[Mapbender-commits] r2838 - branches/2.5/http/print
svn_mapbender at osgeo.org
Mon Aug 18 03:11:32 EDT 2008
Author: tbaschetti
Date: 2008-08-18 03:11:32 -0400 (Mon, 18 Aug 2008)
New Revision: 2838
branches/2.5/http/print/mod_printPDF.php
reapplied fix for http://trac.osgeo.org/mapbender/ticket/205
Modified: branches/2.5/http/print/mod_printPDF.php
--- branches/2.5/http/print/mod_printPDF.php 2008-08-15 22:20:09 UTC (rev 2837)
+++ branches/2.5/http/print/mod_printPDF.php 2008-08-18 07:11:32 UTC (rev 2838)
@@ -1,7 +1,7 @@
<?php
# $Id: mod_printPDF.php
# http://www.mapbender.org/index.php/mod_printPDF.php
-# Copyright (C) 2002 CCGIS
+# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
@@ -73,34 +73,34 @@
document.forms[0].wms_id.value = "";
document.forms[0].wms_title.value = "";
document.forms[0].legendurl.value = "";
for(var i=0; i<pt.mb_mapObj[ind].wms.length; i++){
layers = pt.mb_mapObj[ind].wms[i].getLayers(pt.mb_mapObj[ind]);
if(layers != "" && layers){
if(i>0 && document.forms[0].wms_id.value!=''){
document.forms[0].layers.value += "___";
document.forms[0].wms_id.value += "___";
document.forms[0].wms_title.value += "___";
document.forms[0].legendurl.value += "___";
- document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
+ document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
- for(var j=0; j<layers.length; j++){
+ for(var j=0; j<layers.length; j++){
var layer = layers[j];
var title = pt.mb_mapObj[ind].wms[i].getTitleByLayerName(layers[j]);
var layerStyle = pt.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layers[j]);
if(layerStyle==false){
- var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],"default");
+ var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],"default");
else{
var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],layerStyle);
//---------- legendurl ----------
- tmp_name = "";
+ tmp_name = "";
if(j>0){
document.forms[0].layers.value += ",";
@@ -112,8 +112,8 @@
document.forms[0].legendurl.value += temp_legendurl;
}else{
document.forms[0].legendurl.value +='0';
else{
@@ -122,33 +122,33 @@
document.forms[0].layers.value += "0";
document.forms[0].wms_id.value += "0";
document.forms[0].wms_title.value += "0";
document.forms[0].legendurl.value += "0";
}//for
- //alert(document.forms[0].layers.value+"---"+document.forms[0].wms_id.value+"---"+document.forms[0].wms_title.value+"---"+document.forms[0].legendurl.value);
+ //alert(document.forms[0].layers.value+"---"+document.forms[0].wms_id.value+"---"+document.forms[0].wms_title.value+"---"+document.forms[0].legendurl.value);
function validate(){
size = document.getElementById('size').options[document.getElementById('size').selectedIndex].value;
format = document.getElementById('format').options[document.getElementById('format').selectedIndex].value;
if(size != "" && format != ""){
var ind = pt.getMapObjIndexByName(target);
var coord = pt.mb_mapObj[ind].extent.split(",");
var centerX = parseFloat(coord[0]) + (parseFloat(coord[2]) - parseFloat(coord[0]))/2
var centerY = parseFloat(coord[1]) + (parseFloat(coord[3]) - parseFloat(coord[1]))/2
if(size == "A4" && format == "portrait"){
- map_width = <?php echo $a4p_map_width; ?>;
- map_height = <?php echo $a4p_map_height; ?>;
+ map_width = <?php echo $a4p_map_width; ?>;
+ map_height = <?php echo $a4p_map_height; ?>;
if(size == "A4" && format == "landscape"){
map_width = <?php echo $a4l_map_width; ?>;
- map_height = <?php echo $a4l_map_height; ?>;
+ map_height = <?php echo $a4l_map_height; ?>;
if(size == "A3" && format == "portrait"){
map_width = <?php echo $a3p_map_width; ?>;
@@ -157,7 +157,7 @@
if(size == "A3" && format == "landscape"){
map_width = <?php echo $a3l_map_width; ?>;
map_height = <?php echo $a3l_map_height; ?>;
if(size == "A2" && format == "portrait"){
map_width = <?php echo $a2p_map_width; ?>;
map_height = <?php echo $a2p_map_height; ?>;
@@ -181,8 +181,9 @@
if(size == "A0" && format == "landscape"){
map_width = <?php echo $a0l_map_width; ?>;
map_height = <?php echo $a0l_map_height; ?>;
var pos = pt.makeClickPos2RealWorldPos(target, map_width , map_height);
+ var prevscale= pt.mb_getScale(target);
pt.mb_mapObj[ind].extent = coord[0] + "," + pos[1] + "," + pos[0] + "," + coord[3];
pt.mb_mapObj[ind].width = Math.round(map_width);
@@ -192,20 +193,20 @@
pt.window.frames[target].document.getElementById("maps").style.width = Math.round(map_width);
pt.window.frames[target].document.getElementById("maps").style.height = Math.round(map_height);
- //pt.setMapRequest(target);
- pt.mb_repaintScale(target, null, null, pt.mb_getScale(target));
+ //pt.setMapRequest(target);
+ pt.mb_repaintScale(target, null, null, prevscale);
document.form1.map_url.value = '';
if(pt.mb_mapObj[ind].wms[i].gui_wms_visible > 0){
- if(pt.mb_mapObj[ind].wms[i].mapURL != false && pt.mb_mapObj[ind].wms[i].mapURL != 'false' && pt.mb_mapObj[ind].wms[i].mapURL != ''){
+ if(pt.mb_mapObj[ind].wms[i].mapURL != false && pt.mb_mapObj[ind].wms[i].mapURL != 'false' && pt.mb_mapObj[ind].wms[i].mapURL != ''){
if(document.form1.map_url.value != ""){
document.form1.map_url.value += "___";
document.form1.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
//overview_url
var ind_overview = pt.getMapObjIndexByName('overview');
@@ -224,7 +225,7 @@
if(f.map_url.value != ""){
f.map_url.value += "___";
f.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
@@ -247,9 +248,9 @@
}else{
document.form1.mylegend.value = 'true';
// write the measured coordinates
if (pt.mod_measure_RX != undefined && pt.mod_measure_RY != undefined) {
var tmp_x = '';
var tmp_y = '';
@@ -268,7 +269,7 @@
document.forms['form1'].elements['measured_x_values'].value = tmp_x;
document.forms['form1'].elements['measured_y_values'].value = tmp_y;
document.form1.submit();
else{
@@ -289,7 +290,7 @@
<body>
<form name="form1" method="post" action="../print/mod_printPDF_pdf.php?<?php echo SID; ?>" target="_blank">
<p id="container_size">
- <label for="size"><?php echo $label_format ?></label>
+ <label for="size"><?php echo $label_format ?></label>
<select id="size" name="size" onchange="validate();">
<option value="false">-</option>
<?php
@@ -303,7 +304,7 @@
</p>
<p id="container_orientation">
- <label for="format"><?php echo $label_orientation; ?></label>
+ <label for="format"><?php echo $label_orientation; ?></label>
<select id="format" name="format" onchange="validate();">
<option value="portrait"><?php echo $label_portrait; ?></option>
<option value="landscape"><?php echo $label_landscape; ?></option>
@@ -312,7 +313,7 @@
<?php if($highquality === TRUE): ?>
<p id="container_quality">
- <label for="quality"><?php echo $label_quality; ?></label>
+ <label for="quality"><?php echo $label_quality; ?></label>
<input type="radio" id="quality" name="quality" value="1" checked="checked" /> <?php echo $label_72dpi; ?>
<input type="radio" id="quality" name="quality" value="2" /> <?php echo $label_288dpi; ?>
</p>
@@ -330,19 +331,19 @@
$html .= sprintf("<label for=\"c%s\">%s%s</label> ",$i,${"label_comment".$i},$label_hint);
$html .= sprintf("<textarea id=\"c%s\" name=\"c%s\" cols=\"20\" rows=\"2\"%s></textarea> ",$i,$i,$javascript);
$html .= "</p>";
echo $html;
<?php if($legend === TRUE): ?>
<p id="container_legend">
- <label for="mylegendcheckbox"><?php echo $label_legend; ?></label>
+ <label for="mylegendcheckbox"><?php echo $label_legend; ?></label>
<input type="checkbox" id="mylegendcheckbox" name="mylegendcheckbox" value="false" />
</p>
<?php else: ?>
<input type="hidden" name="mylegendcheckbox" value="false" />
-<?php endif; ?>
+<?php endif; ?>
<input type="hidden" name="map_url" />
<input type="hidden" name="overview_url" />
More information about the Mapbender_commits
