[Mapbender-commits] r2854 - branches/nimix_dev/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 18 10:37:20 EDT 2008
Author: nimix
Date: 2008-08-18 10:37:20 -0400 (Mon, 18 Aug 2008)
New Revision: 2854
Added:
   branches/nimix_dev/http/javascripts/mod_openlayers_layerSwitch.js
   branches/nimix_dev/http/javascripts/mod_openlayers.php
   branches/nimix_dev/http/javascripts/mod_pan.php
   branches/nimix_dev/http/javascripts/mod_perimeter.php
   branches/nimix_dev/http/javascripts/mod_sandclock.php
   branches/nimix_dev/http/javascripts/mod_sandclock2.php
   branches/nimix_dev/http/javascripts/mod_savewmc.php
merge
Modified: branches/nimix_dev/http/javascripts/mod_openlayers.php
--- branches/nimix_dev/http/javascripts/mod_openlayers.php	2008-08-18 14:34:12 UTC (rev 2853)
+++ branches/nimix_dev/http/javascripts/mod_openlayers.php	2008-08-18 14:37:20 UTC (rev 2854)
@@ -31,11 +31,6 @@
                     units: "degrees"
-eventInit.register(function (){
-	OpenLayers.ImgPath = "../img/openlayers/";
-            var ol_map = new OpenLayers.Map('<?php echo $e_id;?>', {'maxResolution': 1.40625/2});
 //            var ol_wms = new OpenLayers.Layer.WMS( "Germany",
 //              "http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&", {layers: 'Germany,Topographie,Grenze,Bundeslaender,Staedte,Postleitzahlbereiche,Bahnlinien,Fluesse,Strassen,Staedtepunkte,Postleitzahlbereichname,Staedtenamen,Bundeslaendernamen', format: 'image/png' } );
@@ -61,11 +56,12 @@
 //var wms_407 = new OpenLayers.Layer.WMS('Mapbender User','http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/mapbender_user/mapbender_user.map&',{layers:'Mapbender,Mapbender_User,Mapbender_Names', transparent: 'true',format: 'image/png'});
 //wms_407.setVisibility(false);
-//ol_map.addLayers([wms_407,wms_893]);
-	<?php
-	include(dirname(__FILE__)."/../php/mod_createOlObjFromDB.php");
-	ol_map.addControl(new OpenLayers.Control.LayerSwitcher());
+var ol_map;
+OpenLayers.ImgPath = "../img/openlayers/";
+ol_map = new OpenLayers.Map('<?php echo $e_id;?>', {'maxResolution': 1.40625/2});
+eventAfterInit.register(function () {
 	ol_map.zoomToMaxExtent();
\ No newline at end of file
Copied: branches/nimix_dev/http/javascripts/mod_openlayers_layerSwitch.js (from rev 2653, trunk/mapbender/http/javascripts/mod_openlayers_layerSwitch.js)
--- branches/nimix_dev/http/javascripts/mod_openlayers_layerSwitch.js	                        (rev 0)
+++ branches/nimix_dev/http/javascripts/mod_openlayers_layerSwitch.js	2008-08-18 14:37:20 UTC (rev 2854)
@@ -0,0 +1 @@
+ol_map.addControl(new OpenLayers.Control.LayerSwitcher());
Modified: branches/nimix_dev/http/javascripts/mod_pan.php
--- branches/nimix_dev/http/javascripts/mod_pan.php	2008-08-18 14:34:12 UTC (rev 2853)
+++ branches/nimix_dev/http/javascripts/mod_pan.php	2008-08-18 14:37:20 UTC (rev 2854)
@@ -28,6 +28,9 @@
 var mod_pan_img_off = new Image(); mod_pan_img_off.src = "<?php  echo $e_src;  ?>";
 var mod_pan_img_over = new Image(); mod_pan_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
+var mb_panActive = false;
 function init_mod_pan(ind){
 	mb_button[ind] = document.getElementById(mod_pan_elName);
 	mb_button[ind].img_over = mod_pan_img_over.src;
@@ -40,12 +43,18 @@
 	mb_button[ind].stop = new Function ("mod_pan_disable()");
 function mod_pan_click(){
+	var p = window.frames[mod_pan_target].document.getElementById("maps");
+	p.style.cursor = "pointer";
 	var el = window.frames[mod_pan_target].document;
 	el.onmousedown = mod_pan_start;
 	el.onmouseup = mod_pan_stop;
 	el.onmousemove = mod_pan_run;
 function mod_pan_disable(){
+	p.style.cursor = "";
 	el.onmousedown = null;
 	el.onmouseup = null;
Modified: branches/nimix_dev/http/javascripts/mod_perimeter.php
--- branches/nimix_dev/http/javascripts/mod_perimeter.php	2008-08-18 14:34:12 UTC (rev 2853)
+++ branches/nimix_dev/http/javascripts/mod_perimeter.php	2008-08-18 14:37:20 UTC (rev 2854)
@@ -36,6 +36,40 @@
 var mod_perimeter_status = 0;
 var mod_perimeter_img_obj = null;
+function mb_checkTag(frameName, tagName, elementId, appendAtTagName, attributes){
+	var oldElement;
+	var newElement;
+	var prefix;
+	if(frameName && frameName !== ""){
+		prefix = window.frames[frameName].document;
+	else if(!frameName || frameName === ""){
+		prefix = document;
+	oldElement = prefix.getElementById(elementId);
+	if (oldElement === null) {
+		newElement = prefix.createElement(tagName);
+		newElement = prefix.getElementsByTagName(appendAtTagName)[0].appendChild(newElement);
+	else {
+		if (oldElement.nodeName.toLowerCase() == tagName.toLowerCase()) {
+			for (var i=0; i<attributes.length; i++) {
+				oldElement.setAttribute(attributes[i][0], attributes[i][1]);
+			return oldElement;
+		else {
+			return false;
+	var newElementAttributeNode = document.createAttribute("id");
+	newElementAttributeNode.value = elementId;
+	newElement.setAttributeNode(newElementAttributeNode);
+		newElement.setAttribute(attributes[i][0], attributes[i][1]);
+	return newElement;
 function mod_perimeter_checkDefaults(){
 	try{var t = mod_perimeter_thickness;}catch(e){mod_perimeter_thickness = 2;}
 	try{var t = mod_perimeter_color;}catch(e){mod_perimeter_color = '#000000';}
Modified: branches/nimix_dev/http/javascripts/mod_sandclock.php
--- branches/nimix_dev/http/javascripts/mod_sandclock.php	2008-08-18 14:34:12 UTC (rev 2853)
+++ branches/nimix_dev/http/javascripts/mod_sandclock.php	2008-08-18 14:37:20 UTC (rev 2854)
@@ -31,17 +31,27 @@
 var mod_sandclock_img = new Image();
 mod_sandclock_img.src = mod_sandclock_image;
-mb_registerSubFunctions("mod_sandclock(true,myMapId)");
+mb_registerSubFunctions("mod_sandclock(true,myMapIds)");
-function mod_sandclock(start,myMapId){
+function mod_sandclock(start,myMapIds){
 	var ind = getMapObjIndexByName(mod_sandclock_target);
 	if(start){
 		var temp = "<img src='"+mod_sandclock_img.src+"'>";
 		writeTag(mod_sandclock_target, "sandclock", temp);
 		mb_arrangeElement(mod_sandclock_target, "sandclock", (mb_mapObj[ind].width/2 - 16), (mb_mapObj[ind].height/2 - 16));
-	aktiv = setTimeout("mod_sandclock('','"+myMapId+"')",100);
-	if(window.frames[mod_sandclock_target].document.getElementById(myMapId) && window.frames[mod_sandclock_target].document.getElementById(myMapId).complete){
+	aktiv = setTimeout("mod_sandclock('','"+myMapIds+"')",10);
+	var myMapIdArray = myMapIds.split(",");
+	var complete = true;
+	var myMapId;
+	for (var i = 0; i < myMapIdArray.length && complete; i++) {
+		myMapId = myMapIdArray[i];
+		if(window.frames[mod_sandclock_target].document.getElementById(myMapId) &&
+			!window.frames[mod_sandclock_target].document.getElementById(myMapId).complete) {
+			complete = false;
+	if (complete) {
 		clearTimeout(aktiv);
 		writeTag(mod_sandclock_target, "sandclock", "");
Modified: branches/nimix_dev/http/javascripts/mod_sandclock2.php
--- branches/nimix_dev/http/javascripts/mod_sandclock2.php	2008-08-18 14:34:12 UTC (rev 2853)
+++ branches/nimix_dev/http/javascripts/mod_sandclock2.php	2008-08-18 14:37:20 UTC (rev 2854)
@@ -29,7 +29,7 @@
+function mod_sandclock(start){
 	if(start){
 		mod_sandclock_count = mod_sandclock_maxWait;
@@ -44,7 +44,7 @@
 	// check images:
+	aktiv = setTimeout("mod_sandclock(false)",100);
 	mod_sandclock_count -= 1000;
 	var allMaps = window.frames[mod_sandclock_target].document.getElementsByName("mapimage");
Modified: branches/nimix_dev/http/javascripts/mod_savewmc.php
--- branches/nimix_dev/http/javascripts/mod_savewmc.php	2008-08-18 14:34:12 UTC (rev 2853)
+++ branches/nimix_dev/http/javascripts/mod_savewmc.php	2008-08-18 14:37:20 UTC (rev 2854)
@@ -22,9 +22,12 @@
 echo "mod_savewmc_target = '".$e_target[0]."';";
 function setOnUnload() {
 	if (ie) {
-		document.getElementsByTagName('body')[0].onunload = function() {var x = new Function ("", "mod_savewmc_session()"); x(); };
+		document.getElementsByTagName('body')[0].onunload = function() {
+			var x = new Function ("", "mod_savewmc_session()"); x();
 	else {
 		document.getElementsByTagName('body')[0].setAttribute("onUnload", "mod_savewmc_session();");
@@ -64,5 +67,5 @@
 	if (storeInSession) {
 		$.ajaxSetup({async:false}); //TODO: find out why async doesn't work onunload
-	$.post("../php/mod_insertWmcIntoDb.php", {"saveInSession":storeInSession, "generalTitle":generalTitle, "extensionData":extensionDataString, "mapObject":$.toJSON(mb_mapObj[ind])}, callbackFunction);
+	$.post("../php/mod_savewmc_server.php", {"saveInSession":storeInSession, "generalTitle":generalTitle, "extensionData":extensionDataString, "mapObject":$.toJSON(mb_mapObj)}, callbackFunction);
More information about the Mapbender_commits mailing list
