[Mapbender-commits] r2867 - branches/nimix_dev/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 18 12:03:32 EDT 2008
Author: nimix
Date: 2008-08-18 12:03:32 -0400 (Mon, 18 Aug 2008)
New Revision: 2867
Removed:
   branches/nimix_dev/http/classes/class_wmc.php
   branches/nimix_dev/http/classes/class_SaveLegend.php
   branches/nimix_dev/http/classes/class_administration.php
   branches/nimix_dev/http/classes/class_bbox.php
   branches/nimix_dev/http/classes/class_checkInput.php
   branches/nimix_dev/http/classes/class_connector.php
   branches/nimix_dev/http/classes/class_gml2.php
   branches/nimix_dev/http/classes/class_gui.php
   branches/nimix_dev/http/classes/class_keyword.php
   branches/nimix_dev/http/classes/class_kml.php
   branches/nimix_dev/http/classes/class_kml_geometry.php
   branches/nimix_dev/http/classes/class_kml_line.php
   branches/nimix_dev/http/classes/class_kml_linearring.php
   branches/nimix_dev/http/classes/class_kml_multigeometry.php
   branches/nimix_dev/http/classes/class_kml_ows.php
   branches/nimix_dev/http/classes/class_kml_parser_ows.php
   branches/nimix_dev/http/classes/class_kml_placemark.php
   branches/nimix_dev/http/classes/class_kml_point.php
   branches/nimix_dev/http/classes/class_kml_polygon.php
   branches/nimix_dev/http/classes/class_layer_monitor.php
   branches/nimix_dev/http/classes/class_locale.php
   branches/nimix_dev/http/classes/class_log.php
   branches/nimix_dev/http/classes/class_map.php
   branches/nimix_dev/http/classes/class_metadata.php
   branches/nimix_dev/http/classes/class_monitor.php
   branches/nimix_dev/http/classes/class_point.php
   branches/nimix_dev/http/classes/class_weldMaps2Image.php
   branches/nimix_dev/http/classes/class_weldMaps2PNG.php
   branches/nimix_dev/http/classes/class_wfs.php
   branches/nimix_dev/http/classes/class_wfs_conf.php
   branches/nimix_dev/http/classes/class_wmcToXml.php
   branches/nimix_dev/http/classes/class_wms.php
merge
Modified: branches/nimix_dev/http/classes/class_SaveLegend.php
--- branches/nimix_dev/http/classes/class_SaveLegend.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_SaveLegend.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -22,8 +22,9 @@
 * getlegendurl
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 require_once(dirname(__FILE__)."/class_stripRequest.php");
-require_once(dirname(__FILE__)."/class_mb_exception.php");
 require_once(dirname(__FILE__)."/class_connector.php");
 class SaveLegend{
@@ -63,4 +64,4 @@
\ No newline at end of file
Modified: branches/nimix_dev/http/classes/class_administration.php
--- branches/nimix_dev/http/classes/class_administration.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_administration.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -16,12 +16,9 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/class_user.php");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
 require(dirname(__FILE__) . "/phpmailer-1.72/class.phpmailer.php");
@@ -706,52 +703,14 @@
 		return $user->getWmcByOwner();
-	function getGuisByPermission($mb_user_id,$ignoreublic){
-		$arrayGuis = array();
-		$mb_user_groups = array();
-		$sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
-		$v = array($mb_user_id);
-		$t = array("i");
-		$res_groups = db_prep_query($sql_groups,$v,$t);
-		$cnt_groups = 0;
-		while($row = db_fetch_array($res_groups)){
-			$mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
-			$cnt_groups++;
+	 * @deprecated
+	function getGuisByPermission($mb_user_id,$ignorepublic){
+		$e = new mb_notice("administration->getGuisByPermission is deprecated, use user->getApplicationsByPermission instead!");
+		$user = new User($mb_user_id);
+		return $user->getApplicationsByPermission($ignorepublic);
-		if($cnt_groups > 0){
-			$v = array();
-			$t = array();
-			$sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
-			$sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
-			for($i=0; $i<count($mb_user_groups);$i++){
-				if($i > 0){$sql_g .= ",";}
-				$sql_g .= "$".strval($i+1);
-				array_push($v,$mb_user_groups[$i]);
-				array_push($t,"i");
-			$sql_g .= ") GROUP BY gui.gui_id";
-			$res_g = db_prep_query($sql_g,$v,$t);
-			while($row = db_fetch_array($res_g)){
-				array_push($arrayGuis,$row["gui_id"]);
-		$sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
-		$sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
-		if (!isset($ignore_public) OR $ignore_public== false){
-			$sql_guis .= " AND gui.gui_public = 1 ";
-		$sql_guis .= " GROUP BY gui.gui_id";
-		$t = array("i");
-		$res_guis = db_prep_query($sql_guis,$v,$t);
-		$guis = array();
-		while($row = db_fetch_array($res_guis)){
-			if(!in_array($row['gui_id'],$arrayGuis)){
-		return $arrayGuis;
 	function getWmsByOwnGuis($array_gui_ids){
 		if(count($array_gui_ids)>0){
@@ -1185,44 +1144,15 @@
 	 /** identifies the Conf-FeatureServices where the current user is owner
+	 * @deprecated
 	 * @param integer 		userid the user-ID of the current user
 	 * @return integer[] 	the IDs of the wfs_conf-table
 	 function getWfsConfByPermission($userid){
-	 	$guisByPer = array();
-//	 	1.
-	 	$guisByPer = $this->getGuisByPermission($userid, true);
-//	 	2.
-		if(count($guisByPer)>0){
-			$v = array();
-			$t = array();
-			$sql = "SELECT wfs_conf.wfs_conf_id  FROM gui_wfs_conf, wfs_conf " .
-					"where wfs_conf.wfs_conf_id = gui_wfs_conf.fkey_wfs_conf_id " .
-					"and gui_wfs_conf.fkey_gui_id IN(";
-			for($i=0; $i<count($guisByPer); $i++){
-				if($i>0){ $sql .= ",";}
-				$sql .= "$".strval($i+1);
-				array_push($v, $guisByPer[$i]);
-				array_push($t, "s");
+		$e = new mb_notice("administration->getWfsConfByPermission is deprecated, use user->getWfsConfByPermission instead!");
+		$user = new User($userid);
+		return $user->getWfsConfByPermission();
-			$sql .= ") GROUP BY wfs_conf.wfs_conf_id ORDER BY wfs_conf.wfs_conf_id";
-			$res = db_prep_query($sql,$v,$t);
-			$ownWFSconfs = array();
-			$i=0;
-			while($row = db_fetch_array($res)){
-				$ownWFSconfs[$i] = $row['wfs_conf_id'];
-				$i++;
-		return $ownWFSconfs;
Modified: branches/nimix_dev/http/classes/class_bbox.php
--- branches/nimix_dev/http/classes/class_bbox.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_bbox.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,11 +17,7 @@
-require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
-require_once(dirname(__FILE__)."/../classes/class_point.php");
  * A bounding box consisting of an lower left and an upper right point, and an EPSG.
Modified: branches/nimix_dev/http/classes/class_checkInput.php
--- branches/nimix_dev/http/classes/class_checkInput.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_checkInput.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,6 +17,8 @@
 class checkInput{
 	var $v;
 	function checkInput($q,$v,$t){
@@ -51,4 +53,4 @@
Modified: branches/nimix_dev/http/classes/class_connector.php
--- branches/nimix_dev/http/classes/class_connector.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_connector.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,11 +17,8 @@
-mb_internal_encoding("UTF-8");
  * Establishes a connection to a given URL (and loads the content).
  * Supports HTTP (GET and POST), cURL and socket connections.
@@ -48,6 +45,11 @@
 		if ($url&&$url!=="") {
 			$this->load($url);
+		// fill array (HOSTs not for Proxy)
+		if (http_ip!=""){
+			$NOT_PROXY_HOSTS_array = split(",", NOT_PROXY_HOSTS);
@@ -56,7 +58,12 @@
 	public function load($url) {
 		switch ($this->connectionType) {
 			case "CURL":
-				$this->file = $this->getCURL($url);
+				if (in_array($host, $NOT_PROXY_HOSTS_array)){
+					$this->file = $this->getHTTP($url);
+				else {
+					$this->file = $this->getCURL($url);
 				break;
 			case "HTTP":
@@ -264,4 +271,4 @@
Modified: branches/nimix_dev/http/classes/class_gml2.php
--- branches/nimix_dev/http/classes/class_gml2.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_gml2.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -16,10 +16,11 @@
 # You should have received a copy of the GNU General Public License
 require_once(dirname(__FILE__)."/../classes/class_connector.php");
 require_once(dirname(__FILE__)."/../classes/class_json.php");
 class gml2 {
 	var $geomtype_point = 'Point';
 	var $geomtype_polygon = 'Polygon';
Modified: branches/nimix_dev/http/classes/class_gui.php
--- branches/nimix_dev/http/classes/class_gui.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_gui.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,12 +17,8 @@
-require_once(dirname(__FILE__)."/../classes/class_element.php");
-$con = db_connect($DBSERVER,$OWNER,$PW);
  * GUI is a set of GUI elements and services.
@@ -293,4 +289,4 @@
Modified: branches/nimix_dev/http/classes/class_keyword.php
--- branches/nimix_dev/http/classes/class_keyword.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_keyword.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -16,9 +16,7 @@
-include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
  * class to handle keywords for services
@@ -293,7 +291,7 @@
 		global $con;
 		$sql = "DELETE FROM keyword WHERE NOT EXISTS (SELECT fkey_keyword_id FROM layer_keyword WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id);";
 		//$sql .= " AND NOT EXISTS  (SELECT fkey_keyword_id FROM wms_keyword WHERE keyword.keyword_id = wms_keyword.fkey_keyword_id);";
-		$res = db_prep_query($sql);
+		$res = db_query($sql);
 		if($res!=FALSE){
 			return true;
Modified: branches/nimix_dev/http/classes/class_kml.php
--- branches/nimix_dev/http/classes/class_kml.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_kml.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -16,8 +16,9 @@
 class kml {
 		var $kml_id;
@@ -172,4 +173,4 @@
 // end class
Modified: branches/nimix_dev/http/classes/class_kml_geometry.php
--- branches/nimix_dev/http/classes/class_kml_geometry.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_kml_geometry.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,7 +17,7 @@
 require_once(dirname(__FILE__)."/../classes/class_kml_polygon.php");
 require_once(dirname(__FILE__)."/../classes/class_kml_linearring.php");
@@ -57,4 +57,4 @@
 		return get_class($this);
Modified: branches/nimix_dev/http/classes/class_kml_line.php
--- branches/nimix_dev/http/classes/class_kml_line.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_kml_line.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,7 +17,8 @@
 require_once(dirname(__FILE__)."/../classes/class_kml_geometry.php");
@@ -117,4 +118,4 @@
 	protected $pointArray = array();
Modified: branches/nimix_dev/http/classes/class_kml_linearring.php
--- branches/nimix_dev/http/classes/class_kml_linearring.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_kml_linearring.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,7 +17,8 @@
 require_once(dirname(__FILE__)."/../classes/class_kml_line.php");
@@ -50,4 +51,4 @@
 		return "";
Modified: branches/nimix_dev/http/classes/class_kml_multigeometry.php
--- branches/nimix_dev/http/classes/class_kml_multigeometry.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_kml_multigeometry.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,7 +17,8 @@
@@ -79,4 +80,4 @@
 	private $geometryArray = array();
Modified: branches/nimix_dev/http/classes/class_kml_ows.php
--- branches/nimix_dev/http/classes/class_kml_ows.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_kml_ows.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,12 +17,9 @@
-session_start();
 require_once(dirname(__FILE__)."/../extensions/JSON.php");
@@ -490,4 +487,4 @@
 	private $placemarkArray = array();
Modified: branches/nimix_dev/http/classes/class_kml_parser_ows.php
--- branches/nimix_dev/http/classes/class_kml_parser_ows.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_kml_parser_ows.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,8 +17,8 @@
-require_once(dirname(__FILE__)."/../extensions/JSON.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
@@ -39,7 +39,7 @@
 	public function parseGeoJSON ($geoJSON, $kmlId) {
 //		$e = new mb_notice("GEOJSON: " . $geoJSON);
-		$json = new Services_JSON();
+		$json = new Mapbender_JSON();
 		$geometryFromGeoJSON = $json->decode($geoJSON);
 		$id = 0;
Modified: branches/nimix_dev/http/classes/class_kml_placemark.php
--- branches/nimix_dev/http/classes/class_kml_placemark.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_kml_placemark.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,7 +17,7 @@
  * A Placemark consists of a geometry of type {@link KMLPoint}, {@link KMLPolygon},
@@ -116,4 +116,4 @@
 	private $geometry;
 	private $properties = array();
Modified: branches/nimix_dev/http/classes/class_kml_point.php
--- branches/nimix_dev/http/classes/class_kml_point.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_kml_point.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -19,7 +19,7 @@
  * 				along with this program; if not, write to the Free Software
  * 				Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
@@ -88,4 +88,4 @@
 	private $point;
Modified: branches/nimix_dev/http/classes/class_kml_polygon.php
--- branches/nimix_dev/http/classes/class_kml_polygon.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_kml_polygon.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -19,7 +19,7 @@
@@ -100,4 +100,4 @@
 	private $innerBoundaryArray = array();
Modified: branches/nimix_dev/http/classes/class_layer_monitor.php
--- branches/nimix_dev/http/classes/class_layer_monitor.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_layer_monitor.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,6 +17,8 @@
 class Layer_load_count {
 	function __construct () {
@@ -52,4 +54,4 @@
Modified: branches/nimix_dev/http/classes/class_locale.php
--- branches/nimix_dev/http/classes/class_locale.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_locale.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,8 +17,7 @@
  * sets the locale, depending on various settings:
@@ -37,10 +36,18 @@
 	var $status = "No locale set.";
 	function Mb_locale($languageId) {
+		if (!$languageId) {
+			$languageId = LANGUAGE;
   		$e = new Mb_notice("class_locale: setting locale to " . $languageId);
-		if (!$this->setCurrentLocale($languageId)) {
-			$e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
+		if (USE_I18N) {
+			if (!$this->setCurrentLocale($languageId)) {
+				$e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
+		else {
+			$this->setCurrentLocale($this->defaultLanguage);
@@ -85,7 +92,7 @@
 			$this->os = $this->guessHostOS();
-		if ($this->os != null && isset($languageId)) {
+		if (!USE_I18N || ($this->os != null && isset($languageId))) {
 			if ($this->isKnownLanguage($languageId)) {
 				if ($this->systemLocales == null) {
@@ -93,14 +100,16 @@
 				$locale = $this->systemLocales[$this->knownLanguages[$languageId]][$this->os];
-				if (setlocale(LC_ALL, $locale)) {
-					$this->name = $locale;
+				$selectedLocale = setlocale(LC_MESSAGES, $locale);
+				if ($selectedLocale) {
+					$this->name = $selectedLocale;
 					$_SESSION["mb_lang"] = $languageId;
 					$_SESSION["mb_locale"] = $this->name;
 					$e = new Mb_notice("locale " . $this->name . " ok on " . $this->os);
 					// from http://de3.php.net/manual/de/function.gettext.php
-					bindtextdomain("Mapbender", dirname(__FILE__)."/../../resources/locale/");
-					textdomain("Mapbender");
+					$path = bindtextdomain("Mapbender", dirname(__FILE__)."/../../resources/locale/");
+					$enc = bind_textdomain_codeset("Mapbender", "UTF-8");
+					$dom = textdomain("Mapbender");
 					return true;
@@ -126,7 +135,7 @@
 	  else if (strncasecmp(php_uname(), 'FreeBSD', 7) == 0)
 	    return 'bsd';
 	  else {
-	    throw new Mb_exception('unknown platform: could not interpret uname. php_uname() returned '. php_uname().'. Please report to MB developers');
+	    $e = new mb_exception('unknown platform: could not interpret uname. php_uname() returned '. php_uname().'. Please report to MB developers');
 	    return null;
@@ -204,4 +213,4 @@
Modified: branches/nimix_dev/http/classes/class_log.php
--- branches/nimix_dev/http/classes/class_log.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_log.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -22,6 +22,7 @@
 *	 [15/Jul/2004:	 10:00:08 +0200] 192.168.2.102 urldecode(username) userid
 *modul "GET /map/http/ HTTP/1.1"
 class log {
 	var $dir = "../../log/";
@@ -91,4 +92,4 @@
Modified: branches/nimix_dev/http/classes/class_map.php
--- branches/nimix_dev/http/classes/class_map.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_map.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -380,7 +380,7 @@
 	private static function selectByApplication ($appId, $frameName) {
 		// find the mapframe in the application elements...
 		$sql = "SELECT * FROM gui_element WHERE fkey_gui_id = $1 AND " .
-				"e_id = $2 LIMIT 1";
+				"e_id = $2 AND e_public = 1 LIMIT 1";
 		$v = array($appId, $frameName);
 		$t = array('s', 's');
@@ -408,7 +408,7 @@
 //				$e = new mb_exception("guess this is the OV");
 				$pattern = "/[\.\/a-zA-Z_]*\?wms=([0-9]*)[^0-9]*/";
 				$ovIndex = preg_replace($pattern, "\$1", $row["e_src"]);
-				$e = new mb_exception("OV index: " . $ovIndex);
+//				$e = new mb_exception("OV index: " . $ovIndex);
 				if (!$ovIndex) {
 					$ovIndex = 0;
@@ -421,8 +421,14 @@
 			$currentMap->wmsArray = $wmsArray;
-			// TO DO: EXTENT!
+			// EXTENT
+			$minx = $wmsArray[0]->objLayer[0]->layer_epsg[0]["minx"];
+			$miny = $wmsArray[0]->objLayer[0]->layer_epsg[0]["miny"];
+			$maxx = $wmsArray[0]->objLayer[0]->layer_epsg[0]["maxx"];
+			$maxy = $wmsArray[0]->objLayer[0]->layer_epsg[0]["maxy"];
+			$epsg = $wmsArray[0]->objLayer[0]->layer_epsg[0]["epsg"];
+			$mapExtent = new Mapbender_bbox($minx, $miny, $maxx, $maxy, $epsg);
+			$currentMap->setExtent($mapExtent);
 			return $currentMap;
 		else {
@@ -432,4 +438,4 @@
Modified: branches/nimix_dev/http/classes/class_metadata.php
--- branches/nimix_dev/http/classes/class_metadata.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_metadata.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -16,14 +16,9 @@
-#require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 require_once(dirname(__FILE__)."/class_administration.php");
Modified: branches/nimix_dev/http/classes/class_monitor.php
--- branches/nimix_dev/http/classes/class_monitor.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_monitor.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,9 +17,10 @@
 require_once(dirname(__FILE__)."/../classes/class_wms.php");
 require_once(dirname(__FILE__)."/../classes/class_bbox.php");
 define("MONITOR_DEFAULT_SCALE", 500000);
 define("MONITOR_IMG_WIDTH", 20);
@@ -475,4 +476,4 @@
Modified: branches/nimix_dev/http/classes/class_point.php
--- branches/nimix_dev/http/classes/class_point.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_point.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,10 +17,7 @@
  * A Mapbender_point is a 2-dimensional point with an EPSG.
@@ -175,4 +172,4 @@
 		return (string) "(" . $this->x . "," . $this->y . "," . $this->epsg . ")";
Modified: branches/nimix_dev/http/classes/class_weldMaps2Image.php
--- branches/nimix_dev/http/classes/class_weldMaps2Image.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_weldMaps2Image.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,10 +17,9 @@
   * Class generats Images (jpegs/pngs/geotiff)
@@ -198,4 +197,4 @@
Modified: branches/nimix_dev/http/classes/class_weldMaps2PNG.php
--- branches/nimix_dev/http/classes/class_weldMaps2PNG.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_weldMaps2PNG.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -23,10 +23,9 @@
 * get/post '___' separated maprequests
 class weldMaps2PNG{
@@ -80,4 +79,4 @@
Modified: branches/nimix_dev/http/classes/class_wfs.php
--- branches/nimix_dev/http/classes/class_wfs.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_wfs.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -21,9 +21,8 @@
 * class for wfs-objects
 class wfs {
Modified: branches/nimix_dev/http/classes/class_wfs_conf.php
--- branches/nimix_dev/http/classes/class_wfs_conf.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_wfs_conf.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,9 +17,9 @@
-require_once(dirname(__FILE__)."/class_user.php");
-require_once(dirname(__FILE__)."/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_user.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
 class WfsConf {
@@ -42,7 +42,7 @@
 	 * @return Object WFS conf data.
 	 * @param $idOrIdArray Object May be an integer or an array of integers representing WFS conf IDs.
 	public function load ($idOrIdArray) {
 		// Check parameter and set idArray
 		if (isset($idOrIdArray)){
@@ -51,6 +51,7 @@
 			if (!is_array($idOrIdArray) && is_numeric($idOrIdArray)) {
 				$idArray = array(intval($idOrIdArray));
 			// parameter is an array of numbers
 			if (is_array($idOrIdArray)) {
 				$idArray = array();
@@ -66,7 +67,7 @@
 				if ($_SESSION["mb_user_id"]) {
 					$user = new User($_SESSION["mb_user_id"]);
 					$idArray = array_intersect($idArray, $user->getWfsConfByPermission());
 				return $this->getWfsConfFromDB($idArray);
@@ -92,24 +93,24 @@
 	 * @param $idArray Array an array of integer values representing WFS conf IDs.
 	private static function getWfsConfFromDbByArray ($idArray) {
-			$sql = "SELECT * FROM wfs_conf ";
-			$sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
-			$sql .= "WHERE wfs_conf.wfs_conf_id IN (";
-			$v = array();
-			$t = array();
-			for ($i = 0; $i < count($idArray); $i++) {
-				if ($i > 0) {$sql .= ", ";}
-				$sql .= "$" . ($i+1);
-				array_push($v, $idArray[$i]);
-				array_push($t, 'i');
-			$sql .= ")";
-			$res = db_prep_query($sql, $v, $t);
+		$sql = "SELECT * FROM wfs_conf ";
+		$sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+		$sql .= "WHERE wfs_conf.wfs_conf_id IN (";
+		$v = array();
+		$t = array();
+		for ($i = 0; $i < count($idArray); $i++) {
+			if ($i > 0) {$sql .= ", ";}
+			$sql .= "$" . ($i+1);
+			array_push($v, $idArray[$i]);
+			array_push($t, 'i');
+		$sql .= ")";
+		$res = db_prep_query($sql, $v, $t);
 		$rowArray = array();
-			while ($row = db_fetch_array($res)) {
+		while ($row = db_fetch_array($res)) {
 			array_push($rowArray, $row);
 		return $rowArray;
@@ -120,7 +121,7 @@
 	 * @return Array
 	 * @param $id Integer the WFS conf ID.
 	private static function getWfsConfElementFromDb ($id) {
 		$sql = "SELECT * FROM wfs_conf_element ";
 		$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
@@ -131,7 +132,7 @@
 		$v = array($id);
 		$t = array('i');
 		$elementArray = array();
 			$currentElement = array("element_name" => $row["element_name"],
@@ -143,55 +144,55 @@
 									"f_label_id" => $row["f_label_id"],
 									"f_geom" => $row["f_geom"],
 									"f_show" => $row["f_show"],
-									"f_mandatory" => $row_conf_element["f_mandatory"],
-									"f_respos" => $row_conf_element["f_respos"],
-									"f_min_input" => $row_conf_element["f_min_input"],
-									"f_form_element_html" => $row_conf_element["f_form_element_html"],
-									"f_show_detail" => $row_conf_element["f_show_detail"],
-									"f_detailpos" => $row_conf_element["f_detailpos"],
-									"f_operator" => $row_conf_element["f_operator"],
+									"f_mandatory" => $row["f_mandatory"],
+									"f_respos" => $row["f_respos"],
+									"f_min_input" => $row["f_min_input"],
+									"f_form_element_html" => $row["f_form_element_html"],
+									"f_auth_varname" => $row["f_auth_varname"],
+									"f_detailpos" => $row["f_detailpos"],
+									"f_operator" => $row["f_operator"],
 									"f_show_detail" => $row["f_show_detail"]
-					array_push($elementArray, $currentElement);
+			array_push($elementArray, $currentElement);
 		return $elementArray;
 	 * Gets the database content of a WFS feature type given by a WFS ID and a featuretype ID.
 	 * @return Array
 	 * @param $wfsId Integer the WFS ID.
 	 * @param $featuretypeId Integer the WFS featuretype ID.
 	private static function getWfsFeatureTypeFromDb($wfsId, $featuretypeId) {
 		$sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
 		$v = array($wfsId, $featuretypeId);
 		$t = array("i", "i");
 		$currentRow = array();
 		if($row = db_fetch_array($res)){
 			$currentRow["featuretype_name"] = $row["featuretype_name"];
 			$currentRow["featuretype_srs"] = $row["featuretype_srs"];
 		return $currentRow;
 	 * get WFS conf data from database
 	private function getWfsConfFromDB ($idArray) {
 		// if a user has access to some WFS confs...
 		if (count($idArray) > 0) {
 			// get WFS conf data from DB
 			$rowArray = self::getWfsConfFromDbByArray($idArray);
 			for ($i=0; $i < count($rowArray); $i++) {
 				// WFS conf data
@@ -227,11 +228,11 @@
 		else {
 			$e = new mb_warning("class_wfs_conf.php: getWfsConfFromDB: You don't have access to any WFS confs. Check EDIT WFS.");
 			return array();
  * @deprecated
@@ -377,4 +378,4 @@
Deleted: branches/nimix_dev/http/classes/class_wmc.php
--- branches/nimix_dev/http/classes/class_wmc.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_wmc.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -1,1375 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_wmc.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__) . "/../../conf/mapbender.conf");
-require_once(dirname(__FILE__) . "/../classes/class_wms.php");
-require_once(dirname(__FILE__) . "/../classes/class_mb_exception.php");
-require_once(dirname(__FILE__) . "/../classes/class_layer_monitor.php");
-require_once(dirname(__FILE__) . "/../classes/class_point.php");
-require_once(dirname(__FILE__) . "/../classes/class_bbox.php");
-require_once(dirname(__FILE__) . "/../extensions/JSON.php");
-function mb_utf8_encode ($str) {
-	if(CHARSET=="UTF-8") return utf8_encode($str);
-	return $str;
-function mb_utf8_decode ($str) {
-	if(CHARSET=="UTF-8") return utf8_decode($str);
-	return $str;
-function sepNameSpace($s){
-	$c = strpos($s,":");
-	if($c>0)return substr($s,$c+1);
-	return $s;
- * Implementation of a Web Map Context Document, WMC 1.1.0
-class wmc {
-	var $xml;
-	var $wmc_id;
-	var $wmc_version;
-	var $wmc_windowWidth;
-	var $wmc_windowHeight;
-	var $wmc_bBox_SRS;
-	var $wmc_bBox_minx;
-	var $wmc_bBox_maxx;
-	var $wmc_bBox_miny;
-	var $wmc_bBox_maxy;
-	var $wmc_name;
-	var $wmc_title;
-	var $wmc_abstract;
-	var $wmc_general_extension = array();
-	var $wmc_logourl;
-	var $wmc_logourl_format;
-	var $wmc_logourl_type;
-	var $wmc_logourl_width;
-	var $wmc_logourl_height;
-	var $wmc_descriptionurl;
-	var $wmc_descriptionurl_format;
-	var $wmc_descriptionurl_type;
-	var $wmc_keyword = array();
-	var $wmc_contactposition;
-	var $wmc_contactvoicetelephone;
-	var $wmc_contactemail;
-	var $wmc_contactfacsimiletelephone;
-	var $wmc_contactperson;
-	var $wmc_contactorganization;
-	var $wmc_contactaddresstype;
-	var $wmc_contactaddress;
-	var $wmc_contactcity;
-	var $wmc_contactstateorprovince;
-	var $wmc_contactpostcode;
-	var $wmc_contactcountry;
-	var $wmc_wms_title = array();
-	var $wmc_layer_queryable = array();
-	var $wmc_layer_hidden = array();
-	var $wmc_wms_id = array();
-	var $wmc_wms_service = array();
-	var $wmc_wms_version = array();
-	var $wmc_wms_layer_id = array();
-	var $wmc_layer_wfs_featuretype = array();
-	var $wmc_layer_id = array();
-	var $wmc_layer_pos = array();
-	var $wmc_layer_parent = array();
-	var $wmc_layer_querylayer = array();
-	var $wmc_layer_title = array();
-	var $wmc_layer_name = array();
-	var $wmc_layer_abstract = array();
-	var $wmc_layer_srs = array();
-	var $wmc_wms_serviceURL = array();
-	var $wmc_layer_format_current = array();
-	var $wmc_layer_dataurl = array();
-	var $wmc_layer_metadataurl = array();
-	var $wmc_layer_minscale = array();
-	var $wmc_layer_maxscale = array();
-	var $wmc_gui_layer_minscale = array();
-	var $wmc_gui_layer_maxscale = array();
-	var $wmc_layer_format = array();
-	var $wmc_layer_style_current = array();
-	var $wmc_layer_style_name = array();
-	var $wmc_layer_style_title = array();
-	var $wmc_layer_style_legendurl = array();
-	var $wmc_layer_style_legendurl_width = array();
-	var $wmc_layer_style_legendurl_height = array();
-	var $wmc_layer_style_legendurl_format = array();
-	var $wmc_layer_style_legendurl_type = array();
-	var $wmc_layer_style_sld_url = array();
-	var $wmc_layer_style_sld_type = array();
-	var $wmc_layer_style_sld_title = array();
-	var $wmc_wms_count = 0;
-	 	var $data_type = array();
-		var $data_format = array();
-		var $objLayer = array();
-		var $gui_wms_mapformat;
-		var $gui_wms_featureinfoformat;
-		var $gui_wms_exceptionformat;
-		var $gui_wms_epsg;
-		var $default_epsg = 0;
-	var $monitoringIsOn = false;
-function wmc() {
- * Saves the current WMC in the log folder.
- * @return string the filename of the WMC document.
-function saveAsFile() {
-	$filename = "wmc_" . date("Y_m_d_H_i_s") . ".log";
-	$logfile = "../../log/" . $filename;
-	if($h = fopen($logfile,"a")){
-		$content = $this->xml;
-		if(!fwrite($h,$content)){
-			$e = new mb_exception("class_wmc.php: failed to write wmc.");
-			return false;
-		fclose($h);
-	return $filename;
- * @return string the title of the WMC.
-function getTitle() {
-	return $this->wmc_title;
- * @return Integer the number of (unique?) WMS contained in this WMC.
-function getNumberOfWms () {
-	return $this->wmc_wms_count;
- * Creates a WMC object from a JS map object {@see map.js}
- * @param object $mapObject a map object
- * @param integer $user_id the ID of the current user
- * @param string $generalTitle the desired title of the WMC
- * @param object $extensionData data exclusive to Mapbender, which will be
- * 								mapped into the extension part of the WMC
-function createWMCFromObj($mapObject, $user_id, $generalTitle, $extensionData) {
-	$this->wmc_id = $user_id . '_' . time();
-	$generalWidth = $mapObject->width;
-	$generalHeight = $mapObject->height;
-	$generalBboxSrs = $mapObject->epsg;
-	$arrayBBox = explode(",", $mapObject->extent);
-	$generalBboxMinx = floatval($arrayBBox[0]);
-	$generalBboxMiny = floatval($arrayBBox[1]);
-	$generalBboxMaxx = floatval($arrayBBox[2]);
-	$generalBboxMaxy = floatval($arrayBBox[3]);
-	$generalName = "Mapbender WMC"; // TO do : insert proper data
-	$generalKeywords = array("Mapbender", "WMC"); // TO do : insert proper data
-	$generalAbstract = ""; // TO do : insert proper data
-	$generalLogoUrl = ""; // TO do : insert proper data
-	$generalLogoUrlWidth = ""; // TO do : insert proper data
-	$generalLogoUrlHeight = ""; // TO do : insert proper data
-	$generalLogoUrlFormat = ""; // TO do : insert proper data
-	$generalDescriptionUrl = ""; // TO do : insert proper data
-	$generalContactPerson = "";
-	$generalContactOrganization = "";
-	$generalContactPosition = "";
-	$generalContactAddressType = "";
-	$generalContactAddress = "";
-	$generalContactCity = "";
-	$generalContactStateOrProvince = "";
-	$generalContactPostCode = "";
-	$generalContactCountry = "";
-	$generalContactVoiceTelephone = "";
-	$generalContactFacsimileTelephone = "";
-	$generalContactElectronicMailAddress = "";
-	$extension_namespace = "mapbender";
-	// LayerList variables
-	$layerHidden = "";
-	$layerQueryable = "";
-	$layerAbstract = "";
-	$layerName = "";
-	$layerSrs = "";
-	$layerDataUrl = "";
-	$layerMetadataUrl = "";
-	$layerFormat = "";
-	$layerFormat_current = "";
-	$layerStyle_current = "";
-	$layerStyle_name = "";
-	$layerStyle_title = "";
-	$layerStyle_legendURL = "";
-	$layerStyle_legendURL_width = "";
-	$layerStyle_legendURL_height = "";
-	$layerStyle_legendURL_format = "";
-	// generate XML
-	$doc = new DOMDocument("1.0", CHARSET);
-	$doc->preserveWhiteSpace = false;
-	// ViewContext
-	$e_view_context = $doc->createElementNS("http://www.opengis.net/context", "ViewContext");
-	$e_view_context->setAttribute("version", "1.0.0");
-	$e_view_context->setAttribute("id", $this->wmc_id);
-	$e_view_context->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
-	$e_view_context->setAttribute("xmlns:mapbender", "http://www.mapbender.org");
-	$e_view_context->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
-	$e_view_context->setAttribute("xsi:SchemaLocation", "http://schemas.opengis.net/context/1.0.0/context.xsd");
-		// General
-		$e_general = $doc->createElement("General");
-			$e_window = $doc->createElement("Window");
-			if (!empty($generalWidth) && !empty($generalHeight)) {
-				$e_window->setAttribute("width", $generalWidth);
-				$e_window->setAttribute("height", $generalHeight);
-			$e_general->appendChild($e_window);
-			$e_bbox = $doc->createElement("BoundingBox");
-			$e_bbox->setAttribute("SRS", $generalBboxSrs);
-			$e_bbox->setAttribute("minx", $generalBboxMinx);
-			$e_bbox->setAttribute("miny", $generalBboxMiny);
-			$e_bbox->setAttribute("maxx", $generalBboxMaxx);
-			$e_bbox->setAttribute("maxy", $generalBboxMaxy);
-			$e_general->appendChild($e_bbox);
-			$e_name = $doc->createElement("Name", $generalName);
-			$e_general->appendChild($e_name);
-			$e_title = $doc->createElement("Title", $generalTitle);
-			$e_general->appendChild($e_title);
-			$e_keyword_list = $doc->createElement("KeywordList");
-			for ($i=0; $i < count($generalKeywords); $i++) {
-				$e_keyword = $doc->createElement("Keyword", $generalKeywords[$i]);
-				$e_keyword_list->appendChild($e_keyword);
-			$e_general->appendChild($e_keyword_list);
-			if ($generalAbstract){
-				$e_abstract = $doc->createElement("Abstract", $generalAbstract);
-				$e_general->appendChild($e_abstract);
-			if ($generalLogoUrlWidth && $generalLogoUrlHeight && $generalLogoUrlFormat && $generalLogoUrl){
-				$e_logo_url = $doc->createElement("LogoURL");
-				$e_logo_url->setAttribute("width", $generalLogoUrlWidth);
-				$e_logo_url->setAttribute("height", $generalLogoUrlHeight);
-				$e_logo_url->setAttribute("format", $generalLogoUrlFormat);
-				$e_logo_url_or = $doc->createElement("OnlineResource");
-				$e_logo_url_or->setAttributeNS("http://www.opengis.net/context", "xmlns:xlink", "http://www.w3.org/1999/xlink");
-				$e_logo_url_or->setAttribute("xlink:type", "simple");
-				$e_logo_url_or->setAttribute("xlink:href", $generalLogoUrl);
-				$e_logo_url->appendChild($e_logo_url_or);
-				$e_general->appendChild($e_logo_url);
-			if ($generalDescriptionUrl){
-				$e_description_url = $doc->createElement("DescriptionURL");
-				$e_description_url_or = $doc->createElement("OnlineResource");
-				$e_description_url_or->setAttributeNS("http://www.opengis.net/context", "xmlns:xlink", "http://www.w3.org/1999/xlink");
-				$e_description_url_or->setAttribute("xlink:type", "simple");
-				$e_description_url_or->setAttribute("xlink:href", $generalDescriptionUrl);
-				$e_description_url->appendChild($e_description_url_or);
-				$e_general->appendChild($e_description_url);
-			if ($generalContactElectronicMailAddress || $generalContactOrganization ||
-				$generalContactPerson || $generalContactPosition || $generalContactAddressType ||
-				$generalContactAddress || $generalContactCity || $generalContactStateOrProvince ||
-				$generalContactPostCode || $generalContactCountry || $generalContactVoiceTelephone ||
-				$generalContactFacsimileTelephone || $generalContactElectronicMailAddress) {
-				$e_contact = $doc->createElement("ContactInformation");
-				if ($generalContactPerson || $generalContactOrganization){
-					$e_contact_person_primary = $doc->createElement("ContactPersonPrimary");
-					if ($generalContactPerson){
-						$e_contact_person = $doc->createElement("ContactPerson", $generalContactPerson);
-						$e_contact_person_primary->appendChild($e_contact_person);
-					if ($generalContactOrganization){
-						$e_contact_organization = $doc->createElement("ContactOrganization", $generalContactOrganization);
-						$e_contact_person_primary->appendChild($e_contact_organization);
-					$e_contact->appendChild($e_contact_person_primary);
-				if ($generalContactPosition){
-					$e_contact_position = $doc->createElement("ContactPosition", $generalContactPosition);
-					$e_contact->appendChild($e_contact_position);
-				if ($generalContactAddressType || $generalContactAddress ||
-					$generalContactCity || $generalContactStateOrProvince ||
-					$generalContactPostCode || $generalContactCountry) {
-					$e_contact_address = $doc->createElement("ContactAddress");
-					if ($generalContactAddressType){
-						$e_address_type = $doc->createElement("AddressType", $generalContactAddressType);
-						$e_contact_address->appendChild($e_address_type);
-					if ($generalContactAddress){
-						$e_address = $doc->createElement("Address", $generalContactAddress);
-						$e_contact_address->appendChild($e_address);
-					if ($generalContactCity){
-						$e_city = $doc->createElement("City", $generalContactCity);
-						$e_contact_address->appendChild($e_city);
-					if ($generalContactStateOrProvince){
-						$e_state = $doc->createElement("StateOrProvince", $generalContactStateOrProvince);
-						$e_contact_address->appendChild($e_state);
-					if ($generalContactPostCode){
-						$e_postcode = $doc->createElement("PostCode", $generalContactPostCode);
-						$e_contact_address->appendChild($e_postcode);
-					if ($generalContactCountry){
-						$e_country = $doc->createElement("Country", $generalContactCountry);
-						$e_contact_address->appendChild($e_country);
-					$e_contact->appendChild($e_contact_address);
-				if ($generalContactVoiceTelephone){
-					$e_voice_telephone = $doc->createElement("ContactVoiceTelephone", $generalContactVoiceTelephone);
-					$e_contact->appendChild($e_voice_telephone);
-				if ($generalContactFacsimileTelephone){
-					$e_facsimile_telephone = $doc->createElement("ContactFacsimileTelephone", $generalContactFacsimileTelephone);
-					$e_contact->appendChild($e_facsimile_telephone);
-				if ($generalContactElectronicMailAddress){
-					$e_email = $doc->createElement("ContactElectronicMailAddress", $generalContactElectronicMailAddress);
-					$e_contact->appendChild($e_email);
-				$e_general->appendChild($e_contact);
-			if (count($extensionData) > 0) {
-				//$e = new mb_exception("writing wmc...");
-				$e_extensionGeneral = $doc->createElement("Extension");
-				foreach ($extensionData as $keyExtensionData => $valueExtensionData) {
-					$e_currentExtensionTag = $doc->createElement($extension_namespace.":".$keyExtensionData, $valueExtensionData);
-					$e_extensionGeneral->appendChild($e_currentExtensionTag);
-				$e_general->appendChild($e_extensionGeneral);
-		$e_view_context->appendChild($e_general);
-		// LayerList
-		$e_layer_list = $doc->createElement("LayerList");
-		for ($i=0; $i < count($mapObject->wms); $i++){
-			$wmsId = $mapObject->wms[$i]->wms_id;
-			$wms_epsg = array();
-			$wms_epsg[0] = $mapObject->epsg;
-			if ($mapObject->wms[$i]->gui_wms_epsg != $mapObject->epsg){
-				$wms_epsg[1] = $mapObject->wms[$i]->gui_wms_epsg;
-			for ($q = 0; $q < count($mapObject->wms[$i]->gui_epsg); $q++){
-				$isInArray = false;
-				for ($r=0 ; $r < count($wms_epsg); $r++){
-					if ($wms_epsg[$r] == $mapObject->wms[$i]->gui_epsg[$q]){
-						$isInArray = true;
-				if ($isInArray == false){
-					array_push($wms_epsg, $mapObject->wms[$i]->gui_epsg[$q]);
-			for ($j = 0; $j < count($mapObject->wms[$i]->objLayer); $j++){
-				if ($mapObject->wms[$i]->objLayer[$j]->layer_parent != ''){
-					if ($mapObject->wms[$i]->objLayer[$j]->gui_layer_visible == "1"){
-						$layerHidden = 0;
-					else{
-						$layerHidden = 1;
-					$layerQueryable = $mapObject->wms[$i]->objLayer[$j]->layer_queryable;
-					$layerQuerylayer = $mapObject->wms[$i]->objLayer[$j]->gui_layer_querylayer;
-					$layerId = $mapObject->wms[$i]->objLayer[$j]->layer_uid;
-					$layerName = $mapObject->wms[$i]->objLayer[$j]->layer_name;
-					$layerTitle = $mapObject->wms[$i]->objLayer[$j]->layer_title;
-					$layerAbstract = $mapObject->wms[$i]->wms_abstract; //To Do: insert actual abstract
-					$layerDataUrl = $mapObject->wms[$i]->objLayer[$j]->layer_dataurl_href;
-					$layerMetadataUrl = $mapObject->wms[$i]->objLayer[$j]->layer_metadataurl;
-					$layerMinscale = $mapObject->wms[$i]->objLayer[$j]->layer_minscale;
-					$layerMaxscale = $mapObject->wms[$i]->objLayer[$j]->layer_maxscale;
-					$guiLayerMinscale = $mapObject->wms[$i]->objLayer[$j]->gui_layer_minscale;
-					$guiLayerMaxscale = $mapObject->wms[$i]->objLayer[$j]->gui_layer_maxscale;
-					$wmsVersion = $mapObject->wms[$i]->wms_version;
-					$wmsTitle = $mapObject->wms[$i]->wms_title;
-					$wmsLayerId = $mapObject->wms[$i]->objLayer[0]->layer_uid;
-					$wmsOnlineResource = $mapObject->wms[$i]->wms_getmap;
-					$layerPos = $mapObject->wms[$i]->objLayer[$j]->layer_pos;
-					$layerParent = $mapObject->wms[$i]->objLayer[$j]->layer_parent;
-					$queryLayer = $mapObject->wms[$i]->objLayer[$j]->gui_layer_querylayer;
-					$wfsFeatureType = $mapObject->wms[$i]->objLayer[$j]->gui_layer_wfs_featuretype;
-					$e_layer = $doc->createElement("Layer");
-					$e_layer->setAttribute("queryable", $layerQueryable);
-					$e_layer->setAttribute("hidden", $layerHidden);
-						$e_service = $doc->createElement("Server");
-						$e_service->setAttribute("service", "OGC:WMS");
-						$e_service->setAttribute("version", $wmsVersion);
-						$e_service->setAttribute("title", $wmsTitle);
-						$e_service_or = $doc->createElement("OnlineResource");
-						$e_service_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
-						$e_service_or->setAttribute("xlink:type", "simple");
-						$e_service_or->setAttribute("xlink:href", $wmsOnlineResource);
-						$e_service->appendChild($e_service_or);
-						$e_layer->appendChild($e_service);
-						$e_layer_name = $doc->createElement("Name", $layerName);
-						$e_layer->appendChild($e_layer_name);
-						$e_layer_title = $doc->createElement("Title", $layerTitle);
-						$e_layer->appendChild($e_layer_title);
-						if ($layerAbstract){
-							$e_layer_abstract = $doc->createElement("Abstract", $layerAbstract);
-							$e_layer->appendChild($e_layer_abstract);
-						$e_layer_srs = $doc->createElement("SRS", implode(" ", $wms_epsg));
-						if ($layerDataUrl){
-							$e_layer_data_url = $doc->createElement("DataURL");
-							$e_layer_data_url_or = $doc->createElement("OnlineResource");
-							$e_layer_data_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
-							$e_layer_data_url_or->setAttribute("xlink:type", "simple");
-							$e_layer_data_url_or->setAttribute("xlink:href", $layerDataUrl);
-							$e_layer_data_url->appendChild($e_layer_data_url_or);
-							$e_layer->appendChild($e_layer_data_url);
-						if ($layerMetadataUrl){
-							$e_layer_metadata_url = $doc->createElement("MetadataURL");
-							$e_layer_metadata_url_or = $doc->createElement("OnlineResource");
-							$e_layer_metadata_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
-							$e_layer_metadata_url_or->setAttribute("xlink:type", "simple");
-							$e_layer_metadata_url_or->setAttribute("xlink:href", $layerMetadataUrl);
-							$e_layer_metadata_url->appendChild($e_layer_metadata_url_or);
-							$e_layer->appendChild($e_layer_metadata_url);
-						$e_extension = $doc->createElement("Extension");
-						$e_scalehint = $doc->createElement($extension_namespace.":ScaleHint");
-						$e_scalehint->setAttribute("min", $layerMinscale);
-						$e_scalehint->setAttribute("max", $layerMaxscale);
-						$e_extension->appendChild($e_scalehint);
-						$e_gui_scalehint = $doc->createElement($extension_namespace.":guiScaleHint");
-						$e_gui_scalehint->setAttribute("min", $guiLayerMinscale);
-						$e_gui_scalehint->setAttribute("max", $guiLayerMaxscale);
-						$e_extension->appendChild($e_gui_scalehint);
-						$e_layer_id = $doc->createElement($extension_namespace.":layer_id", $layerId);
-						$e_extension->appendChild($e_layer_id);
-						$e_wms_layer_id = $doc->createElement($extension_namespace.":wms_layer_id", $wmsLayerId);
-						$e_extension->appendChild($e_wms_layer_id);
-						$e_layer_pos = $doc->createElement($extension_namespace.":layer_pos", $layerPos);
-						$e_extension->appendChild($e_layer_pos);
-						$e_layer_parent = $doc->createElement($extension_namespace.":layer_parent", $layerParent);
-						$e_extension->appendChild($e_layer_parent);
-						$e_wms_id = $doc->createElement($extension_namespace.":wms_id", $wmsId);
-						$e_extension->appendChild($e_wms_id);
-						$e_querylayer = $doc->createElement($extension_namespace.":querylayer", $layerQuerylayer);
-						$e_extension->appendChild($e_querylayer);
-						if ($wfsFeatureType) {
-							$e_wfsFeatureType = $doc->createElement($extension_namespace.":wfsFeatureType", $wfsFeatureType);
-							$e_extension->appendChild($e_wfsFeatureType);
-						$e_layer->appendChild($e_extension);
-						//layerFormat
-						$e_layer_format = $doc->createElement("FormatList");
-						$data_format_current = false;
-						for ($k = 0; $k < count($mapObject->wms[$i]->data_format); $k++){
-							if ($mapObject->wms[$i]->data_type[$k] == "map") {
-								$layerFormat = $mapObject->wms[$i]->data_format[$k];
-								$e_format = $doc->createElement("Format", $layerFormat);
-								if ($data_format_current == false && (
-										($mapObject->wms[$i]->data_format[$k] == $mapObject->wms[$i]->gui_wms_mapformat) ||
-										($k == (count($mapObject->wms[$i]->data_format)-1))
-									$e_format->setAttribute("current", "1");
-									$data_format_current = true;
-								$e_layer_format->appendChild($e_format);
-						$e_layer->appendChild($e_layer_format);
-						// LayerStyle
-						$e_layer_stylelist = $doc->createElement("StyleList");
-						for ($k = 0; $k < count($mapObject->wms[$i]->objLayer[$j]->layer_style); $k++){
-							if ($k == 0){
-								$layerStyle_current = 1; // To do: insert proper data
-							else{
-								$layerStyle_current = 0; // To do: insert proper data
-							$e_layer_style = $doc->createElement("Style");
-							$layerStyleSLD = "";
-							if ($layerStyleSLD){
-								$layerStyleSLDUrl = ""; // To Do: Insert Proper Data
-								$e_layer_style_or = $doc->createElement("OnlineResource");
-								$e_layer_style_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
-								$e_layer_style_or->setAttribute("xlink:type", "simple");
-								$e_layer_style_or->setAttribute("xlink:href", $layerStyleSLDUrl);
-								$e_layer_style->appendChild($e_layer_style_or);
-							else{
-								//TODO: determine correct layer style entries
-								$layerStyle_name = $mapObject->wms[$i]->objLayer[$j]->layer_style[$k]->name;
-								$layerStyle_title = $mapObject->wms[$i]->objLayer[$j]->layer_style[$k]->title;
-								$layerStyle_legendUrl = $mapObject->wms[$i]->objLayer[$j]->layer_style[$k]->legendurl;
-								$layerStyle_legendUrl_width = ""; // To Do: add proper data
-								$layerStyle_legendUrl_height = ""; // To Do: add proper data
-								$layerStyle_legendUrl_format = ""; // To Do: add proper data
-								if ($layerStyle_current == 1){
-									$e_layer_style->setAttribute("current", "1");
-								$e_layer_style_name = $doc->createElement("Name", $layerStyle_name);
-								$e_layer_style->appendChild($e_layer_style_name);
-								$e_layer_style_title = $doc->createElement("Title", $layerStyle_title);
-								$e_layer_style->appendChild($e_layer_style_title);
-								$e_layer_style_legendurl = $doc->createElement("LegendUrl");
-								$e_layer_style_legendurl->setAttribute("width", $layerStyle_legendUrl_width);
-								$e_layer_style_legendurl->setAttribute("height", $layerStyle_legendUrl_height);
-								$e_layer_style_legendurl->setAttribute("format", $layerStyle_legendUrl_format);
-								$e_layer_style_legendurl_or = $doc->createElement("OnlineResource");
-								$e_layer_style_legendurl_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
-								$e_layer_style_legendurl_or->setAttribute("xlink:type", "simple");
-								$e_layer_style_legendurl_or->setAttribute("xlink:href", $layerStyle_legendUrl);
-								$e_layer_style_legendurl->appendChild($e_layer_style_legendurl_or);
-								$e_layer_style->appendChild($e_layer_style_legendurl);
-							$e_layer_stylelist->appendChild($e_layer_style);
-						$e_layer->appendChild($e_layer_stylelist);
-					$e_layer_list->appendChild($e_layer);
-		$e_view_context->appendChild($e_layer_list);
-	$doc->appendChild($e_view_context);
-	$this->xml = $doc->saveXML();
-	// for debugging: saving WMC as file
-	// (comment when no longer needed)
-	$filename = $this->saveAsFile();
-	if ($filename) {
-		$e = new mb_notice("class_wmc: saving WMC as file " . $filename);
- * Loads a WMC from the database.
- * @param integer $wmc_id the ID of the WMC document in the database table "mb_user_wmc"
-function createObjFromWMC_id($wmc_id){
-	global $DBSERVER,$DB,$OWNER,$PW;
-	$con = db_connect($DBSERVER,$OWNER,$PW);
-	db_select_db(DB, $con);
-	$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1";
-	$v = array($wmc_id);
-	$t = array("i");
-	$wmc = db_fetch_row($res);
-	$this->createObjFromWMC_xml($wmc[0]);
-	$this->monitoringIsOn = true;
- * Loads a WMC from an actual WMC XML document.
- * @param string $data the data from the XML file
-function createObjFromWMC_xml($data){
-#	$data = str_replace("&#38;", "&amp;", $data);
-	// store xml
-	$this->xml = $data;
-	if ($filename) {
-	$values = NULL;
-	$tags = NULL;
-	$parser = xml_parser_create(CHARSET);
-	xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
-	xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
-	xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
-	xml_parse_into_struct($parser,$data,$values,$tags);
-	$code = xml_get_error_code ($parser);
-	if ($code) {
-		$line = xml_get_current_line_number($parser);
-		$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
-		return false;
-	xml_parser_free($parser);
-	$section = NULL;
-	$format = NULL;
-	$cnt_format = 0;
-	$parent = array();
-	$myParent = array();
-	$cnt_layer = -1;
-	$request = NULL;
-	$layer_style = array();
-	$extension = false;
-	$general = false;
-	$layerlist = false;
-	$layer = false;
-	$formatlist = false;
-	$dataurl = false;
-	$metadataurl = false;
-	$stylelist = false;
-	$cnt_style = -1;
-	foreach ($values as $element) {
-					$verbose .= ".";
-		if(strtoupper($element[tag]) == "VIEWCONTEXT" && $element[type] == "open"){
-				$this->wmc_id = $element[attributes]["id"];
-				$this->wmc_version = $element[attributes]["version"];
-		if(strtoupper($element[tag]) == "GENERAL" && $element[type] == "open"){
-		   $general = true;
-		if(strtoupper($element[tag]) == "LAYERLIST" && $element[type] == "open"){
-		   $layerlist = true;
-		if ($general) {
-				if(strtoupper($element[tag]) == "WINDOW"){
-						$this->wmc_windowWidth = $element[attributes]["width"];
-						$this->wmc_windowHeight = $element[attributes]["height"];
-				if(strtoupper($element[tag]) == "BOUNDINGBOX"){
-						$this->wmc_bBox_SRS = $element[attributes]["SRS"];
-						$this->wmc_bBox_minx = $element[attributes]["minx"];
-						$this->wmc_bBox_miny = $element[attributes]["miny"];
-						$this->wmc_bBox_maxx = $element[attributes]["maxx"];
-						$this->wmc_bBox_maxy = $element[attributes]["maxy"];
-				if(strtoupper($element[tag]) == "NAME"){
-						$this->wmc_name = mb_utf8_decode(html_entity_decode($element[value]));
-				if(strtoupper($element[tag]) == "TITLE"){
-						$this->wmc_title = mb_utf8_decode(html_entity_decode($element[value]));
-				if(strtoupper($element[tag]) == "ABSTRACT"){
-						$this->wmc_abstract = mb_utf8_decode(html_entity_decode($element[value]));
-				if(strtoupper($element[tag]) == "CONTACTINFORMATION" && $element['type'] == "open"){
-						$contactinformation = true;
-				if ($contactinformation) {
-					if(strtoupper($element[tag]) == "CONTACTPOSITION"){
-							$this->wmc_contactposition = mb_utf8_decode(html_entity_decode($element[value]));
-					if(strtoupper($element[tag]) == "CONTACTVOICETELEPHONE"){
-							$this->wmc_contactvoicetelephone = $element[value];
-					if(strtoupper($element[tag]) == "CONTACTFACSIMILETELEPHONE"){
-							$this->wmc_contactfacsimiletelephone = $element[value];
-					if(strtoupper($element[tag]) == "CONTACTELECTRONICMAILADDRESS"){
-							$this->wmc_contactemail = mb_utf8_decode(html_entity_decode($element[value]));
-					if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "open"){
-							$contactpersonprimary = true;
-					if ($contactpersonprimary) {
-						if(strtoupper($element[tag]) == "CONTACTPERSON"){
-								$this->wmc_contactperson = mb_utf8_decode(html_entity_decode($element[value]));
-						if(strtoupper($element[tag]) == "CONTACTORGANIZATION"){
-								$this->wmc_contactorganization = mb_utf8_decode(html_entity_decode($element[value]));
-						if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "close"){
-								$contactpersonprimary = false;
-					if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "open"){
-							$contactaddress = true;
-					if ($contactaddress) {
-						if(strtoupper($element[tag]) == "ADDRESSTYPE"){
-								$this->wmc_contactaddresstype = mb_utf8_decode(html_entity_decode($element[value]));
-						if(strtoupper($element[tag]) == "ADDRESS"){
-								$this->wmc_contactaddress = mb_utf8_decode(html_entity_decode($element[value]));
-						if(strtoupper($element[tag]) == "CITY"){
-								$this->wmc_contactcity = mb_utf8_decode(html_entity_decode($element[value]));
-						if(strtoupper($element[tag]) == "STATEORPROVINCE"){
-								$this->wmc_contactstateorprovince = mb_utf8_decode(html_entity_decode($element[value]));
-						if(strtoupper($element[tag]) == "POSTCODE"){
-								$this->wmc_contactpostcode = $element[value];
-						if(strtoupper($element[tag]) == "COUNTRY"){
-								$this->wmc_contactcountry = mb_utf8_decode(html_entity_decode($element[value]));
-						if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "close"){
-								$contactaddress = false;
-				if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "open"){
-						$logourl = true;
-						$this->wmc_logourl_width = $element[attributes]["width"];
-						$this->wmc_logourl_height = $element[attributes]["height"];
-						$this->wmc_logourl_format = $element[attributes]["format"];
-				if ($logourl) {
-					if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "close"){
-							$logourl = false;
-					if(strtoupper($element[tag]) == "ONLINERESOURCE"){
-						$this->wmc_logourl_type = $element[attributes]["xlink:type"];
-						$this->wmc_logourl = $element[attributes]["xlink:href"];
-				if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "open"){
-						$descriptionurl = true;
-						$this->wmc_descriptionurl_format = $element[attributes]["format"];
-				if ($descriptionurl) {
-					if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "close"){
-							$descriptionurl = false;
-						$this->wmc_descriptionurl_type = $element[attributes]["xlink:type"];
-						$this->wmc_descriptionurl = $element[attributes]["xlink:href"];
-				if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "open"){
-						$keywordlist = true;
-				if ($keywordlist) {
-					if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "close"){
-							$keywordlist = false;
-							$cnt_keyword = -1;
-					if(strtoupper($element[tag]) == "KEYWORD"){
-						$cnt_keyword++;
-						$this->wmc_keyword[$cnt_keyword] = mb_utf8_decode(html_entity_decode($element[value]));
-				if(strtoupper($element[tag]) == "EXTENSION" && $element['type'] == "close"){
-					$generalExtension = false;
-				if ($generalExtension) {
-					$this->wmc_general_extension[sepNameSpace($element[tag])] = $element[value];
-//					$e = new mb_exception("WMC: " . $element[tag] . ": " . $element[value]);
-				if(strtoupper($element[tag]) == "EXTENSION" && $element['type'] == "open"){
-					$generalExtension = true;
-				if(strtoupper($element[tag]) == "GENERAL" && $element['type'] == "close"){
-		   			$general = false;
-		if ($layerlist) {
-				if(strtoupper($element[tag]) == "LAYERLIST" && $element['type'] == "close"){
-				if(strtoupper($element[tag]) == "LAYER" && $element[type] == "open"){
-					 $cnt_layer++;
-					 $this->wmc_layer_queryable[$cnt_layer] = $element[attributes]["queryable"];
-					 $this->wmc_layer_hidden[$cnt_layer] = $element[attributes]["hidden"];
-					 $layer = true;
-      		 		 $cnt_epsg = 0;
-				if ($layer) {
-					 if(strtoupper($element[tag]) == "LAYER" && $element[type] == "close"){
-					 		$layer = false;
-					 if ($formatlist) {
-						 if(strtoupper($element[tag]) == "FORMAT"){
-						 	$cnt_format++;
-						 	$this->wmc_layer_format_current[$cnt_layer][$cnt_format] = $element[attributes]["current"];
-						 	$this->wmc_layer_format[$cnt_layer][$cnt_format] = $element[value];
-						 if(strtoupper($element[tag]) == "FORMATLIST" && $element[type] == "close"){
-					 elseif ($metadataurl) {
-						 	$this->wmc_layer_metadataurl[$cnt_layer] = $element[attributes]["xlink:href"];
-						 if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "close"){
-					 elseif ($dataurl) {
-						 	$this->wmc_layer_dataurl[$cnt_layer] = $element[attributes]["xlink:href"];
-						 if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "close"){
-							 $dataurl = false;
-					 elseif ($stylelist) {
-						 if(strtoupper($element[tag]) == "STYLE" && $element[type] == "open"){
-						 	$cnt_style++;
-						 	$style = true;
-						 	$this->wmc_layer_style_current[$cnt_layer][$cnt_style] = $element[attributes]["current"];
-						 if ($style) {
-							 if(strtoupper($element[tag]) == "STYLE" && $element[type] == "close"){
-							 	$style = false;
-							 if(strtoupper($element[tag]) == "SLD" && $element[type] == "open"){
-							 	$sld = true;
-							 if ($sld) {
-								 if(strtoupper($element[tag]) == "SLD" && $element[type] == "close"){
-								 	$sld = false;
-								 	$this->wmc_layer_style_sld_type[$cnt_layer][$cnt_style] = $element[attributes]["xlink:type"];
-								 	$this->wmc_layer_style_sld_url[$cnt_layer][$cnt_style] = $element[attributes]["xlink:href"];
-								 	$this->wmc_layer_style_sld_title[$cnt_layer][$cnt_style] = mb_utf8_decode(html_entity_decode($element[value]));
-							 else {
-								 	$this->wmc_layer_style_name[$cnt_layer][$cnt_style] = mb_utf8_decode(html_entity_decode($element[value]));
-								 	$this->wmc_layer_style_title[$cnt_layer][$cnt_style] = $element[value];
-								 if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "open"){
-								 	$legendurl = true;
-								 	$this->wmc_layer_style_legendurl_width[$cnt_layer][$cnt_style] = $element[attributes]["width"];
-								 	$this->wmc_layer_style_legendurl_height[$cnt_layer][$cnt_style] = $element[attributes]["height"];
-								 	$this->wmc_layer_style_legendurl_format[$cnt_layer][$cnt_style] = $element[attributes]["format"];
-								 if ($legendurl) {
-									 if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "close"){
-									 	$legendurl = false;
-									 	$this->wmc_layer_style_legendurl_type[$cnt_layer][$cnt_style] = $element[attributes]["xlink:type"];
-									 	$this->wmc_layer_style_legendurl[$cnt_layer][$cnt_style] = $element[attributes]["xlink:href"];
-						 if(strtoupper($element[tag]) == "STYLELIST" && $element[type] == "close"){
-					 else {
-						 if(strtoupper($element[tag]) == "SERVER" && $element[type] == "open"){
-						 	 $server = true;
-						 	 $this->wmc_wms_service[$cnt_layer] = $element[attributes]["service"];
-						 	 $this->wmc_wms_version[$cnt_layer] = $element[attributes]["version"];
-						 	 $this->wmc_wms_title[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[attributes]["title"]));
-						 if ($server) {
-							 if(strtoupper($element[tag]) == "SERVER" && $element[type] == "close"){
-							 	 $server = false;
-						 		 $this->wmc_wms_serviceURL[$cnt_layer] = $element[attributes]["xlink:href"];
-					 		 $this->wmc_layer_name[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[value]));
-					 		 $this->wmc_layer_title[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[value]));
-					 		 $this->wmc_layer_abstract[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[value]));
-						 if(strtoupper($element[tag]) == "SRS"){
-							 $epsgArray = explode(" ", $element[value]);
-					 		 for ($c = 0 ; $c < count($epsgArray) ; $c ++) {
-						 		 $this->wmc_layer_srs[$cnt_layer][$cnt_epsg] = $epsgArray[$c];
-								 $cnt_epsg++;
-						 if (strtoupper($element[tag]) == "EXTENSION" && $element[type] == "open") {
-						 	$extension = true;
-						 if (strtoupper($element[tag]) == "EXTENSION" && $element[type] == "close") {
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "SCALEHINT"){
-					 		 $this->wmc_layer_minscale[$cnt_layer] = $element[attributes]["min"];
-					 		 $this->wmc_layer_maxscale[$cnt_layer] = $element[attributes]["max"];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "GUISCALEHINT"){
-					 		 $this->wmc_gui_layer_minscale[$cnt_layer] = $element[attributes]["min"];
-					 		 $this->wmc_gui_layer_maxscale[$cnt_layer] = $element[attributes]["max"];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_ID"){
-					 		 $this->wmc_layer_id[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WMS_LAYER_ID"){
-					 		 $this->wmc_wms_layer_id[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_POS"){
-					 		 $this->wmc_layer_pos[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_PARENT"){
-					 		 $this->wmc_layer_parent[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "QUERYLAYER"){
-					 		 $this->wmc_layer_querylayer[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WMS_ID"){
-					 		 $this->wmc_wms_id[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WFSFEATURETYPE"){
-					 		 $this->wmc_layer_wfs_featuretype[$cnt_layer] = $element[value];
-						 if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
-							 $metadataurl = true;
-						 if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "open"){
-							 $dataurl = true;
-						 if(strtoupper($element[tag]) == "FORMATLIST" && $element[type] == "open"){
-							 $formatlist = true;
-							 $cnt_format = -1;
-						 if(strtoupper($element[tag]) == "STYLELIST" && $element[type] == "open"){
-							 $stylelist = true;
-							 $cnt_style = -1;
-		return true;
-	  //return $verbose;
-	 * Creates JS code manipulating the map and wms objects,
-	 * by this displaying the WMC
-	 * @param string $target the link to the map object, f.e. "parent." or "window.opener."
-	 * @param string $mapObj the name of the map object, f.e. "mapframe1"
-	 * @param string $action "load", "merge" or "append"
-	 * @return string the JS code
-	function createJsObjFromWMC($target, $mapObj, $action){
-		 * counts how often a layer has been loaded
-		if ($this->monitoringIsOn) {
-			$monitor = new Layer_load_count();
-			for ($i = 0; $i < count($this->wmc_layer_id); $i++) {
-				$monitor->increment($this->wmc_layer_id[$i]);
-		$wmc_string = "";
-		$validActions = array("load", "merge", "append");
-		if (!in_array($action, $validActions)) {
-			$wmc_string .= "alert('invalid action: ".$action."');";
-		else {
-			// general extension
-			if (count($this->wmc_general_extension) > 0) {
-				$wmc_string .= $target . "restoredWmcExtensionData = " . $json->encode($this->wmc_general_extension) . ";\n";
-			$wmc_string .= "var index = " . $target . "getMapObjIndexByName('" . $mapObj . "');\n";
-			if ($action == "load") {
-				// delete all previous wms
-				$wmc_string .= "while(" . $target . "mb_mapObj[index].wms.length > 0){" . $target . "mb_mapObjremoveWMS(index,0);}";
-				$wmc_string .= $target . "deleteWmsObject();\n";
-			if ($action == "merge") {
-				$wmc_string .= "var wms_exists = false;\n";				// true if this wms exists in the mapObj
-				$wmc_string .= "var current_wms_index = null;\n";		// if wms_exists: index of the wms in the map obj; else: null
-				$wmc_string .= "var layer_exists = false;\n";			// true if this layer exists in an existing wms of the mapObj
-				$wmc_string .= "var current_layer_index = null;\n";		// if layer_exists: index of the layer of the wms in the mapObj; else: null
-			$new_wms = "";
-			$cnt_wms = -1;
-			$added_wms = array();
-			// for all layers in wmc, find individual wms...
-			for ($i = 0; $i < count($this->wmc_layer_title); $i++) {
-				$current_wms = $this->wmc_wms_serviceURL[$i];
-				// ...this is something like 'for every wms'
-				if (!in_array($current_wms , $added_wms)) {
-					$layerlist = "";
-					$querylayerlist = "";
-					$srs_array = array();
-						$wmc_string .= "wms_exists = false;\n";
-						$wmc_string .= "current_wms_index = null;\n";
-						$wmc_string .= "for (var m=0; m < " . $target . "mb_mapObj[index].wms.length; m++) {\n";
-						$wmc_string .= "\tif ('" . $this->wmc_wms_serviceURL[$i] . "' ==  " . $target . "mb_mapObj[index].wms[m].wms_getmap) {\n";
-						$wmc_string .= "\t\twms_exists = true;\n";
-						$wmc_string .= "\t\tcurrent_wms_index = m;\n";
-						$wmc_string .= "\t}\n";
-						$wmc_string .= "}\n";
-						$wmc_string .= "if (!wms_exists) {\n";
-					$mywms = new wms();
-			  		if(!$this->wmc_layer_title[$i] || $this->wmc_layer_title[$i] == ""){
-						echo "alert('Error: no valid capabilities-document !!');\n";
-						die; exit;
-					for($j=0;$j<count($this->wmc_layer_format[$i]);$j++){
-						if ($this->wmc_layer_format_current[$i][$j] == 1) {
-							$wms_data_format = $this->wmc_layer_format[$i][$j];
-					// add wms
-					$wmc_string .= "\t" . $target . "add_wms('".
-						$this->wmc_wms_id[$i]."','".
-						$this->wmc_wms_version[$i] ."','".
-						$this->wmc_wms_title[$i] ."','".
-						$this->wmc_layer_abstract[$i] ."','".
-						$this->wmc_wms_serviceURL[$i] ."','" .
-						$this->wmc_layer_style_legendurl[$i][0] ."','','".
-						$wms_data_format ."','text/html','application/vnd.ogc.se_xml','".
-						$this->wmc_bBox_SRS ."','1','100','');\n";
-					$added_wms[count($added_wms)] = $current_wms;
-					$cnt_wms++;
-					$cnt_layers = 0;
-					$cnt_query_layers = 0;
-					// add epsg
-					$wmc_string .= $target . "wms_addSRS('".
-						$this->wmc_bBox_SRS ."','".
-						$this->wmc_bBox_minx ."','".
-						$this->wmc_bBox_miny ."','".
-						$this->wmc_bBox_maxx ."','".
-						$this->wmc_bBox_maxy ."','".
-						"');\n";
-					// for each layer...
-					for ($ii = 0; $ii < count($this->wmc_layer_title); $ii++) {
-						$layer_wms = $this->wmc_wms_serviceURL[$ii];
-						// ... of this wms
-						if ($current_wms == $layer_wms) {
-							// add format (FIXME: is this working?)
-							$z = count($this->wmc_layer_format[$ii]);
-							for($j=0;$j<$z;$j++){
-								$wmc_string .= $target . "wms_add_data_type_format('map','". $this->wmc_layer_format[$ii][$j] ."');\n";
-							if ($cnt_layers == 0) {
-									$wmc_string .= "if (!wms_exists) {\n\t";
-								// add parent layer
-								$wmc_string .= $target . "wms_add_layer('','".
-									$this->wmc_wms_layer_id[$i]."','','".
-									$this->wmc_wms_title[$i] ."','','0','0','0','0','','".
-									$this->wmc_wms_id[$i]."','1','', '1','1','0','0','0','0','');\n";
-							$cnt_layers++;
-								$wmc_string .= "if (wms_exists) {\n";
-								// check if this layer already exists in this wms
-								$wmc_string .= "\tlayer_exists = false;\n";
-								$wmc_string .= "\tcurrent_layer_index = null;\n";
-								$wmc_string .= "\tfor (var m=0; m < " . $target . "mb_mapObj[index].wms[current_wms_index].objLayer.length; m++) {\n";
-								$wmc_string .= "\t\tif ('" . $this->wmc_layer_name[$ii] . "' ==  " . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[m].layer_name) {\n";
-								$wmc_string .= "\t\t\tlayer_exists = true;\n";
-								$wmc_string .= "\t\t\tcurrent_layer_index = m;\n";
-								$wmc_string .= "\t\t}\n";
-								if ($this->wmc_layer_querylayer[$ii]!="") {
-									$querylayer_yn = $this->wmc_layer_querylayer[$ii];
-								else {
-									$querylayer_yn = $this->wmc_layer_queryable[$ii];
-								$wmc_string .= "\tif (layer_exists) {\n";
-								// check if the visibility or the queryability are different to the existing layer
-								$wmc_string .= "\t\tif (" . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_visible != '" . intval(!$this->wmc_layer_hidden[$ii]) . "'";
-								$wmc_string .= " || " . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_querylayer != '" . $querylayer_yn . "') {\n";
-								// if yes, update the visibility and queryability
-								$wmc_string .= "\t\t\t" . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_visible = " . intval(!$this->wmc_layer_hidden[$ii]) . ";\n";
-								$wmc_string .= "\t\t\t" . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_querylayer = " . $querylayer_yn . ";\n";
-								$wmc_string .= "\telse {\n";
-							// add layer
-							$wmc_string .= "\t" . $target . "wms_add_layer('".
-								($this->wmc_layer_parent[$ii]!=""?$this->wmc_layer_parent[$ii]:"0") . "','".
-								$this->wmc_layer_id[$ii] . "','".
-								$this->wmc_layer_name[$ii] . "','".
-								$this->wmc_layer_title[$ii] ."','".
-								$this->wmc_layer_dataurl[$ii] . "','".
-								($this->wmc_layer_pos[$ii]!=""?$this->wmc_layer_pos[$ii]:intval($cnt_layers)) ."','".
-								$this->wmc_layer_queryable[$ii] ."','".
-								$this->wmc_layer_minscale[$ii]  ."','".
-								$this->wmc_layer_maxscale[$ii]  ."','".
-								$this->wmc_layer_metadataurl[$ii] ."','".
-								$this->wmc_wms_id[$i] ."','1','', '1','".
-								intval(!$this->wmc_layer_hidden[$ii]) ."','".
-								($this->wmc_layer_querylayer[$ii]!=""?$this->wmc_layer_querylayer[$ii]:$this->wmc_layer_queryable[$ii]) ."','".
-								($this->wmc_gui_layer_minscale[$ii]!=""?$this->wmc_gui_layer_minscale[$ii]:$this->wmc_layer_minscale[$ii]) ."','".
-								($this->wmc_gui_layer_maxscale[$ii]!=""?$this->wmc_gui_layer_maxscale[$ii]:$this->wmc_layer_maxscale[$ii]) ."','".
-								$this->wmc_layer_wfs_featuretype[$ii] . "');\n";
-							// if layer is queryable, add it to querylayerlist
-							if (($this->wmc_layer_querylayer[$ii]!=""?$this->wmc_layer_querylayer[$ii]:$this->wmc_layer_queryable[$ii])) {
-								$cnt_query_layers++;
-								if (!in_array($this->wmc_layer_name[$ii], explode(",",$querylayerlist))) {
-									if ($querylayerlist == "") {$querylayerlist = $this->wmc_layer_name[$ii];} else {$querylayerlist .= "," . $this->wmc_layer_name[$ii];}
-							// if layer is visible, add it to layerlist
-							if (intval(!$this->wmc_layer_hidden[$ii]) && !in_array($this->wmc_layer_name[$ii], explode(",",$layerlist))) {
-								if ($layerlist == "") {$layerlist = $this->wmc_layer_name[$ii];} else {$layerlist .= "," . $this->wmc_layer_name[$ii];}
-							// add layer style (FIXME: is this working?)
-							for($j=0; $j<count($this->wmc_layer_style_name[$ii]);$j++){
-								$wmc_string .= $target . "wms_addLayerStyle('".$this->wmc_layer_style_name[$ii][$j] ."','".$this->wmc_layer_style_title[$ii][$j] ."','".$j."','".$cnt_layers."', '" . $this->wmc_layer_style_legendurl[$ii][$j] . "', '" . $this->wmc_layer_style_legendurl_format[$ii][$j] . "');\n";
-					// add wms to mapObj with all layers and querylayers
-					$wmc_string .= $target. "mb_mapObjaddWMSwithLayers('" . $mapObj . "', '" . $layerlist . "', '" . $querylayerlist . "');\n";
-						$wmc_string .= "else {\n";
-						$wmc_string .= $target. "mb_mapObj[index].layers[current_wms_index] = \"" . $layerlist . "\";\n";
-						$wmc_string .= $target. "mb_mapObj[index].querylayers[current_wms_index] = \"" . $querylayerlist . "\";\n";
-			$wmc_string .= "var old_mapObj = ".$target."cloneObject(".$target."mb_mapObj);\n";
-			$wmc_string .= $target . "deleteMapObj();\n";
-			$wmc_string .= "for (var i=0; i<old_mapObj.length; i++) {\n";
-			$wmc_string .= "\tif (old_mapObj[i].frameName != 'overview') {\n";
-			$wmc_string .= "\t\t" . $target . "mb_registerMapObj(old_mapObj[i].frameName, old_mapObj[i].elementName, null, " . $this->wmc_windowWidth . ", " . $this->wmc_windowHeight . ");\n";
-			$wmc_string .= "\t\t" . $target . "document.getElementById(old_mapObj[i].frameName).style.width = " . $this->wmc_windowWidth . ";\n";
-			$wmc_string .= "\t\t" . $target . "document.getElementById(old_mapObj[i].frameName).style.height = " . $this->wmc_windowHeight . ";\n";
-			$wmc_string .= "\t\tvar found = false;\n";
-			$wmc_string .= "\t\tfor (var j=0; j < " . $target . "wms.length && found == false; j++) {\n";
-			$wmc_string .= "\t\t\tif (" . $target . "wms[j].wms_getmap == old_mapObj[i].wms[0].wms_getmap) {\n";
-			$wmc_string .= "\t\t\t\t" . $target . "mb_registerMapObj('overview', old_mapObj[i].elementName, j, old_mapObj[i].width,  old_mapObj[i].width);\n";
-			$wmc_string .= "\t\t\t\tfound = true;\n";
-			$wmc_string .= "\t\t\t}\n";
-			$wmc_string .= "\t\tif (!found) {\n";
-			$wmc_string .= "\t\t\t" . $target . "mb_registerMapObj('overview', old_mapObj[i].elementName, 0, old_mapObj[i].width,  old_mapObj[i].width);\n";
-			$ov_bbox = array();
-			// compute the union of the overview and the mapframe bbox for the new overview bbox
-			if ($this->wmc_general_extension["ov_minx"] && $this->wmc_general_extension["ov_miny"] &&
-				$this->wmc_general_extension["ov_maxx"] && $this->wmc_general_extension["ov_maxy"]) {
-				// box for overview
-				$ov_min = new Mapbender_point($this->wmc_general_extension["ov_minx"], $this->wmc_general_extension["ov_miny"], $this->wmc_bBox_SRS);
-				$ov_max = new Mapbender_point($this->wmc_general_extension["ov_maxx"], $this->wmc_general_extension["ov_maxy"], $this->wmc_bBox_SRS);
-				$ov_box = new Mapbender_bbox($ov_min, $ov_max, $this->wmc_bBox_SRS);
-				// box for mapframe
-				$mf_min = new Mapbender_point($this->wmc_bBox_minx, $this->wmc_bBox_miny, $this->wmc_bBox_SRS);
-				$mf_max = new Mapbender_point($this->wmc_bBox_maxx, $this->wmc_bBox_maxy, $this->wmc_bBox_SRS);
-				$mf_box = new Mapbender_bbox($mf_min, $mf_max, $this->wmc_bBox_SRS);
-				$unionBox = Mapbender_bbox::union(array($ov_box, $mf_box));
-				array_push($ov_bbox, $unionBox->min->x);
-				array_push($ov_bbox, $unionBox->min->y);
-				array_push($ov_bbox, $unionBox->max->x);
-				array_push($ov_bbox, $unionBox->max->y);
-			else {
-				$sql = "SELECT minx, miny, maxx, maxy FROM layer_epsg WHERE fkey_layer_id = $1 AND epsg = $2 LIMIT 1";
-				$v = array($this->wmc_layer_id[0], $this->wmc_bBox_SRS);
-				$t = array('i', 's');
-				$row = db_fetch_array($res);
-				if ($row["minx"] && $row["miny"] && $row["maxx"] && $row["maxy"]) {
-					$ov_bbox = array($row["minx"],$row["miny"],$row["maxx"],$row["maxy"]);
-				else if ($this->wmc_layer_id[0] && $this->wmc_bBox_SRS){
-					$ov_bbox = array($this->wmc_bBox_minx, $this->wmc_bBox_miny, $this->wmc_bBox_maxx, $this->wmc_bBox_maxy);
-				else {
-					$ov_bbox = array(2412139.175257732, 5365000, 2767860.824742268, 5700000);
-			$wmc_string .= "\t\t".$target."mb_calculateExtent(old_mapObj[i].frameName, ";
-			$wmc_string .= $this->wmc_bBox_minx .",".$this->wmc_bBox_miny .",";
-			$wmc_string .= $this->wmc_bBox_maxx .",".$this->wmc_bBox_maxy.");\n";
-			$wmc_string .= $ov_bbox[0] .",".$ov_bbox[1] .",";
-			$wmc_string .= $ov_bbox[2] .",".$ov_bbox[3] .");\n";
-			$wmc_string .= "\t". $target . "setMapRequest(old_mapObj[i].frameName);\n";
-			$wmc_string .= $target . "mb_execloadWmsSubFunctions();\n";
-//		$e = new mb_exception("js code: " . $wmc_string);
-		return $wmc_string;
-// end class
Modified: branches/nimix_dev/http/classes/class_wmcToXml.php
--- branches/nimix_dev/http/classes/class_wmcToXml.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_wmcToXml.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -108,17 +108,22 @@
 	private function createGeneralNode () {
+		$extensionData = array();
 		if ($this->wmc->overviewMap !== null) {
 			$ovExtent = $this->wmc->overviewMap->getExtent();
-			$extensionData->ov_minx = $ovExtent->min->x;
-			$extensionData->ov_miny = $ovExtent->min->y;
-			$extensionData->ov_maxx = $ovExtent->max->x;
-			$extensionData->ov_maxy = $ovExtent->max->y;
-			$extensionData->ov_srs = $ovExtent->epsg;
-			$extensionData->ov_framename = $this->wmc->overviewMap->getFrameName();
-			$extensionData->ov_width = $this->wmc->overviewMap->getWidth();
-			$extensionData->ov_height = $this->wmc->overviewMap->getHeight();
+			$extensionData["ov_minx"] = $ovExtent->min->x;
+			$extensionData["ov_miny"] = $ovExtent->min->y;
+			$extensionData["ov_maxx"] = $ovExtent->max->x;
+			$extensionData["ov_maxy"] = $ovExtent->max->y;
+			$extensionData["ov_srs"] = $ovExtent->epsg;
+			$extensionData["ov_framename"] = $this->wmc->overviewMap->getFrameName();
+			$extensionData["ov_width"] = $this->wmc->overviewMap->getWidth();
+			$extensionData["ov_height"] = $this->wmc->overviewMap->getHeight();
+		if ($this->wmc->mainMap !== null) {
+			$extensionData["main_framename"] = $this->wmc->mainMap->getFrameName();
 		// General
 		$e_general = $this->doc->createElement("General");
@@ -364,6 +369,8 @@
 		$layerExtensionData["gui_selectable"] = $currentLayer->gui_layer_selectable;
 		$layerExtensionData["gui_queryable"] = $currentLayer->gui_layer_queryable;
 		$layerExtensionData["gui_status"] = $currentLayer->gui_layer_status;
+		$layerExtensionData["layer_epsg"] = $currentLayer->layer_epsg;
 		if ($currentMap->isOverview()) {
 			$layerExtensionData["isOverviewLayer"] = 1;
@@ -375,7 +382,7 @@
 			$e_extension = $this->doc->createElement("Extension");
 			foreach ($layerExtensionData as $keyExtensionData => $valueExtensionData) {
-				$e_currentExtensionTag = $this->doc->createElement($this->wmc->extensionNamespace.":".$keyExtensionData, $valueExtensionData);
+				$e_currentExtensionTag = $this->addExtension($keyExtensionData, $valueExtensionData);
 				$e_extension->appendChild($e_currentExtensionTag);
 			return $e_extension;
@@ -383,6 +390,23 @@
 		return null;
+	private function addExtension ($key, $value) {
+		if (is_array($value)) {
+			if (is_numeric($key)) {
+				$key = "data" . $key;
+			$e_currentExtensionTag = $this->doc->createElement($this->wmc->extensionNamespace.":".$key);
+			foreach ($value as $childKey => $childValue) {
+				$newNode = $this->addExtension($childKey, $childValue);
+				$e_currentExtensionTag->appendChild($newNode);
+		else {
+			$e_currentExtensionTag = $this->doc->createElement($this->wmc->extensionNamespace.":".$key, $value);
+		return $e_currentExtensionTag;
 	private function createLayerStyleNode ($currentWms, $currentLayer) {
 		$e_layer_stylelist = $this->doc->createElement("StyleList");
@@ -533,4 +557,4 @@
\ No newline at end of file
Modified: branches/nimix_dev/http/classes/class_wms.php
--- branches/nimix_dev/http/classes/class_wms.php	2008-08-18 16:00:13 UTC (rev 2866)
+++ branches/nimix_dev/http/classes/class_wms.php	2008-08-18 16:03:32 UTC (rev 2867)
@@ -17,15 +17,11 @@
-include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 require_once(dirname(__FILE__)."/class_connector.php");
-require_once(dirname(__FILE__)."/class_mb_exception.php");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
 class wms {
 	var $lastURL;
 	var $wms_id;
@@ -240,7 +236,7 @@
 		$values = null;
 		$tags = null;
 		$admin = new administration();
-		$this->wms_getcapabilities_doc = $admin->char_encode($data);
+		$this->wms_getcapabilities_doc = $data;
 		$this->wms_upload_url = $url;
 		$this->wms_certificateFile = $cert;
 		$this->wms_certificatePassphrase = $pass;
@@ -250,7 +246,7 @@
-		xml_parse_into_struct($parser,$this->wms_getcapabilities_doc,$values,$tags);
+		xml_parse_into_struct($parser,$data,$values,$tags);
 		$code = xml_get_error_code($parser);
 		if ($code) {
@@ -635,13 +631,13 @@
 		if(!$this->wms_title || $this->wms_title == "" || !$this->wms_getmap || $this->wms_getmap == ""){
 			$this->wms_status = false;
 			$this->optimizeWMS();
+			$e = new mb_exception("class_wms: createObjFromXML: WMS " . $url . " could not be loaded.");
 			return false;
 		else{
 			$this->wms_status = true;
+			$e = new mb_notice("class_wms: createObjFromXML: WMS " . $url . " has been loaded successfully.");
 			return true;
@@ -867,19 +863,40 @@
 		$newLayer->layer_abstract = $currentLayer["abstract"];
 		// set layer epsg
 		$newLayer->layer_epsg = array();
-		if ($currentExtent !== null) {
-			$currentLayerEpsg = array();
-			$currentLayerEpsg["epsg"] = $currentExtent->epsg;
-			$currentLayerEpsg["minx"] = $currentExtent->min->x;
-			$currentLayerEpsg["miny"] = $currentExtent->min->y;
-			$currentLayerEpsg["maxx"] = $currentExtent->max->x;
-			$currentLayerEpsg["maxy"] = $currentExtent->max->y;
-			array_push($newLayer->layer_epsg, $currentLayerEpsg);
+		if ($currentLayer["extension"]["EPSG"]) {
+			$layerEpsgArray = array();
+			$layerMinXArray = array();
+			$layerMinYArray = array();
+			$layerMaxXArray = array();
+			$layerMaxYArray = array();
+			if (!is_array($currentLayer["extension"]["EPSG"])) {
+				$layerEpsgArray[0] = $currentLayer["extension"]["EPSG"];
+				$layerMinXArray[0] = $currentLayer["extension"]["MINX"];
+				$layerMinYArray[0] = $currentLayer["extension"]["MINY"];
+				$layerMaxXArray[0] = $currentLayer["extension"]["MAXX"];
+				$layerMaxYArray[0] = $currentLayer["extension"]["MAXY"];
+			else {
+				$layerEpsgArray = $currentLayer["extension"]["EPSG"];
+				$layerMinXArray = $currentLayer["extension"]["MINX"];
+				$layerMinYArray = $currentLayer["extension"]["MINY"];
+				$layerMaxXArray = $currentLayer["extension"]["MAXX"];
+				$layerMaxYArray = $currentLayer["extension"]["MAXY"];
+			for ($i=0; $i < count($layerEpsgArray); $i++) {
+				$currentLayerEpsg = array();
+				$currentLayerEpsg["epsg"] = $layerEpsgArray[$i];
+				$currentLayerEpsg["minx"] = floatval($layerMinXArray[$i]);
+				$currentLayerEpsg["miny"] = floatval($layerMinYArray[$i]);
+				$currentLayerEpsg["maxx"] = floatval($layerMaxXArray[$i]);
+				$currentLayerEpsg["maxy"] = floatval($layerMaxYArray[$i]);
+				array_push($newLayer->layer_epsg, $currentLayerEpsg);
@@ -1121,7 +1138,8 @@
 	function writeObjInDB($gui_id){
 		global $con;
+		$admin = new administration();
 		$this->checkObj();
 		db_begin();
@@ -1134,7 +1152,7 @@
 		$sql .= "wms_supportsld, wms_userlayer, wms_userstyle, wms_remotewfs, wms_certificatefile, wms_certificatepassphrase) ";
 		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24,$25,$26,$27,$28, $29, $30)";
 		$v = array($this->wms_version,$this->wms_title,$this->wms_abstract,$this->wms_getcapabilities,
-			$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,$this->wms_getcapabilities_doc,
+			$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,$admin->char_encode($this->wms_getcapabilities_doc),
 			$this->wms_upload_url,$this->fees,$this->accessconstraints,$this->contactperson,$this->contactposition,
 			$this->contactorganization,$this->address,$this->city,$this->stateorprovince,$this->postcode,$this->country,
 			$this->contactvoicetelephone,$this->contactfacsimiletelephone,$this->contactelectronicmailaddress,
@@ -1460,6 +1478,7 @@
 	function updateObjInDB($myWMS){
 		db_begin();
 		$sql = "UPDATE wms SET ";
@@ -1482,7 +1501,7 @@
 		$v = array($this->wms_version,$this->wms_getcapabilities,
-			$this->wms_getcapabilities_doc,$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),
+			$admin->char_encode($this->wms_getcapabilities_doc),$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),
 			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs,
 			$this->wms_certificateFile, $this->wms_certificatePassphrase,$myWMS);
 		$t = array('s','s','s','s','s','s','s','i','i','s','s','s','s','s','s','i');
@@ -1822,6 +1841,9 @@
 					$this->wms_getfeatureinfo = $row2["wms_getfeatureinfo"];
 					$this->wms_getlegendurl = $row2["wms_getlegendurl"];
+				// TO DO: Capabilities document needs to
+				// be encoded to the original encoding
+				// if different from the database encoding
 				$this->wms_getcapabilities_doc = $row2["wms_getcapabilities_doc"];
 				$this->wms_filter = $row2["wms_filter"];
 				$this->wms_supportsld = $row2["wms_supportsld"];
@@ -1963,6 +1985,9 @@
@@ -1976,6 +2001,18 @@
 			$this->gui_wms_epsg=$row["gui_wms_epsg"];
 			$this->gui_wms_sldurl = $row["gui_wms_sldurl"];
+			if($this->wms_version == "1.0.0"){
+                    $this->gui_wms_mapformat = "PNG";
+                    $this->gui_wms_featureinfoformat = "MIME";
+                    $this->gui_wms_exceptionformat = "INIMAGE";
+            /*define defaults for wms-version 1.1.0 and 1.1.1*/
+            else{
+                    $this->gui_wms_mapformat = "image/png";
+                    $this->gui_wms_featureinfoformat = "text/html";
+                    $this->gui_wms_exceptionformat = "application/vnd.ogc.se_inimage";
 			$count_wms++;
@@ -2210,4 +2247,4 @@
More information about the Mapbender_commits mailing list
