[Mapbender-commits] r2868 - in branches/nimix_dev: conf core http/css
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 18 12:07:47 EDT 2008
Author: nimix
Date: 2008-08-18 12:07:47 -0400 (Mon, 18 Aug 2008)
New Revision: 2868
Added:
   branches/nimix_dev/http/css/addwms.css
   branches/nimix_dev/http/css/print.css
   branches/nimix_dev/conf/digitize_default.conf
   branches/nimix_dev/conf/mapbender.conf-dist
   branches/nimix_dev/conf/session.conf
   branches/nimix_dev/conf/wfs_additional_spatial_search.conf
   branches/nimix_dev/core/globalSettings.php
   branches/nimix_dev/core/i18n.php
   branches/nimix_dev/core/system.php
   branches/nimix_dev/http/css/administration_alloc.css
merge
Modified: branches/nimix_dev/conf/digitize_default.conf
--- branches/nimix_dev/conf/digitize_default.conf	2008-08-18 16:03:32 UTC (rev 2867)
+++ branches/nimix_dev/conf/digitize_default.conf	2008-08-18 16:07:47 UTC (rev 2868)
@@ -11,6 +11,9 @@
 addButtonDig("delBasePoint", 1, "delete_node_off.png", "", "", 125, 0);
 addButtonDig("clear", 1, "del_off.png", "", "", 150, 0);
+//definition of directory of digitize buttons
+buttonDig_imgdir = "../img/button_digitize/";
 var buttonDig_wfs_src = "geomInfo.png";
 var buttonDig_remove_src = "geomRemove.png";
 var buttonDig_removeDb_src = "geomRemoveDb.png";
Modified: branches/nimix_dev/conf/mapbender.conf-dist
--- branches/nimix_dev/conf/mapbender.conf-dist	2008-08-18 16:03:32 UTC (rev 2867)
+++ branches/nimix_dev/conf/mapbender.conf-dist	2008-08-18 16:07:47 UTC (rev 2868)
@@ -94,6 +94,11 @@
 define("CONNECTION_PASSWORD", "<password>");
+# HOSTs not for Proxy (curl)
+define("NOT_PROXY_HOSTS", "<ip>,<ip>,<ip>");
 # security: path to modules
@@ -158,4 +163,4 @@
   $GEOS_PORT =GEOS_PORT;
   $GEOS_OWNER=GEOS_OWNER;
   $GEOS_PW=GEOS_PW;
\ No newline at end of file
Modified: branches/nimix_dev/conf/session.conf
--- branches/nimix_dev/conf/session.conf	2008-08-18 16:03:32 UTC (rev 2867)
+++ branches/nimix_dev/conf/session.conf	2008-08-18 16:07:47 UTC (rev 2868)
@@ -8,6 +8,18 @@
 $_SESSION["mb_myPOI"] = $_REQUEST["mb_myPOI"];
 $_SESSION["mb_myPOI2SCALE"] = $_REQUEST["mb_myPOI2SCALE"];
+$_SESSION["mb_lang"] = $_REQUEST["lang"];
+$_SESSION["command"] = strtoupper($_REQUEST["COMMAND"]);
+$i = 1;
+$_SESSION["wms"] = array();
+while ($_REQUEST["wms".$i]) {
+	array_push($_SESSION["wms"], urldecode($_REQUEST["wms".$i]));
+	$i++;
+unset($i);
 $_SESSION["mb_myWmc"] = "";
 $_SESSION["mb_myWmc_action"] = "";
 if ($_REQUEST["wmc_id"]) {
@@ -22,4 +34,4 @@
 	$_SESSION["mb_myWmc"] = $_REQUEST["append_wmc_id"];
 	$_SESSION["mb_myWmc_action"] = "append";
Modified: branches/nimix_dev/conf/wfs_additional_spatial_search.conf
--- branches/nimix_dev/conf/wfs_additional_spatial_search.conf	2008-08-18 16:03:32 UTC (rev 2867)
+++ branches/nimix_dev/conf/wfs_additional_spatial_search.conf	2008-08-18 16:07:47 UTC (rev 2868)
@@ -15,6 +15,8 @@
 var spatialRequestIsSetMessage = "Gebiet eingegrenzt, bitte OK klicken!";
 var clearFilterButtonLabel = "Neu";
+var noResultMsg = "Kein Ergebnis";
 var buttonWfs_imgdir = "../img/button_gray/";
 var buttonWfs_zIndex = 10;
Modified: branches/nimix_dev/core/globalSettings.php
--- branches/nimix_dev/core/globalSettings.php	2008-08-18 16:03:32 UTC (rev 2867)
+++ branches/nimix_dev/core/globalSettings.php	2008-08-18 16:07:47 UTC (rev 2868)
@@ -1,12 +1,29 @@
 <?php
+# $Id$
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 // start the session
 session_start();
+// All data Mapbender handles internally are UTF-8
-// All data Mapbender handles internally are UTF-8
 mb_internal_encoding("UTF-8");
Property changes on: branches/nimix_dev/core/globalSettings.php
___________________________________________________________________
   + HeadURL Id LastChangedBy LastChangedDate LastChangedRevision
Modified: branches/nimix_dev/core/i18n.php
--- branches/nimix_dev/core/i18n.php	2008-08-18 16:03:32 UTC (rev 2867)
+++ branches/nimix_dev/core/i18n.php	2008-08-18 16:07:47 UTC (rev 2868)
@@ -1,8 +1,26 @@
 <?php
+# $Id$
 	function _mb ($someString) {
 		if (USE_I18N) {
+//			$e = new mb_notice("Translating '" . $someString . "' to language " . $_SESSION["mb_locale"] . ": '" . _($someString) . "'");
 			return _($someString);
 		return $someString;
Property changes on: branches/nimix_dev/core/i18n.php
Modified: branches/nimix_dev/core/system.php
--- branches/nimix_dev/core/system.php	2008-08-18 16:03:32 UTC (rev 2867)
+++ branches/nimix_dev/core/system.php	2008-08-18 16:07:47 UTC (rev 2868)
@@ -1,5 +1,5 @@
 <?php
-# $Id:$
+# $Id$
@@ -19,9 +19,9 @@
 # mapbender version
-define("MB_VERSION_NUMBER", "2.5.0");
-define("MB_VERSION_APPENDIX", "RC2");
-define("MB_RELEASE_DATE", mktime(0,0,0,4,21,2008));//h, min,sec,month,day,year
+define("MB_VERSION_NUMBER", "2.6");
+define("MB_VERSION_APPENDIX", "trunk");
+define("MB_RELEASE_DATE", mktime(0,0,0,7,22,2008));//h, min,sec,month,day,year
 # constants from map.js
Property changes on: branches/nimix_dev/core/system.php
Copied: branches/nimix_dev/http/css/addwms.css (from rev 2864, trunk/mapbender/http/css/addwms.css)
--- branches/nimix_dev/http/css/addwms.css	                        (rev 0)
+++ branches/nimix_dev/http/css/addwms.css	2008-08-18 16:07:47 UTC (rev 2868)
@@ -0,0 +1,80 @@
+	font: 12px normal Verdana,Arial,Helvetica,sans-serif;
+body {
+	margin: 0;
+	padding: 10px;
+	color: #000;
+	background-color: #FFF;
+h1, h2 {
+	margin: .5em 0;
+	padding: 0;
+	font-size: 1.5em;
+h1 {
+	font-weight: bold;
+p em {
+	font-style: italic;
+form fieldset {
+	margin: 0;
+	padding: 0;
+	border: 0;
+form fieldset legend {
+	visibility: hidden;
+	display: none;
+form p {
+	line-height: 1.25em;
+table {
+	width: 100%;
+	border-collapse: collapse;
+table tbody tr.alternate {
+	background-color: #EEE;
+table tbody tr:hover {
+	background-color: #CCC;
+table thead th {
+	padding: 10px 5px;
+	text-align: left;
+	color: #FFF;
+	background-color: #000;
+	border: 1px solid #000;
+	border-top: 0;
+table tbody td {
+	padding: 5px;
+	cursor: pointer;
+table tbody td strong {
+h2#resultString, p#progressIndicator, table#resultTable {
+	display: none;
+p#progressIndicator img {
+	vertical-align: middle;
Modified: branches/nimix_dev/http/css/administration_alloc.css
--- branches/nimix_dev/http/css/administration_alloc.css	2008-08-18 16:03:32 UTC (rev 2867)
+++ branches/nimix_dev/http/css/administration_alloc.css	2008-08-18 16:07:47 UTC (rev 2868)
@@ -1,16 +1,28 @@
 body{
 	background-color : #ffffff;
-	font-family: Arial, Helvetica, sans-serif;
+	font-family: Verdana, Geneva, Arial, Helvetica, sans-serif;
 select {
 	font-size: 11;
-	font-family: "Times New Roman", Times, serif;
 	width: 200px;
 	font-weight : bold;
 .select_short{
 	width: auto;
+table{
+	font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;
+	font-size:11;
+.wms_button{
+	color: black;
+	border: solid thin;
+	height:22px;
+	width:60px;
 checkbox{
 	background-color : #0066ff;
@@ -93,4 +105,4 @@
 	left: auto;
 	color : Red;
 	font-size : 13;
Copied: branches/nimix_dev/http/css/print.css (from rev 2864, trunk/mapbender/http/css/print.css)
--- branches/nimix_dev/http/css/print.css	                        (rev 0)
+++ branches/nimix_dev/http/css/print.css	2008-08-18 16:07:47 UTC (rev 2868)
@@ -0,0 +1,45 @@
+body {
+	margin: 0;
+	padding: 10px;
+	color: #000;
+form fieldset {
+	margin: 0;
+	padding: 0;
+	border: 0;
+form p {
+	white-space: nowrap;
+form p label {
+	display: block;
+	float: left;
+	width: 7em;
+	padding-right: 1em;
+form p label em {
+	display: block;
+	color: #666;
+form p input#mylegendcheckbox {
+	margin: 0;
+	padding: 0;
+form p input#print {
+	margin-left: 8em;
More information about the Mapbender_commits mailing list
