[Mapbender-commits] r2853 - branches/nimix_dev/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 18 10:34:12 EDT 2008
Author: nimix
Date: 2008-08-18 10:34:12 -0400 (Mon, 18 Aug 2008)
New Revision: 2853
Added:
   branches/nimix_dev/http/javascripts/mod_loadwmc.js
   branches/nimix_dev/http/javascripts/mod_loadwmc_list.php
   branches/nimix_dev/http/javascripts/mod_displayWmc.php
   branches/nimix_dev/http/javascripts/mod_initWmc.php
   branches/nimix_dev/http/javascripts/mod_loadwmc.php
   branches/nimix_dev/http/javascripts/mod_measure.php
merge
Modified: branches/nimix_dev/http/javascripts/mod_displayWmc.php
--- branches/nimix_dev/http/javascripts/mod_displayWmc.php	2008-08-18 14:32:27 UTC (rev 2852)
+++ branches/nimix_dev/http/javascripts/mod_displayWmc.php	2008-08-18 14:34:12 UTC (rev 2853)
@@ -22,9 +22,9 @@
 $wmc_id = $_GET["wmc_id"];
 if ($wmc_id){
-	require_once(dirname(__FILE__)."/../classes/class_administration.php");
-	$admin = new administration();
-	$wmc_gml = $admin->getWmcById($wmc_id);
+	require_once(dirname(__FILE__)."/../classes/class_wmc.php");
+	$wmc = new wmc();
+	$wmc_gml = $wmc->getDocument($wmc_id);
 	if ($wmc_gml){
 		//Display WMC
Modified: branches/nimix_dev/http/javascripts/mod_initWmc.php
--- branches/nimix_dev/http/javascripts/mod_initWmc.php	2008-08-18 14:32:27 UTC (rev 2852)
+++ branches/nimix_dev/http/javascripts/mod_initWmc.php	2008-08-18 14:34:12 UTC (rev 2853)
@@ -68,7 +68,7 @@
 			echo "var wmc_id = false;";
 			echo "wmc_id = '".$wmc_id."';";
 			$wmc = new wmc();
-			$wmc->createObjFromWMC_id($wmc_id);
+			$wmc->createFromDb($wmc_id);
 			$js_wmc .= $wmc->createJsObjFromWMC("", $e_target[0], $action);
 			if (!empty($x) && !empty($y) && !empty($icon)) {
Copied: branches/nimix_dev/http/javascripts/mod_loadwmc.js (from rev 2653, trunk/mapbender/http/javascripts/mod_loadwmc.js)
--- branches/nimix_dev/http/javascripts/mod_loadwmc.js	                        (rev 0)
+++ branches/nimix_dev/http/javascripts/mod_loadwmc.js	2008-08-18 14:34:12 UTC (rev 2853)
@@ -0,0 +1,284 @@
+// checks if element var loadFromSession exists
+try {
+	if (loadFromSession) {
+catch(e) {
+	loadFromSession = 0;
+if (loadFromSession) {
+	// function load_wmc_session() is generated by mod_loadwmc.php
+	mb_registerInitFunctions('load_wmc_session()');
+var wmcPopup = null;
+var wmcDisplayPopup = null;
+var serverSideFileName = "../php/mod_loadwmc_server.php";
+function mod_importWmc(id){
+	alert(id);
+ * is called when the load WMC button is pressed
+function mod_loadwmc(){
+	var initialHtml = "<div>" +
+					"<h2 style='font-family: Arial, Helvetica, sans-serif; color: #808080;'><font align='left' color='#000000'>load WMC from list</font></h2>" +
+					"<table id='loadwmc_list' width='90%' style='font-family: Arial, Helvetica, sans-serif;font-size : 12px;color: #808080;' border='1' cellpadding='3' rules='rows'>" +
+						"<tr style='background-color:#F0F0F0;' width='80px'>" +
+							"<td><b>WMC name</b></td>" +
+							"<td><b>last update</b></td>" +
+							"<td colspan=5></td>" +
+						"</tr>" +
+					"</table>" +
+				"</div>";
+	// creates a new pop up (if it doesn't already exist)
+	// the pop up allows you to load, append, merge,
+	// display and delete WMC documents
+	if (wmcPopup === null) {
+		wmcPopup = new mb_popup({
+			title:"Load WMC",
+			width:500,
+			height:600,
+			top:100,
+			left:100,
+			html:initialHtml
+	// display the pop up
+	if (!wmcPopup.isVisible()) {
+		wmcPopup.setHtml(initialHtml);
+		wmcPopup.show();
+	// get WMC data from server
+	var queryObj = {command:"getWmc"};
+	$.post(serverSideFileName, {queryObj:$.toJSON(queryObj)}, function(json, status) {
+		var loadWmcDataError = false;
+		if (json && status == "success") {
+			loadWmcDataError = displayWmcList(json, status);
+		if (loadWmcDataError) {
+			alert("An error has occured. WMC list could not be loaded.");
+ * Displays available WMC documents
+function displayWmcList (json, status) {
+	var wmcObj = eval("(" + json + ")");
+	// for each wmc, add a row to the table
+	for (var i=0; i < wmcObj.wmc.length; i++) {
+		(function () {
+			var currentId = wmcObj.wmc[i].id;
+			var $tr = $("<tr onmouseover='this.style.backgroundColor = \"#F08080\"' onmouseout='this.style.backgroundColor = \"#ffffff\"'></tr>").appendTo($("#loadwmc_list"));
+			$tr.hide();
+			var $td;
+			$tr.append($("<td>" + wmcObj.wmc[i].title + "</td>"));
+			$tr.append($("<td>" + wmcObj.wmc[i].timestamp + "</td>"));
+			// Load WMC
+			$loadWmc = $("<img src='../img/button_gray/wmc_load.png' title='load this WMC'>");
+			$loadWmc.click(function() {
+				var queryObj = {command:"loadWmc", parameters:{id:currentId}};
+				$.post(serverSideFileName, {queryObj: $.toJSON(queryObj)}, function (json, status) {
+					var loadWmcError = false;
+						var resultObj = eval("(" + json + ")");
+						try {
+							if (resultObj.javascript && typeof(resultObj.javascript) == "object") {
+								for (var j=0; j < resultObj.javascript.length; j++) {
+//									console.log("Statement: %s", resultObj.javascript[j]);
+									eval(resultObj.javascript[j]);
+						catch (e) {
+							alert(e);
+							loadWmcError = true;
+					if (loadWmcError) {
+						alert("An error has occured while loading this WMC.");
+					else {
+						// close the Pop up
+						if (wmcDisplayPopup !== null && wmcDisplayPopup.isVisible()) {
+							wmcDisplayPopup.hide();
+						wmcPopup.hide();
+						alert("WMC has been loaded successfully.");
+			$td = $("<td></td>").append($loadWmc);
+			$tr.append($td);
+			// Merge WMC
+			$mergeWmc = $("<img src='../img/button_gray/wmc_merge.png' title='merge WMC'>");
+			$mergeWmc.click(function() {
+				var	extensionDataString = null;
+				if (currentWmcExtensionData !== null) {
+					extensionDataString = currentWmcExtensionData;
+				var queryObj = {
+					command:"mergeWmc",
+					parameters:{
+						id:currentId,
+						extensionData:extensionDataString,
+						mapObject:mb_mapObj,
+						generalTitle:"currentState"
+						try {
+						catch (e) {
+							alert(e);
+					else {
+						wmcPopup.hide();
+			$td = $("<td></td>").append($mergeWmc);
+			$tr.append($td);
+			// Append WMC
+			$appendWmc = $("<img src='../img/button_gray/wmc_append.png' title='append WMC'>");
+			$appendWmc.click(function() {
+				var queryObj = {
+					command:"appendWmc",
+					parameters:{
+						id:currentId,
+						try {
+						catch (e) {
+							alert(e);
+					else {
+						wmcPopup.hide();
+			$td = $("<td></td>").append($appendWmc);
+			$tr.append($td);
+			// Display WMC
+			$displayWmc = $("<img src='../img/button_gray/wmc_xml.png' title='display WMC XML'>");
+			$displayWmc.click(function() {
+				// create Popup
+				if (wmcDisplayPopup === null) {
+					wmcDisplayPopup = new mb_popup({
+						title:"WMC Document",
+						width:600,
+						height:500,
+						top:100,
+						left:300,
+						url:"../javascripts/mod_displayWmc.php?wmc_id=" + currentId
+				// set correct URL
+				if (wmcDisplayPopup.isVisible()) {
+					wmcDisplayPopup.setUrl("../javascripts/mod_displayWmc.php?wmc_id=" + currentId);
+				wmcDisplayPopup.show();
+			$td = $("<td></td>").append($displayWmc);
+			$tr.append($td);
+			$deleteWmc = $("<img src='../img/button_gray/del.png' title='delete this WMC'>");
+			$deleteWmc.click(function() {
+				var queryObj = {command:"deleteWmc", parameters:{id:currentId}};
+					var deleteWmcError = false;
+						try {
+							if (resultObj.success) {
+								$tr.remove();
+						catch (e) {
+							deleteWmcError = true;
+					if (deleteWmcError) {
+						alert("An error has occured while deleting this WMC.");
+			$td = $("<td></td>").append($deleteWmc);
+			$tr.append($td);
+			$tr.fadeIn("slow");
\ No newline at end of file
Modified: branches/nimix_dev/http/javascripts/mod_loadwmc.php
--- branches/nimix_dev/http/javascripts/mod_loadwmc.php	2008-08-18 14:32:27 UTC (rev 2852)
+++ branches/nimix_dev/http/javascripts/mod_loadwmc.php	2008-08-18 14:34:12 UTC (rev 2853)
@@ -22,8 +22,6 @@
 include(dirname(__FILE__) . "/../include/dyn_js.php");
-echo "mod_loadwmc_target = '".$e_target[0]."';";
 // this may be added at a later stage
 if ($new_wmc == 1) {
@@ -46,53 +44,50 @@
-function load_wmc_session() {
-	<?php
-		if (isset($_SESSION['mb_wmc'])) {
-			$wmc = new wmc();
-			if ($wmc->createObjFromWMC_xml($_SESSION['mb_wmc'])) {
-				$js = "";
-				if ($_SESSION['layer_preview']) {
-//					echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: layer preview');";
-					$js = $wmc->createJsObjFromWMC("", $e_target, "load");
-				else if ($startup == true) {
-//					echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: load new wmc');";
-					$js = $wmc->createJsObjFromWMC("", $e_target, "merge");
-					$startup = false;
-				else {
-//					echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: load old wmc');";
-				echo $js;
-			else {
-				echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: error parsing wmc');";
-		else {
-			echo "var e = new Mb_warning('mod_loadwmc: load_wmc_session: no wmc set!');";
+// Creates the function load_wmc_session.
+// This function loads a WMC from the session, if the element var
+// "loadFromSession" is set to true.
+echo "function load_wmc_session() {";
+if (isset($_SESSION['mb_wmc'])) {
+	$wmc = new wmc();
+	if ($wmc->createFromXml($_SESSION['mb_wmc'])) {
+		$jsArray = array();
+//		if ($_SESSION['layer_preview']) {
+//			$js = $wmc->createJsObjFromWMC("", $e_target, "load");
+//		else if ($startup == true) {
+//			$js = $wmc->createJsObjFromWMC("", $e_target, "merge");
+//			$startup = false;
+//		else {
+			$jsArray = $wmc->toJavaScript();
+		echo implode("", $jsArray);
+		// test wmc from app
+		$newWmc = new wmc();
+		$newWmc->createFromApplication($_SESSION["mb_user_gui"]);
+	else {
+		echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: error parsing wmc');";
+else {
+	echo "var e = new Mb_warning('mod_loadwmc: load_wmc_session: no wmc set!');";
+echo "}";
-try {if (loadFromSession) {}}catch(e) {loadFromSession = 0;}
-if (loadFromSession) {
-	mb_registerInitFunctions('load_wmc_session()');
+echo "var mod_loadwmc_img = new Image(); mod_loadwmc_img.src = '" . $e_src . "';";
-var mod_loadwmc_img = new Image(); mod_loadwmc_img.src = "<?php echo $e_src; ?>";
-//var mod_loadwmc_img_over = new Image(); mod_loadwmc_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
-function mod_importWmc(id){
-	alert(id);
-function mod_loadwmc(obj){
-	windowWmc = window.open("../php/mb_listWMCs.php?<?php echo SID;?>","displayWmc","width=500, height=600, scrollbars=yes, dependent=yes");
-function mod_loadwmc_init(obj){
-	//document.getElementById("loadwmc").src = mod_zoom1_img_over.src;
+// Creates a pop up with a dialogue to load, view or delete WMC documents
+include("mod_loadwmc.js");
Copied: branches/nimix_dev/http/javascripts/mod_loadwmc_list.php (from rev 2653, trunk/mapbender/http/javascripts/mod_loadwmc_list.php)
--- branches/nimix_dev/http/javascripts/mod_loadwmc_list.php	                        (rev 0)
+++ branches/nimix_dev/http/javascripts/mod_loadwmc_list.php	2008-08-18 14:34:12 UTC (rev 2853)
@@ -0,0 +1,3 @@
+<?php
+	echo "fisch";
Modified: branches/nimix_dev/http/javascripts/mod_measure.php
--- branches/nimix_dev/http/javascripts/mod_measure.php	2008-08-18 14:32:27 UTC (rev 2852)
+++ branches/nimix_dev/http/javascripts/mod_measure.php	2008-08-18 14:34:12 UTC (rev 2853)
@@ -143,10 +143,10 @@
 function drawDashedLine(){
 	//check if epsg has changed
 	var ind = getMapObjIndexByName(mod_measure_target);
+	mod_measure_width = mb_mapObj[ind].width;
+	mod_measure_height = mb_mapObj[ind].height;
 	if(mod_measure_epsg != mb_mapObj[ind].epsg){
 		mod_measure_delete();
-		mod_measure_width = mb_mapObj[ind].width;
-		mod_measure_height = mb_mapObj[ind].height;
 		mod_measure_epsg = mb_mapObj[ind].epsg;
 	var str_mPoints = "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='"+mod_measure_width+"' height='0'></div>";
More information about the Mapbender_commits mailing list
