A();I 7}});J A=H(b,c,a){G(b){c=c||"28";J q=D.L(b,c+"36");G(!q||a)q=D.L(b,c+"36",D.2d(a))}I q};D.17.5A=H(a){a=a||"28";I 7.P(H(){J q=A(7,a);q.4s();G(q.K)q[0].1k(7)})};D.1l({77:H(b,a,c){J d=b&&b.1q==a0?b:{1J:c||!c&&a||D.1D(b)&&b,2u:b,41:c&&a||a&&a.1q!=9t&&a};d.2u=(d.2u&&d.2u.1q==4L?d.2u:D.28.5K[d.2u])||D.28.5K.74;d.5M=d.1J;d.1J=H(){G(d.36!==Q)D(7).5A();G(D.1D(d.5M))d.5M.1k(7)};I d},41:{73:H(p,n,b,a){I b+a*p},5P:H(p,n,b,a){I((-29.9r(p*29.9q)/2)+0.5)*a+b}},3O:[],48:U,28:H(b,c,a){7.15=c;7.T=b;7.1i=a;G(!c.3Z)c.3Z={}}});D.28.44={4D:H(){G(7.15.2Y)7.15.2Y.1k(7.T,7.1z,7);(D.28.2Y[7.1i]||D.28.2Y.4w)(7);G(7.1i=="1Z"||7.1i=="2h")7.T.V.18="3I"},1t:H(a){G(7.T[7.1i]!=U&&7.T.V[7.1i]==U)I 7.T[7.1i];J r=3d(D.1g(7.T,7.1i,a));I r&&r>-9p?r:3d(D.2a(7.T,7.1i))||0},3G:H(c,b,d){7.5V=1z();7.2b=c;7.3l=b;7.2M=d||7.2M||"2X";7.1z=7.2b;7.2S=7.4N=0;7.4D();J e=7;H t(a){I e.2Y(a)}t.T=7.T;D.3O.1p(t);G(D.48==U){D.48=4I(H(){J a=D.3O;R(J i=0;i<a.K;i++)G(!a[i]())a.7n(i--,1);G(!a.K){7k(D.48);D.48=U}},13)}},1N:H(){7.15.3Z[7.1i]=D.1K(7.T.V,7.1i);7.15.1N=M;7.3G(0,7.1t());G(7.1i=="2h"||7.1i=="1Z")7.T.V[7.1i]="9m";D(7.T).1N()},1M:H(){7.15.3Z[7.1i]=D.1K(7.T.V,7.1i);7.15.1M=M;7.3G(7.1t(),0)},2Y:H(a){J t=1z();G(a||t>7.15.2u+7.5V){7.1z=7.3l;7.2S=7.4N=1;7.4D();7.15.45[7.1i]=M;J b=M;R(J i 1n 7.15.45)G(7.15.45[i]!==M)b=Q;G(b){G(7.15.18!=U){7.T.V.33=7.15.33;7.T.V.18=7.15.18;G(D.1g(7.T,"18")=="2F")7.T.V.18="3I"}G(7.15.1M)7.T.V.18="2F";G(7.15.1M||7.15.1N)R(J p 1n 7.15.45)D.1K(7.T.V,p,7.15.3Z[p])}G(b)7.15.1J.1k(7.T);I Q}N{J n=t-7.5V;7.4N=n/7.15.2u;7.2S=D.41[7.15.41||(D.41.5P?"5P":"73")](7.4N,n,0,1,7.15.2u);7.1z=7.2b+((7.3l-7.2b)*7.2S);7.4D()}I M}};D.1l(D.28,{5K:{9l:9j,9i:7e,74:9g},2Y:{2e:H(a){a.T.2e=a.1z},2c:H(a){a.T.2c=a.1z},1y:H(a){D.1K(a.T.V,"1y",a.1z)},4w:H(a){a.T.V[a.1i]=a.1z+a.2M}}});D.17.2i=H(){J b=0,1S=0,T=7[0],3q;G(T)ao(D.14){J d=T.1d,4a=T,1s=T.1s,1Q=T.2z,5U=2k&&3r(5B)<9c&&!/9a/i.11(v),1g=D.2a,3c=1g(T,"30")=="3c";G(T.7y){J c=T.7y();1e(c.1A+29.2f(1Q.1C.2e,1Q.1c.2e),c.1S+29.2f(1Q.1C.2c,1Q.1c.2c));1e(-1Q.1C.6b,-1Q.1C.6a)}N{1e(T.5X,T.5W);1B(1s){1e(1s.5X,1s.5W);G(42&&!/^t(98|d|h)$/i.11(1s.2j)||2k&&!5U)2C(1s);G(!3c&&1g(1s,"30")=="3c")3c=M;4a=/^1c$/i.11(1s.2j)?4a:1s;1s=1s.1s}1B(d&&d.2j&&!/^1c|2K$/i.11(d.2j)){G(!/^96|1T.*$/i.11(1g(d,"18")))1e(-d.2e,-d.2c);G(42&&1g(d,"33")!="4j")2C(d);d=d.1d}G((5U&&(3c||1g(4a,"30")=="5x"))||(42&&1g(4a,"30")!="5x"))1e(-1Q.1c.5X,-1Q.1c.5W);G(3c)1e(29.2f(1Q.1C.2e,1Q.1c.2e),29.2f(1Q.1C.2c,1Q.1c.2c))}3q={1S:1S,1A:b}}H 2C(a){1e(D.2a(a,"6V",M),D.2a(a,"6U",M))}H 1e(l,t){b+=3r(l,10)||0;1S+=3r(t,10)||0}I 3q};D.17.1l({30:H(){J a=0,1S=0,3q;G(7[0]){J b=7.1s(),2i=7.2i(),4c=/^1c|2K$/i.11(b[0].2j)?{1S:0,1A:0}:b.2i();2i.1S-=25(7,\'94\');2i.1A-=25(7,\'aF\');4c.1S+=25(b,\'6U\');4c.1A+=25(b,\'6V\');3q={1S:2i.1S-4c.1S,1A:2i.1A-4c.1A}}I 3q},1s:H(){J a=7[0].1s;1B(a&&(!/^1c|2K$/i.11(a.2j)&&D.1g(a,\'30\')==\'93\'))a=a.1s;I D(a)}});D.P([\'5e\',\'5G\'],H(i,b){J c=\'4y\'+b;D.17[c]=H(a){G(!7[0])I;I a!=12?7.P(H(){7==1b||7==S?1b.92(!i?a:D(1b).2e(),i?a:D(1b).2c()):7[c]=a}):7[0]==1b||7[0]==S?46[i?\'aI\':\'aJ\']||D.71&&S.1C[c]||S.1c[c]:7[0][c]}});D.P(["6N","4b"],H(i,b){J c=i?"5e":"5G",4f=i?"6k":"6i";D.17["5s"+b]=H(){I 7[b.3y()]()+25(7,"57"+c)+25(7,"57"+4f)};D.17["90"+b]=H(a){I 7["5s"+b]()+25(7,"2C"+c+"4b")+25(7,"2C"+4f+"4b")+(a?25(7,"6S"+c)+25(7,"6S"+4f):0)}})})();',62,669,'|||||||this|||||||||||||||||||||||||||||||||||if|function|return|var|length|data|true|else|type|each|false|for|document|elem|null|style|event||nodeName|||test|undefined||browser|options|nodeType|fn|display|arguments|url|window|body|parentNode|add|msie|css|indexOf|prop|typeof|call|extend|script|in|replace|push|constructor|text|offsetParent|cur|status|div|apply|firstChild|opacity|now|left|while|documentElement|isFunction|filter|className|hidden|handle|match|complete|attr|ret|hide|show|dataType|trigger|doc|split|top|table|try|catch|success|break|cache|height||remove|tbody|string|guid|num|global|ready|fx|Math|curCSS|start|scrollTop|makeArray|scrollLeft|max|animate|width|offset|tagName|safari|map|toggle||done|Array|find|toUpperCase|button|special|duration|id|copy|value|handler|ownerDocument|select|new|border|exec|stack|none|opera|nextSibling|pushStack|target|html|inArray|unit|xml|bind|GET|isReady|merge|pos|timeout|delete|one|selected|px|step|jsre|position|async|preventDefault|overflow|name|which|queue|removeChild|namespace|insertBefore|nth|removeData|fixed|parseFloat|error|readyState|multiFilter|createElement|rl|re|trim|end|_|param|first|get|results|parseInt|slice|childNodes|encodeURIComponent|append|events|elems|toLowerCase|json|readyList|setTimeout|grep|mouseenter|color|is|custom|getElementsByTagName|block|stopPropagation|addEventListener|callee|proxy|mouseleave|timers|defaultView|password|disabled|last|has|appendChild|form|domManip|props|ajax|orig|set|easing|mozilla|load|prototype|curAnim|self|charCode|timerId|object|offsetChild|Width|parentOffset|src|unbind|br|currentStyle|clean|float|visible|relatedTarget|previousSibling|handlers|isXMLDoc|on|setup|nodeIndex|unique|shift|javascript|child|RegExp|_default|deep|scroll|lastModified|teardown|setRequestHeader|timeStamp|update|empty|tr|getAttribute|innerHTML|setInterval|checked|fromElement|Number|jQuery|state|active|jsonp|accepts|application|dir|input|responseText|click|styleSheets|unload|not|lastToggle|outline|mouseout|getPropertyValue|mouseover|getComputedStyle|bindReady|String|padding|pageX|metaKey|keyCode|getWH|andSelf|clientX|Left|all|visibility|container|index|init|triggered|removeAttribute|classFilter|prevObject|submit|file|after|windowData|inner|client|globalEval|sibling|jquery|absolute|clone|wrapAll|dequeue|version|triggerHandler|oldblock|ctrlKey|createTextNode|Top|handleError|getResponseHeader|parsererror|speeds|checkbox|old|00|radio|swing|href|Modified|ifModified|lastChild|safari2|startTime|offsetTop|offsetLeft|username|location|ajaxSettings|getElementById|isSimple|values|selectedIndex|runtimeStyle|rsLeft|_load|loaded|DOMContentLoaded|clientTop|clientLeft|toElement|srcElement|val|pageY|POST|unshift|Bottom|clientY|Right|fix|exclusive|detachEvent|cloneNode|removeEventListener|swap|toString|join|attachEvent|eval|substr|head|parse|textarea|reset|image|zoom|odd|even|before|prepend|exclude|expr|quickClass|quickID|uuid|quickChild|continue|Height|textContent|appendTo|contents|open|margin|evalScript|borderTopWidth|borderLeftWidth|parent|httpData|setArray|CSS1Compat|compatMode|boxModel|cssFloat|linear|def|webkit|nodeValue|speed|_toggle|eq|100|replaceWith|304|concat|200|alpha|Last|httpNotModified|getAttributeNode|httpSuccess|clearInterval|abort|beforeSend|splice|styleFloat|throw|colgroup|XMLHttpRequest|ActiveXObject|scriptCharset|callback|fieldset|multiple|processData|getBoundingClientRect|contentType|link|ajaxSend|ajaxSuccess|ajaxError|col|ajaxComplete|ajaxStop|ajaxStart|serializeArray|notmodified|keypress|keydown|change|mouseup|mousedown|dblclick|focus|blur|stylesheet|hasClass|rel|doScroll|black|hover|solid|cancelBubble|returnValue|wheelDelta|view|round|shiftKey|resize|screenY|screenX|relatedNode|mousemove|prevValue|originalTarget|offsetHeight|keyup|newValue|offsetWidth|eventPhase|detail|currentTarget|cancelable|bubbles|attrName|attrChange|altKey|originalEvent|charAt|0n|substring|animated|header|noConflict|line|enabled|innerText|contains|only|weight|font|gt|lt|uFFFF|u0128|size|417|Boolean|Date|toggleClass|removeClass|addClass|removeAttr|replaceAll|insertAfter|prependTo|wrap|contentWindow|contentDocument|iframe|children|siblings|prevAll|wrapInner|nextAll|outer|prev|scrollTo|static|marginTop|next|inline|parents|able|cellSpacing|adobeair|cellspacing|522|maxLength|maxlength|readOnly|400|readonly|fast|600|class|slow|1px|htmlFor|reverse|10000|PI|cos|compatible|Function|setData|ie|ra|it|rv|getData|userAgent|navigator|fadeTo|fadeIn|slideToggle|slideUp|slideDown|ig|responseXML|content|1223|NaN|fadeOut|300|protocol|send|setAttribute|option|dataFilter|cssText|changed|be|Accept|stop|With|Requested|Object|can|GMT|property|1970|Jan|01|Thu|Since|If|Type|Content|XMLHTTP|th|Microsoft|td|onreadystatechange|onload|cap|charset|colg|host|tfoot|specified|with|1_|thead|leg|plain|attributes|opt|embed|urlencoded|www|area|hr|ajaxSetup|meta|post|getJSON|getScript|marginLeft|img|elements|pageYOffset|pageXOffset|abbr|serialize|pixelLeft'.split('|'),0,{}))
Added: branches/dev_lenkne/http/extensions/jquery-impromptu.1.5.js
--- branches/dev_lenkne/http/extensions/jquery-impromptu.1.5.js	                        (rev 0)
+++ branches/dev_lenkne/http/extensions/jquery-impromptu.1.5.js	2008-08-15 22:20:09 UTC (rev 2837)
@@ -0,0 +1,133 @@
+ * jQuery Impromptu
+ * By: Trent Richardson [http://trentrichardson.com]
+ * Version 1.5
+ * Last Modified: 3/31/2008
+ * Copyright 2008 Trent Richardson
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ *     http://www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an "AS IS" BASIS,
+ * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+jQuery.extend({
+	ImpromptuDefaults: { prefix:'jqi', buttons:{ Ok:true }, loaded:function(){}, submit:function(){return true;}, callback:function(){}, opacity:0.6, zIndex: 999, overlayspeed:'slow', promptspeed:'fast', show:'show', focus:0, useiframe:false },
+	SetImpromptuDefaults: function(o){
+		jQuery.ImpromptuDefaults = jQuery.extend({},jQuery.ImpromptuDefaults,o);
+	prompt: function(m,o){
+		o = jQuery.extend({},jQuery.ImpromptuDefaults,o);
+		var ie6 = (jQuery.browser.msie && jQuery.browser.version < 7);
+		var b = jQuery(document.body);
+		var w = jQuery(window);
+		var msgbox = '<div class="'+ o.prefix +'box" id="'+ o.prefix +'box">';
+		if(o.useiframe && ((jQuery.browser.msie && jQuery('object, applet').length > 0) || ie6))//if you want to use the iframe uncomment these 3 lines
+			msgbox += '<iframe src="javascript:;" class="'+ o.prefix +'fade" id="'+ o.prefix +'fade"></iframe>';
+		else{
+			if(ie6) $('select').css('visibility','hidden');
+			msgbox +='<div class="'+ o.prefix +'fade" id="'+ o.prefix +'fade"></div>';
+		msgbox += '<div class="'+ o.prefix +'" id="'+ o.prefix +'"><div class="'+ o.prefix +'container"><div class="'+ o.prefix +'close">X</div><div class="'+ o.prefix +'message">'+ m +'</div><div class="'+ o.prefix +'buttons" id="'+ o.prefix +'buttons">';
+		jQuery.each(o.buttons,function(k,v){ msgbox += '<button name="'+ o.prefix +'button'+ k +'" id="'+ o.prefix +'button'+ k +'" value="'+ v +'">'+ k +'</button>'}) ;
+		msgbox += '</div></div></div></div>';
+		var jqib =b.append(msgbox).children('#'+ o.prefix +'box');
+		var jqi = jqib.children('#'+ o.prefix);
+		var jqif = jqib.children('#'+ o.prefix +'fade');
+		var getWindowScrollOffset = function(){
+			return (document.documentElement.scrollTop || document.body.scrollTop) + 'px';
+		var getWindowSize = function(){
+			var size = {
+				width: window.innerWidth || (window.document.documentElement.clientWidth || window.document.body.clientWidth),
+				height: window.innerHeight || (window.document.documentElement.clientHeight || window.document.body.clientHeight)
+			return size;
+		var ie6scroll = function(){
+			jqib.css({ top: getWindowScrollOffset() });
+		var flashPrompt = function(){
+			var i = 0;
+			jqib.addClass(o.prefix +'warning');
+			var intervalid = setInterval(function(){
+				jqib.toggleClass(o.prefix +'warning');
+				if(i++ > 1){
+					clearInterval(intervalid);
+					jqib.removeClass(o.prefix +'warning');
+			}, 100);
+		var escapeKeyClosePrompt = function(e){
+			var kC = (window.event) ? event.keyCode : e.keyCode; // MSIE or Firefox?
+			var Esc = (window.event) ? 27 : e.DOM_VK_ESCAPE; // MSIE : Firefox
+			if(kC==Esc) removePrompt();
+		var positionPrompt = function(){
+			var wsize = getWindowSize();
+			jqib.css({ position: (ie6)? "absolute" : "fixed", height: wsize.height, width: "100%", top: (ie6)? getWindowScrollOffset():0, left: 0, right: 0, bottom: 0 });
+			jqif.css({ position: "absolute", height: wsize.height, width: "100%", top: 0, left: 0, right: 0, bottom: 0 });
+			jqi.css({ position: "absolute", top: "100px", left: "50%", marginLeft: ((((jqi.css("paddingLeft").split("px")[0]*1) + jqi.width())/2)*-1) });
+		var stylePrompt = function(){
+			jqif.css({ zIndex: o.zIndex, display: "none", opacity: o.opacity });
+			jqi.css({ zIndex: o.zIndex+1, display: "none" });
+		var removePrompt = function(callCallback, clicked, msg){
+			jqi.remove();
+			if(ie6)b.unbind('scroll',ie6scroll);//ie6, remove the scroll event
+			w.unbind('resize',positionPrompt);
+			jqif.fadeOut(o.overlayspeed,function(){
+				jqif.unbind('click',flashPrompt);
+				jqif.remove();
+				if(callCallback) o.callback(clicked,msg);
+				jqib.unbind('keypress',escapeKeyClosePrompt);
+				jqib.remove();
+				if(ie6 && !o.useiframe) $('select').css('visibility','visible');
+		positionPrompt();
+		stylePrompt();
+		//Events
+		jQuery('#'+ o.prefix +'buttons').children('button').click(function(){
+			var msg = jqi.children('.'+ o.prefix +'container').children('.'+ o.prefix +'message');
+			var clicked = o.buttons[jQuery(this).text()];
+			if(o.submit(clicked,msg))
+				removePrompt(true,clicked,msg);
+		if(ie6) w.scroll(ie6scroll);//ie6, add a scroll event to fix position:fixed
+		jqif.click(flashPrompt);
+		w.resize(positionPrompt);
+		jqib.keypress(escapeKeyClosePrompt);
+		jqi.find('.'+ o.prefix +'close').click(removePrompt);
+		//Show it
+		jqif.fadeIn(o.overlayspeed);
+		jqi[o.show](o.promptspeed,o.loaded);
+		jqi.find('#'+ o.prefix +'buttons button:eq('+ o.focus +')').focus();//focus the default button
+		return jqib;
Added: branches/dev_lenkne/http/extensions/jquery.formvalidation.1.1.5.js
--- branches/dev_lenkne/http/extensions/jquery.formvalidation.1.1.5.js	                        (rev 0)
+++ branches/dev_lenkne/http/extensions/jquery.formvalidation.1.1.5.js	2008-08-15 22:20:09 UTC (rev 2837)
@@ -0,0 +1,232 @@
+ * jQuery Form Validation plug-in version 1.1.5
+ * Last Update : July 13, 2008
+ * New features:
+ * onError event
+ * Add call back support - callback function is called when validation is error, return true form will be submited otherwise not.
+ * Error list in the alert msg
+ * Alias to field name
+ * Select diff html attributes for validation rules instead off using custom html attributes
+ * Bug Fixed:
+ * now support radio buttons
+ * defval to work with LabelIn plugin
+ * now support textarea
+ * Copyright (c) 2007 E-wave web design
+ *   http://www.ewave.com.au/
+ * Licensed under the GPL license:
+ *   http://www.gnu.org/licenses/gpl.html
+ * @requires jQuery v 1.2.1 or later
+ * @name	formValidation
+ * @usage		$('#form1').formValidation({
+ *		newmask : /[0-9]{1}-[0-9]{1}/,	// 1-1
+ *		err_class : "invalidInput"
+ * HTML
+ * <form id="form1">
+ * <input id="input1" type="text" required="true" mask="email"></input>
+ * <input id="input2" type="text" required="true" mask="email" equal="input2"></input>
+ * <input type="submit" value="Submit>
+ * </form>
+ * Description
+ * Validate form fields accordiing to 4 keys
+ * required - check that text field is not empty. checkbox checked, and select val is not empty
+ * equal - checks that field value equal to another field with this id
+ * mask - compre value to mask using reg exp
+ * defval - ignore default value
+ * Prevent Submit and Display alert when not validate and change class of field to invalid class
+ * @param String version
+ * 	Plugin Version
+ * @param String err_class
+ * 	invalid input class name
+ * @param String displayAlert
+ * 	display alert when submit form is invalid
+ *  default true
+ * @param String err_message
+ * 	alert message
+ * @param reg-exp email
+ * 	email pattern
+ * @param reg-exp domain
+ * 	domain pattern
+ * @param reg-exp phone
+ * 	phone pattern
+ * @param reg-exp zip
+ * 	zip pattern
+ * @param reg-exp numeric
+ * 	numeric pattern
+ * @param reg-exp image
+ * 	image file name pattern
+ * @param reg-exp pdf
+ * 	pdf file name pattern
+ * @param alias, required, mask, equal, defval
+ * 	validation rules map to input attributes
+if (!window.jQuery) {
+	throw("jQuery must be referenced before using formValidation");
+} else {
+	(function() {
+		jQuery.fn.formValidation = function(settings, err_msgs) {
+		var iForm = this;
+		var err_list = '';
+		settings = jQuery.extend({
+			version				: '1.1.2',
+			email					:	/^([\w.])+\@(([\w])+\.)[a-zA-Z0-9]{2,}/,
+			domain				:	/^(http:\/\/)([\w]+\.){1,}[A-Z]{2,4}\b/gi,
+			phone					:	/^\+[0-9]{1,3}\.[1-9]{1,2}\.[0-9]{6,}$/gi,
+			zip						:	/^[0-9]{4,}$/gi,
+			numeric				:	/^[0-9]+$/gi,
+			image					:	/[\w]+\.(gif|jpg|bmp|png|jpeg)$/gi,
+			ewvt					:	/[\w]+\.(htm|html|php|txt)$/gi,
+			media					:	/[\w]+\.(avi|mov|mpeg|wmv)$/gi,
+			pdf						:	/[\w]+\.(pdf)$/gi,
+			enable				: false,
+			err_class			: "invalidInput",
+			err_list			: false,
+			alias					:	'name',
+			required			: 'required',
+			mask					: 'mask',
+			equal					: 'equal',
+			defval				: 'defval',
+			callback			:	'',
+			err_message		: "Please fill all required fields! (Marked with red background colour)\n",
+			display_alert	: true	//onsubmit if invalid form display an error message
+		}, settings);
+		err_msgs = jQuery.extend({
+			required	: 'is required',
+			mask			: 'Invalid',
+			equal			: 'is not equal to'
+		}, err_msgs);
+		return iForm.submit( function () {
+				settings['enable'] = true;
+				err_list = '';
+				var frm = true;
+				$(this).find('*').filter("input, select, textarea").each(function() {
+					ret = isValid($(this));
+					if (!ret)
+						frm = ret;
+				if (frm && (typeof settings['callback'] == 'string' && eval('typeof ' + settings['callback']) == 'function')) // form validation ok and callback function defined
+					frm = eval(settings['callback'] + '()'); //call external validation function
+				else if (settings['display_alert'])	// error validation and display alert on
+						alert(settings['err_message'] + err_list);	// display message
+				return frm;
+			}).find('*').filter("input, select, textarea").each(function() {
+			$(this).click(function() {
+				isValid($(this));
+			}).change(function() {
+				isValid($(this));
+			}).keyup(function() {
+				isValid($(this));
+			}).focus(function() {
+				isValid($(this));
+			}).blur(function() {
+				isValid($(this));
+		function isValid(obj) { // check if field is valid
+			if (!settings['enable'])
+				return true;
+			if (required(obj) && mask(obj) && equal(obj)) {
+				obj.removeClass(settings['err_class']);
+				return true;
+			} else {
+				obj.addClass(settings['err_class']);
+				return false;
+		//field is required
+		function required(obj) {
+			if (!(obj.attr(settings['required']) == "true"))	//if not required return true
+				return true;
+			if(obj.is("input[@type=checkbox]") || obj.is('input[@type=radio]')) {		//if checkbox and checked
+				if (obj.attr('checked'))
+					return true;
+			} else if((obj.is("input") || obj.is("select") || obj.is("textarea")) && (!obj.is("button"))) // if not empty
+				if (obj.val() != '' && (!(defval(obj))))
+					return true;
+			if (settings['err_list'])
+				err_list += '- "' + obj.attr(settings['alias']) + '" ' + err_msgs['required'] + '\n';
+			return false;
+		//compare field to mask provided in the extend array
+		function mask(obj) {
+			tname = obj.attr('mask');	//read mask name from input field
+			if (tname == undefined || obj.val() == '')
+				return true;
+			tmask = settings[obj.attr(settings['mask'])];	// get mask pattern from settings
+			ret = tmask.test(obj.val());			//test reg exp
+			ret1 = tmask.exec(obj.val());
+			if (ret)
+				return true;
+				err_list += '- ' + err_msgs['mask'] + ' "' + obj.attr(settings['alias']) + '"\n';
+			return false;
+		//copare field to another field read from the equal attribute
+		function equal(obj) {
+			tname = obj.attr(settings['equal']);		//get comparison field
+			tval = $('#'+tname).val();
+			if (tname == undefined)
+				return true;
+			if (tval == obj.val())
+				return true;
+				err_list += '- "' + obj.attr(settings['alias']) + '" ' + err_msgs['equal'] + ' ' + $('#'+tname).attr('alias') + '\n';
+			return false;
+		//compare field with defval attr, make sure that val was altered
+		function defval(obj) {
+			tdefval = obj.attr(settings['defval']);		//get comparison field
+			tval = obj.val();
+			if (tdefval == undefined)
+				return false;
+			if (tval != tdefval)
+				return false;
+			return true;
+	})(jQuery);
Modified: branches/dev_lenkne/http/extensions/jquery.js
--- branches/dev_lenkne/http/extensions/jquery.js	2008-08-15 20:58:02 UTC (rev 2836)
+++ branches/dev_lenkne/http/extensions/jquery.js	2008-08-15 22:20:09 UTC (rev 2837)
@@ -1,11 +1,2 @@
- * jQuery 1.2.2 - New Wave Javascript
- * Copyright (c) 2007 John Resig (jquery.com)
- * Dual licensed under the MIT (MIT-LICENSE.txt)
- * and GPL (GPL-LICENSE.txt) licenses.
- * $Date: 2008-01-14 17:56:07 -0500 (Mon, 14 Jan 2008) $
- * $Rev: 4454 $
 eval(function(p,a,c,k,e,r){e=function(c){return(c<a?'':e(parseInt(c/a)))+((c=c%a)>35?String.fromCharCode(c+29):c.toString(36))};if(!''.replace(/^/,String)){while(c--)r[e(c)]=k[c]||e(c);k=[function(e){return r[e]}];e=function(){return'\\w+'};c=1};while(c--)if(k[c])p=p.replace(new RegExp('\\b'+e(c)+'\\b','g'),k[c]);return p}('(J(){7(1e.19)L w=1e.19;L E=1e.19=J(a,b){K 1D E.2m.4Y(a,b)};7(1e.$)L D=1e.$;1e.$=E;L u=/^[^<]*(<(.|\\s)+>)[^>]*$|^#(\\w+)$/;L G=/^.[^:#\\[\\.]*$/;E.1i=E.2m={4Y:J(d,b){d=d||T;7(d.15){6[0]=d;6.M=1;K 6}N 7(1v d=="25"){L c=u.39(d);7(c&&(c[1]||!b)){7(c[1])d=E.5c([c[1]],b);N{L a=T.5N(c[3]);7(a)7(a.2s!=c[3])K E().2r(d);N{6[0]=a;6.M=1;K 6}N d=[]}}N K 1D E(b).2r(d)}N 7(E.1q(d))K 1D E(T)[E.1i.21?"21":"43"](d);K 6.6G(d.1n==1N&&d||(d.5j||d.M&&d!=1e&&!d.15&&d[0]!=10&&d[0].15)&&E.2H(d)||[d])},5j:"1.2.2",82:J(){K 6.M},M:0,22:J(a){K a==10?E.2H(6):6[a]},2E:J(b){L a=E(b);a.56=6;K a},6G:J(a){6.M=0;1N.2m.1h.1j(6,a);K 6},V:J(a,b){K E.V(6,a,b)},5E:J(b){L a=-1;6.V(J(i){7(6==b)a=i});K a},1K:J(c,a,b){L d=c;7(c.1n==4d)7(a==10)K 6.M&&E[b||"1K"](6[0],c)||10;N{d={};d[c]=a}K 6.V(J(i){P(c 1r d)E.1K(b?6.Y:6,c,E.1l(6,d[c],b,i,c))})},1m:J(b,a){7((b==\'29\'||b==\'1P\')&&2M(a)<0)a=10;K 6.1K(b,a,"2q")},1t:J(b){7(1v b!="4D"&&b!=W)K 6.4B().3t((6[0]&&6[0].2u||T).5v(b));L a="";E.V(b||6,J(){E.V(6.3p,J(){7(6.15!=8)a+=6.15!=1?6.6M:E.1i.1t([6])})});K a},5r:J(b){7(6[0])E(b,6[0].2u).5J().3n(6[0]).2a(J(){L a=6;2e(a.1B)a=a.1B;K a}).3t(6);K 6},8t:J(a){K 6.V(J(){E(6).6C().5r(a)})},8m:J(a){K 6.V(J(){E(6).5r(a)})},3t:J(){K 6.3P(1a,R,S,J(a){7(6.15==1)6.3k(a)})},6s:J(){K 6.3P(1a,R,R,J(a){7(6.15==1)6.3n(a,6.1B)})},6o:J(){K 6.3P(1a,S,S,J(a){6.1b.3n(a,6)})},5a:J(){K 6.3P(1a,S,R,J(a){6.1b.3n(a,6.2J)})},3h:J(){K 6.56||E([])},2r:J(b){L c=E.2a(6,J(a){K E.2r(b,a)});K 6.2E(/[^+>] [^+>]/.17(b)||b.1g("..")>-1?E.57(c):c)},5J:J(e){L f=6.2a(J(){7(E.14.1d&&!E.3W(6)){L a=6.6c(R),5u=T.2R("1u"),4T=T.2R("1u");5u.3k(a);4T.38=5u.38;K 4T.1B}N K 6.6c(R)});L d=f.2r("*").4R().V(J(){7(6[F]!=10)6[F]=W});7(e===R)6.2r("*").4R().V(J(i){7(6.15==3)K;L c=E.Q(6,"2N");P(L a 1r c)P(L b 1r c[a])E.16.1c(d[i],a,c[a][b],c[a][b].Q)});K f},1F:J(b){K 6.2E(E.1q(b)&&E.3x(6,J(a,i){K b.1O(a,i)})||E.3d(b,6))},4I:J(b){7(b.1n==4d)7(G.17(b))K 6.2E(E.3d(b,6,R));N b=E.3d(b,6);L a=b.M&&b[b.M-1]!==10&&!b.15;K 6.1F(J(){K a?E.35(6,b)<0:6!=b})},1c:J(a){K!a?6:6.2E(E.34(6.22(),a.1n==4d?E(a).22():a.M!=10&&(!a.12||E.12(a,"3i"))?a:[a]))},3K:J(a){K a?E.3d(a,6).M>0:S},7g:J(a){K 6.3K("."+a)},5P:J(b){7(b==10){7(6.M){L c=6[0];7(E.12(c,"2y")){L e=c.44,5L=[],11=c.11,30=c.U=="2y-30";7(e<0)K W;P(L i=30?e:0,2b=30?e+1:11.M;i<2b;i++){L d=11[i];7(d.2p){b=E.14.1d&&!d.9s.1C.9o?d.1t:d.1C;7(30)K b;5L.1h(b)}}K 5L}N K(6[0].1C||"").1p(/\\r/g,"")}K 10}K 6.V(J(){7(6.15!=1)K;7(b.1n==1N&&/5w|5y/.17(6.U))6.3o=(E.35(6.1C,b)>=0||E.35(6.37,b)>=0);N 7(E.12(6,"2y")){L a=b.1n==1N?b:[b];E("90",6).V(J(){6.2p=(E.35(6.1C,a)>=0||E.35(6.1t,a)>=0)});7(!a.M)6.44=-1}N 6.1C=b})},3q:J(a){K a==10?(6.M?6[0].38:W):6.4B().3t(a)},6P:J(a){K 6.5a(a).1Y()},6N:J(i){K 6.2V(i,i+1)},2V:J(){K 6.2E(1N.2m.2V.1j(6,1a))},2a:J(b){K 6.2E(E.2a(6,J(a,i){K b.1O(a,i,a)}))},4R:J(){K 6.1c(6.56)},3P:J(g,f,h,d){L e=6.M>1,3m;K 6.V(J(){7(!3m){3m=E.5c(g,6.2u);7(h)3m.8I()}L b=6;7(f&&E.12(6,"1V")&&E.12(3m[0],"4x"))b=6.3V("1S")[0]||6.3k(6.2u.2R("1S"));L c=E([]);E.V(3m,J(){L a=e?E(6).5J(R)[0]:6;7(E.12(a,"1o")){c=c.1c(a)}N{7(a.15==1)c=c.1c(E("1o",a).1Y());d.1O(b,a)}});c.V(6D)})}};E.2m.4Y.2m=E.2m;J 6D(i,a){7(a.3R)E.3Q({1f:a.3R,3l:S,1G:"1o"});N E.5l(a.1t||a.6A||a.38||"");7(a.1b)a.1b.2X(a)}E.1s=E.1i.1s=J(){L b=1a[0]||{},i=1,M=1a.M,5i=S,11;7(b.1n==8f){5i=b;b=1a[1]||{};i=2}7(1v b!="4D"&&1v b!="J")b={};7(M==1){b=6;i=0}P(;i<M;i++)7((11=1a[i])!=W)P(L a 1r 11){7(b===11[a])6z;7(5i&&11[a]&&1v 11[a]=="4D"&&b[a]&&!11[a].15)b[a]=E.1s(b[a],11[a]);N 7(11[a]!=10)b[a]=11[a]}K b};L F="19"+(1D 3O()).3N(),6y=0,5e={};L H=/z-?5E|89-?87|1y|6q|85-?1P/i;E.1s({81:J(a){1e.$=D;7(a)1e.19=w;K E},1q:J(a){K!!a&&1v a!="25"&&!a.12&&a.1n!=1N&&/J/i.17(a+"")},3W:J(a){K a.1I&&!a.1k||a.28&&a.2u&&!a.2u.1k},5l:J(a){a=E.3f(a);7(a){L b=T.3V("6k")[0]||T.1I,1o=T.2R("1o");1o.U="1t/4l";7(E.14.1d)1o.1t=a;N 1o.3k(T.5v(a));b.3k(1o);b.2X(1o)}},12:J(b,a){K b.12&&b.12.2F()==a.2F()},1Q:{},Q:J(c,d,b){c=c==1e?5e:c;L a=c[F];7(!a)a=c[F]=++6y;7(d&&!E.1Q[a])E.1Q[a]={};7(b!=10)E.1Q[a][d]=b;K d?E.1Q[a][d]:a},3H:J(c,b){c=c==1e?5e:c;L a=c[F];7(b){7(E.1Q[a]){2T E.1Q[a][b];b="";P(b 1r E.1Q[a])1T;7(!b)E.3H(c)}}N{1R{2T c[F]}1W(e){7(c.55)c.55(F)}2T E.1Q[a]}},V:J(c,a,b){7(b){7(c.M==10){P(L d 1r c)7(a.1j(c[d],b)===S)1T}N P(L i=0,M=c.M;i<M;i++)7(a.1j(c[i],b)===S)1T}N{7(c.M==10){P(L d 1r c)7(a.1O(c[d],d,c[d])===S)1T}N P(L i=0,M=c.M,1C=c[0];i<M&&a.1O(1C,i,1C)!==S;1C=c[++i]){}}K c},1l:J(b,a,c,i,d){7(E.1q(a))a=a.1O(b,i);K a&&a.1n==53&&c=="2q"&&!H.17(d)?a+"2P":a},1w:{1c:J(c,b){E.V((b||"").2d(/\\s+/),J(i,a){7(c.15==1&&!E.1w.3E(c.1w,a))c.1w+=(c.1w?" ":"")+a})},1Y:J(c,b){7(c.15==1)c.1w=b!=10?E.3x(c.1w.2d(/\\s+/),J(a){K!E.1w.3E(b,a)}).6g(" "):""},3E:J(b,a){K E.35(a,(b.1w||b).3D().2d(/\\s+/))>-1}},6e:J(b,c,a){L e={};P(L d 1r c){e[d]=b.Y[d];b.Y[d]=c[d]}a.1O(b);P(L d 1r c)b.Y[d]=e[d]},1m:J(d,e,c){7(e=="29"||e=="1P"){L b,3S={3C:"4Z",4X:"23",18:"3u"},3r=e=="29"?["7P","7M"]:["7L","7K"];J 4S(){b=e=="29"?d.7J:d.7I;L a=0,3a=0;E.V(3r,J(){a+=2M(E.2q(d,"7H"+6,R))||0;3a+=2M(E.2q(d,"3a"+6+"62",R))||0});b-=1Z.7E(a+3a)}7(E(d).3K(":4b"))4S();N E.6e(d,3S,4S);K 1Z.2b(0,b)}K E.2q(d,e,c)},2q:J(e,k,j){L d;J 3y(b){7(!E.14.26)K S;L a=T.4a.4L(b,W);K!a||a.4K("3y")==""}7(k=="1y"&&E.14.1d){d=E.1K(e.Y,"1y");K d==""?"1":d}7(E.14.2B&&k=="18"){L c=e.Y.18;e.Y.18="3u";e.Y.18=c}7(k.1E(/4c/i))k=y;7(!j&&e.Y&&e.Y[k])d=e.Y[k];N 7(T.4a&&T.4a.4L){7(k.1E(/4c/i))k="4c";k=k.1p(/([A-Z])/g,"-$1").2w();L h=T.4a.4L(e,W);7(h&&!3y(e))d=h.4K(k);N{L f=[],2L=[];P(L a=e;a&&3y(a);a=a.1b)2L.4U(a);P(L i=0;i<2L.M;i++)7(3y(2L[i])){f[i]=2L[i].Y.18;2L[i].Y.18="3u"}d=k=="18"&&f[2L.M-1]!=W?"2D":(h&&h.4K(k))||"";P(L i=0;i<f.M;i++)7(f[i]!=W)2L[i].Y.18=f[i]}7(k=="1y"&&d=="")d="1"}N 7(e.4j){L g=k.1p(/\\-(\\w)/g,J(a,b){K b.2F()});d=e.4j[k]||e.4j[g];7(!/^\\d+(2P)?$/i.17(d)&&/^\\d/.17(d)){L l=e.Y.2c,3A=e.3A.2c;e.3A.2c=e.4j.2c;e.Y.2c=d||0;d=e.Y.7l+"2P";e.Y.2c=l;e.3A.2c=3A}}K d},5c:J(l,h){L k=[];h=h||T;7(1v h.2R==\'10\')h=h.2u||h[0]&&h[0].2u||T;E.V(l,J(i,d){7(!d)K;7(d.1n==53)d=d.3D();7(1v d=="25"){d=d.1p(/(<(\\w+)[^>]*?)\\/>/g,J(b,a,c){K c.1E(/^(7k|7h|5Q|7f|48|5O|a3|3v|9Y|9W|9T)$/i)?b:a+"></"+c+">"});L f=E.3f(d).2w(),1u=h.2R("1u");L e=!f.1g("<9R")&&[1,"<2y 78=\'78\'>","</2y>"]||!f.1g("<9O")&&[1,"<77>","</77>"]||f.1E(/^<(9K|1S|9I|9F|9A)/)&&[1,"<1V>","</1V>"]||!f.1g("<4x")&&[2,"<1V><1S>","</1S></1V>"]||(!f.1g("<9y")||!f.1g("<9v"))&&[3,"<1V><1S><4x>","</4x></1S></1V>"]||!f.1g("<5Q")&&[2,"<1V><1S></1S><76>","</76></1V>"]||E.14.1d&&[1,"1u<1u>","</1u>"]||[0,"",""];1u.38=e[1]+d+e[2];2e(e[0]--)1u=1u.5D;7(E.14.1d){L g=!f.1g("<1V")&&f.1g("<1S")<0?1u.1B&&1u.1B.3p:e[1]=="<1V>"&&f.1g("<1S")<0?1u.3p:[];P(L j=g.M-1;j>=0;--j)7(E.12(g[j],"1S")&&!g[j].3p.M)g[j].1b.2X(g[j]);7(/^\\s/.17(d))1u.3n(h.5v(d.1E(/^\\s*/)[0]),1u.1B)}d=E.2H(1u.3p)}7(d.M===0&&(!E.12(d,"3i")&&!E.12(d,"2y")))K;7(d[0]==10||E.12(d,"3i")||d.11)k.1h(d);N k=E.34(k,d)});K k},1K:J(d,e,c){7(!d||d.15==3||d.15==8)K 10;L f=E.3W(d)?{}:E.3S;7(e=="2p"&&E.14.26)d.1b.44;7(f[e]){7(c!=10)d[f[e]]=c;K d[f[e]]}N 7(E.14.1d&&e=="Y")K E.1K(d.Y,"9r",c);N 7(c==10&&E.14.1d&&E.12(d,"3i")&&(e=="9q"||e=="9p"))K d.9n(e).6M;N 7(d.28){7(c!=10){7(e=="U"&&E.12(d,"48")&&d.1b)6Z"U 9i 9g\'t 9b 9a";d.99(e,""+c)}7(E.14.1d&&/6T|3R/.17(e)&&!E.3W(d))K d.4z(e,2);K d.4z(e)}N{7(e=="1y"&&E.14.1d){7(c!=10){d.6q=1;d.1F=(d.1F||"").1p(/6W\\([^)]*\\)/,"")+(2M(c).3D()=="93"?"":"6W(1y="+c*6S+")")}K d.1F&&d.1F.1g("1y=")>=0?(2M(d.1F.1E(/1y=([^)]*)/)[1])/6S).3D():""}e=e.1p(/-([a-z])/92,J(a,b){K b.2F()});7(c!=10)d[e]=c;K d[e]}},3f:J(a){K(a||"").1p(/^\\s+|\\s+$/g,"")},2H:J(b){L a=[];7(1v b!="91")P(L i=0,M=b.M;i<M;i++)a.1h(b[i]);N a=b.2V(0);K a},35:J(b,a){P(L i=0,M=a.M;i<M;i++)7(a[i]==b)K i;K-1},34:J(a,b){7(E.14.1d){P(L i=0;b[i];i++)7(b[i].15!=8)a.1h(b[i])}N P(L i=0;b[i];i++)a.1h(b[i]);K a},57:J(a){L c=[],2j={};1R{P(L i=0,M=a.M;i<M;i++){L b=E.Q(a[i]);7(!2j[b]){2j[b]=R;c.1h(a[i])}}}1W(e){c=a}K c},3x:J(c,a,d){7(1v a=="25")a=4A("S||J(a,i){K "+a+"}");L b=[];P(L i=0,M=c.M;i<M;i++)7(!d&&a(c[i],i)||d&&!a(c[i],i))b.1h(c[i]);K b},2a:J(d,a){L c=[];P(L i=0,M=d.M;i<M;i++){L b=a(d[i],i);7(b!==W&&b!=10){7(b.1n!=1N)b=[b];c=c.6Q(b)}}K c}});L v=8X.8V.2w();E.14={5n:(v.1E(/.+(?:8R|8Q|8P|8O)[\\/: ]([\\d.]+)/)||[])[1],26:/6L/.17(v),2B:/2B/.17(v),1d:/1d/.17(v)&&!/2B/.17(v),3X:/3X/.17(v)&&!/(8M|6L)/.17(v)};L y=E.14.1d?"6K":"6J";E.1s({8J:!E.14.1d||T.6I=="6H",3S:{"P":"8G","8E":"1w","4c":y,6J:y,6K:y,38:"38",1w:"1w",1C:"1C",2W:"2W",3o:"3o",8C:"8B",2p:"2p",8A:"8z",44:"44",6F:"6F",28:"28",12:"12"}});E.V({6E:"O.1b",8y:"19.4w(O,\'1b\')",8x:"19.31(O,2,\'2J\')",8w:"19.31(O,2,\'4v\')",8v:"19.4w(O,\'2J\')",8u:"19.4w(O,\'4v\')",8s:"19.5m(O.1b.1B,O)",8r:"19.5m(O.1B)",6C:"19.12(O,\'8q\')?O.8p||O.8o.T:19.2H(O.3p)"},J(c,d){d=4A("S||J(O){K "+d+"}");E.1i[c]=J(b){L a=E.2a(6,d);7(b&&1v b=="25")a=E.3d(b,a);K 6.2E(E.57(a))}});E.V({6B:"3t",8n:"6s",3n:"6o",8l:"5a",8k:"6P"},J(c,b){E.1i[c]=J(){L a=1a;K 6.V(J(){P(L i=0,M=a.M;i<M;i++)E(a[i])[b](6)})}});E.V({8j:J(a){E.1K(6,a,"");7(6.15==1)6.55(a)},8i:J(a){E.1w.1c(6,a)},8h:J(a){E.1w.1Y(6,a)},8g:J(a){E.1w[E.1w.3E(6,a)?"1Y":"1c"](6,a)},1Y:J(a){7(!a||E.1F(a,[6]).r.M){E("*",6).1c(6).V(J(){E.16.1Y(6);E.3H(6)});7(6.1b)6.1b.2X(6)}},4B:J(){E(">*",6).1Y();2e(6.1B)6.2X(6.1B)}},J(a,b){E.1i[a]=J(){K 6.V(b,1a)}});E.V(["8e","62"],J(i,c){L b=c.2w();E.1i[b]=J(a){K 6[0]==1e?E.14.2B&&T.1k["5h"+c]||E.14.26&&1e["8d"+c]||T.6I=="6H"&&T.1I["5h"+c]||T.1k["5h"+c]:6[0]==T?1Z.2b(1Z.2b(T.1k["5g"+c],T.1I["5g"+c]),1Z.2b(T.1k["5f"+c],T.1I["5f"+c])):a==10?(6.M?E.1m(6[0],b):W):6.1m(b,a.1n==4d?a:a+"2P")}});L C=E.14.26&&4t(E.14.5n)<8c?"(?:[\\\\w*4s-]|\\\\\\\\.)":"(?:[\\\\w\\8b-\\8a*4s-]|\\\\\\\\.)",6w=1D 4r("^>\\\\s*("+C+"+)"),6v=1D 4r("^("+C+"+)(#)("+C+"+)"),6u=1D 4r("^([#.]?)("+C+"*)");E.1s({5d:{"":"m[2]==\'*\'||19.12(a,m[2])","#":"a.4z(\'2s\')==m[2]",":":{88:"i<m[3]-0",86:"i>m[3]-0",31:"m[3]-0==i",6N:"m[3]-0==i",3j:"i==0",3M:"i==r.M-1",6r:"i%2==0",6p:"i%2","3j-4m":"a.1b.3V(\'*\')[0]==a","3M-4m":"19.31(a.1b.5D,1,\'4v\')==a","84-4m":"!19.31(a.1b.5D,2,\'4v\')",6E:"a.1B",4B:"!a.1B",83:"(a.6A||a.80||19(a).1t()||\'\').1g(m[3])>=0",4b:\'"23"!=a.U&&19.1m(a,"18")!="2D"&&19.1m(a,"4X")!="23"\',23:\'"23"==a.U||19.1m(a,"18")=="2D"||19.1m(a,"4X")=="23"\',7Y:"!a.2W",2W:"a.2W",3o:"a.3o",2p:"a.2p||19.1K(a,\'2p\')",1t:"\'1t\'==a.U",5w:"\'5w\'==a.U",5y:"\'5y\'==a.U",5b:"\'5b\'==a.U",3J:"\'3J\'==a.U",59:"\'59\'==a.U",6n:"\'6n\'==a.U",6m:"\'6m\'==a.U",2G:\'"2G"==a.U||19.12(a,"2G")\',48:"/48|2y|6l|2G/i.17(a.12)",3E:"19.2r(m[3],a).M",7X:"/h\\\\d/i.17(a.12)",7W:"19.3x(19.3I,J(1i){K a==1i.O;}).M"}},6j:[/^(\\[) *@?([\\w-]+) *([!*$^~=]*) *(\'?"?)(.*?)\\4 *\\]/,/^(:)([\\w-]+)\\("?\'?(.*?(\\(.*?\\))?[^(]*?)"?\'?\\)/,1D 4r("^([:.#]*)("+C+"+)")],3d:J(a,c,b){L d,2o=[];2e(a&&a!=d){d=a;L f=E.1F(a,c,b);a=f.t.1p(/^\\s*,\\s*/,"");2o=b?c=f.r:E.34(2o,f.r)}K 2o},2r:J(t,p){7(1v t!="25")K[t];7(p&&p.15!=1&&p.15!=9)K[];p=p||T;L d=[p],2j=[],3M,12;2e(t&&3M!=t){L r=[];3M=t;t=E.3f(t);L o=S;L g=6w;L m=g.39(t);7(m){12=m[1].2F();P(L i=0;d[i];i++)P(L c=d[i].1B;c;c=c.2J)7(c.15==1&&(12=="*"||c.12.2F()==12))r.1h(c);d=r;t=t.1p(g,"");7(t.1g(" ")==0)6z;o=R}N{g=/^([>+~])\\s*(\\w*)/i;7((m=g.39(t))!=W){r=[];L l={};12=m[2].2F();m=m[1];P(L j=0,3g=d.M;j<3g;j++){L n=m=="~"||m=="+"?d[j].2J:d[j].1B;P(;n;n=n.2J)7(n.15==1){L h=E.Q(n);7(m=="~"&&l[h])1T;7(!12||n.12.2F()==12){7(m=="~")l[h]=R;r.1h(n)}7(m=="+")1T}}d=r;t=E.3f(t.1p(g,""));o=R}}7(t&&!o){7(!t.1g(",")){7(p==d[0])d.4k();2j=E.34(2j,d);r=d=[p];t=" "+t.6i(1,t.M)}N{L k=6v;L m=k.39(t);7(m){m=[0,m[2],m[3],m[1]]}N{k=6u;m=k.39(t)}m[2]=m[2].1p(/\\\\/g,"");L f=d[d.M-1];7(m[1]=="#"&&f&&f.5N&&!E.3W(f)){L q=f.5N(m[2]);7((E.14.1d||E.14.2B)&&q&&1v q.2s=="25"&&q.2s!=m[2])q=E(\'[@2s="\'+m[2]+\'"]\',f)[0];d=r=q&&(!m[3]||E.12(q,m[3]))?[q]:[]}N{P(L i=0;d[i];i++){L a=m[1]=="#"&&m[3]?m[3]:m[1]!=""||m[0]==""?"*":m[2];7(a=="*"&&d[i].12.2w()=="4D")a="3v";r=E.34(r,d[i].3V(a))}7(m[1]==".")r=E.58(r,m[2]);7(m[1]=="#"){L e=[];P(L i=0;r[i];i++)7(r[i].4z("2s")==m[2]){e=[r[i]];1T}r=e}d=r}t=t.1p(k,"")}}7(t){L b=E.1F(t,r);d=r=b.r;t=E.3f(b.t)}}7(t)d=[];7(d&&p==d[0])d.4k();2j=E.34(2j,d);K 2j},58:J(r,m,a){m=" "+m+" ";L c=[];P(L i=0;r[i];i++){L b=(" "+r[i].1w+" ").1g(m)>=0;7(!a&&b||a&&!b)c.1h(r[i])}K c},1F:J(t,r,h){L d;2e(t&&t!=d){d=t;L p=E.6j,m;P(L i=0;p[i];i++){m=p[i].39(t);7(m){t=t.7V(m[0].M);m[2]=m[2].1p(/\\\\/g,"");1T}}7(!m)1T;7(m[1]==":"&&m[2]=="4I")r=G.17(m[3])?E.1F(m[3],r,R).r:E(r).4I(m[3]);N 7(m[1]==".")r=E.58(r,m[2],h);N 7(m[1]=="["){L g=[],U=m[3];P(L i=0,3g=r.M;i<3g;i++){L a=r[i],z=a[E.3S[m[2]]||m[2]];7(z==W||/6T|3R|2p/.17(m[2]))z=E.1K(a,m[2])||\'\';7((U==""&&!!z||U=="="&&z==m[5]||U=="!="&&z!=m[5]||U=="^="&&z&&!z.1g(m[5])||U=="$="&&z.6i(z.M-m[5].M)==m[5]||(U=="*="||U=="~=")&&z.1g(m[5])>=0)^h)g.1h(a)}r=g}N 7(m[1]==":"&&m[2]=="31-4m"){L e={},g=[],17=/(-?)(\\d*)n((?:\\+|-)?\\d*)/.39(m[3]=="6r"&&"2n"||m[3]=="6p"&&"2n+1"||!/\\D/.17(m[3])&&"7U+"+m[3]||m[3]),3j=(17[1]+(17[2]||1))-0,d=17[3]-0;P(L i=0,3g=r.M;i<3g;i++){L j=r[i],1b=j.1b,2s=E.Q(1b);7(!e[2s]){L c=1;P(L n=1b.1B;n;n=n.2J)7(n.15==1)n.4p=c++;e[2s]=R}L b=S;7(3j==0){7(j.4p==d)b=R}N 7((j.4p-d)%3j==0&&(j.4p-d)/3j>=0)b=R;7(b^h)g.1h(j)}r=g}N{L f=E.5d[m[1]];7(1v f!="25")f=E.5d[m[1]][m[2]];f=4A("S||J(a,i){K "+f+"}");r=E.3x(r,f,h)}}K{r:r,t:t}},4w:J(b,c){L d=[];L a=b[c];2e(a&&a!=T){7(a.15==1)d.1h(a);a=a[c]}K d},31:J(a,e,c,b){e=e||1;L d=0;P(;a;a=a[c])7(a.15==1&&++d==e)1T;K a},5m:J(n,a){L r=[];P(;n;n=n.2J){7(n.15==1&&(!a||n!=a))r.1h(n)}K r}});E.16={1c:J(f,i,g,e){7(f.15==3||f.15==8)K;7(E.14.1d&&f.54!=10)f=1e;7(!g.2A)g.2A=6.2A++;7(e!=10){L h=g;g=J(){K h.1j(6,1a)};g.Q=e;g.2A=h.2A}L j=E.Q(f,"2N")||E.Q(f,"2N",{}),1x=E.Q(f,"1x")||E.Q(f,"1x",J(){L a;7(1v E=="10"||E.16.52)K a;a=E.16.1x.1j(1a.3G.O,1a);K a});1x.O=f;E.V(i.2d(/\\s+/),J(c,b){L a=b.2d(".");b=a[0];g.U=a[1];L d=j[b];7(!d){d=j[b]={};7(!E.16.2l[b]||E.16.2l[b].4i.1O(f)===S){7(f.3F)f.3F(b,1x,S);N 7(f.6h)f.6h("4h"+b,1x)}}d[g.2A]=g;E.16.2g[b]=R});f=W},2A:1,2g:{},1Y:J(e,h,f){7(e.15==3||e.15==8)K;L i=E.Q(e,"2N"),2f,5E;7(i){7(h==10)P(L g 1r i)6.1Y(e,g);N{7(h.U){f=h.2k;h=h.U}E.V(h.2d(/\\s+/),J(b,a){L c=a.2d(".");a=c[0];7(i[a]){7(f)2T i[a][f.2A];N P(f 1r i[a])7(!c[1]||i[a][f].U==c[1])2T i[a][f];P(2f 1r i[a])1T;7(!2f){7(!E.16.2l[a]||E.16.2l[a].4g.1O(e)===S){7(e.6f)e.6f(a,E.Q(e,"1x"),S);N 7(e.6d)e.6d("4h"+a,E.Q(e,"1x"))}2f=W;2T i[a]}}})}P(2f 1r i)1T;7(!2f){L d=E.Q(e,"1x");7(d)d.O=W;E.3H(e,"2N");E.3H(e,"1x")}}},1U:J(f,b,c,d,g){b=E.2H(b||[]);7(!c){7(6.2g[f])E("*").1c([1e,T]).1U(f,b)}N{7(c.15==3||c.15==8)K 10;L a,2f,1i=E.1q(c[f]||W),16=!b[0]||!b[0].32;7(16)b.4U(6.51({U:f,2K:c}));b[0].U=f;7(E.1q(E.Q(c,"1x")))a=E.Q(c,"1x").1j(c,b);7(!1i&&c["4h"+f]&&c["4h"+f].1j(c,b)===S)a=S;7(16)b.4k();7(g&&E.1q(g)){2f=g.1j(c,a==W?b:b.6Q(a));7(2f!==10)a=2f}7(1i&&d!==S&&a!==S&&!(E.12(c,\'a\')&&f=="50")){6.52=R;1R{c[f]()}1W(e){}}6.52=S}K a},1x:J(c){L a;c=E.16.51(c||1e.16||{});L b=c.U.2d(".");c.U=b[0];L f=E.Q(6,"2N")&&E.Q(6,"2N")[c.U],3B=1N.2m.2V.1O(1a,1);3B.4U(c);P(L j 1r f){L d=f[j];3B[0].2k=d;3B[0].Q=d.Q;7(!b[1]||d.U==b[1]){L e=d.1j(6,3B);7(a!==S)a=e;7(e===S){c.32();c.41()}}}7(E.14.1d)c.2K=c.32=c.41=c.2k=c.Q=W;K a},51:J(c){L a=c;c=E.1s({},a);c.32=J(){7(a.32)a.32();a.7T=S};c.41=J(){7(a.41)a.41();a.7S=R};7(!c.2K)c.2K=c.7R||T;7(c.2K.15==3)c.2K=a.2K.1b;7(!c.4W&&c.4V)c.4W=c.4V==c.2K?c.7Q:c.4V;7(c.6b==W&&c.6a!=W){L b=T.1I,1k=T.1k;c.6b=c.6a+(b&&b.2i||1k&&1k.2i||0)-(b.68||0);c.7O=c.7N+(b&&b.2x||1k&&1k.2x||0)-(b.67||0)}7(!c.3r&&((c.4f||c.4f===0)?c.4f:c.66))c.3r=c.4f||c.66;7(!c.65&&c.64)c.65=c.64;7(!c.3r&&c.2G)c.3r=(c.2G&1?1:(c.2G&2?3:(c.2G&4?2:0)));K c},2l:{21:{4i:J(){5A();K},4g:J(){K}},47:{4i:J(){7(E.14.1d)K S;E(6).2z("4Q",E.16.2l.47.2k);K R},4g:J(){7(E.14.1d)K S;E(6).42("4Q",E.16.2l.47.2k);K R},2k:J(a){7(I(a,6))K R;1a[0].U="47";K E.16.1x.1j(6,1a)}},46:{4i:J(){7(E.14.1d)K S;E(6).2z("4P",E.16.2l.46.2k);K R},4g:J(){7(E.14.1d)K S;E(6).42("4P",E.16.2l.46.2k);K R},2k:J(a){7(I(a,6))K R;1a[0].U="46";K E.16.1x.1j(6,1a)}}}};E.1i.1s({2z:J(c,a,b){K c=="4O"?6.30(c,a,b):6.V(J(){E.16.1c(6,c,b||a,b&&a)})},30:J(d,b,c){K 6.V(J(){E.16.1c(6,d,J(a){E(6).42(a);K(c||b).1j(6,1a)},c&&b)})},42:J(a,b){K 6.V(J(){E.16.1Y(6,a,b)})},1U:J(c,a,b){K 6.V(J(){E.16.1U(c,a,6,R,b)})},63:J(c,a,b){7(6[0])K E.16.1U(c,a,6[0],S,b);K 10},2h:J(){L b=1a;K 6.50(J(a){6.4N=0==6.4N?1:0;a.32();K b[6.4N].1j(6,1a)||S})},7F:J(a,b){K 6.2z(\'47\',a).2z(\'46\',b)},21:J(a){5A();7(E.2Q)a.1O(T,E);N E.3w.1h(J(){K a.1O(6,E)});K 6}});E.1s({2Q:S,3w:[],21:J(){7(!E.2Q){E.2Q=R;7(E.3w){E.V(E.3w,J(){6.1j(T)});E.3w=W}E(T).63("21")}}});L x=S;J 5A(){7(x)K;x=R;7(T.3F&&!E.14.2B)T.3F("61",E.21,S);7(E.14.1d&&1e==3b)(J(){7(E.2Q)K;1R{T.1I.7D("2c")}1W(3e){3z(1a.3G,0);K}E.21()})();7(E.14.2B)T.3F("61",J(){7(E.2Q)K;P(L i=0;i<T.4M.M;i++)7(T.4M[i].2W){3z(1a.3G,0);K}E.21()},S);7(E.14.26){L a;(J(){7(E.2Q)K;7(T.3c!="60"&&T.3c!="1z"){3z(1a.3G,0);K}7(a===10)a=E("Y, 5O[7B=7A]").M;7(T.4M.M!=a){3z(1a.3G,0);K}E.21()})()}E.16.1c(1e,"43",E.21)}E.V(("7z,7y,43,7x,5g,4O,50,7w,"+"7v,7u,7C,4Q,4P,7t,2y,"+"59,7s,7r,7G,3e").2d(","),J(i,b){E.1i[b]=J(a){K a?6.2z(b,a):6.1U(b)}});L I=J(a,c){L b=a.4W;2e(b&&b!=c)1R{b=b.1b}1W(3e){b=c}K b==c};E(1e).2z("4O",J(){E("*").1c(T).42()});E.1i.1s({43:J(g,d,c){7(E.1q(g))K 6.2z("43",g);L e=g.1g(" ");7(e>=0){L i=g.2V(e,g.M);g=g.2V(0,e)}c=c||J(){};L f="4J";7(d)7(E.1q(d)){c=d;d=W}N{d=E.3v(d);f="5Z"}L h=6;E.3Q({1f:g,U:f,1G:"3q",Q:d,1z:J(a,b){7(b=="1X"||b=="5Y")h.3q(i?E("<1u/>").3t(a.4e.1p(/<1o(.|\\s)*?\\/1o>/g,"")).2r(i):a.4e);h.V(c,[a.4e,b,a])}});K 6},7q:J(){K E.3v(6.5X())},5X:J(){K 6.2a(J(){K E.12(6,"3i")?E.2H(6.7p):6}).1F(J(){K 6.37&&!6.2W&&(6.3o||/2y|6l/i.17(6.12)||/1t|23|3J/i.17(6.U))}).2a(J(i,c){L b=E(6).5P();K b==W?W:b.1n==1N?E.2a(b,J(a,i){K{37:c.37,1C:a}}):{37:c.37,1C:b}}).22()}});E.V("5W,5V,5U,69,5T,5S".2d(","),J(i,o){E.1i[o]=J(f){K 6.2z(o,f)}});L B=(1D 3O).3N();E.1s({22:J(d,b,a,c){7(E.1q(b)){a=b;b=W}K E.3Q({U:"4J",1f:d,Q:b,1X:a,1G:c})},7o:J(b,a){K E.22(b,W,a,"1o")},7n:J(c,b,a){K E.22(c,b,a,"2O")},7m:J(d,b,a,c){7(E.1q(b)){a=b;b={}}K E.3Q({U:"5Z",1f:d,Q:b,1X:a,1G:c})},7Z:J(a){E.1s(E.4H,a)},4H:{2g:R,U:"4J",2U:0,5R:"49/x-7j-3i-7i",6x:R,3l:R,Q:W,6t:W,3J:W,4n:{3L:"49/3L, 1t/3L",3q:"1t/3q",1o:"1t/4l, 49/4l",2O:"49/2O, 1t/4l",1t:"1t/7e",4o:"*/*"}},4q:{},3Q:J(s){L f,2Y=/=\\?(&|$)/g,1A,Q;s=E.1s(R,s,E.1s(R,{},E.4H,s));7(s.Q&&s.6x&&1v s.Q!="25")s.Q=E.3v(s.Q);7(s.1G=="4u"){7(s.U.2w()=="22"){7(!s.1f.1E(2Y))s.1f+=(s.1f.1E(/\\?/)?"&":"?")+(s.4u||"7d")+"=?"}N 7(!s.Q||!s.Q.1E(2Y))s.Q=(s.Q?s.Q+"&":"")+(s.4u||"7d")+"=?";s.1G="2O"}7(s.1G=="2O"&&(s.Q&&s.Q.1E(2Y)||s.1f.1E(2Y))){f="4u"+B++;7(s.Q)s.Q=(s.Q+"").1p(2Y,"="+f+"$1");s.1f=s.1f.1p(2Y,"="+f+"$1");s.1G="1o";1e[f]=J(a){Q=a;1X();1z();1e[f]=10;1R{2T 1e[f]}1W(e){}7(h)h.2X(g)}}7(s.1G=="1o"&&s.1Q==W)s.1Q=S;7(s.1Q===S&&s.U.2w()=="22"){L i=(1D 3O()).3N();L j=s.1f.1p(/(\\?|&)4s=.*?(&|$)/,"$a2="+i+"$2");s.1f=j+((j==s.1f)?(s.1f.1E(/\\?/)?"&":"?")+"4s="+i:"")}7(s.Q&&s.U.2w()=="22"){s.1f+=(s.1f.1E(/\\?/)?"&":"?")+s.Q;s.Q=W}7(s.2g&&!E.5M++)E.16.1U("5W");7((!s.1f.1g("9Z")||!s.1f.1g("//"))&&(s.1G=="1o"||s.1G=="2O")&&s.U.2w()=="22"){L h=T.3V("6k")[0];L g=T.2R("1o");g.3R=s.1f;7(s.7c)g.9X=s.7c;7(!f){L l=S;g.9V=g.9U=J(){7(!l&&(!6.3c||6.3c=="60"||6.3c=="1z")){l=R;1X();1z();h.2X(g)}}}h.3k(g);K 10}L m=S;L k=1e.7a?1D 7a("9S.9Q"):1D 79();k.9P(s.U,s.1f,s.3l,s.6t,s.3J);1R{7(s.Q)k.4G("9N-9M",s.5R);7(s.5I)k.4G("9L-5H-9J",E.4q[s.1f]||"9H, 9G 9E 9B 5G:5G:5G 9z");k.4G("X-9x-9u","79");k.4G("9t",s.1G&&s.4n[s.1G]?s.4n[s.1G]+", */*":s.4n.4o)}1W(e){}7(s.75)s.75(k);7(s.2g)E.16.1U("5S",[k,s]);L c=J(a){7(!m&&k&&(k.3c==4||a=="2U")){m=R;7(d){74(d);d=W}1A=a=="2U"&&"2U"||!E.73(k)&&"3e"||s.5I&&E.72(k,s.1f)&&"5Y"||"1X";7(1A=="1X"){1R{Q=E.71(k,s.1G)}1W(e){1A="5C"}}7(1A=="1X"){L b;1R{b=k.5B("70-5H")}1W(e){}7(s.5I&&b)E.4q[s.1f]=b;7(!f)1X()}N E.5t(s,k,1A);1z();7(s.3l)k=W}};7(s.3l){L d=54(c,13);7(s.2U>0)3z(J(){7(k){k.9m();7(!m)c("2U")}},s.2U)}1R{k.9l(s.Q)}1W(e){E.5t(s,k,W,e)}7(!s.3l)c();J 1X(){7(s.1X)s.1X(Q,1A);7(s.2g)E.16.1U("5T",[k,s])}J 1z(){7(s.1z)s.1z(k,1A);7(s.2g)E.16.1U("5U",[k,s]);7(s.2g&&!--E.5M)E.16.1U("5V")}K k},5t:J(s,a,b,e){7(s.3e)s.3e(a,b,e);7(s.2g)E.16.1U("69",[a,s,e])},5M:0,73:J(r){1R{K!r.1A&&9k.9j=="5b:"||(r.1A>=6Y&&r.1A<9h)||r.1A==6X||r.1A==9e||E.14.26&&r.1A==10}1W(e){}K S},72:J(a,c){1R{L b=a.5B("70-5H");K a.1A==6X||b==E.4q[c]||E.14.26&&a.1A==10}1W(e){}K S},71:J(r,b){L c=r.5B("9d-U");L d=b=="3L"||!b&&c&&c.1g("3L")>=0;L a=d?r.9c:r.4e;7(d&&a.1I.28=="5C")6Z"5C";7(b=="1o")E.5l(a);7(b=="2O")a=4A("("+a+")");K a},3v:J(a){L s=[];7(a.1n==1N||a.5j)E.V(a,J(){s.1h(3s(6.37)+"="+3s(6.1C))});N P(L j 1r a)7(a[j]&&a[j].1n==1N)E.V(a[j],J(){s.1h(3s(j)+"="+3s(6))});N s.1h(3s(j)+"="+3s(a[j]));K s.6g("&").1p(/%20/g,"+")}});E.1i.1s({1J:J(c,b){K c?6.27({1P:"1J",29:"1J",1y:"1J"},c,b):6.1F(":23").V(J(){6.Y.18=6.5x||"";7(E.1m(6,"18")=="2D"){L a=E("<"+6.28+" />").6B("1k");6.Y.18=a.1m("18");7(6.Y.18=="2D")6.Y.18="3u";a.1Y()}}).3h()},1H:J(b,a){K b?6.27({1P:"1H",29:"1H",1y:"1H"},b,a):6.1F(":4b").V(J(){6.5x=6.5x||E.1m(6,"18");6.Y.18="2D"}).3h()},6U:E.1i.2h,2h:J(a,b){K E.1q(a)&&E.1q(b)?6.6U(a,b):a?6.27({1P:"2h",29:"2h",1y:"2h"},a,b):6.V(J(){E(6)[E(6).3K(":23")?"1J":"1H"]()})},98:J(b,a){K 6.27({1P:"1J"},b,a)},97:J(b,a){K 6.27({1P:"1H"},b,a)},96:J(b,a){K 6.27({1P:"2h"},b,a)},95:J(b,a){K 6.27({1y:"1J"},b,a)},94:J(b,a){K 6.27({1y:"1H"},b,a)},9f:J(c,a,b){K 6.27({1y:a},c,b)},27:J(l,k,j,h){L i=E.6V(k,j,h);K 6[i.2S===S?"V":"2S"](J(){7(6.15!=1)K S;L g=E.1s({},i);L f=E(6).3K(":23"),4y=6;P(L p 1r l){7(l[p]=="1H"&&f||l[p]=="1J"&&!f)K E.1q(g.1z)&&g.1z.1j(6);7(p=="1P"||p=="29"){g.18=E.1m(6,"18");g.36=6.Y.36}}7(g.36!=W)6.Y.36="23";g.40=E.1s({},l);E.V(l,J(c,a){L e=1D E.2v(4y,g,c);7(/2h|1J|1H/.17(a))e[a=="2h"?f?"1J":"1H":a](l);N{L b=a.3D().1E(/^([+-]=)?([\\d+-.]+)(.*)$/),24=e.2o(R)||0;7(b){L d=2M(b[2]),2C=b[3]||"2P";7(2C!="2P"){4y.Y[c]=(d||1)+2C;24=((d||1)/e.2o(R))*24;4y.Y[c]=24+2C}7(b[1])d=((b[1]=="-="?-1:1)*d)+24;e.3Z(24,d,2C)}N e.3Z(24,a,"")}});K R})},2S:J(a,b){7(E.1q(a)||(a&&a.1n==1N)){b=a;a="2v"}7(!a||(1v a=="25"&&!b))K A(6[0],a);K 6.V(J(){7(b.1n==1N)A(6,a,b);N{A(6,a).1h(b);7(A(6,a).M==1)b.1j(6)}})},8Z:J(b,c){L a=E.3I;7(b)6.2S([]);6.V(J(){P(L i=a.M-1;i>=0;i--)7(a[i].O==6){7(c)a[i](R);a.6R(i,1)}});7(!c)6.5z();K 6}});L A=J(b,c,a){7(!b)K 10;c=c||"2v";L q=E.Q(b,c+"2S");7(!q||a)q=E.Q(b,c+"2S",a?E.2H(a):[]);K q};E.1i.5z=J(a){a=a||"2v";K 6.V(J(){L q=A(6,a);q.4k();7(q.M)q[0].1j(6)})};E.1s({6V:J(b,a,c){L d=b&&b.1n==8Y?b:{1z:c||!c&&a||E.1q(b)&&b,2t:b,3Y:c&&a||a&&a.1n!=8W&&a};d.2t=(d.2t&&d.2t.1n==53?d.2t:{9w:8U,8T:6Y}[d.2t])||8S;d.5o=d.1z;d.1z=J(){7(d.2S!==S)E(6).5z();7(E.1q(d.5o))d.5o.1j(6)};K d},3Y:{6O:J(p,n,b,a){K b+a*p},5F:J(p,n,b,a){K((-1Z.9C(p*1Z.9D)/2)+0.5)*a+b}},3I:[],3T:W,2v:J(b,c,a){6.11=c;6.O=b;6.1l=a;7(!c.3U)c.3U={}}});E.2v.2m={4C:J(){7(6.11.33)6.11.33.1j(6.O,[6.2I,6]);(E.2v.33[6.1l]||E.2v.33.4o)(6);7(6.1l=="1P"||6.1l=="29")6.O.Y.18="3u"},2o:J(a){7(6.O[6.1l]!=W&&6.O.Y[6.1l]==W)K 6.O[6.1l];L r=2M(E.1m(6.O,6.1l,a));K r&&r>-8N?r:2M(E.2q(6.O,6.1l))||0},3Z:J(c,b,d){6.5s=(1D 3O()).3N();6.24=c;6.3h=b;6.2C=d||6.2C||"2P";6.2I=6.24;6.4E=6.4F=0;6.4C();L e=6;J t(a){K e.33(a)}t.O=6.O;E.3I.1h(t);7(E.3T==W){E.3T=54(J(){L a=E.3I;P(L i=0;i<a.M;i++)7(!a[i]())a.6R(i--,1);7(!a.M){74(E.3T);E.3T=W}},13)}},1J:J(){6.11.3U[6.1l]=E.1K(6.O.Y,6.1l);6.11.1J=R;6.3Z(0,6.2o());7(6.1l=="29"||6.1l=="1P")6.O.Y[6.1l]="8L";E(6.O).1J()},1H:J(){6.11.3U[6.1l]=E.1K(6.O.Y,6.1l);6.11.1H=R;6.3Z(6.2o(),0)},33:J(a){L t=(1D 3O()).3N();7(a||t>6.11.2t+6.5s){6.2I=6.3h;6.4E=6.4F=1;6.4C();6.11.40[6.1l]=R;L b=R;P(L i 1r 6.11.40)7(6.11.40[i]!==R)b=S;7(b){7(6.11.18!=W){6.O.Y.36=6.11.36;6.O.Y.18=6.11.18;7(E.1m(6.O,"18")=="2D")6.O.Y.18="3u"}7(6.11.1H)6.O.Y.18="2D";7(6.11.1H||6.11.1J)P(L p 1r 6.11.40)E.1K(6.O.Y,p,6.11.3U[p])}7(b&&E.1q(6.11.1z))6.11.1z.1j(6.O);K S}N{L n=t-6.5s;6.4F=n/6.11.2t;6.4E=E.3Y[6.11.3Y||(E.3Y.5F?"5F":"6O")](6.4F,n,0,1,6.11.2t);6.2I=6.24+((6.3h-6.24)*6.4E);6.4C()}K R}};E.2v.33={2i:J(a){a.O.2i=a.2I},2x:J(a){a.O.2x=a.2I},1y:J(a){E.1K(a.O.Y,"1y",a.2I)},4o:J(a){a.O.Y[a.1l]=a.2I+a.2C}};E.1i.5f=J(){L b=0,3b=0,O=6[0],5q;7(O)8K(E.14){L d=O.1b,45=O,1M=O.1M,1L=O.2u,5p=26&&4t(5n)<8H,2Z=E.1m(O,"3C")=="2Z";7(O.7b){L c=O.7b();1c(c.2c+1Z.2b(1L.1I.2i,1L.1k.2i),c.3b+1Z.2b(1L.1I.2x,1L.1k.2x));1c(-1L.1I.68,-1L.1I.67)}N{1c(O.5k,O.5K);2e(1M){1c(1M.5k,1M.5K);7(3X&&!/^t(8F|d|h)$/i.17(1M.28)||26&&!5p)3a(1M);7(!2Z&&E.1m(1M,"3C")=="2Z")2Z=R;45=/^1k$/i.17(1M.28)?45:1M;1M=1M.1M}2e(d&&d.28&&!/^1k|3q$/i.17(d.28)){7(!/^a0|1V.*$/i.17(E.1m(d,"18")))1c(-d.2i,-d.2x);7(3X&&E.1m(d,"36")!="4b")3a(d);d=d.1b}7((5p&&(2Z||E.1m(45,"3C")=="4Z"))||(3X&&E.1m(45,"3C")!="4Z"))1c(-1L.1k.5k,-1L.1k.5K);7(2Z)1c(1Z.2b(1L.1I.2i,1L.1k.2i),1Z.2b(1L.1I.2x,1L.1k.2x))}5q={3b:3b,2c:b}}J 3a(a){1c(E.2q(a,"a1",R),E.2q(a,"8D",R))}J 1c(l,t){b+=4t(l)||0;3b+=4t(t)||0}K 5q}})();',62,624,'||||||this|if||||||||||||||||||||||||||||||||||||||function|return|var|length|else|elem|for|data|true|false|document|type|each|null||style||undefined|options|nodeName||browser|nodeType|event|test|display|jQuery|arguments|parentNode|add|msie|window|url|indexOf|push|fn|apply|body|prop|css|constructor|script|replace|isFunction|in|extend|text|div|typeof|className|handle|opacity|complete|status|firstChild|value|new|match|filter|dataType|hide|documentElement|show|attr|doc|offsetParent|Array|call|height|cache|try|tbody|break|trigger|table|catch|success|remove|Math||ready|get|hidden|start|string|safari|animate|tagName|width|map|max|left|split|while|ret|global|toggle|scrollLeft|done|handler|special|prototype||cur|selected|curCSS|find|id|duration|ownerDocument|fx|toLowerCase|scrollTop|select|bind|guid|opera|unit|none|pushStack|toUpperCase|button|makeArray|now|nextSibling|target|stack|parseFloat|events|json|px|isReady|createElement|queue|delete|timeout|slice|disabled|removeChild|jsre|fixed|one|nth|preventDefault|step|merge|inArray|overflow|name|innerHTML|exec|border|top|readyState|multiFilter|error|trim|rl|end|form|first|appendChild|async|elems|insertBefore|checked|childNodes|html|which|encodeURIComponent|append|block|param|readyList|grep|color|setTimeout|runtimeStyle|args|position|toString|has|addEventListener|callee|removeData|timers|password|is|xml|last|getTime|Date|domManip|ajax|src|props|timerId|orig|getElementsByTagName|isXMLDoc|mozilla|easing|custom|curAnim|stopPropagation|unbind|load|selectedIndex|offsetChild|mouseleave|mouseenter|input|application|defaultView|visible|float|String|responseText|charCode|teardown|on|setup|currentStyle|shift|javascript|child|accepts|_default|nodeIndex|lastModified|RegExp|_|parseInt|jsonp|previousSibling|dir|tr|self|getAttribute|eval|empty|update|object|pos|state|setRequestHeader|ajaxSettings|not|GET|getPropertyValue|getComputedStyle|styleSheets|lastToggle|unload|mouseout|mouseover|andSelf|getWH|container2|unshift|fromElement|relatedTarget|visibility|init|absolute|click|fix|triggered|Number|setInterval|removeAttribute|prevObject|unique|classFilter|submit|after|file|clean|expr|windowData|offset|scroll|client|deep|jquery|offsetLeft|globalEval|sibling|version|old|safari2|results|wrapAll|startTime|handleError|container|createTextNode|radio|oldblock|checkbox|dequeue|bindReady|getResponseHeader|parsererror|lastChild|index|swing|00|Modified|ifModified|clone|offsetTop|values|active|getElementById|link|val|col|contentType|ajaxSend|ajaxSuccess|ajaxComplete|ajaxStop|ajaxStart|serializeArray|notmodified|POST|loaded|DOMContentLoaded|Width|triggerHandler|ctrlKey|metaKey|keyCode|clientTop|clientLeft|ajaxError|clientX|pageX|cloneNode|detachEvent|swap|removeEventListener|join|attachEvent|substr|parse|head|textarea|reset|image|before|odd|zoom|even|prepend|username|quickClass|quickID|quickChild|processData|uuid|continue|textContent|appendTo|contents|evalScript|parent|defaultValue|setArray|CSS1Compat|compatMode|cssFloat|styleFloat|webkit|nodeValue|eq|linear|replaceWith|concat|splice|100|href|_toggle|speed|alpha|304|200|throw|Last|httpData|httpNotModified|httpSuccess|clearInterval|beforeSend|colgroup|fieldset|multiple|XMLHttpRequest|ActiveXObject|getBoundingClientRect|scriptCharset|callback|plain|img|hasClass|br|urlencoded|www|abbr|pixelLeft|post|getJSON|getScript|elements|serialize|keypress|keydown|change|mouseup|mousedown|dblclick|resize|focus|blur|stylesheet|rel|mousemove|doScroll|round|hover|keyup|padding|offsetHeight|offsetWidth|Bottom|Top|Right|clientY|pageY|Left|toElement|srcElement|cancelBubble|returnValue|0n|substring|animated|header|enabled|ajaxSetup|innerText|noConflict|size|contains|only|line|gt|weight|lt|font|uFFFF|u0128|417|inner|Height|Boolean|toggleClass|removeClass|addClass|removeAttr|replaceAll|insertAfter|wrap|prependTo|contentWindow|contentDocument|iframe|children|siblings|wrapInner|prevAll|nextAll|prev|next|parents|maxLength|maxlength|readOnly|readonly|borderTopWidth|class|able|htmlFor|522|reverse|boxModel|with|1px|compatible|10000|ie|ra|it|rv|400|fast|600|userAgent|Function|navigator|Object|stop|option|array|ig|NaN|fadeOut|fadeIn|slideToggle|slideUp|slideDown|setAttribute|changed|be|responseXML|content|1223|fadeTo|can|300|property|protocol|location|send|abort|getAttributeNode|specified|method|action|cssText|attributes|Accept|With|th|slow|Requested|td|GMT|cap|1970|cos|PI|Jan|colg|01|Thu|tfoot|Since|thead|If|Type|Content|leg|open|XMLHTTP|opt|Microsoft|embed|onreadystatechange|onload|area|charset|hr|http|inline|borderLeftWidth|1_|meta'.split('|'),0,{}));
\ No newline at end of file
Added: branches/dev_lenkne/http/extensions/jquery.validate.js
--- branches/dev_lenkne/http/extensions/jquery.validate.js	                        (rev 0)
+++ branches/dev_lenkne/http/extensions/jquery.validate.js	2008-08-15 22:20:09 UTC (rev 2837)
@@ -0,0 +1,1103 @@
+ * jQuery validation plug-in 1.4
+ * http://bassistance.de/jquery-plugins/jquery-plugin-validation/
+ * http://docs.jquery.com/Plugins/Validation
+ * Copyright (c) 2006 - 2008 Jörn Zaefferer
+ * $Id: jquery.validate.js 5788 2008-07-13 15:04:50Z joern.zaefferer $
+ * Dual licensed under the MIT and GPL licenses:
+ *   http://www.opensource.org/licenses/mit-license.php
+(function($) {
+$.extend($.fn, {
+	// http://docs.jquery.com/Plugins/Validation/validate
+	validate: function( options ) {
+		// if nothing is selected, return nothing; can't chain anyway
+		if (!this.length) {
+			options && options.debug && window.console && console.warn( "nothing selected, can't validate, returning nothing" );
+			return;
+		// check if a validator for this form was already created
+		var validator = $.data(this[0], 'validator');
+		if ( validator ) {
+			return validator;
+		validator = new $.validator( options, this[0] );
+		$.data(this[0], 'validator', validator);
+		if ( validator.settings.onsubmit ) {
+			// allow suppresing validation by adding a cancel class to the submit button
+			this.find("input, button").filter(".cancel").click(function() {
+				validator.cancelSubmit = true;
+			// validate the form on submit
+			this.submit( function( event ) {
+				if ( validator.settings.debug )
+					// prevent form submit to be able to see console output
+					event.preventDefault();
+				function handle() {
+					if ( validator.settings.submitHandler ) {
+						validator.settings.submitHandler.call( validator, validator.currentForm );
+						return false;
+					return true;
+				// prevent submit for invalid forms or custom submit handlers
+				if ( validator.cancelSubmit ) {
+					validator.cancelSubmit = false;
+					return handle();
+				if ( validator.form() ) {
+					if ( validator.pendingRequest ) {
+						validator.formSubmitted = true;
+						return false;
+					return handle();
+				} else {
+					validator.focusInvalid();
+					return false;
+		return validator;
+	valid: function() {
+        if ( $(this[0]).is('form')) {
+            return this.validate().form();
+        } else {
+            var valid = false;
+            var validator = $(this[0].form).validate();
+            this.each(function() {
+				valid |= validator.element(this);
+            return valid;
+	// attributes: space seperated list of attributes to retrieve and remove
+	removeAttrs: function(attributes) {
+		var result = {},
+			$element = this;
+		$.each(attributes.split(/\s/), function() {
+			result[this] = $element.attr(this);
+			$element.removeAttr(this);
+		return result;
+	// http://docs.jquery.com/Plugins/Validation/rules
+	rules: function(command, argument) {
+		var element = this[0];
+		if (command) {
+			var staticRules = $.data(element.form, 'validator').settings.rules;
+			var existingRules = $.validator.staticRules(element);
+			switch(command) {
+			case "add":
+				$.extend(existingRules, $.validator.normalizeRule(argument));
+				staticRules[element.name] = existingRules;
+				break;
+			case "remove":
+				if (!argument) {
+					delete staticRules[element.name];
+					return existingRules;
+				var filtered = {};
+				$.each(argument.split(/\s/), function(index, method) {
+					filtered[method] = existingRules[method];
+					delete existingRules[method];
+				return filtered;
+		var data = $.validator.normalizeRules(
+		$.extend(
+			$.validator.metadataRules(element),
+			$.validator.classRules(element),
+			$.validator.attributeRules(element),
+			$.validator.staticRules(element)
+		), element);
+		// make sure required is at front
+		if (data.required) {
+			var param = data.required;
+			delete data.required;
+			data = $.extend({required: param}, data);
+		return data;
+	// destructive add
+	push: function( t ) {
+		return this.setArray( this.add(t).get() );
+// Custom selectors
+$.extend($.expr[":"], {
+	// http://docs.jquery.com/Plugins/Validation/blank
+	blank: function(a) {return !$.trim(a.value);},
+	// http://docs.jquery.com/Plugins/Validation/filled
+	filled: function(a) {return !!$.trim(a.value);},
+	// http://docs.jquery.com/Plugins/Validation/unchecked
+	unchecked: function(a) {return !a.checked;}
+$.format = function(source, params) {
+	if ( arguments.length == 1 )
+		return function() {
+			var args = $.makeArray(arguments);
+			args.unshift(source);
+			return $.format.apply( this, args );
+	if ( arguments.length > 2 && params.constructor != Array  ) {
+		params = $.makeArray(arguments).slice(1);
+	if ( params.constructor != Array ) {
+		params = [ params ];
+	$.each(params, function(i, n) {
+		source = source.replace(new RegExp("\\{" + i + "\\}", "g"), n);
+	return source;
+// constructor for validator
+$.validator = function( options, form ) {
+	this.settings = $.extend( {}, $.validator.defaults, options );
+	this.currentForm = form;
+	this.init();
+$.extend($.validator, {
+	defaults: {
+		messages: {},
+		groups: {},
+		rules: {},
+		errorClass: "error",
+		errorElement: "label",
+		focusInvalid: true,
+		errorContainer: $( [] ),
+		errorLabelContainer: $( [] ),
+		onsubmit: true,
+		ignore: [],
+		onfocusin: function(element) {
+			this.lastActive = element;
+			// hide error label and remove error class on focus if enabled
+			if ( this.settings.focusCleanup && !this.blockFocusCleanup ) {
+				this.settings.unhighlight && this.settings.unhighlight.call( this, element, this.settings.errorClass );
+				this.errorsFor(element).hide();
+		onfocusout: function(element) {
+			if ( !this.checkable(element) && (element.name in this.submitted || !this.optional(element)) ) {
+				this.element(element);
+		onkeyup: function(element) {
+			if ( element.name in this.submitted || element == this.lastElement ) {
+		onclick: function(element) {
+			if ( element.name in this.submitted )
+		highlight: function( element, errorClass ) {
+			$( element ).addClass( errorClass );
+		unhighlight: function( element, errorClass ) {
+			$( element ).removeClass( errorClass );
+	// http://docs.jquery.com/Plugins/Validation/Validator/setDefaults
+	setDefaults: function(settings) {
+		$.extend( $.validator.defaults, settings );
+	messages: {
+		required: "This field is required.",
+		remote: "Please fix this field.",
+		email: "Please enter a valid email address.",
+		url: "Please enter a valid URL.",
+		date: "Please enter a valid date.",
+		dateISO: "Please enter a valid date (ISO).",
+		dateDE: "Bitte geben Sie ein gültiges Datum ein.",
+		number: "Please enter a valid number.",
+		numberDE: "Bitte geben Sie eine Nummer ein.",
+		digits: "Please enter only digits",
+		creditcard: "Please enter a valid credit card.",
+		equalTo: "Please enter the same value again.",
+		accept: "Please enter a value with a valid extension.",
+		maxlength: $.format("Please enter no more than {0} characters."),
+		minlength: $.format("Please enter at least {0} characters."),
+		rangelength: $.format("Please enter a value between {0} and {1} characters long."),
+		range: $.format("Please enter a value between {0} and {1}."),
+		max: $.format("Please enter a value less than or equal to {0}."),
+		min: $.format("Please enter a value greater than or equal to {0}.")
+	autoCreateRanges: false,
+	prototype: {
+		init: function() {
+			this.labelContainer = $(this.settings.errorLabelContainer);
+			this.errorContext = this.labelContainer.length && this.labelContainer || $(this.currentForm);
+			this.containers = $(this.settings.errorContainer).add( this.settings.errorLabelContainer );
+			this.submitted = {};
+			this.valueCache = {};
+			this.pendingRequest = 0;
+			this.pending = {};
+			this.invalid = {};
+			this.reset();
+			var groups = (this.groups = {});
+			$.each(this.settings.groups, function(key, value) {
+				$.each(value.split(/\s/), function(index, name) {
+					groups[name] = key;
+			var rules = this.settings.rules;
+			$.each(rules, function(key, value) {
+				rules[key] = $.validator.normalizeRule(value);
+			function delegate(event) {
+				var validator = $.data(this[0].form, "validator");
+				validator.settings["on" + event.type] && validator.settings["on" + event.type].call(validator, this[0] );
+			$(this.currentForm)
+				.delegate("focusin focusout keyup", ":text, :password, :file, select, textarea", delegate)
+				.delegate("click", ":radio, :checkbox", delegate);
+		// http://docs.jquery.com/Plugins/Validation/Validator/form
+		form: function() {
+			this.checkForm();
+			$.extend(this.submitted, this.errorMap);
+			this.invalid = $.extend({}, this.errorMap);
+			if (!this.valid())
+				$(this.currentForm).triggerHandler("invalid-form.validate", [this]);
+			this.showErrors();
+			return this.valid();
+		checkForm: function() {
+			this.prepareForm();
+			for ( var i = 0, elements = (this.currentElements = this.elements()); elements[i]; i++ ) {
+				this.check( elements[i] );
+		// http://docs.jquery.com/Plugins/Validation/Validator/element
+		element: function( element ) {
+			element = this.clean( element );
+			this.lastElement = element;
+			this.prepareElement( element );
+			this.currentElements = $(element);
+			var result = this.check( element );
+			if ( result ) {
+				delete this.invalid[element.name];
+			} else {
+				this.invalid[element.name] = true;
+			if ( !this.numberOfInvalids() ) {
+				// Hide error containers on last error
+				this.toHide.push( this.containers );
+			return result;
+		// http://docs.jquery.com/Plugins/Validation/Validator/showErrors
+		showErrors: function(errors) {
+			if(errors) {
+				// add items to error list and map
+				$.extend( this.errorMap, errors );
+				this.errorList = [];
+				for ( var name in errors ) {
+					this.errorList.push({
+						message: errors[name],
+						element: this.findByName(name)[0]
+				// remove items from success list
+				this.successList = $.grep( this.successList, function(element) {
+					return !(element.name in errors);
+			this.settings.showErrors
+				? this.settings.showErrors.call( this, this.errorMap, this.errorList )
+				: this.defaultShowErrors();
+		// http://docs.jquery.com/Plugins/Validation/Validator/resetForm
+		resetForm: function() {
+			if ( $.fn.resetForm )
+				$( this.currentForm ).resetForm();
+			this.hideErrors();
+			this.elements().removeClass( this.settings.errorClass );
+		numberOfInvalids: function() {
+			return this.objectLength(this.invalid);
+		objectLength: function( obj ) {
+			var count = 0;
+			for ( var i in obj )
+				count++;
+			return count;
+		hideErrors: function() {
+			this.addWrapper( this.toHide ).hide();
+			return this.size() == 0;
+		size: function() {
+			return this.errorList.length;
+		focusInvalid: function() {
+			if( this.settings.focusInvalid ) {
+				try {
+					$(this.findLastActive() || this.errorList.length && this.errorList[0].element || []).filter(":visible").focus();
+				} catch(e) { /* ignore IE throwing errors when focusing hidden elements */ }
+		findLastActive: function() {
+			var lastActive = this.lastActive;
+			return lastActive && $.grep(this.errorList, function(n) {
+				return n.element.name == lastActive.name;
+			}).length == 1 && lastActive;
+		elements: function() {
+			var validator = this,
+				rulesCache = {};
+			// select all valid inputs inside the form (no submit or reset buttons)
+			// workaround $Query([]).add until http://dev.jquery.com/ticket/2114 is solved
+			return $([]).add(this.currentForm.elements)
+			.filter(":input")
+			.not(":submit, :reset, :image, [disabled]")
+			.not( this.settings.ignore )
+			.filter(function() {
+				!this.name && validator.settings.debug && window.console && console.error( "%o has no name assigned", this);
+				// select only the first element for each name, and only those with rules specified
+				if ( this.name in rulesCache || !validator.objectLength($(this).rules()) )
+					return false;
+				rulesCache[this.name] = true;
+				return true;
+		clean: function( selector ) {
+			return $( selector )[0];
+		errors: function() {
+			return $( this.settings.errorElement + "." + this.settings.errorClass, this.errorContext );
+		reset: function() {
+			this.successList = [];
+			this.errorMap = {};
+			this.toShow = $([]);
+			this.toHide = $([]);
+			this.formSubmitted = false;
+			this.currentElements = $([]);
+		prepareForm: function() {
+			this.reset();
+			this.toHide = this.errors().push( this.containers );
+		prepareElement: function( element ) {
+			this.reset();
+			this.toHide = this.errorsFor(element);
+		check: function( element ) {
+			// if radio/checkbox, validate first element in group instead
+			if (this.checkable(element)) {
+				element = this.findByName( element.name )[0];
+			var rules = $(element).rules();
+			var dependencyMismatch = false;
+			for( method in rules ) {
+				var rule = { method: method, parameters: rules[method] };
+				try {
+					var result = $.validator.methods[method].call( this, $.trim(element.value), element, rule.parameters );
+					// if a method indicates that the field is optional and therefore valid,
+					// don't mark it as valid when there are no other rules
+					if ( result == "dependency-mismatch" ) {
+						dependencyMismatch = true;
+						continue;
+					dependencyMismatch = false;
+					if ( result == "pending" ) {
+						this.toHide = this.toHide.not( this.errorsFor(element) );
+						return;
+					if( !result ) {
+						this.formatAndAdd( element, rule );
+						return false;
+				} catch(e) {
+					this.settings.debug && window.console && console.log("exception occured when checking element " + element.id
+						 + ", check the '" + rule.method + "' method");
+					throw e;
+			if (dependencyMismatch)
+				return;
+			if ( this.objectLength(rules) )
+				this.successList.push(element);
+			return true;
+		// return the custom message for the given element and validation method
+		// specified in the element's "messages" metadata
+		customMetaMessage: function(element, method) {
+			if (!$.metadata)
+				return;
+			var meta = this.settings.meta
+				? $(element).metadata()[this.settings.meta]
+				: $(element).metadata();
+			return meta.messages && meta.messages[method];
+		// return the custom message for the given element name and validation method
+		customMessage: function( name, method ) {
+			var m = this.settings.messages[name];
+			return m && (m.constructor == String
+				? m
+				: m[method]);
+		// return the first defined argument, allowing empty strings
+		findDefined: function() {
+			for(var i = 0; i < arguments.length; i++) {
+				if (arguments[i] !== undefined)
+					return arguments[i];
+			return undefined;
+		defaultMessage: function( element, method) {
+			return this.findDefined(
+				this.customMessage( element.name, method ),
+				this.customMetaMessage( element, method ),
+				// title is never undefined, so handle empty string as undefined
+				element.title || undefined,
+				$.validator.messages[method],
+				"<strong>Warning: No message defined for " + element.name + "</strong>"
+		formatAndAdd: function( element, rule ) {
+			var message = this.defaultMessage( element, rule.method );
+			if ( typeof message == "function" )
+				message = message.call(this, rule.parameters, element);
+				message: message,
+				element: element
+			this.errorMap[element.name] = message;
+			this.submitted[element.name] = message;
+		addWrapper: function(toToggle) {
+			if ( this.settings.wrapper )
+				toToggle.push( toToggle.parents( this.settings.wrapper ) );
+			return toToggle;
+		defaultShowErrors: function() {
+			for ( var i = 0; this.errorList[i]; i++ ) {
+				var error = this.errorList[i];
+				this.settings.highlight && this.settings.highlight.call( this, error.element, this.settings.errorClass );
+				this.showLabel( error.element, error.message );
+			if( this.errorList.length ) {
+				this.toShow.push( this.containers );
+			if (this.settings.success) {
+				for ( var i = 0; this.successList[i]; i++ ) {
+					this.showLabel( this.successList[i] );
+			if (this.settings.unhighlight) {
+				for ( var i = 0, elements = this.validElements(); elements[i]; i++ ) {
+					this.settings.unhighlight.call( this, elements[i], this.settings.errorClass );
+			this.toHide = this.toHide.not( this.toShow );
+			this.addWrapper( this.toShow ).show();
+		validElements: function() {
+			return this.currentElements.not(this.invalidElements());
+		invalidElements: function() {
+			return $(this.errorList).map(function() {
+				return this.element;
+		showLabel: function(element, message) {
+			var label = this.errorsFor( element );
+			if ( label.length ) {
+				// refresh error/success class
+				label.removeClass().addClass( this.settings.errorClass );
+				// check if we have a generated label, replace the message then
+				label.attr("generated") && label.html(message);
+			} else {
+				// create label
+				label = $("<" + this.settings.errorElement + "/>")
+					.attr({"for":  this.idOrName(element), generated: true})
+					.addClass(this.settings.errorClass)
+					.html(message || "");
+				if ( this.settings.wrapper ) {
+					// make sure the element is visible, even in IE
+					// actually showing the wrapped element is handled elsewhere
+					label = label.hide().show().wrap("<" + this.settings.wrapper + ">").parent();
+				if ( !this.labelContainer.append(label).length )
+					this.settings.errorPlacement
+						? this.settings.errorPlacement(label, $(element) )
+						: label.insertAfter(element);
+			if ( !message && this.settings.success ) {
+				label.text("");
+				typeof this.settings.success == "string"
+					? label.addClass( this.settings.success )
+					: this.settings.success( label );
+			this.toShow.push(label);
+		errorsFor: function(element) {
+			return this.errors().filter("[@for='" + this.idOrName(element) + "']");
+		idOrName: function(element) {
+			return this.groups[element.name] || (this.checkable(element) ? element.name : element.id || element.name);
+		checkable: function( element ) {
+			return /radio|checkbox/i.test(element.type);
+		findByName: function( name ) {
+			// select by name and filter by form for performance over form.find("[name=...]")
+			var form = this.currentForm;
+			return $(document.getElementsByName(name)).map(function(index, element) {
+				return element.form == form && element.name == name && element  || null;
+		getLength: function(value, element) {
+			switch( element.nodeName.toLowerCase() ) {
+			case 'select':
+				return $("option:selected", element).length;
+			case 'input':
+				if( this.checkable( element) )
+					return this.findByName(element.name).filter(':checked').length;
+			return value.length;
+		depend: function(param, element) {
+			return this.dependTypes[typeof param]
+				? this.dependTypes[typeof param](param, element)
+				: true;
+		dependTypes: {
+			"boolean": function(param, element) {
+				return param;
+			"string": function(param, element) {
+				return !!$(param, element.form).length;
+			"function": function(param, element) {
+				return param(element);
+		optional: function(element) {
+			return !$.validator.methods.required.call(this, $.trim(element.value), element) && "dependency-mismatch";
+		startRequest: function(element) {
+			if (!this.pending[element.name]) {
+				this.pendingRequest++;
+				this.pending[element.name] = true;
+		stopRequest: function(element, valid) {
+			this.pendingRequest--;
+			// sometimes synchronization fails, make pendingRequest is never < 0
+			if (this.pendingRequest < 0)
+			delete this.pending[element.name];
+			if ( valid && this.pendingRequest == 0 && this.formSubmitted && this.form() ) {
+				$(this.currentForm).submit();
+		previousValue: function(element) {
+			return $.data(element, "previousValue") || $.data(element, "previousValue", previous = {
+				old: null,
+				valid: true,
+				message: this.defaultMessage( element, "remote" )
+	classRuleSettings: {
+		required: {required: true},
+		email: {email: true},
+		url: {url: true},
+		date: {date: true},
+		dateISO: {dateISO: true},
+		dateDE: {dateDE: true},
+		number: {number: true},
+		numberDE: {numberDE: true},
+		digits: {digits: true},
+		creditcard: {creditcard: true}
+	addClassRules: function(className, rules) {
+		className.constructor == String ?
+			this.classRuleSettings[className] = rules :
+			$.extend(this.classRuleSettings, className);
+	classRules: function(element) {
+		var rules = {};
+		var classes = $(element).attr('class');
+		classes && $.each(classes.split(' '), function() {
+			if (this in $.validator.classRuleSettings) {
+				$.extend(rules, $.validator.classRuleSettings[this]);
+		return rules;
+	attributeRules: function(element) {
+		var rules = {};
+		var $element = $(element);
+		for (method in $.validator.methods) {
+			var value = $element.attr(method);
+			if (value) {
+				rules[method] = value;
+		// maxlength may be returned as -1, 2147483647 (IE) and 524288 (safari) for text inputs
+		if (rules.maxlength && /-1|2147483647|524288/.test(rules.maxlength)) {
+			delete rules.maxlength;
+		return rules;
+	metadataRules: function(element) {
+		if (!$.metadata) return {};
+		var meta = $.data(element.form, 'validator').settings.meta;
+		return meta ?
+			$(element).metadata()[meta] :
+			$(element).metadata();
+	staticRules: function(element) {
+		var rules = {};
+		var validator = $.data(element.form, 'validator');
+		if (validator.settings.rules) {
+			rules = $.validator.normalizeRule(validator.settings.rules[element.name]) || {};
+		return rules;
+	normalizeRules: function(rules, element) {
+		// handle dependency check
+		$.each(rules, function(prop, val) {
+			// ignore rule when param is explicitly false, eg. required:false
+			if (val === false) {
+				delete rules[prop];
+				return;
+			if (val.param || val.depends) {
+				var keepRule = true;
+				switch (typeof val.depends) {
+					case "string":
+						keepRule = !!$(val.depends, element.form).length;
+						break;
+					case "function":
+						keepRule = val.depends.call(element, element);
+						break;
+				if (keepRule) {
+					rules[prop] = val.param !== undefined ? val.param : true;
+				} else {
+		// evaluate parameters
+		$.each(rules, function(rule, parameter) {
+			rules[rule] = $.isFunction(parameter) ? parameter(element) : parameter;
+		// clean number parameters
+		$.each(['minlength', 'maxlength', 'min', 'max'], function() {
+			if (rules[this]) {
+				rules[this] = Number(rules[this]);
+		$.each(['rangelength', 'range'], function() {
+				rules[this] = [Number(rules[this][0]), Number(rules[this][1])];
+		if ($.validator.autoCreateRanges) {
+			// auto-create ranges
+			if (rules.min && rules.max) {
+				rules.range = [rules.min, rules.max];
+				delete rules.min;
+				delete rules.max;
+			if (rules.minlength && rules.maxlength) {
+				rules.rangelength = [rules.minlength, rules.maxlength];
+				delete rules.minlength;
+		// To support custom messages in metadata ignore rule methods titled "messages"
+		if (rules.messages) {
+			delete rules.messages
+		return rules;
+	// Converts a simple string to a {string: true} rule, e.g., "required" to {required:true}
+	normalizeRule: function(data) {
+		if( typeof data == "string" ) {
+			var transformed = {};
+			$.each(data.split(/\s/), function() {
+				transformed[this] = true;
+			data = transformed;
+		return data;
+	// http://docs.jquery.com/Plugins/Validation/Validator/addMethod
+	addMethod: function(name, method, message) {
+		$.validator.methods[name] = method;
+		$.validator.messages[name] = message;
+		if (method.length < 3) {
+			$.validator.addClassRules(name, $.validator.normalizeRule(name));
+	methods: {
+		// http://docs.jquery.com/Plugins/Validation/Methods/required
+		required: function(value, element, param) {
+			// check if dependency is met
+			if ( !this.depend(param, element) )
+				return "dependency-mismatch";
+			case 'select':
+				var options = $("option:selected", element);
+				return options.length > 0 && ( element.type == "select-multiple" || ($.browser.msie && !(options[0].attributes['value'].specified) ? options[0].text : options[0].value).length > 0);
+			case 'input':
+				if ( this.checkable(element) )
+					return this.getLength(value, element) > 0;
+			default:
+				return value.length > 0;
+		// http://docs.jquery.com/Plugins/Validation/Methods/remote
+		remote: function(value, element, param) {
+			if ( this.optional(element) )
+			var previous = this.previousValue(element);
+			if (!this.settings.messages[element.name] )
+				this.settings.messages[element.name] = {};
+			this.settings.messages[element.name].remote = typeof previous.message == "function" ? previous.message(value) : previous.message;
+			if ( previous.old !== value ) {
+				previous.old = value;
+				var validator = this;
+				this.startRequest(element);
+				var data = {};
+				data[element.name] = value;
+				$.ajax({
+					url: param,
+					mode: "abort",
+					port: "validate" + element.name,
+					dataType: "json",
+					data: data,
+					success: function(response) {
+						if ( !response ) {
+							var errors = {};
+							errors[element.name] =  response || validator.defaultMessage( element, "remote" );
+							validator.showErrors(errors);
+						} else {
+							var submitted = validator.formSubmitted;
+							validator.prepareElement(element);
+							validator.formSubmitted = submitted;
+							validator.successList.push(element);
+							validator.showErrors();
+						previous.valid = response;
+						validator.stopRequest(element, response);
+				return "pending";
+			} else if( this.pending[element.name] ) {
+				return "pending";
+			return previous.valid;
+		// http://docs.jquery.com/Plugins/Validation/Methods/minlength
+		minlength: function(value, element, param) {
+			return this.optional(element) || this.getLength(value, element) >= param;
+		// http://docs.jquery.com/Plugins/Validation/Methods/maxlength
+		maxlength: function(value, element, param) {
+			return this.optional(element) || this.getLength(value, element) <= param;
+		// http://docs.jquery.com/Plugins/Validation/Methods/rangelength
+		rangelength: function(value, element, param) {
+			var length = this.getLength(value, element);
+			return this.optional(element) || ( length >= param[0] && length <= param[1] );
+		min: function( value, element, param ) {
+			return this.optional(element) || value >= param;
+		max: function( value, element, param ) {
+			return this.optional(element) || value <= param;
+		range: function( value, element, param ) {
+			return this.optional(element) || ( value >= param[0] && value <= param[1] );
+		// http://docs.jquery.com/Plugins/Validation/Methods/email
+		email: function(value, element) {
+			// contributed by Scott Gonzalez: http://projects.scottsplayground.com/email_address_validation/
+			return this.optional(element) || /^((([a-z]|\d|[!#\$%&'\*\+\-\/=\?\^_`{\|}~]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])+(\.([a-z]|\d|[!#\$%&'\*\+\-\/=\?\^_`{\|}~]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])+)*)|((\x22)((((\x20|\x09)*(\x0d\x0a))?(\x20|\x09)+)?(([\x01-\x08\x0b\x0c\x0e-\x1f\x7f]|\x21|[\x23-\x5b]|[\x5d-\x7e]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(\\([\x01-\x09\x0b\x0c\x0d-\x7f]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF]))))*(((\x20|\x09)*(\x0d\x0a))?(\x20|\x09)+)?(\x22)))@((([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.)+(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.?$/i.test(element.value);
+		// http://docs.jquery.com/Plugins/Validation/Methods/url
+		url: function(value, element) {
+			// contributed by Scott Gonzalez: http://projects.scottsplayground.com/iri/
+			return this.optional(element) || /^(https?|ftp):\/\/(((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:)*@)?(((\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5])\.(\d|[1-9]\d|1\d\d|2[0-4]\d|25[0-5]))|((([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|\d|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.)+(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])*([a-z]|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])))\.?)(:\d*)?)(\/((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)+(\/(([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)*)*)?)?(\?((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)|[\uE000-\uF8FF]|\/|\?)*)?(\#((([a-z]|\d|-|\.|_|~|[\u00A0-\uD7FF\uF900-\uFDCF\uFDF0-\uFFEF])|(%[\da-f]{2})|[!\$&'\(\)\*\+,;=]|:|@)|\/|\?)*)?$/i.test(element.value);
+		// http://docs.jquery.com/Plugins/Validation/Methods/date
+		date: function(value, element) {
+			return this.optional(element) || !/Invalid|NaN/.test(new Date(value));
+		// http://docs.jquery.com/Plugins/Validation/Methods/dateISO
+		dateISO: function(value, element) {
+			return this.optional(element) || /^\d{4}[\/-]\d{1,2}[\/-]\d{1,2}$/.test(value);
+		// http://docs.jquery.com/Plugins/Validation/Methods/dateDE
+		dateDE: function(value, element) {
+			return this.optional(element) || /^\d\d?\.\d\d?\.\d\d\d?\d?$/.test(value);
+		// http://docs.jquery.com/Plugins/Validation/Methods/number
+		number: function(value, element) {
+			return this.optional(element) || /^-?(?:\d+|\d{1,3}(?:,\d{3})+)(?:\.\d+)?$/.test(value);
+		// http://docs.jquery.com/Plugins/Validation/Methods/numberDE
+		numberDE: function(value, element) {
+			return this.optional(element) || /^-?(?:\d+|\d{1,3}(?:\.\d{3})+)(?:,\d+)?$/.test(value);
+		// http://docs.jquery.com/Plugins/Validation/Methods/digits
+		digits: function(value, element) {
+			return this.optional(element) || /^\d+$/.test(value);
+		// http://docs.jquery.com/Plugins/Validation/Methods/creditcard
+		// based on http://en.wikipedia.org/wiki/Luhn
+		creditcard: function(value, element) {
+			// accept only digits and dashes
+			if (/[^0-9-]+/.test(value))
+				return false;
+			var nCheck = 0,
+				nDigit = 0,
+				bEven = false;
+			value = value.replace(/\D/g, "");
+			for (n = value.length - 1; n >= 0; n--) {
+				var cDigit = value.charAt(n);
+				var nDigit = parseInt(cDigit, 10);
+				if (bEven) {
+					if ((nDigit *= 2) > 9)
+						nDigit -= 9;
+				nCheck += nDigit;
+				bEven = !bEven;
+			return (nCheck % 10) == 0;
+		// http://docs.jquery.com/Plugins/Validation/Methods/accept
+		accept: function(value, element, param) {
+			param = typeof param == "string" ? param : "png|jpe?g|gif";
+			return this.optional(element) || value.match(new RegExp(".(" + param + ")$", "i"));
+		// http://docs.jquery.com/Plugins/Validation/Methods/equalTo
+		equalTo: function(value, element, param) {
+			return value == $(param).val();
+})(jQuery);
+// ajax mode: abort
+// usage: $.ajax({ mode: "abort"[, port: "uniqueport"]});
+// if mode:"abort" is used, the previous request on that port (port can be undefined) is aborted via XMLHttpRequest.abort()
+;(function($) {
+	var ajax = $.ajax;
+	var pendingRequests = {};
+	$.ajax = function(settings) {
+		// create settings for compatibility with ajaxSetup
+		settings = $.extend(settings, $.extend({}, $.ajaxSettings, settings));
+		var port = settings.port;
+		if (settings.mode == "abort") {
+			if ( pendingRequests[port] ) {
+				pendingRequests[port].abort();
+			return (pendingRequests[port] = ajax.apply(this, arguments));
+		return ajax.apply(this, arguments);
+})(jQuery);
+// provides cross-browser focusin and focusout events
+// IE has native support, in other browsers, use event caputuring (neither bubbles)
+// provides delegate(type: String, delegate: Selector, handler: Callback) plugin for easier event delegation
+// handler is only called when $(event.target).is(delegate), in the scope of the jquery-object for event.target
+// provides triggerEvent(type: String, target: Element) to trigger delegated events
+;(function($) {
+	$.each({
+		focus: 'focusin',
+		blur: 'focusout'
+	}, function( original, fix ){
+		$.event.special[fix] = {
+			setup:function() {
+				if ( $.browser.msie ) return false;
+				this.addEventListener( original, $.event.special[fix].handler, true );
+			teardown:function() {
+				this.removeEventListener( original,
+				$.event.special[fix].handler, true );
+			handler: function(e) {
+				arguments[0] = $.event.fix(e);
+				arguments[0].type = fix;
+				return $.event.handle.apply(this, arguments);
+	$.extend($.fn, {
+		delegate: function(type, delegate, handler) {
+			return this.bind(type, function(event) {
+				var target = $(event.target);
+				if (target.is(delegate)) {
+					return handler.apply(target, arguments);
+		triggerEvent: function(type, target) {
+			return this.triggerHandler(type, [$.event.fix({ type: type, target: target })]);
+})(jQuery);
Modified: branches/dev_lenkne/http/extensions/markResult.php
--- branches/dev_lenkne/http/extensions/markResult.php	2008-08-15 20:58:02 UTC (rev 2836)
+++ branches/dev_lenkne/http/extensions/markResult.php	2008-08-15 22:20:09 UTC (rev 2837)
@@ -1,64 +1,64 @@
-<?PHP
-# $Id$
-# http://www.mapbender.org/index.php/markResult.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-* following parameters are required:
-* $width, $height ->  dimensions of the image
-* $color -> Color of the polygon/line, commasaparated RGB-values
-import_request_variables("PG");
-require(dirname(__FILE__)."/../php/mb_validateSession.php");
-$tmpx = array();
-$tmpy = array();
-$x = array();
-$y = array();
-$tmpx = explode(":", $_REQUEST["x"]);
-$tmpy = explode(":", $_REQUEST["y"]);
-for($i=0; $i<count($tmpx); $i++){
-	$x[$i] = array();
-	$y[$i] = array();
-	$x[$i] = explode(",",$tmpx[$i]);
-	$y[$i] = explode(",",$tmpy[$i]);
-if(!$_REQUEST["color"]){ $color = "255,0,0"; }
-$myCol = mb_split(",", $color);
-$image = imagecreate($width,$height);
-$transparent = ImageColorAllocate($image,155,155,155);
-ImageFilledRectangle($image,0,0,$width,$height,$transparent);
-ImageColorTransparent ($image , $transparent);
-$red = imagecolorallocate($image,$myCol[0],$myCol[1],$myCol[2]);
-for($j=0; $j<count($x); $j++){
-	for($i=0; $i < (count($x[$j])-1); $i++){
-		imageline($image,$x[$j][$i],$y[$j][$i],$x[$j][$i+1],$y[$j][$i+1],$red);
-		imageline($image,$x[$j][$i]+1,$y[$j][$i],$x[$j][$i+1]+1,$y[$j][$i+1],$red);
-		imageline($image,$x[$j][$i]-1,$y[$j][$i],$x[$j][$i+1]-1,$y[$j][$i+1],$red);
-		imageline($image,$x[$j][$i],$y[$j][$i]+1,$x[$j][$i+1],$y[$j][$i+1]+1,$red);
-		imageline($image,$x[$j][$i],$y[$j][$i]-1,$x[$j][$i+1],$y[$j][$i+1]-1,$red);
-header("Content-Type: image/png");
-imagepng($image);
+<?PHP
+# $Id$
+# http://www.mapbender.org/index.php/markResult.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+* following parameters are required:
+* $width, $height ->  dimensions of the image
+* $color -> Color of the polygon/line, commasaparated RGB-values
+import_request_variables("PG");
+require(dirname(__FILE__)."/../php/mb_validateSession.php");
+$tmpx = array();
+$tmpy = array();
+$x = array();
+$y = array();
+$tmpx = explode(":", $_REQUEST["x"]);
+$tmpy = explode(":", $_REQUEST["y"]);
+for($i=0; $i<count($tmpx); $i++){
+	$x[$i] = array();
+	$y[$i] = array();
+	$x[$i] = explode(",",$tmpx[$i]);
+	$y[$i] = explode(",",$tmpy[$i]);
+if(!$_REQUEST["color"]){ $color = "255,0,0"; }
+$myCol = mb_split(",", $color);
+$image = imagecreate($width,$height);
+$transparent = ImageColorAllocate($image,155,155,155);
+ImageFilledRectangle($image,0,0,$width,$height,$transparent);
+ImageColorTransparent ($image , $transparent);
+$red = imagecolorallocate($image,$myCol[0],$myCol[1],$myCol[2]);
+for($j=0; $j<count($x); $j++){
+	for($i=0; $i < (count($x[$j])-1); $i++){
+		imageline($image,$x[$j][$i],$y[$j][$i],$x[$j][$i+1],$y[$j][$i+1],$red);
+		imageline($image,$x[$j][$i]+1,$y[$j][$i],$x[$j][$i+1]+1,$y[$j][$i+1],$red);
+		imageline($image,$x[$j][$i]-1,$y[$j][$i],$x[$j][$i+1]-1,$y[$j][$i+1],$red);
+		imageline($image,$x[$j][$i],$y[$j][$i]+1,$x[$j][$i+1],$y[$j][$i+1]+1,$red);
+		imageline($image,$x[$j][$i],$y[$j][$i]-1,$x[$j][$i+1],$y[$j][$i+1]-1,$red);
+header("Content-Type: image/png");
+imagepng($image);
Modified: branches/dev_lenkne/http/extensions/wz_jsgraphics.js
--- branches/dev_lenkne/http/extensions/wz_jsgraphics.js	2008-08-15 20:58:02 UTC (rev 2836)
+++ branches/dev_lenkne/http/extensions/wz_jsgraphics.js	2008-08-15 22:20:09 UTC (rev 2837)
@@ -1,938 +1,212 @@
-/* This notice must be untouched at all times.
-wz_jsgraphics.js    v. 2.3
-The latest version is available at
-http://www.walterzorn.com
-or http://www.devira.com
-or http://www.walterzorn.de
-Copyright (c) 2002-2004 Walter Zorn. All rights reserved.
-Created 3. 11. 2002 by Walter Zorn (Web: http://www.walterzorn.com )
-Last modified: 29. 9. 2004
-Performance optimizations for Internet Explorer
-by Thomas Frank and John Holdsworth.
-fillPolygon method implemented by Matthieu Haller.
-High Performance JavaScript Graphics Library.
-Provides methods
-- to draw lines, rectangles, ellipses, polygons
-  with specifiable line thickness,
-- to fill rectangles and ellipses
-- to draw text.
-NOTE: Operations, functions and branching have rather been optimized
-to efficiency and speed than to shortness of source code.
-LICENSE: LGPL
-This library is free software; you can redistribute it and/or
-modify it under the terms of the GNU Lesser General Public
-License (LGPL) as published by the Free Software Foundation; either
-version 2.1 of the License, or (at your option) any later version.
-This library is distributed in the hope that it will be useful,
-but WITHOUT ANY WARRANTY; without even the implied warranty of
-MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-Lesser General Public License for more details.
-You should have received a copy of the GNU Lesser General Public
-License along with this library; if not, write to the Free Software
-Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA,
-or see http://www.gnu.org/copyleft/lesser.html
-var jg_ihtm, jg_ie, jg_fast, jg_dom, jg_moz,
-jg_n4 = (document.layers && typeof document.classes != "undefined");
-function chkDHTM(x, i)
-        x = document.body || null;
-        jg_ie = x && typeof x.insertAdjacentHTML != "undefined";
-        jg_dom = (x && !jg_ie &&
-                typeof x.appendChild != "undefined" &&
-                typeof document.createRange != "undefined" &&
-                typeof (i = document.createRange()).setStartBefore != "undefined" &&
-                typeof i.createContextualFragment != "undefined");
-        jg_ihtm = !jg_ie && !jg_dom && x && typeof x.innerHTML != "undefined";
-        jg_fast = jg_ie && document.all && !window.opera;
-        jg_moz = jg_dom && typeof x.style.MozOpacity != "undefined";
+var jg_ihtm,jg_ie,jg_fast,jg_dom,jg_moz,jg_n4=(document.layers&&typeof document.classes!="undefined");function chkDHTM(x,i)
+{x=document.body||null;jg_ie=x&&typeof x.insertAdjacentHTML!="undefined";jg_dom=(x&&!jg_ie&&typeof x.appendChild!="undefined"&&typeof document.createRange!="undefined"&&typeof(i=document.createRange()).setStartBefore!="undefined"&&typeof i.createContextualFragment!="undefined");jg_ihtm=!jg_ie&&!jg_dom&&x&&typeof x.innerHTML!="undefined";jg_fast=jg_ie&&document.all&&!window.opera;jg_moz=jg_dom&&typeof x.style.MozOpacity!="undefined";}
 function pntDoc()
-        this.wnd.document.write(jg_fast? this.htmRpc() : this.htm);
-        this.htm = '';
+{this.wnd.document.write(jg_fast?this.htmRpc():this.htm);this.htm='';}
 function pntCnvDom()
-        var x = document.createRange();
-        x.setStartBefore(this.cnv);
-        x = x.createContextualFragment(jg_fast? this.htmRpc() : this.htm);
-        this.cnv.appendChild(x);
-        this.htm = '';
+{var x=document.createRange();x.setStartBefore(this.cnv);x=x.createContextualFragment(jg_fast?this.htmRpc():this.htm);this.cnv.appendChild(x);this.htm='';}
 function pntCnvIe()
-        this.cnv.insertAdjacentHTML("BeforeEnd", jg_fast? this.htmRpc() : this.htm);
-        this.htm = '';
+{this.cnv.insertAdjacentHTML("BeforeEnd",jg_fast?this.htmRpc():this.htm);this.htm='';}
 function pntCnvIhtm()
-        this.cnv.innerHTML += this.htm;
-        this.htm = '';
+{this.cnv.innerHTML+=this.htm;this.htm='';}
 function pntCnv()
-        this.htm = '';
-function mkDiv(x, y, w, h)
-		if (!isNaN(h)) {
-	        this.htm += '<div style="position:absolute;'+
-	                'left:' + x + 'px;'+
-	                'top:' + y + 'px;'+
-	                'width:' + w + 'px;'+
-	                'height:' + h + 'px;';
-	        if (ie) {
-	        		this.htm += '-opacity:' + cw_opacity + ';' +
-	                '-khtml-opacity:' + cw_opacity + ';'+
-	                'filter: alpha(opacity=' + (cw_opacity * 100) + ');';
-	//'-moz-opacity:' + window.cw_opacity + ';'+
-	        this.htm +=
-	                'clip:rect(0,'+w+'px,'+h+'px,0);'+
-	                'background-color:' + this.color +
-	                (!jg_moz? ';overflow:hidden' : '')+
-	                ';"><\/div>';
-function mkDivIe(x, y, w, h)
-		if (!isNaN(h)) {
-	        this.htm += '%%'+this.color+';'+x+';'+y+';'+w+';'+h+';';
-function mkDivPrt(x, y, w, h)
-                'border-left:' + w + 'px solid ' + this.color + ';'+
-                'width:0px;'+
-                'height:' + h + 'px;'+
-                ';"><\/div>';
-function mkLyr(x, y, w, h)
-        this.htm += '<layer '+
-                'left="' + x + '" '+
-                'top="' + y + '" '+
-                'width="' + w + '" '+
-                'height="' + h + '" '+
-                'bgcolor="' + this.color + '"><\/layer>\n';
-var regex =  /%%([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);/g;
-function htmRpc()
-        return this.htm.replace(
-                regex,
-                '<div style="overflow:hidden;position:absolute;background-color:'+
-                '$1;left:$2;top:$3;width:$4;height:$5"></div>\n');
+{this.htm='';}
+function mkDiv(x,y,w,h)
+{if(!isNaN(h)){this.htm+='<div style="position:absolute;'+'left:'+x+'px;'+'top:'+y+'px;'+'width:'+w+'px;'+'height:'+h+'px;';if(ie){this.htm+='-opacity:'+cw_opacity+';'+'-khtml-opacity:'+cw_opacity+';'+'filter: alpha(opacity='+(cw_opacity*100)+');';}
+this.htm+='clip:rect(0,'+w+'px,'+h+'px,0);'+'background-color:'+this.color+
+(!jg_moz?';overflow:hidden':'')+';"><\/div>';}}
+function mkDivIe(x,y,w,h)
+{if(!isNaN(h)){this.htm+='%%'+this.color+';'+x+';'+y+';'+w+';'+h+';';}}
+function mkDivPrt(x,y,w,h)
+{this.htm+='<div style="position:absolute;'+'border-left:'+w+'px solid '+this.color+';'+'left:'+x+'px;'+'top:'+y+'px;'+'width:0px;'+'height:'+h+'px;'+'clip:rect(0,'+w+'px,'+h+'px,0);'+'background-color:'+this.color+
+function mkLyr(x,y,w,h)
+{this.htm+='<layer '+'left="'+x+'" '+'top="'+y+'" '+'width="'+w+'" '+'height="'+h+'" '+'bgcolor="'+this.color+'"><\/layer>\n';}
+var regex=/%%([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);/g;function htmRpc()
+{return this.htm.replace(regex,'<div style="overflow:hidden;position:absolute;background-color:'+'$1;left:$2;top:$3;width:$4;height:$5"></div>\n');}
 function htmPrtRpc()
-                regex,
-                '$1;left:$2;top:$3;width:$4;height:$5;border-left:$4px solid $1"></div>\n');
-function mkLin(x1, y1, x2, y2)
-        if (x1 > x2)
-                var _x2 = x2;
-                var _y2 = y2;
-                x2 = x1;
-                y2 = y1;
-                x1 = _x2;
-                y1 = _y2;
-        var dx = x2-x1, dy = Math.abs(y2-y1),
-        x = x1, y = y1,
-        yIncr = (y1 > y2)? -1 : 1;
-        if (dx >= dy)
-                var pr = dy<<1,
-                pru = pr - (dx<<1),
-                p = pr-dx,
-                ox = x;
-                while ((dx--) > 0)
-                        ++x;
-                        if (p > 0)
-                                this.mkDiv(ox, y, x-ox, 1);
-                                y += yIncr;
-                                p += pru;
-                                ox = x;
-                        else p += pr;
-                this.mkDiv(ox, y, x2-ox+1, 1);
-        else
-                var pr = dx<<1,
-                pru = pr - (dy<<1),
-                p = pr-dy,
-                oy = y;
-                if (y2 <= y1)
-                        while ((dy--) > 0)
-                                if (p > 0)
-                                        this.mkDiv(x++, y, 1, oy-y+1);
-                                        y += yIncr;
-                                        p += pru;
-                                        oy = y;
-                                else
-                                        y += yIncr;
-                                        p += pr;
-                        this.mkDiv(x2, y2, 1, oy-y2+1);
-                else
-                                y += yIncr;
-                                if (p > 0)
-                                        this.mkDiv(x++, oy, 1, y-oy);
-                                        p += pru;
-                                        oy = y;
-                                else p += pr;
-                        this.mkDiv(x2, oy, 1, y2-oy+1);
-function mkLin2D(x1, y1, x2, y2)
-        if (x1 > x2)
-                var _x2 = x2;
-                var _y2 = y2;
-                x2 = x1;
-                y2 = y1;
-                x1 = _x2;
-                y1 = _y2;
-        x = x1, y = y1,
-        var s = this.stroke;
-        if (dx >= dy)
-                if (s-3 > 0)
-                        var _s = (s*dx*Math.sqrt(1+dy*dy/(dx*dx))-dx-(s>>1)*dy) / dx;
-                        _s = (!(s-4)? Math.ceil(_s) : Math.round(_s)) + 1;
-                else var _s = s;
-                var ad = Math.ceil(s/2);
-                var pr = dy<<1,
-                p = pr-dx,
-                ox = x;
-                        ++x;
-                        if (p > 0)
-                                this.mkDiv(ox, y, x-ox+ad, _s);
-                                y += yIncr;
-                                p += pru;
-                                ox = x;
-                        else p += pr;
-                this.mkDiv(ox, y, x2-ox+ad+1, _s);
-        else
-                if (s-3 > 0)
-                        var _s = (s*dy*Math.sqrt(1+dx*dx/(dy*dy))-(s>>1)*dx-dy) / dy;
-                else var _s = s;
-                var ad = Math.round(s/2);
-                var pr = dx<<1,
-                p = pr-dy,
-                oy = y;
-                if (y2 <= y1)
-                        ++ad;
-                                if (p > 0)
-                                        this.mkDiv(x++, y, _s, oy-y+ad);
-                                        y += yIncr;
-                                        p += pru;
-                                        oy = y;
-                                else
-                                        y += yIncr;
-                                        p += pr;
-                        this.mkDiv(x2, y2, _s, oy-y2+ad);
-                else
-                                y += yIncr;
-                                if (p > 0)
-                                        this.mkDiv(x++, oy, _s, y-oy+ad);
-                                        p += pru;
-                                        oy = y;
-                                else p += pr;
-                        this.mkDiv(x2, oy, _s, y2-oy+ad+1);
-function mkLinDott(x1, y1, x2, y2)
-        if (x1 > x2)
-                var _x2 = x2;
-                var _y2 = y2;
-                x2 = x1;
-                y2 = y1;
-                x1 = _x2;
-                y1 = _y2;
-        x = x1, y = y1,
-        yIncr = (y1 > y2)? -1 : 1,
-        drw = true;
-        if (dx >= dy)
-                var pr = dy<<1,
-                p = pr-dx;
-                        if (drw) this.mkDiv(x, y, 1, 1);
-                        drw = !drw;
-                        if (p > 0)
-                                y += yIncr;
-                                p += pru;
-                        else p += pr;
-                        ++x;
-        else
-                var pr = dx<<1,
-                p = pr-dy;
-                        drw = !drw;
-                        y += yIncr;
-                        if (p > 0)
-                                ++x;
-                                p += pru;
-                        else p += pr;
-function mkOv(left, top, width, height)
-        var a = width>>1, b = height>>1,
-        wod = width&1, hod = (height&1)+1,
-        cx = left+a, cy = top+b,
-        x = 0, y = b,
-        ox = 0, oy = b,
-        aa = (a*a)<<1, bb = (b*b)<<1,
-        st = (aa>>1)*(1-(b<<1)) + bb,
-        tt = (bb>>1) - aa*((b<<1)-1),
-        w, h;
-        while (y > 0)
-                if (st < 0)
-                        st += bb*((x<<1)+3);
-                        tt += (bb<<1)*(++x);
-                else if (tt < 0)
-                        st += bb*((x<<1)+3) - (aa<<1)*(y-1);
-                        tt += (bb<<1)*(++x) - aa*(((y--)<<1)-3);
-                        w = x-ox;
-                        h = oy-y;
-                        if (w&2 && h&2)
-                                this.mkOvQds(cx, cy, -x+2, ox+wod, -oy, oy-1+hod, 1, 1);
-                                this.mkOvQds(cx, cy, -x+1, x-1+wod, -y-1, y+hod, 1, 1);
-                        else this.mkOvQds(cx, cy, -x+1, ox+wod, -oy, oy-h+hod, w, h);
-                        ox = x;
-                        oy = y;
-                else
-                        tt -= aa*((y<<1)-3);
-                        st -= (aa<<1)*(--y);
-        this.mkDiv(cx-a, cy-oy, a-ox+1, (oy<<1)+hod);
-        this.mkDiv(cx+ox+wod, cy-oy, a-ox+1, (oy<<1)+hod);
-function mkOv2D(left, top, width, height)
-        width += s-1;
-        height += s-1;
-        x = 0, y = b,
-        tt = (bb>>1) - aa*((b<<1)-1);
-        if (s-4 < 0 && (!(s-2) || width-51 > 0 && height-51 > 0))
-                var ox = 0, oy = b,
-                w, h,
-                pxl, pxr, pxt, pxb, pxw;
-                while (y > 0)
-                        if (st < 0)
-                        else if (tt < 0)
-                                w = x-ox;
-                                h = oy-y;
-                                if (w-1)
-                                        pxw = w+1+(s&1);
-                                        h = s;
-                                else if (h-1)
-                                        pxw = s;
-                                        h += 1+(s&1);
-                                else pxw = h = s;
-                                this.mkOvQds(cx, cy, -x+1, ox-pxw+w+wod, -oy, -h+oy+hod, pxw, h);
-                                ox = x;
-                                oy = y;
-                        else
-                this.mkDiv(cx-a, cy-oy, s, (oy<<1)+hod);
-                this.mkDiv(cx+a+wod-s+1, cy-oy, s, (oy<<1)+hod);
-        else
-                var _a = (width-((s-1)<<1))>>1,
-                _b = (height-((s-1)<<1))>>1,
-                _x = 0, _y = _b,
-                _aa = (_a*_a)<<1, _bb = (_b*_b)<<1,
-                _st = (_aa>>1)*(1-(_b<<1)) + _bb,
-                _tt = (_bb>>1) - _aa*((_b<<1)-1),
-                pxl = new Array(),
-                pxt = new Array(),
-                _pxb = new Array();
-                pxl[0] = 0;
-                pxt[0] = b;
-                _pxb[0] = _b-1;
-                while (y > 0)
-                        if (st < 0)
-                                pxl[pxl.length] = x;
-                                pxt[pxt.length] = y;
-                        else if (tt < 0)
-                        else
-                        if (_y > 0)
-                                if (_st < 0)
-                                        _st += _bb*((_x<<1)+3);
-                                        _tt += (_bb<<1)*(++_x);
-                                        _pxb[_pxb.length] = _y-1;
-                                else if (_tt < 0)
-                                        _st += _bb*((_x<<1)+3) - (_aa<<1)*(_y-1);
-                                        _tt += (_bb<<1)*(++_x) - _aa*(((_y--)<<1)-3);
-                                else
-                                        _tt -= _aa*((_y<<1)-3);
-                                        _st -= (_aa<<1)*(--_y);
-                                        _pxb[_pxb.length-1]--;
-                _oy = _pxb[0],
-                l = pxl.length,
-                w, h;
-                for (var i = 0; i < l; i++)
-                        if (typeof _pxb[i] != "undefined")
-                                if (_pxb[i] < _oy || pxt[i] < oy)
-                                        x = pxl[i];
-                                        this.mkOvQds(cx, cy, -x+1, ox+wod, -oy, _oy+hod, x-ox, oy-_oy);
-                                        ox = x;
-                                        oy = pxt[i];
-                                        _oy = _pxb[i];
-                        else
-                                x = pxl[i];
-                                this.mkDiv(cx-x+1, cy-oy, 1, (oy<<1)+hod);
-                                this.mkDiv(cx+ox+wod, cy-oy, 1, (oy<<1)+hod);
-                                ox = x;
-                                oy = pxt[i];
-                this.mkDiv(cx-a, cy-oy, 1, (oy<<1)+hod);
-function mkOvDott(left, top, width, height)
-        wod = width&1, hod = height&1,
-        x = 0, y = b,
-        aa2 = (a*a)<<1, aa4 = aa2<<1, bb = (b*b)<<1,
-        st = (aa2>>1)*(1-(b<<1)) + bb,
-        tt = (bb>>1) - aa2*((b<<1)-1),
-        drw = true;
-        while (y > 0)
-                if (st < 0)
-                else if (tt < 0)
-                        st += bb*((x<<1)+3) - aa4*(y-1);
-                        tt += (bb<<1)*(++x) - aa2*(((y--)<<1)-3);
-                else
-                        tt -= aa2*((y<<1)-3);
-                        st -= aa4*(--y);
-                if (drw) this.mkOvQds(cx, cy, -x, x+wod, -y, y+hod, 1, 1);
-                drw = !drw;
-function mkRect(x, y, w, h)
-        this.mkDiv(x, y, w, s);
-        this.mkDiv(x+w, y, s, h);
-        this.mkDiv(x, y+h, w+s, s);
-        this.mkDiv(x, y+s, s, h-s);
-function mkRectDott(x, y, w, h)
-        this.drawLine(x, y, x+w, y);
-        this.drawLine(x+w, y, x+w, y+h);
-        this.drawLine(x, y+h, x+w, y+h);
-        this.drawLine(x, y, x, y+h);
+{return this.htm.replace(regex,'<div style="overflow:hidden;position:absolute;background-color:'+'$1;left:$2;top:$3;width:$4;height:$5;border-left:$4px solid $1"></div>\n');}
+function mkLin(x1,y1,x2,y2)
+{if(x1>x2)
+{var _x2=x2;var _y2=y2;x2=x1;y2=y1;x1=_x2;y1=_y2;}
+var dx=x2-x1,dy=Math.abs(y2-y1),x=x1,y=y1,yIncr=(y1>y2)?-1:1;if(dx>=dy)
+{var pr=dy<<1,pru=pr-(dx<<1),p=pr-dx,ox=x;while((dx--)>0)
+{++x;if(p>0)
+{this.mkDiv(ox,y,x-ox,1);y+=yIncr;p+=pru;ox=x;}
+else p+=pr;}
+this.mkDiv(ox,y,x2-ox+1,1);}
+else
+{var pr=dx<<1,pru=pr-(dy<<1),p=pr-dy,oy=y;if(y2<=y1)
+{while((dy--)>0)
+{if(p>0)
+{this.mkDiv(x++,y,1,oy-y+1);y+=yIncr;p+=pru;oy=y;}
+else
+{y+=yIncr;p+=pr;}}
+this.mkDiv(x2,y2,1,oy-y2+1);}
+else
+{while((dy--)>0)
+{y+=yIncr;if(p>0)
+{this.mkDiv(x++,oy,1,y-oy);p+=pru;oy=y;}
+else p+=pr;}
+this.mkDiv(x2,oy,1,y2-oy+1);}}}
+function mkLin2D(x1,y1,x2,y2)
+{if(x1>x2)
+var dx=x2-x1,dy=Math.abs(y2-y1),x=x1,y=y1,yIncr=(y1>y2)?-1:1;var s=this.stroke;if(dx>=dy)
+{if(s-3>0)
+{var _s=(s*dx*Math.sqrt(1+dy*dy/(dx*dx))-dx-(s>>1)*dy)/dx;_s=(!(s-4)?Math.ceil(_s):Math.round(_s))+1;}
+else var _s=s;var ad=Math.ceil(s/2);var pr=dy<<1,pru=pr-(dx<<1),p=pr-dx,ox=x;while((dx--)>0)
+{++x;if(p>0)
+{this.mkDiv(ox,y,x-ox+ad,_s);y+=yIncr;p+=pru;ox=x;}
+else p+=pr;}
+this.mkDiv(ox,y,x2-ox+ad+1,_s);}
+else
+{if(s-3>0)
+{var _s=(s*dy*Math.sqrt(1+dx*dx/(dy*dy))-(s>>1)*dx-dy)/dy;_s=(!(s-4)?Math.ceil(_s):Math.round(_s))+1;}
+else var _s=s;var ad=Math.round(s/2);var pr=dx<<1,pru=pr-(dy<<1),p=pr-dy,oy=y;if(y2<=y1)
+{++ad;while((dy--)>0)
+{if(p>0)
+{this.mkDiv(x++,y,_s,oy-y+ad);y+=yIncr;p+=pru;oy=y;}
+else
+{y+=yIncr;p+=pr;}}
+this.mkDiv(x2,y2,_s,oy-y2+ad);}
+else
+{while((dy--)>0)
+{y+=yIncr;if(p>0)
+{this.mkDiv(x++,oy,_s,y-oy+ad);p+=pru;oy=y;}
+else p+=pr;}
+this.mkDiv(x2,oy,_s,y2-oy+ad+1);}}}
+function mkLinDott(x1,y1,x2,y2)
+{if(x1>x2)
+var dx=x2-x1,dy=Math.abs(y2-y1),x=x1,y=y1,yIncr=(y1>y2)?-1:1,drw=true;if(dx>=dy)
+{var pr=dy<<1,pru=pr-(dx<<1),p=pr-dx;while((dx--)>0)
+{if(drw)this.mkDiv(x,y,1,1);drw=!drw;if(p>0)
+{y+=yIncr;p+=pru;}
+else p+=pr;++x;}
+if(drw)this.mkDiv(x,y,1,1);}
+else
+{var pr=dx<<1,pru=pr-(dy<<1),p=pr-dy;while((dy--)>0)
+{if(drw)this.mkDiv(x,y,1,1);drw=!drw;y+=yIncr;if(p>0)
+{++x;p+=pru;}
+else p+=pr;}
+if(drw)this.mkDiv(x,y,1,1);}}
+function mkOv(left,top,width,height)
+{var a=width>>1,b=height>>1,wod=width&1,hod=(height&1)+1,cx=left+a,cy=top+b,x=0,y=b,ox=0,oy=b,aa=(a*a)<<1,bb=(b*b)<<1,st=(aa>>1)*(1-(b<<1))+bb,tt=(bb>>1)-aa*((b<<1)-1),w,h;while(y>0)
+{if(st<0)
+{st+=bb*((x<<1)+3);tt+=(bb<<1)*(++x);}
+else if(tt<0)
+{st+=bb*((x<<1)+3)-(aa<<1)*(y-1);tt+=(bb<<1)*(++x)-aa*(((y--)<<1)-3);w=x-ox;h=oy-y;if(w&2&&h&2)
+{this.mkOvQds(cx,cy,-x+2,ox+wod,-oy,oy-1+hod,1,1);this.mkOvQds(cx,cy,-x+1,x-1+wod,-y-1,y+hod,1,1);}
+else this.mkOvQds(cx,cy,-x+1,ox+wod,-oy,oy-h+hod,w,h);ox=x;oy=y;}
+else
+{tt-=aa*((y<<1)-3);st-=(aa<<1)*(--y);}}
+this.mkDiv(cx-a,cy-oy,a-ox+1,(oy<<1)+hod);this.mkDiv(cx+ox+wod,cy-oy,a-ox+1,(oy<<1)+hod);}
+function mkOv2D(left,top,width,height)
+{var s=this.stroke;width+=s-1;height+=s-1;var a=width>>1,b=height>>1,wod=width&1,hod=(height&1)+1,cx=left+a,cy=top+b,x=0,y=b,aa=(a*a)<<1,bb=(b*b)<<1,st=(aa>>1)*(1-(b<<1))+bb,tt=(bb>>1)-aa*((b<<1)-1);if(s-4<0&&(!(s-2)||width-51>0&&height-51>0))
+{var ox=0,oy=b,w,h,pxl,pxr,pxt,pxb,pxw;while(y>0)
+{if(st<0)
+else if(tt<0)
+{st+=bb*((x<<1)+3)-(aa<<1)*(y-1);tt+=(bb<<1)*(++x)-aa*(((y--)<<1)-3);w=x-ox;h=oy-y;if(w-1)
+{pxw=w+1+(s&1);h=s;}
+else if(h-1)
+{pxw=s;h+=1+(s&1);}
+else pxw=h=s;this.mkOvQds(cx,cy,-x+1,ox-pxw+w+wod,-oy,-h+oy+hod,pxw,h);ox=x;oy=y;}
+else
+this.mkDiv(cx-a,cy-oy,s,(oy<<1)+hod);this.mkDiv(cx+a+wod-s+1,cy-oy,s,(oy<<1)+hod);}
+else
+{var _a=(width-((s-1)<<1))>>1,_b=(height-((s-1)<<1))>>1,_x=0,_y=_b,_aa=(_a*_a)<<1,_bb=(_b*_b)<<1,_st=(_aa>>1)*(1-(_b<<1))+_bb,_tt=(_bb>>1)-_aa*((_b<<1)-1),pxl=new Array(),pxt=new Array(),_pxb=new Array();pxl[0]=0;pxt[0]=b;_pxb[0]=_b-1;while(y>0)
+{if(st<0)
+{st+=bb*((x<<1)+3);tt+=(bb<<1)*(++x);pxl[pxl.length]=x;pxt[pxt.length]=y;}
+else if(tt<0)
+{st+=bb*((x<<1)+3)-(aa<<1)*(y-1);tt+=(bb<<1)*(++x)-aa*(((y--)<<1)-3);pxl[pxl.length]=x;pxt[pxt.length]=y;}
+else
+if(_y>0)
+{if(_st<0)
+{_st+=_bb*((_x<<1)+3);_tt+=(_bb<<1)*(++_x);_pxb[_pxb.length]=_y-1;}
+else if(_tt<0)
+{_st+=_bb*((_x<<1)+3)-(_aa<<1)*(_y-1);_tt+=(_bb<<1)*(++_x)-_aa*(((_y--)<<1)-3);_pxb[_pxb.length]=_y-1;}
+else
+{_tt-=_aa*((_y<<1)-3);_st-=(_aa<<1)*(--_y);_pxb[_pxb.length-1]--;}}}
+var ox=0,oy=b,_oy=_pxb[0],l=pxl.length,w,h;for(var i=0;i<l;i++)
+{if(typeof _pxb[i]!="undefined")
+{if(_pxb[i]<_oy||pxt[i]<oy)
+{x=pxl[i];this.mkOvQds(cx,cy,-x+1,ox+wod,-oy,_oy+hod,x-ox,oy-_oy);ox=x;oy=pxt[i];_oy=_pxb[i];}}
+else
+{x=pxl[i];this.mkDiv(cx-x+1,cy-oy,1,(oy<<1)+hod);this.mkDiv(cx+ox+wod,cy-oy,1,(oy<<1)+hod);ox=x;oy=pxt[i];}}
+this.mkDiv(cx-a,cy-oy,1,(oy<<1)+hod);this.mkDiv(cx+ox+wod,cy-oy,1,(oy<<1)+hod);}}
+function mkOvDott(left,top,width,height)
+{var a=width>>1,b=height>>1,wod=width&1,hod=height&1,cx=left+a,cy=top+b,x=0,y=b,aa2=(a*a)<<1,aa4=aa2<<1,bb=(b*b)<<1,st=(aa2>>1)*(1-(b<<1))+bb,tt=(bb>>1)-aa2*((b<<1)-1),drw=true;while(y>0)
+{if(st<0)
+else if(tt<0)
+{st+=bb*((x<<1)+3)-aa4*(y-1);tt+=(bb<<1)*(++x)-aa2*(((y--)<<1)-3);}
+else
+{tt-=aa2*((y<<1)-3);st-=aa4*(--y);}
+if(drw)this.mkOvQds(cx,cy,-x,x+wod,-y,y+hod,1,1);drw=!drw;}}
+function mkRect(x,y,w,h)
+{var s=this.stroke;this.mkDiv(x,y,w,s);this.mkDiv(x+w,y,s,h);this.mkDiv(x,y+h,w+s,s);this.mkDiv(x,y+s,s,h-s);}
+function mkRectDott(x,y,w,h)
+{this.drawLine(x,y,x+w,y);this.drawLine(x+w,y,x+w,y+h);this.drawLine(x,y+h,x+w,y+h);this.drawLine(x,y,x,y+h);}
 function jsgFont()
-        this.PLAIN = 'font-weight:normal;';
-        this.BOLD = 'font-weight:bold;';
-        this.ITALIC = 'font-style:italic;';
-        this.ITALIC_BOLD = this.ITALIC + this.BOLD;
-        this.BOLD_ITALIC = this.ITALIC_BOLD;
-var Font = new jsgFont();
-function jsgStroke()
-        this.DOTTED = -1;
-var Stroke = new jsgStroke();
-function jsGraphics(id, wnd)
-        this.setColor = new Function('arg', 'this.color = arg.toLowerCase();');
-        this.setStroke = function(x)
-                this.stroke = x;
-                if (!(x+1))
-                        this.drawLine = mkLinDott;
-                        this.mkOv = mkOvDott;
-                        this.drawRect = mkRectDott;
-                else if (x-1 > 0)
-                        this.drawLine = mkLin2D;
-                        this.mkOv = mkOv2D;
-                        this.drawRect = mkRect;
-                else
-                        this.drawLine = mkLin;
-                        this.mkOv = mkOv;
-        this.setPrintable = function(arg)
-                this.printable = arg;
-                if (jg_fast)
-                        this.mkDiv = mkDivIe;
-                        this.htmRpc = arg? htmPrtRpc : htmRpc;
-                else this.mkDiv = jg_n4? mkLyr : arg? mkDivPrt : mkDiv;
-        this.setFont = function(fam, sz, sty)
-                this.ftFam = fam;
-                this.ftSz = sz;
-                this.ftSty = sty || Font.PLAIN;
-        this.drawPolyline = this.drawPolyLine = function(x, y, s)
-                for (var i=0 ; i<x.length-1 ; i++ )
-                        this.drawLine(x[i], y[i], x[i+1], y[i+1]);
-        this.fillRect = function(x, y, w, h)
-                this.mkDiv(x, y, w, h);
-        this.drawPolygon = function(x, y)
-                this.drawPolyline(x, y);
-                this.drawLine(x[x.length-1], y[x.length-1], x[0], y[0]);
-        this.drawEllipse = this.drawOval = function(x, y, w, h)
-                this.mkOv(x, y, w, h);
-        this.fillEllipse = this.fillOval = function(left, top, w, h)
-                var a = (w -= 1)>>1, b = (h -= 1)>>1,
-                wod = (w&1)+1, hod = (h&1)+1,
-                x = 0, y = b,
-                ox = 0, oy = b,
-                pxl, dw, dh;
-                if (w+1) while (y > 0)
-                        if (st < 0)
-                        else if (tt < 0)
-                                pxl = cx-x;
-                                dw = (x<<1)+wod;
-                                dh = oy-y;
-                                this.mkDiv(pxl, cy-oy, dw, dh);
-                                this.mkDiv(pxl, cy+oy-dh+hod, dw, dh);
-                                ox = x;
-                                oy = y;
-                        else
-                                st -= aa4*(--y);
-                this.mkDiv(cx-a, cy-oy, w+1, (oy<<1)+hod);
-/* fillPolygon method, implemented by Matthieu Haller.
-This javascript function is an adaptation of the gdImageFilledPolygon for Walter Zorn lib.
-C source of GD 1.8.4 found at http://www.boutell.com/gd/
-THANKS to Kirsten Schulz for the polygon fixes!
-The intersection finding technique of this code could be improved
-by remembering the previous intertersection, and by using the slope.
-That could help to adjust intersections to produce a nice
-interior_extrema. */
-        this.fillPolygon = function(array_x, array_y)
-                var i;
-                var y;
-                var miny, maxy;
-                var x1, y1;
-                var x2, y2;
-                var ind1, ind2;
-                var ints;
-                var n = array_x.length;
-                if (!n) return;
-                miny = array_y[0];
-                maxy = array_y[0];
-                for (i = 1; i < n; i++)
-                        if (array_y[i] < miny)
-                                miny = array_y[i];
-                        if (array_y[i] > maxy)
-                                maxy = array_y[i];
-                for (y = miny; y <= maxy; y++)
-                        var polyInts = new Array();
-                        ints = 0;
-                        for (i = 0; i < n; i++)
-                                if (!i)
-                                        ind1 = n-1;
-                                        ind2 = 0;
-                                else
-                                        ind1 = i-1;
-                                        ind2 = i;
-                                y1 = array_y[ind1];
-                                y2 = array_y[ind2];
-                                if (y1 < y2)
-                                        x1 = array_x[ind1];
-                                        x2 = array_x[ind2];
-                                else if (y1 > y2)
-                                        y2 = array_y[ind1];
-                                        y1 = array_y[ind2];
-                                        x2 = array_x[ind1];
-                                        x1 = array_x[ind2];
-                                else continue;
-                                 // modified 11. 2. 2004 Walter Zorn
-                                if ((y >= y1) && (y < y2))
-                                        polyInts[ints++] = Math.round((y-y1) * (x2-x1) / (y2-y1) + x1);
-                                else if ((y == maxy) && (y > y1) && (y <= y2))
-                        polyInts.sort(integer_compare);
-                        for (i = 0; i < ints; i+=2)
-                                this.mkDiv(polyInts[i], y, polyInts[i+1]-polyInts[i]+1, 1);
-        this.drawString = function(txt, x, y)
-                this.htm += '<div style="position:absolute;white-space:nowrap;'+
-                        'font-family:' +  this.ftFam + ';'+
-                        'font-size:' + this.ftSz + ';'+
-                        'color:' + this.color + ';' + this.ftSty + '">'+
-                        txt +
-                        '<\/div>';
-        this.drawImage = function(imgSrc, x, y, w, h)
-                        'width:' +  w + ';'+
-                        'height:' + h + ';">'+
-                        '<img src="' + imgSrc + '" width="' + w + '" height="' + h + '">'+
-                        '<\/div>';
-        this.clear = function()
-                this.htm = "";
-                if (this.cnv) this.cnv.innerHTML = this.defhtm;
-        this.mkOvQds = function(cx, cy, xl, xr, yt, yb, w, h)
-                this.mkDiv(xr+cx, yt+cy, w, h);
-                this.mkDiv(xr+cx, yb+cy, w, h);
-                this.mkDiv(xl+cx, yb+cy, w, h);
-                this.mkDiv(xl+cx, yt+cy, w, h);
-        this.setStroke(1);
-        this.setFont('verdana,geneva,helvetica,sans-serif', String.fromCharCode(0x31, 0x32, 0x70, 0x78), Font.PLAIN);
-        this.color = '#000000';
-        this.htm = '';
-        this.wnd = wnd || window;
-        if (!(jg_ie || jg_dom || jg_ihtm)) chkDHTM();
-        if (typeof id != 'string' || !id) this.paint = pntDoc;
-        else
-                this.cnv = document.all? (this.wnd.document.all[id] || null)
-                        : document.getElementById? (this.wnd.document.getElementById(id) || null)
-                        : null;
-                this.defhtm = (this.cnv && this.cnv.innerHTML)? this.cnv.innerHTML : '';
-                this.paint = jg_dom? pntCnvDom : jg_ie? pntCnvIe : jg_ihtm? pntCnvIhtm : pntCnv;
-        this.setPrintable(false);
+{this.PLAIN='font-weight:normal;';this.BOLD='font-weight:bold;';this.ITALIC='font-style:italic;';this.ITALIC_BOLD=this.ITALIC+this.BOLD;this.BOLD_ITALIC=this.ITALIC_BOLD;}
+var Font=new jsgFont();function jsgStroke()
+{this.DOTTED=-1;}
+var Stroke=new jsgStroke();function jsGraphics(id,wnd)
+{this.setColor=new Function('arg','this.color = arg.toLowerCase();');this.setStroke=function(x)
+{this.stroke=x;if(!(x+1))
+{this.drawLine=mkLinDott;this.mkOv=mkOvDott;this.drawRect=mkRectDott;}
+else if(x-1>0)
+{this.drawLine=mkLin2D;this.mkOv=mkOv2D;this.drawRect=mkRect;}
+else
+{this.drawLine=mkLin;this.mkOv=mkOv;this.drawRect=mkRect;}};this.setPrintable=function(arg)
+{this.printable=arg;if(jg_fast)
+{this.mkDiv=mkDivIe;this.htmRpc=arg?htmPrtRpc:htmRpc;}
+else this.mkDiv=jg_n4?mkLyr:arg?mkDivPrt:mkDiv;};this.setFont=function(fam,sz,sty)
+{this.ftFam=fam;this.ftSz=sz;this.ftSty=sty||Font.PLAIN;};this.drawPolyline=this.drawPolyLine=function(x,y,s)
+{for(var i=0;i<x.length-1;i++)
+this.drawLine(x[i],y[i],x[i+1],y[i+1]);};this.fillRect=function(x,y,w,h)
+{this.mkDiv(x,y,w,h);};this.drawPolygon=function(x,y)
+{this.drawPolyline(x,y);this.drawLine(x[x.length-1],y[x.length-1],x[0],y[0]);};this.drawEllipse=this.drawOval=function(x,y,w,h)
+{this.mkOv(x,y,w,h);};this.fillEllipse=this.fillOval=function(left,top,w,h)
+{var a=(w-=1)>>1,b=(h-=1)>>1,wod=(w&1)+1,hod=(h&1)+1,cx=left+a,cy=top+b,x=0,y=b,ox=0,oy=b,aa2=(a*a)<<1,aa4=aa2<<1,bb=(b*b)<<1,st=(aa2>>1)*(1-(b<<1))+bb,tt=(bb>>1)-aa2*((b<<1)-1),pxl,dw,dh;if(w+1)while(y>0)
+{if(st<0)
+else if(tt<0)
+{st+=bb*((x<<1)+3)-aa4*(y-1);pxl=cx-x;dw=(x<<1)+wod;tt+=(bb<<1)*(++x)-aa2*(((y--)<<1)-3);dh=oy-y;this.mkDiv(pxl,cy-oy,dw,dh);this.mkDiv(pxl,cy+oy-dh+hod,dw,dh);ox=x;oy=y;}
+else
+{tt-=aa2*((y<<1)-3);st-=aa4*(--y);}}
+this.mkDiv(cx-a,cy-oy,w+1,(oy<<1)+hod);};this.fillPolygon=function(array_x,array_y)
+{var i;var y;var miny,maxy;var x1,y1;var x2,y2;var ind1,ind2;var ints;var n=array_x.length;if(!n)return;miny=array_y[0];maxy=array_y[0];for(i=1;i<n;i++)
+{if(array_y[i]<miny)
+miny=array_y[i];if(array_y[i]>maxy)
+maxy=array_y[i];}
+for(y=miny;y<=maxy;y++)
+{var polyInts=new Array();ints=0;for(i=0;i<n;i++)
+{if(!i)
+{ind1=n-1;ind2=0;}
+else
+{ind1=i-1;ind2=i;}
+y1=array_y[ind1];y2=array_y[ind2];if(y1<y2)
+{x1=array_x[ind1];x2=array_x[ind2];}
+else if(y1>y2)
+{y2=array_y[ind1];y1=array_y[ind2];x2=array_x[ind1];x1=array_x[ind2];}
+else continue;if((y>=y1)&&(y<y2))
+polyInts[ints++]=Math.round((y-y1)*(x2-x1)/(y2-y1)+x1);else if((y==maxy)&&(y>y1)&&(y<=y2))
+polyInts[ints++]=Math.round((y-y1)*(x2-x1)/(y2-y1)+x1);}
+polyInts.sort(integer_compare);for(i=0;i<ints;i+=2)
+this.mkDiv(polyInts[i],y,polyInts[i+1]-polyInts[i]+1,1);}};this.drawString=function(txt,x,y)
+{this.htm+='<div style="position:absolute;white-space:nowrap;'+'left:'+x+'px;'+'top:'+y+'px;'+'font-family:'+this.ftFam+';'+'font-size:'+this.ftSz+';'+'color:'+this.color+';'+this.ftSty+'">'+
+txt+'<\/div>';}
+this.drawImage=function(imgSrc,x,y,w,h)
+{this.htm+='<div style="position:absolute;'+'left:'+x+'px;'+'top:'+y+'px;'+'width:'+w+';'+'height:'+h+';">'+'<img src="'+imgSrc+'" width="'+w+'" height="'+h+'">'+'<\/div>';}
+this.clear=function()
+{this.htm="";if(this.cnv)this.cnv.innerHTML=this.defhtm;};this.mkOvQds=function(cx,cy,xl,xr,yt,yb,w,h)
+{this.mkDiv(xr+cx,yt+cy,w,h);this.mkDiv(xr+cx,yb+cy,w,h);this.mkDiv(xl+cx,yb+cy,w,h);this.mkDiv(xl+cx,yt+cy,w,h);};this.setStroke(1);this.setFont('verdana,geneva,helvetica,sans-serif',String.fromCharCode(0x31,0x32,0x70,0x78),Font.PLAIN);this.color='#000000';this.htm='';this.wnd=wnd||window;if(!(jg_ie||jg_dom||jg_ihtm))chkDHTM();if(typeof id!='string'||!id)this.paint=pntDoc;else
+{this.cnv=document.all?(this.wnd.document.all[id]||null):document.getElementById?(this.wnd.document.getElementById(id)||null):null;this.defhtm=(this.cnv&&this.cnv.innerHTML)?this.cnv.innerHTML:'';this.paint=jg_dom?pntCnvDom:jg_ie?pntCnvIe:jg_ihtm?pntCnvIhtm:pntCnv;}
+this.setPrintable(false);}
 function integer_compare(x,y)
-        return (x < y) ? -1 : ((x > y)*1);
+{return(x<y)?-1:((x>y)*1);}
\ No newline at end of file
Modified: branches/dev_lenkne/http/php/mod_adminEditFilteredUser.php
--- branches/dev_lenkne/http/php/mod_adminEditFilteredUser.php	2008-08-15 20:58:02 UTC (rev 2836)
+++ branches/dev_lenkne/http/php/mod_adminEditFilteredUser.php	2008-08-15 22:20:09 UTC (rev 2837)
@@ -21,6 +21,7 @@
 require_once(dirname(__FILE__)."/../classes/class_json.php");
 require_once(dirname(__FILE__)."/../classes/class_administration.php");
 require_once(dirname(__FILE__)."/../classes/class_mb_html.php");
+require_once(dirname(__FILE__)."/../classes/class_user.php");
 $e = new mb_notice("locale: " . $_SESSION["mb_locale"] . "; lang: " . $_SESSION["mb_lang"]);
 $e = new mb_notice(setlocale(LC_ALL, $_SESSION["mb_locale"]));
@@ -28,9 +29,10 @@
 $admin = new administration();
 $html = new html();
 $json = new Mapbender_JSON();
+$user = new User();
 $queryObj = $json->decode(stripslashes($_REQUEST['queryObj']));
 $resultObj = array();
-//$e = new mb_exception("command: " . $queryObj->command);
+$e = new mb_exception("command: " . $queryObj->command);
 function sendOutput($out){
     global $json;
@@ -75,7 +77,7 @@
 case "searchUsers":
-	$searchResults = $admin->getSearchResults($_SESSION["mb_user_id"], $queryObj->parameters->searchText);
+	$searchResults = $user->getSearchResults($_SESSION["mb_user_id"], $queryObj->parameters->searchText);
 	if ($searchResults) {
 		$resultObj["success"] = true;
@@ -84,7 +86,8 @@
 	else {
 		$resultObj["success"] = false;
-		$resultObj["message"] = _mb("No matches found.");
+		$resultObj["data"] = "'" . _mb("No matches found.") . "'";
+		$resultObj["command"] = "noMatchFound";
 break;
@@ -98,40 +101,15 @@
 		$resultObj["message"] = _mb("Username must be unique. Select a different name.");
 	else{
-		$tableColumns = $admin->getTableColumns(mb_user,mb_user_id,$queryObj->parameters->mb_user_id);
-		$parameters = array();
+		$parameters = array(); //Takes form fields and puts them into an array
 		foreach ($queryObj->parameters as $keyq => $valueq) {
 			$parameters[$keyq] = $valueq;
+		$tableColumns = $admin->getTableColumns(mb_user); //Retrives column name and type from DB
+		$updateArray = array_merge_recursive($tableColumns, array_intersect_key($parameters, $tableColumns)); //Removes from fields not in DB
+		$res = $user->updateUser($updateArray); //Update the DB
-		$sqlArray = array_merge_recursive($tableColumns, array_intersect_key($parameters, $tableColumns));
-		$res = "";
-		$sql = "UPDATE mb_user SET ";
-		$i = 0;
-		foreach ($sqlArray as $key => $value) {
-			if ($value[1]) {
-				if (($i+1) == 1) {
-					$sql.= $key . "=$" . ($i+1);
-				else {
-					$sql.= "," . $key . "=$" . ($i+1);
-			$t[$i] = $value[0];
-			if ($key == "mb_user_password") { // for password
-				$v[$i] = md5($value[1]);
-			else {
-				$v[$i] = $value[1];
-			$i++;
-		$sql.= " WHERE mb_user_id = $1";
-		$res = db_prep_query($sql,$v,$t);
 		if ($res) {
 			$resultObj["data"] = $admin->getAllUserColumns($queryObj->parameters->mb_user_id);
@@ -154,54 +132,15 @@
 		$resultObj["message"] = "Username must be unique. Select a different name.";
 	else{
+		$insertArray = array_merge_recursive($tableColumns, array_intersect_key($parameters, $tableColumns));
+		$res = $user->insertUser($insertArray); //Insert user in the DB
-		$res = "";
-		$sql = "INSERT INTO mb_user (";
-		$i = 0;
-		foreach ($sqlArray as $key => $value) { //Adds the field names, $v & $t
-			if ($value[1]) {
-					$sql.= $key;
-				else {
-					$sql.= "," . $key;
-			else {
-			$i++;
-		$sql.=") VALUES (";
-		$i = 0;
-		foreach ($sqlArray as $key => $value) {  //Adds field values from form
-			if ($value[1]) {
-					$sql.= "$" . ($i+1);
-				else {
-					$sql.= ",$" . ($i+1);
-			$i++;
-		$sql.=")";
 		if ($res) {
@@ -215,13 +154,28 @@
 break;
+case "deleteUserConfirm":
+	$resultObj["success"] = true;
+	$resultObj["message"] = _mb("Delete User?");
+	$optionArray = array();
+	$buttonArray = array();
+	$buttonArray[_mb("Confirm")] = "true";
+	$buttonArray[_mb("Cancel")] = "false";
+	$resultObj["button"] = $buttonArray;
+	$resultObj["callback"] = "deleteUser";
+break;
 case "deleteUser":
 	$result = $admin->deleteTableRecord(mb_user,mb_user_id,($queryObj->parameters->mb_user_id));
 	if ($result == true) {
 		$resultObj["data"] = $result;
-		$resultObj["command"] = "refreshUser";
+		$resultObj["command"] = "clearUser";
 		$resultObj["message"] = _mb("User Deleted.");
 	else {
@@ -237,21 +191,21 @@
 $html->begintag("div","main");
 	$html->beginEndTag("h2","",_mb('Create or edit user'));
+echo "<script  type='text/javascript' src='../php/validate.js'></script>";
 	$html->beginForm("user","post");
 		$html->beginTag("fieldset");
 			$html->beginTag("p");
 				$html->createInput("button","insert",_mb('Create')," onclick='insertUser(\"mod_adminEditFilteredUser\")'");
 				$html->createInput("button","update",_mb('Update')," onclick='updateUser(\"mod_adminEditFilteredUser\")'");
-				$html->createInput("button","delete",_mb('Delete')," onclick='deleteUser(\"mod_adminEditFilteredUser\");loadAction(\"mod_adminEditFilteredUser\",this);showFilteredUsers(\"mod_adminEditFilteredUser\")'");
-				$html->createInput("button","cancel",_mb('Cancel')," onclick='loadAction(\"mod_adminEditFilteredUser\",this);showFilteredUsers(\"mod_adminEditFilteredUser\")'");
+				$html->createInput("button","delete",_mb('Delete')," onclick='deleteUserConfirm();'");
+				$html->createInput("button","cancel",_mb('Cancel')," onclick='clearUser()'");
 			$html->endTag("p");
 		$html->endTag("Fieldset");
-				$html->createLabel("mb_user_id",_mb('User ID:'));
-				$html->createInput("text","mb_user_id","","disabled='disabled'");
-			$html->endTag("p");
-			$html->beginTag("p");
 				$html->createLabel("mb_user_name",_mb('Name:'));
 				$html->createInput("text","mb_user_name");
 			$html->endTag("p");
@@ -263,12 +217,12 @@
 				$html->createLabel("mb_user_password",_mb('Password:'));
 				$html->createInput("password","mb_user_password");
 			$html->endTag("p");
-		$html->endTag("Fieldset");
-		$html->beginTag("fieldset","details","style=\"visibility:hidden\"");
 				$html->createLabel("mb_user_email",_mb('E-mail:'));
-				$html->createInput("text","mb_user_email");
+				$html->createInput("text","mb_user_email","","class='required email'");
 			$html->endTag("p");
+		$html->endTag("Fieldset");
+		$html->beginTag("fieldset","details","style=\"visibility:hidden\"");
 				$html->createLabel("mb_user_phone",_mb('Telephone:'));
 				$html->createInput("text","mb_user_phone");
@@ -323,8 +277,12 @@
 			$html->endTag("p");
 				$html->createLabel("mb_user_owner",_mb('Owner:'));
-				$html->createInput("text","mb_user_owner","31");
+				$html->createInput("text","mb_user_owner","69");
 			$html->endTag("p");
+			$html->beginTag("p");
+				$html->createLabel("mb_user_id",_mb('User ID:'));
+				$html->createInput("text","mb_user_id","","disabled='disabled'");
+			$html->endTag("p");
 	$html->endTag("form");
 $html->endtag("div");
Modified: branches/dev_lenkne/http/php/mod_adminFrame.php
--- branches/dev_lenkne/http/php/mod_adminFrame.php	2008-08-15 20:58:02 UTC (rev 2836)
+++ branches/dev_lenkne/http/php/mod_adminFrame.php	2008-08-15 22:20:09 UTC (rev 2837)
@@ -1,5 +1,7 @@
 <?php
 require_once(dirname(__FILE__)."/../../lib/mb_admin_functions.js");
-// require_once(dirname(__FILE__)."/../extensions/ui.core.js");
+//require_once(dirname(__FILE__)."/../extensions/jquery-1.2.6.pack.js");
+require_once(dirname(__FILE__)."/../extensions/jquery-impromptu.1.5.js");
+//require_once(dirname(__FILE__)."/../extensions/jquery.validate.js");
 // require_once(dirname(__FILE__)."/../extensions/ui.accordion.js");
Modified: branches/dev_lenkne/lib/mb_admin_functions.js
--- branches/dev_lenkne/lib/mb_admin_functions.js	2008-08-15 20:58:02 UTC (rev 2836)
+++ branches/dev_lenkne/lib/mb_admin_functions.js	2008-08-15 22:20:09 UTC (rev 2837)
@@ -116,12 +116,13 @@
 	fullscreenProgressIndicator.style.lineHeight      = (window.innerHeight - fullscreenProgressIndicatorImage.height) + 'px';
 	fullscreenProgressIndicator.style.textAlign       = 'center';
 	fullscreenProgressIndicator.style.backgroundColor = '#666';
-	fullscreenProgressIndicator.style.opacity         = '.75';
+	fullscreenProgressIndicator.style.opacity         = '.50';
 function showFullscreenProgressIndicator() {
-	fullscreenProgressIndicator.style.visibility = 'visible';
-	fullscreenProgressIndicator.style.display    = 'block';
+//	fullscreenProgressIndicator.style.visibility = 'visible';
+//	fullscreenProgressIndicator.style.display    = 'block';
+	$("div").show("slow");
 function hideFullscreenProgressIndicator() {
@@ -139,7 +140,6 @@
 	mb_localizeDiv();
-//TODO This needs to be replaced with GETTEXT
 function updateDivTitle(obj){
 	showFullscreenProgressIndicator();
 	var locArray= document.getElementsByTagName("li");
@@ -175,26 +175,32 @@
-//TODO This should go to class
 function processAjax(result) {
 	var resultObj = eval("(" + result + ")");
-	if (resultObj.success == true) {
+	if (resultObj) {
 		data = eval(resultObj.data);
-		command = eval(resultObj.command);
-		command(data);
-		if (resultObj.message) {
-			alert(resultObj.message);
+		if (resultObj.command) {
+			command = eval(resultObj.command);
+			command(data);
-	else if (resultObj.success == false) {
+			button = eval(resultObj.button);
+			callbackFunction = eval(resultObj.callback);
+			$.prompt(resultObj.message, {buttons: button,
+							callback: callbackFunction});
+//	else if (resultObj.success == false) {
+//		if (resultObj.message) {
+////			alert(resultObj.message);
+//			$.prompt(resultObj.message,{ buttons: { Ok: true} });
 	else {
 		alert("Error.");
 function showUser(module, mb_user_id) {
 	var queryObj = {module: module,
@@ -228,6 +234,11 @@
 	hideFullscreenProgressIndicator();
+function clearUser() {
+	user.reset();
+	showFilteredUsers('mod_adminEditFilteredUser');
 function showFilteredUsers(module) {
@@ -265,6 +276,10 @@
+function noMatchFound(resultObj) {
+	document.getElementById("usersList").innerHTML=resultObj;
 function refreshFilteredUsers(resultObj) {
 	var user = '<h3 id="userListHeading">All users</h3>';
@@ -278,7 +293,6 @@
 	document.getElementById("usersList").innerHTML=user;
 function updateUser(module) {
@@ -335,19 +349,13 @@
-//TODO put YES/NO to make sure they really want to delete user
-function deleteUser(module) {
+function deleteUserConfirm() {
-	var queryObj = {module: module,
-			command: "deleteUser",
-			parameters:{
-				mb_user_id: document.getElementById('mb_user_id').value
-//			mb_user_id: document.getElementById('mb_user_id').value
+	var queryObj = {module: "mod_adminEditFilteredUser",
+			command: "deleteUserConfirm",
-	$.post('../php/' + module + '.php',{queryObj: $.toJSON(queryObj)}, function(result, status) {
+	$.post('../php/mod_adminEditFilteredUser.php',{queryObj: $.toJSON(queryObj)}, function(result, status) {
   		if (result && status == "success") {
 			processAjax(result);
@@ -358,3 +366,25 @@
+function deleteUser(confirm) {
+	if (confirm == "true") {
+		showFullscreenProgressIndicator();
+				command: "deleteUser",
+				parameters:{
+					mb_user_id: document.getElementById('mb_user_id').value
+	  		if (result && status == "success") {
+				processAjax(result);
+			else {
+				alert("Error.");
+		hideFullscreenProgressIndicator();
Added: branches/dev_lenkne/resources/locale/de_DE/LC_MESSAGES/Mapbender.mo
(Binary files differ)
Property changes on: branches/dev_lenkne/resources/locale/de_DE/LC_MESSAGES/Mapbender.mo
___________________________________________________________________
   + application/octet-stream
More information about the Mapbender_commits mailing list
