[Mapbender-commits] r2861 - branches/nimix_dev/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 18 10:45:42 EDT 2008
Author: nimix
Date: 2008-08-18 10:45:42 -0400 (Mon, 18 Aug 2008)
New Revision: 2861
Added:
   branches/nimix_dev/http/classes/class_element.php
   branches/nimix_dev/http/classes/class_map.php
   branches/nimix_dev/http/classes/class_administration.php
   branches/nimix_dev/http/classes/class_bbox.php
   branches/nimix_dev/http/classes/class_gml2.php
   branches/nimix_dev/http/classes/class_gui.php
   branches/nimix_dev/http/classes/class_locale.php
merge
Modified: branches/nimix_dev/http/classes/class_administration.php
--- branches/nimix_dev/http/classes/class_administration.php	2008-08-18 14:44:53 UTC (rev 2860)
+++ branches/nimix_dev/http/classes/class_administration.php	2008-08-18 14:45:42 UTC (rev 2861)
@@ -18,6 +18,7 @@
 require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 require_once(dirname(__FILE__)."/class_mb_exception.php");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
@@ -27,8 +28,8 @@
  * class to wrap administration methods
  * @uses phpmailer
-class administration{
+class administration {
 	 * authentificates a user
 	 * @param string name of the user
@@ -150,6 +151,54 @@
+	 * Removes the namespace from a tag name
+	 * @return String like "gml"
+	 * @param $s String like "ogc:gml"
+	public static function sepNameSpace($s) {
+		$c = strpos($s,":");
+		if ($c > 0) {
+			return substr($s,$c+1);
+		return $s;
+	 * Parses an XML with PHP XML parser, see
+	 * http://de2.php.net/manual/de/book.xml.php
+	 * @return Array an associative array of tags, values, attributes and types
+	 * @param $someXml String The actual XML as string.
+	public static function parseXml ($someXml) {
+		$values = null;
+		$tags = null;
+		$parser = xml_parser_create(CHARSET);
+		// set parsing options
+		xml_parser_set_option($parser, XML_OPTION_CASE_FOLDING, 0);
+		xml_parser_set_option($parser, XML_OPTION_SKIP_WHITE, 1);
+		xml_parser_set_option($parser, XML_OPTION_TARGET_ENCODING, CHARSET);
+		// this is the actual parsing process
+		xml_parse_into_struct($parser, $someXml, $values, $tags);
+		// check if an error occured
+		$code = xml_get_error_code ($parser);
+		if ($code) {
+			// report error
+			$line = xml_get_current_line_number($parser);
+			$errorMessage = xml_error_string($code) . " in line " . $line;
+			$mb_exception = new mb_exception($errorMessage);
+			return false;
+		xml_parser_free($parser);
+		return $values;
      * returns a random password with numbers and chars both lowercase and uppercase (0-9a-zA-Z)
@@ -387,19 +436,13 @@
      * @param	string		the wmc_id
      * @return	boolean		Did the query run succesfull? This does not necessarily mean that
      * 						an entry was deleted.
+     * @deprecated
  	function deleteWmc($wmc_id, $user_id){
-		$sql = "DELETE FROM mb_user_wmc ";
-		$sql .= "WHERE fkey_user_id = $1 AND wmc_id = $2";
-		$v = array($user_id,$wmc_id);
-		$t = array('i','s');
-		$res = db_prep_query($sql,$v,$t);
-		if ($res) {
-			return true;
-		else {
-			return false;
+		$e = new mb_notice("administration->deleteWmc is deprecated, use wmc->delete instead!");
+		$wmc = new wmc();
+		return $wmc->delete($wmc_id, $user_id);
@@ -558,19 +601,13 @@
      * @param integer			the wms id
      * @return string|boolean	either the wmc as string or false when none exists
+     * @deprecated
 	function getWmcById($id){
-		$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 ";
-		$v = array($id);
-		$t = array('s');
-		$row = db_fetch_array($res);
-		if ($row) {
-			return $row["wmc"];
-		else {
-			return false;
+		$e = new mb_notice("administration->getWmcById is deprecated, use wmc->getDocument instead!");
+		$wmc = new wmc();
+		return $wmc->getDocument($id);
@@ -659,19 +696,14 @@
 		return $arrayGuis;
+	 * @deprecated
  	function getWmcByOwner($user_id){
-		$sql_wmc = "SELECT wmc_id FROM mb_user_wmc ";
-		$sql_wmc .= "WHERE fkey_user_id = $1 GROUP BY wmc_id";
-		$v = array($user_id);
-		$t = array('i');
-		$res_wmc = db_prep_query($sql_wmc,$v,$t);
-  		$count_g = 0;
-  		$arrayWmc = array();
-		while($row = db_fetch_array($res_wmc)){
-			$arrayWmc[$count_g] = $row["wmc_id"];
-			$count_g++;
-		return $arrayWmc;
+		$e = new mb_notice("administration->getWmcByOwner is deprecated, use user->getWmcByOwner instead!");
+		$user = new User($user_id);
+		return $user->getWmcByOwner();
 	function getGuisByPermission($mb_user_id,$ignoreublic){
Modified: branches/nimix_dev/http/classes/class_bbox.php
--- branches/nimix_dev/http/classes/class_bbox.php	2008-08-18 14:44:53 UTC (rev 2860)
+++ branches/nimix_dev/http/classes/class_bbox.php	2008-08-18 14:45:42 UTC (rev 2861)
@@ -19,6 +19,7 @@
 require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+require_once(dirname(__FILE__)."/../classes/class_point.php");
@@ -146,6 +147,10 @@
 		return false;
+	function toHtml () {
+		return (string) $this->min->toHtml() . " | " . $this->max->toHtml();
 	function __toString() {
 		return (string) "[" . $this->min . $this->max . " " . $this->epsg . "]";
Copied: branches/nimix_dev/http/classes/class_element.php (from rev 2653, trunk/mapbender/http/classes/class_element.php)
--- branches/nimix_dev/http/classes/class_element.php	                        (rev 0)
+++ branches/nimix_dev/http/classes/class_element.php	2008-08-18 14:45:42 UTC (rev 2861)
@@ -0,0 +1,240 @@
+<?php
+# $Id: class_bbox.php 1965 2008-01-15 08:24:29Z christoph $
+# http://www.mapbender.org/index.php/
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+define("ELEMENT_PATTERN", "/sessionID/");
+class Element {
+	var $guiId;
+	var $id;
+	var $pos;
+	var $isPublic;
+	var $comment;
+	var $title;
+	var $element;
+	var $src;
+	var $attributes;
+	var $left;
+	var $top;
+	var $width;
+	var $height;
+	var $zIndex;
+	var $moreStyles;
+	var $content;
+	var $closeTag;
+	var $jsFile;
+	var $mbMod;
+	var $target;
+	var $requires;
+	var $helpUrl;
+	public function __contruct() {
+	public function select ($id, $applicationId) {
+		$sql = "SELECT fkey_gui_id, e_id, e_pos, e_public, e_comment, e_public, ".
+				"gettext($1, e_title) as e_title, e_element, e_src, e_attributes, " .
+				"e_left, e_top, e_width, e_height, e_z_index, e_more_styles, " .
+				"e_content, e_closetag, e_js_file, e_mb_mod, e_target, " .
+				"e_requires, e_url FROM gui_element WHERE e_id = $2 AND " .
+				"fkey_gui_id = $3 LIMIT 1";
+		$v = array ($_SESSION["mb_lang"], $id, $applicationId);
+		$t = array ("s", "s", "s");
+		$res = db_prep_query($sql, $v, $t);
+		$row = db_fetch_array($res);
+		if ($row) {
+			$this->guiId = $applicationId;
+			$this->id = $row["e_id"];
+			$this->pos = $row["e_pos"];
+			$this->isPublic = $row["e_public"];
+			$this->comment = $row["e_comment"];
+			$this->title = $row["e_title"];
+			$this->element = $row["e_element"];
+			$this->src = $row["e_src"];
+			$this->attributes = $row["e_attributes"];
+			$this->left = $row["e_left"];
+			$this->top = $row["e_top"];
+			$this->width = $row["e_width"];
+			$this->height = $row["e_height"];
+			$this->zIndex = $row["e_z_index"];
+			$this->moreStyles = $row["e_more_styles"];
+			$this->content = $row["e_content"];
+			$this->closeTag = $row["e_closetag"];
+			$this->jsFile = $row["e_js_file"];
+			$this->mbMod = $row["e_mb_mod"];
+			$this->target = $row["e_target"];
+			$this->requires = $row["e_requires"];
+			$this->helpUrl = $row["e_url"];
+			return true;
+		return false;
+	public function __toString () {
+		return $this->toHtml();
+	public function getJavaScriptModules () {
+		$jsArray = array();
+		if ($this->mbMod != "") {
+			$moduleArray = explode(",", $this->mbMod);
+			for ($i = 0; $i < count($moduleArray); $i++) {
+				$currentFile = dirname(__FILE__) . "/../javascripts/" . trim($moduleArray[$i]);
+				if (file_exists($currentFile)) {
+					array_push($jsArray, $currentFile);
+				else {
+					$e = new mb_exception("Javascript module not found: " . $currentFile);
+		return $jsArray;
+	public function toHtmlArray () {
+		if ($this->isPublic) {
+			return array($this->getHtmlOpenTag(), $this->getHtmlContent(), $this->getHtmlCloseTag());
+		return array("", "", "");
+	public function toHtml () {
+			return implode("", $this->toHtmlArray());
+		return "";
+	private function getHtmlOpenTag () {
+		$openTag = "";
+		if ($this->id) {
+			// tag name
+			$openTag .= "<" . $this->element . " ";
+			// id and name
+			$openTag .= "id='" . $this->id . "' name='" . $this->id . "' ";
+			// attributes
+			if ($this->attributes) {
+				$openTag .= stripslashes($this->replaceSessionStringByUrlParameters($this->attributes)) . " ";
+			// title
+			if ($this->title) {
+				$openTag .= "title='" . $this->title . "' ";
+			// src
+			if ($this->src) {
+   				$openTag .= "src = '" . $this->replaceSessionStringByUrlParameters($this->src);
+				// for iframes which are not "loadData",
+				// add additional parameters
+				if ($this->closeTag == "iframe" && $this->id != "loadData") {
+					if(mb_strpos($this->src, "?")) {
+						$openTag .= "&";
+					else {
+	      				$openTag .= "?";
+	      			$openTag .= "e_id_css=" . $this->id . "&" .
+	      					 "e_id= " . $this->id . "&" .
+	      					 "e_target=" . $this->target . "&" .
+	      					 $this->getUrlParameters();
+   				$openTag .= "' ";
+			// style
+			$openTag .= " style = '";
+			if ($this->top != "" && $this->left != "") {
+				$openTag .= "position:absolute;" .
+						 "left:" . $this->left . ";" .
+						 "top:" . $this->top . ";";
+			if ($this->width != "" && $this->height != "") {
+				$openTag .= "width:" . $this->width . ";" .
+						 "height:" . $this->height . ";";
+			if ($this->zIndex) {
+		    	$openTag .= "z-index:" . $this->zIndex . ";";
+			if ($this->moreStyles) {
+		    	$openTag .= $this->moreStyles;
+			$openTag .= "'>";
+			if ($this->element == "body" && USE_LOAD_MESSAGE) {
+				$htmlWhileLoading = "<img src='../img/indicator_wheel.gif'>&nbsp;" .
+					"<b>Ma<font color='#0000CE'>p</font><font color='#C00000'>b</font>ender " .
+					MB_VERSION_NUMBER . " " . strtolower(MB_VERSION_APPENDIX) . "</b>..." .
+					"loading application '" . $this->guiId . "'";
+				$openTag .= "<div id='loading_mapbender' " .
+								"style='position:absolute;top:100;left:100'>" .
+								$htmlWhileLoading . "</div>" .
+								"<div id='complete_mapbender' " .
+								"style='display:none'>";
+		return $openTag;
+	private function getHtmlContent () {
+		$htmlContent = "";
+		if ($this->content != "") {
+			$htmlContent .= stripslashes($this->content);
+		return $htmlContent;
+	private function getHtmlCloseTag () {
+			return "</div></body>";
+		if ($this->closeTag != "") {
+			return "</" . $this->closeTag . ">";
+		return "";
+	private function getUrlParameters () {
+		$urlParameters = SID;
+		if (isset($this->guiId)) {
+			$urlParameters .= "&guiID=" . $this->guiId;
+		if (isset($this->id)) {
+			$urlParameters .= "&elementID=" . $this->id;
+		return $urlParameters;
+	private function replaceSessionStringByUrlParameters ($string) {
+		$urlParameters = $this->getUrlParameters();
+		return preg_replace(ELEMENT_PATTERN, $urlParameters, $string);
\ No newline at end of file
Modified: branches/nimix_dev/http/classes/class_gml2.php
--- branches/nimix_dev/http/classes/class_gml2.php	2008-08-18 14:44:53 UTC (rev 2860)
+++ branches/nimix_dev/http/classes/class_gml2.php	2008-08-18 14:45:42 UTC (rev 2861)
@@ -16,10 +16,10 @@
-require_once("class_mb_exception.php");
-require_once("class_connector.php");
-require_once("../extensions/JSON.php");
-require_once("../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 class gml2 {
 	var $geomtype_point = 'Point';
 	var $geomtype_polygon = 'Polygon';
@@ -196,7 +196,7 @@
 		foreach ($values as $element) {
-			$e = new mb_exception($element[tag]);
+			#$e = new mb_exception($element[tag]);
 			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("boundedBy") && $element[type] == "open"){
 				$boundedBy = true;
@@ -427,6 +427,49 @@
 		return $nodeName;
+	 * Parses the feature segment of a GML and stores the geometry in the
+	 * $geometry variable of the class.
+	 * Example of a feature segment of a GML.
+	 * 	<gml:featureMember>
+	 * 		<ms:ROUTE fid="ROUTE.228168">
+	 * 			<gml:boundedBy>
+	 * 				<gml:Box srsName="EPSG:31466">
+	 * 					<gml:coordinates>2557381.0,5562371.1 2557653.7,5562526.0</gml:coordinates>
+	 * 				</gml:Box>
+	 * 			</gml:boundedBy>
+	 * 			<ms:geometry>
+	 * 				<gml:LineString>
+	 * 						2557380.97,5562526 2557390.96,
+	 * 						5562523.22 2557404.03,5562518.2 2557422.31,
+	 * 						5562512 2557437.16,5562508.37 2557441.79,
+	 * 						5562507.49 2557454.31,5562505.1 2557464.27,
+	 * 						5562503.97 2557473.24,5562502.97 2557491.67,
+	 * 						5562502.12 2557505.65,5562502.43 2557513.78,
+	 * 						5562501.12 2557520.89,5562498.79 2557528.5,
+	 * 						5562495.07 2557538.9,5562488.91 2557549.5,
+	 * 						5562483.83 2557558.55,5562476.61 2557569.07,
+	 * 						5562469.82 2557576.61,5562462.72 2557582.75,
+	 * 						5562457.92 2557588.57,5562452.56 2557590.38,
+	 * 						5562449.69 2557593.57,5562445.07 2557596.17,
+	 * 						5562441.31 2557601.71,5562433.93 2557612.97,
+	 * 						5562421.03 2557626,5562405.33 2557639.66,
+	 * 						5562389.75 2557653.69,5562371.12
+	 * 					</gml:coordinates>
+	 * 				</gml:LineString>
+	 * 			</ms:geometry>
+	 * 			<code>354</code>
+	 * 			<Verkehr>0</Verkehr>
+	 * 			<rlp>t</rlp>
+	 * 		</ms:ROUTE>
+	 * 	</gml:featureMember>
+	 * @return void
+	 * @param $domNode DOMNodeObject the feature tag of the GML
+	 * 								(<gml:featureMember> in the above example)
 	public function parse($domNode) {
 		$currentSibling = $domNode->firstChild;
@@ -443,10 +486,14 @@
 			$ns = $namespace['ns'];
 			$columnName = $namespace['value'];
-			if ($name==$ns.":the_geom"){
+			// check if this node is a geometry node.
+			// however, even if it is a property node,
+			// it has a child node, the text node!
+			// So we might need to do something more
+			// sophisticated here...
+			if ($currentSibling->hasChildNodes()){
 				$geomNode = $currentSibling->firstChild;
 					$geomType = $geomNode->nodeName;
-//					echo "geomtype: " . $geomType . "<br>";
 					switch ($geomType) {
 						case "gml:Polygon" :
 							$this->geometry = new GMLPolygon();
@@ -459,20 +506,21 @@
 						case "gml:Point" :
 							$this->geometry = new GMLPoint();
 							$this->geometry->parsePoint($geomNode);
-#							$this->properties["Mapbender:icon"] = "../img/sy_star.png";
 							break;
 						case "gml:MultiLineString" :
 							$this->geometry = new GMLMultiLine();
 							$this->geometry->parseMultiLine($geomNode);
-//							$this->properties["Mapbender:icon"] = "../img/sy_star.png";
 							break;
 						case "gml:MultiPolygon" :
 							$this->geometry = new GMLMultiPolygon();
 							$this->geometry->parseMultiPolygon($geomNode);
 							break;
+						default:
+							$this->properties[$columnName] = $value;
+							break;
-			} else {
+			else {
@@ -500,7 +548,7 @@
 				$cnt ++;
-		$json = new Services_JSON();
+		$json = new Mapbender_JSON();
 		$str .= $json->encode($prop);
 		$str .= "}";
Modified: branches/nimix_dev/http/classes/class_gui.php
--- branches/nimix_dev/http/classes/class_gui.php	2008-08-18 14:44:53 UTC (rev 2860)
+++ branches/nimix_dev/http/classes/class_gui.php	2008-08-18 14:45:42 UTC (rev 2861)
@@ -18,6 +18,7 @@
+require_once(dirname(__FILE__)."/../classes/class_element.php");
 $con = db_connect($DBSERVER,$OWNER,$PW);
@@ -27,9 +28,51 @@
 class gui {
-	public function __construct () {
+	var $id;
+	var $elementArray = array();
+	public function __construct ($id) {
+		if ($id) {
+			$this->id = $id;
+			$this->elementArray = $this->selectElements();
+	public function selectElements () {
+		$sql = "SELECT e_id FROM gui_element WHERE fkey_gui_id = $1 " .
+				"ORDER BY e_pos";
+		$v = array($this->id);
+		$t = array('s');
+		$res = db_prep_query($sql,$v,$t);
+		$elementArray = array();
+		while ($row = db_fetch_array($res)) {
+			array_push($elementArray, $row[0]);
+		$this->elementArray = array();
+		for ($i = 0; $i < count($elementArray); $i++) {
+			$currentElement = new Element();
+			$currentElement->select($elementArray[$i], $this->id);
+			array_push($this->elementArray, $currentElement);
+		return $this->elementArray;
+		$htmlString = "";
+		$htmlString .= $this->elementsToHtml();
+		return $htmlString;
+		for ($i = 0; $i < count($this->elementArray); $i++) {
+			$currentElement = $this->elementArray[$i];
+			array_merge($jsArray, $currentElement->getJavaScriptModules());
+		return $jsArray;
  	 * Checks if a GUI with a given ID exists in the database
@@ -221,5 +264,33 @@
 	      return false;
+	private function elementsToHtml () {
+		$bodyStringArray = array();
+		$elementString = "";
+			if ($currentElement->id != "body") {
+				$elementString .= $currentElement->toHtml();
+			else {
+				$bodyStringArray = $currentElement->toHtmlArray();
+		$elementString .= "<form id='sendData' name='sendData' action='' " .
+						  "method='POST' target='loadData' " .
+						  "style='position:absolute;left:800px'>" .
+						  "<input type='hidden' name='data'></form>";
+		if (count($bodyStringArray) == 3) {
+			$elementString = $bodyStringArray[0] .
+				$bodyStringArray[1] .
+				$elementString .
+				$bodyStringArray[2];
+		return $elementString;
Modified: branches/nimix_dev/http/classes/class_locale.php
--- branches/nimix_dev/http/classes/class_locale.php	2008-08-18 14:44:53 UTC (rev 2860)
+++ branches/nimix_dev/http/classes/class_locale.php	2008-08-18 14:45:42 UTC (rev 2861)
@@ -93,19 +93,19 @@
 				$locale = $this->systemLocales[$this->knownLanguages[$languageId]][$this->os];
-				bindtextdomain(LOCALE_DOMAIN, LOCALE_DIR);
-				textdomain(LOCALE_DOMAIN);
 				if (setlocale(LC_ALL, $locale)) {
 					$this->name = $locale;
 					$_SESSION["mb_lang"] = $languageId;
 					$_SESSION["mb_locale"] = $this->name;
 					$e = new Mb_notice("locale " . $this->name . " ok on " . $this->os);
+					// from http://de3.php.net/manual/de/function.gettext.php
+					bindtextdomain("Mapbender", dirname(__FILE__)."/../../resources/locale/");
+					textdomain("Mapbender");
 					return true;
-				$e = new Mb_notice("locale " . $locale . " not found.");
+		$e = new Mb_notice("locale " . $locale . " not found.");
 		return false;
Copied: branches/nimix_dev/http/classes/class_map.php (from rev 2653, trunk/mapbender/http/classes/class_map.php)
--- branches/nimix_dev/http/classes/class_map.php	                        (rev 0)
+++ branches/nimix_dev/http/classes/class_map.php	2008-08-18 14:45:42 UTC (rev 2861)
@@ -0,0 +1,435 @@
+<?php
+require_once(dirname(__FILE__)."/../classes/class_bbox.php");
+ * Representing a map object, identical to the JS object in javascripts/map.js
+ * @class
+class Map {
+	private $width;
+	private $height;
+	private $frameName;
+	private $elementName = "maps";
+	private $extent;
+	private $isOverview = false;
+	private $wmsArray = array();
+	 * @destructor
+	 * @param
+	function __destruct() {
+	 * @constructor
+	 * @param
+	function __construct() {
+	// getter and setter
+	 * @param $value Integer
+	public function setWidth ($value) {
+		$this->width = $value;
+	 * @return
+	public function getWidth () {
+		return $this->width;
+	public function setHeight ($value) {
+		$this->height = $value;
+	 * @return
+	public function getHeight () {
+		return $this->height;
+	 * @param $value String
+	public function setFrameName ($value) {
+		$this->frameName = $value;
+	 * @return String
+	public function getFrameName () {
+		return $this->frameName;
+	public function setExtent ($aMapbenderBbox) {
+		$this->extent = $aMapbenderBbox;
+	 * @return Mapbender_bbox
+	public function getExtent () {
+		return $this->extent;
+	 * @return String EPSG code of the map.
+	public function getEpsg () {
+		return $this->extent->epsg;
+	 * @return
+	public function getWmsArray () {
+		return $this->wmsArray;
+	 * @return
+	 * @param $wmsArray Object
+	public function setWmsArray ($wmsArray) {
+		$this->wmsArray = $wmsArray;
+	 * @return
+	public function isOverview () {
+		return $this->isOverview;
+	public function setIsOverview ($bool) {
+		$this->isOverview = $bool;
+	 * @param $value Object
+	public function addWms ($value) {
+		array_push($this->wms, $value);
+	// map manipulation
+	 * Appends the WMS of another map to this map.
+	 * @param $anotherMap Map
+	public function append ($anotherMap) {
+		$this->wmsArray = array_merge($anotherMap->getWmsArray(), $this->wmsArray);
+	 * Merges this map with another map: Copies the map settings from the
+	 * other map and merges the WMS (keeping the settings of the other
+	 * map if there are duplicates)
+	public function merge ($anotherMap) {
+		$this->width = $anotherMap->width;
+		$this->height = $anotherMap->height;
+		$this->frameName = $anotherMap->frameName;
+		$this->elementName = $anotherMap->elementName;
+		$this->extent = $anotherMap->extent;
+		$this->isOverview = $anotherMap->isOverview;
+		$this->wmsArray = wms::merge(array_merge($anotherMap->getWmsArray(), $this->wmsArray));
+	 * Adds WMS to this map
+	 * @return
+	public function appendWmsArray ($wmsArray) {
+		$this->wmsArray = array_merge($this->wmsArray, $wmsArray);
+	 * Merge WMS into this map
+	 * @return
+	public function mergeWmsArray ($wmsArray) {
+		$this->wmsArray = wms::merge(array_merge($this->wmsArray, $wmsArray));
+	// Instantiation
+	 * @return
+	 * @param $jsMapObject Object
+	public function createFromJs ($jsMapObject) {
+		$arrayBBox = explode(",", $jsMapObject->extent);
+		$minx = floatval($arrayBBox[0]);
+		$miny = floatval($arrayBBox[1]);
+		$maxx = floatval($arrayBBox[2]);
+		$maxy = floatval($arrayBBox[3]);
+		$srs = $jsMapObject->epsg;
+		$bbox = new Mapbender_bbox($minx, $miny, $maxx, $maxy, $srs);
+		$this->width = $jsMapObject->width;
+		$this->height = $jsMapObject->height;
+		$this->frameName = $jsMapObject->frameName;
+		$this->extent = $bbox;
+		if (isset($jsMapObject->isOverview) && $jsMapObject->isOverview == "1") {
+			$this->isOverview = true;
+		for ($i=0; $i < count($jsMapObject->wms); $i++){
+			$currentWms = $jsMapObject->wms[$i];
+			$wms = new wms();
+			// set WMS data
+			$wms->wms_id = $currentWms->wms_id;
+			$wms->wms_version = $currentWms->wms_version;
+			$wms->wms_title = $currentWms->wms_title;
+			$wms->wms_abstract = $currentWms->wms_abstract;
+			$wms->wms_getmap = $currentWms->wms_getmap;
+			$wms->wms_getfeatureinfo = $currentWms->wms_getfeatureinfo;
+			$wms->wms_getlegendurl = $currentWms->wms_getlegendurl;
+			$wms->wms_filter = $currentWms->wms_filter;
+			$wms->gui_epsg = $currentWms->gui_epsg;
+			$wms->gui_minx = $currentWms->gui_minx;
+			$wms->gui_miny = $currentWms->gui_miny;
+			$wms->gui_maxx = $currentWms->gui_maxx;
+			$wms->gui_maxy = $currentWms->gui_maxy;
+			$wms->gui_wms_mapformat = $currentWms->gui_wms_mapformat;
+			$wms->gui_wms_featureinfoformat = $currentWms->gui_wms_featureinfoformat;
+			$wms->gui_wms_exceptionformat = $currentWms->gui_wms_exceptionformat;
+			$wms->gui_wms_opacity = $currentWms->wms_opacity;
+			$wms->gui_wms_sldurl = $currentWms->gui_wms_sldurl;
+			$wms->gui_wms_visible = $currentWms->gui_wms_visible;
+			$wms->gui_wms_epsg = $currentWms->gui_wms_epsg;
+			$wms->data_type = $currentWms->data_type;
+			$wms->data_format = $currentWms->data_format;
+			for ($k = 0; $k < count($currentWms->objLayer); $k++){
+				// the current layer of the JSON map object
+				$currentLayer = $currentWms->objLayer[$k];
+				// add new layer to WMS
+				$pos = $currentLayer->layer_pos;
+				$parent = $currentLayer->layer_parent;
+				$wms->addLayer($pos, $parent);
+				$newLayerIndex = count($wms->objLayer) - 1;
+				// $newLayer is a short cut to the layer we just added
+				$newLayer = $wms->objLayer[$newLayerIndex];
+				// set layer data
+				$newLayer->layer_uid = $currentLayer->layer_uid;
+				$newLayer->layer_name = $currentLayer->layer_name;
+				$newLayer->layer_title = $currentLayer->layer_title;
+				$newLayer->layer_dataurl_href = $currentLayer->layer_dataurl_href;
+				$newLayer->layer_pos = $currentLayer->layer_pos;
+				$newLayer->layer_queryable = $currentLayer->layer_queryable;
+				$newLayer->layer_minscale = $currentLayer->layer_minscale;
+				$newLayer->layer_maxscale = $currentLayer->layer_maxscale;
+				$newLayer->layer_metadataurl = $currentLayer->metadataurl;
+				$newLayer->gui_layer_wms_id = $wms->objLayer[0]->layer_uid;
+				$newLayer->gui_layer_status = $currentLayer->gui_layer_status;
+				$newLayer->gui_layer_style = $currentLayer->gui_layer_style;
+				$newLayer->gui_layer_selectable = $currentLayer->gui_layer_selectable;
+				$newLayer->gui_layer_visible = $currentLayer->gui_layer_visible;
+				$newLayer->gui_layer_queryable = $currentLayer->gui_layer_queryable;
+				$newLayer->gui_layer_querylayer = $currentLayer->gui_layer_querylayer;
+				$newLayer->gui_layer_minscale = $currentLayer->gui_layer_minscale;
+				$newLayer->gui_layer_maxscale = $currentLayer->gui_layer_maxscale;
+				$newLayer->gui_layer_wfs_featuretype = $currentLayer->gui_layer_wfs_featuretype;
+				// BEWARE THIS IS SUPER UGLY CODE
+				$newLayer->layer_epsg = array();
+				for ($z = 0; $z < count($currentLayer->layer_epsg); $z++) {
+					$newLayer->layer_epsg[$z] = array();
+					$newLayer->layer_epsg[$z]["epsg"] = $currentLayer->layer_epsg[$z]->epsg;
+					$newLayer->layer_epsg[$z]["minx"] = $currentLayer->layer_epsg[$z]->minx;
+					$newLayer->layer_epsg[$z]["miny"] = $currentLayer->layer_epsg[$z]->miny;
+					$newLayer->layer_epsg[$z]["maxx"] = $currentLayer->layer_epsg[$z]->maxx;
+					$newLayer->layer_epsg[$z]["maxy"] = $currentLayer->layer_epsg[$z]->maxy;
+				$newLayer->layer_style = array();
+				for ($z = 0; $z < count($currentLayer->layer_style); $z++) {
+					$newLayer->layer_style[$z] = array();
+					$newLayer->layer_style[$z]["name"] = $currentLayer->layer_style[$z]->name;
+					$newLayer->layer_style[$z]["title"] = $currentLayer->layer_style[$z]->title;
+					$newLayer->layer_style[$z]["legendurl"] = $currentLayer->layer_style[$z]->legendurl;
+					$newLayer->layer_style[$z]["legendurlformat"] = $currentLayer->layer_style[$z]->legendurlformat;
+			array_push($this->wmsArray, $wms);
+		return true;
+	// database functions
+	public static function selectMainMapByApplication ($appId) {
+		return map::selectByApplication($appId, "mapframe1");
+	public static function selectOverviewMapByApplication ($appId) {
+		$currentMap = map::selectByApplication($appId, "overview");
+		if ($currentMap !== null) {
+			$currentMap->setIsOverview(true);
+		return $currentMap;
+	// Output
+	 * Returns an array of string, which are JS statements.
+	 * @return String[]
+	public function toJavaScript ($wmsIndex) {
+		$jsCodeArray = array();
+		// initialise map object
+		if ($wmsIndex === null) {
+			$wmsIndex = "null";
+		$registerMapString = "mb_registerMapObj('" .
+			$this->frameName . "', " .
+			"'maps', " .
+			$wmsIndex . ", " .
+			$this->width . ", " .
+			$this->height . ");";
+		array_push($jsCodeArray, $registerMapString);
+//		$e = new mb_notice("Map to JS: ov? " . $this->isOverview);
+		// if map is overview...
+		if ($this->isOverview) {
+			// ...set overview flag
+			$setOverviewFlagString = "mb_mapObj[mb_mapObj.length-1].isOverview = true;";
+			array_push($jsCodeArray, $setOverviewFlagString);
+		// set width
+		$setMapframeWidth = "document.getElementById('" . $this->frameName . "')." .
+			"style.width = " . $this->width . ";";
+		array_push($jsCodeArray, $setMapframeWidth);
+		// set height
+		$setMapframeHeight = "document.getElementById('" . $this->frameName . "')." .
+			"style.height = " . $this->height . ";";
+		array_push($jsCodeArray, $setMapframeHeight);
+		// calculate extent
+		$calcExtentString = "mb_calculateExtent('" .
+			$this->extent->min->x . ", " .
+			$this->extent->min->y . ", " .
+			$this->extent->max->x . ", " .
+			$this->extent->max->y . ");";
+		array_push($jsCodeArray, $calcExtentString);
+		return $jsCodeArray;
+	// PRIVATE FUNCTIONS
+	private static function selectByApplication ($appId, $frameName) {
+		// find the mapframe in the application elements...
+		$sql = "SELECT * FROM gui_element WHERE fkey_gui_id = $1 AND " .
+				"e_id = $2 LIMIT 1";
+		$v = array($appId, $frameName);
+		$t = array('s', 's');
+		// if found...
+		if ($row) {
+			$currentMap = new Map();
+			// use settings from database
+			$currentMap->setWidth($row["e_width"]);
+			$currentMap->setHeight($row["e_height"]);
+			$currentMap->setFrameName($row["e_id"]);
+			// get the WMS
+			$wmsArray = wms::selectMyWmsByApplication($appId);
+//			$e = new mb_notice("WMS in this map: " . implode(",", $wmsArray));
+			// if this is the overview, find the WMS index and
+			// reset the WMS array
+			// BEWARE, SUPER UGLY CODE AHEAD!!
+			// (BUT THERE IS NO OTHER WAY TO DO IT)
+			if (strpos($row["e_src"], "mod_mapOV.php?wms") !== false) {
+//				$e = new mb_exception("guess this is the OV");
+				$pattern = "/[\.\/a-zA-Z_]*\?wms=([0-9]*)[^0-9]*/";
+				$ovIndex = preg_replace($pattern, "\$1", $row["e_src"]);
+				$e = new mb_exception("OV index: " . $ovIndex);
+				if (!$ovIndex) {
+					$ovIndex = 0;
+				$wmsArray = array($wmsArray[$ovIndex]);
+//				$e = new mb_notice("WMS in this map (corrected): " . implode(",", $wmsArray));
+			else {
+//				$e = new mb_exception("guess this is NOT the OV");
+			$currentMap->wmsArray = $wmsArray;
+			// TO DO: EXTENT!
+		else {
+			return null;
More information about the Mapbender_commits mailing list
