[Mapbender-commits] r2862 - branches/nimix_dev/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 18 10:47:14 EDT 2008
Author: nimix
Date: 2008-08-18 10:47:14 -0400 (Mon, 18 Aug 2008)
New Revision: 2862
Added:
   branches/nimix_dev/http/classes/class_wmcToXml.php
   branches/nimix_dev/http/classes/class_point.php
   branches/nimix_dev/http/classes/class_wfs_conf.php
merge
Modified: branches/nimix_dev/http/classes/class_point.php
--- branches/nimix_dev/http/classes/class_point.php	2008-08-18 14:45:42 UTC (rev 2861)
+++ branches/nimix_dev/http/classes/class_point.php	2008-08-18 14:47:14 UTC (rev 2862)
@@ -151,6 +151,26 @@
+	function toHtml () {
+		$str = "";
+		$xArray = explode(".", strval($this->x));
+		$str .= $xArray[0] . "°";
+		if ($xArray[1]) {
+			$str .= $xArray[1] . "'";
+		$str .= " O / ";
+		$yArray = explode(".", strval($this->y));
+		$str .= $yArray[0] . "°";
+		if ($yArray[1]) {
+			$str .= $yArray[1] . "'";
+		$str .= " N";
+		return $str;
 	function __toString() {
 		return (string) "(" . $this->x . "," . $this->y . "," . $this->epsg . ")";
Modified: branches/nimix_dev/http/classes/class_wfs_conf.php
--- branches/nimix_dev/http/classes/class_wfs_conf.php	2008-08-18 14:45:42 UTC (rev 2861)
+++ branches/nimix_dev/http/classes/class_wfs_conf.php	2008-08-18 14:47:14 UTC (rev 2862)
@@ -18,8 +18,9 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__)."/class_mb_exception.php");
+require_once(dirname(__FILE__)."/class_user.php");
 require_once(dirname(__FILE__)."/class_administration.php");
-require_once(dirname(__FILE__)."/../extensions/JSON.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
 class WfsConf {
 	var $confArray = array();
@@ -31,54 +32,66 @@
+	function __toString () {
+		$json = new Mapbender_JSON();
+		return $json->encode($this->confArray);
+	 * Loads WFS conf data from the database
+	 * @return Object WFS conf data.
+	 * @param $idOrIdArray Object May be an integer or an array of integers representing WFS conf IDs.
 	public function load ($idOrIdArray) {
-		 * Check parameter and set idArray
+		// Check parameter and set idArray
 		if (isset($idOrIdArray)){
 			// parameter is a number
 			if (!is_array($idOrIdArray) && is_numeric($idOrIdArray)) {
-				$this->getWfsConfFromDB(array(intval($idOrIdArray)), $_SESSION["mb_user_id"]);
+				$idArray = array(intval($idOrIdArray));
 			// parameter is an array of numbers
-			else if (is_array($idOrIdArray)) {
+			if (is_array($idOrIdArray)) {
 				$idArray = array();
 				for ($i=0; $i < count($idOrIdArray); $i++) {
 					if (!is_numeric($idOrIdArray[$i])) {
 						$e = new mb_exception("Wfs_conf: constructor: wrong parameter: ".$idOrIdArray[$i]." is not a number.");
-						return null;
+						return array();
 					array_push($idArray, intval($idOrIdArray[$i]));
-				$this->getWfsConfFromDB($idArray, $_SESSION["mb_user_id"]);
+				// If a user ID is given, remove the ones the user has no access to
+				if ($_SESSION["mb_user_id"]) {
+					$user = new User($_SESSION["mb_user_id"]);
+					$idArray = array_intersect($idArray, $user->getWfsConfByPermission());
+				return $this->getWfsConfFromDB($idArray);
 			// parameter is invalid
 			else {
 				$e = new mb_exception("Wfs_conf: constructor: parameter must be number or an array of numbers.");
-				return null;
+				return array();
 		else {
 			$e = new mb_exception("Wfs_conf: constructor: parameter is not valid");
+			return null;
+	// --------------------------- private -----------------------------------
-	 * get WFS conf data from database
+	 * Gets the database content for a number of WFS configurations given by their IDs.
+	 * @return Array
+	 * @param $idArray Array an array of integer values representing WFS conf IDs.
-	private function getWfsConfFromDB ($idArray, $userId) {
-		 * If a user ID is given, remove the ones the user has no access to
-		if ($userId) {
-			$idArray = array_intersect($idArray, WfsConf::getWfsConfByPermission($userId));
-		if (count($idArray) > 0) {
-			 * Get WFS configurations
+	private static function getWfsConfFromDbByArray ($idArray) {
 			$sql = "SELECT * FROM wfs_conf ";
 			$sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
 			$sql .= "WHERE wfs_conf.wfs_conf_id IN (";
@@ -95,123 +108,133 @@
 			$res = db_prep_query($sql, $v, $t);
+		$rowArray = array();
 			while ($row = db_fetch_array($res)) {
+			array_push($rowArray, $row);
+		return $rowArray;
-				 * Get WFS conf elements
+	 * Gets the database content of a WFS conf element given by a WFS conf ID.
+	 * @return Array
+	 * @param $id Integer the WFS conf ID.
-				$id = $row["wfs_conf_id"];
-				$sql_conf_element = "SELECT * FROM wfs_conf_element ";
-				$sql_conf_element .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-				$sql_conf_element .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-#filtered on client side
-#				$sql_conf_element .= "AND wfs_conf_element.f_search = 1 ";
-				$sql_conf_element .= "ORDER BY wfs_conf_element.f_pos";
-				$v_conf_element = array($id);
-				$t_conf_element = array('i');
-				$res_conf_element = db_prep_query($sql_conf_element, $v_conf_element, $t_conf_element);
+	private static function getWfsConfElementFromDb ($id) {
+		$sql = "SELECT * FROM wfs_conf_element ";
+		$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+		$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+		#filtered on client side
+		#$sql .= "AND wfs_conf_element.f_search = 1 ";
+		$sql .= "ORDER BY wfs_conf_element.f_pos";
+		$v = array($id);
+		$t = array('i');
+		$res = db_prep_query($sql, $v, $t);
-				$elementArray = array();
-				while ($row_conf_element = db_fetch_array($res_conf_element)) {
-					$currentElement = array("f_search" => $row_conf_element["f_search"],
-											"f_style_id" => $row_conf_element["f_style_id"],
-											"f_toupper" => $row_conf_element["f_toupper"],
-											"f_label" => $row_conf_element["f_label"],
-											"f_label_id" => $row_conf_element["f_label_id"],
-											"f_geom" => $row_conf_element["f_geom"],
-											"f_show" => $row_conf_element["f_show"],
-											"f_respos" => $row_conf_element["f_respos"],
-											"f_form_element_html" => $row_conf_element["f_form_element_html"],
-											"f_show_detail" => $row_conf_element["f_show_detail"],
-											"element_name" => $row_conf_element["element_name"],
-											"element_type" => $row_conf_element["element_type"]
+		$elementArray = array();
+		while ($row = db_fetch_array($res)) {
+			$currentElement = array("element_name" => $row["element_name"],
+									"element_type" => $row["element_type"],
+									"f_search" => $row["f_search"],
+									"f_style_id" => $row["f_style_id"],
+									"f_toupper" => $row["f_toupper"],
+									"f_label" => $row["f_label"],
+									"f_label_id" => $row["f_label_id"],
+									"f_geom" => $row["f_geom"],
+									"f_show" => $row["f_show"],
+									"f_mandatory" => $row_conf_element["f_mandatory"],
+									"f_respos" => $row_conf_element["f_respos"],
+									"f_min_input" => $row_conf_element["f_min_input"],
+									"f_form_element_html" => $row_conf_element["f_form_element_html"],
+									"f_show_detail" => $row_conf_element["f_show_detail"],
+									"f_detailpos" => $row_conf_element["f_detailpos"],
+									"f_operator" => $row_conf_element["f_operator"],
+									"f_show_detail" => $row["f_show_detail"]
 					array_push($elementArray, $currentElement);
+		return $elementArray;
-				 * Get WFS featuretype
+	 * Gets the database content of a WFS feature type given by a WFS ID and a featuretype ID.
+	 * @return Array
+	 * @param $wfsId Integer the WFS ID.
+	 * @param $featuretypeId Integer the WFS featuretype ID.
-				$sql_feature_type = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
-				$v_feature_type = array($row["fkey_wfs_id"], $row["fkey_featuretype_id"]);
-				$t_feature_type = array("i", "i");
+	private static function getWfsFeatureTypeFromDb($wfsId, $featuretypeId) {
+		$sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
+		$v = array($wfsId, $featuretypeId);
+		$t = array("i", "i");
-				$res_feature_type = db_prep_query($sql_feature_type, $v_feature_type, $t_feature_type);
-				if($row_feature_type = db_fetch_array($res_feature_type)){
-					$featuretype_name  = $row_feature_type["featuretype_name"];
-					$featuretype_srs  = $row_feature_type["featuretype_srs"];
-				$currentRow = array("g_label" => $row["g_label"],
-			                        "g_label_id" => $row["g_label_id"],
-									"g_style" => $row["g_style"],
-									"g_button" => $row["g_button"],
-									"g_button_id" => $row["g_button_id"],
-									"g_buffer" => $row["g_buffer"],
-									"g_res_style" => $row["g_res_style"],
-									"g_use_wzgraphics" => $row["g_use_wzgraphics"],
-									"wfs_id" => $row["fkey_wfs_id"],
-									"featuretype_id" => $row["fkey_featuretype_id"],
-									"featuretype_name" => $featuretype_name,
-									"featuretype_srs" => $featuretype_srs,
-									"wfs_getfeature" => $row["wfs_getfeature"],
-									"wfs_describefeaturetype" => $row["wfs_describefeaturetype"],
-									"wfs_transaction" => $row["wfs_transaction"],
-									"element" => $elementArray
+		$currentRow = array();
-				$this->confArray[$id] = $currentRow;
+		if($row = db_fetch_array($res)){
+			$currentRow["featuretype_name"] = $row["featuretype_name"];
+			$currentRow["featuretype_srs"] = $row["featuretype_srs"];
+		return $currentRow;
-		else {
-			$e = new mb_warning("class_wfs_conf.php: getWfsConfFromDB: You don't have access to any WFS confs. Check EDIT WFS.");
-	/** identifies the Conf-FeatureServices where the current user is owner
-	 * @param integer userid the user-ID of the current user
-	 * @return integer[] the IDs of the wfs_conf-table
+	 * get WFS conf data from database
-	public static function getWfsConfByPermission($userid){
-	 	$guisByPer = array();
-//	 	1.
-		$adm = new administration();
-	 	$guisByPer = $adm->getGuisByPermission($userid, true);
-//	 	2.
-		if(count($guisByPer)>0){
-			$v = array();
-			$t = array();
-			$sql = "SELECT wfs_conf.wfs_conf_id  FROM gui_wfs_conf, wfs_conf " .
-					"where wfs_conf.wfs_conf_id = gui_wfs_conf.fkey_wfs_conf_id " .
-					"and gui_wfs_conf.fkey_gui_id IN(";
-			for($i=0; $i<count($guisByPer); $i++){
-				if($i>0){ $sql .= ",";}
-				$sql .= "$".strval($i+1);
+	private function getWfsConfFromDB ($idArray) {
-				array_push($v, $guisByPer[$i]);
-				array_push($t, "s");
-			$sql .= ") GROUP BY wfs_conf.wfs_conf_id ORDER BY wfs_conf.wfs_conf_id";
+		// if a user has access to some WFS confs...
+		if (count($idArray) > 0) {
-			$res = db_prep_query($sql,$v,$t);
-			$ownWFSconfs = array();
-			$i=0;
-			while($row = db_fetch_array($res)){
+			// get WFS conf data from DB
+			$rowArray = self::getWfsConfFromDbByArray($idArray);
-				$ownWFSconfs[$i] = $row['wfs_conf_id'];
-				$i++;
+			for ($i=0; $i < count($rowArray); $i++) {
+				// WFS conf data
+				$currentRow = array("g_label" => $rowArray[$i]["g_label"],
+			                        "g_label_id" => $rowArray[$i]["g_label_id"],
+									"g_style" => $rowArray[$i]["g_style"],
+									"g_button" => $rowArray[$i]["g_button"],
+									"g_button_id" => $rowArray[$i]["g_button_id"],
+									"g_buffer" => $rowArray[$i]["g_buffer"],
+									"g_res_style" => $rowArray[$i]["g_res_style"],
+									"g_use_wzgraphics" => $rowArray[$i]["g_use_wzgraphics"],
+									"wfs_id" => $rowArray[$i]["fkey_wfs_id"],
+									"featuretype_id" => $rowArray[$i]["fkey_featuretype_id"],
+									"wfs_getfeature" => $rowArray[$i]["wfs_getfeature"],
+									"wfs_describefeaturetype" => $rowArray[$i]["wfs_describefeaturetype"],
+									"wfs_transaction" => $rowArray[$i]["wfs_transaction"],
+									"element" => $elementArray
+				// get WFS conf element data of current WFS conf
+				$id = $rowArray[$i]["wfs_conf_id"];
+				$currentRow["element"] = self::getWfsConfElementFromDb($id);
+				// get WFS featuretype data of current WFS conf
+				$wfsId = $rowArray[$i]["fkey_wfs_id"];
+				$featuretypeId = $rowArray[$i]["fkey_featuretype_id"];
+				$currentRow = array_merge($currentRow , self::getWfsFeatureTypeFromDb($wfsId, $featuretypeId));
+				$this->confArray[$id] = $currentRow;
+			return $this->confArray;
-		return $ownWFSconfs;
+		else {
+			$e = new mb_warning("class_wfs_conf.php: getWfsConfFromDB: You don't have access to any WFS confs. Check EDIT WFS.");
+			return array();
+ * @deprecated
 class wfs_conf{
 	var $wfs_id;
Copied: branches/nimix_dev/http/classes/class_wmcToXml.php (from rev 2653, trunk/mapbender/http/classes/class_wmcToXml.php)
--- branches/nimix_dev/http/classes/class_wmcToXml.php	                        (rev 0)
+++ branches/nimix_dev/http/classes/class_wmcToXml.php	2008-08-18 14:47:14 UTC (rev 2862)
@@ -0,0 +1,536 @@
+<?php
+# $Id: class_wmc.php 2466 2008-05-20 08:55:03Z christoph $
+# http://www.mapbender.org/index.php/class_wmc.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+ * The XML representation of a WMC object.
+ * Usage:
+ * $wmcToXml = new WmcToXml($wmc);
+ * $xml = $wmcToXml->getXml();
+class WmcToXml {
+	private $wmc = null;
+	private $doc;
+	private $xml = "";
+	 * Constructor. Computes the XML of the WMC object given as parameter.
+	 * @param $someWmc wmc
+	public function __construct ($someWmc) {
+		$this->wmc = $someWmc;
+		$this->toXml();
+	// public functions
+	public function getXml () {
+		return $this->xml;
+	// private functions
+	private function toXml () {
+		// add main map and overview (if exists) to $mapArray
+		$mapArray = array($this->wmc->mainMap);
+		if ($this->wmc->overviewMap !== null) {
+			array_push($mapArray, $this->wmc->overviewMap);
+		// generate XML
+		$this->doc = new DOMDocument("1.0", CHARSET);
+		$this->doc->preserveWhiteSpace = false;
+		// ViewContext
+		$e_view_context = $this->doc->createElementNS("http://www.opengis.net/context", "ViewContext");
+		$e_view_context->setAttribute("version", "1.1.0");
+		$e_view_context->setAttribute("id", $this->wmc->wmc_id);
+		$e_view_context->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+		$e_view_context->setAttribute("xmlns:" . $this->wmc->extensionNamespace, $this->wmc->extensionNamespaceUrl);
+		$e_view_context->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
+		$e_view_context->setAttribute("xsi:SchemaLocation", "http://schemas.opengis.net/context/1.0.0/context.xsd");
+		// General
+		$e_general = $this->createGeneralNode();
+		if ($e_general !== null) {
+			$e_view_context->appendChild($e_general);
+		// Layerlist
+		$e_layer_list = $this->doc->createElement("LayerList");
+		while (count($mapArray) > 0) {
+			$currentMap = array_pop($mapArray);
+			$currentWmsArray = $currentMap->getWmsArray();
+			for ($i = 0; $i < count($currentWmsArray); $i++) {
+				$currentWms = $currentWmsArray[$i];
+				for ($j = 0; $j < count($currentWms->objLayer); $j++) {
+					$currentLayer = $currentWms->objLayer[$j];
+					$layerNode = $this->createLayerNode($currentMap, $currentWms, $currentLayer);
+					if ($layerNode !== null) {
+						$e_layer_list->appendChild($layerNode);
+		$e_view_context->appendChild($e_layer_list);
+		$this->doc->appendChild($e_view_context);
+		$this->xml = $this->doc->saveXML();
+	private function createGeneralNode () {
+			$ovExtent = $this->wmc->overviewMap->getExtent();
+			$extensionData->ov_minx = $ovExtent->min->x;
+			$extensionData->ov_miny = $ovExtent->min->y;
+			$extensionData->ov_maxx = $ovExtent->max->x;
+			$extensionData->ov_maxy = $ovExtent->max->y;
+			$extensionData->ov_srs = $ovExtent->epsg;
+			$extensionData->ov_framename = $this->wmc->overviewMap->getFrameName();
+			$extensionData->ov_width = $this->wmc->overviewMap->getWidth();
+			$extensionData->ov_height = $this->wmc->overviewMap->getHeight();
+		// General
+		$e_general = $this->doc->createElement("General");
+		// Window
+		$e_window = $this->doc->createElement("Window");
+		if ($this->wmc->mainMap->getWidth() && $this->wmc->mainMap->getHeight()) {
+			$e_window->setAttribute("width", $this->wmc->mainMap->getWidth());
+			$e_window->setAttribute("height", $this->wmc->mainMap->getHeight());
+		$e_general->appendChild($e_window);
+		// BoundingBox
+		$mainExtent = $this->wmc->mainMap->getExtent();
+		$e_bbox = $this->doc->createElement("BoundingBox");
+		$e_bbox->setAttribute("SRS", $mainExtent->epsg);
+		$e_bbox->setAttribute("minx", $mainExtent->min->x);
+		$e_bbox->setAttribute("miny", $mainExtent->min->y);
+		$e_bbox->setAttribute("maxx", $mainExtent->max->x);
+		$e_bbox->setAttribute("maxy", $mainExtent->max->y);
+		$e_general->appendChild($e_bbox);
+		// Name
+		$e_name = $this->doc->createElement("Name", $this->wmc->wmc_name);
+		$e_general->appendChild($e_name);
+		// Title
+		$e_title = $this->doc->createElement("Title", $this->wmc->wmc_title);
+		$e_general->appendChild($e_title);
+		// Keywords
+		$e_keyword_list = $this->doc->createElement("KeywordList");
+		for ($i=0; $i < count($this->wmc->wmc_keyword); $i++) {
+			$e_keyword = $this->doc->createElement("Keyword", $this->wmc->wmc_keyword[$i]);
+			$e_keyword_list->appendChild($e_keyword);
+		$e_general->appendChild($e_keyword_list);
+		// Abstract
+		if ($this->wmc->wmc_abstract) {
+			$e_abstract = $this->doc->createElement("Abstract", $this->wmc->wmc_abstract);
+			$e_general->appendChild($e_abstract);
+		// Logo URL
+		if ($this->wmc->wmc_logourl_width && $this->wmc->wmc_logourl_height &&
+			$this->wmc->wmc_logourl_format && $this->wmc->wmc_logourl){
+			$e_logo_url = $this->doc->createElement("LogoURL");
+			$e_logo_url->setAttribute("width", $this->wmc->wmc_logourl_width);
+			$e_logo_url->setAttribute("height", $this->wmc->wmc_logourl_height);
+			$e_logo_url->setAttribute("format", $this->wmc->wmc_logourl_format);
+			$e_logo_url_or = $this->doc->createElement("OnlineResource");
+			$e_logo_url_or->setAttributeNS("http://www.opengis.net/context", "xmlns:xlink", "http://www.w3.org/1999/xlink");
+			$e_logo_url_or->setAttribute("xlink:type", "simple");
+			$e_logo_url_or->setAttribute("xlink:href", $this->wmc->wmc_logourl);
+			$e_logo_url->appendChild($e_logo_url_or);
+			$e_general->appendChild($e_logo_url);
+		// Description URL
+		if ($this->wmc->wmc_descriptionurl){
+			$e_description_url = $this->doc->createElement("DescriptionURL");
+			$e_description_url_or = $this->doc->createElement("OnlineResource");
+			$e_description_url_or->setAttributeNS("http://www.opengis.net/context", "xmlns:xlink", "http://www.w3.org/1999/xlink");
+			$e_description_url_or->setAttribute("xlink:type", "simple");
+			$e_description_url_or->setAttribute("xlink:href", $this->wmc->wmc_descriptionurl);
+			$e_description_url->appendChild($e_description_url_or);
+			$e_general->appendChild($e_description_url);
+		// Contact information
+		$e_contact = $this->createContactInformationNode();
+		if ($e_contact !== null) {
+			$e_general->appendChild($e_contact);
+		// Extension data
+		if (count($extensionData) > 0) {
+			$e_extensionGeneral = $this->doc->createElement("Extension");
+			foreach ($extensionData as $keyExtensionData => $valueExtensionData) {
+				$e_currentExtensionTag = $this->doc->createElement($this->wmc->extensionNamespace.":".$keyExtensionData, $valueExtensionData);
+				$e_extensionGeneral->appendChild($e_currentExtensionTag);
+			$e_general->appendChild($e_extensionGeneral);
+		return $e_general;
+	private function createLayerNode ($currentMap, $currentWms, $currentLayer) {
+		if ($currentLayer->layer_parent != '') {
+			// Layer
+			$e_layer = $this->doc->createElement("Layer");
+			$e_layer->setAttribute("queryable", $currentLayer->layer_queryable);
+			$e_layer->setAttribute("hidden", ($currentLayer->gui_layer_visible ? 0 : 1));
+			// Server
+			$e_service = $this->doc->createElement("Server");
+			$e_service->setAttribute("service", "OGC:WMS");
+			$e_service->setAttribute("version", $currentWms->wms_version);
+			$e_service->setAttribute("title", $currentWms->wms_title);
+			// Online resource
+			$e_service_or = $this->doc->createElement("OnlineResource");
+			$e_service_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+			$e_service_or->setAttribute("xlink:type", "simple");
+			$e_service_or->setAttribute("xlink:href", $currentWms->wms_getmap);
+			$e_service->appendChild($e_service_or);
+			$e_layer->appendChild($e_service);
+			// Name
+			$e_layer_name = $this->doc->createElement("Name", $currentLayer->layer_name);
+			$e_layer->appendChild($e_layer_name);
+			// Title
+			$e_layer_title = $this->doc->createElement("Title", $currentLayer->layer_title);
+			$e_layer->appendChild($e_layer_title);
+			// Abstract
+			if ($currentWms->wms_abstract){
+				$e_layer_abstract = $this->doc->createElement("Abstract", $currentWms->wms_abstract);
+				$e_layer->appendChild($e_layer_abstract);
+			// SRS
+			$srsNode = $this->createSrsNode($currentMap, $currentWms);
+			if ($srsNode !== null) {
+				$e_layer->appendChild($srsNode);
+			// Data URL
+			if ($currentLayer->layer_dataurl_href){
+				$e_layer_data_url = $this->doc->createElement("DataURL");
+				$e_layer_data_url_or = $this->doc->createElement("OnlineResource");
+				$e_layer_data_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+				$e_layer_data_url_or->setAttribute("xlink:type", "simple");
+				$e_layer_data_url_or->setAttribute("xlink:href", $currentLayer->layer_dataurl_href);
+				$e_layer_data_url->appendChild($e_layer_data_url_or);
+				$e_layer->appendChild($e_layer_data_url);
+			// Metadata URL
+			if ($currentLayer->layer_metadataurl){
+				$e_layer_metadata_url = $this->doc->createElement("MetadataURL");
+				// Metadata URL online resource
+				$e_layer_metadata_url_or = $this->doc->createElement("OnlineResource");
+				$e_layer_metadata_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+				$e_layer_metadata_url_or->setAttribute("xlink:type", "simple");
+				$e_layer_metadata_url_or->setAttribute("xlink:href", $currentLayer->layer_metadataurl);
+				$e_layer_metadata_url->appendChild($e_layer_metadata_url_or);
+				$e_layer->appendChild($e_layer_metadata_url);
+			// Layer format
+			$formatListNode = $this->createLayerFormatListNode($currentWms);
+			if ($formatListNode !== null) {
+				$e_layer->appendChild($formatListNode);
+			// Layer style
+			$layerStyleListNode = $this->createLayerStyleNode($currentWms, $currentLayer);
+			if ($layerStyleListNode !== null) {
+				$e_layer->appendChild($layerStyleListNode);
+			// Extension
+			$extensionNode = $this->createLayerExtensionNode($currentMap, $currentWms, $currentLayer);
+			if ($extensionNode !== null) {
+				$e_layer->appendChild($extensionNode);
+			return $e_layer;
+		return null;
+	private function createSrsNode ($currentMap, $currentWms) {
+		$wms_epsg = array();
+		$wms_epsg[0] = $currentMap->getEpsg();
+		if ($currentWms->gui_wms_epsg != $currentMap->getEpsg()) {
+			$wms_epsg[1] = $currentWms->gui_wms_epsg;
+		for ($j = 0; $j < count($currentWms->gui_epsg); $j++) {
+			if (!in_array($currentWms->gui_epsg[$j], $wms_epsg)){
+				array_push($wms_epsg, $currentWms->gui_epsg[$j]);
+		$e_layer_srs = $this->doc->createElement("SRS", implode(" ", $wms_epsg));
+		return $e_layer_srs;
+	private function createLayerFormatListNode ($currentWms) {
+		$e_layer_format = $this->doc->createElement("FormatList");
+		$data_format_current = false;
+		for ($k = 0; $k < count($currentWms->data_format); $k++){
+			if ($currentWms->data_type[$k] == "map") {
+				$layerFormat = $currentWms->data_format[$k];
+				$e_format = $this->doc->createElement("Format", $layerFormat);
+				if ($data_format_current === false && (
+						$currentWms->data_format[$k] == $currentWms->gui_wms_mapformat ||
+						$k == (count($currentWms->data_format)-1)
+					$e_format->setAttribute("current", "1");
+					$data_format_current = true;
+				$e_layer_format->appendChild($e_format);
+		return $e_layer_format;
+	private function createLayerExtensionNode ($currentMap, $currentWms, $currentLayer) {
+		$layerExtensionData = array();
+		$layerExtensionData["wms_name"] = $currentWms->objLayer[0]->layer_name;
+		$layerExtensionData["minscale"] = $currentLayer->layer_minscale;
+		$layerExtensionData["maxscale"] = $currentLayer->layer_maxscale;
+		$layerExtensionData["gui_minscale"] = $currentLayer->gui_layer_minscale;
+		$layerExtensionData["gui_maxscale"] = $currentLayer->gui_layer_maxscale;
+		$layerExtensionData["layer_id"] = $currentLayer->layer_uid;
+		$layerExtensionData["wms_layer_id"] = $currentWms->objLayer[0]->layer_uid;
+		$layerExtensionData["layer_pos"] = $currentLayer->layer_pos;
+		$layerExtensionData["layer_parent"] = $currentLayer->layer_parent;
+		$layerExtensionData["wms_id"] = $currentWms->wms_id;
+		$layerExtensionData["querylayer"] = $currentLayer->gui_layer_querylayer;
+		$layerExtensionData["gui_selectable"] = $currentLayer->gui_layer_selectable;
+		$layerExtensionData["gui_queryable"] = $currentLayer->gui_layer_queryable;
+		$layerExtensionData["gui_status"] = $currentLayer->gui_layer_status;
+		if ($currentMap->isOverview()) {
+			$layerExtensionData["isOverviewLayer"] = 1;
+		if ($currentLayer->gui_layer_wfs_featuretype) {
+			$layerExtensionData["wfsFeatureType"] = $currentLayer->gui_layer_wfs_featuretype;
+		if (count($layerExtensionData) > 0) {
+			$e_extension = $this->doc->createElement("Extension");
+			foreach ($layerExtensionData as $keyExtensionData => $valueExtensionData) {
+				$e_extension->appendChild($e_currentExtensionTag);
+			return $e_extension;
+		return null;
+	private function createLayerStyleNode ($currentWms, $currentLayer) {
+		$e_layer_stylelist = $this->doc->createElement("StyleList");
+		for ($k = 0; $k < count($currentLayer->layer_style); $k++) {
+			$currentStyle = $currentLayer->layer_style[$k];
+			$layerStyle_current = 0;
+			if ($k === 0){
+				$layerStyle_current = 1; // To do: insert proper data
+			$e_layer_style = $this->doc->createElement("Style");
+			$layerStyleSLD = "";
+			if ($layerStyleSLD) {
+				$e_layer_style_or = $this->doc->createElement("OnlineResource");
+				$e_layer_style_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+				$e_layer_style_or->setAttribute("xlink:type", "simple");
+				$e_layer_style_or->setAttribute("xlink:href", $currentWms->gui_wms_sldurl);
+				$e_layer_style->appendChild($e_layer_style_or);
+			else{
+				if ($layerStyle_current == 1){
+					$e_layer_style->setAttribute("current", "1");
+				$e_layer_style_name = $this->doc->createElement("Name", $currentStyle->name);
+				$e_layer_style->appendChild($e_layer_style_name);
+				$e_layer_style_title = $this->doc->createElement("Title", $currentStyle->title);
+				$e_layer_style->appendChild($e_layer_style_title);
+				$e_layer_style_legendurl = $this->doc->createElement("LegendUrl");
+				//TODO: determine correct layer style entries
+				$layerStyle_legendUrl_width = ""; // To Do: add proper data
+				$layerStyle_legendUrl_height = ""; // To Do: add proper data
+				$layerStyle_legendUrl_format = ""; // To Do: add proper data
+				$e_layer_style_legendurl->setAttribute("width", $layerStyle_legendUrl_width);
+				$e_layer_style_legendurl->setAttribute("height", $layerStyle_legendUrl_height);
+				$e_layer_style_legendurl->setAttribute("format", $layerStyle_legendUrl_format);
+				$e_layer_style_legendurl_or = $this->doc->createElement("OnlineResource");
+				$e_layer_style_legendurl_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+				$e_layer_style_legendurl_or->setAttribute("xlink:type", "simple");
+				$e_layer_style_legendurl_or->setAttribute("xlink:href", $currentWms->wms_getlegendurl);
+				$e_layer_style_legendurl->appendChild($e_layer_style_legendurl_or);
+				$e_layer_style->appendChild($e_layer_style_legendurl);
+			$e_layer_stylelist->appendChild($e_layer_style);
+		return $e_layer_stylelist;
+	 * @return
+	private function createContactInformationNode () {
+		if ($this->wmc->wmc_contactemail || $this->wmc->wmc_contactorganization ||
+			$this->wmc->wmc_contactperson || $this->wmc->wmc_contactposition ||
+			$this->wmc->wmc_contactaddresstype || $this->wmc->wmc_contactaddress ||
+			$this->wmc->wmc_contactcity || $this->wmc->wmc_contactstateorprovince ||
+			$this->wmc->wmc_contactpostcode || $this->wmc->wmc_contactcountry ||
+			$this->wmc->wmc_contactvoicetelephone || $this->wmc->wmc_contactfacsimiletelephone) {
+			$e_contact = $this->doc->createElement("ContactInformation");
+			$e_contact_person_primary = $this->wmc->createContactPersonPrimaryNode();
+			if ($e_contact_person_primary !== null) {
+				$e_contact->appendChild($e_contact_person_primary);
+			if ($this->wmc->wmc_contactposition){
+				$e_contact_position = $this->doc->createElement("ContactPosition", $this->wmc->wmc_contactposition);
+				$e_contact->appendChild($e_contact_position);
+			if ($this->wmc->wmc_contactaddresstype || $this->wmc->wmc_contactaddress ||
+				$this->wmc->wmc_contactpostcode || $this->wmc->wmc_contactcountry) {
+				$e_contact_address = $this->doc->createElement("ContactAddress");
+				if ($this->wmc->wmc_contactaddresstype){
+					$e_address_type = $this->doc->createElement("AddressType", $this->wmc->wmc_contactaddresstype);
+					$e_contact_address->appendChild($e_address_type);
+				if ($this->wmc->wmc_contactaddress){
+					$e_address = $this->doc->createElement("Address", $this->wmc->wmc_contactaddress);
+					$e_contact_address->appendChild($e_address);
+				if ($this->wmc->wmc_contactcity){
+					$e_city = $this->doc->createElement("City", $this->wmc->wmc_contactcity);
+					$e_contact_address->appendChild($e_city);
+				if ($this->wmc->wmc_contactstateorprovince){
+					$e_state = $this->doc->createElement("StateOrProvince", $this->wmc->wmc_contactstateorprovince);
+					$e_contact_address->appendChild($e_state);
+				if ($this->wmc->wmc_contactpostcode){
+					$e_postcode = $this->doc->createElement("PostCode", $this->wmc->wmc_contactpostcode);
+					$e_contact_address->appendChild($e_postcode);
+				if ($this->wmc->wmc_contactcountry){
+					$e_country = $this->doc->createElement("Country", $this->wmc->wmc_contactcountry);
+					$e_contact_address->appendChild($e_country);
+				$e_contact->appendChild($e_contact_address);
+			if ($this->wmc->wmc_contactvoicetelephone){
+				$e_voice_telephone = $this->doc->createElement("ContactVoiceTelephone", $this->wmc->wmc_contactvoicetelephone);
+				$e_contact->appendChild($e_voice_telephone);
+			if ($this->wmc->wmc_contactfacsimiletelephone){
+				$e_facsimile_telephone = $this->doc->createElement("ContactFacsimileTelephone", $this->wmc->wmc_contactfacsimiletelephone);
+				$e_contact->appendChild($e_facsimile_telephone);
+			if ($this->wmc->wmc_contactemail){
+				$e_email = $this->doc->createElement("ContactElectronicMailAddress", $this->wmc->wmc_contactemail);
+				$e_contact->appendChild($e_email);
+			return $e_contact;
+		return null;
+	private function createContactPersonPrimaryNode () {
+		if ($this->wmc->wmc_contactperson || $this->wmc->wmc_contactorganization){
+			$e_contact_person_primary = $this->doc->createElement("ContactPersonPrimary");
+			if ($this->wmc->wmc_contactperson){
+				$e_contact_person = $this->doc->createElement("ContactPerson", $this->wmc->wmc_contactperson);
+				$e_contact_person_primary->appendChild($e_contact_person);
+			if ($this->wmc->wmc_contactorganization){
+				$e_contact_organization = $this->doc->createElement("ContactOrganization", $this->wmc->wmc_contactorganization);
+				$e_contact_person_primary->appendChild($e_contact_organization);
+			return $e_contact_person_primary;
+		return null;
\ No newline at end of file
More information about the Mapbender_commits mailing list
