[Mapbender-commits] r2865 - branches/nimix_dev/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Aug 18 11:58:39 EDT 2008
Author: nimix
Date: 2008-08-18 11:58:39 -0400 (Mon, 18 Aug 2008)
New Revision: 2865
Added:
   branches/nimix_dev/resources/db/schema_2.5.dia
Copied: branches/nimix_dev/resources/db/schema_2.5.dia (from rev 2864, trunk/mapbender/resources/db/schema_2.5.dia)
--- branches/nimix_dev/resources/db/schema_2.5.dia	                        (rev 0)
+++ branches/nimix_dev/resources/db/schema_2.5.dia	2008-08-18 15:58:39 UTC (rev 2865)
@@ -0,0 +1,16388 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<dia:diagram xmlns:dia="http://www.lysator.liu.se/~alla/dia/">
+  <dia:diagramdata>
+    <dia:attribute name="background">
+      <dia:color val="#ffffff"/>
+    </dia:attribute>
+    <dia:attribute name="pagebreak">
+      <dia:color val="#000099"/>
+    </dia:attribute>
+    <dia:attribute name="paper">
+      <dia:composite type="paper">
+        <dia:attribute name="name">
+          <dia:string>#A4#</dia:string>
+        </dia:attribute>
+        <dia:attribute name="tmargin">
+          <dia:real val="2.8222000598907471"/>
+        </dia:attribute>
+        <dia:attribute name="bmargin">
+        </dia:attribute>
+        <dia:attribute name="lmargin">
+        </dia:attribute>
+        <dia:attribute name="rmargin">
+        </dia:attribute>
+        <dia:attribute name="is_portrait">
+          <dia:boolean val="true"/>
+        </dia:attribute>
+        <dia:attribute name="scaling">
+          <dia:real val="1"/>
+        </dia:attribute>
+        <dia:attribute name="fitto">
+          <dia:boolean val="false"/>
+        </dia:attribute>
+      </dia:composite>
+    </dia:attribute>
+    <dia:attribute name="grid">
+      <dia:composite type="grid">
+        <dia:attribute name="width_x">
+        </dia:attribute>
+        <dia:attribute name="width_y">
+        </dia:attribute>
+        <dia:attribute name="visible_x">
+          <dia:int val="1"/>
+        </dia:attribute>
+        <dia:attribute name="visible_y">
+        </dia:attribute>
+        <dia:composite type="color"/>
+      </dia:composite>
+    </dia:attribute>
+    <dia:attribute name="color">
+      <dia:color val="#d8e5e5"/>
+    </dia:attribute>
+    <dia:attribute name="guides">
+      <dia:composite type="guides">
+        <dia:attribute name="hguides"/>
+        <dia:attribute name="vguides"/>
+      </dia:composite>
+    </dia:attribute>
+  </dia:diagramdata>
+  <dia:layer name="Background" visible="true">
+    <dia:object type="UML - Class" version="0" id="O0">
+      <dia:attribute name="obj_pos">
+        <dia:point val="-27,-29"/>
+      </dia:attribute>
+      <dia:attribute name="obj_bb">
+        <dia:rectangle val="-27.05,-29.05;-9.3,-24.15"/>
+      </dia:attribute>
+      <dia:attribute name="elem_corner">
+      </dia:attribute>
+      <dia:attribute name="elem_width">
+        <dia:real val="17.649999999999999"/>
+      </dia:attribute>
+      <dia:attribute name="elem_height">
+        <dia:real val="4.8000000000000007"/>
+      </dia:attribute>
+        <dia:string>#mb_group#</dia:string>
+      </dia:attribute>
+      <dia:attribute name="stereotype">
+        <dia:string>##</dia:string>
+      </dia:attribute>
+      <dia:attribute name="comment">
+      </dia:attribute>
+      <dia:attribute name="abstract">
+      </dia:attribute>
+      <dia:attribute name="suppress_attributes">
+      </dia:attribute>
+      <dia:attribute name="suppress_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_attributes">
+      </dia:attribute>
+      <dia:attribute name="visible_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_comments">
+      </dia:attribute>
+      <dia:attribute name="wrap_operations">
+      </dia:attribute>
+      <dia:attribute name="wrap_after_char">
+        <dia:int val="40"/>
+      </dia:attribute>
+      <dia:attribute name="comment_line_length">
+      </dia:attribute>
+      <dia:attribute name="comment_tagging">
+      </dia:attribute>
+      <dia:attribute name="line_color">
+        <dia:color val="#000000"/>
+      </dia:attribute>
+      <dia:attribute name="fill_color">
+        <dia:color val="#add8e6"/>
+      </dia:attribute>
+      <dia:attribute name="text_color">
+      </dia:attribute>
+      <dia:attribute name="normal_font">
+        <dia:font family="monospace" style="0" name="Courier"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_font">
+        <dia:font family="monospace" style="88" name="Courier-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font">
+        <dia:font family="monospace" style="8" name="Courier-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="classname_font">
+        <dia:font family="sans" style="80" name="Helvetica-Bold"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font">
+        <dia:font family="sans" style="88" name="Helvetica-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="comment_font">
+        <dia:font family="sans" style="8" name="Helvetica-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="normal_font_height">
+        <dia:real val="0.80000000000000004"/>
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font_height">
+      </dia:attribute>
+      <dia:attribute name="abstract_font_height">
+      </dia:attribute>
+      <dia:attribute name="classname_font_height">
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font_height">
+      </dia:attribute>
+      <dia:attribute name="comment_font_height">
+      </dia:attribute>
+      <dia:attribute name="attributes">
+        <dia:composite type="umlattribute">
+            <dia:string>#mb_group_id#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="type">
+            <dia:string>#integer#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="value">
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="visibility">
+            <dia:enum val="2"/>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="class_scope">
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_group_name#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(50)#</dia:string>
+          </dia:attribute>
+            <dia:string>#'' NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:enum val="0"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_group_owner#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_group_description#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(255)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="operations"/>
+      <dia:attribute name="template">
+      </dia:attribute>
+      <dia:attribute name="templates"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O1">
+        <dia:point val="-47,-29"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-29.05;-31.05,-12.15"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="15.9"/>
+      </dia:attribute>
+        <dia:real val="16.800000000000004"/>
+      </dia:attribute>
+        <dia:string>#mb_user#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#mb_user_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_password#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_owner#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#0 NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_description#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_login_count#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_email#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_phone#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_department#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_resolution#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#72 NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_organisation_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_position_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_phone1#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_facsimile#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_delivery_point#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_city#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_postal_code#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_country#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_online_resource#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O2">
+        <dia:point val="-35,-34"/>
+      </dia:attribute>
+        <dia:rectangle val="-35.05,-34.05;-23.95,-30.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="11"/>
+      </dia:attribute>
+        <dia:real val="3.2000000000000002"/>
+      </dia:attribute>
+        <dia:string>#mb_user_mb_group#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#fkey_mb_user_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#0#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_mb_group_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O3">
+        <dia:point val="-39.05,-29.0481"/>
+      </dia:attribute>
+        <dia:rectangle val="-48.85,-32.9;-34.25,-28.2481"/>
+      </dia:attribute>
+      <dia:attribute name="orth_points">
+        <dia:point val="-39.05,-32.1"/>
+        <dia:point val="-35,-32.1"/>
+      </dia:attribute>
+      <dia:attribute name="orth_orient">
+        <dia:enum val="1"/>
+      </dia:attribute>
+      <dia:attribute name="autorouting">
+      </dia:attribute>
+      </dia:attribute>
+      <dia:attribute name="direction">
+      </dia:attribute>
+      <dia:attribute name="ends">
+        <dia:composite>
+          <dia:attribute name="role">
+          </dia:attribute>
+          <dia:attribute name="multiplicity">
+          </dia:attribute>
+          <dia:attribute name="arrow">
+          </dia:attribute>
+          <dia:attribute name="aggregate">
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+            <dia:string>#on delete cascade on update cascade#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O1" connection="46"/>
+        <dia:connection handle="1" to="O2" connection="8"/>
+      </dia:connections>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O4">
+        <dia:point val="-18.175,-29.0503"/>
+      </dia:attribute>
+        <dia:rectangle val="-24.75,-32.9;-10.15,-28.2503"/>
+      </dia:attribute>
+        <dia:point val="-18.175,-32.1"/>
+        <dia:point val="-24,-32.1"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O0" connection="16"/>
+        <dia:connection handle="1" to="O2" connection="9"/>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O5">
+        <dia:point val="-47,-6"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-6.95;-1.2,-3.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="45.75"/>
+      </dia:attribute>
+        <dia:real val="2.2000000000000002"/>
+      </dia:attribute>
+      <dia:attribute name="line_colour">
+      </dia:attribute>
+      <dia:attribute name="fill_colour">
+      </dia:attribute>
+        <dia:string>#postgres:post#</dia:string>
+      </dia:attribute>
+      <dia:attribute name="text">
+        <dia:composite type="text">
+          <dia:attribute name="string">
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_user','mb_user_id'), (SELECT max(mb_user_id) FROM mb_user), true);#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="font">
+          </dia:attribute>
+          <dia:attribute name="height">
+          </dia:attribute>
+          <dia:attribute name="pos">
+            <dia:point val="-46.7,-4.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="alignment">
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O6">
+        <dia:point val="-47,-2"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-2.95;-15.55,0.25"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="31.400000000000002"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#innodb:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE mb_user CHANGE COLUMN mb_user_id mb_user_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-0.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O7">
+        <dia:point val="-47,-11"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-11.95;-14.15,-7.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="32.800000000000004"/>
+      </dia:attribute>
+        <dia:real val="3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#postgres:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE mb_user_id_seq;
+ALTER TABLE mb_user ALTER COLUMN mb_user_id SET DEFAULT nextval('mb_user_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-9.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O8">
+        <dia:point val="-27,-14"/>
+      </dia:attribute>
+        <dia:rectangle val="-27.05,-14.95;5.5,-11.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="32.450000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE mb_group CHANGE COLUMN mb_group_id mb_group_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-26.7,-12.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O9">
+        <dia:point val="-27,-18"/>
+      </dia:attribute>
+        <dia:rectangle val="-27.05,-18.95;20.2,-15.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="47.149999999999999"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_group','mb_group_id'), (SELECT max(mb_group_id) FROM mb_group), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-26.7,-16.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O10">
+        <dia:point val="-27,-23"/>
+      </dia:attribute>
+        <dia:rectangle val="-27.05,-23.95;6.9,-19.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="33.850000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE mb_group_id_seq;
+ALTER TABLE mb_group ALTER COLUMN mb_group_id SET DEFAULT nextval('mb_group_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-26.7,-21.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O11">
+        <dia:point val="34,-33"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-33.05;49.95,-28.15"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#gui#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#90ee90"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#gui_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#'' not null#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_description#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_public#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#1 not null#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O12">
+        <dia:point val="55,-27"/>
+      </dia:attribute>
+        <dia:rectangle val="54.95,-27.05;68.85,-8.55"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="13.800000000000001"/>
+      </dia:attribute>
+        <dia:real val="18.400000000000006"/>
+      </dia:attribute>
+        <dia:string>#gui_element#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#fkey_gui_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#''#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_pos#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_public#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_comment#</dia:string>
+          </dia:attribute>
+            <dia:string>#text#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_element#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_attributes#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_left#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_tio#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_width#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_height#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_z_index#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_more_styles#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_content#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_closetag#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_js_file#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_mb_mod#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_target#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_requires#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#e_url#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="operations">
+        <dia:composite type="umloperation">
+            <dia:string>#gui_element_idx#</dia:string>
+          </dia:attribute>
+            <dia:string>#btree#</dia:string>
+          </dia:attribute>
+            <dia:string>#unique index#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="inheritance_type">
+          </dia:attribute>
+          <dia:attribute name="query">
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="parameters">
+            <dia:composite type="umlparameter">
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              <dia:attribute name="kind">
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O13">
+        <dia:point val="34,-22.8"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-22.85;45.05,-16.35"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="6.4000000000000004"/>
+      </dia:attribute>
+        <dia:string>#gui_element_vars#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_e_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#var_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#var_value#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#context#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#var_type#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+            <dia:string>#gui_element_vars_idx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#index#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O14">
+        <dia:point val="54.9496,-17.8"/>
+      </dia:attribute>
+        <dia:rectangle val="44.25,-20.85;58.85,-17.285"/>
+      </dia:attribute>
+        <dia:point val="49.9748,-17.8"/>
+        <dia:point val="49.9748,-20.1"/>
+        <dia:point val="45,-20.1"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#fkey_gui_id,e_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+            <dia:string>#fkey_gui_id,fkey_e_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O12" connection="50"/>
+        <dia:connection handle="1" to="O13" connection="11"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O15">
+        <dia:point val="49.9,-29.5"/>
+      </dia:attribute>
+        <dia:rectangle val="49.85,-30.585;74.7,-26.25"/>
+      </dia:attribute>
+        <dia:point val="61.9,-29.5"/>
+        <dia:point val="61.9,-27"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="13"/>
+        <dia:connection handle="1" to="O12" connection="1"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O16">
+        <dia:point val="1,-34"/>
+      </dia:attribute>
+        <dia:rectangle val="0.95,-34.05;12.05,-29.95"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="4"/>
+      </dia:attribute>
+        <dia:string>#gui_mb_user#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_user_type#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O17">
+        <dia:point val="-47,-28.3"/>
+      </dia:attribute>
+        <dia:rectangle val="-50.7,-37.8;19.3,-27.785"/>
+      </dia:attribute>
+        <dia:point val="-48,-28.3"/>
+        <dia:point val="-48,-37"/>
+        <dia:point val="6.5,-37"/>
+        <dia:point val="6.5,-34"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O1" connection="3"/>
+        <dia:connection handle="1" to="O16" connection="1"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O18">
+        <dia:point val="41.95,-28.2"/>
+      </dia:attribute>
+        <dia:rectangle val="11.25,-31.25;44.25,-26.6"/>
+      </dia:attribute>
+        <dia:point val="41.95,-27"/>
+        <dia:point val="19,-27"/>
+        <dia:point val="19,-30.5"/>
+        <dia:point val="12,-30.5"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="6"/>
+        <dia:connection handle="1" to="O16" connection="13"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O19">
+        <dia:point val="73,-129"/>
+      </dia:attribute>
+        <dia:rectangle val="72.95,-129.05;90.35,-101.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="17.300000000000001"/>
+      </dia:attribute>
+        <dia:real val="27.200000000000014"/>
+      </dia:attribute>
+        <dia:string>#wms#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffc0cb"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#wms_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_version#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getcapabilities#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getmap#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getfeatureinfo#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getlegendurl#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_filter#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_owsproxy#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_upload_url#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fees#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#accessconstraints#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactperson#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactposition#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactorganization#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#address#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#city#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#stateorprovince#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#postcode#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#country#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactvoicetelephone#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactfacsimiletelephone#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#contactelectronicmailaddress#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_mb_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_owner#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_timestamp#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_supportsld#</dia:string>
+          </dia:attribute>
+            <dia:string>#boolean#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_userlayer#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_userstyle#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_remotewfs#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O20">
+        <dia:point val="73,-95"/>
+      </dia:attribute>
+        <dia:rectangle val="72.95,-95.95;113.2,-92.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="40.149999999999999"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wms','wms_id'), (SELECT max(wms_id) FROM wms), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="73.3,-93.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O21">
+        <dia:point val="73,-91"/>
+      </dia:attribute>
+        <dia:rectangle val="72.95,-91.95;100.25,-88.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="27.200000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE wms CHANGE COLUMN wms_id wms_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="73.3,-89.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O22">
+        <dia:point val="73,-100"/>
+      </dia:attribute>
+        <dia:rectangle val="72.95,-100.95;101.65,-96.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="28.600000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE wms_id_seq;
+ALTER TABLE wms ALTER COLUMN wms_id SET DEFAULT nextval('wms_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="73.3,-98.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O23">
+        <dia:point val="53,-79"/>
+      </dia:attribute>
+        <dia:rectangle val="52.95,-79.05;67.55,-67.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="14.5"/>
+      </dia:attribute>
+        <dia:real val="11.200000000000001"/>
+      </dia:attribute>
+        <dia:string>#layer#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#layer_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_wms_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_pos#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_parent#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_queryable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_minscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_maxscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_dataurl#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_metadataurl#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O24">
+        <dia:point val="34,-89"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-89.05;48.2,-77.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="14.15"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#gui_layer#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_layer_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_wms_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_status#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#1#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_selectable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_visible#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_queryable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_minscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_maxscale#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_priotity#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_style#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_layer_wfs_featuretype#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O25">
+        <dia:point val="98,-54"/>
+      </dia:attribute>
+        <dia:rectangle val="97.95,-54.05;115.35,-31.55"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="22.400000000000009"/>
+      </dia:attribute>
+        <dia:string>#wfs#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffa500"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#wfs_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_version#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_getcapabilities#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_getfeature#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_transaction#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_owsproxy#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_upload_url#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#individualname#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#positionname#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#providername#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#deliverypoint#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#postalcode#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#voice#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#facsimile#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#electronicmailaddress#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_mb_getcapabilities_doc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_owner#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_timestamp#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O26">
+        <dia:point val="34,-31.1"/>
+      </dia:attribute>
+        <dia:rectangle val="20.0997,-84.15;34.6997,-30.585"/>
+      </dia:attribute>
+        <dia:point val="28,-31.1"/>
+        <dia:point val="28,-83.4"/>
+        <dia:point val="33.9497,-83.4"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="8"/>
+        <dia:connection handle="1" to="O24" connection="32"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O27">
+        <dia:point val="53,-74.7"/>
+      </dia:attribute>
+        <dia:rectangle val="40.325,-78.55;53.875,-74.185"/>
+      </dia:attribute>
+        <dia:point val="41.075,-74.7"/>
+        <dia:point val="41.075,-77.8"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O23" connection="14"/>
+        <dia:connection handle="1" to="O24" connection="6"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O28">
+        <dia:point val="73,-105.5"/>
+      </dia:attribute>
+        <dia:rectangle val="66.75,-106.585;81.35,-77.3825"/>
+      </dia:attribute>
+        <dia:point val="71,-105.5"/>
+        <dia:point val="71,-78.3"/>
+        <dia:point val="67.5,-78.3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O19" connection="62"/>
+        <dia:connection handle="1" to="O23" connection="4"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O29">
+        <dia:point val="80,-44"/>
+      </dia:attribute>
+        <dia:rectangle val="79.95,-44.05;91.05,-40.75"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#gui_wfs#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_wfs_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O30">
+        <dia:point val="49.9,-32.3"/>
+      </dia:attribute>
+        <dia:rectangle val="49.85,-47.8;98.3,-31.785"/>
+      </dia:attribute>
+        <dia:point val="78,-32.3"/>
+        <dia:point val="78,-47"/>
+        <dia:point val="85.5,-47"/>
+        <dia:point val="85.5,-44"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="4"/>
+        <dia:connection handle="1" to="O29" connection="1"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O31">
+        <dia:point val="98,-48.9"/>
+      </dia:attribute>
+        <dia:rectangle val="95.7,-49.985;144.75,-15.5825"/>
+      </dia:attribute>
+        <dia:point val="96,-48.9"/>
+        <dia:point val="96,-16.5"/>
+        <dia:point val="144,-16.5"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O25" connection="16"/>
+        <dia:connection handle="1" to="O41" connection="22"/>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O32">
+        <dia:point val="98,-25"/>
+      </dia:attribute>
+        <dia:rectangle val="97.95,-25.95;138.2,-22.75"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs','wfs_id'), (SELECT max(wfs_id) FROM wfs), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="98.3,-23.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O33">
+        <dia:point val="98,-21"/>
+      </dia:attribute>
+        <dia:rectangle val="97.95,-21.95;125.25,-18.75"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE wfs CHANGE COLUMN wfs_id wfs_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="98.3,-19.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O34">
+        <dia:point val="98,-30"/>
+      </dia:attribute>
+        <dia:rectangle val="97.95,-30.95;126.65,-26.95"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE wfs_id_seq;
+ALTER TABLE wfs ALTER COLUMN wfs_id SET DEFAULT nextval('wfs_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="98.3,-28.3575"/>
+          </dia:attribute>
+          <dia:attribute name="color">
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O35">
+      <dia:attribute name="obj_pos">
+        <dia:point val="-1,-29"/>
+      </dia:attribute>
+      <dia:attribute name="obj_bb">
+        <dia:rectangle val="-1.05,-29.05;13.9,-24.95"/>
+      </dia:attribute>
+      <dia:attribute name="elem_corner">
+      </dia:attribute>
+      <dia:attribute name="elem_width">
+        <dia:real val="14.85"/>
+      </dia:attribute>
+      <dia:attribute name="elem_height">
+      </dia:attribute>
+      <dia:attribute name="name">
+        <dia:string>#gui_mb_group#</dia:string>
+      </dia:attribute>
+      <dia:attribute name="stereotype">
+        <dia:string>##</dia:string>
+      </dia:attribute>
+      <dia:attribute name="comment">
+      </dia:attribute>
+      <dia:attribute name="abstract">
+        <dia:boolean val="false"/>
+      </dia:attribute>
+      <dia:attribute name="suppress_attributes">
+      </dia:attribute>
+      <dia:attribute name="suppress_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_attributes">
+        <dia:boolean val="true"/>
+      </dia:attribute>
+      <dia:attribute name="visible_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_comments">
+      </dia:attribute>
+      <dia:attribute name="wrap_operations">
+      </dia:attribute>
+      <dia:attribute name="wrap_after_char">
+        <dia:int val="40"/>
+      </dia:attribute>
+      <dia:attribute name="comment_line_length">
+      </dia:attribute>
+      <dia:attribute name="comment_tagging">
+      </dia:attribute>
+      <dia:attribute name="line_color">
+        <dia:color val="#000000"/>
+      </dia:attribute>
+      <dia:attribute name="fill_color">
+        <dia:color val="#add8e6"/>
+      </dia:attribute>
+      <dia:attribute name="text_color">
+      </dia:attribute>
+      <dia:attribute name="normal_font">
+        <dia:font family="monospace" style="0" name="Courier"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_font">
+        <dia:font family="monospace" style="88" name="Courier-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font">
+        <dia:font family="monospace" style="8" name="Courier-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="classname_font">
+        <dia:font family="sans" style="80" name="Helvetica-Bold"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font">
+        <dia:font family="sans" style="88" name="Helvetica-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="comment_font">
+        <dia:font family="sans" style="8" name="Helvetica-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="normal_font_height">
+        <dia:real val="0.80000000000000004"/>
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font_height">
+      </dia:attribute>
+      <dia:attribute name="abstract_font_height">
+      </dia:attribute>
+      <dia:attribute name="classname_font_height">
+        <dia:real val="1"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font_height">
+      </dia:attribute>
+      <dia:attribute name="comment_font_height">
+      </dia:attribute>
+      <dia:attribute name="attributes">
+        <dia:composite type="umlattribute">
+          </dia:attribute>
+          <dia:attribute name="type">
+          </dia:attribute>
+          <dia:attribute name="value">
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="visibility">
+            <dia:enum val="2"/>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="class_scope">
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+            <dia:string>#integer#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_group_type#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(50)#</dia:string>
+          </dia:attribute>
+            <dia:string>#'' NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:enum val="0"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O36">
+        <dia:point val="-9.35,-26.3"/>
+      </dia:attribute>
+        <dia:rectangle val="-14.85,-27.85;-0.25,-25.785"/>
+      </dia:attribute>
+        <dia:point val="-5.175,-26.3"/>
+        <dia:point val="-5.175,-27.1"/>
+        <dia:point val="-1,-27.1"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#mb_group_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O0" connection="11"/>
+        <dia:connection handle="1" to="O35" connection="8"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O37">
+        <dia:point val="49.9,-28.7"/>
+      </dia:attribute>
+        <dia:rectangle val="13.1,-29.785;52.2,-24.5825"/>
+      </dia:attribute>
+        <dia:point val="52,-28.7"/>
+        <dia:point val="52,-25.5"/>
+        <dia:point val="13.85,-25.5"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="15"/>
+        <dia:connection handle="1" to="O35" connection="13"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O38">
+        <dia:point val="34,-100"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-100.05;53.1,-90.35"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="19.050000000000001"/>
+      </dia:attribute>
+        <dia:real val="9.5999999999999996"/>
+      </dia:attribute>
+        <dia:string>#gui_wms#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_position#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#0 NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_mapformat#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_featureinfoformat#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_exceptionformat#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_epsg#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_visible#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#1 NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_sldurl#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(255)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui_wms_opacity#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#100#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+            <dia:string>#gui_wms_idx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="template">
+      </dia:attribute>
+      <dia:attribute name="templates"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O39">
+        <dia:point val="34,-30.3"/>
+      </dia:attribute>
+        <dia:rectangle val="20.15,-98.05;34.75,-29.785"/>
+      </dia:attribute>
+        <dia:point val="26,-30.3"/>
+        <dia:point val="26,-97.3"/>
+        <dia:point val="34,-97.3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="10"/>
+        <dia:connection handle="1" to="O38" connection="10"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O40">
+        <dia:point val="73,-107.9"/>
+      </dia:attribute>
+        <dia:rectangle val="52.3503,-108.985;73.05,-94.2825"/>
+      </dia:attribute>
+        <dia:point val="69,-107.9"/>
+        <dia:point val="69,-95.2"/>
+        <dia:point val="53.1003,-95.2"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O19" connection="56"/>
+        <dia:connection handle="1" to="O38" connection="28"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O41">
+        <dia:point val="144,-24"/>
+      </dia:attribute>
+        <dia:rectangle val="143.95,-24.05;159.25,-11.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="15.199999999999999"/>
+      </dia:attribute>
+        <dia:real val="12.000000000000002"/>
+      </dia:attribute>
+        <dia:string>#wfs_conf#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#wfs_conf_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_conf_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_featuretype_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_label#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_label_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_button#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_button_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_style#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_buffer#</dia:string>
+          </dia:attribute>
+            <dia:string>#double#</dia:string>
+          </dia:attribute>
+            <dia:string>#0#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_res_style#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#g_use_wzgraphics#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wfs_conf_description#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="operations"/>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O42">
+        <dia:point val="131,-48"/>
+      </dia:attribute>
+        <dia:rectangle val="130.95,-48.05;146.95,-40.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="15.9"/>
+      </dia:attribute>
+        <dia:real val="7.1999999999999993"/>
+      </dia:attribute>
+        <dia:string>#wfs_featuretype#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_srs#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_searchable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#featuretype_abstract#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O43">
+        <dia:point val="115.3,-49.7"/>
+      </dia:attribute>
+        <dia:rectangle val="115.25,-50.785;131.7,-43.4825"/>
+      </dia:attribute>
+      <dia:attribute name="orth_points">
+        <dia:point val="122,-49.7"/>
+        <dia:point val="122,-44.4"/>
+        <dia:point val="130.95,-44.4"/>
+      </dia:attribute>
+      <dia:attribute name="orth_orient">
+        <dia:enum val="1"/>
+      </dia:attribute>
+      <dia:attribute name="autorouting">
+      </dia:attribute>
+      </dia:attribute>
+      <dia:attribute name="direction">
+      </dia:attribute>
+      <dia:attribute name="ends">
+        <dia:composite>
+          <dia:attribute name="role">
+          </dia:attribute>
+          <dia:attribute name="multiplicity">
+          </dia:attribute>
+          <dia:attribute name="arrow">
+          </dia:attribute>
+          <dia:attribute name="aggregate">
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+            <dia:string>#on delete cascade on update cascade#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O25" connection="15"/>
+        <dia:connection handle="1" to="O42" connection="22"/>
+      </dia:connections>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O44">
+        <dia:point val="49.9,-31.1"/>
+      </dia:attribute>
+        <dia:rectangle val="49.85,-37.55;98.3,-30.585"/>
+      </dia:attribute>
+        <dia:point val="85.5,-31.1"/>
+        <dia:point val="85.5,-36.8"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#gui_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="9"/>
+        <dia:connection handle="1" to="O65" connection="6"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O45">
+        <dia:point val="98,-50.5"/>
+      </dia:attribute>
+        <dia:rectangle val="90.25,-51.585;104.85,-40.3825"/>
+      </dia:attribute>
+        <dia:point val="95,-50.5"/>
+        <dia:point val="95,-41.3"/>
+        <dia:point val="91,-41.3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O25" connection="12"/>
+        <dia:connection handle="1" to="O29" connection="11"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O46">
+        <dia:point val="160,-62"/>
+      </dia:attribute>
+        <dia:rectangle val="159.95,-62.05;172.1,-57.15"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="12.050000000000001"/>
+      </dia:attribute>
+        <dia:real val="4.8000000000000007"/>
+      </dia:attribute>
+        <dia:string>#wfs_element#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#element_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#element_name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#element_type#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+            <dia:string>#wfs_element_idx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O47">
+        <dia:point val="146.9,-44.5"/>
+      </dia:attribute>
+        <dia:rectangle val="146.15,-58.45;160.75,-43.985"/>
+      </dia:attribute>
+        <dia:point val="154,-44.5"/>
+        <dia:point val="154,-57.7"/>
+        <dia:point val="160,-57.7"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O42" connection="13"/>
+        <dia:connection handle="1" to="O46" connection="14"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O48">
+        <dia:point val="34,-112"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-112.05;45.4,-107.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="11.35"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#wms_format#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#data_type#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#''#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#data_format#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(100)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O49">
+        <dia:point val="73,-122.3"/>
+      </dia:attribute>
+        <dia:rectangle val="44.6495,-123.385;73.05,-109.082"/>
+      </dia:attribute>
+        <dia:point val="63,-122.3"/>
+        <dia:point val="63,-110"/>
+        <dia:point val="45.3995,-110"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O19" connection="20"/>
+        <dia:connection handle="1" to="O48" connection="14"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O50">
+        <dia:point val="34,-107"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-107.05;43.65,-103.75"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="3.2000000000000002"/>
+      </dia:attribute>
+        <dia:string>#wms_srs#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O51">
+        <dia:point val="73,-117.5"/>
+      </dia:attribute>
+        <dia:rectangle val="42.8986,-118.585;73.05,-104.483"/>
+      </dia:attribute>
+        <dia:point val="67,-117.5"/>
+        <dia:point val="67,-105.4"/>
+        <dia:point val="43.6486,-105.4"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O19" connection="32"/>
+        <dia:connection handle="1" to="O50" connection="12"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O52">
+        <dia:point val="34,-116"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-116.05;46.8,-112.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="12.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#wms_md_topic_category#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_md_topic_category_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O53">
+        <dia:point val="73,-127.1"/>
+      </dia:attribute>
+        <dia:rectangle val="46.0499,-128.185;73.05,-113.483"/>
+      </dia:attribute>
+        <dia:point val="58,-127.1"/>
+        <dia:point val="58,-114.4"/>
+        <dia:point val="46.7999,-114.4"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O19" connection="8"/>
+        <dia:connection handle="1" to="O52" connection="12"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O54">
+        <dia:point val="-47,-117"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-117.05;-32.45,-112.95"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="4"/>
+      </dia:attribute>
+        <dia:string>#md_topic_category#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffffff"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#md_topic_category_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#md_topic_category_code_en#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#md_topic_category_code_de#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O55">
+        <dia:point val="-32.5,-115.1"/>
+      </dia:attribute>
+        <dia:rectangle val="-32.55,-116.185;34.75,-114.382"/>
+      </dia:attribute>
+        <dia:point val="0.75,-115.1"/>
+        <dia:point val="0.75,-115.3"/>
+        <dia:point val="34,-115.3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O54" connection="9"/>
+        <dia:connection handle="1" to="O52" connection="3"/>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O56">
+        <dia:point val="160,-50"/>
+      </dia:attribute>
+        <dia:rectangle val="159.95,-50.95;211.4,-47.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="51.350000000000001"/>
+      </dia:attribute>
+        <dia:real val="2.2000000000000002"/>
+      </dia:attribute>
+      <dia:attribute name="line_colour">
+      </dia:attribute>
+      <dia:attribute name="fill_colour">
+      </dia:attribute>
+        <dia:string>#postgres:post#</dia:string>
+      </dia:attribute>
+      <dia:attribute name="text">
+        <dia:composite type="text">
+          <dia:attribute name="string">
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_element','wfs_element_id'), (SELECT max(wfs_element_id) FROM wfs_element), true);#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="font">
+          </dia:attribute>
+          <dia:attribute name="height">
+          </dia:attribute>
+          <dia:attribute name="pos">
+            <dia:point val="160.3,-48.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="alignment">
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O57">
+        <dia:point val="160,-46"/>
+      </dia:attribute>
+        <dia:rectangle val="159.95,-46.95;192.85,-43.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="32.800000000000004"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#innodb:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE wfs_element CHANGE COLUMN element_id element_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="160.3,-44.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O58">
+        <dia:point val="160,-55"/>
+      </dia:attribute>
+        <dia:rectangle val="159.95,-55.95;195.65,-51.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="35.600000000000001"/>
+      </dia:attribute>
+        <dia:real val="3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#postgres:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE wfs_element_id_seq;
+ALTER TABLE wfs_element ALTER COLUMN element_id SET DEFAULT nextval('wfs_element_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="160.3,-53.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O59">
+        <dia:point val="131,-34"/>
+      </dia:attribute>
+        <dia:rectangle val="130.95,-34.95;188,-31.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="56.950000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_featuretype','wfs_featuretype_id'), (SELECT max(wfs_featuretype_id) FROM wfs_featuretype), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="131.3,-32.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O60">
+        <dia:point val="131,-30"/>
+      </dia:attribute>
+        <dia:rectangle val="130.95,-30.95;168.05,-27.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="37"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE wfs_featuretype CHANGE COLUMN featuretype_id featuretype_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="131.3,-28.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O61">
+        <dia:point val="131,-39"/>
+      </dia:attribute>
+        <dia:rectangle val="130.95,-39.95;170.85,-35.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="39.800000000000004"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE wfs_featuretype_id_seq;
+ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_id SET DEFAULT nextval('wfs_featuretype_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="131.3,-37.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O62">
+        <dia:point val="53,-61"/>
+      </dia:attribute>
+        <dia:rectangle val="52.95,-61.95;96,-58.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="42.950000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffc0cb"/>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('layer','layer_id'), (SELECT max(layer_id) FROM layer), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="53.3,-59.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O63">
+        <dia:point val="53,-57"/>
+      </dia:attribute>
+        <dia:rectangle val="52.95,-57.95;82.35,-54.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="29.300000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE layer CHANGE COLUMN layer_id layer_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="53.3,-55.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O64">
+        <dia:point val="53,-66"/>
+      </dia:attribute>
+        <dia:rectangle val="52.95,-66.95;83.75,-62.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="30.700000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE layer_id_seq;
+ALTER TABLE layer ALTER COLUMN layer_id SET DEFAULT nextval('layer_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="53.3,-64.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O65">
+        <dia:point val="80,-40"/>
+      </dia:attribute>
+        <dia:rectangle val="79.95,-40.05;91.05,-36.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="11"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#gui_wfs_conf#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#fkey_gui_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_wfs_conf_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O66">
+        <dia:point val="144,-14.9"/>
+      </dia:attribute>
+        <dia:rectangle val="90.25,-40.05;144.05,-14.385"/>
+      </dia:attribute>
+        <dia:point val="95,-14.9"/>
+        <dia:point val="95,-39.3"/>
+        <dia:point val="91,-39.3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O41" connection="26"/>
+        <dia:connection handle="1" to="O65" connection="4"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O67">
+        <dia:point val="131,-42.1"/>
+      </dia:attribute>
+        <dia:rectangle val="125.9,-43.185;164.4,-23.25"/>
+      </dia:attribute>
+        <dia:point val="129,-42.1"/>
+        <dia:point val="129,-26"/>
+        <dia:point val="151.6,-26"/>
+        <dia:point val="151.6,-24"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O42" connection="18"/>
+        <dia:connection handle="1" to="O41" connection="1"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O68">
+        <dia:point val="-47,-61"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-61.05;-33.85,-53.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="13.1"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#gui_kml#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#kml_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_mb_user_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#kml_doc#</dia:string>
+          </dia:attribute>
+            <dia:string>#text#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#kml_name#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(64)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#kml_description#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#kml_timestamp#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O69">
+        <dia:point val="34,-56"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-56.05;45.05,-47.95"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="8"/>
+      </dia:attribute>
+        <dia:string>#gui_treegde#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#90ee90"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#lft#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#rgt#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#my_layer_title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#layer#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wms_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="operations">
+        <dia:composite type="umloperation">
+            <dia:string>#gui_treegde_idx#</dia:string>
+          </dia:attribute>
+            <dia:string>#btree#</dia:string>
+          </dia:attribute>
+            <dia:string>#unique index#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="inheritance_type">
+          </dia:attribute>
+          <dia:attribute name="query">
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="parameters">
+            <dia:composite type="umlparameter">
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              <dia:attribute name="kind">
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O70">
+        <dia:point val="126,-87"/>
+      </dia:attribute>
+        <dia:rectangle val="125.95,-87.05;139.15,-83.75"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#keyword#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#keyword_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+            <dia:string>#keyword_idx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O71">
+        <dia:point val="89,-71"/>
+      </dia:attribute>
+        <dia:rectangle val="88.95,-71.05;102.15,-65.35"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="5.5999999999999996"/>
+      </dia:attribute>
+        <dia:string>#layer_style#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#fkey_layer_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#name#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#title#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#legendurl#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#legendurlformat#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O72">
+        <dia:point val="67.5,-71.5"/>
+      </dia:attribute>
+        <dia:rectangle val="67.45,-72.585;89.75,-69.3825"/>
+      </dia:attribute>
+        <dia:point val="78,-71.5"/>
+        <dia:point val="78,-70.3"/>
+        <dia:point val="89,-70.3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#layer_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O23" connection="23"/>
+        <dia:connection handle="1" to="O71" connection="3"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O73">
+        <dia:point val="89,-86"/>
+      </dia:attribute>
+        <dia:rectangle val="88.95,-86.05;102.15,-79.55"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="6.4000000000000004"/>
+      </dia:attribute>
+        <dia:string>#layer_epsg#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#epsg#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#minx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#miny#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#maxx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#maxy#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O74">
+        <dia:point val="67.5,-76.3"/>
+      </dia:attribute>
+        <dia:rectangle val="67.45,-81.65;89.75,-75.785"/>
+      </dia:attribute>
+        <dia:point val="75,-76.3"/>
+        <dia:point val="75,-80.9"/>
+        <dia:point val="89,-80.9"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O23" connection="11"/>
+        <dia:connection handle="1" to="O73" connection="16"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O75">
+        <dia:point val="89,-79"/>
+      </dia:attribute>
+        <dia:rectangle val="88.95,-79.05;102.15,-75.75"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#layer_load_count#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#load_count#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O76">
+        <dia:point val="67.5,-74.7"/>
+      </dia:attribute>
+        <dia:rectangle val="67.45,-78.15;89.7005,-74.185"/>
+      </dia:attribute>
+        <dia:point val="78,-74.7"/>
+        <dia:point val="78,-77.4"/>
+        <dia:point val="88.9505,-77.4"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O23" connection="15"/>
+        <dia:connection handle="1" to="O75" connection="12"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O77">
+        <dia:point val="89,-75"/>
+      </dia:attribute>
+        <dia:rectangle val="88.95,-75.05;98.3,-71.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="9.25"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#layer_keyword#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_keyword_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O78">
+        <dia:point val="67.5,-73.1"/>
+      </dia:attribute>
+        <dia:rectangle val="67.5,-74.185;89.0707,-72.1825"/>
+      </dia:attribute>
+        <dia:point val="89,-73.1"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O23" connection="19"/>
+        <dia:connection handle="1" to="O77" connection="8"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O79">
+        <dia:point val="125.95,-85.4"/>
+      </dia:attribute>
+        <dia:rectangle val="97.5,-86.485;126,-72.1825"/>
+      </dia:attribute>
+        <dia:point val="112.1,-85.4"/>
+        <dia:point val="112.1,-73.1"/>
+        <dia:point val="98.25,-73.1"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O70" connection="12"/>
+        <dia:connection handle="1" to="O77" connection="9"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O80">
+        <dia:point val="126,-112"/>
+      </dia:attribute>
+        <dia:rectangle val="125.95,-112.05;137.4,-101.55"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="10.4"/>
+      </dia:attribute>
+        <dia:string>#mb_log#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#time_client#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(13)#</dia:string>
+          </dia:attribute>
+            <dia:string>#'0'#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#time_server#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#time_readable#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#mb_session#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#gui#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#module#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#ip#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(20)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#username#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          <dia:attribute name="name">
+            <dia:string>#userid#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>##</dia:string>
+          </dia:attribute>
+          <dia:attribute name="comment">
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="abstract">
+            <dia:boolean val="false"/>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#request#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O81">
+      <dia:attribute name="obj_pos">
+        <dia:point val="126,-95"/>
+      </dia:attribute>
+      <dia:attribute name="obj_bb">
+        <dia:rectangle val="125.95,-95.95;165.5,-92.75"/>
+      </dia:attribute>
+      <dia:attribute name="elem_corner">
+      </dia:attribute>
+      <dia:attribute name="elem_width">
+        <dia:real val="39.450000000000003"/>
+      </dia:attribute>
+      <dia:attribute name="elem_height">
+      </dia:attribute>
+        <dia:color val="#000000"/>
+      </dia:attribute>
+      </dia:attribute>
+      <dia:attribute name="stereotype">
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('mb_log','id'), (SELECT max(id) FROM mb_log), true);#</dia:string>
+          </dia:attribute>
+            <dia:font family="monospace" style="0" name="Courier"/>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="126.3,-93.3575"/>
+          </dia:attribute>
+          <dia:attribute name="color">
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O82">
+        <dia:point val="126,-91"/>
+      </dia:attribute>
+        <dia:rectangle val="125.95,-91.95;151.5,-88.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="25.450000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE mb_log CHANGE COLUMN id id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:real val="0.80000000000000004"/>
+          </dia:attribute>
+            <dia:point val="126.3,-89.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O83">
+        <dia:point val="126,-100"/>
+      </dia:attribute>
+        <dia:rectangle val="125.95,-100.95;157.8,-96.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="31.75"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE mb_log_id_seq;
+ALTER TABLE mb_log ALTER COLUMN mb_log_id SET DEFAULT nextval('mb_log_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="126.3,-98.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O84">
+        <dia:point val="126,-123"/>
+      </dia:attribute>
+        <dia:rectangle val="125.95,-123.05;141.6,-113.35"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="15.550000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#mb_monitor#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      <dia:attribute name="suppress_attributes">
+      </dia:attribute>
+      <dia:attribute name="suppress_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_attributes">
+        <dia:boolean val="true"/>
+      </dia:attribute>
+      <dia:attribute name="visible_operations">
+      </dia:attribute>
+      <dia:attribute name="visible_comments">
+      </dia:attribute>
+      <dia:attribute name="wrap_operations">
+      </dia:attribute>
+      <dia:attribute name="wrap_after_char">
+        <dia:int val="40"/>
+      </dia:attribute>
+      <dia:attribute name="comment_line_length">
+      </dia:attribute>
+      <dia:attribute name="comment_tagging">
+      </dia:attribute>
+      <dia:attribute name="line_color">
+      </dia:attribute>
+      <dia:attribute name="fill_color">
+      </dia:attribute>
+      <dia:attribute name="text_color">
+      </dia:attribute>
+      <dia:attribute name="normal_font">
+      </dia:attribute>
+      <dia:attribute name="abstract_font">
+        <dia:font family="monospace" style="88" name="Courier-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font">
+        <dia:font family="monospace" style="8" name="Courier-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="classname_font">
+        <dia:font family="sans" style="80" name="Helvetica-Bold"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font">
+        <dia:font family="sans" style="88" name="Helvetica-BoldOblique"/>
+      </dia:attribute>
+      <dia:attribute name="comment_font">
+        <dia:font family="sans" style="8" name="Helvetica-Oblique"/>
+      </dia:attribute>
+      <dia:attribute name="normal_font_height">
+      </dia:attribute>
+      <dia:attribute name="polymorphic_font_height">
+      </dia:attribute>
+      <dia:attribute name="abstract_font_height">
+      </dia:attribute>
+      <dia:attribute name="classname_font_height">
+        <dia:real val="1"/>
+      </dia:attribute>
+      <dia:attribute name="abstract_classname_font_height">
+      </dia:attribute>
+      <dia:attribute name="comment_font_height">
+      </dia:attribute>
+      <dia:attribute name="attributes">
+        <dia:composite type="umlattribute">
+            <dia:string>#upload_id#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="type">
+          </dia:attribute>
+          <dia:attribute name="value">
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="visibility">
+            <dia:enum val="2"/>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="class_scope">
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_wms_id#</dia:string>
+          </dia:attribute>
+            <dia:string>#integer#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#status#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:enum val="0"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#status_comment#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#'' NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#timestamp_begin#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#timestamp_end#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#upload_url#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#updated#</dia:string>
+          </dia:attribute>
+            <dia:string>#char(1)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#image#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#map_url#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(2048)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O85">
+        <dia:point val="90.3503,-115.4"/>
+      </dia:attribute>
+        <dia:rectangle val="90.3003,-121.85;126.75,-114.885"/>
+      </dia:attribute>
+        <dia:point val="108.175,-115.4"/>
+        <dia:point val="108.175,-121.1"/>
+        <dia:point val="126,-121.1"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O19" connection="72"/>
+        <dia:connection handle="1" to="O84" connection="8"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O86">
+        <dia:point val="-47,-124"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-124.05;-34.2,-118.35"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#mb_user_wmc#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#wmc_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#fkey_user_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#0 NOT NULL#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wmc#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wmc_title#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(50)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#wmc_timestamp#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="template">
+      </dia:attribute>
+      <dia:attribute name="templates"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O87">
+        <dia:point val="-47.0504,-20.6"/>
+      </dia:attribute>
+        <dia:rectangle val="-60.85,-122.05;-46.25,-20.085"/>
+      </dia:attribute>
+        <dia:point val="-56.2733,-20.6"/>
+        <dia:point val="-56.2733,-121.3"/>
+        <dia:point val="-47,-121.3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#mb_user_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O1" connection="46"/>
+        <dia:connection handle="1" to="O86" connection="10"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O88">
+        <dia:point val="-47,-25.5"/>
+      </dia:attribute>
+        <dia:rectangle val="-60.85,-58.25;-46.25,-24.985"/>
+      </dia:attribute>
+        <dia:point val="-52.1242,-25.5"/>
+        <dia:point val="-52.1242,-57.5"/>
+        <dia:point val="-47,-57.5"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O1" connection="12"/>
+        <dia:connection handle="1" to="O68" connection="12"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O89">
+        <dia:point val="34,-28.7"/>
+      </dia:attribute>
+        <dia:rectangle val="-34.6011,-58.15;34.05,-28.185"/>
+      </dia:attribute>
+        <dia:point val="21.1025,-28.7"/>
+        <dia:point val="21.1025,-57.4"/>
+        <dia:point val="-33.8511,-57.4"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="14"/>
+        <dia:connection handle="1" to="O68" connection="22"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O90">
+        <dia:point val="-47,-99"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-99.05;-37.7,-94.15"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#translations#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#trs_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#locale#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(8)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#msgid#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(512)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#msgstr#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+            <dia:string>#msg_id_idx#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#index#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+              </dia:attribute>
+            </dia:composite>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O91">
+        <dia:point val="-47,-88"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-88.95;-0.5,-85.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="46.450000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('translations','trs_id'), (SELECT max(trs_id) FROM translations), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-86.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O92">
+        <dia:point val="-47,-84"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-84.95;-16.6,-81.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="30.350000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE translations CHANGE COLUMN trs_id trs_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-82.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O93">
+        <dia:point val="-47,-93"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-93.95;-12.05,-89.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="34.899999999999999"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE translations_id_seq;
+ALTER TABLE translations ALTER COLUMN trs_id SET DEFAULT nextval('translations_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-91.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O94">
+        <dia:point val="78,-30"/>
+      </dia:attribute>
+        <dia:rectangle val="77.95,-30.05;92.2,-13.15"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="14.15"/>
+      </dia:attribute>
+        <dia:real val="16.800000000000004"/>
+      </dia:attribute>
+        <dia:string>#wfs_conf_element#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffa500"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#wfs_conf_element_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_geom#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#0#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_gid#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_search#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_pos#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_style_id#</dia:string>
+          </dia:attribute>
+            <dia:string>#varchar(255)#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_toupper#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_label#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_label_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_show#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_respos#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_form_element_html#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_edit#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_mandatory#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_auth_varname#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_show_detail#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#f_operator#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:attribute name="operations"/>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O95">
+        <dia:point val="144,-13.3"/>
+      </dia:attribute>
+        <dia:rectangle val="91.4,-14.385;144.05,-12.2825"/>
+      </dia:attribute>
+      <dia:attribute name="orth_points">
+        <dia:point val="94,-13.3"/>
+        <dia:point val="94,-13.2"/>
+        <dia:point val="92.15,-13.2"/>
+      </dia:attribute>
+      <dia:attribute name="orth_orient">
+        <dia:enum val="1"/>
+      </dia:attribute>
+      <dia:attribute name="autorouting">
+      </dia:attribute>
+      </dia:attribute>
+      <dia:attribute name="direction">
+      </dia:attribute>
+      <dia:attribute name="ends">
+        <dia:composite>
+          <dia:attribute name="role">
+            <dia:string>#wfs_conf_id#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="multiplicity">
+          </dia:attribute>
+          <dia:attribute name="arrow">
+          </dia:attribute>
+          <dia:attribute name="aggregate">
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+            <dia:string>#on delete cascade on update cascade#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O41" connection="30"/>
+        <dia:connection handle="1" to="O94" connection="7"/>
+      </dia:connections>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O96">
+        <dia:point val="78,-6"/>
+      </dia:attribute>
+        <dia:rectangle val="77.95,-6.95;136.4,-3.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="58.350000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_conf_element','wfs_conf_element_id'), (SELECT max(wfs_conf_element_id) FROM wfs_conf_element), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="78.3,-4.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O97">
+        <dia:point val="78,-2"/>
+      </dia:attribute>
+        <dia:rectangle val="77.95,-2.95;118.9,0.25"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="40.850000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE wfs_conf_element CHANGE COLUMN wfs_conf_element_id wfs_conf_element_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="78.3,-0.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O98">
+        <dia:point val="78,-11"/>
+      </dia:attribute>
+        <dia:rectangle val="77.95,-11.95;120.3,-7.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="42.25"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE wfs_conf_element_id_seq;
+ALTER TABLE wfs_conf_element ALTER COLUMN wfs_conf_element_id SET DEFAULT nextval('wfs_conf_element_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="78.3,-9.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O99">
+        <dia:point val="131,-64"/>
+      </dia:attribute>
+        <dia:rectangle val="130.95,-64.05;145.55,-60.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="14.5"/>
+      </dia:attribute>
+        <dia:real val="3.2000000000000002"/>
+      </dia:attribute>
+        <dia:string>#wfs_featuretype_keyword#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#fkey_featuretype_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O100">
+        <dia:point val="131,-57"/>
+      </dia:attribute>
+        <dia:rectangle val="130.95,-57.05;148,-52.15"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="16.949999999999999"/>
+      </dia:attribute>
+        <dia:real val="4.8000000000000007"/>
+      </dia:attribute>
+        <dia:string>#wfs_featuretype_namespace#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#fkey_wfs_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#namespace#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:string>#''#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#namespace_location#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O101">
+        <dia:point val="131,-46.1"/>
+      </dia:attribute>
+        <dia:rectangle val="117.15,-53.45;131.75,-45.585"/>
+      </dia:attribute>
+        <dia:point val="125,-46.1"/>
+        <dia:point val="125,-52.7"/>
+        <dia:point val="131,-52.7"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#featuretype_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O42" connection="8"/>
+        <dia:connection handle="1" to="O100" connection="14"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O102">
+        <dia:point val="115.3,-51.3"/>
+      </dia:attribute>
+        <dia:rectangle val="115.25,-55.05;131.75,-50.785"/>
+      </dia:attribute>
+        <dia:point val="122,-51.3"/>
+        <dia:point val="122,-54.3"/>
+        <dia:point val="131,-54.3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#wfs_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O25" connection="11"/>
+        <dia:connection handle="1" to="O100" connection="10"/>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O103">
+        <dia:point val="144,-5"/>
+      </dia:attribute>
+        <dia:rectangle val="143.95,-5.95;191.2,-2.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="47.149999999999999"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('wfs_conf','wfs_conf_id'), (SELECT max(wfs_conf_id) FROM wfs_conf), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="144.3,-3.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O104">
+        <dia:point val="144,-1"/>
+      </dia:attribute>
+        <dia:rectangle val="143.95,-1.95;176.5,1.25"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="32.450000000000003"/>
+      </dia:attribute>
+        <dia:real val="2.2000000000000002"/>
+      </dia:attribute>
+      <dia:attribute name="line_colour">
+      </dia:attribute>
+      <dia:attribute name="fill_colour">
+      </dia:attribute>
+      </dia:attribute>
+      <dia:attribute name="text">
+        <dia:composite type="text">
+          <dia:attribute name="string">
+            <dia:string>#ALTER TABLE wfs_conf CHANGE COLUMN wfs_conf_id wfs_conf_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          <dia:attribute name="font">
+          </dia:attribute>
+          <dia:attribute name="height">
+          </dia:attribute>
+          <dia:attribute name="pos">
+            <dia:point val="144.3,0.6425"/>
+          </dia:attribute>
+          </dia:attribute>
+          <dia:attribute name="alignment">
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O105">
+        <dia:point val="144,-10"/>
+      </dia:attribute>
+        <dia:rectangle val="143.95,-10.95;177.9,-6.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="33.850000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE wfs_conf_id_seq;
+ALTER TABLE wfs_conf ALTER COLUMN wfs_conf_id SET DEFAULT nextval('wfs_conf_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="144.3,-8.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O106">
+        <dia:point val="146.9,-46.1"/>
+      </dia:attribute>
+        <dia:rectangle val="144.75,-62.85;159.35,-45.585"/>
+      </dia:attribute>
+        <dia:point val="151,-46.1"/>
+        <dia:point val="151,-62.1"/>
+        <dia:point val="145.5,-62.1"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O42" connection="9"/>
+        <dia:connection handle="1" to="O99" connection="9"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O107">
+        <dia:point val="126,-84.3"/>
+      </dia:attribute>
+        <dia:rectangle val="117.15,-85.385;131.75,-61.1825"/>
+      </dia:attribute>
+        <dia:point val="122,-84.3"/>
+        <dia:point val="122,-62.1"/>
+        <dia:point val="131,-62.1"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O70" connection="10"/>
+        <dia:connection handle="1" to="O99" connection="8"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O108">
+        <dia:point val="34,-32.3"/>
+      </dia:attribute>
+        <dia:rectangle val="20.15,-53.25;34.75,-31.785"/>
+      </dia:attribute>
+        <dia:point val="30,-32.3"/>
+        <dia:point val="30,-52.5"/>
+        <dia:point val="34,-52.5"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+            <dia:string>#gui_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="3"/>
+        <dia:connection handle="1" to="O69" connection="12"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O109">
+        <dia:point val="53,-71.5"/>
+      </dia:attribute>
+        <dia:rectangle val="38.75,-72.585;53.05,-55.25"/>
+      </dia:attribute>
+        <dia:point val="39.5,-71.5"/>
+        <dia:point val="39.5,-56"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O23" connection="22"/>
+        <dia:connection handle="1" to="O69" connection="1"/>
+    </dia:object>
+    <dia:object type="UML - Class" version="0" id="O110">
+        <dia:point val="-47,-81"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-81.05;-33.85,-74.55"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#sld_user_layer#</dia:string>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#ffffff"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#sld_user_layer_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#sld_xml#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+            <dia:string>#use_sld#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O111">
+        <dia:point val="-47,-68"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-68.95;8.6,-65.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="55.550000000000004"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#postgres:post#</dia:string>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('sld_user_layer','sld_user_layer_id'), (SELECT max(sld_user_layer_id) FROM sld_user_layer), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-66.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O112">
+        <dia:point val="-47,-64"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-64.95;-8.2,-61.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="38.75"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#innodb:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE sld_user_layer CHANGE COLUMN sld_user_layer_id sld_user_layer_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-62.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O113">
+        <dia:point val="-47,-73"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-73.95;-6.8,-69.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="40.149999999999999"/>
+      </dia:attribute>
+        <dia:real val="3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:string>#postgres:pre#</dia:string>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE sld_user_layer_id_seq;
+ALTER TABLE sld_user_layer ALTER COLUMN sld_user_layer_id SET DEFAULT nextval('sld_user_layer_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-71.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O114">
+        <dia:point val="-47,-22.3"/>
+      </dia:attribute>
+        <dia:rectangle val="-60.85,-79.05;-46.25,-21.785"/>
+      </dia:attribute>
+        <dia:point val="-54.062,-22.3"/>
+        <dia:point val="-54.062,-78.3"/>
+        <dia:point val="-47,-78.3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O1" connection="20"/>
+        <dia:connection handle="1" to="O110" connection="10"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O115">
+        <dia:point val="34,-29.5"/>
+      </dia:attribute>
+        <dia:rectangle val="-34.65,-77.45;34.05,-28.985"/>
+      </dia:attribute>
+        <dia:point val="23,-29.5"/>
+        <dia:point val="23,-76.7"/>
+        <dia:point val="-33.9,-76.7"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+            <dia:string>#fkey_gui_id#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O11" connection="12"/>
+        <dia:connection handle="1" to="O110" connection="15"/>
+    </dia:object>
+    <dia:object type="UML - Association" version="1" id="O116">
+        <dia:point val="53,-73.1"/>
+      </dia:attribute>
+        <dia:rectangle val="-34.65,-79.05;53.05,-72.585"/>
+      </dia:attribute>
+        <dia:point val="24,-73.1"/>
+        <dia:point val="24,-78.3"/>
+        <dia:point val="-33.9,-78.3"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+        <dia:composite>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+      <dia:connections>
+        <dia:connection handle="0" to="O23" connection="18"/>
+        <dia:connection handle="1" to="O110" connection="11"/>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O117">
+        <dia:point val="-47,-47"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-47.95;-4,-44.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="42.950000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_kml','kml_id'), (SELECT max(kml_id) FROM gui_kml), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-45.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O118">
+        <dia:point val="-47,-43"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-43.95;-18.35,-40.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="28.600000000000001"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE gui_kml CHANGE COLUMN kml_id kml_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-41.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O119">
+        <dia:point val="-47,-52"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-52.95;-16.95,-48.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="30"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE kml_id_seq;
+ALTER TABLE gui_kml ALTER COLUMN kml_id SET DEFAULT nextval('kml_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-50.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O120">
+        <dia:point val="34,-41"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-41.95;74.9,-38.75"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:color val="#90ee90"/>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_treegde','id'), (SELECT max(id) FROM layer), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="34.3,-39.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O121">
+        <dia:point val="34,-37"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-37.95;61.25,-34.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="27.200000000000003"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE gui_treegde CHANGE COLUMN id id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="34.3,-35.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O122">
+        <dia:point val="34,-46"/>
+      </dia:attribute>
+        <dia:rectangle val="33.95,-46.95;66.85,-42.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="32.800000000000004"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE gui_treegde_id_seq;
+ALTER TABLE gui_treegde ALTER COLUMN id SET DEFAULT nextval('gui_treegde_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="34.3,-44.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O123">
+        <dia:point val="126,-77"/>
+      </dia:attribute>
+        <dia:rectangle val="125.95,-77.95;171.8,-74.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="45.75"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('keyword','keyword_id'), (SELECT max(keyword_id) FROM keyword), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="126.3,-75.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O124">
+        <dia:point val="126,-73"/>
+      </dia:attribute>
+        <dia:rectangle val="125.95,-73.95;157.45,-70.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="31.400000000000002"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE keyword CHANGE COLUMN keyword_id keyword_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="126.3,-71.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O125">
+        <dia:point val="126,-82"/>
+      </dia:attribute>
+        <dia:rectangle val="125.95,-82.95;158.85,-78.95"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE keyword_id_seq;
+ALTER TABLE keyword ALTER COLUMN keyword_id SET DEFAULT nextval('keyword_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="126.3,-80.3575"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O126">
+        <dia:point val="-47,-106"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-106.95;12.8,-103.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="59.75"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('md_topic_category','md_topic_category_id'), (SELECT max(md_topic_category_id) FROM md_topic_category), true);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-104.358"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O127">
+        <dia:point val="-47,-102"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-102.95;-5.05,-99.75"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="41.899999999999999"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#ALTER TABLE md_topic_category CHANGE COLUMN md_topic_category_id md_topic_category_id integer NOT NULL AUTO_INCREMENT;#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-100.358"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+    <dia:object type="UML - SmallPackage" version="0" id="O128">
+        <dia:point val="-47,-111"/>
+      </dia:attribute>
+        <dia:rectangle val="-47.05,-111.95;-3.65,-107.95"/>
+      </dia:attribute>
+      </dia:attribute>
+        <dia:real val="43.300000000000004"/>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+      </dia:attribute>
+            <dia:string>#CREATE SEQUENCE md_topic_category_id_seq;
+ALTER TABLE md_topic_category ALTER COLUMN md_topic_category_id SET DEFAULT nextval('md_topic_category_id_seq'::regclass);#</dia:string>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+            <dia:point val="-46.7,-109.358"/>
+          </dia:attribute>
+          </dia:attribute>
+          </dia:attribute>
+        </dia:composite>
+      </dia:attribute>
+    </dia:object>
+  </dia:layer>
+</dia:diagram>
More information about the Mapbender_commits mailing list
