[Mapbender-commits] r2863 - branches/nimix_dev/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 18 10:48:26 EDT 2008
Author: nimix
Date: 2008-08-18 10:48:26 -0400 (Mon, 18 Aug 2008)
New Revision: 2863
   branches/nimix_dev/http/classes/class_wms.php
merge
Modified: branches/nimix_dev/http/classes/class_wms.php
--- branches/nimix_dev/http/classes/class_wms.php	2008-08-18 14:47:14 UTC (rev 2862)
+++ branches/nimix_dev/http/classes/class_wms.php	2008-08-18 14:48:26 UTC (rev 2863)
@@ -19,12 +19,12 @@
 include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_user.php");
 require_once(dirname(__FILE__)."/class_mb_exception.php");
 require_once(dirname(__FILE__)."/class_administration.php");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
 class wms {
 	var $lastURL;
@@ -77,7 +77,147 @@
 	function wms() {
+	function createOlObjFromWMS($base){
+	 	if(!$this->wms_title || $this->wms_title == ""){
+			echo "alert('Error: no valid capabilities-document !!');";
+			die; exit;
+		// wms_title and abstract have previously been urlencoded
+		// this solution may not yet be the ultimate one
+		$add_wms_string = "var wms_".$this->wms_id." = new OpenLayers.Layer.WMS.Untiled(" .
+				"'" . addslashes($this->wms_title) . "'," .
+				"'" . $this->wms_getmap ."'," ."{layers:'";
+				for($i=1;$i<count($this->objLayer);$i++){
+					$add_wms_string .= addslashes($this->objLayer[$i]->layer_name);
+					if($i!=count($this->objLayer)-1)
+						$add_wms_string .= ",";
+				$add_wms_string .= "', transparent: 'true'";
+				$add_wms_string .= ",format: '".$this->gui_wms_mapformat."'});\n";
+				if($base)
+					$add_wms_string .= 	"wms_".$this->wms_id.".isBaseLayer=true;\n";
+				$add_wms_string .= 	"wms_".$this->wms_id.".setVisibility(".($this->gui_wms_visible=="1"?"true":"false").");\n";
+				$add_wms_string .= "ol_map.addLayer(wms_".$this->wms_id.");\n";
+		echo $add_wms_string;
+	 * Compares this WMS to another WMS.
+	 * @return boolean false, if
+	 * 					- the capabilities URLs don't match
+	 * 					- the layer count is different
+	 * 					- the layer names are different
+	 * @param $anotherWms wms this is just another WMS object
+	public function equals ($anotherWms) {
+		// If the getMap URLs are not equal, the WMS are not equal.
+		if ($this->wms_getmap != $anotherWms->wms_getmap) {
+//			$e = new mb_notice($this . " != " . $anotherWms . " (getMap URL)");
+			return false;
+		// If the layer count is different, the WMS are not equal.
+		if (count($this->objLayer) != count($anotherWms->objLayer)) {
+//			$e = new mb_notice($this . " != " . $anotherWms . " (layer count: " . count($this->objLayer) . ":" . count($anotherWms->objLayer). ")");
+			return false;
+		// If the layer names are different, the WMS are not equal.
+		for ($i = 0; $i < count($this->objLayer); $i++) {
+			$name1 = $this->objLayer[$i]->layer_name;
+			$name2 = $anotherWms->objLayer[$i]->layer_name;
+			if ($name1 != $name2) {
+//				$e = new mb_notice($this . " != " . $anotherWms . " (layer names, " . $name1 . " vs. " . $name2 . ")");
+				return false;
+//		$e = new mb_notice($this . " == " . $anotherWms);
+		return true;
+	 * The other WMS must be the same as this WMS, but with different
+	 * application settings. These application settings are copied,
+	 * the local settings are overwritten.
+	 * @return boolean true if the settings could be copied; false
+	 * 					when an error occured.
+	 * @param $anotherWms wms The same WMS with possibly other settings
+	public function copyConfiguration ($anotherWms) {
+		if (!$this->equals($anotherWms)) {
+			$e = new mb_exception("class_wms.php: copyConfiguration(): parameters cannot be copied, it's a different WMS.");
+			return false;
+			$myCurrentLayer = $this->objLayer[$i];
+			$theirCurrentLayer = $anotherWms->objLayer[$i];
+			$myCurrentLayer->gui_layer_selectable = $theirCurrentLayer->gui_layer_selectable;
+			$myCurrentLayer->gui_layer_visible    = $theirCurrentLayer->gui_layer_visible;
+			$myCurrentLayer->gui_layer_queryable  = $theirCurrentLayer->gui_layer_queryable;
+			$myCurrentLayer->gui_layer_querylayer = $theirCurrentLayer->gui_layer_querylayer;
+			$myCurrentLayer->gui_layer_style      = $theirCurrentLayer->gui_layer_style;
+	 * Removes duplicate WMS from an array of WMS. To find duplicates,
+	 * two WMS are compared via equals().
+	 * @return wms[]
+	 * @param $wmsArray wms[]
+	public static function merge ($wmsArray) {
+		$e = new mb_notice("before: " . implode(", ", $wmsArray));
+		if (!is_array($wmsArray)) {
+			$e = new mb_exception("class_wms.php: merge(): parameter is NOT an array.");
+			return array();
+		if (count($wmsArray) == 0) {
+			$e = new mb_exception("class_wms.php: merge(): parameter is an EMPTY array.");
+			return array();
+		$newWmsArray = array();
+		while (count($wmsArray) > 0) {
+			$currentWms = array_pop($wmsArray);
+			$isNewWms = true;
+			if (get_class($currentWms) != "wms") {
+				$e = new mb_exception("class_wms.php: merge(): current WMS is not a WMS object, but a " . get_class($currentWms));
+			else {
+				for ($i = 0; $i < count($newWmsArray) && $isNewWms; $i++) {
+					if ($currentWms->equals($newWmsArray[$i])) {
+						$isNewWms = false;
+				if ($isNewWms) {
+//					$e = new mb_notice("adding WMS " . $currentWms);
+					array_push($newWmsArray, $currentWms);
+		// reversal of the array, because the elements were popped
+		// from another array before.
+//		$e = new mb_notice("after: " . implode(", ", array_reverse($newWmsArray)));
+		return array_reverse($newWmsArray);
+	public function __toString () {
+		return $this->wms_title;
 	function createObjFromXML($url, $cert = "", $pass = ""){
 		$x = new connector();
@@ -691,13 +831,80 @@
 	  function stripEndlineAndCarriageReturn($string) {
 	  	return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
-	  function createJsObjFromWMS($parent=0){
+		function createJsObjFromWMS($parent=0){
+			echo $this->createJsObjFromWMS_($parent);
+	function newLayer ($currentLayer, $currentExtent) {
+		$pos = $currentLayer["extension"]["LAYER_POS"];
+		$parent = $currentLayer["extension"]["LAYER_PARENT"];
+		$this->addLayer($pos, $parent);
+		// set layer data
+		$layerIndex = count($this->objLayer) - 1;
+		$newLayer = $this->objLayer[$layerIndex];
+		$newLayer->layer_uid = $currentLayer["extension"]["LAYER_ID"];
+		$newLayer->layer_name = $currentLayer["name"];
+		$newLayer->layer_title = $currentLayer["title"];
+		$newLayer->layer_dataurl_href = $currentLayer["dataurl"];
+		$newLayer->layer_pos = $currentLayer["extension"]["LAYER_POS"];
+		$newLayer->layer_queryable = $currentLayer["queryable"];
+		$newLayer->layer_minscale = $currentLayer["extension"]["MINSCALE"];
+		$newLayer->layer_maxscale = $currentLayer["extension"]["MAXSCALE"];
+		$newLayer->layer_metadataurl = $currentLayer["metadataurl"];
+		$newLayer->gui_layer_wms_id = $currentLayer["extension"]["WMS_LAYER_ID"];
+		$newLayer->gui_layer_status = $currentLayer["extension"]["GUI_STATUS"];
+		$newLayer->gui_layer_style = ""; // TODO: Add correct data
+		$newLayer->gui_layer_selectable = $currentLayer["extension"]["GUI_SELECTABLE"];
+		$newLayer->gui_layer_visible = $currentLayer["visible"];
+		$newLayer->gui_layer_queryable = $currentLayer["extension"]["GUI_QUERYABLE"];
+		$newLayer->gui_layer_querylayer = $currentLayer["extension"]["QUERYLAYER"];
+		$newLayer->gui_layer_minscale = $currentLayer["extension"]["GUI_MINSCALE"];
+		$newLayer->gui_layer_maxscale = $currentLayer["extension"]["GUI_MAXSCALE"];
+		if (isset($currentLayer["extension"]["WFSFEATURETYPE"])) {
+			$newLayer->gui_layer_wfs_featuretype = $currentLayer["extension"]["WFSFEATURETYPE"];
+		$newLayer->layer_abstract = $currentLayer["abstract"];
+		// set layer epsg
+		$newLayer->layer_epsg = array();
+		if ($currentExtent !== null) {
+			$currentLayerEpsg = array();
+			$currentLayerEpsg["epsg"] = $currentExtent->epsg;
+			$currentLayerEpsg["minx"] = $currentExtent->min->x;
+			$currentLayerEpsg["miny"] = $currentExtent->min->y;
+			$currentLayerEpsg["maxx"] = $currentExtent->max->x;
+			$currentLayerEpsg["maxy"] = $currentExtent->max->y;
+			array_push($newLayer->layer_epsg, $currentLayerEpsg);
+		// set layer style
+		for ($i = 0; $i < count($currentLayer["format"]); $i++) {
+			$layerStyleIndex = count($newLayer->gui_layer_style) - 1;
+			$newLayer->layer_style[$layerStyleIndex] = array();
+			$currentStyle = $newLayer->layer_style[$layerStyleIndex];
+			$currentStyle["name"] = $currentLayer["style"][$i]["name"];
+			$currentStyle["title"] = $currentLayer["style"][$i]["title"];
+			$currentStyle["legendurl"] = $currentLayer["style"][$i]["legendurl"];
+			$currentStyle["legendurl_format"] = $currentLayer["style"][$i]["legendurl_type"];
+	  function createJsObjFromWMS_($parent=0){
+	  	$str = "";
-			echo "alert('Error: no valid capabilities-document !!');";
+			$str .= "alert('Error: no valid capabilities-document !!');";
 			die; exit;
 			if($parent){
-				echo "parent.";
+				$str .=  "parent.";
@@ -719,19 +926,19 @@
 					"'" . $this->gui_wms_opacity ."'," .
 					"'" . $this->gui_wms_sldurl ."" .
-			echo $add_wms_string;
+			$str .=  $add_wms_string;
 		for($i=0;$i<count($this->data_format);$i++){
 			if($parent){
-				echo "parent.";
-			echo "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');\n";
+			$str .= "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');\n";
 		for($i=0; $i<count($this->objLayer); $i++){
 			if($parent){
-				echo "parent.";
-			print ("wms_add_layer('".
+			$str .=  "wms_add_layer('".
 				$this->objLayer[$i]->layer_parent ."','".
 				$this->objLayer[$i]->layer_uid ."','".
 				addslashes($this->objLayer[$i]->layer_name) . "','".
@@ -751,37 +958,43 @@
 				$this->objLayer[$i]->gui_layer_querylayer ."','".
 				$this->objLayer[$i]->gui_layer_minscale ."','".
 				$this->objLayer[$i]->gui_layer_maxscale ."','".
-				$this->objLayer[$i]->gui_layer_wfs_featuretype ."');\n");
+				$this->objLayer[$i]->gui_layer_wfs_featuretype ."');\n";
 			for($j=0; $j<count($this->objLayer[$i]->layer_epsg);$j++){
 				if($i==0){
 					if($parent){
-					echo "parent.";
-					print("wms_addSRS('".
+					$str .= "wms_addSRS('".
 						$this->objLayer[$i]->layer_epsg[$j]["epsg"] ."','".
 						$this->objLayer[$i]->layer_epsg[$j]["minx"] ."','".
 						$this->objLayer[$i]->layer_epsg[$j]["miny"] ."','".
 						$this->objLayer[$i]->layer_epsg[$j]["maxx"] ."','".
-						$this->objLayer[$i]->layer_epsg[$j]["maxy"] ."');\n");
+						$this->objLayer[$i]->layer_epsg[$j]["maxy"] ."');\n";
 				if($parent){
-				echo "parent.";
-				print("layer_addEpsg('".
+				$str .= "layer_addEpsg('".
 			for($j=0; $j<count($this->objLayer[$i]->layer_style);$j++){
 				if($parent){
-				echo "parent.";
-				print("wms_addLayerStyle('".$this->objLayer[$i]->layer_style[$j]["name"]."', '".$this->objLayer[$i]->layer_style[$j]["title"]."', ".$j.",".$i.",'".$this->objLayer[$i]->layer_style[$j]["legendurl"]."', '".$this->objLayer[$i]->layer_style[$j]["legendformat"]."');\n");
+				$str .= "wms_addLayerStyle('".$this->objLayer[$i]->layer_style[$j]["name"].
+					"', '".$this->objLayer[$i]->layer_style[$j]["title"].
+					"', ".$j.
+					",".$i.
+					",'".$this->objLayer[$i]->layer_style[$j]["legendurl"].
+					"', '".$this->objLayer[$i]->layer_style[$j]["legendformat"]."');\n";
+		return $str;
 	  function createJsLayerObjFromWMS($parent=0, $layer_name){
@@ -1720,6 +1933,141 @@
 	/** end createObjfromDB **/
+	* creatObjfromDBNoGui
+	  function createObjFromDBNoGui($wms_id){
+	   	$sql = "Select * from wms where wms_id = $1 ";
+		$v = array($wms_id);
+		$t = array('i');
+		$res_wms = db_prep_query($sql,$v,$t);
+		$count_wms=0;
+		while($row2 = db_fetch_array($res_wms)){
+			$this->wms_id = $row2["wms_id"];
+			$this->wms_version = $row2["wms_version"];
+			$this->wms_title = $this->stripEndlineAndCarriageReturn($row2["wms_title"]);
+			$this->wms_abstract = $this->stripEndlineAndCarriageReturn($row2["wms_abstract"]);
+			$wmsowsproxy = $row2["wms_owsproxy"];
+			#$wmsowsproxy = "test";
+			if($wmsowsproxy != ""){
+				$owsproxyurl = OWSPROXY."/".session_id()."/".$wmsowsproxy."?";
+				$this->wms_getmap = $owsproxyurl;
+				$this->wms_getcapabilities =  $owsproxyurl;
+				$this->wms_getfeatureinfo = $owsproxyurl;
+				$this->wms_getlegendurl = $owsproxyurl;
+			else{
+				$this->wms_getmap =  $row2["wms_getmap"];
+				$this->wms_getcapabilities =  $row2["wms_getcapabilities"];
+				$this->wms_getfeatureinfo = $row2["wms_getfeatureinfo"];
+				$this->wms_getlegendurl = $row2["wms_getlegendurl"];
+			$this->wms_getcapabilities_doc = $row2["wms_getcapabilities_doc"];
+			$this->wms_filter = $row2["wms_filter"];
+			$this->wms_supportsld = $row2["wms_supportsld"];
+			$this->wms_userlayer = $row2["wms_userlayer"];
+			$this->wms_userstyle = $row2["wms_userstyle"];
+			$this->wms_remotewfs = $row2["wms_remotewfs"];
+			#some default
+			$this->gui_wms_visible = 1;
+			$this->gui_wms_opacity = 100;
+			$this->gui_wms_epsg=$row["gui_wms_epsg"];
+			$this->gui_wms_sldurl = $row["gui_wms_sldurl"];
+			$count_wms++;
+		### formats
+		$sql = "SELECT * FROM wms_format WHERE fkey_wms_id = $1 ";
+		$t = array('i');
+		$count_format=0;
+		while($row3 = db_fetch_array($res_wms)){
+			$this->data_type[$count_format] = $row3["data_type"];
+			$this->data_format[$count_format] = $row3["data_format"];
+			$count_format++;
+		$sql = "Select * from layer where fkey_wms_id = $1";
+		$t = array('i');
+		$res_layer = db_prep_query($sql,$v,$t);
+		$count_layer=0;
+		while($row2 = db_fetch_array($res_layer)){
+			$this->addLayer($row2["layer_pos"],$row2["layer_parent"]);
+			$layer_cnt=count($this->objLayer)-1;
+			$this->objLayer[$layer_cnt]->layer_uid = $row2["layer_id"];
+			$this->objLayer[$layer_cnt]->layer_name =$row2["layer_name"];
+			$this->objLayer[$layer_cnt]->layer_title =$row2["layer_title"];
+			$this->objLayer[$layer_cnt]->layer_dataurl_href =$row2["layer_dataurl"];
+			$this->objLayer[$layer_cnt]->layer_metadataurl =$row2["layer_metadataurl"];
+			$this->objLayer[$layer_cnt]->layer_pos =$row2["layer_pos"];
+			$this->objLayer[$layer_cnt]->layer_queryable =$row2["layer_pos"];
+			$this->objLayer[$layer_cnt]->layer_queryable =$row2["layer_queryable"];
+			$this->objLayer[$layer_cnt]->layer_minscale =$row2["layer_minscale"];
+			$this->objLayer[$layer_cnt]->layer_maxscale = $row2["layer_maxscale"];
+			if($this->objLayer[$layer_cnt]->layer_minscale == ""){
+				$this->objLayer[$layer_cnt]->layer_minscale = 0;
+			if($this->objLayer[$layer_cnt]->layer_maxscale == ""){
+				$this->objLayer[$layer_cnt]->layer_maxscale = 0;
+			$this->objLayer[$layer_cnt]->gui_layer_minscale = $this->objLayer[$layer_cnt]->layer_minscale;
+			$this->objLayer[$layer_cnt]->gui_layer_maxscale = $this->objLayer[$layer_cnt]->layer_maxscale;
+			$sql = "Select * from layer_epsg where fkey_layer_id = $1 ORDER BY fkey_layer_id";
+			$v = array($this->objLayer[$layer_cnt]->layer_uid);
+			$t = array('i');
+			$res_layer_epsg = db_prep_query($sql,$v,$t);
+			$count_layer_epsg=0;
+			while($row2 = db_fetch_array($res_layer_epsg)){
+				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["epsg"]=$row2["epsg"];
+				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["minx"]=$row2["minx"];
+				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["miny"]=$row2["miny"];
+				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["maxx"]=$row2["maxx"];
+				$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["maxy"]=$row2["maxy"];
+				$count_layer_epsg++;
+			### handle styles
+			$sql = "SELECT * FROM layer_style WHERE fkey_layer_id = $1 ";
+			$t = array('i');
+			$res_style = db_prep_query($sql,$v,$t);
+			$count_layer_style = 0;
+			while($row2 = db_fetch_array($res_style)){
+				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["name"]=$row2["name"];
+				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["title"]=$row2["title"];
+					if($row2["legendurl"]!=''){
+						$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]=$owsproxyurl.
+						"REQUEST=getlegendgraphic&VERSION=".$this->wms_version."&LAYER=".$this->objLayer[$layer_cnt]->layer_name."&FORMAT=".$row2["legendurlformat"].
+						"&STYLE=".$row2["name"];
+				else{
+						$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]=$row2["legendurl"];
+						#$e = new mb_exception("legendurl = ".$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]);
+				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurlformat"]=$row2["legendurlformat"];
+				$count_layer_style++;
+			$count_layer++;
+	/** end createObjfromDBNoGui **/
 	* function checkObjExistsInDB()
 	* this function checks wether the onlineresource already exists in the database.
@@ -1786,10 +2134,45 @@
 		if($this->wms_getcapabilities == '' || $this->wms_getmap == '' ){
 			echo "<br>Missing parameters: <br>";
 			$this->displayWMS();
-			echo "<br> Data not commited<br>";
+			print_r($this);
+			echo "<br> Data not committed<br>";
 			die();
+	 * Selects all WMS of the current user from the database.
+	 * Then it creates the corresponding WMS object and returns
+	 * these objects as an array.
+	 * @return wms[]
+	 * @param $appId String
+	public static function selectMyWmsByApplication ($appId) {
+		// check if user is permitted to access the application
+		$currentUser = new User($_SESSION["mb_user_id"]);
+		$appArray = $currentUser->getApplicationsByPermission(false);
+		if (!in_array($appId, $appArray)) {
+			$e = new mb_warning("class_wms.php: selectMyWmsByApplication(): User '" . $currentUser . "' is not allowed to acces application '" . $appId . "'.");
+			return array();
+		// get WMS of this application
+		$sql = "SELECT fkey_wms_id FROM gui_wms WHERE " .
+				"fkey_gui_id = $1 ORDER BY gui_wms_position";
+		$v = array($appId);
+		$t = array('s');
+		$res = db_prep_query($sql,$v,$t);
+		// instantiate PHP objects and store in array
+		$wmsArray = array();
+		while ($row = db_fetch_array($res)) {
+			$currentWms = new wms();
+			$currentWms->createObjFromDB($appId, $row["fkey_wms_id"]);
+			array_push($wmsArray, $currentWms);
+		return $wmsArray;
 class layer extends wms {
 	var $layer_id;
@@ -1820,5 +2203,11 @@
 		$this->layer_parent = $parent;
 		//var_dump($this);
+		$e = new mb_exception("TITLE: " . $this->layer_title);
+		return $this->layer_title;
\ No newline at end of file
More information about the Mapbender_commits mailing list
